[geos-commits] r2376 - in trunk/tests/unit: . algorithm
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Apr 16 08:54:34 EDT 2009
Author: strk
Date: 2009-04-16 08:54:34 -0400 (Thu, 16 Apr 2009)
New Revision: 2376
Added:
   trunk/tests/unit/algorithm/RobustLineIntersectorTest.cpp
   trunk/tests/unit/Makefile.am
Port RobustLineIntersectorTest from JTS
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2009-04-16 12:08:26 UTC (rev 2375)
+++ trunk/tests/unit/Makefile.am	2009-04-16 12:54:34 UTC (rev 2376)
@@ -35,6 +35,7 @@
 	algorithm/ConvexHullTest.cpp \
 	algorithm/PointLocatorTest.cpp \
 	algorithm/RobustLineIntersectionTest.cpp \
+	algorithm/RobustLineIntersectorTest.cpp \
 	geom/CoordinateArraySequenceFactoryTest.cpp \
 	geom/CoordinateArraySequenceTest.cpp \
 	geom/CoordinateListTest.cpp \
Added: trunk/tests/unit/algorithm/RobustLineIntersectorTest.cpp
--- trunk/tests/unit/algorithm/RobustLineIntersectorTest.cpp	                        (rev 0)
+++ trunk/tests/unit/algorithm/RobustLineIntersectorTest.cpp	2009-04-16 12:54:34 UTC (rev 2376)
@@ -0,0 +1,255 @@
+// $Id$
+// Ported from JTS junit/algorithm/RobustLineIntersectorTest.java rev. 1.1
+#include <tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+#include <geos/algorithm/LineIntersector.h>
+#include <geos/algorithm/CGAlgorithms.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h> // required for use in auto_ptr
+#include <geos/geom/LineString.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateArraySequence.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+using namespace geos::geom; //
+using geos::algorithm::LineIntersector;
+using geos::algorithm::CGAlgorithms;
+namespace tut
+	// Test Group
+	struct test_robustlineintersector_data {
+	typedef std::auto_ptr<Geometry> GeomPtr;
+	LineIntersector i;
+	typedef test_group<test_robustlineintersector_data> group;
+	typedef group::object object;
+	group test_robustlineintersector_group(
+		"geos::algorithm::RobustLineIntersector");
+	// Test Cases
+	// 1 - test2Lines
+	template<>
+	template<>
+	void object::test<1>()
+    Coordinate p1(10, 10);
+    Coordinate p2(20, 20);
+    Coordinate q1(20, 10);
+    Coordinate q2(10, 20);
+    Coordinate x(15, 15);
+    i.computeIntersection(p1, p2, q1, q2);
+    ensure_equals(i.getIntersectionNum(), (int)LineIntersector::DO_INTERSECT);
+    ensure_equals(i.getIntersectionNum(), 1);
+    ensure_equals(i.getIntersection(0), x);
+    ensure("isProper", i.isProper());
+    ensure("hasIntersection", i.hasIntersection());
+	// 2 - testCollinear1
+	template<>
+	template<>
+	void object::test<2>()
+    Coordinate p2(20, 10);
+    Coordinate q1(22, 10);
+    Coordinate q2(30, 10);
+    ensure_equals(i.getIntersectionNum(), (int)LineIntersector::DONT_INTERSECT);
+    ensure_equals(i.getIntersectionNum(), 0);
+    ensure("!isProper", !i.isProper());
+    ensure("!hasIntersection", !i.hasIntersection());
+	// 3 - testCollinear2
+	template<>
+	template<>
+	void object::test<3>()
+	// 4 - testCollinear3
+	template<>
+	template<>
+	void object::test<4>()
+    Coordinate q1(15, 10);
+    ensure_equals(i.getIntersectionNum(), (int)LineIntersector::COLLINEAR);
+    ensure_equals(i.getIntersectionNum(), 2);
+	// 5 - testCollinear4
+	template<>
+	template<>
+	void object::test<5>()
+    Coordinate q1(10, 10);
+	// 6 - testEndpointIntersection
+	template<>
+	template<>
+	void object::test<6>()
+    i.computeIntersection(Coordinate(100, 100), Coordinate(10, 100),
+        Coordinate(100, 10), Coordinate(100, 100));
+	// 7 - testEndpointIntersection2
+	template<>
+	template<>
+	void object::test<7>()
+    i.computeIntersection(Coordinate(190, 50), Coordinate(120, 100),
+        Coordinate(120, 100), Coordinate(50, 150));
+    ensure_equals(i.getIntersection(1), Coordinate(120, 100));
+	// 8 - testOverlap
+	template<>
+	template<>
+	void object::test<8>()
+    i.computeIntersection(Coordinate(180, 200), Coordinate(160, 180),
+        Coordinate(220, 240), Coordinate(140, 160));
+	// 9 - testIsProper1
+	template<>
+	template<>
+	void object::test<9>()
+    i.computeIntersection(Coordinate(30, 10), Coordinate(30, 30),
+        Coordinate(10, 10), Coordinate(90, 11));
+	// 10 - testIsProper2
+	template<>
+	template<>
+	void object::test<10>()
+    i.computeIntersection(Coordinate(10, 30), Coordinate(10, 0),
+        Coordinate(11, 90), Coordinate(10, 10));
+	// 11 - testIsCCW
+	template<>
+	template<>
+	void object::test<11>()
+	    ensure_equals(CGAlgorithms::computeOrientation(
+		Coordinate(-123456789, -40),
+		Coordinate(0, 0),
+		Coordinate(381039468754763.0, 123456789)), 1);
+	// 12 - testIsCCW2
+	template<>
+	template<>
+	void object::test<12>()
+		Coordinate(20, 20),
+		Coordinate(0, 0)), 0);
+	// 13 - testA
+	template<>
+	template<>
+	void object::test<13>()
+    Coordinate p1(-123456789, -40);
+    Coordinate p2(381039468754763.0, 123456789);
+    Coordinate q(0, 0);
+    using geos::geom::CoordinateSequence;
+    using geos::geom::GeometryFactory;
+    using geos::geom::LineString;
+    GeometryFactory factory;
+    CoordinateSequence* cs = new CoordinateArraySequence();
+    cs->add(p1);
+    cs->add(p2);
+    LineString* l = factory.createLineString(cs);
+    Point* p = factory.createPoint(q);
+    ensure(!l->intersects(p));
+    ensure(!CGAlgorithms::isOnLine(q, l->getCoordinatesRO()));
+    ensure_equals(CGAlgorithms::computeOrientation(p1, p2, q), -1);
+} // namespace tut
More information about the geos-commits mailing list
