[geos-commits] r4284 - branches/3.4
Sandro Santilli
strk at kbt.io
Thu Oct 27 07:45:21 PDT 2016
Author: strk
Date: 2016-10-27 07:45:20 -0700 (Thu, 27 Oct 2016)
New Revision: 4284
Removed:
branches/3.4/ChangeLog
branches/3.4/Makefile.am
Remove ChangeLog from repository.
The file will be created by "make dist" from either git
(if .git exists) or svn (if .svn exists).
Tested with builds from package, from source dir and from
external build dir. Only automake.
See #778, backported for 3.4 branch
Deleted: branches/3.4/ChangeLog
--- branches/3.4/ChangeLog 2016-10-27 14:27:26 UTC (rev 4283)
+++ branches/3.4/ChangeLog 2016-10-27 14:45:20 UTC (rev 4284)
@@ -1,16506 +0,0 @@
-2013-08-22 07:44 Sandro Santilli <strk at keybit.net>
- * [r3915] .travis.yml, tools/ci, tools/ci/before_install.sh,
- tools/ci/before_install_autotools.sh,
- tools/ci/before_install_cmake.sh, tools/ci/common.sh,
- tools/ci/script.sh, tools/ci/script_autotools.sh,
- tools/ci/script_cmake.sh: Configure Travis CI for GEOS (#657)
- Configurations for GCC and clang with both Autotools and CMake.
- Enable IRC notifications
- Contributed by Mateusz Loskot <mateusz at loskot.net>
-2013-08-22 06:35 Sandro Santilli <strk at keybit.net>
- * [r3911] tests/unit/capi/GEOSisValidDetailTest.cpp: Accept
- multiple NaN representations (#656)
-2013-08-21 13:44 Sandro Santilli <strk at keybit.net>
- * [r3906] CMakeLists.txt, capi/geos_c.h.in, configure.in: Fix CAPI
- version to 1.8.2, and fix a missing c++ version too
- * [r3905] NEWS: Fill up 3.4.2 NEWS section so far
- * [r3904] include/geos/geom/BinaryOp.h: Use a double for
- PrecisionModel scale, avoiding overflows
- Fixes #652
-2013-08-21 11:14 Regina Obe <lr at pcorp.us>
- * [r3903] include/geos/platform.h.in: #650 isnan workaround OS
- detection missing NetBSD, DragonFly, Sun nuance
-2013-08-19 15:39 Regina Obe <lr at pcorp.us>
- * [r3897] include/geos/Makefile.am: #601 backport trunk fix -- do
- not include platform.h , version.h in tar ball, but install
-2013-08-17 17:56 Regina Obe <lr at pcorp.us>
- * [r3895] HOWTO_RELEASE, NEWS: update news release date and
- reminder to do so for future
-2013-08-17 17:47 Regina Obe <lr at pcorp.us>
- * [r3893] capi/geos_c.h.in, configure.in,
- include/geos/version.h.vc: bump versions to 3.4.2dev (3.4.2)
-2013-08-17 14:06 Regina Obe <lr at pcorp.us>
- * [r3891] CMakeLists.txt, configure.in: other changes in
- preparation for 3.4.1 release
-2013-08-17 04:22 Regina Obe <lr at pcorp.us>
- * [r3890] ChangeLog, NEWS: update news and changelog in preparation
- for geos 3.4.1
-2013-08-17 03:09 Regina Obe <lr at pcorp.us>
- * [r3888] CMakeLists.txt: #644 only do svn check if there is a .svn
- file in source folder to ensure it works with tar ball
-2013-08-16 15:26 Sandro Santilli <strk at keybit.net>
- * [r3886] NEWS, src/operation/overlay/snap/LineStringSnapper.cpp,
- tests/unit/capi/GEOSSnapTest.cpp: Fix assertion failure in
- snapping code (#649)
- The bug affected attempts to snapping lines to the points
- of a rectangle with a side smaller than the tolerance.
-2013-08-14 06:10 Regina Obe <lr at pcorp.us>
- * [r3884] CMakeLists.txt, HOWTO_RELEASE: update HOWTO_RELEASE to
- include bumping revision numbrs in CMake and also bump numbers in
- CMake.
-2013-08-14 05:28 Regina Obe <lr at pcorp.us>
- * [r3882] configure.in, include/geos/version.h.vc: bump version
- numbers to 3.4.1dev and 3.4.1 in prep for next release
-2013-08-11 11:42 Sandro Santilli <strk at keybit.net>
- * [r3880] include/geos/platform.h.in,
- tests/xmltester/testrunner.sh, tools/geos-config.in: Set correct
- eol-style for geos-config, platform.h and testrunner (#645)
-2013-08-11 04:17 Regina Obe <lr at pcorp.us>
- * [r3875] NEWS: update date on news
-2013-08-11 03:47 Regina Obe <lr at pcorp.us>
- * [r3872] .: Branch 3.4
-2013-08-11 03:44 Regina Obe <lr at pcorp.us>
- * [r3870] update version numbers to agree with configure.in - huh
- why are the version numbers all old in this file?
-2013-08-11 03:41 Regina Obe <lr at pcorp.us>
- * [r3869] get rid of dev in version# in prep for 3.4.0 release
-2013-08-11 03:37 Regina Obe <lr at pcorp.us>
- * [r3868] update change log in prep for 3.4.0 release
-2013-08-08 04:25 Regina Obe <lr at pcorp.us>
- * [r3867] update news and change log in prep for Aug 10 release of
- 3.4.0
-2013-08-04 20:05 Regina Obe <lr at pcorp.us>
- * [r3866] #601 do not incude platform.h in tar ball.
-2013-08-04 12:27 Sandro Santilli <strk at keybit.net>
- * [r3864] Avoid Coordinate copies in
- DelaunayTriangulationBuilder::envelope
-2013-08-04 12:23 Sandro Santilli <strk at keybit.net>
- * [r3863] Simplify testcase for
-2013-08-04 11:58 Sandro Santilli <strk at keybit.net>
- * [r3862] envelope() method added to DelaunayTriangulationBuilder
- class
- Includes testcase. Patch by Vishal Tiwari
-2013-08-03 15:37 Mateusz Loskot <mateusz at loskot.net>
- * [r3861] Add geos_svn_revision.h generator to CMake config
- Patch from David Burken attached to #643
-2013-08-02 22:38 Regina Obe <lr at pcorp.us>
- * [r3860] #607 Makefile.vc 'clean' step leaks obj files
-2013-08-01 21:13 Regina Obe <lr at pcorp.us>
- * [r3858] updates add some missing ticket items and add ticket
- numbers where missing
-2013-07-31 21:25 Sean Gillies <sgillies at frii.com>
- * [r3857] Print to stderr only in debug mode
-2013-07-31 20:38 Regina Obe <lr at pcorp.us>
- * [r3856] #641 - distinguish between active and inactive group and
- add Regina Obe to list.
-2013-07-31 14:13 Regina Obe <lr at pcorp.us>
- * [r3855]
-2013-07-31 14:07 Regina Obe <lr at pcorp.us>
- * [r3854] add myself to author list
-2013-07-31 09:42 Sandro Santilli <strk at keybit.net>
- * [r3853] Improve overlay robustness
- - Validate CBR results before accepting them
- - Enable overlay node validator even for FIXED precision
- - Enable geometry-reduction policy
- - Bail out on exception from overlay if any input is invalid
- Fixes bug #459
-2013-07-31 08:34 Sandro Santilli <strk at keybit.net>
- * [r3852] Do not expect invalid output from buffer
- The test verification code is tollerant, but better fix this
-2013-07-31 08:30 Sandro Santilli <strk at keybit.net>
- * [r3851] Turn test for ticket 275 into an "area test".
- Area test checks that the area of the Union between two
- geometries
- is about the same as the sum of area of symdifference + area of
- intersection.
-2013-07-25 21:00 Sandro Santilli <strk at keybit.net>
- * [r3850] Fix CoordinateList.closeRing() use of past-the-end
- operator
-2013-07-25 20:51 Sandro Santilli <strk at keybit.net>
- * [r3849] closeRing() method added in CoordinateList class
- Patch by Vishal Tiwari <hi.vishal123 at gmail.com>
-2013-07-23 11:01 Sandro Santilli <strk at keybit.net>
- * [r3848] Cosmetic changes into the CAPI code, by Mike Toews
- - Replace "reader" with "writer" in prototypes
- - describe "_r" functions
- - Function arguments with only one geometry changed from g1 to g
- - Rename nf -> ef for
- GEOSContext_setErrorHandler_rsetErrorHandler_r
- - Move GEOSBuffer* declaration to top of buffer related function
- section
- - Change char* mat to char *mat
- - Fix typos in comments
- - Clip trailing white space, and other white space consistencies
- - Other minor rearrangements for consistency
-2013-07-17 16:07 Sandro Santilli <strk at keybit.net>
- * [r3846] Make GEOSOffsetCurve survive single-point input (with an
- exception)
-2013-07-17 15:58 Sandro Santilli <strk at keybit.net>
- * [r3845] Fix OffsetCurve op in presence of duplicated vertices
- (#602)
-2013-07-17 13:05 Sandro Santilli <strk at keybit.net>
- * [r3844] Fix LineSegmentVisitor copy ctor (#636)
-2013-07-15 15:21 Sandro Santilli <strk at keybit.net>
- * [r3840] Drop SRID from geometrycollection elements (#583)
-2013-07-12 12:37 Sandro Santilli <strk at keybit.net>
- * [r3839] Add test for #580 (successful)
-2013-07-11 15:58 Sandro Santilli <strk at keybit.net>
- * [r3837] Fix memory leak in testcase
-2013-07-11 15:54 Sandro Santilli <strk at keybit.net>
- * [r3836] Drop carriage returns
-2013-07-11 15:34 Sandro Santilli <strk at keybit.net>
- * [r3835] Fix memory in QuadEdgeSubdivision (#604)
-2013-07-11 08:21 Sandro Santilli <strk at keybit.net>
- * [r3834] Expose Delaunay triangulation to PHP API (#567)
-2013-07-11 07:36 Sandro Santilli <strk at keybit.net>
- * [r3833] Fix test after changes in PointOnSurface
-2013-07-11 05:49 Sandro Santilli <strk at keybit.net>
- * [r3832] Add --cclibs, --static-clibs and --static-cclibs to
- geos-config (#497)
-2013-07-11 05:46 Sandro Santilli <strk at keybit.net>
- * [r3831] Add 3.3.1 to 3.3.8 section
-2013-07-11 05:42 Sandro Santilli <strk at keybit.net>
- * [r3830] Cleanup NEWS file confused in r3816
-2013-07-05 14:56 Sandro Santilli <strk at keybit.net>
- * [r3829] Fix install location of linearref headers (#624)
-2013-06-28 10:33 Mateusz Loskot <mateusz at loskot.net>
- * [r3827] Add NMAKE version from Visual Studio 2012 Update 3 RTM
-2013-06-26 16:27 Sandro Santilli <strk at keybit.net>
- * [r3826] Fix typo in HotPixel corners initializer
- Patch by Mickael BORNE <mickael.borne at ign.fr>
-2013-06-26 16:03 Mateusz Loskot <mateusz at loskot.net>
- * [r3824] Add another NMAKE version from Visual Studio 2012
-2013-06-12 16:08 Mateusz Loskot <mateusz at loskot.net>
- * [r3823] Final clarification of
- BufferBuilder::bufferLineSingleSided behaviour (ticket #633)
- * Ignore BufferParameters::setSingleSided() parameter as it is
- specific to areal geometries.
- * Document semantic of input parameters.
- * Document order of coordinates in generated output (conforms to
- PostGIS behaviour).
- * Add test for coordinates order assumptions.
-2013-06-12 14:06 Mateusz Loskot <mateusz at loskot.net>
- * [r3822] Update single side offset curve tests to check uniform
- coordinates order in output (ticket #633). We need to decide if
- BufferBuilder::bufferLineSingleSided should take care of
- reversing coordinates if necessary.
-2013-06-12 13:22 Mateusz Loskot <mateusz at loskot.net>
- * [r3821] Add updated C++ API test case for the left/right offset
- curve (ticket #633)
-2013-06-12 09:56 Mateusz Loskot <mateusz at loskot.net>
- * [r3820] Add comment missing from previous commit.
-2013-06-12 09:50 Mateusz Loskot <mateusz at loskot.net>
- * [r3819] Add test case for #633 based on GEOSOffsetCurve from
- C-API. Passing negative distance for right-sided offset curve
- generates correct/expected output. Interestingly, equivalent test
- using BufferBuilder directly, from C++ API, does not pass.
-2013-06-11 15:29 Mateusz Loskot <mateusz at loskot.net>
- * [r3818] Revert r3817 as partial or incorrect fix. See ticket #633
- for details.
-2013-06-11 14:19 Mateusz Loskot <mateusz at loskot.net>
- * [r3817] * Fix bug in OffsetCurveBuilder case for right-side
- offset curve used left-side flag to initialise the side segments.
- * Corresponding test case attached.
-2013-06-11 12:42 Sandro Santilli <strk at keybit.net>
- * [r3816] Fix for mingw64 compile, by Regina Obe (#630)
-2013-06-07 09:29 Sandro Santilli <strk at keybit.net>
- * [r3814] Simplify code looking for closer vertex snap
-2013-06-07 09:21 Mateusz Loskot <mateusz at loskot.net>
- * [r3813] Fix incomplete type of Node at the point of destruction
- (by GeometryNoder) leading to never called destructor bug.
-2013-06-07 09:13 Mateusz Loskot <mateusz at loskot.net>
- * [r3812] Correct int and std::size_t mismatch for 64-bit target.
-2013-06-07 09:10 Mateusz Loskot <mateusz at loskot.net>
- * [r3811] * Disable copy constructor and assignment operator.
- * Correct int and std::size_t mismatch for 64-bit target.
-2013-06-07 09:02 Mateusz Loskot <mateusz at loskot.net>
- * [r3810] Disable copy constructor and assignment operator
-2013-06-07 08:30 Mateusz Loskot <mateusz at loskot.net>
- * [r3809] Correct return type of OffsetSegmentString::size() to be
- size_t
-2013-06-06 20:18 Sandro Santilli <strk at keybit.net>
- * [r3808] Drop obsoleted files
-2013-06-06 16:39 Sandro Santilli <strk at keybit.net>
- * [r3807] Drop commented out / disabled code
-2013-06-05 22:18 Mateusz Loskot <mateusz at loskot.net>
- * [r3806] Implement generating geos_svn_revision.h using shell
- script.
-2013-06-05 08:52 Mateusz Loskot <mateusz at loskot.net>
- * [r3805] Make Visual C++ 11.0 recognised by CMake configuration
-2013-06-03 07:36 Sandro Santilli <strk at keybit.net>
- * [r3803] Short-circuit prepared polygon/point intersection
- Reduces memory fragmentation for area-puntal ops
-2013-05-30 20:16 Sandro Santilli <strk at keybit.net>
- * [r3800] Improve snap algorithm reducing likelyhood of invalid
- output
- - Snap input vertices to closest snap point (#629)
- - Do not snap segments to external points (#501)
- - Never snap multiple vertices to the same snap point
- Work funded by Tuscany Region - SITA. Contract "Support to the
- use
- of GFOSS (Geographic Free and Open Source Software) Desktop
- tools"
- (CIG Z3B06FA6D7).
-2013-05-23 17:21 Sandro Santilli <strk at keybit.net>
- * [r3799] Create geos_svn_revision.h in the source tree
- It's a generated source, should always be in the tarball anyway
-2013-05-23 15:51 Sandro Santilli <strk at keybit.net>
- * [r3798] Distribute svn_repo_revision.sh
-2013-05-10 08:40 Mateusz Loskot <mateusz at loskot.net>
- * [r3797] Add NMAKE option WIN64 to simplify x64 build
- configuration
-2013-05-09 10:04 Mateusz Loskot <mateusz at loskot.net>
- * [r3796] Add NMAKE version from Visual Studio 2012 Update 3
-2013-04-02 09:24 Mateusz Loskot <mateusz at loskot.net>
- * [r3795] Add missing directories
-2013-04-02 09:20 Mateusz Loskot <mateusz at loskot.net>
- * [r3794] Add Visual Leak Detector (VLD) support to GEOS core
- * Add MSVC_VLD_DIR option to nmake.opt to enable/disable VLD
- * Add optional #include <vld.h> to Geometry.cpp
-2013-03-15 18:48 Sandro Santilli <strk at keybit.net>
- * [r3793] Fix memory leaks in unit tests
-2013-03-15 18:05 Sandro Santilli <strk at keybit.net>
- * [r3792] Add GEOSNearestPoints CAPI function
- Contributed by Richard Frith-Macdonald
- <richard at tiptree.demon.co.uk>
-2013-03-15 15:36 Mateusz Loskot <mateusz at loskot.net>
- * [r3791] Add x64 NMAKE version from Visual Studio 2012 Update 1
-2013-03-12 16:20 Sandro Santilli <strk at keybit.net>
- * [r3790] Fix "puts puts" typo in ruby macro (#625)
-2013-03-11 11:19 Sandro Santilli <strk at keybit.net>
- * [r3789] Port new RobustLineIntersection test from JTS
-2013-03-08 17:51 Sandro Santilli <strk at keybit.net>
- * [r3787] Fix RobustLineIntersector handling of invalid
- intersection points (#622)
- Adds new testcases. Many of them fail, probably due to the lack
- of
- double double use, but one of them only fails with the old
- RobustLineIntersector heuristic handling invalid intersection
- points
-2013-03-08 17:48 Mateusz Loskot <mateusz at loskot.net>
- * [r3786] Add algorithm/Centroid.obj
-2013-03-08 17:41 Mateusz Loskot <mateusz at loskot.net>
- * [r3785] Untabify
-2013-03-08 17:37 Mateusz Loskot <mateusz at loskot.net>
- * [r3784] Add NMAKE version from Visual Studio 2012 Update 1
-2013-03-08 13:02 Sandro Santilli <strk at keybit.net>
- * [r3781] Fix GEOSPointOnSurface returning point on boundary (#623)
- Ports SafeBisector for InteriorPointArea from JTS
-2013-03-05 14:46 Sandro Santilli <strk at keybit.net>
- * [r3779] Speedup GEOSWKBWriter_read_r (#621)
- Patch by Daniel Zeitlin
-2013-03-01 11:58 Sandro Santilli <strk at keybit.net>
- * [r3778] Add wiki update and announce steps
-2013-02-28 09:40 Sandro Santilli <strk at keybit.net>
- * [r3773] Fix centroid computation for collections with empty
- components
- Fixes bug #582
-2013-02-25 11:41 Sandro Santilli <strk at keybit.net>
- * [r3772] Update macros/ruby.m4 for ruby 1.9.x
- Used RbConfig instead of obsolete and deprecated Config.
- Updated SWIG generated files.
- Patch by Kashif Rasul <kashif.rasul at gmail.com>
-2013-02-25 11:11 Sandro Santilli <strk at keybit.net>
- * [r3771] Fix build under cygwin (#595)
- Thanks Jason Huntley
-2013-02-25 11:04 Sandro Santilli <strk at keybit.net>
- * [r3770] Deprecate WKTReader constructor taking GeometryFactory by
- pointer
- Add constructor taking it by reference, for consistency with
- WKBReader
- Closes #310
-2013-02-25 10:37 Sandro Santilli <strk at keybit.net>
- * [r3769] New ::reserve(size_t) method for io::Writer class
-2013-02-25 10:34 Sandro Santilli <strk at keybit.net>
- * [r3768] io::Writer: take and give strings by const ref, use
- .append, testcase
-2013-02-21 10:29 Sandro Santilli <strk at keybit.net>
- * [r3767] WKTWriter::appendCoordinate optimisation
- Modified the WKTWriter::appendCoordinate method to not create an
- intermediate std::string, but instead write directly into the
- Writer
- object. The result is a small performance improvement.
- Patch by Mats Taraldsvik <mats.taraldsvik at norkart.no>
-2013-02-15 13:46 Mateusz Loskot <mateusz at loskot.net>
- * [r3765] Update svn:ignore property
-2013-02-01 06:31 Sandro Santilli <strk at keybit.net>
- * [r3762] Add header guard to CLocalizer (#619)
-2013-02-01 06:28 Sandro Santilli <strk at keybit.net>
- * [r3760] Fix header guard and port info in LocatioNIndexOfLine
- (#618)
-2013-02-01 06:25 Sandro Santilli <strk at keybit.net>
- * [r3758] Fix header guard in GeometryExtracter (#617)
-2013-01-25 17:19 Sandro Santilli <strk at keybit.net>
- * [r3755] IsValidOp: throw proper error on nested shells (#608)
- Thanks geomworx
-2013-01-17 12:07 Sandro Santilli <strk at keybit.net>
- * [r3751] Only attempt to fix self-intersection between multiple
- components
- Doing this reduces the likelyhood of entering an infinite
- recursion
- whereas UnaryUnion (meant to fix that) would enter the
- self-intersection
- attempt again. Fixes #615 for which a test is added.
- This also gives us back an exception with the input of ticket
- #488,
- which is the same behavior JTS exposes. The (bogus) test for it
- is disabled by this commit.
-2013-01-14 16:15 Sandro Santilli <strk at keybit.net>
- * [r3749] Fix EMPTY return from single-point lines and zero-length
- polygons
- This commit ports new Centroid class from JTS (#612)
-2013-01-14 11:16 Sandro Santilli <strk at keybit.net>
- * [r3748] Fix EMPTY return from zero-area polygon (#613)
-2013-01-14 11:12 Sandro Santilli <strk at keybit.net>
- * [r3747] Have XMLTester use POINT EMPTY for a null return from
- getInteriorPoint
-2013-01-14 09:50 Sandro Santilli <strk at keybit.net>
- * [r3744] Move static class members of Interrupt out of header
- (#611)
- Patch by Mateusz Loskot
-2013-01-11 17:15 Mateusz Loskot <mateusz at loskot.net>
- * [r3743] Missing QuadEdge.h causing incomplete types.
-2013-01-11 17:11 Mateusz Loskot <mateusz at loskot.net>
- * [r3742] Report general and custom flags separately
-2013-01-11 14:58 Sandro Santilli <strk at keybit.net>
- * [r3741] Fix GEOSPointOnSurface with zero-length linestring (#609)
-2013-01-11 14:35 Mateusz Loskot <mateusz at loskot.net>
- * [r3740] Added test<7>() for the poorly reported bug ticket #610 -
- bug not reproducible.
-2012-12-06 08:23 Sandro Santilli <strk at keybit.net>
- * [r3737] See if AC_CONFIG_HEADERS makes winnie happier
- ... and also how many other builds it breaks, if any
-2012-12-06 08:04 Sandro Santilli <strk at keybit.net>
- * [r3736] Add missing classes to build script for evil compiler
- Curtesy of Geoff Evans
-2012-12-05 09:06 Sandro Santilli <strk at keybit.net>
- * [r3734] Add note about rounding in fixed precision buffer op
- (#605)
-2012-12-05 07:56 Sandro Santilli <strk at keybit.net>
- * [r3733] Do not reduce precision below 6 significant digits.
