[geos-commits] r2319 - in trunk: source/geomgraph source/headers/geos/geomgraph source/headers/geos/noding source/headers/geos/noding/snapround source/headers/geos/operation/buffer source/noding source/noding/snapround source/operation/buffer tests/unit tests/unit/noding
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Apr 7 15:00:36 EDT 2009
Author: strk
Date: 2009-04-07 15:00:36 -0400 (Tue, 07 Apr 2009)
New Revision: 2319
Added:
   trunk/source/headers/geos/noding/BasicSegmentString.h
   trunk/source/noding/BasicSegmentString.cpp
   trunk/tests/unit/noding/BasicSegmentStringTest.cpp
   trunk/tests/unit/noding/NodedSegmentStringTest.cpp
Removed:
   trunk/tests/unit/noding/SegmentStringTest.cpp
   trunk/source/geomgraph/EdgeNodingValidator.cpp
   trunk/source/headers/geos/geomgraph/EdgeNodingValidator.h
   trunk/source/headers/geos/noding/IntersectionAdder.h
   trunk/source/headers/geos/noding/IntersectionFinderAdder.h
   trunk/source/headers/geos/noding/IteratedNoder.h
   trunk/source/headers/geos/noding/MCIndexNoder.h
   trunk/source/headers/geos/noding/MCIndexNoder.inl
   trunk/source/headers/geos/noding/Makefile.am
   trunk/source/headers/geos/noding/NodableSegmentString.h
   trunk/source/headers/geos/noding/NodedSegmentString.h
   trunk/source/headers/geos/noding/SegmentNodeList.h
   trunk/source/headers/geos/noding/SegmentString.h
   trunk/source/headers/geos/noding/SegmentString.inl
   trunk/source/headers/geos/noding/SimpleNoder.h
   trunk/source/headers/geos/noding/snapround/MCIndexPointSnapper.h
   trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.h
   trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.inl
   trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h
   trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h
   trunk/source/noding/IntersectionAdder.cpp
   trunk/source/noding/IntersectionFinderAdder.cpp
   trunk/source/noding/IteratedNoder.cpp
   trunk/source/noding/MCIndexNoder.cpp
   trunk/source/noding/Makefile.am
   trunk/source/noding/NodedSegmentString.cpp
   trunk/source/noding/ScaledNoder.cpp
   trunk/source/noding/SegmentNodeList.cpp
   trunk/source/noding/SegmentString.cpp
   trunk/source/noding/SimpleNoder.cpp
   trunk/source/noding/snapround/MCIndexPointSnapper.cpp
   trunk/source/noding/snapround/MCIndexSnapRounder.cpp
   trunk/source/noding/snapround/SimpleSnapRounder.cpp
   trunk/source/operation/buffer/OffsetCurveSetBuilder.cpp
   trunk/tests/unit/Makefile.am
   trunk/tests/unit/noding/SegmentNodeTest.cpp
Refactor SegmentString to be an abstract class, to be in sync with JTS-1.9.
Modified: trunk/source/geomgraph/EdgeNodingValidator.cpp
--- trunk/source/geomgraph/EdgeNodingValidator.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/geomgraph/EdgeNodingValidator.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -14,13 +14,15 @@
+ * Last port: geomgraph/EdgeNodingValidator.java rev. 1.6 (JTS-1.9)
 #include <vector>
 #include <geos/geomgraph/EdgeNodingValidator.h>
 #include <geos/geomgraph/Edge.h>
-#include <geos/noding/SegmentString.h>
+#include <geos/noding/BasicSegmentString.h>
 #include <geos/geom/CoordinateSequence.h>
 using namespace std;
@@ -38,7 +40,7 @@
 		Edge *e=edges[i];
 		CoordinateSequence* cs=e->getCoordinates()->clone();
 		newCoordSeq.push_back(cs);
-		segStr.push_back(new SegmentString(cs, e));
+		segStr.push_back(new BasicSegmentString(cs, e));
 	return segStr;
Modified: trunk/source/headers/geos/geomgraph/EdgeNodingValidator.h
--- trunk/source/headers/geos/geomgraph/EdgeNodingValidator.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/geomgraph/EdgeNodingValidator.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -12,6 +12,10 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
Added: trunk/source/headers/geos/noding/BasicSegmentString.h
--- trunk/source/headers/geos/noding/BasicSegmentString.h	                        (rev 0)
+++ trunk/source/headers/geos/noding/BasicSegmentString.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -0,0 +1,111 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: noding/BasicSegmentString.java rev. 1.1 (JTS-1.9)
+#ifndef GEOS_NODING_BASICSEGMENTSTRING_H
+#define GEOS_NODING_BASICSEGMENTSTRING_H
+#include <geos/noding/SegmentString.h> // for inheritance
+#include <geos/geom/CoordinateSequence.h> // for inlines (size())
+#include <geos/inline.h>
+#include <vector>
+// Forward declarations
+namespace geos {
+	namespace algorithm {
+		//class LineIntersector;
+namespace geos {
+namespace noding { // geos.noding
+ * Represents a list of contiguous line segments,
+ * and supports noding the segments.
+ * The line segments are represented by an array of {@link Coordinate}s.
+ * Intended to optimize the noding of contiguous segments by
+ * reducing the number of allocated objects.
+ * SegmentStrings can carry a context object, which is useful
+ * for preserving topological or parentage information.
+ * All noded substrings are initialized with the same context object.
+class BasicSegmentString : public SegmentString {
+public:
+	/// Construct a BasicSegmentString.
+	/// @param newPts CoordinateSequence representing the string,
+	///                externally owned
+	/// @param newContext the context associated to this SegmentString
+	BasicSegmentString(geom::CoordinateSequence *newPts,
+			const void* newContext)
+		SegmentString(newContext),
+		pts(newPts)
+	virtual ~BasicSegmentString()
+	/// see dox in SegmentString.h
+	virtual unsigned int size() const
+		return pts->size();
+	virtual const geom::Coordinate& getCoordinate(unsigned int i) const;
+	virtual geom::CoordinateSequence* getCoordinates() const;
+	virtual bool isClosed() const;
+	virtual std::ostream& print(std::ostream& os) const;
+	/** \brief
+	 * Gets the octant of the segment starting at vertex index.
+	 * @param index the index of the vertex starting the segment.
+	 *        Must not be the last index in the vertex list
+	 * @return the octant of the segment at the vertex
+	int getSegmentOctant(unsigned int index) const;
+private:
+	geom::CoordinateSequence *pts;
+} // namespace geos.noding
+#ifdef GEOS_INLINE
+# include "geos/noding/SegmentString.inl"
+#endif
+#endif // ndef GEOS_NODING_BASICSEGMENTSTRING_H
Modified: trunk/source/headers/geos/noding/IntersectionAdder.h
--- trunk/source/headers/geos/noding/IntersectionAdder.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/IntersectionAdder.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: noding/IntersectionAdder.java rev. 1.6 (JTS-1.9)
 #ifndef GEOS_NODING_INTERSECTIONADDER_H
@@ -49,8 +53,6 @@
  * detects that two SegmentStrings <i>might</i> intersect.
  * This class is an example of the <i>Strategy</i> pattern.
- * Last port: noding/IntersectionAdder.java rev. 1.4 (JTS-1.7)
 class IntersectionAdder: public SegmentIntersector {
@@ -160,6 +162,14 @@
 		return std::abs(i1 - i2) == 1;
+	 * Always process all intersections
+	 * @return false always
+	virtual bool isDone() const {
+		return false;
Modified: trunk/source/headers/geos/noding/IntersectionFinderAdder.h
--- trunk/source/headers/geos/noding/IntersectionFinderAdder.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/IntersectionFinderAdder.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: noding/IntersectionFinderAdder.java rev. 1.5 (JTS-1.9)
 #ifndef GEOS_NODING_INTERSECTIONFINDERADDER_H
@@ -44,8 +48,6 @@
  * Finds proper and interior intersections in a set of SegmentStrings,
  * and adds them as nodes.
