[Geoprisma-dev] Script loading issue with Firefox 4
Etienne Dube etienne.dube at boreal-is.com
Thu Mar 31 14:04:06 EDT 2011
There you go: http://trac.osgeo.org/geoprisma/ticket/203
No hurry to fix it, just wanted to notify the list so nobody waste as
much time as I did trying to make things work under FF4... I may be able
to fix it in the GeoExt sandboxes in the next days (if you don't mind
that I commit to MapGears' sandbox on svn.geoext.org).
Etienne
On 30/03/2011 11:53 AM, Alexandre Dube wrote:
> Etienne,
>   Thanks for pointing this out.  Could you please open a ticket for
> this issue ?  Also, I won't be able to work on it for the following
> days (just to let you know).
> Thanks,
> Alexandre
> On 11-03-30 11:25 AM, Etienne Dube wrote:
>> Hi,
>> I encountered a weird and intermittent issue related to the loading
>> order of JavaScript files while testing the AttributeFilterPanel
>> widget with Firefox 4. Some objects declared in the external GeoExt
>> ux widgets were sporadically still undefined by the time
>> Ext.onready() executes. Turns out FF4 behaves differently than 3.6
>> when loading dynamically-inserted <script> tags... see the following
>> OpenLayers ticket: http://trac.osgeo.org/openlayers/ticket/2933 . The
>> snippet of code from OL that we use for loading GeoExt ux .js files
>> (when not using a minified build) is affected by this.
>> Applying the changes from the patch in the OL ticket solves the
>> issue. I did it for the AttributeFilterPanel ux, but it should be
>> done too for the other ux'es.
>> Etienne
Etienne Dubé
Developer
Boréal Informations Stratégiques
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1
Canada
Tel. :  514.313.5951 #1131
Email: etienne.dube at boreal-is.com
More information about the Geoprisma-dev mailing list