- Avoids gross results (preferring an exception)
- See http://trac.osgeo.org/geos/ticket/605
-2012-12-04 21:50 Sandro Santilli <strk at keybit.net>
- * [r3731] Add note about BufferOp robustness improvement
-2012-12-04 21:22 Sandro Santilli <strk at keybit.net>
- * [r3728] Reduce coordinates precision on robustness issues in
- BufferOp
- Fixes #605, adds test for it
-2012-12-04 19:26 Sandro Santilli <strk at keybit.net>
- * [r3727] Fix an abort in Buffer op (RightmostEdgeFinder)
- Rather than abort we throw a TopologyException, because the
- problem
- seems to occur when noding isn't correct.
-2012-12-04 17:23 Sandro Santilli <strk at keybit.net>
- * [r3726] Add unit test for OrientedCoordinateArray
-2012-11-15 15:55 Sandro Santilli <strk at keybit.net>
- * [r3720] Add automated test for #599 (succeeds)
-2012-10-26 14:01 Sandro Santilli <strk at keybit.net>
- * [r3719] Fix building outside the source tree
-2012-09-10 10:34 Sandro Santilli <strk at keybit.net>
- * [r3716] Add Z support in delaunay triangulation (#570)
- Thanks Benjamin Campbell
-2012-09-10 09:23 Sandro Santilli <strk at keybit.net>
- * [r3715] Tweak the test for bug 586 to succeed while still being
- small
-2012-09-10 08:00 Sandro Santilli <strk at keybit.net>
- * [r3712] Add test for bug #586
-2012-09-10 07:56 Sandro Santilli <strk at keybit.net>
- * [r3711] Do not try to fix valid geometries (#586)
-2012-09-07 12:01 Sandro Santilli <strk at keybit.net>
- * [r3710] Regenerate swig files with swig 2.0.4
-2012-09-06 18:22 Sandro Santilli <strk at keybit.net>
- * [r3708] Add support for phpunit 3.6 (not loosing support for 3.4)
- I don't have phpunit-3.4 anymore so if anyone does please see
- if "make check" still works (with php enabled)
- NOTE: Ubuntu 10.04 ships phpunit 3.4
-2012-07-27 08:09 Mateusz Loskot <mateusz at loskot.net>
- * [r3705] Updated NMAKE makefile with recently added source files
- (Ticket #574)
-2012-07-26 22:43 Sandro Santilli <strk at keybit.net>
- * [r3704] Don't live triangulate includes out of build (#573)
- Thanks Sandro Furieri
-2012-06-27 10:53 Sandro Santilli <strk at keybit.net>
- * [r3703] Add test for Delaunay triangulation with a tolerance
-2012-06-27 10:43 Sandro Santilli <strk at keybit.net>
- * [r3702] Expose Delaunay triangulation to C-API (#565)
- * [r3701] Const-correct getTriangles / getEdges and move to proper
- namespace
- * [r3700] indent
-2012-06-27 09:23 Sandro Santilli <strk at keybit.net>
- * [r3699] Indent and port info style
-2012-06-26 20:41 Mateusz Loskot <mateusz at loskot.net>
- * [r3697] [CMake] Corrected description of default value for
- GEOS_ENABLE_MACOSX_FRAMEWORK option
-2012-06-26 20:34 Mateusz Loskot <mateusz at loskot.net>
- * [r3696] Updated NEWS file with changes related to ticket #446
-2012-06-26 20:29 Mateusz Loskot <mateusz at loskot.net>
- * [r3695] Updated svn:ignore for tests/perf
-2012-06-26 17:17 Sandro Santilli <strk at keybit.net>
- * [r3694] typo
-2012-06-26 17:11 Sandro Santilli <strk at keybit.net>
- * [r3693] Port Delaunay Triangulation API from JTS (#487)
- Work contributed by Benjamin Campbell
-2012-06-25 23:31 Mateusz Loskot <mateusz at loskot.net>
- * [r3692] [CMake] Fixed incorrect SOVERSION value. The SOVERSION is
- now set with CAPI_VERSION_CURRENT - CAPI_VERSION_AGE (Ticket
- #446)
-2012-06-25 15:17 Sandro Santilli <strk at keybit.net>
- * [r3691] Add tarball verification step
-2012-06-25 10:19 Sandro Santilli <strk at keybit.net>
- * [r3684] Always return POINT from GEOSPointOnSurface, even for
- EMPTY (#561)
-2012-06-24 22:22 Mateusz Loskot <mateusz at loskot.net>
- * [r3683] [CMake] Set SOVERSION property on C API shared library
- using CAPI_INTERFACE_* values (Ticket #446).
-2012-06-22 15:44 Sandro Santilli <strk at keybit.net>
- * [r3680] Add note about handling of degenerate polygons
-2012-06-22 15:32 Sandro Santilli <strk at keybit.net>
- * [r3679] Always return POINT from GEOSGetCentroid, even for EMPTY
- (#560)
-2012-06-22 15:03 Sandro Santilli <strk at keybit.net>
- * [r3677] Port robustness fix to CentroidArea (#559)
-2012-06-11 09:18 Sandro Santilli <strk at keybit.net>
- * [r3673] Retain GEOS_INLINE define while building XMLTester (#319,
- #472)
-2012-06-07 15:11 Sandro Santilli <strk at keybit.net>
- * [r3672] Allow chaining interrupt callbacks, drop arg parameter
-2012-06-07 15:10 Sandro Santilli <strk at keybit.net>
- * [r3671] Revert the interrupt request callback reset on initGEOS
- Once you set a callback why would you want it unregistered on
- initGEOS ? You will not want that....
-2012-06-07 14:41 Sandro Santilli <strk at keybit.net>
- * [r3670] Clear interruption request flag just before interrupting
-2012-06-07 10:24 Sandro Santilli <strk at keybit.net>
- * [r3669] Drop orphaned custom allocation signatures from C-API
- header
-2012-06-07 10:23 Sandro Santilli <strk at keybit.net>
- * [r3668] Test that initGEOS clears the interrupt callback
- Also explicitly cleanup the callback after each test.
- * [r3667] Unregister the interrupt request on initGEOS
-2012-06-07 10:07 Sandro Santilli <strk at keybit.net>
- * [r3666] Add support for registering interruption-checking
- callback.
- This is to enhance flexibility of the interruption request model.
-2012-06-06 14:15 Sandro Santilli <strk at keybit.net>
- * [r3665] Enable capi::GEOSConvexHull test, and fix it (#555)
-2012-06-06 07:03 Sandro Santilli <strk at keybit.net>
- * [r3663] Clarify problems with linking against C++ api (#553)
- Path by Greg Troxel.
-2012-05-29 19:23 Sandro Santilli <strk at keybit.net>
- * [r3657] No need to forward declare Coordinate (full definition
- included)
- * [r3656] Do not define an empty destructor for Coordinate
-2012-05-29 16:41 Sandro Santilli <strk at keybit.net>
- * [r3655] Make sure to build geos_svn_config.h
-2012-05-29 10:04 Sandro Santilli <strk at keybit.net>
- * [r3654] Include SVN revision in GEOSversion output
- * [r3653] Fix revision file path
-2012-05-29 09:48 Sandro Santilli <strk at keybit.net>
- * [r3652] Fix test for directory existance
-2012-05-29 09:45 Sandro Santilli <strk at keybit.net>
- * [r3651] Add script to fetch SVN revision from git or SVN
-2012-05-29 08:42 Sandro Santilli <strk at keybit.net>
- * [r3650] Drop embedded RCS logs
-2012-05-28 12:29 Sandro Santilli <strk at keybit.net>
- * [r3649] Install BufferInputLineSimplifier.h header (#548)
- Thanks ylan for the patch
-2012-05-28 07:48 Sandro Santilli <strk at keybit.net>
- * [r3648] Rename interrupt request/cancel methods, cancel interrupt
- in init
-2012-05-25 15:50 Sandro Santilli <strk at keybit.net>
- * [r3647] Revert the whole custom memory allocation work (#540)
- It wasn't well done. Pity.
-2012-05-25 15:26 Sandro Santilli <strk at keybit.net>
- * [r3646] Expose interrupt request cancel to the C-API
-2012-05-25 12:26 Sandro Santilli <strk at keybit.net>
- * [r3645] Add method to cancel an interruption request in
- util::Interrupt
-2012-05-25 12:15 Sandro Santilli <strk at keybit.net>
- * [r3644] Add strategic check for interrupt in MCIndexNoder loop
- Greatly increases interruptability of buffer operations in
- presence of many polygons.
-2012-05-25 10:54 Sandro Santilli <strk at keybit.net>
- * [r3643] Check for interruption in OverlayOp and BufferBuilder
- These are just two operations known to take a lot of time.
- It'll take a better analisys to find appropriate check point.
- The checks could as well be put within graph operation loops or
- Coordinate constructors...
- * [r3642] Initial support for an explicit mechanism to request
- interruption
- This commit provides a GEOS_CHECK_FOR_INTERRUPTS macro for
- internal
- use but adds no users.
- Early tests shows that registering a SIGINT handler is an
- effective
- way to request interruption of running GEOS operations.
-2012-05-24 06:00 Sandro Santilli <strk at keybit.net>
- * [r3641] Don't call GeometryFactory::getDefaultInstance() at
- startup (#540)
-2012-05-24 00:23 Mateusz Loskot <mateusz at loskot.net>
- * [r3640] Replaced static members/references to global boundary
- rule objects with static methods providing access to those
- objects. The previous implementation was troublesome for exports
- from Windows DLL. From POV, it is just syntactical change.
- Semantically nothing has changed.
-2012-05-24 00:21 Mateusz Loskot <mateusz at loskot.net>
- * [r3639] [CMake] Link GEOS C-API library against geos.dll instead
- of static geos.lib to avoid breaking ODR for allocators.
-2012-05-23 23:53 Mateusz Loskot <mateusz at loskot.net>
- * [r3638] Added missing GEOS_DLL directive to GeometryNoder and
- custom allocators.
-2012-05-23 23:34 Mateusz Loskot <mateusz at loskot.net>
- * [r3637] Updated svn:ignore patterns
-2012-05-23 23:03 Mateusz Loskot <mateusz at loskot.net>
- * [r3636] Renamed Freer to Deallocator
-2012-05-23 22:57 Mateusz Loskot <mateusz at loskot.net>
- * [r3635] Missing namespace prevented Visual C++ compiler to find
- GEOSAllocator and GEOSFreer
-2012-05-16 16:47 Sandro Santilli <strk at keybit.net>
- * [r3633] Fix CustomAllocators to really use the custom allocators
- Improve the unit test for it
-2012-05-16 12:20 Sandro Santilli <strk at keybit.net>
- * [r3632] Lazily create default GeometryFactory instance (#540)
- Seems to fix a problem with mismatch of allocator and deallocator
- for the static object
- * [r3631] Allow passing custom memory managment functions (#540)
- This is both in the C++ library _and_ the C library.
-2012-05-16 10:29 Mateusz Loskot <mateusz at loskot.net>
- * [r3630] New test for C-API convex hull func.
-2012-05-14 19:03 Sandro Santilli <strk at keybit.net>
- * [r3629] Reduce calls to ptNotInList, greatly speeding up
- Polygonizer (#545)
-2012-05-09 18:02 Sandro Santilli <strk at keybit.net>
- * [r3627] Fix TopologyPreservingSimplifier invalid output on closed
- line (#508)
-2012-05-09 16:28 Sandro Santilli <strk at keybit.net>
- * [r3625] Add support for PHP 5.4 (#513) -- thanks voxik
-2012-05-08 18:41 Sandro Santilli <strk at keybit.net>
- * [r3623] Envelope-based short-circuit for Geometry->symDifference
- (#543)
-2012-05-08 17:39 Sandro Santilli <strk at keybit.net>
- * [r3621] Geometry methods do use BinaryOp internally + shortcuts
- (#542)
- This commit changes both XMLTester and C-API to not use BinaryOp
- directly but rather rely on geometry methods to do that.
-2012-05-04 14:51 Sandro Santilli <strk at keybit.net>
- * [r3619] Correct include directives for GeometryNoder (#538)
-2012-05-04 08:24 Sandro Santilli <strk at keybit.net>
- * [r3618] Update PGAC_TYPE_64BIT_INT for better cross-compiler
- support (#534)
-2012-05-03 10:08 Sandro Santilli <strk at keybit.net>
- * [r3616] Check size of "intt64"
-2012-04-27 07:01 Sandro Santilli <strk at keybit.net>
- * [r3615] Expose GEOSNode to PHP api
-2012-04-12 09:07 Sandro Santilli <strk at keybit.net>
- * [r3614] Throw an exception rather than aborting on NaN overlay
- input (#530)
-2012-04-10 17:01 Sandro Santilli <strk at keybit.net>
- * [r3612] Abort if HotPixel is constructed with zero scale (#529)
-2012-04-10 15:58 Sandro Santilli <strk at keybit.net>
- * [r3611] Add test for bug #527
-2012-04-10 15:16 Sandro Santilli <strk at keybit.net>
- * [r3609] Have UnaryUnion use BinaryOp for the simple case
- See ticket #527 -- there's no infinite loop triggered by our
- testsuite...
-2012-04-10 15:04 Sandro Santilli <strk at keybit.net>
- * [r3607] Reduce CommonBitsRemover harmful effects during overlay
- op (#527)
-2012-04-10 08:38 Sandro Santilli <strk at keybit.net>
- * [r3605] Port GeometryPrecisionReducer, include testcase
-2012-04-06 19:04 Sandro Santilli <strk at keybit.net>
- * [r3604] Deep copy Geometry with GeometryFactory.createGeometry()
- Uses the CoordinateSequenceFactory of the factory
-2012-04-06 19:03 Sandro Santilli <strk at keybit.net>
- * [r3603] Add CoordinateSequence deep copy trhough
- CoordinateSequenceFactory
-2012-04-05 17:07 Sandro Santilli <strk at keybit.net>
- * [r3602] Normalize noded geometry before comparing with expected
- value
- In this way we can change the noding implementation w/out
- breaking the tests.
-2012-04-05 16:56 Sandro Santilli <strk at keybit.net>
- * [r3601] Regnerate geos wrapper with correct version for this
- branch
-2012-04-05 16:47 Sandro Santilli <strk at keybit.net>
- * [r3599] Regenerate swig wrappers with SWIG 1.3.40
-2012-04-05 14:53 Sandro Santilli <strk at keybit.net>
- * [r3598] Fix SimpleSnapRounder::getNodedSubstrings, fix leak on
- exception
-2012-04-05 14:37 Sandro Santilli <strk at keybit.net>
- * [r3597] Clean memory on exception
-2012-04-05 14:23 Sandro Santilli <strk at keybit.net>
- * [r3596] Generalize NodedSegmentString::getNodedSubstrings
-2012-04-05 14:14 Sandro Santilli <strk at keybit.net>
- * [r3595] Ensure GEOSNode doesn't throw an exception with current
- tests
-2012-04-05 13:43 Sandro Santilli <strk at keybit.net>
- * [r3594] Add note about GEOSNode
-2012-04-05 13:40 Sandro Santilli <strk at keybit.net>
- * [r3593] Add GEOSNode C-API interface (#496)
- Includes a new GeometryNoder C++ class and regression testing.
-2012-04-05 12:05 Sandro Santilli <strk at keybit.net>
- * [r3592] Fix memory leak with IteratedNoder
-2012-04-05 11:07 Sandro Santilli <strk at keybit.net>
- * [r3591] Update port info and cleanup IteratedNoder
-2012-04-05 10:30 Sandro Santilli <strk at keybit.net>
- * [r3590] Make OrientedCoordinateArray comparable
- * [r3589] Make OrientedCoordinateArray assignable
-2012-04-03 14:23 Sandro Santilli <strk at keybit.net>
- * [r3588] Make OrientedCoordinateArray copyable
-2012-04-03 12:59 Sandro Santilli <strk at keybit.net>
- * [r3587] Const-correct PrecisionModel use in MCIndexSnapRounder
-2012-04-01 20:50 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r3585] Update howto release
-2012-04-01 20:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r3583] Sync up versions advertised in capi to those in
- configure.in
-2012-03-27 08:37 Sandro Santilli <strk at keybit.net>
- * [r3576] Indent..
-2012-03-22 08:39 Sandro Santilli <strk at keybit.net>
- * [r3575] Fix simplification of collections with empty items (#519)
-2012-02-20 21:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r3573] Synch patch level version with autoconf number
-2012-02-16 18:19 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r3568] Update provenance for Olivier Devillers.
-2012-01-16 20:36 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r3567] More info on provenance.
-2012-01-16 20:15 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r3566] Update provenenance
-2012-01-16 18:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r3565] Complete Note#1 in the
- http://wiki.osgeo.org/wiki/GEOS_Provenance_Review to get out of
- incubation.
-2012-01-07 21:09 Mateusz Loskot <mateusz at loskot.net>
- * [r3563] Fixed (hopefully) CMake issues with std:: namespace
- detection (Ticket #493)
-2012-01-07 21:08 Mateusz Loskot <mateusz at loskot.net>
- * [r3562] Missing <cctype> header for toupper. Fixed Visual C++
- warning.
-2012-01-06 21:53 Sandro Santilli <strk at keybit.net>
- * [r3561] Forward port: Fix MSVC compilation of ambiguous log()
- call #506
-2011-12-16 14:15 Sandro Santilli <strk at keybit.net>
- * [r3555] Make debugging output of LineStringSnapper more readable
-2011-12-15 14:36 Sandro Santilli <strk at keybit.net>
- * [r3553] Check validity after snapping in BinaryOp. Fixes bug #488
- Adds regression test. This is a GEOS-only approach.
-2011-12-15 11:34 Sandro Santilli <strk at keybit.net>
- * [r3550] indent
-2011-12-15 08:59 Sandro Santilli <strk at keybit.net>
- * [r3548] Fix build with CBR_BEFORE_SNAPPING undefined
-2011-12-12 15:09 Howard Butler <hobu.inc at gmail.com>
- * [r3546] apply patch for #500 to fix clang's complaint about a
- missing default initialization
-2011-12-12 10:10 Sandro Santilli <strk at keybit.net>
- * [r3544] Apply Shoelace formula for area calculation (#485)
-2011-12-12 09:59 Sandro Santilli <strk at keybit.net>
- * [r3542] Add --clibs to geos-config and GEOS_C_LIBS to geos.m4
- (#497)
-2011-12-09 10:54 Sandro Santilli <strk at keybit.net>
- * [r3540] Fix C++11 build by avoiding std::pair<auto_ptr> (#491)
-2011-12-09 10:04 Sandro Santilli <strk at keybit.net>
- * [r3536] Ignore built performance tests
- * [r3535] Improve buffer robustness by reverting to non
- snaprounding noder
- This commit fixes all cases reported in
- http://trac.osgeo.org/geos/wiki/BufferRobustness
- They include #495 and #494
-2011-12-09 08:48 Sandro Santilli <strk at keybit.net>
- * [r3534] Fix CascadedPolygonUnion to discard non-polygonal
- components created during unioning
- This is to avoid failures and provide more desirable behaviour.
- Includes automated testing. Closes ticket #499.
-2011-12-07 15:13 Sandro Santilli <strk at keybit.net>
- * [r3530] Update port info for MCIndexPointSnapper and
- MCIndexSnapRounder
-2011-12-07 11:17 Sandro Santilli <strk at keybit.net>
- * [r3529] Add a simple test for MCIndexSnapRounderTest
- The test would fail before the fix in r3528
-2011-12-06 17:26 Sandro Santilli <strk at keybit.net>
- * [r3528] HotPixel: do not invalidate reference to original point.
- Fixes #498.
-2011-12-02 09:42 Sandro Santilli <strk at keybit.net>
- * [r3525] Add <resultMatcher> tag to make the test runnable with
- JTS
-2011-11-30 09:45 Sandro Santilli <strk at keybit.net>
- * [r3523] Fix MCIndexSnapRounder use of provided precision model.
- Fixes bug #473 (RightmostEdgeFinder assertion failure).
- Includes regression test.
-2011-11-29 14:01 Sandro Santilli <strk at keybit.net>
- * [r3522] Use 18 significant digits for TopologyException point
- coordinates
-2011-11-28 08:53 Sandro Santilli <strk at keybit.net>
- * [r3520] BufferBuilder: fix handling of collapsed edges skipping.
- Fixes #494.
- Includes regression test, provided by SAFE.
-2011-11-24 22:07 Sandro Santilli <strk at keybit.net>
- * [r3518] Fix to get swig/ruby compiling for ruby 1.9
-2011-11-06 03:25 Mateusz Loskot <mateusz at loskot.net>
- * [r3517] * GEOS builds with Visual C++ from Visual Studio
- 11(Developer Preview).
- * Added related _NMAKE_VER case to nmake.opt.
-2011-11-04 20:41 Sandro Santilli <strk at keybit.net>
- * [r3515] Allow any case in NaN for testcase purposes (#486)
-2011-11-04 17:59 Sandro Santilli <strk at keybit.net>
- * [r3514] Fix noding of self-intersecting lines through UnaryUnion
- (#482)
- Includes updated tests from JTS
-2011-10-28 23:13 Mateusz Loskot <mateusz at loskot.net>
- * [r3511] Updated svn:ignore property
-2011-10-27 07:04 Sandro Santilli <strk at keybit.net>
- * [r3510] Add JTS triangulation api item
-2011-10-26 16:49 Mateusz Loskot <mateusz at loskot.net>
- * [r3509] * Test of two ways of executing buffer operation.
- * Test problems with BufferOp when using BufferParameters
- reported by Markus Meyer.
- * TODO: if possible, replace sample WKT with WKT from Markus.
-2011-10-26 16:14 Sandro Santilli <strk at keybit.net>
- * [r3508] Add test for BufferParameters class
-2011-10-26 14:16 Sandro Santilli <strk at keybit.net>
- * [r3505] Add missing entries in the author file. Order
- alphabetically.