- * Last port: noding/IntersectionFinderAdder.java rev. 1.2 (JTS-1.7)
 class IntersectionFinderAdder: public SegmentIntersector {
@@ -87,6 +89,14 @@
 		return interiorIntersections;
+		return false;
Modified: trunk/source/headers/geos/noding/IteratedNoder.h
--- trunk/source/headers/geos/noding/IteratedNoder.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/IteratedNoder.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: noding/IteratedNoder.java rev. 1.6 (JTS-1.9)
 #ifndef GEOS_NODING_ITERATEDNODER_H
@@ -45,7 +49,6 @@
  * due to roundoff error.   This problem is detected and an exception is thrown.
  * Clients can choose to rerun the noding using a lower precision model.
- * Last port: noding/IteratedNoder.java rev. 1.6 (JTS-1.7)
 class IteratedNoder : public Noder { // implements Noder
@@ -89,7 +92,7 @@
 	void setMaximumIterations(int n) { maxIter = n; }
 	std::vector<SegmentString*>* getNodedSubstrings() const {
-		return SegmentString::getNodedSubstrings(*nodedSegStrings);
+		return nodedSegStrings;
Modified: trunk/source/headers/geos/noding/MCIndexNoder.h
--- trunk/source/headers/geos/noding/MCIndexNoder.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/MCIndexNoder.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: noding/MCIndexNoder.java rev. 1.6 (JTS-1.9)
 #ifndef GEOS_NODING_MCINDEXNODER_H
Modified: trunk/source/headers/geos/noding/MCIndexNoder.inl
--- trunk/source/headers/geos/noding/MCIndexNoder.inl	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/MCIndexNoder.inl	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
 #ifndef GEOS_NODINGMCINDEXNODER_INL
@@ -18,6 +22,7 @@
 #include <geos/noding/MCIndexNoder.h>
+#include <geos/noding/NodedSegmentString.h>
 #include <cassert>
@@ -34,7 +39,7 @@
 MCIndexNoder::getNodedSubstrings() const
 	assert(nodedSegStrings); // must have colled computeNodes before!
+	return NodedSegmentString::getNodedSubstrings(*nodedSegStrings);
 } // namespace geos::noding
Modified: trunk/source/headers/geos/noding/Makefile.am
--- trunk/source/headers/geos/noding/Makefile.am	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/Makefile.am	2009-04-07 19:00:36 UTC (rev 2319)
@@ -6,6 +6,7 @@
 noinst_HEADERS = \
+	BasicSegmentString.h \
 	FastNodingValidator.h \
 	FastSegmentSetIntersectionFinder.h \
 	IntersectionAdder.h \
Modified: trunk/source/headers/geos/noding/NodableSegmentString.h
--- trunk/source/headers/geos/noding/NodableSegmentString.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/NodableSegmentString.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -39,8 +39,9 @@
 private:
 protected:
 public:
-	NodableSegmentString( geom::CoordinateSequence *newPts, const void* newContext)
-		: SegmentString( newPts, newContext )
+	NodableSegmentString(const void* newContext)
+		SegmentString( newContext )
Modified: trunk/source/headers/geos/noding/NodedSegmentString.h
--- trunk/source/headers/geos/noding/NodedSegmentString.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/NodedSegmentString.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -12,11 +12,16 @@
+ * Last port: noding/NodedSegmentString.java rev. 1.2 (JTS-1.9)
 #ifndef GEOS_NODING_NODEDSEGMENTSTRING_H
 #define GEOS_NODING_NODEDSEGMENTSTRING_H
 #include <geos/algorithm/LineIntersector.h>
 #include <geos/noding/NodableSegmentString.h>
 #include <geos/noding/SegmentNode.h>
@@ -41,14 +46,13 @@
- * @version 1.7
 class NodedSegmentString : public NodableSegmentString
-private:
-protected:
 public:
-	static void getNodedSubstrings( SegmentString::ConstVect * segStrings, SegmentString::NonConstVect * resultEdgelist)
+	static void getNodedSubstrings(SegmentString::ConstVect* segStrings,
+			SegmentString::NonConstVect* resultEdgelist)
 		for (size_t i=0, n=segStrings->size(); i<n; i++)
@@ -57,14 +61,30 @@
+			const SegmentString::NonConstVect& segStrings,
+			SegmentString::NonConstVect* resultEdgeList);
+	/// Returns allocated object
+	static SegmentString::NonConstVect* getNodedSubstrings(
+			const SegmentString::NonConstVect& segStrings);
 	 * Creates a new segment string from a list of vertices.
-	 * @param pts the vertices of the segment string
-	 * @param data the user-defined data of this segment string (may be null)
+	 * @param newPts CoordinateSequence representing the string,
+	 *                externally owned
+	 * @param data the user-defined data of this segment string
+	 *             (may be null)
-	NodedSegmentString( geom::CoordinateSequence *newPts, const void* newContext)
-		: NodableSegmentString( newPts, newContext )
+	NodedSegmentString(geom::CoordinateSequence *newPts,
+		NodableSegmentString(newContext),
+		nodeList(this),
+		pts(newPts)
 	~NodedSegmentString()
@@ -102,6 +122,69 @@
 		return ei;
+	SegmentNodeList& getNodeList();
+	const SegmentNodeList& getNodeList() const;
+	/** \brief
+	/** \brief
+	 * Add {SegmentNode}s for one or both
+	 * intersections found for a segment of an edge to the edge
+	 * intersection list.
+	void addIntersections(algorithm::LineIntersector *li,
+			unsigned int segmentIndex, int geomIndex);
+	/** \brief
+	 * Add an SegmentNode for intersection intIndex.
+	 * An intersection that falls exactly on a vertex
+	 * of the SegmentString is normalized
+	 * to use the higher of the two possible segmentIndexes
+	void addIntersection(algorithm::LineIntersector *li,
+			int geomIndex, int intIndex);
+	/** \brief
+	 * An intersection that falls exactly on a vertex of the
+	 * edge is normalized
+	void addIntersection(const geom::Coordinate& intPt,
+			unsigned int segmentIndex);
+private:
+	SegmentNodeList nodeList;
Modified: trunk/source/headers/geos/noding/SegmentNodeList.h
--- trunk/source/headers/geos/noding/SegmentNodeList.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/SegmentNodeList.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: noding/SegmentNodeList.java rev. 1.8 (JTS-1.9)
 #ifndef GEOS_NODING_SEGMENTNODELIST_H
@@ -23,7 +27,7 @@
 #include <vector>
 #include <set>
-#include <geos/noding/SegmentNode.h>
+#include <geos/noding/SegmentNode.h> // for composition
 namespace geos {
@@ -31,7 +35,7 @@
 		class CoordinateSequence;
 	namespace noding {
-		class SegmentString;
+		class NodedSegmentString;
@@ -41,15 +45,13 @@
 /** \brief
  * A list of the SegmentNode present along a
  * noded SegmentString.
- * Last port: noding/SegmentNodeList.java rev. 1.7 (JTS-1.7)
 class SegmentNodeList {
 private:
 	std::set<SegmentNode*,SegmentNodeLT> nodeMap;
 	// the parent edge
-	const SegmentString& edge;
+	const NodedSegmentString& edge;
 	// UNUSED
 	//std::vector<SegmentNode*> *sortedNodes;
@@ -113,11 +115,11 @@
 	typedef container::iterator iterator;
 	typedef container::const_iterator const_iterator;
-	SegmentNodeList(const SegmentString* newEdge): edge(*newEdge) {}
+	SegmentNodeList(const NodedSegmentString* newEdge): edge(*newEdge) {}
-	SegmentNodeList(const SegmentString& newEdge): edge(newEdge) {}
+	SegmentNodeList(const NodedSegmentString& newEdge): edge(newEdge) {}
-	const SegmentString& getEdge() const { return edge; }
+	const NodedSegmentString& getEdge() const { return edge; }
 	// TODO: Is this a final class ?
