[geos-commits] r3501 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Oct 18 18:12:14 EDT 2011
Author: mloskot
Date: 2011-10-18 15:12:14 -0700 (Tue, 18 Oct 2011)
New Revision: 3501
   trunk/CMakeLists.txt
Missing 3.4.0 versions update in CMake configuration
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt	2011-10-18 22:08:15 UTC (rev 3500)
+++ trunk/CMakeLists.txt	2011-10-18 22:12:14 UTC (rev 3501)
@@ -28,18 +28,18 @@
 # GEOS release version
 # GEOS C++ library SONAME will use these encoding ABI break at every release
 set(VERSION_MAJOR 3)
-set(VERSION_MINOR 3)
-set(VERSION_PATCH 0)
+set(VERSION_MINOR 4)
+set(VERSION_PATCH dev)
 set(VERSION "${VERSION_MAJOR}.${VERSION_MINOR}.${VERSION_PATCH}")
 # JTS_PORT is the version of JTS this release is bound to
-set(JTS_PORT 1.10.0)
+set(JTS_PORT 1.12.0)
 message(STATUS "Setting GEOS version ${VERSION} as port of JTS ${JTS_PORT}")
 # GEOS C API version
-set(CAPI_INTERFACE_CURRENT 7)
-set(CAPI_INTERFACE_REVISION 1)
-set(CAPI_INTERFACE_AGE 6)
+set(CAPI_INTERFACE_CURRENT 9)
+set(CAPI_INTERFACE_REVISION 0)
+set(CAPI_INTERFACE_AGE 8)
 math(EXPR CAPI_VERSION_MAJOR "${CAPI_INTERFACE_CURRENT} - ${CAPI_INTERFACE_AGE}")
 set(CAPI_VERSION_MINOR ${CAPI_INTERFACE_AGE})
More information about the geos-commits mailing list
