[Geoprisma-dev] Script loading issue with Firefox 4
Alexandre Dube adube at mapgears.com
Wed Mar 30 11:53:02 EDT 2011
Etienne,
   Thanks for pointing this out.  Could you please open a ticket for
this issue ?  Also, I won't be able to work on it for the following days
(just to let you know).
Thanks,
Alexandre
On 11-03-30 11:25 AM, Etienne Dube wrote:
> Hi,
> I encountered a weird and intermittent issue related to the loading
> order of JavaScript files while testing the AttributeFilterPanel
> widget with Firefox 4. Some objects declared in the external GeoExt ux
> widgets were sporadically still undefined by the time Ext.onready()
> executes. Turns out FF4 behaves differently than 3.6 when loading
> dynamically-inserted <script> tags... see the following OpenLayers
> ticket: http://trac.osgeo.org/openlayers/ticket/2933 . The snippet of
> code from OL that we use for loading GeoExt ux .js files (when not
> using a minified build) is affected by this.
> Applying the changes from the patch in the OL ticket solves the issue.
> I did it for the AttributeFilterPanel ux, but it should be done too
> for the other ux'es.
> Etienne
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
