[Geoprisma-users] More Sample Problems - using r702
Stephen Woodbridge woodbri at swoodbridge.com
Fri Nov 13 18:00:11 EST 2009
Alexandre,
http://imaptools.com:8080/gp/samples/     this is r706 download
http://imaptools.com:8080/gp2/samples/    this is trunk (at r706)
so it looks like the release process is not setting stuff up correctly:
Fails:
http://imaptools.com:8080/gp/samples/borealis-authentification/index.php
This works:
http://imaptools.com:8080/gp2/samples/borealis-authentification/index.php
-Steve
Stephen Woodbridge wrote:
> Alexandre Dube wrote:
>> I can confirm that problem as well locally.
>> Stephen, could you confirm that you don't have this kind of behavior
>> with trunk ?
> OK, things look much better with trunk.
> Only this one fails because it looks like apache does not have write
> perms to my home dir where the svn is linked from:
> http://imaptools.com:8080/gp2/samples/sandbox1/default/index.php
> So I think trunk is looking good.
> -Steve
>> Alexandre
>>> Hi guys,
>>> I'm have gone through all the samples and the follow fail to load:
>>> http://imaptools.com:8080/gp/samples/borealis-authentication/
>>> http://imaptools.com:8080/gp/samples/helloworld/
>>> http://imaptools.com:8080/gp/samples/mapfishlayertree/
>>>   failed to load external entity
>>> "/var/www/geoprisma-r702/src/client/templates/inc/Globals.xslt"
>>>   and a lot more errors.
>>> http://imaptools.com:8080/gp/samples/merge_split/
>>> http://imaptools.com:8080/gp/samples/navtools/
>>> http://imaptools.com:8080/gp/samples/queryonclick/myownmarker/
>>> http://imaptools.com:8080/gp/samples/queryonclick/simple/
>>> http://imaptools.com:8080/gp/samples/quickzoom/
>>> http://imaptools.com:8080/gp/samples/sample0/
>>>   loads with only "Droit insuffisant" message
>>> http://imaptools.com:8080/gp/samples/sample1/default/
>>>   loads with Google apikey error, but does not show a google layer
>>> option.
>>> http://imaptools.com:8080/gp/samples/sample1/auth_xml/
>>>   loads with Google apikey error, and then displays "Droit
>>> http://imaptools.com:8080/gp/samples/sandbox1/default/index.php
>>> http://imaptools.com:8080/gp/samples/shortcut/activateresources/
>>> http://imaptools.com:8080/gp/samples/shortcut/inpanel/
>>> http://imaptools.com:8080/gp/samples/shortcut/intoolbar/
>>> So it looks like there are probably three separate errors effecting
>>> the bulk of these:
>>> 1) is the Autoload.php path problem
>>> 2) is an xslt path problem
>>> 3) issues is the google apikey issue which seems to be cached
>>> somewhere or defined also in some other place that config/*.xml
>>> So it looks like these run:
>>> http://imaptools.com:8080/gp/samples/acl2/
>>> http://imaptools.com:8080/gp/samples/bdga/
>>> http://imaptools.com:8080/gp/samples/complex_workspace/
>>> http://imaptools.com:8080/gp/samples/google/  (with apikey issue)
>>> http://imaptools.com:8080/gp/samples/onegeology/default/   (with
>>> apikey issue)
>>> http://imaptools.com:8080/gp/samples/release/
>>> http://imaptools.com:8080/gp/samples/sampleLink/  ( but links might
>>> have issues)
>>> http://imaptools.com:8080/gp/samples/sampleObservable/
>>> http://imaptools.com:8080/gp/samples/workspace/
>>> Nothing critical from my point of view, but thought I could help with
>>> the little extrat testing.
>>> -Steve
>>> Geoprisma-users mailing list
>>> Geoprisma-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
More information about the Geoprisma-users mailing list
