[Geoprisma-users] Does Geoprisma proxy works with generic WMS client/server ?
Julien-Samuel Lacroix jlacroix at mapgears.com
Tue Jun 21 12:39:26 EDT 2011
The proxy currently does not play with the Capabilities. It should
indeed modify the online resource and probably filter out the layer you
don't have access to.
You can look in the following file. That's where the call to the WMS
server is done.
Patch welcome.
On 11-06-21 12:19 PM, Niccolo Rigacci wrote:
> Hi to all,
> I'm moving my first steps with Geoprisma; my goal is to use the
> Geoprisma proxy to add ACL into a standard interaction between
> WMS client/server (e.g. QGIS/QGIS-Mapserver).
> I managed to setup the proxy so it responds to a GetCapabilities
> query:
> http://../proxy.php?osmservice=S_MYDEMO&osmresource[]=R_MYDEMO&username=admin&password=demo&SERVICE=WMS&REQUEST=GetCapabilities
>> From the proxy I was expecting a different response upon the
> original WMS GetCapabilities: at least the OnlineResource should
> be changed, pointing to the proxy.php itself.
> The GetCapabilities is passed unaltered instead.
> Am I trying to force Geoprisma proxy beyond its intended use?
More information about the Geoprisma-users mailing list
