[geos-commits] r2358 - in trunk/source: algorithm headers/geos/algorithm
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Apr 14 09:23:08 EDT 2009
Author: strk
Date: 2009-04-14 09:23:07 -0400 (Tue, 14 Apr 2009)
New Revision: 2358
   trunk/source/algorithm/CGAlgorithms.cpp
   trunk/source/headers/geos/algorithm/CGAlgorithms.h
Sync CGAlgorithms with JTS-1.9
Modified: trunk/source/algorithm/CGAlgorithms.cpp
--- trunk/source/algorithm/CGAlgorithms.cpp	2009-04-14 12:55:39 UTC (rev 2357)
+++ trunk/source/algorithm/CGAlgorithms.cpp	2009-04-14 13:23:07 UTC (rev 2358)
@@ -14,15 +14,18 @@
- * Last port: algorithm/CGAlgorithms.java rev. 1.34 (JTS-1.7.1)
+ * Last port: algorithm/CGAlgorithms.java rev. 1.46 (JTS-1.9)
 #include <geos/algorithm/CGAlgorithms.h>
 #include <geos/algorithm/RobustDeterminant.h>
 #include <geos/algorithm/LineIntersector.h>
+#include <geos/algorithm/RayCrossingCounter.h>
 #include <geos/geom/CoordinateSequence.h>
 #include <geos/geom/Coordinate.h>
+#include <geos/geom/Location.h>
+#include <geos/util/IllegalArgumentException.h>
 #include <algorithm>
 //#include <cstdio>
@@ -53,48 +56,7 @@
 bool
 CGAlgorithms::isPointInRing(const Coordinate& p, const CoordinateSequence* ring)
-	double xInt;  // x intersection of segment with ray
-	int crossings = 0;  // number of segment/ray crossings
-	double x1;    // translated coordinates
-	double y1;
-	double x2;
-	double y2;
-	 * For each segment l = (i-1, i), see if it crosses ray from
-	 * test point in positive x direction.
-	size_t nPts=ring->getSize();
-	for(size_t i=1; i<nPts; i++)
-		const Coordinate &p1=ring->getAt(i);
-		const Coordinate &p2=ring->getAt(i-1);
-		x1 = p1.x - p.x;
-		y1 = p1.y - p.y;
-		x2 = p2.x - p.x;
-		y2 = p2.y - p.y;
-		if (((y1 > 0) && (y2 <= 0)) ||
-			((y2 > 0) && (y1 <= 0)))
-			 *  segment straddles x axis, so compute intersection.
-			xInt = RobustDeterminant::signOfDet2x2(x1, y1, x2, y2)
-				/ (y2 - y1);
-			 *  crosses ray if strictly positive intersection.
-			if (0.0 < xInt) crossings++;
-	 *  p is inside if number of crossings is odd.
