[geos-commits] r2187 - in trunk: source/geom/prep tests/unit/geom/prep
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Sep 16 16:58:49 EDT 2008
Author: mloskot
Date: 2008-09-16 16:58:49 -0400 (Tue, 16 Sep 2008)
New Revision: 2187
   trunk/source/geom/prep/PreparedGeometryFactory.cpp
   trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
Fixed crash of Prepared Geometry construction with nullptr to Geometry object (Ticket #197).
Modified: trunk/source/geom/prep/PreparedGeometryFactory.cpp
--- trunk/source/geom/prep/PreparedGeometryFactory.cpp	2008-09-16 20:55:42 UTC (rev 2186)
+++ trunk/source/geom/prep/PreparedGeometryFactory.cpp	2008-09-16 20:58:49 UTC (rev 2187)
@@ -21,13 +21,13 @@
 #include <geos/geom/MultiLineString.h>
 #include <geos/geom/Polygon.h>
 #include <geos/geom/MultiPolygon.h>
 #include <geos/geom/prep/PreparedGeometryFactory.h>
 #include <geos/geom/prep/PreparedGeometry.h>
 #include <geos/geom/prep/BasicPreparedGeometry.h>
 #include <geos/geom/prep/PreparedPolygon.h>
 #include <geos/geom/prep/PreparedLineString.h>
 #include <geos/geom/prep/PreparedPoint.h>
+#include <geos/util/IllegalArgumentException.h>
 namespace geos {
 namespace geom { // geos.geom
@@ -38,6 +38,11 @@
     using geos::geom::GeometryTypeId;
+    if (0 == g)
+        throw util::IllegalArgumentException("PreparedGeometry constructd with null Geometry object");
 	PreparedGeometry* pg = 0;
 	switch ( g->getGeometryTypeId() )
Modified: trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
--- trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp	2008-09-16 20:55:42 UTC (rev 2186)
+++ trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp	2008-09-16 20:58:49 UTC (rev 2187)
@@ -75,8 +75,20 @@
     template<>
     void object::test<2>()
-        // FIXME - mloskot: null pointer throws segfault (Ticket #197)
-        // ensure(0 == prep::PreparedGeometryFactory::prepare(0));
+        try
+            GeometryPtr nullgeom = 0; // intentionally nullptr
+            prep::PreparedGeometry const* pg = 0;
+            pg = prep::PreparedGeometryFactory::prepare(nullgeom);
+            fail("IllegalArgumentException expected");
+        catch (geos::util::IllegalArgumentException const& e)
+            const char* msg = e.what(); // ok
+            ensure( msg != 0 );
     // Test passing null-pointer to create method
@@ -84,11 +96,22 @@
     template<>
     void object::test<3>()
-        prep::PreparedGeometryFactory pgf;
-        UNREFERENCED_PARAMETER(pgf);
-        // ensure(0 == pgf.create(0));
+        try
+            prep::PreparedGeometryFactory pgf;
+            pg = pgf.create(nullgeom);
     // Test prepare empty GEOMETRY
More information about the geos-commits mailing list
