[geos-commits] r2427 - in trunk/tests/xmltester: . tests
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Apr 30 05:49:53 EDT 2009
Author: strk
Date: 2009-04-30 05:49:53 -0400 (Thu, 30 Apr 2009)
New Revision: 2427
Added:
   trunk/tests/xmltester/tests/TestSimple.xml
   trunk/tests/xmltester/Makefile.am
   trunk/tests/xmltester/tests/testLeaksBig.xml
Import TestSimple.xml from JTS, drop duplicated tests from testLeaksBig.xml
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am	2009-04-30 09:26:28 UTC (rev 2426)
+++ trunk/tests/xmltester/Makefile.am	2009-04-30 09:49:53 UTC (rev 2427)
@@ -8,7 +8,7 @@
 EXTRA_DIST = testrunner.sh
-SAFE_XMLTESTS=$(srcdir)/tests/testLeaksBig.xml $(srcdir)/tests/hexwkb.xml $(srcdir)/tests/test.xml $(srcdir)/tests/linemerge.xml $(srcdir)/tests/TestInteriorPoint.xml $(srcdir)/tests/TestCentroid.xml $(srcdir)/tests/TestIsValid.xml $(srcdir)/tests/TestValid.xml $(srcdir)/tests/TestValid2.xml $(srcdir)/tests/TestValid2-big.xml $(srcdir)/tests/robustness.xml $(srcdir)/tests/stmlf-cases-20061020.xml $(srcdir)/tests/TestRobustOverlayFixed.xml $(srcdir)/tests/fme.xml $(srcdir)/tests/TestBuffer.xml $(srcdir)/tests/TestBufferExternal.xml $(srcdir)/tests/TestBufferExternal2.xml $(srcdir)/tests/TestBufferMitredJoin.xml $(srcdir)/tests/heisenbugs.xml $(srcdir)/tests/stmlf-cases-20070119.xml $(srcdir)/tests/badguy3.xml $(srcdir)/tests/hole_from_shell.xml $(srcdir)/tests/hole_red.xml
+SAFE_XMLTESTS=$(srcdir)/tests/testLeaksBig.xml $(srcdir)/tests/TestSimple.xml $(srcdir)/tests/hexwkb.xml $(srcdir)/tests/test.xml $(srcdir)/tests/linemerge.xml $(srcdir)/tests/TestInteriorPoint.xml $(srcdir)/tests/TestCentroid.xml $(srcdir)/tests/TestIsValid.xml $(srcdir)/tests/TestValid.xml $(srcdir)/tests/TestValid2.xml $(srcdir)/tests/TestValid2-big.xml $(srcdir)/tests/robustness.xml $(srcdir)/tests/stmlf-cases-20061020.xml $(srcdir)/tests/TestRobustOverlayFixed.xml $(srcdir)/tests/fme.xml $(srcdir)/tests/TestBuffer.xml $(srcdir)/tests/TestBufferExternal.xml $(srcdir)/tests/TestBufferExternal2.xml $(srcdir)/tests/TestBufferMitredJoin.xml $(srcdir)/tests/heisenbugs.xml $(srcdir)/tests/stmlf-cases-20070119.xml $(srcdir)/tests/badguy3.xml $(srcdir)/tests/hole_from_shell.xml $(srcdir)/tests/hole_red.xml
 XMLTESTS=$(SAFE_XMLTESTS)
Added: trunk/tests/xmltester/tests/TestSimple.xml
--- trunk/tests/xmltester/tests/TestSimple.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/TestSimple.xml	2009-04-30 09:49:53 UTC (rev 2427)
@@ -0,0 +1,296 @@
+<run>
+  <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/>
+<case>
+  <desc>P - point</desc>
+  <a>
+    POINT(10 10)
+  </a>
+<test>
+  <op name="isSimple" arg1="A">
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>mP - multipoint with repeated points</desc>
+  <a>
+    MULTIPOINT ((80 280), (80 220), (160 220), (80 220))
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>mP - multipoint with no repeated points</desc>
+  <a>
+    MULTIPOINT ((80 280), (80 220), (160 220))
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>mP - empty</desc>
+  <a>
+    MULTIPOINT EMPTY
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>L - simple line</desc>
+  <a>
+    LINESTRING(10 10, 20 20)
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>L - non-simple, proper interior intersection</desc>