 	// Should remove the virtual in that case
Modified: trunk/source/headers/geos/noding/SegmentString.h
--- trunk/source/headers/geos/noding/SegmentString.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/SegmentString.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,13 +11,16 @@
+ * Last port: noding/SegmentString.java rev. 1.6 (JTS-1.9)
 #ifndef GEOS_NODING_SEGMENTSTRING_H
 #define GEOS_NODING_SEGMENTSTRING_H
 #include <geos/noding/SegmentNodeList.h>
-#include <geos/geom/CoordinateSequence.h> // for testInvariant
@@ -34,23 +37,11 @@
 /** \brief
- * Represents a list of contiguous line segments,
- * and supports noding the segments.
+ * An interface for classes which represent a sequence of contiguous
+ * line segments.
- * The line segments are represented by a CoordinateSequence.
- * TODO:
- * This should be changed to use a vector of Coordinate,
- * to optimize the noding of contiguous segments by
- * reducing the number of allocated objects.
- * All noded substrings are initialized with the same context object.
- * Final class.
- * Last port: noding/SegmentString.java rev. 1.5 (JTS-1.7)
 class SegmentString {
 public:
@@ -60,40 +51,36 @@
 	friend std::ostream& operator<< (std::ostream& os,
 			const SegmentString& ss);
-private:
-	SegmentNodeList nodeList;
-	geom::CoordinateSequence *pts;
-	mutable unsigned int npts; // this is a cache
-	const void* context;
-	bool isIsolatedVar;
-public:
-	void testInvariant() const;
 	/// Construct a SegmentString.
-	/// @param newPts CoordinateSequence representing the string,
-	/// externally owned
-	SegmentString(geom::CoordinateSequence *newPts, const void* newContext);
+	SegmentString(const void* newContext)
+		context(newContext)
-	virtual ~SegmentString();
+	virtual ~SegmentString() {}
-	//const void* getContext() const { return getData(); }
+	 * Gets the user-defined data for this segment string.
+	 * @return the user-defined data
+	const void* getData() const { return context; }
-	const void* getData() const;
+	 * Sets the user-defined data for this segment string.
+	 * @param data an Object containing user-defined data
+	void setData(const void* data) { context=data; }
-	const SegmentNodeList& getNodeList() const;
-	SegmentNodeList& getNodeList();
+	virtual unsigned int size() const=0;
-	unsigned int size() const;
+	virtual const geom::Coordinate& getCoordinate(unsigned int i) const=0;
-	const geom::Coordinate& getCoordinate(unsigned int i) const;
 	/// \brief
 	/// Return a pointer to the CoordinateSequence associated
 	/// with this SegmentString.
@@ -101,81 +88,21 @@
 	/// Note that the CoordinateSequence is not owned by
 	/// this SegmentString!
-	geom::CoordinateSequence* getCoordinates() const;
+	virtual geom::CoordinateSequence* getCoordinates() const=0;
-	/// \brief
-	/// Notify this object that the CoordinateSequence associated
-	/// with it might have been updated.
-	/// This must be called so that the SegmentString object makes
-	/// all the necessary checks and updates to verify consistency
-	void notifyCoordinatesChange() const;
 	// Return a read-only pointer to this SegmentString CoordinateSequence
 	//const CoordinateSequence* getCoordinatesRO() const { return pts; }
-	void setIsolated(bool isIsolated);
+	virtual bool isClosed() const=0;
-	bool isIsolated() const;
-	bool isClosed() const;
-	/** \brief
-	 * Gets the octant of the segment starting at vertex
-	 * <code>index</code>.
-	 * @param index the index of the vertex starting the segment.
-	 *              Must not be the last index in the vertex list
-	 * @return the octant of the segment at the vertex
-	int getSegmentOctant(unsigned int index) const;
+private:
-	/** \brief
-	 * Add {SegmentNode}s for one or both
-	 * intersections found for a segment of an edge to the edge
-	 * intersection list.
-	void addIntersections(algorithm::LineIntersector *li,
-			unsigned int segmentIndex, int geomIndex);
+	const void* context;
-	/** \brief
-	 * Add an SegmentNode for intersection intIndex.
-	 * An intersection that falls exactly on a vertex
-	 * of the SegmentString is normalized
-	 * to use the higher of the two possible segmentIndexes
-	void addIntersection(algorithm::LineIntersector *li,
-			int geomIndex, int intIndex);
-	/** \brief
-	 * An intersection that falls exactly on a vertex of the
-	 * edge is normalized
-	void addIntersection(const geom::Coordinate& intPt,
-			unsigned int segmentIndex);
-			const SegmentString::NonConstVect& segStrings,
-			SegmentString::NonConstVect* resultEdgeList);
-	static SegmentString::NonConstVect* getNodedSubstrings(
-			const SegmentString::NonConstVect& segStrings);
-inline void
-SegmentString::testInvariant() const
-	assert(pts);
-	assert(pts->size() > 1);
-	assert(pts->size() == npts);
 std::ostream& operator<< (std::ostream& os, const SegmentString& ss);
Modified: trunk/source/headers/geos/noding/SegmentString.inl
--- trunk/source/headers/geos/noding/SegmentString.inl	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/SegmentString.inl	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
 #ifndef GEOS_NODING_SEGMENTSTRING_INL
@@ -24,84 +28,8 @@
 namespace geos {
-INLINE
-SegmentString::SegmentString(geom::CoordinateSequence *newPts, const void* newContext)
-		nodeList(this),
-		pts(newPts),
-		npts(pts->size()),
-		context(newContext),
-		isIsolatedVar(false)
-	testInvariant();
-INLINE
-SegmentString::~SegmentString() {}
-INLINE const void*
-SegmentString::getData() const
-	testInvariant();
-	return context;
-INLINE const SegmentNodeList&
-SegmentString::getNodeList() const
-	testInvariant();
-	return nodeList;
-INLINE SegmentNodeList&
-	testInvariant();
-	return nodeList;
-INLINE unsigned int
-SegmentString::size() const
-	testInvariant();
-	return npts;
-INLINE const geom::Coordinate&
-SegmentString::getCoordinate(unsigned int i) const
-	testInvariant();
-	return pts->getAt(i);
-INLINE geom::CoordinateSequence*
-SegmentString::getCoordinates() const
-	testInvariant();
-	return pts;
-INLINE void
-SegmentString::setIsolated(bool isIsolated)
-	isIsolatedVar=isIsolated;
-	testInvariant();
-INLINE bool
-SegmentString::isIsolated() const
-	testInvariant();
-	return isIsolatedVar;
-INLINE bool
-SegmentString::isClosed() const
-	testInvariant();
-	return pts->getAt(0)==pts->getAt(npts-1);
 } // namespace geos
Modified: trunk/source/headers/geos/noding/SimpleNoder.h
--- trunk/source/headers/geos/noding/SimpleNoder.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/SimpleNoder.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: noding/SimpleNoder.java rev. 1.7 (JTS-1.9)
 #ifndef GEOS_NODING_SIMPLENODER_H
@@ -21,7 +25,7 @@
 #include <geos/noding/SinglePassNoder.h>
-#include <geos/noding/SegmentString.h> // for inlined (FIXME)
+#include <geos/noding/NodedSegmentString.h> // for inlined (FIXME)
 namespace geos {
@@ -57,7 +61,7 @@
 	void computeNodes(std::vector<SegmentString*>* inputSegmentStrings);
Modified: trunk/source/headers/geos/noding/snapround/MCIndexPointSnapper.h
--- trunk/source/headers/geos/noding/snapround/MCIndexPointSnapper.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/snapround/MCIndexPointSnapper.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: noding/snapround/MCIndexPointSnapper.java rev. 1.4 (JTS-1.9)
 #ifndef GEOS_NODING_SNAPROUND_MCINDEXPOINTSNAPPER_H
@@ -39,7 +43,6 @@
  * "Snaps" all {@link SegmentString}s in a {@link SpatialIndex} containing
  * {@link MonotoneChain}s to a given {@link HotPixel}.
