[geos-commits] r2410 - in trunk/source: headers/geos/index/quadtree index/quadtree
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Apr 27 11:30:52 EDT 2009
Author: strk
Date: 2009-04-27 11:30:52 -0400 (Mon, 27 Apr 2009)
New Revision: 2410
   trunk/source/headers/geos/index/quadtree/Quadtree.h
   trunk/source/index/quadtree/Quadtree.cpp
Sync to JTS-1.10, reduce heap allocations and pointers usage. Includes a bugfix in collectStats.
Modified: trunk/source/headers/geos/index/quadtree/Quadtree.h
--- trunk/source/headers/geos/index/quadtree/Quadtree.h	2009-04-27 15:00:53 UTC (rev 2409)
+++ trunk/source/headers/geos/index/quadtree/Quadtree.h	2009-04-27 15:30:52 UTC (rev 2410)
@@ -13,7 +13,7 @@
- * Last port: index/quadtree/Quadtree.java rev. 1.14
+ * Last port: index/quadtree/Quadtree.java rev. 1.16 (JTS-1.10)
@@ -21,7 +21,7 @@
 #define GEOS_IDX_QUADTREE_QUADTREE_H
 #include <geos/index/SpatialIndex.h> // for inheritance
-#include <geos/index/quadtree/Root.h> // for inline
+#include <geos/index/quadtree/Root.h> // for composition
 #include <vector>
 #include <string>
@@ -70,9 +70,9 @@
 	std::vector<geom::Envelope *> newEnvelopes;
-	void collectStats(const geom::Envelope *itemEnv);
+	void collectStats(const geom::Envelope& itemEnv);
-	Root *root;
+	Root root;
 	 *  Statistics
@@ -104,7 +104,7 @@
 	Quadtree()
-		root(new Root()),
+		root(),
 		minExtent(1.0)
@@ -118,22 +118,57 @@
 	void insert(const geom::Envelope *itemEnv, void *item);
+	/** \brief
+	 * Queries the tree and returns items which may lie
+	 * in the given search envelope.
+	 * Precisely, the items that are returned are all items in the tree
+	 * whose envelope <b>may</b> intersect the search Envelope.
+	 * Note that some items with non-intersecting envelopes may be
+	 * returned as well;
+	 * the client is responsible for filtering these out.
+	 * In most situations there will be many items in the tree which do not
+	 * intersect the search envelope and which are not returned - thus
+	 * providing improved performance over a simple linear scan.
+	 * @param searchEnv the envelope of the desired query area.
+	 * @param ret a vector where items which may intersect the
+	 * 	      search envelope are pushed
 	void query(const geom::Envelope *searchEnv, std::vector<void*>& ret);
-	void query(const geom::Envelope *searchEnv, ItemVisitor& visitor) {
+	/** \brief
+	 * Queries the tree and visits items which may lie in
+	 * the given search envelope.
+	 * Precisely, the items that are visited are all items in the tree
+	 * visited as well;
+	 * intersect the search envelope and which are not visited - thus
+	 * @param visitor a visitor object which is passed the visited items
+	void query(const geom::Envelope *searchEnv, ItemVisitor& visitor)
 		 * the items that are matched are the items in quads which
 		 * overlap the search envelope
-		root->visit(searchEnv, visitor);
+		root.visit(searchEnv, visitor);
 	 * Removes a single item from the tree.
-	 * @param itemEnv the Envelope of the item to remove
+	 * @param itemEnv the Envelope of the item to be removed
 	 * @param item the item to remove
-	 * @return <code>true</code> if the item was found
+	 * @return <code>true</code> if the item was found (and thus removed)
 	bool remove(const geom::Envelope* itemEnv, void* item);
Modified: trunk/source/index/quadtree/Quadtree.cpp
--- trunk/source/index/quadtree/Quadtree.cpp	2009-04-27 15:00:53 UTC (rev 2409)
+++ trunk/source/index/quadtree/Quadtree.cpp	2009-04-27 15:30:52 UTC (rev 2410)
@@ -14,7 +14,7 @@
@@ -71,41 +71,35 @@
 	for (unsigned int i=0; i<newEnvelopes.size(); i++)
 		delete newEnvelopes[i];
-	delete root;
 /*public*/
 int
 Quadtree::depth()
-	//I don't think it's possible for root to be null. Perhaps we should
-	//remove the check. [Jon Aquino]
-    //Or make an assertion [Jon Aquino 10/29/2003]
-	if (root!=NULL) return root->depth();
-	return 0;
+	return root.depth();
 /*public*/
 int
 Quadtree::size()
-	assert(root!=NULL);
-	return root->size();
+	return root.size();
 /*public*/
 void
 Quadtree::insert(const Envelope *itemEnv, void* item)
-	collectStats(itemEnv);
+	collectStats(*itemEnv);
 	Envelope *insertEnv=ensureExtent(itemEnv,minExtent);
 	if ( insertEnv != itemEnv ) newEnvelopes.push_back(insertEnv);
-	root->insert(insertEnv,item);
+	root.insert(insertEnv,item);
 #if GEOS_DEBUG
 	cerr<<"Quadtree::insert("<<itemEnv->toString()<<", "<<item<<")"<<endl;
 	cerr<<"       insertEnv:"<<insertEnv->toString()<<endl;
-	cerr<<"       tree:"<<endl<<root->toString()<<endl;
+	cerr<<"       tree:"<<endl<<root.toString()<<endl;
 #endif
@@ -119,12 +113,12 @@
-	root->addAllItemsFromOverlapping(*searchEnv, foundItems);
+	root.addAllItemsFromOverlapping(*searchEnv, foundItems);
 #if GEOS_DEBUG
 	cerr<<"Quadtree::query returning "<<foundItems.size()
 		<<" items over "<<size()
 		<<" items in index (of depth: "<<depth()<<")"<<endl;
-	cerr<<" Root:\n"<<root->toString()<<endl;
+	cerr<<" Root:\n"<<root.toString()<<endl;
 #endif
@@ -133,7 +127,7 @@
 Quadtree::queryAll()
 	vector<void*> *foundItems=new vector<void*>();
-	root->addAllItems(*foundItems);
+	root.addAllItems(*foundItems);
 	return foundItems;
@@ -142,28 +136,29 @@
 Quadtree::remove(const Envelope* itemEnv, void* item)
 	Envelope* posEnv = ensureExtent(itemEnv, minExtent);
-	bool ret = root->remove(posEnv, item);
+	bool ret = root.remove(posEnv, item);
 	if ( posEnv != itemEnv ) delete posEnv;
 	return ret;
 /*private*/
 void
-Quadtree::collectStats(const Envelope *itemEnv)
+Quadtree::collectStats(const Envelope& itemEnv)
-	double delX=itemEnv->getWidth();
-	if (delX<minExtent && delX>0.0)
-		minExtent=delX;
-	double delY=itemEnv->getWidth();
-	if (delY<minExtent && delY>0.0)
-		minExtent=delY;
+	double delX = itemEnv.getWidth();
+	if (delX < minExtent && delX > 0.0)
+		minExtent = delX;
+	double delY = itemEnv.getHeight();
+	if (delY < minExtent && delY > 0.0)
+		minExtent = delY;
 /*public*/
 string
 Quadtree::toString() const
-	string ret = root->toString();
+	string ret = root.toString();
 	return ret;
More information about the geos-commits mailing list
