[geos-commits] r2359 - in trunk/source: algorithm
headers/geos/algorithm
svn_geos at osgeo.org
Tue Apr 14 09:35:21 EDT 2009
Author: strk
Date: 2009-04-14 09:35:21 -0400 (Tue, 14 Apr 2009)
New Revision: 2359
trunk/source/algorithm/LineIntersector.cpp
trunk/source/headers/geos/algorithm/LineIntersector.h
Sync (Robust)LineIntersector to JTS-1.9
Modified: trunk/source/algorithm/LineIntersector.cpp
--- trunk/source/algorithm/LineIntersector.cpp 2009-04-14 13:23:07 UTC (rev 2358)
+++ trunk/source/algorithm/LineIntersector.cpp 2009-04-14 13:35:21 UTC (rev 2359)
@@ -14,7 +14,7 @@
- * Last port: algorithm/RobustLineIntersector.java rev. 1.35
+ * Last port: algorithm/RobustLineIntersector.java rev. 1.37 (JTS-1.9)
@@ -692,36 +692,13 @@
/*private*/
void
-LineIntersector::intersection(const Coordinate& p1, const Coordinate& p2,
- const Coordinate& q1, const Coordinate& q2, Coordinate &intPt) const
+LineIntersector::intersection(const Coordinate& p1,
+ const Coordinate& p2, const Coordinate& q1, const Coordinate& q2,
+ Coordinate &intPt) const
- Coordinate n1=p1;
- Coordinate n2=p2;
- Coordinate n3=q1;
- Coordinate n4=q2;
- Coordinate normPt;
- //normalize(&n1, &n2, &n3, &n4, &normPt);
- normalizeToEnvCentre(n1, n2, n3, n4, normPt);
+ intersectionWithNormalization(p1, p2, q1, q2, intPt);
-#if GEOS_DEBUG
- cerr<<"RobustIntersector::intersection(p1,p2,q1,q2,intPt) called:"<<endl;
- cerr<<" p1:"<<p1.toString()<<endl;
- cerr<<" p2:"<<p2.toString()<<endl;
- cerr<<" q1:"<<q1.toString()<<endl;
- cerr<<" q2:"<<q2.toString()<<endl;
- cerr<<" n1:"<<n1.toString()<<endl;
- cerr<<" n2:"<<n2.toString()<<endl;
- cerr<<" n3:"<<n3.toString()<<endl;
- cerr<<" n4:"<<n4.toString()<<endl;
-#endif
- safeHCoordinateIntersection(n1,n2,n3,n4,intPt);
- intPt.x+=normPt.x;
- intPt.y+=normPt.y;
* Due to rounding it can happen that the computed intersection is
* outside the envelopes of the input segments. Clearly this
@@ -746,7 +723,9 @@
#endif
- if (precisionModel!=NULL) precisionModel->makePrecise(intPt);
+ if (precisionModel!=NULL) {
+ precisionModel->makePrecise(intPt);
#if COMPUTE_Z
@@ -761,7 +740,26 @@
+/*private*/
+void
+LineIntersector::intersectionWithNormalization(const Coordinate& p1,
+ Coordinate n1=p1;
+ Coordinate n2=p2;
+ Coordinate n3=q1;
+ Coordinate n4=q2;
+ Coordinate normPt;
+ normalizeToEnvCentre(n1, n2, n3, n4, normPt);
+ safeHCoordinateIntersection(n1, n2, n3, n4, intPt);
+ intPt.x += normPt.x;
+ intPt.y += normPt.y;
/*private*/
double
LineIntersector::smallestInAbsValue(double x1,double x2,double x3,double x4) const
Modified: trunk/source/headers/geos/algorithm/LineIntersector.h
--- trunk/source/headers/geos/algorithm/LineIntersector.h 2009-04-14 13:23:07 UTC (rev 2358)
+++ trunk/source/headers/geos/algorithm/LineIntersector.h 2009-04-14 13:35:21 UTC (rev 2359)
@@ -14,7 +14,7 @@
@@ -232,6 +232,12 @@
private:
+ void intersectionWithNormalization(const geom::Coordinate& p1,
+ const geom::Coordinate& p2,
+ const geom::Coordinate& q1,
+ const geom::Coordinate& q2,
+ geom::Coordinate &ret) const;
* If makePrecise is true, computed intersection coordinates
* will be made precise using Coordinate#makePrecise
More information about the geos-commits
