[geos-commits] r3500 - branches/3.3
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Oct 18 18:08:15 EDT 2011
Author: mloskot
Date: 2011-10-18 15:08:15 -0700 (Tue, 18 Oct 2011)
New Revision: 3500
   branches/3.3/CMakeLists.txt
Missing versions update in CMake configuration (#490)
Modified: branches/3.3/CMakeLists.txt
--- branches/3.3/CMakeLists.txt	2011-10-05 23:24:56 UTC (rev 3499)
+++ branches/3.3/CMakeLists.txt	2011-10-18 22:08:15 UTC (rev 3500)
@@ -30,17 +30,17 @@
 # GEOS C++ library SONAME will use these encoding ABI break at every release
 set(VERSION_MAJOR 3)
 set(VERSION_MINOR 3)
-set(VERSION_PATCH 0)
+set(VERSION_PATCH 2dev)
 set(VERSION "${VERSION_MAJOR}.${VERSION_MINOR}.${VERSION_PATCH}")
 # JTS_PORT is the version of JTS this release is bound to
-set(JTS_PORT 1.10.0)
+set(JTS_PORT 1.12.0)
 message(STATUS "Setting GEOS version ${VERSION} as port of JTS ${JTS_PORT}")
 # GEOS C API version
-set(CAPI_INTERFACE_CURRENT 7)
-set(CAPI_INTERFACE_REVISION 1)
-set(CAPI_INTERFACE_AGE 6)
+set(CAPI_INTERFACE_CURRENT 8)
+set(CAPI_INTERFACE_REVISION 2)
+set(CAPI_INTERFACE_AGE 7)
 math(EXPR CAPI_VERSION_MAJOR "${CAPI_INTERFACE_CURRENT} - ${CAPI_INTERFACE_AGE}")
 set(CAPI_VERSION_MINOR ${CAPI_INTERFACE_AGE})
More information about the geos-commits mailing list