- * [r3504] Add missing CAPI additions of 3.3.0 to NEWS file
-2011-10-19 00:45 Mateusz Loskot <mateusz at loskot.net>
- * [r3502] Fixed CMAKE_CXX_FLAGS overridind -std=gnu++0x (#489)
-2011-10-18 22:12 Mateusz Loskot <mateusz at loskot.net>
- * [r3501] Missing 3.4.0 versions update in CMake configuration
-2011-10-05 23:24 Mateusz Loskot <mateusz at loskot.net>
- * [r3499] Removed redundant casts between integer types
-2011-10-05 00:09 Howard Butler <hobu.inc at gmail.com>
- * [r3498] declare these functions static inline to silence
- unused-function warning
-2011-10-04 20:46 Howard Butler <hobu.inc at gmail.com>
- * [r3497] remove extra ;'s to satisfy pedantic warning
-2011-10-04 15:48 Howard Butler <hobu.inc at gmail.com>
- * [r3495] turn off framework building by default on APPLE
-2011-10-04 15:43 Howard Butler <hobu.inc at gmail.com>
- * [r3494] propsets to svn:ignore CMake build junk
-2011-10-04 15:42 Howard Butler <hobu.inc at gmail.com>
- * [r3493] fix up non-framework CMake builds on APPLE
-2011-10-04 15:32 Howard Butler <hobu.inc at gmail.com>
- * [r3492] fix up order initialization
-2011-09-28 17:23 Mateusz Loskot <mateusz at loskot.net>
- * [r3491] * Added interesting test<11> case to Douglas-Peucker unit
- * Visual C++ build on Windows x86-32 is all green and happy
- throwing ok:737
-2011-09-23 12:14 Sandro Santilli <strk at keybit.net>
- * [r3484] Fixed handling of Linear Referencing over
- MultiLineStrings to always return lowest index, and to trim
- zero-length result components (#323)
- Includes test. This is a port of JTS changesets 463, 464 and 465
- * [r3483] Port updates to the LenghtIndexedLineTest testcase (see
- #323)
- Note that the test fails if the library isn't also fixed
-2011-09-23 01:03 Mateusz Loskot <mateusz at loskot.net>
- * [r3482] Removed Subversion Id keyword from all text files (#480)
-2011-09-23 00:16 Mateusz Loskot <mateusz at loskot.net>
- * [r3481] Removed Subversion svn:keywords property (#480)
-2011-09-21 08:11 Sandro Santilli <strk at keybit.net>
- * [r3475] Fix out-of-place build for python binding (#332)
-2011-09-20 14:35 Howard Butler <hobu.inc at gmail.com>
- * [r3472] mark concrete implementations as non-virtual for
- GeometryCollection::computeEnvelopInternal and
- GeometryCollection::compareToSameClass #478
-2011-09-20 14:24 Howard Butler <hobu.inc at gmail.com>
- * [r3470] apply clang fix for #463
-2011-09-19 15:07 Mateusz Loskot <mateusz at loskot.net>
- * [r3469] Disable unit test relying on C99 feature if GEOS built
- using Visual C++
-2011-09-17 15:53 Sandro Santilli <strk at keybit.net>
- * [r3468] Use the global isnan from math.h for Solaris (#461)
-2011-09-12 07:47 Sandro Santilli <strk at keybit.net>
- * [r3465] Fix memory leak on invalid geometry in InteriorPointArea
- (#475)
-2011-08-24 14:55 Sandro Santilli <strk at keybit.net>
- * [r3463] Fix warnings on MSVC 2008 64 Bit (#470)
-2011-08-20 21:02 Sandro Santilli <strk at keybit.net>
- * [r3461] Forward port fix for #464 (Geometry.clone SRID copy)
-2011-08-19 09:42 Sandro Santilli <strk at keybit.net>
- * [r3458] Fix missing return from DirectedEdge output operator
-2011-08-19 09:41 Sandro Santilli <strk at keybit.net>
- * [r3457] Fix out-of-source builds
-2011-08-06 09:10 Sandro Santilli <strk at keybit.net>
- * [r3456] Drop dangling references to SegmentString.inl (ticket
- #467)
-2011-07-27 13:55 Sandro Santilli <strk at keybit.net>
- * [r3455] Add test file printing sizes of some classes
-2011-07-27 13:29 Sandro Santilli <strk at keybit.net>
- * [r3454] Earlier release of input segment strings, earlier release
- of buffer subgraphs.
-2011-07-27 08:12 Sandro Santilli <strk at keybit.net>
- * [r3453] Change Noder interface to transfer ownership of noded
- segment strings to caller. Delete them as soon as converted to
- Edges in BufferOp.
-2011-07-26 16:36 Sandro Santilli <strk at keybit.net>
- * [r3452] Update class documentation and port info. Drop empty .inl
- file.
-2011-07-26 16:23 Sandro Santilli <strk at keybit.net>
- * [r3451] Have NodedSegmentString take ownership of
-2011-07-26 15:09 Sandro Santilli <strk at keybit.net>
- * [r3450] Use geomgraph::Label by value (less extra-heap), cleanups
- and port sync.
-2011-07-21 09:54 Sandro Santilli <strk at keybit.net>
- * [r3449] Make geomgraph::Label non virtual, implement assignment
- operator, drop old logs, sync port info.
- * [r3448] Add assignment operator to TopologyLocation, drop old
- logs, sync port info
-2011-07-20 15:40 Sandro Santilli <strk at keybit.net>
- * [r3444] Port JTS robustness fix for ConvexHull (ticket #457)
-2011-07-20 14:32 Sandro Santilli <strk at keybit.net>
- * [r3443] Allow XML tests not to specify a precision model,
- defaulting to floating
- This allows running some JTS tests w/out touching them
-2011-07-20 14:19 Sandro Santilli <strk at keybit.net>
- * [r3442] Add unit test for bug #337.
-2011-07-20 14:04 Sandro Santilli <strk at keybit.net>
- * [r3441] Reset CXXFLAGS for building XMLTester, should fix bug
- #319 (non-c++98 tinyxml)
-2011-07-20 11:45 Sandro Santilli <strk at keybit.net>
- * [r3439] Have GEOSOffsetCurve with distance 0 return the input
- (fixes bug #454)
-2011-07-20 09:12 Sandro Santilli <strk at keybit.net>
- * [r3438] Add note about new BufferOp interface
-2011-07-20 09:03 Sandro Santilli <strk at keybit.net>
- * [r3437] Add setSingleSided interface to BufferOp-accessible
- BufferParam setters
- Patch by Tai Meng <tai.meng at safe.com>
-2011-07-20 08:46 Sandro Santilli <strk at keybit.net>
- * [r3436] Add output operator for planargraph::DirectedEdge class
- * [r3435] Drop unused variable
- * [r3434] Add port info
- * [r3433] Port JTS unit test for Polygonizer class (very light..)
-2011-07-07 08:33 Sandro Santilli <strk at keybit.net>
- * [r3432] Include platform.h, fixing SOLARIS build. Patch by Tai
- Meng <tai.meng at safe.com>.
-2011-07-06 07:02 Sandro Santilli <strk at keybit.net>
- * [r3429] Nodes always have labels (ported JTS fix to
- GeometryGraph::insertBoundaryPoint). Update port info.
- * [r3428] Update port info for geomgraph::Node after GEOS fix was
- ported to JTS
-2011-07-05 13:59 Sandro Santilli <strk at keybit.net>
- * [r3427] svn update before running svn2cl
-2011-07-05 11:07 Sandro Santilli <strk at keybit.net>
- * [r3425] Update port info for IndexedNestedRingTester class
-2011-07-05 10:58 Sandro Santilli <strk at keybit.net>
- * [r3424] Changes of 3.3.1 do not belong in trunk (aimed at 3.4.0)
-2011-07-05 10:56 Sandro Santilli <strk at keybit.net>
- * [r3423] Fix #449 (Assertion fails checking validity of polygon)
- the JTS way.
- * [r3422] Revert "When checking for validity, do not abort if every
- vertex of an hole is also a vertex of another one. Fixes bug
- #449, including regress testing." (will redo the JTS way)
- This reverts commit 7d2306c8dca2f0f1c5722640758578c1d59c7295.
-2011-07-05 09:52 Sandro Santilli <strk at keybit.net>
- * [r3417] Initialize MinimumDiamiter::minPtIndex in the
- constructor, to make static analisys tools happier
- * [r3416] Initialize SweepLineIndex::indexBuilt in ctor
- * [r3415] Initialize LineIntersector::isProperVar in constructor
- (not really needed but makes less noise under static analisys
- tools)
- * [r3414] Fix bogus override of PreparedGeometry::intersect by
- PreparedPoint
- * [r3413] Assert that the variable used as array index is not
- negative before using it (quadtree)
- * [r3412] Avoid segfalting when an added node has no label in
- GeometryGraph::insertBoundaryPoint. See
- https://sourceforge.net/tracker/?func=detail&aid=3353879&group_id=128875&atid=713120
- * [r3411] Avoid segfaulting when Node.setLabelBoundary is called
- against a node with null label. See
- https://sourceforge.net/tracker/?func=detail&aid=3353871&group_id=128875&atid=713120
- * [r3410] Assert that the variable used as array index is not
- negative before using it.
-2011-07-05 09:51 Sandro Santilli <strk at keybit.net>
- * [r3409] Do not dereference past-the-end iterator on invalid call
-2011-07-01 08:22 Sandro Santilli <strk at keybit.net>
- * [r3398] Add test for ticket #455 (bad result from the deprecated
- GEOSSingleSidedBuffer). It passes here in trunk, good!
- * [r3397] NEWS item about #449
-2011-06-27 11:45 Sandro Santilli <strk at keybit.net>
- * [r3394] Bump versions up assuming a new minor release will come
- out from trunk. Closes #453
-2011-06-09 15:28 Sandro Santilli <strk at keybit.net>
- * [r3392] When checking for validity, do not abort if every vertex
- of an hole is also a vertex of another one. Fixes bug #449,
- including regress testing.
-2011-06-02 20:18 Sandro Santilli <strk at keybit.net>
- * [r3390] Refine test for #448
-2011-06-02 20:13 Sandro Santilli <strk at keybit.net>
- * [r3389] Add test for bug #448
-2011-05-30 12:50 Sandro Santilli <strk at keybit.net>
- * [r3387] Update for release
-2011-05-30 12:48 Sandro Santilli <strk at keybit.net>
- * [r3386] Set version to 3.3.0 (final) - Set release date to
- 2011-05-30
-2011-05-30 10:49 Mateusz Loskot <mateusz at loskot.net>
- * [r3385] Applied William\'s patch capi_CMakeLists.txt.patch for
- OSX framework (Ticket #385)
-2011-05-30 10:45 Mateusz Loskot <mateusz at loskot.net>
- * [r3384] Applied William\'s patch * src_CMakeLists.txt.patch
- Download added OSX framework (Ticket #385)
-2011-05-30 10:30 Mateusz Loskot <mateusz at loskot.net>
- * [r3383] Applied William\'s patch with missing library versions
- for OSX framework (Ticket #385)
-2011-05-30 09:41 Mateusz Loskot <mateusz at loskot.net>
- * [r3382] Applied supplementary tests.patch for 85 from William
-2011-05-27 14:04 Sandro Santilli <strk at keybit.net>
- * [r3381] The mac framework info.plist.in from r3376 didn't make it
- into the rc2 tarball.
-2011-05-23 10:04 Sandro Santilli <strk at keybit.net>
- * [r3378] updated for 3.3.0rc2 release
-2011-05-23 09:58 Sandro Santilli <strk at keybit.net>
- * [r3377] Set version to 3.3.0rc2
-2011-05-23 08:52 Mateusz Loskot <mateusz at loskot.net>
- * [r3376] Added src/info.plist.in file for OS X framework build
- option in CMake configuration (Ticket #385)
-2011-05-22 23:34 Mateusz Loskot <mateusz at loskot.net>
- * [r3375] Added OS X framework build option to CMake configuration
- (Ticket #385)
-2011-05-20 08:02 Sandro Santilli <strk at keybit.net>
- * [r3374] add missing return from main
-2011-05-19 20:39 Frank Warmerdam <warmerdam at pobox.com>
- * [r3373] shellCount checking should not be DEBUG only now that we
- throw an exception (#398)
-2011-05-19 19:32 Frank Warmerdam <warmerdam at pobox.com>
- * [r3372] Updates for Makefile.vc builds and issues when building
- NDEBUG and no inlining
-2011-05-19 14:58 Sandro Santilli <strk at keybit.net>
- * [r3371] Fix build of prepared geoms memleak tester on system
- w/out geos installed
-2011-05-18 19:59 Sandro Santilli <strk at keybit.net>
- * [r3370] Do not assume isfinite is in std:: namespace to fix #444;
- Have RobustDeterminant use a broad 'using namespace std' to fix
- #442 in another way.
-2011-05-17 20:44 Sandro Santilli <strk at keybit.net>
- * [r3369] Distribute cmake build scripts. Fixes bug #441.
-2011-05-17 17:04 Sandro Santilli <strk at keybit.net>
- * [r3368] Remove inlines machinery from MCIndexSnapRounder.
- Possibly fixes ticket #222.
-2011-05-17 16:50 Sandro Santilli <strk at keybit.net>
- * [r3367] Remove disabled code and old logs. No functional change.
-2011-05-16 14:17 Mateusz Loskot <mateusz at loskot.net>
- * [r3366] Fixed buggy self-assignment in
- SineStarFactory::setNumArms
-2011-05-16 11:46 Sandro Santilli <strk at keybit.net>
- * [r3365] Quality ::finite and ::isfinite symbols, when available,
- into the std:: namespace. Fixes bug #442.
-2011-05-13 16:22 Mateusz Loskot <mateusz at loskot.net>
- * [r3364] GEOS DLL exports are pretty much messed up. The same DLL
- declspec is used by both C++ and C DLLs. So, GEOS C DLL cannot
- import and link properly against GEOS C++ interface as the
- declspec(dllexport) is specified for the GEOS C++ DLL where
- declspec(dllimport) is expected. This commit fixes the issue
- (temporarily) by linking GEOS C DLL against GEOS C++ static
- library.
-2011-05-13 16:17 Mateusz Loskot <mateusz at loskot.net>
- * [r3363] Added missing DLL decspec for Angle class
-2011-05-13 15:53 Mateusz Loskot <mateusz at loskot.net>
- * [r3362] Removed std::isfinite as possibly non-existing on some
- platforms - rather fix platform.h if needed.
-2011-05-12 10:11 Sandro Santilli <strk at keybit.net>
- * [r3361] Add note about #357 fix
-2011-05-12 09:56 Sandro Santilli <strk at keybit.net>
- * [r3360] Have RobustDeterminant throw an IllegalArgument if passed
- any infinite or nan value. Fixes bug #357. Includes regress test.
-2011-05-12 07:39 Sandro Santilli <strk at keybit.net>
- * [r3359] Add note about the memory usage reduction in prepared
- geoms (#342)
-2011-05-12 07:21 Sandro Santilli <strk at keybit.net>
- * [r3358] Reserve vector space, use ::size_type for vector indices.
-2011-05-12 07:18 Sandro Santilli <strk at keybit.net>
- * [r3357] Don't let MCIndexSegmentSetMutualIntersector grow in
- memory on every new ::process call. Fixes bug #342.
-2011-05-12 07:14 Sandro Santilli <strk at keybit.net>
- * [r3356] Port info for MonotoneChainBuilder
-2011-05-12 06:20 Sandro Santilli <strk at keybit.net>
- * [r3355] Fix a memory leak in
- PreparedLineStringIntersects::isAnyPointInRing
-2011-05-12 06:16 Sandro Santilli <strk at keybit.net>
- * [r3354] Drop commented out code
-2011-05-12 06:13 Sandro Santilli <strk at keybit.net>
- * [r3353] Port info for PreparedLineStringIntersects, and avoid
- polluting the global namespace
-2011-05-12 06:10 Sandro Santilli <strk at keybit.net>
- * [r3352] Reduce heap allocations in
- AbstractPreparedPolygonContains
-2011-05-11 17:59 Sandro Santilli <strk at keybit.net>
- * [r3351] Port info for FastSegmentSetIntersectionFinder
- * [r3350] Port info for MCIndexSegmentSetMutualIntersector
-2011-05-11 17:25 Sandro Santilli <strk at keybit.net>
- * [r3349] Import test for bug #342. It is not automated as it's not
- general (requires bash)
-2011-05-11 10:00 Sandro Santilli <strk at keybit.net>
- * [r3348] Producing a bzip2 tarball is easier than described
-2011-05-11 09:54 Sandro Santilli <strk at keybit.net>
- * [r3346] Updated for 3.0.0rc1 release
-2011-05-11 09:48 Sandro Santilli <strk at keybit.net>
- * [r3345] Add Geometry.offsetCurve to PHP binding
-2011-05-11 09:47 Sandro Santilli <strk at keybit.net>
- * [r3344] Add single-sided buffering support in PHP binding
-2011-05-11 09:15 Sandro Santilli <strk at keybit.net>
- * [r3343] Set version to 3.0.0rc1
-2011-05-10 18:10 Sandro Santilli <strk at keybit.net>
- * [r3342] Have GEOSOffsetCurve return LINESTRING EMPTY for
- collapsing lines (right offset on right-turning curve can do
- that). Regress test one such case, taken from
- http://trac.osgeo.org/postgis/ticket/413.
-2011-05-10 11:11 Sandro Santilli <strk at keybit.net>
- * [r3341] Add test for 357 (doesn't succeed at failing)
-2011-05-10 09:51 Sandro Santilli <strk at keybit.net>
- * [r3340] Revert "Use long double to compute edge distance."
- (r3334). Simple double in HCoordinate made #350 pass anyway.
- * [r3339] Drop STORE_INTERMEDIATE_COMPUTATION_VALUES macro and
- protected non-unrolled computation, that is all paranoia aimed at
- making floats stored to match java IEEE. Since we get no failures
- in testsuite (our and postgis') I think it makes sense to have
- the code as close as possible to the JTS one.
-2011-05-10 09:50 Sandro Santilli <strk at keybit.net>
- * [r3338] Update port info
- * [r3337] Expect the same results given by JTS
- * [r3336] Bring hcoordinate back to double precision (from long
- double)
-2011-05-09 11:57 Sandro Santilli <strk at keybit.net>
- * [r3335] Automate test for bug350, change the expected result to
- match the one obtained by GEOS. It is not _exactly_ the same
- output obtained with JTS but close enough. Unfortunately both
- GEOS and JTS use an exact match for comparison so we won't be
- able to share this test.
- * [r3334] Use long double to compute edge distance. Makes noding
- more robust, fixes bug #350.
-2011-05-06 18:51 Sandro Santilli <strk at keybit.net>
- * [r3333] Turn EdgeIntersection into a concrete, fully-inlined, C++
- class.
- * [r3332] Describe MonotoneChain
- * [r3331] Make output operators for Edge, EdgeIntersection and
- EdgeIntersectionList closer to JTS, for easier comparison
- * [r3330] Output operator for EdgeIntersection and
- * [r3329] Drop book keeping of segment intersectors, as we're
- transferring their ownership to caller anyway
-2011-05-06 08:57 Sandro Santilli <strk at keybit.net>
- * [r3328] Re-add also the original data in test for bug350, so
- nothing gets lost.
- * [r3327] Use logical (not bitwise) AND, use dynamic_cast to map
- JTS's instanceof operator
- * [r3326] Modify test for bug350 so to use pre-snapped geometries.
- Shows that the problem is not in snapping code, but after that
- (ie: JTS succeeds at fist shot on this new input)
-2011-05-04 17:45 Sandro Santilli <strk at keybit.net>
- * [r3325] Fix regression accidentally introduced by commit r3322
- (Sean's). Add automated test for it (was found trough PostGIS
- regression test)
-2011-05-04 16:30 Sandro Santilli <strk at keybit.net>
- * [r3324] Drop useless and unavailable include
-2011-05-03 02:30 Sean Gillies <sgillies at frii.com>
- * [r3323] Damn these tabs
-2011-05-03 02:27 Sean Gillies <sgillies at frii.com>
- * [r3322] Add missing prepared geometry predicates to C API (#436)
-2011-04-28 16:39 Sandro Santilli <strk at keybit.net>
- * [r3321] Improve performance of RectangleIntersects (of one order
- of magnitude).
-2011-04-28 16:38 Sandro Santilli <strk at keybit.net>
- * [r3320] More concise output from performance tester
-2011-04-28 15:09 Sandro Santilli <strk at keybit.net>
- * [r3319] Hush uncontrolled debugging prints
-2011-04-28 15:08 Sandro Santilli <strk at keybit.net>
- * [r3318] Plug leak on exception in RelateComputer (exposed by
- running doc/example)
- * [r3317] Do not leak on exception during relational geometry
- predicates
-2011-04-28 14:16 Sandro Santilli <strk at keybit.net>
- * [r3316] Port RectangleIntersects performance test from JTS-1.12
- * [r3315] Do not leak memory during rectangle intersects predicate
- * [r3314] Drop unneeded include
-2011-04-28 10:04 Sandro Santilli <strk at keybit.net>
- * [r3313] Port geos::geom::util::SineStarFactory from JTS-1.12,
- useful for profile-test RectangleIntersects.
- * [r3312] Trim old embedded history log (from CVS times)
-2011-04-27 16:42 Sandro Santilli <strk at keybit.net>
- * [r3311] Improve speed of Geometry.getArea, unit-test it.
-2011-04-27 15:52 Sandro Santilli <strk at keybit.net>
- * [r3310] Match full class names, not partial. Allow specifying a
- package name.
-2011-04-27 15:47 Sandro Santilli <strk at keybit.net>
- * [r3309] Sync linemerge package to JTS-1.12 (nothing changed)
-2011-04-27 15:33 Sandro Santilli <strk at keybit.net>
- * [r3308] Utility script to help with editing all files of a class
-2011-04-27 15:18 Sandro Santilli <strk at keybit.net>
- * [r3307] Sync Angle class to JTS-1.12, port unit testing for it.
-2011-04-27 14:13 Sandro Santilli <strk at keybit.net>
- * [r3306] Add test for singlesided buffer (areal). Fix premature
- exit from OffsetCurveSetBuilder.
-2011-04-27 13:38 Sandro Santilli <strk at keybit.net>
- * [r3305] Drop one argument from GEOSOffsetCurve. Tell right/left
- from width/distance sign (<0 for right side)
-2011-04-27 13:06 Sandro Santilli <strk at keybit.net>
- * [r3304] Put OffsetCurveTest in its own file (old singleside test
- + a couple more tests)
- * [r3303] Add GEOSBufferParams type and GEOSBufferWithParams
- function to have an extensible buffer operation. Allows areal
- single sided buffer.
-2011-04-27 11:13 Sandro Santilli <strk at keybit.net>
- * [r3302] Add GEOSOffsetCurve C-API interface deprecating
-2011-04-27 09:42 Sandro Santilli <strk at keybit.net>
- * [r3301] Refactored offset curve generation (from JTS-1.12)
- * [r3300] Sync BufferParameters class to JTS r378 (isSingleSided
- property)
- * [r3299] Sync BufferOp class to JTS r378. Do not port the unused
- isSingleSided property.
-2011-04-23 10:30 Sandro Santilli <strk at keybit.net>
- * [r3298] Add note about GEOSCascadedUnion deprecation
-2011-04-23 10:28 Sandro Santilli <strk at keybit.net>
- * [r3297] Mark GEOSUnionCascaded as deprecated, GEOSUnaryUnion does
- the same thing w/out refusin to deal with lines, points,
- collections
-2011-04-23 10:03 Sandro Santilli <strk at keybit.net>
- * [r3296] Generalize CascadedPolygonUnion into a CascadedUnion. Use
- the generalized class for unary union of lines, fixing bug #392.