- * Last port: noding/snapround/MCIndexPointSnapper.java rev. 1.2 (JTS-1.7)
 class MCIndexPointSnapper {
@@ -68,10 +71,10 @@
 	 * @param vertexIndex the index of the vertex, if applicable, or -1
 	 * @return <code>true</code> if a node was added for this pixel
-	bool snap(const HotPixel& hotPixel, SegmentString* parentEdge,
+	bool snap(HotPixel& hotPixel, SegmentString* parentEdge,
 			unsigned int vertexIndex);
-	bool snap(const HotPixel& hotPixel) {
+	bool snap(HotPixel& hotPixel) {
 		return snap(hotPixel, 0, 0);
Modified: trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.h
--- trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: noding/snapround/MCIndexSnapRounder.java rev. 1.3 (JTS-1.9)
 #ifndef GEOS_NODING_SNAPROUND_MCINDEXSNAPROUNDER_H
@@ -34,6 +38,7 @@
 	namespace noding {
 		class MCIndexNoder;
 		namespace snapround {
 			//class HotPixel;
@@ -66,9 +71,6 @@
  * It will function with non-integer precision models, but the
  * results are not 100% guaranteed to be correctly noded.
- * Last port: noding/snapround/MCIndexSnapRounder.java rev. 1.1 (JTS-1.7)
 class MCIndexSnapRounder: public Noder { // implments Noder
@@ -109,7 +111,7 @@
 	 * Performs a brute-force comparison of every segment in each {@link SegmentString}.
 	 * This has n^2 performance.
-	void computeEdgeVertexSnaps(SegmentString* e);
+	void computeVertexSnaps(NodedSegmentString* e);
 	void checkCorrectness(std::vector<SegmentString*>& inputSegmentStrings);
@@ -126,6 +128,8 @@
 	 * snapping segments to vertices of other segments
 	 * @param segStrings the list of segment strings to snap together
+	 *        NOTE: they *must* be instances of NodedSegmentString, or
+	 * 	  an assertion will fail.
 	void computeVertexSnaps(std::vector<SegmentString*>& edges);
Modified: trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.inl
--- trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.inl	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/snapround/MCIndexSnapRounder.inl	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
 #ifndef GEOS_NODING_SNAPROUND_MCINDEXSNAPROUNDER_INL
@@ -19,6 +23,7 @@
 #include <geos/noding/snapround/MCIndexSnapRounder.h>
 #include <geos/noding/snapround/MCIndexPointSnapper.h>
 #include <geos/geom/PrecisionModel.h>
 #include <memory>
@@ -30,7 +35,7 @@
 INLINE std::vector<SegmentString*>*
 MCIndexSnapRounder::getNodedSubstrings() const
 INLINE
Modified: trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h
--- trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: noding/snapround/SimpleSnapRounder.java rev. 1.4 (JTS-1.9)
 #ifndef GEOS_NODING_SNAPROUND_SIMPLESNAPROUNDER_H
@@ -35,6 +39,7 @@
 	namespace noding {
 			class HotPixel;
@@ -100,14 +105,14 @@
 	void computeSnaps(const std::vector<SegmentString*>& segStrings,
 		std::vector<geom::Coordinate>& snapPts);
-	void computeSnaps(SegmentString* ss, std::vector<geom::Coordinate>& snapPts);
+	void computeSnaps(NodedSegmentString* ss, std::vector<geom::Coordinate>& snapPts);
 	/** \brief
 	 * {@link SegmentString}.
-	void computeVertexSnaps(SegmentString* e0, SegmentString* e1);
+	void computeVertexSnaps(NodedSegmentString* e0, NodedSegmentString* e1);
 public:
@@ -129,14 +134,15 @@
 	static bool addSnappedNode(const HotPixel& hotPix,
-			SegmentString& segStr,
+			NodedSegmentString& segStr,
 			unsigned int segIndex);
 	 * Computes nodes introduced as a result of
-	 * @param segStrings the list of segment strings to snap together
+	 * @param segStrings the list of segment strings to snap together.
+	 *        Must be NodedSegmentString or an assertion will fail.
 	void computeVertexSnaps(const std::vector<SegmentString*>& edges);
Modified: trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h
--- trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,6 +11,10 @@
+ * Last port: operation/buffer/OffsetCurveSetBuilder.java rev. 1.11 (JTS-1.9)
 #ifndef GEOS_OP_BUFFER_OFFSETCURVESETBUILDER_H
@@ -54,8 +58,6 @@
  * Raw curves need to be noded together and polygonized to form the
  * final buffer area.
- * Last port: operation/buffer/OffsetCurveSetBuilder.java rev. 1.7 (JTS-1.7)
 class OffsetCurveSetBuilder {
Added: trunk/source/noding/BasicSegmentString.cpp
--- trunk/source/noding/BasicSegmentString.cpp	                        (rev 0)
+++ trunk/source/noding/BasicSegmentString.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -0,0 +1,84 @@
+ * $Id$
+ * the terms of the GNU Lesser General Licence as published
+#include <geos/geom/Coordinate.h>
+#include <geos/util/IllegalArgumentException.h>
+#include <geos/noding/Octant.h>
+//#include <geos/profiler.h>
+#ifndef GEOS_DEBUG
+#define GEOS_DEBUG 0
+#endif
+#include <iostream>
+#include <sstream>
+using namespace geos::algorithm;
+using namespace geos::geom;
+namespace geos {
+/*public*/
+int
+BasicSegmentString::getSegmentOctant(unsigned int index) const
+	if (index >= size() - 1) return -1;
+	return Octant::octant(getCoordinate(index), getCoordinate(index+1));
+/* virtual public */
+const geom::Coordinate&
+BasicSegmentString::getCoordinate(unsigned int i) const
+	return pts->getAt(i);
+geom::CoordinateSequence*
+BasicSegmentString::getCoordinates() const
+	return pts;
+bool
+BasicSegmentString::isClosed() const
+	return pts->getAt(0)==pts->getAt(size()-1);
+/* public virtual */
+std::ostream&
+BasicSegmentString::print(std::ostream& os) const
+	os << "BasicSegmentString: " << std::endl;
+	os << " LINESTRING" << *(pts) << ";" << std::endl;
+	return os;
Modified: trunk/source/noding/IntersectionAdder.cpp
--- trunk/source/noding/IntersectionAdder.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/IntersectionAdder.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -13,12 +13,13 @@
 #include <geos/noding/IntersectionAdder.h>
@@ -90,8 +91,13 @@
 	if (! isTrivialIntersection(e0, segIndex0, e1, segIndex1))
 		hasIntersectionVar = true;
-		e0->addIntersections(&li, segIndex0, 0);
-		e1->addIntersections(&li, segIndex1, 1);
+		NodedSegmentString* ee0 = dynamic_cast<NodedSegmentString*>(e0);
+		NodedSegmentString* ee1 = dynamic_cast<NodedSegmentString*>(e1);
+		assert(ee0 && ee1);
+		ee0->addIntersections(&li, segIndex0, 0);
+		ee1->addIntersections(&li, segIndex1, 1);
 		if (li.isProper()) {
 			numProperIntersections++;
 			//Debug.println(li.toString());
Modified: trunk/source/noding/IntersectionFinderAdder.cpp
--- trunk/source/noding/IntersectionFinderAdder.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/IntersectionFinderAdder.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -13,7 +13,7 @@
@@ -21,6 +21,7 @@
 #include <geos/noding/IntersectionFinderAdder.h>
@@ -53,8 +54,12 @@
 				interiorIntersections.push_back(li.getIntersection(intIndex));
Modified: trunk/source/noding/IteratedNoder.cpp
--- trunk/source/noding/IteratedNoder.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/IteratedNoder.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -14,7 +14,7 @@
Modified: trunk/source/noding/MCIndexNoder.cpp
--- trunk/source/noding/MCIndexNoder.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/MCIndexNoder.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -13,13 +13,13 @@
- * Last port: noding/MCIndexNoder.java rev. 1.4 (JTS-1.7)
 #include <geos/noding/SegmentIntersector.h>
 #include <geos/index/chain/MonotoneChain.h>
 #include <geos/index/chain/MonotoneChainBuilder.h>
Modified: trunk/source/noding/Makefile.am
