[geos-commits] r2188 - trunk/tests/unit/geom/prep
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Sep 16 17:01:36 EDT 2008
Author: mloskot
Date: 2008-09-16 17:01:36 -0400 (Tue, 16 Sep 2008)
New Revision: 2188
   trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
Fixed EOL to LF.
Modified: trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
--- trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp	2008-09-16 20:58:49 UTC (rev 2187)
+++ trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp	2008-09-16 21:01:36 UTC (rev 2188)
@@ -75,20 +75,20 @@
     template<>
     void object::test<2>()
-        try
-            GeometryPtr nullgeom = 0; // intentionally nullptr
-            prep::PreparedGeometry const* pg = 0;
-            pg = prep::PreparedGeometryFactory::prepare(nullgeom);
-            fail("IllegalArgumentException expected");
-        catch (geos::util::IllegalArgumentException const& e)
-            const char* msg = e.what(); // ok
-            ensure( msg != 0 );
+        try
+            GeometryPtr nullgeom = 0; // intentionally nullptr
+            prep::PreparedGeometry const* pg = 0;
+            pg = prep::PreparedGeometryFactory::prepare(nullgeom);
+            fail("IllegalArgumentException expected");
+        catch (geos::util::IllegalArgumentException const& e)
+            const char* msg = e.what(); // ok
+            ensure( msg != 0 );
     // Test passing null-pointer to create method
@@ -96,22 +96,22 @@
     template<>
     void object::test<3>()
-        try
-            prep::PreparedGeometryFactory pgf;
-            pg = pgf.create(nullgeom);
+        try
+            prep::PreparedGeometryFactory pgf;
+            pg = pgf.create(nullgeom);
     // Test prepare empty GEOMETRY
More information about the geos-commits mailing list