- Automate testing of it, tweak expected results from other tests
- (output components reordered).
-2011-04-22 22:26 Sandro Santilli <strk at keybit.net>
- * [r3295] Use equals() to compare expected/obtained results of
- "Union" operation. This matches JTS and prevents being too strict
- about equality.
-2011-04-22 18:46 Sandro Santilli <strk at keybit.net>
- * [r3294] Put GeometryListHolder in its own header file.
-2011-04-22 13:51 Sandro Santilli <strk at keybit.net>
- * [r3293] Use stringstream to format strings rather than
- printf-like statements. Simplifies things a lot.
-2011-04-22 13:04 Sandro Santilli <strk at keybit.net>
- * [r3292] Sync PrecisionModel to JTS-1.12, add unit testing, fix
- getMaximumPrecisionDigit to behave as documented (JTS doesn't).
-2011-04-20 17:13 Sandro Santilli <strk at keybit.net>
- * [r3291] Sync OffsetCurveSetBuilder::isErodedCompletely
- implementation to JTS, fixing bug #434
-2011-04-20 15:55 Sandro Santilli <strk at keybit.net>
- * [r3290] Move per-ticket testcases under their own directory
-2011-04-20 15:42 Sandro Santilli <strk at keybit.net>
- * [r3289] Set JTS port version to 1.12
-2011-04-19 07:57 Sandro Santilli <strk at keybit.net>
- * [r3288] Add test for IsCCW against the two almost-collapsed rings
- resulting by GEOS or JTS during execution of the union described
- in ticket #398. This is done after confirmation of same results
- in JTS (1 bit makes the difference between CCW and CW
- orientation).
-2011-04-18 21:45 Sandro Santilli <strk at keybit.net>
- * [r3287] Add the actual ->distance() call to the test for bug #367
-2011-04-18 21:28 Sandro Santilli <strk at keybit.net>
- * [r3286] Throw a TopologyException, rather than aborting, when
- finding more than a shell in MinimalEdgeRing list. Fixes bug
- #398. Enables automated test for it. Note that JTS fails the test
- now, triggering the failed assertion.
- * [r3285] Expect a result with/out the collapsed ring in the test
- for bug 398. Funny enough, this makes JTS react by failing the
- assertion I was tracking...
-2011-04-18 21:01 Sandro Santilli <strk at keybit.net>
- * [r3284] Avoid more heap allocations in PolygonBuilder
-2011-04-18 15:08 Sandro Santilli <strk at keybit.net>
- * [r3283] Reduce heap allocations in PolygonBuilder, rewrite some
- private interfaces to deal with refs rather than pointers
- * [r3282] Use PlanarGraph::linkResultDirectedEdges rather than
- rewriting it inline
- * [r3281] Turn PlanarGraph::linkResultDirectedEdges into a
- templated method
-2011-04-13 11:52 Sandro Santilli <strk at keybit.net>
- * [r3280] Add test for bug #435
-2011-04-13 11:32 Sandro Santilli <strk at keybit.net>
- * [r3279] Fix path to CAPI includes for PHP binding
-2011-04-13 10:44 Sandro Santilli <strk at keybit.net>
- * [r3278] Drop coordinate dimension cache after read-write
- filtering. Fixes ticket #435.
-2011-04-13 08:26 Sandro Santilli <strk at keybit.net>
- * [r3277] Drop author.sh, add a rule to create authors.git instead
-2011-04-13 07:37 Sandro Santilli <strk at keybit.net>
- * [r3276] Add script to be used with git-svn --authors-prog
-2011-03-26 14:02 Sandro Santilli <strk at keybit.net>
- * [r3275] fix missing size_t with gcc 4.6
- * [r3274] fixed missing NULL with gcc 4.6
- * [r3273] fix uninitialized const caused by missing constructor
-2011-03-24 17:54 Mateusz Loskot <mateusz at loskot.net>
- * [r3272] Added source_group properties to support source browsers
- in various IDEs
-2011-03-16 22:29 Sandro Santilli <strk at keybit.net>
- * [r3271] Use GEOSVALID flag correctly, thanks Mat for spotting
- this.
-2011-03-11 14:40 Sandro Santilli <strk at keybit.net>
- * [r3270] Add XML test for bug #350
-2011-03-11 14:24 Sandro Santilli <strk at keybit.net>
- * [r3269] Add XML test for bug398 (not automatically run, as it
- fails)
- * [r3268] Tell more about XML loading failures
-2011-03-08 09:04 Sandro Santilli <strk at keybit.net>
- * [r3267] Add test for invalid boundary node rule value
-2011-03-04 17:05 Sandro Santilli <strk at keybit.net>
- * [r3266] PHP: add relateBoundaryNodeRule method to GEOSGeometry
- object
-2011-03-04 16:38 Sandro Santilli <strk at keybit.net>
- * [r3265] Add note aboute GEOSRelateBoundaryNodeRule
-2011-03-04 16:31 Sandro Santilli <strk at keybit.net>
- * [r3264] GEOSRelateBoundaryNodeRule test, ticket #399 [RT-SIGTA]
-2011-03-04 16:30 Sandro Santilli <strk at keybit.net>
- * [r3263] GEOSRelateBoundaryNodeRule, ticket #399 [RT-SIGTA]
- * [r3262] Indenting..
-2011-03-02 13:45 Sandro Santilli <strk at keybit.net>
- * [r3261] Tweak unit test to expect distance 0 between an empty an
- anything else. Report the change in NEWS file.
- * [r3260] Add support for "distance" op in XMLTester, and import
- JTS TestDistance.xml
- * [r3259] Fixed Geometry.distance() and DistanceOp to return 0.0
- for empty inputs (JTS-1.11)
-2011-03-02 13:13 Sandro Santilli <strk at keybit.net>
- * [r3258] Sync IsValidOp and related XML testcase to JTS-1.12
-2011-03-02 12:46 Sandro Santilli <strk at keybit.net>
- * [r3257] Added check for illegal state in offsetPoint method
-2011-03-02 09:24 Sandro Santilli <strk at keybit.net>
- * [r3256] Fix debug build
-2011-03-01 17:56 Mateusz Loskot <mateusz at loskot.net>
- * [r3255] Fix DLL build using Visual C++: *) added missing exports;
- *) do not use static data members in inline methods - linker
- fails to find definition ; *) Clean up C4251 warning.
-2011-03-01 17:53 Mateusz Loskot <mateusz at loskot.net>
- * [r3254] Check geometry against nullptr
-2011-03-01 17:50 Mateusz Loskot <mateusz at loskot.net>
- * [r3253] Redefined ENDIAN_BIG and ENDIAN_LITTLE as enumerators
- instead of static non-const members - Visual C++ linker has
- mysterious problems with exporting them from DLL.
-2011-02-28 14:36 Sandro Santilli <strk at keybit.net>
- * [r3252] Fix BufferOp::bufferFixedPrecision to use snap-rounding
- noder. Fixes bug #356.
-2011-02-28 12:19 Sandro Santilli <strk at keybit.net>
- * [r3251] Cleanup debugging output. Previous version didn't really
- print the _noded_ output at all.
-2011-02-28 11:43 Sandro Santilli <strk at keybit.net>
- * [r3250] Expose and test covers/coveredBy to PHP binding
-2011-02-28 11:32 Sandro Santilli <strk at keybit.net>
- * [r3249] GEOSCovers and GEOSCoveredBy (ticket #396) by Alessandro
- Furieri
-2011-02-25 16:05 Sandro Santilli <strk at keybit.net>
- * [r3248] be explicit about quadrant segments
-2011-02-25 10:22 Sandro Santilli <strk at keybit.net>
- * [r3247] Add test for ticket #356 (not run, as it fails)
-2011-02-23 17:13 Sandro Santilli <strk at keybit.net>
- * [r3246] JTS-1.12 sync
-2011-02-23 16:46 Sandro Santilli <strk at keybit.net>
- * [r3245] Update port info
-2011-02-23 16:21 Sandro Santilli <strk at keybit.net>
- * [r3244] Update port info
- * [r3243] Fixed buffer OffsetCurveSetBuilder to handle "flat" rings
- correctly
-2011-02-23 15:45 Sandro Santilli <strk at keybit.net>
- * [r3242] Don't bother adding ring if it is "flat" and will
- disappear in the output (from TS r261)
- * [r3241] Sync LinearRing to JTS-1.12: empty LinearRing are closed
- by definition now
-2011-02-23 14:37 Sandro Santilli <strk at keybit.net>
- * [r3240] Update port info for MCIndexPointSnapper
- * [r3239] Update port info for SimpleSnapRounder
- * [r3238] Update port info for MCIndexSnapRounder (and remove
- testing-only check)
- * [r3237] Sync HotPixel to JTS-1.12 (doxygen + privatization of a
- method..)
-2011-02-23 11:05 Sandro Santilli <strk at keybit.net>
- * [r3236] Run test for bug366 (succeeds)
-2011-02-23 10:25 Sandro Santilli <strk at keybit.net>
- * [r3235] Port JTS unit tests for SegmentPointComparator
- * [r3234] Take SegmentPointComparator out of implelmentation file,
- to allow for unit-testing.
-2011-02-23 09:37 Sandro Santilli <strk at keybit.net>
- * [r3233] Fix NodedSegmentString to handle zero-length line
- segments correctly (via safeOctant)
-2011-02-22 21:22 Sandro Santilli <strk at keybit.net>
- * [r3232] Export Puntal, Lineal and Polygonal symbols
-2011-02-22 17:53 Sandro Santilli <strk at keybit.net>
- * [r3231] Fix linemerge test (wrong initial copy)
-2011-02-21 17:30 Sandro Santilli <strk at keybit.net>
- * [r3230] Add LineSequencer unit test, fix memory leaks in the
- class.
- * [r3229] Add templated geometry adder to LineSequencer class
-2011-02-21 16:14 Sandro Santilli <strk at keybit.net>
- * [r3228] Sync linemerge namespace to JTS-1.12 fixing LineMerger to
- skip lines with only a single unique coordinate; reduce some heap
- allocations; add unit testing for Linemerger
- * [r3227] Sync linemerge::LineSequencer to JTS-1.12
-2011-02-21 14:02 Sandro Santilli <strk at keybit.net>
- * [r3226] Add note about SnapIfNeededOverlayOp change
- * [r3225] Update port info
-2011-02-21 12:03 Sandro Santilli <strk at keybit.net>
- * [r3224] Fix SnapIfNeededOverlayOp to throw the originating
- exception, which contains meaningful coordinates, and update port
- info.
-2011-02-18 18:25 Mateusz Loskot <mateusz at loskot.net>
- * [r3223] Updated CMake configuration to use libgeos.lib for static
- library and geos.lib for import library. Define GEOS_DLL_EXPORT
- for GEOS DLL target.
-2011-02-15 17:35 Mateusz Loskot <mateusz at loskot.net>
- * [r3222] gstrdup may throw since r3088 thus should no longer be
- declared as C function
-2011-02-15 15:24 Sandro Santilli <strk at keybit.net>
- * [r3221] Allow passing NULL for "reason" and "location" arguments
- of GEOSisValidDetail [RT-SIGTA]
-2011-02-15 15:15 Sandro Santilli <strk at keybit.net>
- * [r3220] Adapt PHP binding to the new GEOSisValidDetail interface
- * [r3219] Add a 'flags' parameter to GEOSisValidDetail.
-2011-02-15 15:14 Sandro Santilli <strk at keybit.net>
- * [r3218] Make sure php binding are built _before_ the
- corresponding test is run
-2011-02-13 22:31 Sandro Santilli <strk at keybit.net>
- * [r3217] Guard againts empty vectors before decrementing .end()
-2011-02-13 22:30 Sandro Santilli <strk at keybit.net>
- * [r3216] Add an .empty() interface to CoordinateList
-2011-02-13 21:29 Mateusz Loskot <mateusz at loskot.net>
- * [r3215] Added new ./configure option: --enable-glibcxx-debug
- which to enable libstdc++ debug mode (see Ticket #395). Added
- AC_MSG_CHECKING and AC_MSG_RESULT to existing options.
-2011-02-13 20:14 Mateusz Loskot <mateusz at loskot.net>
- * [r3214] CRLF to LF
- * [r3213] Added test case submitted with Ticket #367. No
- segmentation fault in distance() method observed under Visual C++
- 10.0
-2011-02-13 20:03 Sandro Santilli <strk at keybit.net>
- * [r3212] Always use BinaryOp for overlay operations accessible
- from Geometry
-2011-02-13 19:54 Mateusz Loskot <mateusz at loskot.net>
- * [r3211] Explicitly disabled Visual C++ warning C4250 ('class1' :
- inherits 'class2::member' via dominance) - it is still unclear if
- caused by Visual C++ bug
- https://connect.microsoft.com/VisualStudio/feedback/details/101259/
- - safe to disable anyway.
-2011-02-13 19:51 Mateusz Loskot <mateusz at loskot.net>
- * [r3210] Return unset std::auto_otr from GeometryFactory,
- otherwise error condition causes no return
-2011-02-13 19:50 Mateusz Loskot <mateusz at loskot.net>
- * [r3209] Declare PointGeometryUnion type as non-copyable
-2011-02-13 19:25 Mateusz Loskot <mateusz at loskot.net>
- * [r3208] Renamed template parameters to more readable CamelCase
- and self-descriptive form. Declare Extracter type as
- non-copyable. Do not use names starting with underscore - they
- are reserved for C++ implementations.
-2011-02-13 19:22 Mateusz Loskot <mateusz at loskot.net>
- * [r3207] Fixed missing or ambiguous declarations of
- TopologyException (Ticket #394)
-2011-02-12 08:54 Sandro Santilli <strk at keybit.net>
- * [r3206] Have Geometry::Union use BinaryOp rather than
- SnapIfNeededOverlayOp. Improves robustness (fixes bug #360, test
- for which is enabled with this commit)
-2011-02-11 15:59 Sandro Santilli <strk at keybit.net>
- * [r3205] Add description
-2011-02-11 10:51 Sandro Santilli <strk at keybit.net>
- * [r3204] XML version of test for bug #360
-2011-02-11 10:28 Sandro Santilli <strk at keybit.net>
- * [r3203] Optimize container->container copy, on Mat's suggestion
-2011-02-11 09:58 Sandro Santilli <strk at keybit.net>
- * [r3202] PHP support or UnaryUnion
- * [r3201] GEOSUnaryUnion C-API interface (and test)
-2011-02-10 21:05 Sandro Santilli <strk at keybit.net>
- * [r3200] Add support for UnaryUnion testing in XML format, import
- the JTS xml test for it
- * [r3199] Add test exposing the std::copy bug of two commits ago
- * [r3198] Expose unary union trought Geometry.Union()
- * [r3197] Can't just std::copy over an empty container. Need a
- back_inserter !
-2011-02-10 15:51 Sandro Santilli <strk at keybit.net>
- * [r3196] Add unit test for UnaryUnionOp (and fix interface bug)
-2011-02-10 14:14 Sandro Santilli <strk at keybit.net>
- * [r3195] UnaryUnionOp port from JTS-1.12
-2011-02-10 14:10 Sandro Santilli <strk at keybit.net>
- * [r3194] Oops, didn't want to commit this one.
-2011-02-10 14:05 Sandro Santilli <strk at keybit.net>
- * [r3193] Fix dynamic cast
-2011-02-10 13:48 Sandro Santilli <strk at keybit.net>
- * [r3192] Add a template interface to CascadedPolygonUnion to relax
- requirements on used container
-2011-02-10 11:09 Sandro Santilli <strk at keybit.net>
- * [r3191] Introduce a templated version of
- GeometryFactory::buildGeometry, and test it.
- * [r3190] Include required GeometryFactory header (it's used)
-2011-02-07 17:52 Sandro Santilli <strk at keybit.net>
- * [r3189] Port GeometryExtracter from JTS-1.12
-2011-02-07 17:00 Sandro Santilli <strk at keybit.net>
- * [r3188] Fix casts
-2011-02-07 15:41 Sandro Santilli <strk at keybit.net>
- * [r3187] PointGeometryUnion port
-2011-02-07 15:39 Sandro Santilli <strk at keybit.net>
- * [r3186] Include definition of base class
- * [r3185] Turn Puntal, Lineal and Polygonal into Geometry
- derivates. This commit introduces virtual inheritance and 3
- diamonds.
-2011-02-04 12:27 Sandro Santilli <strk at keybit.net>
- * [r3184] dynamic_cast Polygon to Geometry before converting to
- void pointer. This is safer, altought the whole void pointer use
- should be dropped for real safety.
-2011-02-04 12:26 Sandro Santilli <strk at keybit.net>
- * [r3183] Avoid useless reinterpret_cast
-2011-02-04 10:12 Sandro Santilli <strk at keybit.net>
- * [r3182] Even more static casts drops
-2011-02-04 08:50 Sandro Santilli <strk at keybit.net>
- * [r3181] Drop more static casts
-2011-02-03 21:50 Sandro Santilli <strk at keybit.net>
- * [r3180] Don't downcast with static_cast
-2011-02-03 19:59 Sandro Santilli <strk at keybit.net>
- * [r3179] reduce static casts
-2011-02-03 19:58 Sandro Santilli <strk at keybit.net>
- * [r3178] provide standard strict weak ordering operator for
- Coordinate
- * [r3177] A step toward better const-correctness in
- GeometryCombiner interface
- * [r3176] Document ownerhips of GeometryCombiner inputs
-2011-02-03 08:15 Sandro Santilli <strk at keybit.net>
- * [r3175] Oops.. fix the newly added interface to create MultiPoint
- from a vector of coordinates
-2011-02-02 19:24 Sandro Santilli <strk at keybit.net>
- * [r3174] Check PointLocator sync with JTS-1.12
-2011-02-02 19:23 Sandro Santilli <strk at keybit.net>
- * [r3173] Add interface to create MultiPoint from Coordinate vector
-2011-02-02 17:57 Sandro Santilli <strk at keybit.net>
- * [r3172] Check GeometryCombiner against JTS-1.12
-2011-02-02 17:41 Sandro Santilli <strk at keybit.net>
- * [r3171] Add Puntal, Lineal and Polygonal "interfaces"
-2011-01-27 18:01 Sandro Santilli <strk at keybit.net>
- * [r3170] Add release date of 3.2.0 (more than an year ago..)
-2011-01-27 10:16 Sandro Santilli <strk at keybit.net>
- * [r3169] Don't use is_null on unexistant array elements [#393]
-2011-01-25 23:20 Mateusz Loskot <mateusz at loskot.net>
- * [r3168] Added tests/bigtest programs to CMake configuration
-2011-01-25 23:08 Mateusz Loskot <mateusz at loskot.net>
- * [r3167] Updated CMake configuration to call xmltester from
- runtime output directory.
-2010-12-26 21:20 Sandro Santilli <strk at keybit.net>
- * [r3166] remove warning in testcase
-2010-12-26 20:32 Sandro Santilli <strk at keybit.net>
- * [r3165] Declare SharedPathsOp class as noncopyable. Hopefully
- fixes VC2008 warning. [RT-SIGTA]
-2010-12-24 14:27 Sandro Santilli <strk at keybit.net>
- * [r3164] Record port info for InteriorPointLine
-2010-12-22 16:28 Sandro Santilli <strk at keybit.net>
- * [r3163] Fix computation of shared path direction when path starts
- or ends on the first-last point of a closed line. Fixes ticket
- #391. Includes automated testing.
-2010-12-22 09:42 Sandro Santilli <strk at keybit.net>
- * [r3162] Expose GEOSRelateMatch to PHP api.
-2010-12-21 08:55 Sandro Santilli <strk at keybit.net>
- * [r3161] Add GEOSRelatePatternMatch C-API interface [RT-SIGTA]
-2010-12-20 11:34 Sandro Santilli <strk at keybit.net>
- * [r3160] MinGW32 fixes by Sandro Furieri
-2010-12-20 11:16 Mateusz Loskot <mateusz at loskot.net>
- * [r3159] Updated svn:ignore properties.
-2010-12-06 15:00 Sandro Santilli <strk at keybit.net>
- * [r3158] typo
-2010-12-03 17:26 Sandro Santilli <strk at keybit.net>
- * [r3157] Add test for src-vertex snapping allowance
-2010-12-03 14:02 Sandro Santilli <strk at keybit.net>
- * [r3156] Update copyright
-2010-12-03 13:57 Sandro Santilli <strk at keybit.net>
- * [r3155] Add method to insert coordinats into a CoordinateList
- w/out allowing duplicates (fixes issue #387)
-2010-12-03 10:58 Sandro Santilli <strk at keybit.net>
- * [r3154] Another test for snapping (empty sequence vs. non-empty
- snaps)
-2010-12-03 10:52 Sandro Santilli <strk at keybit.net>
- * [r3153] update dox
-2010-12-03 10:49 Sandro Santilli <strk at keybit.net>
- * [r3152] Take the allowSnappingToSourceVertices support in
-2010-12-03 08:36 Sandro Santilli <strk at keybit.net>
- * [r3151] Add test for GEOSSharedPaths C-API interface
-2010-12-02 18:06 Sandro Santilli <strk at keybit.net>
- * [r3150] Another test, and a leak plug (in the test)
-2010-12-02 16:49 Sandro Santilli <strk at keybit.net>
- * [r3149] Add GEOSSnap item
-2010-12-02 16:48 Sandro Santilli <strk at keybit.net>
- * [r3148] Expose GEOSSnap to PHP interface
-2010-12-02 16:44 Sandro Santilli <strk at keybit.net>
- * [r3147] Add test for C-API GEOSSnap interface
-2010-12-02 15:07 Sandro Santilli <strk at keybit.net>
- * [r3146] OOps.. this one build
-2010-12-02 14:52 Sandro Santilli <strk at keybit.net>
- * [r3145] Expose snapping to the C-API
-2010-12-02 14:29 Sandro Santilli <strk at keybit.net>
- * [r3144] Allow testing snapping something different from a single
- polygon..
-2010-12-02 14:16 Sandro Santilli <strk at keybit.net>
- * [r3143] tab to 8 spaces
-2010-12-02 10:32 Sandro Santilli <strk at keybit.net>
- * [r3142] Bring LineStringSnapper forward to r309 (JTS-1.11+):
- avoid snapping final point of closed rings.
