[geos-commits] r2320 - in trunk: source/headers/geos/noding
	source/noding tests/unit/noding
    svn_geos at osgeo.org
    Wed Apr  8 05:42:56 EDT 2009
Author: strk
Date: 2009-04-08 05:42:55 -0400 (Wed, 08 Apr 2009)
New Revision: 2320
   trunk/source/headers/geos/noding/NodableSegmentString.h
   trunk/source/headers/geos/noding/NodedSegmentString.h
   trunk/source/headers/geos/noding/SegmentNode.h
   trunk/source/headers/geos/noding/SegmentNodeList.h
   trunk/source/noding/SegmentNode.cpp
   trunk/source/noding/SegmentNodeList.cpp
   trunk/tests/unit/noding/SegmentNodeTest.cpp
   trunk/tests/unit/noding/SegmentPointComparatorTest.cpp
Port SegmentNode to JTS-1.9
Modified: trunk/source/headers/geos/noding/NodableSegmentString.h
--- trunk/source/headers/geos/noding/NodableSegmentString.h	2009-04-07 19:00:36 UTC (rev 2319)
+++ trunk/source/headers/geos/noding/NodableSegmentString.h	2009-04-08 09:42:55 UTC (rev 2320)
@@ -17,7 +17,7 @@
 #ifndef GEOS_NODING_NODABLESEGMENTSTRING_H
 #define GEOS_NODING_NODABLESEGMENTSTRING_H
-#include <geos/noding/SegmentString.h>
+#include <geos/noding/SegmentString.h> // for inheritance
 namespace geos {
 	namespace geom {
Modified: trunk/source/headers/geos/noding/NodedSegmentString.h
--- trunk/source/headers/geos/noding/NodedSegmentString.h	2009-04-07 19:00:36 UTC (rev 2319)
+++ trunk/source/headers/geos/noding/NodedSegmentString.h	2009-04-08 09:42:55 UTC (rev 2320)
@@ -21,9 +21,9 @@
 #ifndef GEOS_NODING_NODEDSEGMENTSTRING_H
 #define GEOS_NODING_NODEDSEGMENTSTRING_H
+#include <geos/noding/NodableSegmentString.h> // for inheritance
 #include <geos/geom/CoordinateSequence.h> // for inlines
 #include <geos/algorithm/LineIntersector.h>
-#include <geos/noding/NodableSegmentString.h>
 #include <geos/noding/SegmentNode.h>
 #include <geos/noding/SegmentNodeList.h>
Modified: trunk/source/headers/geos/noding/SegmentNode.h
--- trunk/source/headers/geos/noding/SegmentNode.h	2009-04-07 19:00:36 UTC (rev 2319)
+++ trunk/source/headers/geos/noding/SegmentNode.h	2009-04-08 09:42:55 UTC (rev 2320)
@@ -11,6 +11,10 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
+ *  Last port: noding/SegmentNode.java rev. 1.6 (JTS-1.9)
 #ifndef GEOS_NODING_SEGMENTNODE_H
@@ -26,22 +30,20 @@
 // Forward declarations
 namespace geos {
 	namespace noding {
-		class SegmentString;
+		class NodedSegmentString;
 namespace geos {
 namespace noding { // geos.noding
-/// Represents an intersection point between two SegmentString.
+/// Represents an intersection point between two NodedSegmentString.
 /// Final class.
-/// Last port: noding/SegmentNode.java rev. 1.5 (JTS-1.7)
 class SegmentNode {
 private:
-	const SegmentString& segString;
+	const NodedSegmentString& segString;
 	int segmentOctant;
@@ -56,18 +58,20 @@
 	/// the index of the containing line segment in the parent edge
 	unsigned int segmentIndex;
-	/// Construct a node on the given SegmentString
+	/// Construct a node on the given NodedSegmentString
-	/// @param ss the parent SegmentString
+	/// @param ss the parent NodedSegmentString
 	/// @param coord the coordinate of the intersection, will be copied
-	/// @param nSegmentIndex the index of the segment on parent SegmentString
+	/// @param nSegmentIndex the index of the segment on parent
+	///                      NodedSegmentString
 	///        where the Node is located.
