[geos-commits] r2375 - trunk/tests/unit/algorithm
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Apr 16 08:08:26 EDT 2009
Author: strk
Date: 2009-04-16 08:08:26 -0400 (Thu, 16 Apr 2009)
New Revision: 2375
   trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp
better isolation of test-specific functions
Modified: trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp
--- trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp	2009-04-16 10:48:14 UTC (rev 2374)
+++ trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp	2009-04-16 12:08:26 UTC (rev 2375)
@@ -30,24 +30,9 @@
 	// Test Group
-	struct test_lineintersector_data {};
-	typedef test_group<test_lineintersector_data> group;
-	typedef group::object object;
-	group test_lineintersector_group(
-		"geos::algorithm::RobustLineIntersection");
-	// These are static to avoid namespace pollution
-	// The struct test_*_data above is probably there
-	// for the same reason...
-	static PrecisionModel pm;
-	static GeometryFactory gf(&pm);
-        static geos::io::WKTReader reader(&gf);
+	struct test_robustlineintersection_data
 	typedef std::auto_ptr<Geometry> GeomPtr;
-	typedef std::auto_ptr<Geometry> GeomPtr;
 	bool equals(const Coordinate& p0, const Coordinate& p1,
 	            double distanceTolerance)
@@ -191,9 +176,27 @@
 		                    intPt, distanceTolerance);
+	test_robustlineintersection_data()
+		pm(),
+		gf(&pm),
+		reader(&gf)
+	PrecisionModel pm;
+	GeometryFactory gf;
+        geos::io::WKTReader reader;
+	typedef test_group<test_robustlineintersection_data> group;
+	typedef group::object object;
+	group test_robustlineintersection_group(
+		"geos::algorithm::RobustLineIntersection");
 	// Test Cases
More information about the geos-commits mailing list