--- trunk/source/noding/Makefile.am	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/Makefile.am	2009-04-07 19:00:36 UTC (rev 2319)
@@ -5,6 +5,7 @@
 INCLUDES = -I$(top_srcdir)/source/headers
 libnoding_la_SOURCES = \
+	BasicSegmentString.cpp \
 	FastNodingValidator.cpp \
 	FastSegmentSetIntersectionFinder.cpp \
 	IntersectionAdder.cpp \
Modified: trunk/source/noding/NodedSegmentString.cpp
--- trunk/source/noding/NodedSegmentString.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/NodedSegmentString.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,14 +11,163 @@
+#include <geos/algorithm/LineIntersector.h>
 namespace geos {
 namespace noding { // geos::noding
+const SegmentNodeList&
+NodedSegmentString::getNodeList() const
+	return nodeList;
+SegmentNodeList&
+	return nodeList;
+/*public*/
+int
+NodedSegmentString::getSegmentOctant(unsigned int index) const
+/*public*/
+void
+NodedSegmentString::addIntersections(LineIntersector *li, unsigned int
+		segmentIndex, int geomIndex)
+	for (int i=0, n=li->getIntersectionNum(); i<n; ++i) {
+		addIntersection(li, segmentIndex, geomIndex, i);
+/*public*/
+void
+NodedSegmentString::addIntersection(LineIntersector *li,
+    UNREFERENCED_PARAMETER(geomIndex);
+	const Coordinate &intPt=li->getIntersection(intIndex);
+	addIntersection(intPt, segmentIndex);
+/*public*/
+void
+NodedSegmentString::addIntersection(const Coordinate& intPt,
+	unsigned int normalizedSegmentIndex = segmentIndex;
+	if ( segmentIndex > size()-2 )
+		throw util::IllegalArgumentException("SegmentString::addIntersection: SegmentIndex out of range");
+	// normalize the intersection point location
+	unsigned int nextSegIndex = normalizedSegmentIndex + 1;
+	if (nextSegIndex < size())
+		const Coordinate& nextPt = pts->getAt(nextSegIndex);
+		// Normalize segment index if intPt falls on vertex
+		// The check for point equality is 2D only -
+		// Z values are ignored
+		if (intPt.equals2D(nextPt)) {
+			normalizedSegmentIndex = nextSegIndex;
+	 * Add the intersection point to edge intersection list
+	 * (unless the node is already known)
+	//SegmentNode *ei=
+	nodeList.add(intPt, normalizedSegmentIndex);
+/* public static */
+void
+NodedSegmentString::getNodedSubstrings(
+	SegmentString::NonConstVect *resultEdgeList)
+	assert(resultEdgeList);
+	for ( SegmentString::NonConstVect::const_iterator
+		i=segStrings.begin(), iEnd=segStrings.end();
+		i != iEnd; ++i )
+		NodedSegmentString* ss = dynamic_cast<NodedSegmentString*>(*i);
+		assert(ss);
+		ss->getNodeList().addSplitEdges(resultEdgeList);
+SegmentString::NonConstVect*
+	SegmentString::NonConstVect* resultEdgelist = \
+		new SegmentString::NonConstVect();
+	getNodedSubstrings(segStrings, resultEdgelist);
+	return resultEdgelist;
+NodedSegmentString::getCoordinate(unsigned int i) const
+NodedSegmentString::getCoordinates() const
+	return pts;
+bool
+NodedSegmentString::isClosed() const
+std::ostream&
+NodedSegmentString::print(std::ostream& os) const
+	os << "NodedSegmentString: " << std::endl;
+	os << " Nodes: " << nodeList.size() << std::endl;
+	return os;
 } // geos::noding
 } // geos
Modified: trunk/source/noding/ScaledNoder.cpp
--- trunk/source/noding/ScaledNoder.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/ScaledNoder.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -146,8 +146,6 @@
 		SegmentString* ss=*i0;
-		ss->testInvariant();
 		CoordinateSequence* cs=ss->getCoordinates();
 #ifndef NDEBUG
@@ -162,8 +160,6 @@
 		// the memory cost ?
 		cs->removeRepeatedPoints();
-		// Let SegmentString know that something might be changed
-		ss->notifyCoordinatesChange();
Modified: trunk/source/noding/SegmentNodeList.cpp
--- trunk/source/noding/SegmentNodeList.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/SegmentNodeList.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -14,7 +14,7 @@
@@ -24,7 +24,7 @@
 #include <geos/util/GEOSException.h>
 #include <geos/geom/CoordinateArraySequence.h> // FIXME: should we really be using this ?
@@ -283,7 +283,7 @@
 	if (useIntPt1) 	pts->setAt(ei1->coord, ipt++);
-	SegmentString *ret = new SegmentString(pts, edge.getData());
+	SegmentString *ret = new NodedSegmentString(pts, edge.getData());
 #if GEOS_DEBUG
 	std::cerr<<" SegmentString created"<<std::endl;
 #endif
Modified: trunk/source/noding/SegmentString.cpp
--- trunk/source/noding/SegmentString.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/SegmentString.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -11,15 +11,19 @@
-#include <geos/noding/SegmentNodeList.h>
-#include <geos/algorithm/LineIntersector.h>
-#include <geos/geom/Coordinate.h>
-#include <geos/util/IllegalArgumentException.h>
-#include <geos/noding/Octant.h>
+//#include <geos/noding/SegmentNodeList.h>
+//#include <geos/algorithm/LineIntersector.h>
+//#include <geos/geom/Coordinate.h>
+//#include <geos/geom/CoordinateSequence.h>
+//#include <geos/util/IllegalArgumentException.h>
+//#include <geos/noding/Octant.h>
 #ifndef GEOS_DEBUG
@@ -39,122 +43,18 @@
 namespace geos {
-/*public*/
-void
-SegmentString::addIntersections(LineIntersector *li, unsigned int segmentIndex,
-		int geomIndex)
+std::ostream& operator<< (std::ostream& os, const SegmentString& ss)
-	for (int i=0, n=li->getIntersectionNum(); i<n; ++i) {
-		addIntersection(li, segmentIndex, geomIndex, i);
+	return ss.print(os);
-/*public*/
-void
-SegmentString::addIntersection(LineIntersector *li, unsigned int segmentIndex,
+std::ostream&
+SegmentString::print(std::ostream& os) const
-    UNREFERENCED_PARAMETER(geomIndex);
-	const Coordinate &intPt=li->getIntersection(intIndex);
-	addIntersection(intPt, segmentIndex);
-/*public*/
-void
-SegmentString::addIntersection(const Coordinate& intPt,
-	unsigned int normalizedSegmentIndex = segmentIndex;
-	if ( segmentIndex > size()-2 )
-		throw util::IllegalArgumentException("SegmentString::addIntersection: SegmentIndex out of range");
-	// normalize the intersection point location
-	unsigned int nextSegIndex = normalizedSegmentIndex + 1;
-	if (nextSegIndex < size())
-		const Coordinate& nextPt = pts->getAt(nextSegIndex);
-		// Normalize segment index if intPt falls on vertex
-		// The check for point equality is 2D only -
-		// Z values are ignored
-		if (intPt.equals2D(nextPt)) {
-			normalizedSegmentIndex = nextSegIndex;
-	 * Add the intersection point to edge intersection list
-	 * (unless the node is already known)
-	//SegmentNode *ei=
-	nodeList.add(intPt, normalizedSegmentIndex);
-	testInvariant();
-/* public static */
-void
-SegmentString::getNodedSubstrings(const SegmentString::NonConstVect& segStrings,
-	SegmentString::NonConstVect *resultEdgeList)
-	assert(resultEdgeList);
-	for ( SegmentString::NonConstVect::const_iterator
-		i=segStrings.begin(), iEnd=segStrings.end();
-		i != iEnd; ++i )
-		SegmentString* ss = *i;
-		assert(ss);
-		ss->getNodeList().addSplitEdges(resultEdgeList);
-SegmentString::NonConstVect*
-SegmentString::getNodedSubstrings(const SegmentString::NonConstVect& segStrings)
-	SegmentString::NonConstVect* resultEdgelist = \
-		new SegmentString::NonConstVect();
-	getNodedSubstrings(segStrings, resultEdgelist);
-	return resultEdgelist;
-/*public*/
-int
-SegmentString::getSegmentOctant(unsigned int index) const
-	testInvariant();
-	if (index >= size() - 1) return -1;
-	return Octant::octant(getCoordinate(index), getCoordinate(index+1));
-/* public */
-void
-SegmentString::notifyCoordinatesChange() const
-	npts = pts->size();
-	// What about SegmentNodes ? should
-	// we invalidate them as well ?
