[Geoprisma-users] Trouble try to add the zoomslider widget
Stephen Woodbridge woodbri at swoodbridge.com
Thu Dec 3 21:46:07 EST 2009
More progress in getting the zoomslider to to almost work. I works but
the display is a little messed up and the geoexttoolbar widgets are not
working any more.
I also installed and turned on mod_deflate in apache2, but it does not
seem to be speeding anything up much. FF.NET tab reports went from 5m
30s to like 5m 17s
Also I added:
    var epsg4326 = new OpenLayers.Projection("EPSG:4326");
    var nInitZoom = 12;
    var oInitCenter = new OpenLayers.LonLat(-97.46537,32.0933);
        oMap.getProjectionObject()), nInitZoom);
to set the initial view of the map. It seems to set the zoom level
correctly, but the map is not centered on those coordinates.
Anyway, I will leave things like this for this evening as I have to
tackle some other tasks for a bit, in case anyone wants to look at it.
Stephen Woodbridge wrote:
> Hi,
> I am trying to add the zoomslider widget to my project, but am getting a
> Javascript error that seems to be because I missed adding something to
> my template or maybe it is ordered wrong.
> http://imaptools.com:8080/project/myproj/xslt/default.xslt
> http://imaptools.com:8080/project/myproj/config.xml
> http://imaptools.com:8080/project/myproj/  (takes 5m 30s to load)
> which errors out with "org is not defined" on:
>  Ext.apply(org.geoprisma.widget.geoexttoolbar.GeoExtToolbar.prototype, {
> Basically what I did was look at the Navtools sample and tried to
> migrate the relevant pieces into my then working app.
> Any ideas?
> -Steve
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
More information about the Geoprisma-users mailing list
