[Geoprisma-dev] Editing widgets - in production ?
Alexandre Dube adube at mapgears.com
Tue Jan 18 13:04:43 EST 2011
Hi Yves,
   By default, a View in PostgreSQL is "read-only".   In order to be
able to make insert/update/delete transactions in views, you have to
manually take care of it.
   You're right to say that it is not related with the UI.
Regards,
Alexandre
On 11-01-18 11:20 AM, Yves Moisan wrote:
>> Hi,
>>   Is anyone currently using the editing widgets in production ?  We
>> would like to modify them in the following days.  If no one ever used
>> them, we would make the changes without thinking "backward
>> compatibility".
>> Best regards,
> Hi Alexandre,
> You can consider you have a blank slate to start with.  One issue we
> have found with the edit widget is that we needed to use fake
> sequences to make it work with PG views.  This is probably not related
> with the UI though.  Just in case.
> Cheers,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