-	testInvariant();
-std::ostream& operator<< (std::ostream& os, const SegmentString& ss)
-	os << "SegmentString: " << std::endl;
-	os << " LINESTRING" << *(ss.pts) << ";" << std::endl;
-	os << " Nodes: " << ss.nodeList.size() << std::endl;
+	os << "SegmentString" << std::endl;
 	return os;
 } // namespace geos
Modified: trunk/source/noding/SimpleNoder.cpp
--- trunk/source/noding/SimpleNoder.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/SimpleNoder.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -12,6 +12,10 @@
 #include <geos/noding/SimpleNoder.h>
Modified: trunk/source/noding/snapround/MCIndexPointSnapper.cpp
--- trunk/source/noding/snapround/MCIndexPointSnapper.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/snapround/MCIndexPointSnapper.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -13,7 +13,7 @@
@@ -21,6 +21,7 @@
 #include <geos/noding/snapround/HotPixel.h>
 #include <geos/noding/snapround/SimpleSnapRounder.h>
 #include <geos/spatialIndex.h>
 #include <geos/geom/Envelope.h>
 #include <geos/index/chain/MonotoneChainSelectAction.h>
@@ -39,14 +40,14 @@
 class HotPixelSnapAction: public index::chain::MonotoneChainSelectAction {
 private:
-	const HotPixel& hotPixel;
+	HotPixel& hotPixel;
 	SegmentString* parentEdge;
 	unsigned int vertexIndex;
 	bool isNodeAddedVar;
 public:
-	HotPixelSnapAction(const HotPixel& nHotPixel,
+	HotPixelSnapAction(HotPixel& nHotPixel,
 			SegmentString* nParentEdge,
 			unsigned int nVertexIndex)
@@ -61,13 +62,16 @@
 	void select(chain::MonotoneChain& mc, unsigned int startIndex)
 		// This is casting away 'constness'!
-		SegmentString& ss = *(static_cast<SegmentString*>(mc.getContext()));
+		NodedSegmentString& ss = *(static_cast<NodedSegmentString*>(mc.getContext()));
 		// don't snap a vertex to itself
 		if ( parentEdge ) {
 			if (&ss == parentEdge && startIndex == vertexIndex) return;
-		isNodeAddedVar = SimpleSnapRounder::addSnappedNode(hotPixel, ss, startIndex);
+		//isNodeAddedVar = SimpleSnapRounder::addSnappedNode(hotPixel, ss, startIndex);
+		isNodeAddedVar = hotPixel.addSnappedNode(ss, startIndex);
 	void select(LineSegment* ls)
@@ -100,7 +104,7 @@
 /* public */
 bool
-MCIndexPointSnapper::snap(const HotPixel& hotPixel,
+MCIndexPointSnapper::snap(HotPixel& hotPixel,
Modified: trunk/source/noding/snapround/MCIndexSnapRounder.cpp
--- trunk/source/noding/snapround/MCIndexSnapRounder.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/snapround/MCIndexSnapRounder.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -13,7 +13,7 @@
@@ -46,7 +46,7 @@
 /*private*/
 void
 MCIndexSnapRounder::findInteriorIntersections(MCIndexNoder& noder,
-		SegmentString::NonConstVect* segStrings,
+		NodedSegmentString::NonConstVect* segStrings,
 		vector<Coordinate>& intersections)
 	IntersectionFinderAdder intFinderAdder(li, intersections);
@@ -71,7 +71,7 @@
 /*private*/
 void
-MCIndexSnapRounder::computeEdgeVertexSnaps(SegmentString* e)
+MCIndexSnapRounder::computeVertexSnaps(NodedSegmentString* e)
 	CoordinateSequence& pts0 = *(e->getCoordinates());
 	for (unsigned int i=0, n=pts0.size()-1; i<n; ++i)
@@ -89,7 +89,14 @@
 void
 MCIndexSnapRounder::computeVertexSnaps(SegmentString::NonConstVect& edges)
-	for_each(edges.begin(), edges.end(), bind1st(mem_fun(&MCIndexSnapRounder::computeEdgeVertexSnaps), this));
+	SegmentString::NonConstVect::iterator i=edges.begin(), e=edges.end();
+	for (; i!=e; ++i)
+		NodedSegmentString* edge0 =
+			dynamic_cast<NodedSegmentString*>(*i);
+		assert(edge0);
+		computeVertexSnaps(edge0);
 /*private*/
@@ -125,7 +132,7 @@
 	SegmentString::NonConstVect& inputSegmentStrings)
 	auto_ptr<SegmentString::NonConstVect> resultSegStrings(
-		SegmentString::getNodedSubstrings(inputSegmentStrings)
+		NodedSegmentString::getNodedSubstrings(inputSegmentStrings)
 	NodingValidator nv(*(resultSegStrings.get()));
Modified: trunk/source/noding/snapround/SimpleSnapRounder.cpp
--- trunk/source/noding/snapround/SimpleSnapRounder.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/noding/snapround/SimpleSnapRounder.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -13,13 +13,14 @@
- * Last port: noding/snapround/SimpleSnapRounder.java rev. 1.2 (JTS-1.7)
 #include <geos/noding/NodingValidator.h>
@@ -77,7 +78,7 @@
@@ -99,17 +100,15 @@
 			i!=iEnd; ++i)
 		computeSnaps(ss, snapPts);
 /*private*/
 void
-SimpleSnapRounder::computeSnaps(SegmentString* ss, vector<Coordinate>& snapPts)
+SimpleSnapRounder::computeSnaps(NodedSegmentString* ss, vector<Coordinate>& snapPts)
 	for (vector<Coordinate>::iterator
 		it=snapPts.begin(), itEnd=snapPts.end();
@@ -126,7 +125,7 @@
 /* public static */
 bool
 SimpleSnapRounder::addSnappedNode(const HotPixel& hotPix,
-		SegmentString& segStr, unsigned int segIndex)
+		NodedSegmentString& segStr, unsigned int segIndex)
 	const Coordinate& p0 = segStr.getCoordinate(segIndex);
 	const Coordinate& p1 = segStr.getCoordinate(segIndex + 1);
@@ -144,7 +143,7 @@
 /*private*/
 void
-SimpleSnapRounder::computeVertexSnaps(SegmentString* e0, SegmentString* e1)
+SimpleSnapRounder::computeVertexSnaps(NodedSegmentString* e0, NodedSegmentString* e1)
 	const CoordinateSequence* pts0 = e0->getCoordinates();
 	const CoordinateSequence* pts1 = e1->getCoordinates();
@@ -179,12 +178,14 @@
 			i0=edges.begin(), i0End=edges.end();
 			i0!=i0End; ++i0)
-		SegmentString* edge0 = *i0;
+		NodedSegmentString* edge0 = dynamic_cast<NodedSegmentString*>(*i0);
+		assert(edge0);
 		for (SegmentString::NonConstVect::const_iterator
 				i1=edges.begin(), i1End=edges.end();
 				i1!=i1End; ++i1)
-			SegmentString* edge1 = *i1;
+			NodedSegmentString* edge1 = dynamic_cast<NodedSegmentString*>(*i1);
+			assert(edge1);
 			computeVertexSnaps(edge0, edge1);
Modified: trunk/source/operation/buffer/OffsetCurveSetBuilder.cpp