+  <a>
+    LINESTRING (20 60, 160 60, 80 160, 80 20)
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>L - non-simple, interior intersection at vertices</desc>
+  <a>
+    LINESTRING (20 80, 80 20, 80 80, 140 60, 80 20, 160 20)
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>L - non-simple, interior intersection at Bdy/non-vertex</desc>
+  <a>
+    LINESTRING (20 60, 100 60, 60 100, 60 60)
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>L - non-simple, interior intersection at Bdy/vertex</desc>
+  <a>
+    LINESTRING (20 60, 60 60, 100 60, 60 100, 60 60)
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>L - simple, intersection at Bdy/Bdy (ring)</desc>
+  <a>
+    LINESTRING (20 20, 80 20, 80 80, 20 20)
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>L - simple, intersection at Bdy/Bdy + non-vertex</desc>
+  <a>
+    LINESTRING (80 80, 20 20, 20 80, 140 80, 140 140, 80 80)
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>L - empty</desc>
+  <a>
+    LINESTRING EMPTY
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>mL - intersection between elements at non-vertex</desc>
+  <a>
+    MULTILINESTRING(
+  (40 140, 160 40),
+  (160 140, 40 40))
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>mL - no intersection between elements</desc>
+  <a>
+    MULTILINESTRING(
+  (20 160, 20 20),
+  (100 160, 100 20))
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>mL - mutual intersection at endpoints only</desc>
+  <a>
+    MULTILINESTRING ((60 140, 20 80, 60 40),
+  (60 40, 100 80, 60 140))
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>mL - one element is non-simple</desc>
+  <a>
+    MULTILINESTRING ((60 40, 140 40, 100 120, 100 0),
+  (100 200, 200 120))
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>mL - proper intersection between elements at vertex</desc>
+  <a>
+    MULTILINESTRING ((40 120, 100 60),
+  (160 120, 100 60),
+  (40 60, 160 60))
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>mL - intersection between closed lines</desc>
+  <a>
+    MULTILINESTRING ((80 160, 40 220, 40 100, 80 160),
+  (80 160, 120 220, 120 100, 80 160))
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>mL - intersection between closed and open lines</desc>
+  <a>
+    MULTILINESTRING ((80 160, 40 220),
+  (80 160, 120 220, 120 100, 80 160),
+  (40 100, 80 160))
+  </a>
+<test>
+    false
+  </op>
+</test>
+</case>
+<case>
+  <desc>A</desc>
+  <a>
+    POLYGON ((180 260, 80 300, 40 180, 160 120, 180 260))
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>A - empty</desc>
+  <a>
+    POLYGON EMPTY
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>mA</desc>
+  <a>
+    MULTIPOLYGON (((240 160, 140 220, 80 60, 220 40, 240 160)),
+  ((160 380, 100 240, 20 380, 160 380),
+    (120 340, 60 360, 80 320, 120 340)))
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>mA - with touching elements</desc>
+  <a>
+    MULTIPOLYGON (((240 160, 100 240, 80 60, 220 40, 240 160)),
+  </a>
+<test>
+    true
+  </op>
+</test>
+</case>
+</run>
Modified: trunk/tests/xmltester/tests/testLeaksBig.xml
--- trunk/tests/xmltester/tests/testLeaksBig.xml	2009-04-30 09:26:28 UTC (rev 2426)
+++ trunk/tests/xmltester/tests/testLeaksBig.xml	2009-04-30 09:49:53 UTC (rev 2427)
@@ -10284,122 +10284,6 @@