-2010-12-02 09:38 Sandro Santilli <strk at keybit.net>
- * [r3141] update copyright date
-2010-12-02 09:36 Sandro Santilli <strk at keybit.net>
- * [r3140] Take GeometrySnapper forward to r309 (JTS-1.11+): add
- self-snapping
-2010-11-30 08:31 Sandro Santilli <strk at keybit.net>
- * [r3139] Hope this is the last one... (RT credit tweaks)
-2010-11-29 13:45 Sandro Santilli <strk at keybit.net>
- * [r3138] Full credit line [RT-SIGTA]
-2010-11-29 11:08 Sandro Santilli <strk at keybit.net>
- * [r3137] SharedPaths in NEWS [RT-SIGTA]
-2010-11-29 10:51 Sandro Santilli <strk at keybit.net>
- * [r3136] Merge branch 'rt'
-2010-11-29 09:43 Sandro Santilli <strk at keybit.net>
- * [r3135] Write RT credit and NEWS itam
-2010-11-29 09:34 Sandro Santilli <strk at keybit.net>
- * [r3134] drop unused include
- * [r3133] Test equal lines
- * [r3132] Have SharedPathsOp throw an exception on illegal
- (non-lineal) arg
- * [r3131] Add tests for multiline-multiline both single dir and
- mixed dirs
- * [r3130] Add two tests of mixed direction shared paths
- * [r3129] Document that the direction of the returned paths is the
- one these paths have on the first geometry given
-2010-11-29 09:33 Sandro Santilli <strk at keybit.net>
- * [r3128] Initial tests for SharedPathsOp
- * [r3127] Paths are always LINESTRING types
- * [r3126] forgot aclocal.m4
- * [r3125] Complete implementation of SharedPathsOp
- * [r3124] more ignores
- * [r3123] Build sharedpaths lib/namespace
-2010-11-29 09:32 Sandro Santilli <strk at keybit.net>
- * [r3122] Add support for 'maintainer mode'
- * [r3121] ignores
- * [r3120] Stub SharedPathsOp
- * [r3119] stub tet for SameDirection predicate
-2010-11-24 09:00 Sandro Santilli <strk at keybit.net>
- * [r3118] typo
-2010-10-25 15:12 Sandro Santilli <strk at keybit.net>
- * [r3117] Don't try to configure missing files (fixes bug #382)
-2010-10-15 15:54 Mateusz Loskot <mateusz at loskot.net>
- * [r3116] Unified CMAKE_*_OUTPUT_DIRECTOR locations to simplify
- tests running and finding all binaries.
-2010-10-15 15:20 Mateusz Loskot <mateusz at loskot.net>
- * [r3115] Visual C++ warnings cleanup
-2010-10-15 15:19 Mateusz Loskot <mateusz at loskot.net>
- * [r3114] Missing DLL storage-class attributes for
- GEOSOrientationIndex
-2010-10-15 14:55 Mateusz Loskot <mateusz at loskot.net>
- * [r3113] Cast toupper() result to char
-2010-10-15 13:42 Mateusz Loskot <mateusz at loskot.net>
- * [r3112] Deprecate Visual Studio projects in trunk/build (#381).
- Long live the CMake.
-2010-10-10 21:36 Mateusz Loskot <mateusz at loskot.net>
- * [r3111] Cleaned compiler warnings
- * [r3110] Cleaned compiler warnings
-2010-10-10 21:28 Mateusz Loskot <mateusz at loskot.net>
- * [r3109] Disable inline.obj if GEOS_INLINE defined while building
- with Visual C++
-2010-10-10 21:15 Mateusz Loskot <mateusz at loskot.net>
- * [r3108] Disable argument dependant lookup (Koenig) for min/max
- functions to make sure GEOS compiles in the presence of the min
- and max macros.
-2010-10-10 21:07 Mateusz Loskot <mateusz at loskot.net>
- * [r3107] Added NOMINMAX define for Visual C++
-2010-10-10 20:50 Mateusz Loskot <mateusz at loskot.net>
- * [r3106] Do not set CMAKE_BUILD_TYPE for Visual Studio IDE
- generators - CMAKE_BUILD_TYPE is dedicated to
- single-configuration generators like Make or NMAKE.
-2010-10-10 11:32 Mateusz Loskot <mateusz at loskot.net>
- * [r3105] Updated GEOS_HEADERS location. Thanks to Andrea Peri for
- reporting.
-2010-08-27 18:23 Sandro Santilli <strk at keybit.net>
- * [r3104] Add test for 358 in the loop (now fixed).
-2010-08-27 15:58 Sandro Santilli <strk at keybit.net>
- * [r3103] Drop duplicated testcase
-2010-08-27 15:55 Sandro Santilli <strk at keybit.net>
- * [r3102] Check validity of CommonBitsOp return, as JTS does. Check
- output validity for all tests, do not run the now-throwing tests
- also known to be bogus in JTS.
-2010-08-27 15:43 Sandro Santilli <strk at keybit.net>
- * [r3101] Found bug375.xml (==robustness-invalid-output.xml) to be
- the same of JTS's failure/TestOverlay.xml, so dropped the
- previous 2 and copied over the latter. Won't run that test for
- now, so to get in sync with JTS as next step.
-2010-08-27 15:27 Sandro Santilli <strk at keybit.net>
- * [r3100] Add proper arg1 and arg2 attributes (for JTS support)
-2010-08-27 14:13 Sandro Santilli <strk at keybit.net>
- * [r3099] Add code to check validity of CommonBits removal policy
- op (known as EnhancedPreicionOp in JTS). The check can be turned
- on at compile time. Currently defaults to off to avoid breaking a
- previously-almost-working test (robustness-invalid-output.xml).
- It'll need some discussion before going on with this as to
- whether we can accept to return invalid geometries or not..
-2010-08-27 13:53 Sandro Santilli <strk at keybit.net>
- * [r3098] Split tests that trigger invalid outputs from the rest.
- Test the sane ones with --test-invalid-output and the other ones
- with
- less strictness. Add (but dont run) tests for bugs 375 and 358
- (to
- review for correct expected otuput)
-2010-08-27 13:00 Sandro Santilli <strk at keybit.net>
- * [r3097] Have --test-valid-output influence test results
-2010-08-27 10:22 Sandro Santilli <strk at keybit.net>
- * [r3096] Add note about configuring for php support
-2010-08-27 09:04 Sandro Santilli <strk at keybit.net>
- * [r3095] const-correctness
-2010-08-27 06:17 Sandro Santilli <strk at keybit.net>
- * [r3094] Have --test-valid-output test actual result, not the
- expected one (more useful)
-2010-08-26 23:11 Sandro Santilli <strk at keybit.net>
- * [r3093] Fix name of the test to match ticket number
-2010-08-23 16:37 Stephen Wong <swongu at gmail.com>
- * [r3092] Fixed a filtering distance problem in
- bufferLineSingleSided. (#372)
-2010-08-23 15:10 Sandro Santilli <strk at keybit.net>
- * [r3091] Add more debugging calls (for bug #358)
-2010-08-23 13:38 Sandro Santilli <strk at keybit.net>
- * [r3090] Snapping heuristic was never really dropping common bits.
- Now it does.
- This is just to have code match documentation, and still passes
- 'make
- check' for GEOS. Wasn't tried against postgis, would be useful to
- do.
-2010-08-17 18:57 Sean Gillies <sgillies at frii.com>
- * [r3089] Use fully qualified std::runtime_error (#371) and fix
- indentation
-2010-08-17 18:33 Sean Gillies <sgillies at frii.com>
- * [r3088] Throw runtime_error if allocation fails in gstrdup_s
-2010-07-26 22:21 Stephen Wong <swongu at gmail.com>
- * [r3087] Fixed a bufferLineSingleSided crash and fixed OGC
- validation on rare cases. (#364)
-2010-07-15 15:54 Sandro Santilli <strk at keybit.net>
- * [r3086] Updated
-2010-07-15 09:15 Sandro Santilli <strk at keybit.net>
- * [r3085] Add item about the new PHP5 binding
-2010-07-15 09:13 Sandro Santilli <strk at keybit.net>
- * [r3084] PHP: Drop debug lines from serialization code, add test
- for
- serialization
-2010-07-15 09:07 Sandro Santilli <strk at keybit.net>
- * [r3083] Fix logic bug in phpunit check
-2010-07-14 08:38 Sandro Santilli <strk at keybit.net>
- * [r3082] Serialization/deserialization support for GEOSGeometry
- type
-2010-07-13 11:03 Sandro Santilli <strk at keybit.net>
- * [r3081] Cleanup PHP-specific dependency handling and reporting
-2010-07-08 20:54 Sandro Santilli <strk at keybit.net>
- * [r3080] Object passed for ownership transfer in the constructor
- shouldn't be deleted when construction fails. Fixes bug #361
-2010-07-01 21:49 Sandro Santilli <strk at keybit.net>
- * [r3079] Note the bugfix in news file
-2010-07-01 21:44 Sandro Santilli <strk at keybit.net>
- * [r3078] Fix PolygonizeGraph::deleteDangles so it doesn't return
- duplicated LineStrings, as per JTS design. Fixes the Polygonizer
- Bug reported in list. This commit also takes the chance to reduce
- some heap allocations.
-2010-07-01 20:49 Sandro Santilli <strk at keybit.net>
- * [r3077] Minor optimizations / strictnesses
-2010-07-01 20:03 Sandro Santilli <strk at keybit.net>
- * [r3076] Drop useless heap-allocation in Polygonize op
-2010-06-24 14:40 Frank Warmerdam <warmerdam at pobox.com>
- * [r3075] fix memory leaks
-2010-06-24 14:10 Sandro Santilli <strk at keybit.net>
- * [r3074] PHP: GEOSWKTWriter::getOutputDimension and test
-2010-06-24 13:58 Frank Warmerdam <warmerdam at pobox.com>
- * [r3073] added GEOSWKTWriter_getOutputDimension and test (#354)
-2010-06-24 09:42 Sandro Santilli <strk at keybit.net>
- * [r3072] Update
-2010-06-24 09:41 Sandro Santilli <strk at keybit.net>
- * [r3071] WKBReader: construct and readHEX; improve WKTReader test
- to include 'Z' label
-2010-06-24 09:20 Sandro Santilli <strk at keybit.net>
- * [r3070] WKBWriter::{set,get}IncludeSRID (and test)
-2010-06-24 09:07 Sandro Santilli <strk at keybit.net>
- * [r3069] WKBWriter::{get,set}ByteOrder, improve tests for writeHEX
-2010-06-24 09:01 Sandro Santilli <strk at keybit.net>
- * [r3068] Make WKBWriter::setByteOrder check for argument and throw
- IllegalArgumentException when appropriate. Make sure C-API
- wrapper catches those.
-2010-06-24 08:28 Sandro Santilli <strk at keybit.net>
- * [r3067] PHP: WKBWriter: ctor, getOutputDimension,
- setOutputDimension, writeHEX and tests
-2010-06-24 08:27 Sandro Santilli <strk at keybit.net>
- * [r3066] Properly catch exceptions from
- WKTWriter::setOutputDimension and WKBWriter::setOutputDimension
- * [r3065] Make WKTWriter::setOutputDimensions check parameter
- validity (must be 2 or 3) to be consistent with WKBWriter already
- doing so in constructor; make WKBWriter::setOutputDimensions
- perform the check as well (like the constructor); Drop virtual
- methods from WKTWriter class, which wasn't meant to be a virtual
- class (no virtual dtor anyway)
-2010-06-23 09:48 Sandro Santilli <strk at keybit.net>
- * [r3064] Log ABI change
-2010-06-23 09:47 Sandro Santilli <strk at keybit.net>
- * [r3063] Const-correct Geometry::isWithinDistance. Thanks to Yabo,
- see ticket #349
-2010-06-23 09:31 Sandro Santilli <strk at keybit.net>
- * [r3062] There's no point for GEOSisValidDetail to take output
- parameter as const pointer
-2010-06-23 09:23 Sandro Santilli <strk at keybit.net>
- * [r3061] Fix for 4.4.3 builds, patch by Yabo (see ticket #351)
-2010-06-21 14:31 Sandro Santilli <strk at keybit.net>
- * [r3060] Switch back to unchecked getGeometryN, getPointN and
- getInteriorRingN, check them at the PHP level, for performance
- sake in C-land.
-2010-06-21 10:30 Sandro Santilli <strk at keybit.net>
- * [r3059] Rename getGeometryN to geometryN, for interface
- consistency
-2010-06-21 10:21 Sandro Santilli <strk at keybit.net>
- * [r3058] area, length, distance, hausdorffDistance; fix leaks in
- pointN, startPoint and endPoint
-2010-06-21 02:02 Sandro Santilli <strk at keybit.net>
- * [r3057] startPoint, endPoint
-2010-06-21 01:58 Sandro Santilli <strk at keybit.net>
- * [r3056] pointN
-2010-06-21 01:57 Sandro Santilli <strk at keybit.net>
- * [r3055] LineString::getPointN is part of the API, check before
- segfaulting..
-2010-06-21 01:49 Sandro Santilli <strk at keybit.net>
- * [r3054] coordinateDimension()
-2010-06-21 01:46 Sandro Santilli <strk at keybit.net>
- * [r3053] dimension() [ spatial ]
-2010-06-21 01:43 Sandro Santilli <strk at keybit.net>
- * [r3052] numCoordinates
-2010-06-21 01:39 Sandro Santilli <strk at keybit.net>
- * [r3051] exteriorRing
-2010-06-21 01:36 Sandro Santilli <strk at keybit.net>
- * [r3050] numPoints, getX, getY, interiorRingN
-2010-06-21 01:34 Sandro Santilli <strk at keybit.net>
- * [r3049] Make getInteriorRingN checked (API)
-2010-06-21 01:05 Sandro Santilli <strk at keybit.net>
- * [r3048] numInteriorRings
-2010-06-21 00:56 Sandro Santilli <strk at keybit.net>
- * [r3047] Test null-return from unexistent offset
-2010-06-21 00:53 Sandro Santilli <strk at keybit.net>
- * [r3046] Geometry::getGeometryN is an API function, so make it
- safe/checked
-2010-06-21 00:44 Sandro Santilli <strk at keybit.net>
- * [r3045] getGeometryN
-2010-06-21 00:06 Sandro Santilli <strk at keybit.net>
- * [r3044] Test numGeometries
-2010-06-21 00:01 Sandro Santilli <strk at keybit.net>
- * [r3043] getSRID, setSRID
-2010-06-20 23:53 Sandro Santilli <strk at keybit.net>
- * [r3042] typeName, typeId
-2010-06-20 23:40 Sandro Santilli <strk at keybit.net>
- * [r3041] Geometry type constants
-2010-06-20 23:35 Sandro Santilli <strk at keybit.net>
- * [r3040] isSimple, isRing, hasZ, isClosed
-2010-06-20 22:59 Sandro Santilli <strk at keybit.net>
- * [r3039] checkValidity (isValid in disguise)
-2010-06-20 21:10 Sandro Santilli <strk at keybit.net>
- * [r3038] isEmpty
-2010-06-20 21:00 Sandro Santilli <strk at keybit.net>
- * [r3037] Relational operators + equalsExact
-2010-06-20 19:05 Sandro Santilli <strk at keybit.net>
- * [r3036] Simplify (also topology-preserving), ExtractUniquePoints
-2010-06-20 17:00 Sandro Santilli <strk at keybit.net>
- * [r3035] GEOSLineMerge
-2010-06-20 09:13 Sandro Santilli <strk at keybit.net>
- * [r3034] Make GEOSPolygonize a free function rather than a method
- on GEOSGeometry. This is to allow extending it to accept
- differnet kind of args, like arrays of GEOSGeometry for example..
-2010-06-20 09:02 Sandro Santilli <strk at keybit.net>
- * [r3033] Add serialize/unserialize TODO item
-2010-06-20 08:50 Sandro Santilli <strk at keybit.net>
- * [r3032] Geometry.__toString for easier debuggin
-2010-06-20 08:32 Sandro Santilli <strk at keybit.net>
- * [r3031] Polygonize (testing need further review for a possible
- bug in core lib)
-2010-06-19 21:38 Sandro Santilli <strk at keybit.net>
- * [r3030] Use the "T" char for IM9 pattern sometime (for fun and
- proof)
-2010-06-19 21:36 Sandro Santilli <strk at keybit.net>
- * [r3029] relate, relatePattern
-2010-06-19 18:27 Sandro Santilli <strk at keybit.net>
- * [r3028] Geometry->{pointOnSurface,centroid}
-2010-06-19 18:13 Sandro Santilli <strk at keybit.net>
- * [r3027] More Geometry methods: envelope, intersection,
- convexHull, difference, symDifference, boundary, union (including
- cascaded)
-2010-06-19 17:14 Sandro Santilli <strk at keybit.net>
- * [r3026] Export buffer costants and method
-2010-06-19 13:27 Sandro Santilli <strk at keybit.net>
- * [r3025] Test typed empty geoms too for IO
-2010-06-19 13:17 Sandro Santilli <strk at keybit.net>
- * [r3024] Add second optional argument to Geometry->project and
- Geometry->interpolate to request normalization
-2010-06-19 13:08 Sandro Santilli <strk at keybit.net>
- * [r3023] Document GEOSInterpolate
-2010-06-19 13:06 Sandro Santilli <strk at keybit.net>
- * [r3022] Add GEOSGeometry->interpolate()
-2010-06-19 12:42 Sandro Santilli <strk at keybit.net>
- * [r3021] Handle exceptions in GEOSInterpolate
-2010-06-19 12:30 Sandro Santilli <strk at keybit.net>
- * [r3020] Better automake integration of unit test
-2010-06-19 12:28 Sandro Santilli <strk at keybit.net>
- * [r3019] Handle illegal argument to LinearLocation::getCoordinate
-2010-06-19 12:20 Sandro Santilli <strk at keybit.net>
- * [r3018] document GEOSProject
-2010-06-19 11:34 Sandro Santilli <strk at keybit.net>
- * [r3017] Complete implementation of WKTWriter interfaces, add
- phpunit-based testing, add .project interface to Geometry
-2010-06-19 11:32 Sandro Santilli <strk at keybit.net>
- * [r3016] Check for PHP and PHPUNIT (for testing php bindings)
-2010-06-19 11:25 Sandro Santilli <strk at keybit.net>
- * [r3015] Handle exceptions from LenghtIndexedLine::project
-2010-06-19 11:23 Sandro Santilli <strk at keybit.net>
- * [r3014] The thrown error shall make sense...
-2010-06-19 11:16 Sandro Santilli <strk at keybit.net>
- * [r3013] Throw an exception on first non-linestring component,
- rather than segfaulting la
- ter... (might be better to refuse non-lineal even earlier, but
- this way we *migh
- * be supporting collections with only linestrings)
-2010-06-19 11:14 Sandro Santilli <strk at keybit.net>
- * [r3012] Dox cleanup
-2010-06-18 16:15 Sandro Santilli <strk at keybit.net>
- * [r3011] WKTWriter::setTrim
-2010-06-18 16:12 Sandro Santilli <strk at keybit.net>
- * [r3010] Ubuntu 8.10 version of gcc needs -std=gnu99 to digest
- Zend headers :(
-2010-06-18 15:09 Sandro Santilli <strk at keybit.net>
- * [r3009] Add 'doxygen' rule (and 'apidoc' alias) to top-level
- Makefile.am
-2010-06-18 14:43 Sandro Santilli <strk at keybit.net>
- * [r3008] tip for test
-2010-06-18 14:20 Sandro Santilli <strk at keybit.net>
- * [r3007] Initial go at PHP5 bindings. Can only read and write WKT
- so far.
-2010-06-18 10:29 Sandro Santilli <strk at keybit.net>
- * [r3006] Do not set user FLAGS, se project flags instead.
- For the whole story, see:
- http://www.gnu.org/software/hello/manual/automake/Flag-Variables-Ordering.html
-2010-06-18 09:57 Sandro Santilli <strk at keybit.net>
- * [r3005] Fix automake override
-2010-06-18 09:52 Sandro Santilli <strk at keybit.net>
- * [r3004] Add -Woverride option to automake invocation, to catch
- Makefile.am errors (there's one)
-2010-06-16 10:39 Sandro Santilli <strk at keybit.net>
- * [r3003] Drop carriage returns
-2010-06-16 09:45 Sandro Santilli <strk at keybit.net>
- * [r3002] OOps, tabs instead of spaces confuse automake
-2010-06-16 09:31 Sandro Santilli <strk at keybit.net>
- * [r3001] Always distribute swig bindings, closes bug #352
-2010-06-16 09:25 Sandro Santilli <strk at keybit.net>
- * [r3000] Fix swig macro so it doesn't think version 2.0.0 is <
- 1.3.37
-2010-06-01 15:15 Frank Warmerdam <warmerdam at pobox.com>
- * [r2999] make WKTReader keywords case insensitive
-2010-05-31 16:25 Frank Warmerdam <warmerdam at pobox.com>
- * [r2998] Attempt to make geometry dimension perform more smoothly.
- Modified CoordinateArraySequence to default to unknown dimension
- (0), which
- is determined at the point getDimension() is called by
- examination of the
- first coordinate Z (ISNAN test). The WKTWriter has also been
- altered to
- write 0.0 instead of nan, and to avoid writing "Z" for EMPTY
- geometries.(#348)
-2010-05-31 02:57 Frank Warmerdam <warmerdam at pobox.com>
- * [r2997] Addition of getCoordinateDimension() on GEOSGeom (#311)
- Addition of setOutputDimension, setOld3D on WKTWriter (#292)
-2010-05-28 20:44 Frank Warmerdam <warmerdam at pobox.com>
- * [r2996] added missing test that should have been in r2995
-2010-05-28 20:38 Frank Warmerdam <warmerdam at pobox.com>
- * [r2995] Implement getCoordinateDimension() for geometries (#331)
- WKTWriter now has setOutputDimension() method, and writes 3D
- geometries (#292)
- WKBWriter has fixes for writing 2D geometries from 3D geometry
- (#346)
- Minimal unit tests for the above.
-2010-05-28 20:32 Frank Warmerdam <warmerdam at pobox.com>
- * [r2994] add support for reading SF1.2 Z/M/ZM geometries (#347)
-2010-05-19 05:22 Frank Warmerdam <warmerdam at pobox.com>
- * [r2993] added setPrecision, setTrim support on WKTWriter and
- provided tests (#341)
-2010-05-18 20:28 Frank Warmerdam <warmerdam at pobox.com>
- * [r2992] expose several new accessor functions on geometries
- (#345)
-2010-05-18 20:07 Frank Warmerdam <warmerdam at pobox.com>
- * [r2991] disamiguate create args (#345)
-2010-05-18 19:18 Frank Warmerdam <warmerdam at pobox.com>
- * [r2990] preserve dimension as part of CoordinateArraySequence and
- while reading WKT (#345)
-2010-05-15 12:47 Sandro Santilli <strk at keybit.net>
- * [r2989] Minor tweaks
-2010-05-15 12:31 Sandro Santilli <strk at keybit.net>
- * [r2988] Move OffsetCurveVertexList.h to headers dir, add a
- .reset() method to reduce memory allocations, use the new
- interface.