 	/// @param nSegmentOctant
-	SegmentNode(const SegmentString& ss, const geom::Coordinate& nCoord,
+	SegmentNode(const NodedSegmentString& ss,
+		    const geom::Coordinate& nCoord,
 			unsigned int nSegmentIndex, int nSegmentOctant);
 	~SegmentNode() {}
Modified: trunk/source/headers/geos/noding/SegmentNodeList.h
--- trunk/source/headers/geos/noding/SegmentNodeList.h	2009-04-07 19:00:36 UTC (rev 2319)
+++ trunk/source/headers/geos/noding/SegmentNodeList.h	2009-04-08 09:42:55 UTC (rev 2320)
@@ -35,6 +35,7 @@
 		class CoordinateSequence;
 	namespace noding {
+		class SegmentString;
@@ -44,7 +45,7 @@
 /** \brief
  * A list of the SegmentNode present along a
- * noded SegmentString.
+ * NodedSegmentString.
 class SegmentNodeList {
 private:
@@ -53,9 +54,6 @@
 	// the parent edge
 	const NodedSegmentString& edge;
-	// UNUSED
-	//std::vector<SegmentNode*> *sortedNodes;
 	// This vector is here to keep track of created splitEdges
 	std::vector<SegmentString*> splitEdges;
Modified: trunk/source/noding/SegmentNode.cpp
--- trunk/source/noding/SegmentNode.cpp	2009-04-07 19:00:36 UTC (rev 2319)
+++ trunk/source/noding/SegmentNode.cpp	2009-04-08 09:42:55 UTC (rev 2320)
@@ -14,7 +14,7 @@
- * Last port: noding/SegmentNode.java rev. 1.5 (JTS-1.7)
@@ -27,7 +27,7 @@
 #include <iomanip>
+#include <geos/noding/NodedSegmentString.h>
 #include <geos/geom/Coordinate.h>
 using namespace std;
@@ -103,7 +103,7 @@
 /*public*/
-SegmentNode::SegmentNode(const SegmentString& ss, const Coordinate& nCoord,
+SegmentNode::SegmentNode(const NodedSegmentString& ss, const Coordinate& nCoord,
 	segString(ss),
@@ -111,7 +111,7 @@
 	coord(nCoord),
 	segmentIndex(nSegmentIndex)
-	// Number of points in SegmentString is one-more number of segments
+	// Number of points in NodedSegmentString is one-more number of segments
 	assert(segmentIndex < segString.size() );
 	isInteriorVar = \
Modified: trunk/source/noding/SegmentNodeList.cpp
--- trunk/source/noding/SegmentNodeList.cpp	2009-04-07 19:00:36 UTC (rev 2319)
+++ trunk/source/noding/SegmentNodeList.cpp	2009-04-08 09:42:55 UTC (rev 2320)
@@ -25,6 +25,7 @@
 #include <geos/util/GEOSException.h>
+#include <geos/noding/SegmentString.h> // for use
 #include <geos/geom/CoordinateArraySequence.h> // FIXME: should we really be using this ?
Modified: trunk/tests/unit/noding/SegmentNodeTest.cpp
--- trunk/tests/unit/noding/SegmentNodeTest.cpp	2009-04-07 19:00:36 UTC (rev 2319)
+++ trunk/tests/unit/noding/SegmentNodeTest.cpp	2009-04-08 09:42:55 UTC (rev 2320)
@@ -6,7 +6,7 @@
 #include <tut.h>
 // GEOS
-#include <geos/noding/BasicSegmentString.h>
 #include <geos/geom/CoordinateArraySequenceFactory.h>
@@ -50,7 +50,7 @@
     void object::test<1>()
         using geos::geom::Coordinate;
-        using geos::noding::BasicSegmentString;
+        using geos::noding::NodedSegmentString;
         using geos::noding::SegmentNode;
         // Create coordinates sequence
@@ -68,11 +68,11 @@
         // Create SegmentString instance
-        BasicSegmentString segment(cs.get(), 0);
+        NodedSegmentString segment(cs.get(), 0);
         ensure_equals( segment.size(), coords_size );
-        // Construct a node on the given SegmentString
+        // Construct a node on the given NodedSegmentString
             const size_t segment_index = 0;
             Coordinate cint(3, 3);
Modified: trunk/tests/unit/noding/SegmentPointComparatorTest.cpp
--- trunk/tests/unit/noding/SegmentPointComparatorTest.cpp	2009-04-07 19:00:36 UTC (rev 2319)
+++ trunk/tests/unit/noding/SegmentPointComparatorTest.cpp	2009-04-08 09:42:55 UTC (rev 2320)
@@ -6,6 +6,7 @@
 #include <tut.h>
 // GEOS
More information about the geos-commits