   </test>
 </case>
-<case><desc>P - point</desc><a>POINT(10 10)</a>
-<test><op name="isSimple" arg1="A">true</op>
-</test>
-</case>
-<case><desc>mP - multipoint with repeated points</desc><a>MULTIPOINT (80 280, 80 220, 160 220, 80 220)</a>
-<test><op name="isSimple" arg1="A">false</op>
-</test>
-</case>
-<case><desc>mP - multipoint with no repeated points</desc><a>MULTIPOINT (80 280, 80 220, 160 220)</a>
-</test>
-</case>
-<case><desc>mP - empty</desc><a>MULTIPOINT EMPTY</a>
-</test>
-</case>
-<case><desc>L - simple line</desc><a>LINESTRING(10 10, 20 20)</a>
-</test>
-</case>
-<case><desc>L - non-simple, proper interior intersection</desc><a>LINESTRING (20 60, 160 60, 80 160, 80 20)</a>
-</test>
-</case>
-<case><desc>L - non-simple, interior intersection at vertices</desc><a>LINESTRING (20 80, 80 20, 80 80, 140 60, 80 20, 160 20)</a>
-</test>
-</case>
-<case><desc>L - non-simple, interior intersection at Bdy/non-vertex</desc><a>LINESTRING (20 60, 100 60, 60 100, 60 60)</a>
-</test>
-</case>
-<case><desc>L - non-simple, interior intersection at Bdy/vertex</desc><a>LINESTRING (20 60, 60 60, 100 60, 60 100, 60 60)</a>
-</test>
-</case>
-<case><desc>L - simple, intersection at Bdy/Bdy (ring)</desc><a>LINESTRING (20 20, 80 20, 80 80, 20 20)</a>
-</test>
-</case>
-<case><desc>L - simple, intersection at Bdy/Bdy + non-vertex</desc><a>LINESTRING (80 80, 20 20, 20 80, 140 80, 140 140, 80 80)</a>
-</test>
-</case>
-<case><desc>L - empty</desc><a>LINESTRING EMPTY</a>
-</test>
-</case>
-<case><desc>mL - intersection between elements at non-vertex</desc><a>MULTILINESTRING((40 140, 160 40), (160 140, 40 40))</a>
-</test>
-</case>
-<case><desc>mL - no intersection between elements</desc><a>MULTILINESTRING((20 160, 20 20), (100 160, 100 20))</a>
-</test>
-</case>
-<case><desc>mL - mutual intersection at endpoints only</desc><a>MULTILINESTRING ((60 140, 20 80, 60 40), (60 40, 100 80, 60 140))</a>
-</test>
-</case>
-<case><desc>mL - one element is non-simple</desc><a>MULTILINESTRING ((60 40, 140 40, 100 120, 100 0), (100 200, 200 120))</a>
-</test>
-</case>
-<case><desc>mL - proper intersection between elements at vertex</desc><a>MULTILINESTRING ((40 120, 100 60), (160 120, 100 60), (40 60, 160 60))</a>
-</test>
-</case>
-<case><desc>mL - intersection between closed lines</desc><a>MULTILINESTRING ((80 160, 40 220, 40 100, 80 160), (80 160, 120 220, 120 100, 80 160))</a>
-</test>
-</case>
-<case><desc>mL - intersection between closed and open lines</desc><a>MULTILINESTRING ((80 160, 40 220), (80 160, 120 220, 120 100, 80 160), (40 100, 80 160))</a>
-</test>
-</case>
-<case><desc>A</desc><a>POLYGON ((180 260, 80 300, 40 180, 160 120, 180 260))</a>
-</test>
-</case>
-<case><desc>A - empty</desc><a>POLYGON EMPTY</a>
-</test>
-</case>
-<case><desc>mA</desc><a>MULTIPOLYGON (((240 160, 140 220, 80 60, 220 40, 240 160)), ((160 380, 100 240, 20 380, 160 380), (120 340, 60 360, 80 320, 120 340)))</a>
-</test>
-</case>
-<case><desc>mA - with touching elements</desc><a>MULTIPOLYGON (((240 160, 100 240, 80 60, 220 40, 240 160)), ((160 380, 100 240, 20 380, 160 380), (120 340, 60 360, 80 320, 120 340)))</a>
-</test>
-</case>
 <case>
   <desc>PP - disjoint points</desc>
   <a>    POINT(10 10)  </a>
More information about the geos-commits mailing list
