[Geoprisma-users] Any thoughts on a geoprisma lite?
Stephen Woodbridge woodbri at swoodbridge.com
Tue Apr 19 16:20:30 EDT 2011
Hi Julien,
Thanks for the quick reply.
On 4/19/2011 3:46 PM, Julien-Samuel Lacroix wrote:
> Hi Steve,
> What we've done in the past is to use only the proxy of geoprisma
> without all the UI component. So we just defined services, datastores
> and resources and we pointed to the proxy instead of pointing to the WMS
> service.
Ok, this is an interesting idea. I might play with this to see how that
works.
> On 11-04-19 02:20 PM, Stephen Woodbridge wrote:
>> 1. Can this be done with geoprisma? How light-weight is it?
> The proxy, if you use the Memcached PHP session is fairly light-weight.
> I think it's a 30% overhead, but I'm not sure.
Hmmm, Memcached PHP session, this is another interesting idea that I
have not thought about.
>> 2. What are your thoughts on doing this as an apache2 module?
> We thought about it and it would be great! However it's not a small task
> and will probably need some funding to develop it.
I don't have a funded project yet for this, but in talking with clients
the issue of securing access to their tile caches always comes up.
Mostly I just side-step the issue because I don't have a good solution
to offer. But if I had a solution, I could probably sell it as an add-on
or bundled with another solution, which has got me looking into these
options.
I've done some mod_perl stuff in the past that was not that hard to
figure out and looking at mod_geocoache the coding seems straight
forward. I think the challenge is figuring out the security model. I
think there is a mod_oauth that might be applicable but I need to do
more reading on it.
Anyway, if I get enough time to figure anything out, I'll give the list
an update.
>> 3. Are you aware of other tools well suited for this?
> There's GeoShield, but it's Java running under Tomcat which cancel the
> fact that you use a Apache module for mod_geocache. Other than that, I
> don't know, I'm sorry.
Yeah, I try to avoid Java stuff mostly because it is not a core expertise.
> Hope this helps,
Yes, it does!
Thanks,
   -Steve
> Julien
More information about the Geoprisma-users mailing list
