[Geoprisma-users] More Sample Problems - using r702
Stephen Woodbridge woodbri at swoodbridge.com
Fri Nov 13 17:38:49 EST 2009
Alexandre Dube wrote:
> I can confirm that problem as well locally.
> Stephen, could you confirm that you don't have this kind of behavior
> with trunk ?
OK, things look much better with trunk.
Only this one fails because it looks like apache does not have write
perms to my home dir where the svn is linked from:
http://imaptools.com:8080/gp2/samples/sandbox1/default/index.php
So I think trunk is looking good.
-Steve
> Alexandre
> Stephen Woodbridge wrote:
>> Hi guys,
>> I'm have gone through all the samples and the follow fail to load:
>> http://imaptools.com:8080/gp/samples/borealis-authentication/
>> http://imaptools.com:8080/gp/samples/helloworld/
>> http://imaptools.com:8080/gp/samples/mapfishlayertree/
>>   failed to load external entity
>> "/var/www/geoprisma-r702/src/client/templates/inc/Globals.xslt"
>>   and a lot more errors.
>> http://imaptools.com:8080/gp/samples/merge_split/
>> http://imaptools.com:8080/gp/samples/navtools/
>> http://imaptools.com:8080/gp/samples/queryonclick/myownmarker/
>> http://imaptools.com:8080/gp/samples/queryonclick/simple/
>> http://imaptools.com:8080/gp/samples/quickzoom/
>> http://imaptools.com:8080/gp/samples/sample0/
>>   loads with only "Droit insuffisant" message
>> http://imaptools.com:8080/gp/samples/sample1/default/
>>   loads with Google apikey error, but does not show a google layer
>> option.
>> http://imaptools.com:8080/gp/samples/sample1/auth_xml/
>>   loads with Google apikey error, and then displays "Droit
>> http://imaptools.com:8080/gp/samples/sandbox1/default/index.php
>> http://imaptools.com:8080/gp/samples/shortcut/activateresources/
>> http://imaptools.com:8080/gp/samples/shortcut/inpanel/
>> http://imaptools.com:8080/gp/samples/shortcut/intoolbar/
>> So it looks like there are probably three separate errors effecting
>> the bulk of these:
>> 1) is the Autoload.php path problem
>> 2) is an xslt path problem
>> 3) issues is the google apikey issue which seems to be cached
>> somewhere or defined also in some other place that config/*.xml
>> So it looks like these run:
>> http://imaptools.com:8080/gp/samples/acl2/
>> http://imaptools.com:8080/gp/samples/bdga/
>> http://imaptools.com:8080/gp/samples/complex_workspace/
>> http://imaptools.com:8080/gp/samples/google/  (with apikey issue)
>> http://imaptools.com:8080/gp/samples/onegeology/default/   (with
>> apikey issue)
>> http://imaptools.com:8080/gp/samples/release/
>> http://imaptools.com:8080/gp/samples/sampleLink/  ( but links might
>> have issues)
>> http://imaptools.com:8080/gp/samples/sampleObservable/
>> http://imaptools.com:8080/gp/samples/workspace/
>> Nothing critical from my point of view, but thought I could help with
>> the little extrat testing.
>> -Steve
>> Geoprisma-users mailing list
>> Geoprisma-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
More information about the Geoprisma-users mailing list