--- trunk/source/operation/buffer/OffsetCurveSetBuilder.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/source/operation/buffer/OffsetCurveSetBuilder.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -14,7 +14,7 @@
@@ -35,7 +35,7 @@
 #include <geos/geom/Triangle.h>
 #include <geos/geomgraph/Position.h>
 #include <geos/geomgraph/Label.h>
 #include <cmath>
 #include <cassert>
@@ -68,7 +68,6 @@
 OffsetCurveSetBuilder::~OffsetCurveSetBuilder()
-	//delete cga;
 	for (size_t i=0, n=curveList.size(); i<n; ++i)
 		delete curveList[i]->getCoordinates();
@@ -117,7 +116,11 @@
 	// add the edge for a coordinate list which is a raw offset curve
 	Label *newlabel = new Label(0, Location::BOUNDARY, leftLoc, rightLoc);
-	SegmentString *e=new SegmentString(coord, newlabel); // SegmentString doesnt own the sequence, so we need to delete in the destructor
+	SegmentString *e=new NodedSegmentString(coord, newlabel);
+	// SegmentString doesnt own the sequence, so we need to delete in
+	// the destructor
 	newLabels.push_back(newlabel);
 	curveList.push_back(e);
@@ -222,6 +225,14 @@
 		return;
+	// don't attemtp to buffer a polygon
+	// with too few distinct vertices
+	if (distance <= 0.0 && shellCoord->size() < 3)
+		delete shellCoord;
+        	return;
 	addPolygonRing(
 		shellCoord,
 		offsetDistance,
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/tests/unit/Makefile.am	2009-04-07 19:00:36 UTC (rev 2319)
@@ -50,9 +50,10 @@
 	index/quadtree/DoubleBitsTest.cpp \
 	io/ByteOrderValuesTest.cpp \
 	io/WKBReaderTest.cpp \
+	noding/BasicSegmentStringTest.cpp \
+	noding/NodedSegmentStringTest.cpp \
 	noding/SegmentNodeTest.cpp \
 	noding/SegmentPointComparatorTest.cpp \
-	noding/SegmentStringTest.cpp \
 	operation/distance/DistanceOpTest.cpp \
 	operation/IsSimpleOpTest.cpp \
 	operation/overlay/FuzzyPointLocatorTest.cpp \
Copied: trunk/tests/unit/noding/BasicSegmentStringTest.cpp (from rev 2311, trunk/tests/unit/noding/SegmentStringTest.cpp)
--- trunk/tests/unit/noding/BasicSegmentStringTest.cpp	                        (rev 0)
+++ trunk/tests/unit/noding/BasicSegmentStringTest.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -0,0 +1,211 @@
+// $Id@
+// Test Suite for geos::noding::BasicSegmentString class.
+// TUT
+#include <tut.h>
+// GEOS
+#include <geos/geom/CoordinateArraySequenceFactory.h>
+#include <memory>
+namespace tut
+    // Test Group
+    // Common data used by tests
+    struct test_basicsegmentstring_data
+    	typedef std::auto_ptr<geos::geom::CoordinateSequence> \
+		CoordinateSequenceAutoPtr;
+    	typedef std::auto_ptr<geos::noding::BasicSegmentString> \
+		SegmentStringAutoPtr;
+	const geos::geom::CoordinateSequenceFactory* csFactory;
+	makeSegmentString(geos::geom::CoordinateSequence* cs, void *d = 0)
+		return SegmentStringAutoPtr(
+			new geos::noding::BasicSegmentString(cs, d)
+	test_basicsegmentstring_data()
+		csFactory(geos::geom::CoordinateArraySequenceFactory::instance())
+	~test_basicsegmentstring_data()
+    typedef test_group<test_basicsegmentstring_data> group;
+    typedef group::object object;
+    group test_basicsegmentstring_group("geos::noding::BasicSegmentString");
+    // Test Cases
+    // test constructor with 2 equal points
+    template<>
+    template<>
+    void object::test<1>()
+    	CoordinateSequenceAutoPtr cs(csFactory->create(0, 2));
+	ensure(cs.get());
+	geos::geom::Coordinate c0(0, 0);
+	geos::geom::Coordinate c1(0, 0);
+	cs->add(c0);
+	cs->add(c1);
+	ensure_equals(cs->size(), 2u);
+	SegmentStringAutoPtr ss(makeSegmentString(cs.get()));
+	ensure(ss.get());
+	ensure_equals(ss->size(), 2u);
+	ensure_equals(ss->getData(), (void*)0);
+	ensure_equals(ss->getCoordinates(), cs.get());
+	ensure_equals(ss->getCoordinate(0), c0);
+	ensure_equals(ss->getCoordinate(1), c1);
+	ensure_equals(ss->isClosed(), true);
+	// this would throw an exception
+	bool octant_failed=false;
+	try {
+		ss->getSegmentOctant(0);
+	} catch (...) {
+		octant_failed=true;
+	ensure(octant_failed);
+    // test constructor with 2 different points
+    template<>
+    template<>
+    void object::test<2>()
+	ensure(cs.get());
+	geos::geom::Coordinate c1(1, 0);
+	cs->add(c0);
+	cs->add(c1);
+	ensure(ss.get());
+	ensure_equals(ss->isClosed(), false);
+	ensure_equals(ss->getSegmentOctant(0), 0);
+    // test constructor with 4 different points forming a ring
+    template<>
+    template<>
+    void object::test<3>()
+	ensure(cs.get());
+	geos::geom::Coordinate c2(1, 1);
+	cs->add(c0);
+	cs->add(c1);
+	cs->add(c2);
+	cs->add(c0);
+	ensure_equals(cs->size(), 4u);
+	ensure(ss.get());
+	ensure_equals(ss->size(), 4u);
+	ensure_equals(ss->getCoordinate(2), c2);
+	ensure_equals(ss->getCoordinate(3), c0);
+	ensure_equals(ss->getSegmentOctant(2), 4);
+	ensure_equals(ss->getSegmentOctant(1), 1);
+	// test Octant class
+	template<>
+	template<>
+	void object::test<4>()
+		geos::geom::Coordinate p0(0, 0);
+		geos::geom::Coordinate p1(5,-5);
+		int octant_rc1 = 0;
+		int octant_rc2 = 0;
+		int testPassed = true;
+		try {
+			octant_rc1 = geos::noding::Octant::octant(p0,p1);
+			octant_rc2 = geos::noding::Octant::octant(&p0,&p1);
+			testPassed = (octant_rc1 == octant_rc2);
+		catch (...) {
+			testPassed = false;
+		ensure(testPassed);
+} // namespace tut
Property changes on: trunk/tests/unit/noding/BasicSegmentStringTest.cpp
___________________________________________________________________
   + text/plain
   + Id
   + native
Added: trunk/tests/unit/noding/NodedSegmentStringTest.cpp
--- trunk/tests/unit/noding/NodedSegmentStringTest.cpp	                        (rev 0)
+++ trunk/tests/unit/noding/NodedSegmentStringTest.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -0,0 +1,283 @@
+// $Id@
+// Test Suite for geos::noding::NodedSegmentString class.