-2010-05-15 12:30 Sandro Santilli <strk at keybit.net>
- * [r2987] Add clear() method to CoordinateArraySequence, inline
- empty()
-2010-05-04 21:29 Sandro Santilli <strk at keybit.net>
- * [r2986] Add 'ldconfig' step, seems to be a recurring issue with
- builders...
-2010-05-02 09:35 Sandro Santilli <strk at keybit.net>
- * [r2985] Add a note about 2d nature of extractUniquePoints
-2010-04-21 16:17 Mateusz Loskot <mateusz at loskot.net>
- * [r2982] * Updated nmake.opt with NMake version from Visual Studio
- 2010 release.
-2010-04-17 22:16 Sandro Santilli <strk at keybit.net>
- * [r2977] Also set version for the systems not using autoconf, and
- update paths in HOWTO_RELEASE file
-2010-04-17 22:14 Sandro Santilli <strk at keybit.net>
- * [r2976] As we're still maintaining 3.2 branch, and since new CAPI
- interface were added, bump CAPI lib interface version up. We'll
- be 1.7.0 there from now on.
-2010-04-17 15:34 Sandro Santilli <strk at keybit.net>
- * [r2974] Have initGEOS(..) return a singleton, as used to be up to
- 3.0.0
-2010-04-07 13:24 Mateusz Loskot <mateusz at loskot.net>
- * [r2968] Added ENABLE_INLINE=YES|NO option to nmake.opt for Visual
- C++ builds using NMake. The ENABLE_INLINE=YES does not link for
- me - to be fixed
-2010-04-07 13:22 Mateusz Loskot <mateusz at loskot.net>
- * [r2967] Updated src/dirlist.mk (Ticket 337)
-2010-03-29 17:44 Mateusz Loskot <mateusz at loskot.net>
- * [r2965] Added NMake 10.x version to be recognized by nmake.opt
-2010-03-29 12:17 Mateusz Loskot <mateusz at loskot.net>
- * [r2961] Qualify size_t with std namespace in headers.
-2010-03-29 12:13 Mateusz Loskot <mateusz at loskot.net>
- * [r2960] Updated svn:ignore property
-2010-03-29 11:30 Mateusz Loskot <mateusz at loskot.net>
- * [r2959] Updated projects for Visual Studio 2008 and 2010
-2010-03-29 11:29 Mateusz Loskot <mateusz at loskot.net>
- * [r2958] Added pragma to disable Visual C++ warning C4251 - safe
- to ignore (http://support.microsoft.com/kb/813810/)
-2010-03-29 11:21 Mateusz Loskot <mateusz at loskot.net>
- * [r2957] No need to load the whole std namespace to use
- std::vector only.
-2010-03-26 12:35 Mateusz Loskot <mateusz at loskot.net>
- * [r2955] platform.h.vc: disable min/max macros substitution
-2010-03-26 12:06 Mateusz Loskot <mateusz at loskot.net>
- * [r2954] Added GEOS_DLL with Microsoft-specific __declspec
- attribute missing from CascadedPolygonUnion class (ported from
- branches/3.2)
-2010-03-26 12:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2952] geom\GeoemtryList.cpp: missing implementation of
- GeometryList::size() function (ported from branches/3.2)
-2010-03-26 11:58 Mateusz Loskot <mateusz at loskot.net>
- * [r2950] src\Makefile.vc: added missing geom\GeometryList.cpp
- (ported from branches/3.2)
-2010-03-26 11:55 Mateusz Loskot <mateusz at loskot.net>
- * [r2948] nmake.opt: Added missing GEOS_DLL_EXPORT to CPPFLAGS
-2010-03-19 15:13 Sandro Santilli <strk at keybit.net>
- * [r2946] Improve formatting for GEOSisValidReason_r (#329)
-2010-03-18 18:39 Sandro Santilli <strk at keybit.net>
- * [r2944] Forw-port a better fix for #333 (false positive valid
- geoms)
-2010-03-16 13:13 Sandro Santilli <strk at keybit.net>
- * [r2941] Fix ST_IsValidDetail (broke by last commit)
-2010-03-16 12:32 Sandro Santilli <strk at keybit.net>
- * [r2940] Now that IsValidOp doesn't cache the 'checked' status it
- is better to trigger a single check rather than two (also fix
- leaks)
-2010-03-14 10:13 Sandro Santilli <strk at keybit.net>
- * [r2939] Install Machine.h
-2010-03-13 22:07 Sandro Santilli <strk at keybit.net>
- * [r2938] Fix GEOSOrientationIndex implementation and testcase.
- Closes ticket #335.
-2010-03-12 07:54 Sandro Santilli <strk at keybit.net>
- * [r2937] Expose GEOSOrientationIndex to C-API
-2010-03-10 09:34 Sandro Santilli <strk at keybit.net>
- * [r2936] Sync TestValid xml from JTS, review IsValidOp to be in
- sync with current JTS trunk.
-2010-03-07 11:39 Sandro Santilli <strk at keybit.net>
- * [r2935] Apply slightly modified patch by mwtoews (#344)
-2010-03-06 01:49 Mateusz Loskot <mateusz at loskot.net>
- * [r2934] Added cmake/cmake_uninstall.cmake.in script and
- configured make uninstall target for CMake configuration (#317)
-2010-03-03 07:21 Sandro Santilli <strk at keybit.net>
- * [r2933] Improve documentation for GEOSPOlygonize_full
-2010-03-02 21:04 Sandro Santilli <strk at keybit.net>
- * [r2932] Fix false positive return from IsValidOp (#333)
-2010-02-28 19:01 Sandro Santilli <strk at keybit.net>
- * [r2931] Minor tweak
-2010-02-28 18:55 Sandro Santilli <strk at keybit.net>
- * [r2930] Provide non-rehentrant version of empty geometries
- constructors
-2010-02-28 17:02 Sandro Santilli <strk at keybit.net>
- * [r2929] extractUniquePoints comes in non-reentrant version too
-2010-02-25 07:50 Sandro Santilli <strk at keybit.net>
- * [r2928] Update with GEOSPolygonize_full item
-2010-02-23 20:00 Sandro Santilli <strk at keybit.net>
- * [r2927] GEOSPolygonize_full [RT-SIGTA]
-2010-02-22 22:21 Sandro Santilli <strk at keybit.net>
- * [r2926] LineStringAdder heap-allocation removal
-2010-02-22 22:17 Sandro Santilli <strk at keybit.net>
- * [r2925] Drop heap allocation of invalidRingLines vector
-2010-02-22 22:06 Sandro Santilli <strk at keybit.net>
- * [r2924] More heap allocations bite the dust...
-2010-02-22 21:51 Sandro Santilli <strk at keybit.net>
- * [r2923] Drop HEAP allocation for dangles vector too, and document
- all these API changes
-2010-02-22 21:41 Sandro Santilli <strk at keybit.net>
- * [r2922] Avoid heap allocation of a vector for cut edges, bits of
- additional documentation
-2010-02-22 21:29 Sandro Santilli <strk at keybit.net>
- * [r2921] Try to document current behaviour (very bad behaviour
- indeed...)
-2010-02-21 17:11 Mateusz Loskot <mateusz at loskot.net>
- * [r2920] Another patch from Gavin Heavyside to enable GEOS as a
- dependency of a project with CMake
-2010-02-21 17:05 Sandro Santilli <strk at keybit.net>
- * [r2919] Allow GEOSGetGeometryN calls against single geometries
-2010-02-21 16:27 Sandro Santilli <strk at keybit.net>
- * [r2918] Expose the non-reentrant version too (I know, I was
- against, but it's too much work on the postgis side for that
- right now)
-2010-02-21 15:03 Sandro Santilli <strk at keybit.net>
- * [r2917] GEOSGeom_extractUniquePoints [RT-SIGTA]
-2010-02-21 14:50 Mateusz Loskot <mateusz at loskot.net>
- * [r2916] Patch from Gavin Heavyside that enables CMake to build
- GEOS as a dependency of user-defined project
-2010-02-17 14:04 Sandro Santilli <strk at keybit.net>
- * [r2915] Throw an IllegalArgumentException when setOrdinate is
- called with unknown ordinate index
-2010-02-14 14:01 Sandro Santilli <strk at keybit.net>
- * [r2913] Add GEOSPolygonizer_getCutEdges NEWS item where it
- belongs
-2010-02-12 17:35 Mateusz Loskot <mateusz at loskot.net>
- * [r2912] Fixed but in CMake configuration which installed geos_c.h
- in incorrect location (#330)
-2010-02-11 18:15 Sandro Santilli <strk at keybit.net>
- * [r2911] Update
-2010-02-11 08:33 Sandro Santilli <strk at keybit.net>
- * [r2910] Complete set of typed-empty constructors and tests for
- them [RT-SIGTA]
-2010-02-11 08:18 Sandro Santilli <strk at keybit.net>
- * [r2909] Go for consistency with reentrant interfaces [RT-SIGTA]
-2010-02-11 00:10 Sandro Santilli <strk at keybit.net>
- * [r2908] GEOSContext_setNoticeHandler,
- GEOSContext_setErrorHandler, GEOSGeom_createEmptyPolygon_r (and
- test)
-2010-02-09 17:52 Sandro Santilli <strk at keybit.net>
- * [r2907] Fix to match new layout
-2010-02-06 04:07 Mateusz Loskot <mateusz at loskot.net>
- * [r2906] Ported list of SAVE_XMLTESTS to CMake configuration of
- XMLTester (#317) All tests pass on Ubuntu 9.10
-2010-02-05 21:24 Mateusz Loskot <mateusz at loskot.net>
- * [r2905] Fixed CMake version comparison to disable platform.h
- (#317)
-2010-02-05 14:54 Sandro Santilli <strk at keybit.net>
- * [r2904] Document ownership of created types
-2010-02-05 14:39 Sandro Santilli <strk at keybit.net>
- * [r2903] New CAPI interface: GEOSisValidDetail ( tell state,
- reason & location apart )
-2010-02-04 23:35 Mateusz Loskot <mateusz at loskot.net>
- * [r2902] Fixed missing substitution of @libdir@ in geos-config
- generated by CMake #(317)
-2010-02-02 18:14 Mateusz Loskot <mateusz at loskot.net>
- * [r2901] Fixed problem with use of new command with file() macro
- for older CMake versions (#327)
-2010-01-31 03:06 Mateusz Loskot <mateusz at loskot.net>
- * [r2900] Added XMLTester to CTest configuration - work in progress
- (#317)
-2010-01-31 03:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2899] Added GEOS_ENABLE_FLOATSTORE option to CMake to control
- GCC flag -ffloat-store (#317)
-2010-01-31 01:26 Mateusz Loskot <mateusz at loskot.net>
- * [r2898] Added platform.h.disabled to svn:ignore property
-2010-01-31 01:22 Mateusz Loskot <mateusz at loskot.net>
- * [r2897] A minor fix to order of enable_testing() and
- add_subdirectories(tests) - it is important to include the former
- macro first so the tests are caught in
-2010-01-30 23:45 Mateusz Loskot <mateusz at loskot.net>
- * [r2896] Updated configuration of GEOS_ENABLE_TESTS option for
- CMake (#317)
-2010-01-30 22:48 Mateusz Loskot <mateusz at loskot.net>
- * [r2895] Configured 'make check' target for CMake as alias to
- 'make test' to mimic GNU Autotools manner of running tests (#317)
-2010-01-29 20:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2894] Extend support of Apple ISNAN case to newer? compilers
-2010-01-29 17:42 Mateusz Loskot <mateusz at loskot.net>
- * [r2893] Solved problem with repeated definition of
- getMachineByteOrder (#317). Added check if alternative platform.h
- is already present in the include/geos directory and deactivate
- it renaming to platform.h.disable, before generating
- CMake-specific platform.h. Tested on Windows with Visual C++ but
- with -DGEOS_ENABLE_INLINE=OFF otherwise DLL linking fails with
- many redefined symbols - to be checked.
-2010-01-29 01:43 Mateusz Loskot <mateusz at loskot.net>
- * [r2892] Configured 'make test' target for CMake build (#317). Now
- only geos_unit is executed
-2010-01-28 18:42 Mateusz Loskot <mateusz at loskot.net>
- * [r2891] Missing includes of platform.h and <cmath>
-2010-01-27 22:25 Mateusz Loskot <mateusz at loskot.net>
- * [r2890] Tidy up messy code in tests/unit/linearref
-2010-01-27 22:09 Mateusz Loskot <mateusz at loskot.net>
- * [r2889] Fixed CMake configuration for the problem about
- unavailable C99 features if -std=c99 is not specified for GCC
- 4.3.3 on Ubuntu 9.04. This is inconsistent behaviour with GCC
- 4.4.1
- (https://bugs.launchpad.net/ubuntu/+source/gcc-4.3/+bug/512741).
-2010-01-23 02:43 Mateusz Loskot <mateusz at loskot.net>
- * [r2888] GEOS C++ static library was missing from installation
- targets (#317)
-2010-01-23 02:36 Mateusz Loskot <mateusz at loskot.net>
- * [r2887] CMake configuration update (#317): * Configured shared
- library target for C++ API. * Added library version information
- and TODO comment about SOVERSION.
-2010-01-23 01:38 Mateusz Loskot <mateusz at loskot.net>
- * [r2886] Small fix to latest commit (#317)
-2010-01-23 01:32 Mateusz Loskot <mateusz at loskot.net>
- * [r2885] Disabled GEOS_ENABLE_ASSERT option for Visual Studio
- builds - not supported, no sense (#317)
-2010-01-23 00:10 Mateusz Loskot <mateusz at loskot.net>
- * [r2884] Tweaked detection isfinite and isnan declared as
- functions in C++ (#317)
-2010-01-22 23:52 Mateusz Loskot <mateusz at loskot.net>
- * [r2883] Added CheckPrototypeExists.cmake module - imported from
- KDE/kdelibs tree
-2010-01-22 23:51 Mateusz Loskot <mateusz at loskot.net>
- * [r2882] Added trunk/cmake directory for custom CMake modules
-2010-01-21 01:23 Mateusz Loskot <mateusz at loskot.net>
- * [r2881] CMake configuration update (#317): * Set default
- CMAKE_BUILD_TYPE to Debug * Added GEOS_ENABLE_ASSERT and
- GEOS_ENABLE_INLINE options. * Renamed option ENABLE_MSVC_MP to
- GEOS_MSVC_ENABLE_MP.
-2010-01-20 23:42 Mateusz Loskot <mateusz at loskot.net>
- * [r2880] Fix for addd extra test for STL classes in std namespace
- to CMake configuration (#317)
-2010-01-20 23:37 Mateusz Loskot <mateusz at loskot.net>
- * [r2879] Addd extra test for STL classes in std namespace to CMake
- configuration (#317)
-2010-01-20 23:21 Mateusz Loskot <mateusz at loskot.net>
- * [r2878] Updated svn:keyword with Id for CMake files
-2010-01-20 22:17 Mateusz Loskot <mateusz at loskot.net>
- * [r2877] Fixed bug with not setting proper permissions to
- geos-config while installing with CMake build configuration
- (#318).
-2010-01-19 00:19 Mateusz Loskot <mateusz at loskot.net>
- * [r2876] #317: compiler flags can not be handled using CMake list
- type, reverted last change that sneaked in with Visual Studio
- related commit.
-2010-01-19 00:03 Mateusz Loskot <mateusz at loskot.net>
- * [r2875] #317: Added CXX flags specific to Visual C++ compiler.
- Added ENABLE_MSVC_MP option to allow setting Visual C++ /MP flag
- that enables multi-process compilation.
-2010-01-18 21:15 Mateusz Loskot <mateusz at loskot.net>
- * [r2874] Load elements of std namespace to scope of geos_ts_c.cpp
- file, so C99 functions are loaded even if hidden in std
- (non-standard extension in GCC).
-2010-01-18 18:15 Mateusz Loskot <mateusz at loskot.net>
- * [r2873] Added missing headers platform.h and <cmath> where ISNAN
- or FINITE macros are expanded
-2010-01-18 18:14 Mateusz Loskot <mateusz at loskot.net>
- * [r2872] Updated svn:ignore patterns
-2010-01-18 18:13 Mateusz Loskot <mateusz at loskot.net>
- * [r2871] Cleaned redundant include for cmath and math.h from
- platform.h.cmake (#317)
-2010-01-18 18:12 Mateusz Loskot <mateusz at loskot.net>
- * [r2870] Updated svn:ignore patterns
-2010-01-18 01:25 Mateusz Loskot <mateusz at loskot.net>
- * [r2869] Updated Windows elements of build configuration for CMake
- system (#317):
- * Added missing symbol GEOS_DLL_EXPORT to request generation of
- import library for GEOS C API DLL
- * All targets configured for CMake build system have been
- successfully built and tested using CMake.
- * CMake-based install target successfully tested on Windows 7
- ** Default prefix for 32-bit build is "c:\Program Files
- (x86)\geos\" where bin, lib and include directories are created.
-2010-01-18 00:59 Mateusz Loskot <mateusz at loskot.net>
- * [r2868] * Successfully tested CMake configuration with Visual
- Studio 2010 (#317).
- * Disable argument dependant lookup (Koenig) for min/max
- min/max macros.
- * Some platform headers define min() and max() macros which cause
- some common C++ constructs to fail to compile.
-2010-01-17 23:54 Mateusz Loskot <mateusz at loskot.net>
- * [r2867] Configured 'make install' for tools to install
- geos-config program on Unix platforms (#317). Fixed missing
- prefix nad exec_prefix variables substitution during geos-config
- generation.
-2010-01-17 23:40 Mateusz Loskot <mateusz at loskot.net>
- * [r2866] Configured 'make install' target for GEOS C shared
- library and headers (#317). Install platform.h and version.h from
- build directory where they are installed, not from source tree.
- Added GEOS C API header location to include directories.
-2010-01-17 23:06 Mateusz Loskot <mateusz at loskot.net>
- * [r2865] Configured 'make install' target for GEOS C++ static
- library archive and headers (#317)
-2010-01-17 03:21 Mateusz Loskot <mateusz at loskot.net>
- * [r2864] Removed build/bjam directory with old and no longer
- maintained build configuration based on Boost.Build
-2010-01-17 03:12 Mateusz Loskot <mateusz at loskot.net>
- * [r2863] Added simplewkttester and xmltester tests to CMake
-2010-01-17 03:00 Mateusz Loskot <mateusz at loskot.net>
- * [r2862] Updated CMake configuration (#317): CMake generates
- config headers in build tree. Added generation of geos-config
- script. Refined include directories settings. Added unit tests
- package to the configuration. Status: GEOS core + GEOS C library
- + unit tests build and run successfully.
-2010-01-17 02:07 Mateusz Loskot <mateusz at loskot.net>
- * [r2861] Now CMake can generates geos_c.h (#317). Removed
- include/geos/version.h.cmake as no longer needed - CMake can
- subsitute variables of Autoconf-style @VAR@ very well.
-2010-01-17 00:46 Mateusz Loskot <mateusz at loskot.net>
- * [r2860] Refined detection of isnan and isfinite features (#317)
-2010-01-16 22:20 Mateusz Loskot <mateusz at loskot.net>
- * [r2859] Added checks of C/C++ headers and library features like
- 64-bit integer type (#317)
-2010-01-16 21:45 Mateusz Loskot <mateusz at loskot.net>
- * [r2858] Added generation of build-specific platform.h file from
-2010-01-16 21:25 Mateusz Loskot <mateusz at loskot.net>
- * [r2857] Set version numbers and generate version.h for CMake
- build (#317)
-2010-01-16 20:41 Mateusz Loskot <mateusz at loskot.net>
- * [r2856] Added platform.h.cmake file used by build configuration
- for CMake build system (#317)
-2010-01-16 20:40 Mateusz Loskot <mateusz at loskot.net>
- * [r2855] Removed definition of INT64_CONST_IS_I64 - it is not
- checked or used anywhere
-2010-01-16 20:12 Mateusz Loskot <mateusz at loskot.net>
- * [r2854] Unified detection of math features to define FINITE and
- ISNAN macros
-2010-01-16 18:14 Mateusz Loskot <mateusz at loskot.net>
- * [r2853] Moved getMachineByteOrder from include/geos/platform.h to
- include/geos/util/Machine.h. This function is universal for
- non-Windows and Windows platforms
-2010-01-16 17:03 Mateusz Loskot <mateusz at loskot.net>
- * [r2852] Added first straps of configuration for CMake build
- system (#317)
-2010-01-16 02:40 Mateusz Loskot <mateusz at loskot.net>
- * [r2851] Removed tests/geostest/.deps directory
-2010-01-16 02:14 Mateusz Loskot <mateusz at loskot.net>
- * [r2850] Moved src/examples out of src directory (#315)
-2010-01-14 00:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2849] Updated Visual Studio 2010 projects in build/msvc10 with
- new location of include and src (#315)
-2010-01-13 21:35 Mateusz Loskot <mateusz at loskot.net>
- * [r2848] * Successfully compiled with Visual C++ 8.0 after
- restructuring source tree.
- ** NodedSegmentString class;
- ** Use explicit self-describing two-step casts to indicate what's
- really happening - C-cast is evil and hides serious interface
- issues.
- ** Added missing <cstddef> and qualify size_t with std namespace.
-2010-01-13 21:25 Mateusz Loskot <mateusz at loskot.net>
- * [r2847] Updated Visual Studio 2005 projects in build/msvc80 with
-2010-01-13 18:07 Mateusz Loskot <mateusz at loskot.net>
- * [r2846] Updated Visual Studio 2008 projects in build/msvc90 with
-2010-01-13 17:54 Mateusz Loskot <mateusz at loskot.net>
- * [r2845] Updated makefile.vc, nmake.opt, src/makefile.vc files
- with new location of include and src (#315)
-2010-01-13 03:03 Mateusz Loskot <mateusz at loskot.net>
- * [r2844] Updated remaining directories doc, macros, tools, tests,
- swig, capi with new src and include location (#315). Fixed
- previous updates. Successfull build on Linux.
