[geos-commits] r2428 - in trunk/source: headers/geos/operation operation
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Apr 30 05:54:09 EDT 2009
Author: strk
Date: 2009-04-30 05:54:09 -0400 (Thu, 30 Apr 2009)
New Revision: 2428
   trunk/source/headers/geos/operation/IsSimpleOp.h
   trunk/source/operation/IsSimpleOp.cpp
port to rev 1.8 (use of BoundaryNodeRule)
Modified: trunk/source/headers/geos/operation/IsSimpleOp.h
--- trunk/source/headers/geos/operation/IsSimpleOp.h	2009-04-30 09:49:53 UTC (rev 2427)
+++ trunk/source/headers/geos/operation/IsSimpleOp.h	2009-04-30 09:54:09 UTC (rev 2428)
@@ -4,6 +4,7 @@
  * GEOS - Geometry Engine Open Source
  * http://geos.refractions.net
+ * Copyright (C) 2009      Sandro Santilli <strk at keybit.net>
  * Copyright (C) 2005-2006 Refractions Research Inc.
  * Copyright (C) 2001-2002 Vivid Solutions Inc.
@@ -14,7 +15,7 @@
- * Last port: operation/IsSimpleOp.java rev. 1.17
+ * Last port: operation/IsSimpleOp.java rev. 1.18
@@ -25,6 +26,9 @@
 // Forward declarations
 namespace geos {
+	namespace algorithm {
+		class BoundaryNodeRule;
 	namespace geom {
 		class LineString;
 		class MultiLineString;
@@ -50,28 +54,65 @@
  * In general, the SFS specification of simplicity follows the rule:
- *  - A Geometry is simple iff the only self-intersections are at
- *    boundary points.
+ *  - A Geometry is simple if and only if the only self-intersections
+ *    are at boundary points.
+ * This definition relies on the definition of boundary points.
+ * The SFS uses the Mod-2 rule to determine which points are on the boundary of
+ * lineal geometries, but this class supports
+ * using other {@link BoundaryNodeRule}s as well.
  * Simplicity is defined for each {@link Geometry} subclass as follows:
  *  - Valid polygonal geometries are simple by definition, so
  *    <code>isSimple</code> trivially returns true.
+ *    (Hint: in order to check if a polygonal geometry has self-intersections,
+ *    use {@link Geometry::isValid}).
  *  - Linear geometries are simple iff they do not self-intersect at points
- *    other than boundary points.
+ *    other than boundary points. (This means that closed linestrings
+ *    cannot be touched at their endpoints, since by the Mod-2 rule these are
+ *    interior points, not boundary points).
  *  - Zero-dimensional geometries (points) are simple iff they have no
  *    repeated points.
  *  - Empty <code>Geometry</code>s are always simple
+ * @see algorithm::BoundaryNodeRule
-class IsSimpleOp {
+class IsSimpleOp
 public:
+	/** \brief
+	 * Creates a simplicity checker using the default
+	 * SFS Mod-2 Boundary Node Rule
 	IsSimpleOp();
+	/** \brief
+	 * Creates a simplicity checker using a given
+	 * algorithm::BoundaryNodeRule
+	IsSimpleOp(const algorithm::BoundaryNodeRule& boundaryNodeRule);
+	 * Reports whether a geom::LineString is simple.
+	 * @param geom the lineal geometry to test
+	 * @return true if the geometry is simple
 	bool isSimple(const geom::LineString *geom);
+	 * Reports whether a geom::MultiLineString is simple.
 	bool isSimple(const geom::MultiLineString *geom);
@@ -107,6 +148,8 @@
 	void addEndpoint(std::map<const geom::Coordinate*, EndpointInfo*,
 			geom::CoordinateLessThen>&endPoints,
 			const geom::Coordinate *p, bool isClosed);
+	bool isClosedEndpointsInInterior;
 } // namespace geos.operation
Modified: trunk/source/operation/IsSimpleOp.cpp
--- trunk/source/operation/IsSimpleOp.cpp	2009-04-30 09:49:53 UTC (rev 2427)
+++ trunk/source/operation/IsSimpleOp.cpp	2009-04-30 09:54:09 UTC (rev 2428)
@@ -4,6 +4,7 @@
  * Copyright (C) 2005 Refractions Research Inc.
@@ -14,12 +15,13 @@
 #include <geos/operation/IsSimpleOp.h>
 #include <geos/operation/EndpointInfo.h>
+#include <geos/algorithm/BoundaryNodeRule.h>
 #include <geos/algorithm/LineIntersector.h>
 #include <geos/geomgraph/GeometryGraph.h>
 #include <geos/geomgraph/Edge.h>
@@ -45,9 +47,17 @@
 /*public*/
 IsSimpleOp::IsSimpleOp()
+	isClosedEndpointsInInterior(true)
 /*public*/
+IsSimpleOp::IsSimpleOp(const algorithm::BoundaryNodeRule& boundaryNodeRule)
+	isClosedEndpointsInInterior( ! boundaryNodeRule.isInBoundary(2) )
+/*public*/
 bool
 IsSimpleOp::isSimple(const LineString *geom)
@@ -87,25 +97,19 @@
 	if (geom->isEmpty()) return true;
 	GeometryGraph graph(0,geom);
 	LineIntersector li;
-	SegmentIntersector *si=graph.computeSelfNodes(&li,true);
+	std::auto_ptr<SegmentIntersector> si (graph.computeSelfNodes(&li,true));
 	// if no self-intersection, must be simple
-	if (!si->hasIntersection()) {
-		delete si;
-		return true;
+	if (!si->hasIntersection()) return true;
+	if (si->hasProperIntersection()) return false;
+	if (hasNonEndpointIntersection(graph)) return false;
+	if ( isClosedEndpointsInInterior ) {
+		if (hasClosedEndpointIntersection(graph)) return false;
-	if (si->hasProperIntersection()) {
-		delete si;
-		return false;
-	if (hasNonEndpointIntersection(graph)) {
-		delete si;
-		return false;
-	if (hasClosedEndpointIntersection(graph)) {
-		delete si;
-		return false;
-	delete si;
 	return true;
More information about the geos-commits mailing list