+// TUT
+#include <tut.h>
+// GEOS
+#include <memory>
+namespace tut
+    // Test Group
+    struct test_nodedsegmentstring_data
+    	typedef std::auto_ptr<geos::noding::NodedSegmentString> \
+			new geos::noding::NodedSegmentString(cs, d)
+	test_nodedsegmentstring_data()
+	~test_nodedsegmentstring_data()
+    typedef test_group<test_nodedsegmentstring_data> group;
+    group test_nodedsegmentstring_group("geos::noding::NodedSegmentString");
+    // Test Cases
+    template<>
+    template<>
+	ensure(cs.get());
+	cs->add(c0);
+	cs->add(c1);
+	ensure(ss.get());
+	ensure_equals(ss->getNodeList().size(), 0u);
+	try {
+	} catch (...) {
+    template<>
+    template<>
+	ensure(cs.get());
+	cs->add(c0);
+	cs->add(c1);
+	ensure(ss.get());
+    template<>
+    template<>
+	ensure(cs.get());
+	cs->add(c0);
+	cs->add(c1);
+	cs->add(c2);
+	cs->add(c0);
+	ensure(ss.get());
+	template<>
+	template<>
+		try {
+		catch (...) {
+	// test adding intersections
+	template<>
+	template<>
+	void object::test<5>()
+		geos::geom::Coordinate p1(10, 0);
+		cs->add(p0);
+		cs->add(p1);
+		// the intersection is invalid, but SegmentString trusts us
+		ss->addIntersection(p0, 0);
+		ensure_equals(ss->getNodeList().size(), 1u);
+		// This node is already present, so shouldn't be
+		// accepted as a new one
+		ss->addIntersection(p1, 0);
+		ensure_equals(ss->getNodeList().size(), 2u);
+	// TODO: test getting noded substrings
+//	template<>
+//	template<>
+//	void object::test<6>()
+//		geos::geom::Coordinate cs1p0(0, 0);
+//		geos::geom::Coordinate cs1p1(10, 0);
+//		CoordinateSequenceAutoPtr cs1(csFactory->create(0, 2));
+//		cs1->add(cs1p0);
+//		cs1->add(cs1p1);
+//		geos::geom::Coordinate cs2p0(5, -5);
+//		geos::geom::Coordinate cs2p1(5, 5);
+//		CoordinateSequenceAutoPtr cs2(csFactory->create(0, 2));
+//		cs2->add(cs2p0);
+//		cs2->add(cs2p1);
+//		using geos::noding::SegmentString;
+//		using geos::noding::NodedSegmentString;
+//		SegmentString::NonConstVect inputStrings;
+//		inputStrings.push_back(makeSegmentString(cs2.get()).get());
+//		std::auto_ptr<SegmentString::NonConstVect> nodedStrings(
+//			NodedSegmentString::getNodedSubstrings(inputStrings)
+//		ensure_equals(nodedStrings->size(), 0u);
+} // namespace tut
Modified: trunk/tests/unit/noding/SegmentNodeTest.cpp
--- trunk/tests/unit/noding/SegmentNodeTest.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/tests/unit/noding/SegmentNodeTest.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -6,7 +6,7 @@
 #include <tut.h>
 // GEOS
@@ -50,7 +50,7 @@
         using geos::geom::Coordinate;
-        using geos::noding::SegmentString;
+        using geos::noding::BasicSegmentString;
         using geos::noding::SegmentNode;
         // Create coordinates sequence
@@ -68,7 +68,7 @@
         // Create SegmentString instance
-        SegmentString segment(cs.get(), 0);
+        BasicSegmentString segment(cs.get(), 0);
         ensure_equals( segment.size(), coords_size );
Deleted: trunk/tests/unit/noding/SegmentStringTest.cpp
--- trunk/tests/unit/noding/SegmentStringTest.cpp	2009-04-07 12:36:50 UTC (rev 2318)
+++ trunk/tests/unit/noding/SegmentStringTest.cpp	2009-04-07 19:00:36 UTC (rev 2319)
@@ -1,263 +0,0 @@
-// $Id$
-// Test Suite for geos::noding::SegmentString class.
-// TUT
-#include <tut.h>
-// GEOS
-#include <geos/geom/CoordinateArraySequenceFactory.h>
-#include <memory>
-namespace tut
-    // Test Group
-    // Common data used by tests
-    struct test_segmentstring_data
-    	typedef std::auto_ptr<geos::geom::CoordinateSequence> \
-		CoordinateSequenceAutoPtr;
-    	typedef std::auto_ptr<geos::noding::SegmentString> \
-		SegmentStringAutoPtr;
-	const geos::geom::CoordinateSequenceFactory* csFactory;
-	makeSegmentString(geos::geom::CoordinateSequence* cs, void *d = 0)
-		return SegmentStringAutoPtr(
-			new geos::noding::SegmentString(cs, d)
-	test_segmentstring_data()
-		csFactory(geos::geom::CoordinateArraySequenceFactory::instance())
-	~test_segmentstring_data()
-    typedef test_group<test_segmentstring_data> group;
-    typedef group::object object;
-    group test_segmentstring_group("geos::noding::SegmentString");
-    // Test Cases
-    // test constructor with 2 equal points
-    template<>
-    template<>
-    void object::test<1>()
-    	CoordinateSequenceAutoPtr cs(csFactory->create(0, 2));
-	ensure(cs.get());
-	geos::geom::Coordinate c0(0, 0);
-	geos::geom::Coordinate c1(0, 0);
-	cs->add(c0);
-	cs->add(c1);
-	ensure_equals(cs->size(), 2u);
-	SegmentStringAutoPtr ss(makeSegmentString(cs.get()));
-	ensure(ss.get());
-	ensure_equals(ss->size(), 2u);
-	ensure_equals(ss->getData(), (void*)0);
-	ensure_equals(ss->getCoordinates(), cs.get());
-	ensure_equals(ss->getCoordinate(0), c0);
-	ensure_equals(ss->getCoordinate(1), c1);
-	ensure_equals(ss->isIsolated(), false);
-	ensure_equals(ss->isClosed(), true);
-	// this would throw an exception
-	bool octant_failed=false;
-	try {
-		ss->getSegmentOctant(0);
-	} catch (...) {
-		octant_failed=true;
-	ensure(octant_failed);
-	ensure_equals(ss->getNodeList().size(), 0u);
-    // test constructor with 2 different points
-    template<>
-    template<>
-    void object::test<2>()
-	ensure(cs.get());
-	geos::geom::Coordinate c1(1, 0);
-	cs->add(c0);
-	cs->add(c1);
-	ensure(ss.get());
-	ensure_equals(ss->isClosed(), false);
-	ensure_equals(ss->getSegmentOctant(0), 0);
-    // test constructor with 4 different points forming a ring
-    template<>
-    template<>
-    void object::test<3>()
-	ensure(cs.get());
-	geos::geom::Coordinate c2(1, 1);
-	cs->add(c0);
-	cs->add(c1);
-	cs->add(c2);
-	cs->add(c0);
-	ensure_equals(cs->size(), 4u);
-	ensure(ss.get());
-	ensure_equals(ss->size(), 4u);
-	ensure_equals(ss->getCoordinate(2), c2);
-	ensure_equals(ss->getCoordinate(3), c0);
-	ensure_equals(ss->getSegmentOctant(2), 4);
-	ensure_equals(ss->getSegmentOctant(1), 1);
-    // test adding intersections
-    template<>
-    template<>
-    void object::test<4>()
-	geos::geom::Coordinate p0(0, 0);
-	geos::geom::Coordinate p1(10, 0);
-	cs->add(p0);
-	cs->add(p1);
-	// the intersection is invalid, but SegmentString trusts us
-	ss->addIntersection(p0, 0);
-	ensure_equals(ss->getNodeList().size(), 1u);
-	// This node is already present, so shouldn't be
-	// accepted as a new one
-	ss->addIntersection(p1, 0);
-	ensure_equals(ss->getNodeList().size(), 2u);
-	// test Octant class
-	template<>
-	template<>
-	void object::test<5>()
-		geos::geom::Coordinate p1(5,-5);
-		int octant_rc1 = 0;
-		int octant_rc2 = 0;
-		int testPassed = true;
-		try {
-			octant_rc1 = geos::noding::Octant::octant(p0,p1);
-			octant_rc2 = geos::noding::Octant::octant(&p0,&p1);
-			testPassed = (octant_rc1 == octant_rc2);
-		catch (...) {
-			testPassed = false;
-		ensure(testPassed);
-} // namespace tut
More information about the geos-commits mailing list