-2010-01-13 02:08 Mateusz Loskot <mateusz at loskot.net>
- * [r2843] Updated Makefile.am files in capi subtree after moved to
- new location (#315)
-2010-01-13 02:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2842] Updated Makefile.am files in src subtree after moved to
-2010-01-13 00:48 Mateusz Loskot <mateusz at loskot.net>
- * [r2841] Updated new source structure in configure.in and root
- Makefile.am - part 2 (#315)
-2010-01-13 00:45 Mateusz Loskot <mateusz at loskot.net>
- * [r2840] Updated new source structure in configure.in and root
- Makefile.am (#315)
-2010-01-13 00:43 Mateusz Loskot <mateusz at loskot.net>
- * [r2839] Updated Makefile.am files in headers subtree after moved
- to new location in include (#315)
-2010-01-12 23:58 Mateusz Loskot <mateusz at loskot.net>
- * [r2838] Moved source directory to src (#315)
-2010-01-12 23:55 Mateusz Loskot <mateusz at loskot.net>
- * [r2837] Moved source/headers directory to include (#315)
-2009-12-23 12:37 Mateusz Loskot <mateusz at loskot.net>
- * [r2835] Removed GNU specific printf formatter
-2009-12-22 11:38 Mateusz Loskot <mateusz at loskot.net>
- * [r2834] Fixed compiler warning about extra tokens at end of
- #endif directive in export.h
-2009-12-15 17:29 Mateusz Loskot <mateusz at loskot.net>
- * [r2833] Fixed missing CoordinateSequenceFactory.cpp from
- makefile.vc (Ticket #313)
-2009-12-15 14:44 Mateusz Loskot <mateusz at loskot.net>
- * [r2832] * Assert precision model scale must never be negative
- * Replaced use of operator== against float-point number with
- operator<=
- * Typos
-2009-12-15 14:38 Mateusz Loskot <mateusz at loskot.net>
- * [r2831] In WKTWriter, initialise formatting buffer and avoid
- unnecessary calls to string constructor.
-2009-12-14 19:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2828] Update version numbers on trunk to 3.3 series
-2009-12-14 19:06 Sandro Santilli <strk at keybit.net>
- * [r2826] Updated
-2009-12-14 18:58 Sandro Santilli <strk at keybit.net>
- * [r2825] Don't mention 'troubles' in documentation (some like it
- not)
-2009-12-14 15:23 Mateusz Loskot <mateusz at loskot.net>
- * [r2824] * Fixed bug in WKTWriter that was dropping geometry tag
- in string representation of geometry
- * Improved message carried by TopologyException
-2009-12-11 13:17 Sandro Santilli <strk at keybit.net>
- * [r2823] Updated
-2009-12-11 13:10 Sandro Santilli <strk at keybit.net>
- * [r2822] Fix memory leak in
- BasicPreparedGeometry::isAnyTargetComponentInTest (issue #308)
- and drop Coordinate copies from it.
-2009-12-09 11:10 Mateusz Loskot <mateusz at loskot.net>
- * [r2821] Fixed generation of platform.h as pre-build step of GEOS
- lib project for Visual C++
-2009-12-09 11:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2820] * Fixed generation of platform.h as pre-build step of
- GEOS lib project for Visual C++ 2005 and 2008
- * Added missing headers.
-2009-12-08 22:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2817] Prepare for RC4 release.
-2009-12-08 21:40 Mateusz Loskot <mateusz at loskot.net>
- * [r2816] Updated svn:ignore patterns
-2009-12-08 21:39 Mateusz Loskot <mateusz at loskot.net>
- * [r2815] build/msvc10: fixed list of EXTRA_DIST files
-2009-12-08 17:51 Sandro Santilli <strk at keybit.net>
- * [r2814] This shouldn't be in the repository !
-2009-12-08 17:50 Sandro Santilli <strk at keybit.net>
- * [r2813] Remove deprecated/unused files
-2009-12-08 17:42 Sandro Santilli <strk at keybit.net>
- * [r2812] Drop useless (and leaking) heap allocation exposed by the
- new prepared linestring intersection test
- * [r2811] Add missing destructor of PreparedLineString (closes
- ticket #305)
-2009-12-08 17:39 Sandro Santilli <strk at keybit.net>
- * [r2810] Add test with Prepared linestrings, for the sake of
- testing the leak reported in ticket #305
-2009-12-06 01:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2809] Updated source code files with svn:keywords property.
-2009-12-06 01:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2808] Updated svn:ignore patterns
-2009-12-06 00:56 Mateusz Loskot <mateusz at loskot.net>
- * [r2807] Updated svn:ignore patterns
-2009-12-06 00:51 Mateusz Loskot <mateusz at loskot.net>
- * [r2806] Updated configure.in after moved non-unit tests programs
- out of tests/unit (Tickets #240).
-2009-12-06 00:47 Mateusz Loskot <mateusz at loskot.net>
- * [r2805] Moved non-unit tests programs out of tests/unit: geostest
- -> tests/geostest, threadtest -> tests/thread, badthreadtest ->
- tests/thread (Ticket #240).
-2009-12-05 21:59 Mateusz Loskot <mateusz at loskot.net>
- * [r2804] Added build/msvc80/geos_xmltester to configure.in
-2009-12-05 21:28 Mateusz Loskot <mateusz at loskot.net>
- * [r2803] Added geos_xmltester.vcproj project to build/msvc80
-2009-12-05 21:20 Mateusz Loskot <mateusz at loskot.net>
- * [r2802] Added GEOS_DLL_EXPORT to preprocessor definitions in
- build/msvc80/geos_c_dll/geos_c_dll.vcproj
-2009-12-05 20:30 Mateusz Loskot <mateusz at loskot.net>
- * [r2801] small cleanup
-2009-12-05 20:23 Mateusz Loskot <mateusz at loskot.net>
- * [r2800] Updated solution for Visual C++ 8.0 (Visual Studio 2005)
- (Ticket #303)
-2009-12-05 20:21 Mateusz Loskot <mateusz at loskot.net>
- * [r2799] Updated information in README about build/msvcXY
- solutions
-2009-12-04 17:38 Mateusz Loskot <mateusz at loskot.net>
- * [r2798] Updated configure.in with msvc10
-2009-12-04 17:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2797] Added solution and projects for Visual Studio 2010 (note
- msvc90 denotes 9.0 however msvc10 is 10 not 1.0)
-2009-12-04 15:58 Mateusz Loskot <mateusz at loskot.net>
- * [r2796] Missing svn keywords
-2009-12-04 15:30 Mateusz Loskot <mateusz at loskot.net>
- * [r2795] Small fixes to TUT.
-2009-12-04 15:20 Mateusz Loskot <mateusz at loskot.net>
- * [r2794] Replaced long with std::streampos
-2009-12-04 15:07 Mateusz Loskot <mateusz at loskot.net>
- * [r2793] std::back_inserter requires <iterator> in
- geom/CoordinateSequence.cpp
-2009-12-04 13:57 Mateusz Loskot <mateusz at loskot.net>
- * [r2792] Updated Visual C++ 9.0 project
-2009-12-03 22:51 Mateusz Loskot <mateusz at loskot.net>
- * [r2791] Yet another try to fix EOL in geos/export.h
-2009-12-03 20:29 Mateusz Loskot <mateusz at loskot.net>
- * [r2790] Removed mysterious extra tokens (blanks) from
- geos/export.h
-2009-12-03 20:16 Mateusz Loskot <mateusz at loskot.net>
- * [r2789] Removed mysterious extra tokens (blanks) from
- geos/export.h
-2009-12-03 20:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2788] Updated Visual C++ project geos_unit.vcproj
-2009-12-03 19:59 Mateusz Loskot <mateusz at loskot.net>
- * [r2787] Part 26 of larger changeset - source/headers:
- * Refine FINITE macro - pseudo-POSIX layer in Visual C++ does not
- offer long double version of finite()
- * Tidy up.
-2009-12-03 19:57 Mateusz Loskot <mateusz at loskot.net>
- * [r2786] Part 25 of larger changeset - source/headers/geos/util:
- * Declare noncopyable types as such explicitly (Ticket #304).
- * Tidy up.
-2009-12-03 19:55 Mateusz Loskot <mateusz at loskot.net>
- * [r2785] Part 24 of larger changeset -
- source/headers/geos/simplify:
- * Tidy up.
-2009-12-03 19:52 Mateusz Loskot <mateusz at loskot.net>
- * [r2784] Part 23 of larger changeset -
- source/headers/geos/planargraph
- * Tidy up.
-2009-12-03 19:51 Mateusz Loskot <mateusz at loskot.net>
- * [r2783] Part 22 of larger changeset -
- source/headers/geos/planargraph/algorithm:
- * Tidy up.
-2009-12-03 19:50 Mateusz Loskot <mateusz at loskot.net>
- * [r2782] Part 21 of larger changeset -
- source/headers/geos/operation/valid:
- * Tidy up.
-2009-12-03 19:48 Mateusz Loskot <mateusz at loskot.net>
- * [r2781] Part 20 of larger changeset -
- source/headers/geos/operation/overlay:
- * Unified EOL and style.
- * Tidy up.
-2009-12-03 19:46 Mateusz Loskot <mateusz at loskot.net>
- * [r2780] Part 19 of larger changeset -
- * Tidy up.
-2009-12-03 19:45 Mateusz Loskot <mateusz at loskot.net>
- * [r2779] Part 18of larger changeset -
- source/headers/geos/operation/buffer:
- * Tidy up.
-2009-12-03 19:44 Mateusz Loskot <mateusz at loskot.net>
- * [r2778] Part 17 of larger changeset -
- source/headers/geos/noding/snapround:
- * Added Visual C++ pragmas.
- * Tidy up.
-2009-12-03 19:41 Mateusz Loskot <mateusz at loskot.net>
- * [r2777] Part 16 of larger changeset -
- * Tidy up.
-2009-12-03 19:39 Mateusz Loskot <mateusz at loskot.net>
- * [r2776] Part 15 of larger changeset -
- source/headers/geos/linearref:
- * Tidy up.
-2009-12-03 19:38 Mateusz Loskot <mateusz at loskot.net>
- * [r2775] Part 14 of larger changeset - source/headers/geos/io:
- * Tidy up.
-2009-12-03 19:36 Mateusz Loskot <mateusz at loskot.net>
- * [r2774] Part 13 of larger changeset -
- source/headers/geos/index/chain:
- * Tidy up.
- * [r2773] Part 12 of larger changeset -
- source/headers/geos/geomgraph:
- * Tidy up.
-2009-12-03 19:30 Mateusz Loskot <mateusz at loskot.net>
- * [r2772] Part 11 of larger changeset -
- source/headers/geos/geom/util:
- * Tidy up.
-2009-12-03 19:29 Mateusz Loskot <mateusz at loskot.net>
- * [r2771] Part 10of larger changeset -
- source/headers/geos/geom/prep:
- * Tidy up.
-2009-12-03 19:27 Mateusz Loskot <mateusz at loskot.net>
- * [r2770] Part 9 of larger changeset -
- source/headers/geos/algorithm:
- * Tidy up.
-2009-12-03 19:24 Mateusz Loskot <mateusz at loskot.net>
- * [r2769] Part 7 of larger changeset - source/geomgraph:
- * Fixed incorrect int to string conversion.
-2009-12-03 19:23 Mateusz Loskot <mateusz at loskot.net>
- * [r2768] Part 7 of larger changeset - source/index/intervalrtree:
- * Tidy up.
-2009-12-03 19:22 Mateusz Loskot <mateusz at loskot.net>
- * [r2767] Refined changeset r2766 - fix for nested classes required
- by GCC.
-2009-12-03 19:14 Mateusz Loskot <mateusz at loskot.net>
- * [r2766] Part 6 of larger changeset - source/noding:
- * Tidy up.
-2009-12-03 19:11 Mateusz Loskot <mateusz at loskot.net>
- * [r2765] Part 5 of larger changeset - source/noding/snapround:
- * Tidy up.
-2009-12-03 19:03 Mateusz Loskot <mateusz at loskot.net>
- * [r2764] Part 4 of larger changeset - source/algorithm:
- * Tidy up.
-2009-12-03 19:02 Mateusz Loskot <mateusz at loskot.net>
- * [r2763] Part 3 of larger changeset - source/operation:
- * Tidy up.
-2009-12-03 19:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2762] Part 2 of larger changeset - source/simplify:
- * Cleanup.
- * Unified EOL to LF.
-2009-12-03 18:56 Mateusz Loskot <mateusz at loskot.net>
- * [r2761] Part 1 of larger changeset - tests/unit:
- * Cleanup.
-2009-12-03 14:48 Mateusz Loskot <mateusz at loskot.net>
- * [r2760] * Added Visual C++ pragmas.
- * Fixed implicit pointer tests for 0 (save typing is a myth, be
- explicit is bless).
-2009-12-03 13:25 Mateusz Loskot <mateusz at loskot.net>
- * [r2759] Updated C++ TUT framework.
-2009-12-01 16:16 Mateusz Loskot <mateusz at loskot.net>
- * [r2758] Improved WKBReader::readHEX to read WKB encoded with
- lower-case hex digits, useful if combined with SQL
- encode(geometry, 'hex')
-2009-12-01 15:39 Mateusz Loskot <mateusz at loskot.net>
- * [r2757] * More fixes for incompleteness of types required by
- std::auto_ptr
- * Replaced utility macros with disappearing ignorance template
- trick.
-2009-12-01 13:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2756] Tweaked projects for Visual Studio 2008
-2009-11-30 17:29 Mateusz Loskot <mateusz at loskot.net>
- * [r2755] * GEOSFree_r should check context handle even if its not
- used - nullptr may indicate logic error.
-2009-11-30 13:55 Mateusz Loskot <mateusz at loskot.net>
- * [r2754] * Fixed incomplete types Geometry and
- TaggedLinesSimplifier in TopologyPreservingSimplifier.h -
- required by std::auto_ptr
- * Removed unreachable code.
- * Removed /Wp64 option from Visual Studio 2008 projects.
-2009-11-30 12:25 Mateusz Loskot <mateusz at loskot.net>
- * [r2753] Missing log.
-2009-11-30 10:48 Mateusz Loskot <mateusz at loskot.net>
- * [r2752] * Added missing tests to Visual Studio 2008 project
- * Replaced call to isnan() missing in Visual C++ with ISNAN macro
-2009-11-29 10:09 Sandro Santilli <strk at keybit.net>
- * [r2749] updated
-2009-11-26 21:42 Sandro Santilli <strk at keybit.net>
- * [r2748] Add ISNAN support in platform.h.in
-2009-11-26 21:34 Sandro Santilli <strk at keybit.net>
- * [r2747] Remove unreferenced files from the repository
-2009-11-26 21:28 Sandro Santilli <strk at keybit.net>
- * [r2746] Remove reference to files not needing to go in the dll
-2009-11-26 21:21 Sandro Santilli <strk at keybit.net>
- * [r2745] Put destructor of the CoordinateSequenceFactory in an
- implementation file, hopefully reducing linker confusion about
- RTTI (see ticket #299)
-2009-11-26 19:49 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2744] Add magic flags for OS/X Snow Leopard only. (#299)
-2009-11-26 19:46 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2743] Add vc90 xmltester target to Makefile build
-2009-11-26 18:29 Frank Warmerdam <warmerdam at pobox.com>
- * [r2742] clarify ownership of returned buffer from wkbwriter
-2009-11-26 16:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2741] Fix missing components in tarball (#300)
-2009-11-24 18:05 Sandro Santilli <strk at keybit.net>
- * [r2736] updated
-2009-11-23 18:17 Sandro Santilli <strk at keybit.net>
- * [r2735] Coordiante->Coordinate
-2009-11-23 18:06 Sandro Santilli <strk at keybit.net>
- * [r2734] Avoid reallocations in Union short-circuit
-2009-11-20 19:58 Sandro Santilli <strk at keybit.net>
- * [r2733] Don't force heap allocation of vectors for getting nodes
- of a NodeMap
-2009-11-19 21:30 Sandro Santilli <strk at keybit.net>
- * [r2732] Don't heap-allocate std::vector in
- MCIndexSegmentSetMutualIntersector
-2009-11-19 21:06 Sandro Santilli <strk at keybit.net>
- * [r2731] Don't force heap allocation when building edge rings for
- isValidOp
-2009-11-19 20:29 Sandro Santilli <strk at keybit.net>
- * [r2730] Don't force heap allocation of std::vector in
- PolygonizeGraph when deleting dangles (moved allocation higher,
- in Polygonizer, so needs a second pass)
-2009-11-19 20:20 Sandro Santilli <strk at keybit.net>
- * [r2729] don't heap-allocate vectors in findLabeledEdgeRings
-2009-11-19 19:57 Sandro Santilli <strk at keybit.net>
- * [r2728] Move heap-allocation of vector used for 'cut-lines'
- containment out of PolygonizeGraph (but into Polygonizer)
-2009-11-19 19:31 Sandro Santilli <strk at keybit.net>
- * [r2727] Don't force heap-allocation of vectors for
- finding/labeling edge rings
-2009-11-19 19:19 Sandro Santilli <strk at keybit.net>
- * [r2726] Change PolygonizeGraph::getEdgeRings signature so not to
- force heap allocation of std::vector, update Polygonizer
- accordingly
-2009-11-19 19:06 Sandro Santilli <strk at keybit.net>
- * [r2725] Do not heap-allocate vector of Node when finding
- intersections
-2009-11-19 18:52 Sandro Santilli <strk at keybit.net>
- * [r2724] Don not allocate the container of STRtree node childs on
- the heap
-2009-11-19 16:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2723] Apply patch for --disable-cassert compilation (#291)
-2009-11-18 18:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2720] Reverse the upgrade process a bit, bump up revision
- numbers *after* release so that the repo version is always one
- higher than the release version. (#287)
-2009-11-18 01:28 Mateusz Loskot <mateusz at loskot.net>
- * [r2717] Silent warning thrown by Visual C++ about mixed class and
- struct keyword (#269)
-2009-11-17 20:29 Sandro Santilli <strk at keybit.net>
- * [r2716] Include capi::GEOSGeomFromWKB test in geos_unit build
- (should also distribute as side-effect)
-2009-11-11 23:05 Sandro Santilli <strk at keybit.net>
- * [r2713] Change ChangeLog generation rule so it doesn't mess with
- make dist. Reflect in HOW_TO_RELEASE
-2009-11-10 23:54 Sandro Santilli <strk at keybit.net>
- * [r2712] Make ChangeLog target non-phony to keep 'distcheck'
- happy. Reorganize HOW_TO_RELEASE steps.
-2009-11-10 22:58 Sandro Santilli <strk at keybit.net>
- * [r2711] Package stuff for release
-2009-10-29 21:06 Mateusz Loskot <mateusz at loskot.net>
- * [r2710] Testing linker problem with DEFAULT_QUADRANT_SEGMENT
- constant
-2009-10-29 20:58 Mateusz Loskot <mateusz at loskot.net>
- * [r2709] Testing linker problem with DEFAULT_QUADRANT_SEGMENT
- constant
-2009-10-29 20:55 Mateusz Loskot <mateusz at loskot.net>
- * [r2708] Fixed CRLF to LF in BufferOpTest.cpp
-2009-10-29 20:47 Mateusz Loskot <mateusz at loskot.net>
- * [r2707] Missing include of BufferParameters.h header in
- BufferOpTest.cpp unit suite
-2009-10-29 16:20 Mateusz Loskot <mateusz at loskot.net>
- * [r2706] Added more test cases for buffer calculation based on A
- (input) geometries from XMLTester's buffer.xml and
- TestBufferExternal2.xml tests.
-2009-10-29 15:11 Mateusz Loskot <mateusz at loskot.net>
- * [r2705] Added test case for buffer of multipolygon from
- XMLTester's buffer.xml, case #25 but with custom quadrant
- segments
-2009-10-29 14:24 Mateusz Loskot <mateusz at loskot.net>
- * [r2704] Added test case for buffer of POINT(0 0) with distance
- 1.0 and 32 quadrant segments.
-2009-10-29 12:33 Mateusz Loskot <mateusz at loskot.net>
- * [r2703] * tests/unit/operation/buffer: added unit test case for
- BufferOp,
- * tests/unit/Makefile.am: added new test case source to Makefile,
- * build/msvc90/geos_unit/geos_unit.vcproj: updated Visual C++
- project.
-2009-10-28 12:09 Mateusz Loskot <mateusz at loskot.net>
- * [r2702] tests/xmltester/XMLTester.cpp: declare checkBufferSuccess
- function to take geometries by refernece to const
-2009-10-25 18:48 Mateusz Loskot <mateusz at loskot.net>
- * [r2701] Fixed typo in getCentroid function comment in Geometry.h.
-2009-10-23 13:04 Sandro Santilli <strk at keybit.net>
- * [r2700] Have LinearLocation::getSegment return by auto_ptr to
- encode ownership transfer. Fixes leak reported in #296.
-2009-10-23 12:58 Sandro Santilli <strk at keybit.net>
- * [r2699] Fix port info, add standard protection notes
-2009-10-23 10:21 Sandro Santilli <strk at keybit.net>
- * [r2698] Add destructor to LinearGeometryBuilder fixing memory
- leaks there.
-2009-10-23 10:13 Sandro Santilli <strk at keybit.net>
- * [r2697] Fix memory access error (#283)
-2009-10-23 10:03 Sandro Santilli <strk at keybit.net>
- * [r2696] Fix port info for LinearGeometryBuilder
-2009-10-23 09:53 Sandro Santilli <strk at keybit.net>
- * [r2695] Cleanup LinearGeometrybuilder defs and impl to match
- common code style, add note about suspicious things (not written
- but noted that the class seems to lack a destructor..)
-2009-10-23 09:43 Sandro Santilli <strk at keybit.net>
- * [r2694] Document ownership of return from
- LocationIndexOfLine::indicesOf, fix mismatch delete/delete[] in
- core and unit test
-2009-10-23 09:34 Sandro Santilli <strk at keybit.net>
- * [r2693] Add virtual dtor to virtual class
-2009-10-23 09:33 Sandro Santilli <strk at keybit.net>
- * [r2692] add some parens to hush gcc warning
-2009-10-23 09:00 Sandro Santilli <strk at keybit.net>
- * [r2691] Fix static building of C-api demo/tests
-2009-10-23 08:34 Sandro Santilli <strk at keybit.net>
- * [r2690] Run the last available-but-no-automatically-run test:
- test.xml
-2009-10-22 18:18 Sandro Santilli <strk at keybit.net>
- * [r2689] Merge buffer_snapround.xml into buffer.xml
-2009-10-22 17:13 Sandro Santilli <strk at keybit.net>
- * [r2688] A quick check reveals that the tests in buffer.xml are
- not really duplicated elsewhere so we run that test too now as
- part of make check
-2009-10-22 17:07 Sandro Santilli <strk at keybit.net>
- * [r2687] Give buffer.xml cases a somewhat more helpful
- description, fix 4 expected results after eye-checking. This is
- still not automatically run case it might contain duplicated
- tests from elsewhere (to be checked).
-2009-10-22 16:30 Sandro Santilli <strk at keybit.net>
- * [r2686] Don't segfault on EOF inside <op> tag
-2009-10-20 16:59 Sandro Santilli <strk at keybit.net>
- * [r2685] Commit MingW bug workaround provided by sanak in ticket
- #293
-2009-10-19 13:38 Mateusz Loskot <mateusz at loskot.net>
- * [r2684] tests/xmltester/tests/buffer_snapround.xml: not
- well-formed XML, fixed missing attribute.
