[geos-commits] r2644 - trunk/source/operation/buffer
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Oct 1 03:23:13 EDT 2009
Author: strk
Date: 2009-10-01 03:23:07 -0400 (Thu, 01 Oct 2009)
New Revision: 2644
   trunk/source/operation/buffer/BufferBuilder.cpp
Use FLAT/BUTT endcaps when doing single sided buffering
Modified: trunk/source/operation/buffer/BufferBuilder.cpp
--- trunk/source/operation/buffer/BufferBuilder.cpp	2009-10-01 07:06:36 UTC (rev 2643)
+++ trunk/source/operation/buffer/BufferBuilder.cpp	2009-10-01 07:23:07 UTC (rev 2644)
@@ -131,8 +131,17 @@
    // First, generate the two-sided buffer using a butt-cap.
    BufferParameters modParams = bufParams;
    modParams.setEndCapStyle(BufferParameters::CAP_FLAT);
-   Geometry* buf = buffer( l, distance );
+   Geometry* buf = 0;
+   // This is a (temp?) hack to workaround the fact that
+   // BufferBuilder BufferParamaters are immutable after
+   // construction, while we want to force the end cap
+   // style to FLAT for single-sided buffering
+      BufferBuilder tmp(modParams);
+      buf = tmp.buffer( l, distance );
    // Create MultiLineStrings from this polygon.
    Geometry* bufLineString = buf->getBoundary();
More information about the geos-commits mailing list