-	if ((crossings % 2) == 1) return true;
-	return false;
+	return locatePointInRing(p, *ring) != Location::EXTERIOR;
 /*public static*/
@@ -102,47 +64,23 @@
 		const Coordinate::ConstVect& ring)
-	double y1;
-	double x2;
-	double y2;
+	return locatePointInRing(p, ring) != Location::EXTERIOR;
-	for(size_t i=1, nPts=ring.size(); i<nPts; ++i)
-		const Coordinate *p1=ring[i];
-		const Coordinate *p2=ring[i-1];
-		x1 = p1->x - p.x;
-		y1 = p1->y - p.y;
-		x2 = p2->x - p.x;
-		y2 = p2->y - p.y;
+/*public static*/
+int
+CGAlgorithms::locatePointInRing(const Coordinate& p,
+		const CoordinateSequence& ring)
+	return RayCrossingCounter::locatePointInRing(p, ring);
-				/ (y2 - y1);
-	return false;
+/*public static*/
+int
+		const std::vector<const geom::Coordinate*>& ring)
 /*public static*/
@@ -169,12 +107,18 @@
 CGAlgorithms::isCCW(const CoordinateSequence* ring)
 	// # of points without closing endpoint
-    const std::size_t nPts=ring->getSize()-1;
+	const std::size_t nPts=ring->getSize()-1;
+	// sanity check
+	if (nPts < 3)
+		throw util::IllegalArgumentException("Ring has fewer than 3 points, so orientation cannot be determined");
 	// find highest point
 	const Coordinate *hiPt=&ring->getAt(0);
 	int hiIndex=0;
-    for (std::size_t i=1; i<=nPts; ++i)
+	for (std::size_t i=1; i<=nPts; ++i)
 		const Coordinate *p=&ring->getAt(i);
 		if (p->y > hiPt->y) {
@@ -379,17 +323,32 @@
 double
 CGAlgorithms::length(const CoordinateSequence* pts)
+	// optimized for processing CoordinateSequences
 	size_t npts=pts->getSize();
+	if (npts <= 1) return 0.0;
-	if (npts<1) return 0.0;
+	double len = 0.0;
-	double sum=0.0;
+	const Coordinate& p = pts->getAt(0);
+	double x0 = p.x;
+	double y0 = p.y;
-	for(size_t i=1; i<npts; ++i)
+	for(size_t i = 1; i < npts; ++i)
-		sum+=pts->getAt(i).distance(pts->getAt(i - 1));
+		const Coordinate& p = pts->getAt(i);
+		double x1 = p.x;
+		double y1 = p.y;
+		double dx = x1 - x0;
+		double dy = y1 - y0;
+		len += sqrt(dx * dx + dy * dy);
+		x0 = x1;
+		y0 = y1;
-	return sum;
+	return len;
Modified: trunk/source/headers/geos/algorithm/CGAlgorithms.h
--- trunk/source/headers/geos/algorithm/CGAlgorithms.h	2009-04-14 12:55:39 UTC (rev 2357)
+++ trunk/source/headers/geos/algorithm/CGAlgorithms.h	2009-04-14 13:23:07 UTC (rev 2358)
@@ -14,7 +14,7 @@
@@ -62,18 +62,20 @@
 	CGAlgorithms(){};
 	/** \brief
-	 * Test whether a point lies inside a ring.
+	 * Tests whether a point lies inside a ring.
 	 * The ring may be oriented in either direction.
-	 * If the point lies on the ring boundary the result
-	 * of this method is unspecified.
+	 * A point lying exactly on the ring boundary is considered
+	 * to be inside the ring.
-	 * This algorithm does not attempt to first check the
+	 * This algorithm does not first check the
 	 * point against the envelope of the ring.
 	 * @param p point to check for ring inclusion
-	 * @param ring assumed to have first point identical to last point
+	 * @param ring is assumed to have first point identical to last point
 	 * @return <code>true</code> if p is inside ring
+	 * @see locatePointInRing
 	static bool isPointInRing(const geom::Coordinate& p,
 			const geom::CoordinateSequence* ring);
@@ -83,8 +85,29 @@
 			const std::vector<const geom::Coordinate*>& ring);
 	/** \brief
-	 * Test whether a point lies on a linestring.
+	 * Determines whether a point lies in the interior,
+	 * on the boundary, or in the exterior of a ring.
+	 * The ring may be oriented in either direction.
+	 * This method does <i>not</i> first check the point against
+	 * the envelope of the ring.
+	 * @param p point to check for ring inclusion
+	 * @param ring an array of coordinates representing the ring
+	 *        (which must have first point identical to last point)
+	 * @return the {@link Location} of p relative to the ring
+	static int locatePointInRing(const geom::Coordinate& p,
+			const geom::CoordinateSequence& ring);
+	/// Same as above, but taking a vector of const Coordinates
+			const std::vector<const geom::Coordinate*>& ring);
+	/** \brief
+	 * Test whether a point lies on the given line segment
 	 * @return true true if
 	 * the point is a vertex of the line or lies in the interior of a line
 	 * segment in the linestring
More information about the geos-commits mailing list