-2009-10-17 14:47 Sandro Santilli <strk at keybit.net>
- * [r2683] updated
-2009-10-17 14:43 Sandro Santilli <strk at keybit.net>
- * [r2682] updated
-2009-10-17 14:35 Sandro Santilli <strk at keybit.net>
- * [r2681] Half the calls to the virtual CoordinateSequence::getAt
- when computing line distances
-2009-10-17 13:40 Sandro Santilli <strk at keybit.net>
- * [r2680] Drop pointless asserts. We'd abort anyway if vector is
- null. For the out-of-range case the GNU c++ lib helps debugging
- with an environment variable
-2009-10-17 13:04 Sandro Santilli <strk at keybit.net>
- * [r2679] Add note of private/static nature of implemented methods
-2009-10-17 12:28 Sandro Santilli <strk at keybit.net>
- * [r2678] Expose a usable toVector method for CoordinateSequence
- (ie: no memory management issues). Use it from
- Polygon::getCoordinates.
-2009-10-17 12:02 Sandro Santilli <strk at keybit.net>
- * [r2677] Don't allocate too much space for polygon points vector.
- Fixes bug #294.
-2009-10-16 15:27 Mateusz Loskot <mateusz at loskot.net>
- * [r2676] xmltester/tests: missing double quotes around XML
- attribute value in fme.xml.
-2009-10-14 20:42 Sandro Santilli <strk at keybit.net>
- * [r2675] regenerate ChangeLog
-2009-10-14 15:32 Mateusz Loskot <mateusz at loskot.net>
- * [r2674] * Optional use of GEOS_DEBUG_MSVC_USE_VLD in
- XMLTester.cpp
- * Added xmltester/makefile.vc as port of testrunner.sh for
- Windows to be able to run all tests in batch:
- ** nmake /f makefile.vc XMLTESTER=C:\path\to\xmltester.exe
-2009-10-14 12:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2673] Added msvc90/geos_xmltester to solution for Visual Studio
- 2008.
-2009-10-14 12:03 Mateusz Loskot <mateusz at loskot.net>
- * [r2672] Enable use of Stalkwalker only if building with Visual
- C++ and GEOS_TEST_USE_STACKWALKER is defined.
-2009-10-13 16:25 Mateusz Loskot <mateusz at loskot.net>
- * [r2671] build/msvc90: added missing sources of linearref package.
- Builds with Visual C++ 9.0 (using both project and makefiles).
-2009-10-13 14:20 Frank Warmerdam <warmerdam at pobox.com>
- * [r2670] fix nmake dll export, and link test programs (#288)
-2009-10-08 12:51 Frank Warmerdam <warmerdam at pobox.com>
- * [r2669] add new directories and source (#288)
-2009-10-08 08:56 Sandro Santilli <strk at keybit.net>
- * [r2668] regenerate ChangeLog now that we have all names in
-2009-10-08 08:47 Sandro Santilli <strk at keybit.net>
- * [r2667] Add other missing names/addresses
-2009-10-08 08:40 Sandro Santilli <strk at keybit.net>
- * [r2666] Automatically generate the ChangeLog file, forget
- ChangeLog.svn.
-2009-10-08 08:38 Sandro Santilli <strk at keybit.net>
- * [r2665] Don't signal topology exception when it triggers snapping
-2009-10-08 08:37 Sandro Santilli <strk at keybit.net>
- * [r2664] Add yury, fernando and sean
-2009-10-08 08:17 Sandro Santilli <strk at keybit.net>
- * [r2663] Distribute all of TUT
-2009-10-08 07:56 Sandro Santilli <strk at keybit.net>
- * [r2662] Properly set version for win target
-2009-10-07 07:53 Sandro Santilli <strk at keybit.net>
- * [r2661] Expose single-sided buffering in C-API (see ticket #258)
-2009-10-05 21:36 Sandro Santilli <strk at keybit.net>
- * [r2659] Drop use of static data in DistanceToPoint class (for
- thread-safety)
-2009-10-05 19:29 Sandro Santilli <strk at keybit.net>
- * [r2658] release memory earlier, and closer to allocation
-2009-10-05 19:04 Sandro Santilli <strk at keybit.net>
- * [r2657] Finish plugging leaks. Make check runs with no leaks.
-2009-10-05 18:42 Sandro Santilli <strk at keybit.net>
- * [r2656] another memory management doc
-2009-10-05 18:40 Sandro Santilli <strk at keybit.net>
- * [r2655] Document more memory management issues
-2009-10-05 17:20 Sandro Santilli <strk at keybit.net>
- * [r2654] More memory leak fixes in single-sided buffering
- implementation
-2009-10-05 16:58 Sandro Santilli <strk at keybit.net>
- * [r2653] Plug some memory leaks in single sided buffering
- implementation
-2009-10-05 16:44 Sandro Santilli <strk at keybit.net>
- * [r2652] Document ownership of return from
- LineMerger::getMergedLineStrings
-2009-10-05 16:40 Sandro Santilli <strk at keybit.net>
- * [r2651] Alright, there's no standard style yet so this file is
- made empty, but good to have for reference
-2009-10-01 10:30 Sandro Santilli <strk at keybit.net>
- * [r2650] Throw an exception rather than returning NULL if input to
- single-sided buffer code is invalid
-2009-10-01 09:10 Sandro Santilli <strk at keybit.net>
- * [r2649] Have single-sided buffer constructor return a simple
- LINESTRING when appropriate rather than forcing a MULTI; import 2
- tests from the SAFE testsuite
-2009-10-01 09:01 Sandro Santilli <strk at keybit.net>
- * [r2648] Better parse style parameter
-2009-10-01 08:46 Sandro Santilli <strk at keybit.net>
- * [r2647] Add utility script to import tests from SAFE software
-2009-10-01 08:42 Sandro Santilli <strk at keybit.net>
- * [r2646] Don't segfault on xml tests missing precision model
- specification
-2009-10-01 07:24 Sandro Santilli <strk at keybit.net>
- * [r2645] Re-enable the now succeeding test for sharp edges line
- single sided buffering
-2009-10-01 07:23 Sandro Santilli <strk at keybit.net>
- * [r2644] Use FLAT/BUTT endcaps when doing single sided buffering
-2009-10-01 07:06 Sandro Santilli <strk at keybit.net>
- * [r2643] Fix trimming of left/right curves (ie: don't include the
- endcap)
-2009-10-01 06:33 Sandro Santilli <strk at keybit.net>
- * [r2642] Use snapped intersection between full buffer boundary and
- single-sided offset curves
-2009-09-30 22:18 Sandro Santilli <strk at keybit.net>
- * [r2641] Check hausdorff distance in both directions, or an
- expected output line longer than the obtained one would be found
- as correct
-2009-09-30 20:27 Sandro Santilli <strk at keybit.net>
- * [r2640] Some debugging for single sided buffers
-2009-09-30 19:18 Sandro Santilli <strk at keybit.net>
- * [r2639] Another simple test for single-sided buffer (horizontal
- line, both directions)
-2009-09-30 19:07 Sandro Santilli <strk at keybit.net>
- * [r2638] Another simple test for a vertical line, opposite
- direction from previous
-2009-09-30 19:05 Sandro Santilli <strk at keybit.net>
- * [r2637] Add test for single sided buffer on simple, vertical,
- line (this one succeeds both left and right)
-2009-09-30 18:57 Sandro Santilli <strk at keybit.net>
- * [r2636] VIM setting for GEOS source code style (3-spaces tabs)
-2009-09-30 14:14 Sandro Santilli <strk at keybit.net>
- * [r2635] Don't use non-standard escape sequences with 'echo'
-2009-09-28 10:35 Sandro Santilli <strk at keybit.net>
- * [r2634] Replace no-commercial-use licenced MarkupSTL with tinyXML
-2009-09-28 10:34 Sandro Santilli <strk at keybit.net>
- * [r2633] Temporarly disable failing single sided buffer test
-2009-09-28 10:10 Sandro Santilli <strk at keybit.net>
- * [r2632] Oops, it seems I just don't want a test to fail ;)
-2009-09-28 10:09 Sandro Santilli <strk at keybit.net>
- * [r2631] Don't give a false success if one of the
- expected/obtained geometry is empty
-2009-09-28 09:03 Sandro Santilli <strk at keybit.net>
- * [r2630] Add offsets to PrecisionModel text output
-2009-09-28 07:02 Sandro Santilli <strk at keybit.net>
- * [r2629] Add an hausdorff distance based result matcher for
- single-sided buffer tests. Enable the single sided buffer test
- provided by swong in ticket #215 with minor tweak (expect
- multilinestring).
-2009-09-27 20:43 Sandro Santilli <strk at keybit.net>
- * [r2628] Re-introduce the singlesided buffer patch. Tests still
- need to be worked on.
-2009-09-21 19:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2626] Polygon with empty ring causes a crash in WKBReader (from
- Tamas Szekeres) (#290)
-2009-09-11 18:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2624] Patch for #285, C api for project and interpolate, from
- David Turner (novalis)
-2009-08-21 09:54 Mateusz Loskot <mateusz at loskot.net>
- * [r2623] Updated svn:ignore property
-2009-08-21 09:50 Mateusz Loskot <mateusz at loskot.net>
- * [r2622] Cleaned compilation warnings in unit tests.
-2009-08-21 09:43 Mateusz Loskot <mateusz at loskot.net>
- * [r2621] Updated C++ TUT Framework to latest revision (147) of its
- SVN trunk
-2009-08-15 13:26 Sandro Santilli <strk at keybit.net>
- * [r2620] Const correctness of LenghtIndexedLine port, by novalis
- (issue #284)
-2009-08-12 19:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2619] Port of JTS linear referencing (from David Turner) (#283)
-2009-08-02 23:39 Mateusz Loskot <mateusz at loskot.net>
- * [r2618] Removed incomplete GEOS_DEBUG message causing compilation
- error because Edge type is incomplete.
-2009-08-02 23:15 Mateusz Loskot <mateusz at loskot.net>
- * [r2617] Fixed broken escape sequence in debug msg.
-2009-07-17 22:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2616] Remove static string in WKB reader (#232)
-2009-07-15 18:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2613] Add PreparedGeometry and STRtree support to SWIG (#279)
- Schuyler Erle
-2009-07-15 18:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2612] Add STRtree support to the C API (#278) Schuyler Erle
-2009-07-15 18:53 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2611] Add geos::index::strtree::AbstractSTRtree::iterate (#277)
- Schuyler Erle
-2009-07-06 17:35 Sandro Santilli <strk at keybit.net>
- * [r2610] Add automated XML test for issue #275. Succeeds here.
-2009-07-05 15:58 Sandro Santilli <strk at keybit.net>
- * [r2609] Apply fix-msvc90-only2.patch by Sanak from issue #273
-2009-07-04 16:19 Sandro Santilli <strk at keybit.net>
- * [r2608] Apply fix-mingw.patch by Sanak (issue #273)
-2009-06-29 16:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2607] Include nmake.opt in 'dist' target (#274)
-2009-06-26 21:59 Sandro Santilli <strk at keybit.net>
- * [r2605] Fix typo reported in ticket #272
-2009-06-24 21:43 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2604] Expose Hausdorf distance to CAPI (#264) from Vincent
- Picavet
-2009-06-24 21:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2603] Fix stoopid syntax error.
-2009-06-24 21:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2602] Remove old logging noise.
-2009-06-24 21:19 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2601] Fix for #270, bad definition of isnan() in OS/X <cmath>.
- This needs to be tested on other operating systems to make sure
- it doesn't break them instead.
-2009-06-23 22:20 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2599] Fix clean target for VC build (#267)
-2009-06-23 18:22 Howard Butler <hobu.inc at gmail.com>
- * [r2598] fix up syntax of the makefile related to the patch for
- #257
-2009-06-22 19:14 Sandro Santilli <strk at keybit.net>
- * [r2597] Add tests for limited mitre join (now working)
-2009-06-22 19:02 Sandro Santilli <strk at keybit.net>
- * [r2596] Fix bug in BufferParameters::setMitreLimit
-2009-06-20 21:29 Sandro Santilli <strk at keybit.net>
- * [r2595] Bump versions (core 3.2.0, capi 1.6.0, port 1.10.0)
-2009-06-20 08:53 Sandro Santilli <strk at keybit.net>
- * [r2594] Add tests for GEOSBufferWithStyle
-2009-06-19 22:32 Sandro Santilli <strk at keybit.net>
- * [r2593] Extend the C-API interface to expose a
- GEOSBufferWithStyle (and corresponding thread-safe version) and
- related enums.
-2009-06-16 15:49 Sandro Santilli <strk at keybit.net>
- * [r2592] Sync RobustDeterminant to JTS-1.10 (r1.15 was just
- commented-out code)
-2009-06-16 15:46 Sandro Santilli <strk at keybit.net>
- * [r2591] Sync RobustDeterminant to revision 1.14
-2009-06-16 15:43 Sandro Santilli <strk at keybit.net>
- * [r2590] Port info for RobustDeterminant
-2009-06-16 15:33 Sandro Santilli <strk at keybit.net>
- * [r2589] Revert single-sided patch. Martin Davis is workin on it
- from the JTS side
-2009-06-16 00:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2581] add reminders on bump versions in various places
-2009-06-15 14:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2580] operation.h in Makefile.am twice. (#261)
-2009-06-15 14:03 Sandro Santilli <strk at keybit.net>
- * [r2579] Port info in the geos::io namespace
-2009-06-15 13:19 Sandro Santilli <strk at keybit.net>
- * [r2578] Put CLocalizer in the correct function. Fixes #260 for
- the writing part.
-2009-06-15 10:13 Sandro Santilli <strk at keybit.net>
- * [r2577] Stop explicitly using the CLocalizer now that it is done
- within WKTReader and WKTWriter (see bug #260). Some deep testing
- about this would be good. Make check worked for me with
- comma-using locale.
-2009-06-15 10:06 Sandro Santilli <strk at keybit.net>
- * [r2576] Use C locale while reading/writing WKT. Fixes bug #260.
-2009-06-15 06:57 Sandro Santilli <strk at keybit.net>
- * [r2575] Add XML version of the testcase provided for bug #176
-2009-06-08 22:10 Sandro Santilli <strk at keybit.net>
- * [r2572] JTS-1.10 port sync. The whole 'operation' namespace is
- complete on this.
-2009-06-08 21:53 Sandro Santilli <strk at keybit.net>
- * [r2571] Port info for operation::union
-2009-06-08 17:15 Sandro Santilli <strk at keybit.net>
- * [r2570] Sync to JTS-1.10 (port info in SegmentIntersectionTester
- was wrong, btw)
-2009-06-08 17:12 Sandro Santilli <strk at keybit.net>
- * [r2569] Sync RectangleContains to JTS-1.10
-2009-06-08 17:02 Sandro Santilli <strk at keybit.net>
- * [r2568] Port info for operation::predicate (we're at JTS-1.7
- here)
-2009-06-08 16:58 Sandro Santilli <strk at keybit.net>
- * [r2567] Port info for polygonize operation
-2009-06-08 16:46 Sandro Santilli <strk at keybit.net>
- * [r2566] Port info and sync for operation::overlay::validate
-2009-06-08 16:26 Sandro Santilli <strk at keybit.net>
- * [r2565] sync LineBuilder to JTS-1.10, completing overlay port
-2009-06-08 16:09 Sandro Santilli <strk at keybit.net>
- * [r2564] Complete port info in overlay package
-2009-06-08 15:43 Sandro Santilli <strk at keybit.net>
- * [r2563] Add missing setMarked static methods in GraphComponent
- and make use of them in LineMerger making it able to be called
- incrementally (JTS-1.10)
-2009-06-08 15:28 Sandro Santilli <strk at keybit.net>
- * [r2562] Port info in operation::linemerge (a single class is
- still at JTS-1.7, needs changes in GeometryGraphComponent.h to go
- up)
-2009-06-08 10:37 Sandro Santilli <strk at keybit.net>
- * [r2561] GeometryLocation sync to JTS-1.10 (docs)
-2009-06-08 10:29 Sandro Santilli <strk at keybit.net>
- * [r2560] DistanceOp sync to JTS-1.10 (renames, docs...)
-2009-06-08 10:07 Sandro Santilli <strk at keybit.net>
- * [r2559] Update port info for buffer package (it's really
- JTS-1.10)
-2009-06-08 09:40 Sandro Santilli <strk at keybit.net>
- * [r2558] Warn at configure time if 64bit integer type isn't found.
- See bug #202.
-2009-06-08 09:30 Sandro Santilli <strk at keybit.net>
- * [r2557] Install all C++ headers to reduce maintainance costs. C++
- API is documented as being unstable after all so let's give users
- the power to hurt themselves :)
-2009-06-06 22:22 Sandro Santilli <strk at keybit.net>
- * [r2556] Windows C++ exports by Ragi Y. Burhum. See
- http://lists.osgeo.org/pipermail/geos-devel/2009-June/004190.html
-2009-06-06 22:17 Sandro Santilli <strk at keybit.net>
- * [r2555] fix headers inclusion warnings
-2009-06-06 21:14 Sandro Santilli <strk at keybit.net>
- * [r2554] Use real NaNs rather than fake them. Applies patch in
- ticket #259. Adds autoconf checks for finite() and isfinite() and
- makes use of them for unix systems (platform.h)
-2009-06-06 00:55 Sandro Santilli <strk at keybit.net>
- * [r2553] Complete port info and headers exposion for
- operation::distance package
-2009-06-05 18:18 Sandro Santilli <strk at keybit.net>
- * [r2552] JTS-1.10 OverlayOp
-2009-06-05 18:12 Sandro Santilli <strk at keybit.net>
- * [r2551] Add missing static function
-2009-06-05 18:02 Sandro Santilli <strk at keybit.net>
- * [r2550] JTS-1.10 sync
-2009-06-05 17:50 Sandro Santilli <strk at keybit.net>
- * [r2549] Boundary Node Rule support in relateOp. JTS-1.10.
-2009-06-05 13:44 Sandro Santilli <strk at keybit.net>
- * [r2548] geomgraph package fully sync'ed to JTS-1.10 now
-2009-06-05 13:41 Sandro Santilli <strk at keybit.net>
- * [r2547] added BoundaryNodeRule capability to EdgeEnds
-2009-06-05 12:42 Sandro Santilli <strk at keybit.net>
- * [r2546] Add support for custom BoundaryNodeRule bringing
- GeometryGraph to JTS-1.10
-2009-06-05 12:07 Sandro Santilli <strk at keybit.net>
- * [r2545] Complete port info in geomgraph package
-2009-06-05 11:03 Sandro Santilli <strk at keybit.net>
- * [r2544] Port info in the geomgraph package (unfinished); fix
- compiler warning in GeometryGraph and make code more readable;
-2009-06-05 10:23 Sandro Santilli <strk at keybit.net>
- * [r2543] Add port info and introduce header exposion info. Relate
- op results partially in JTS-1.7 still.
-2009-06-05 09:36 Sandro Santilli <strk at keybit.net>
- * [r2542] typo in doxygen index page
-2009-06-05 09:35 Sandro Santilli <strk at keybit.net>
- * [r2541] Fix doxygen link
-2009-06-05 09:28 Sandro Santilli <strk at keybit.net>
- * [r2540] Fix deletion of void pointer in IntervalRTreeLeafNode,
- document ownership, fix callers tracking allocations to avoid
- leaks. Fixes bug #227.
-2009-06-05 09:15 Sandro Santilli <strk at keybit.net>
- * [r2539] Allow generating ChangeLog from external build tree
-2009-06-04 15:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2538] * Applied patch for ticket #257.
- * Noticed that unit tests fail:
- 1>geos::util::UniqueCoordinateArrayFilter: .
- 1>---> group: geos::operation::valid::IsValidOp, test: test<1>
- 1> problem: assertion failed
-2009-06-04 14:59 Mateusz Loskot <mateusz at loskot.net>
- * [r2537] Fixed bug of inaccessible constructor of incomplete type
- NodedSegmentString - header missing.
-2009-06-04 13:59 Sandro Santilli <strk at keybit.net>
- * [r2536] Add support for testing single sided buffers
-2009-06-01 03:34 Howard Butler <hobu.inc at gmail.com>
- * [r2534] #256 finishGEOS called multiple times will segfault
-2009-05-28 14:38 Mateusz Loskot <mateusz at loskot.net>
- * [r2533] Fixed aclocal warnings for mixing cache-id's in
- configure.in.
-2009-05-27 16:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2516] remove error
- * [r2515] Add single-sided item
-2009-05-21 10:08 Sandro Santilli <strk at keybit.net>
- * [r2514] Add Mat's and Paul's entries, make ChangeLog.svn rule
- phony
-2009-05-21 09:56 Sandro Santilli <strk at keybit.net>
- * [r2513] Add a rule to generate a ChangeLog using svn2cl. The
- authors.svn file will be used to map usernames and full names:
- please expand your own nick. The generated ChangeLog is added to
- repository to show you how it looks. If everybody agree we could
- rename this to ChangeLog and stop requiring manual edits (+1 from
- me:)
-2009-05-13 11:29 Frank Warmerdam <warmerdam at pobox.com>
- * [r2508] refer to GEOSFree() instead of free()
-2009-05-13 11:26 Frank Warmerdam <warmerdam at pobox.com>
- * [r2507] forward GEOSFree to GEOSFree_r, use std:: prefix on
- free() (#249)
-2009-05-13 04:14 Frank Warmerdam <warmerdam at pobox.com>
- * [r2506] Added GEOSFree() and GEOSFree_r() (#249)
-2009-05-12 17:47 Sandro Santilli <strk at keybit.net>
- * [r2505] Add note about single-sided buffer
-2009-05-12 16:49 Sandro Santilli <strk at keybit.net>
- * [r2504] Never fail bug #244 again (regression testcase added)
-2009-05-12 16:48 Sandro Santilli <strk at keybit.net>
- * [r2503] Have DepthSegment hold a real LineSegment, not a
- reference. SubgraphDepthLocater was passing the same LineSegment
- reference to multiple DepthSegments, messing everything up. This
- fixes bug #244.
-2009-05-12 15:38 Sandro Santilli <strk at keybit.net>
- * [r2502] Port info
-2009-05-08 16:30 Sandro Santilli <strk at keybit.net>
- * [r2501] Update port info
-2009-05-08 12:47 Sandro Santilli <strk at keybit.net>
- * [r2500] When included in a C++ environment, include <cstddef> and
- use std::size_t. Patch by Mateusz Loskot, ticket #252.
-2009-05-08 12:46 Sandro Santilli <strk at keybit.net>
- * [r2499] Oops, forgot to update the static closedPoints
- signature..
-2009-05-08 12:29 Sandro Santilli <strk at keybit.net>
- * [r2498] Note the withinDistance addition to DistanceOp
-2009-05-08 12:27 Sandro Santilli <strk at keybit.net>
- * [r2497] Add the complete set of tests for closedPoints
-2009-05-08 12:11 Sandro Santilli <strk at keybit.net>
- * [r2496] Document semantic of a null return from closestPoints
-2009-05-08 12:09 Sandro Santilli <strk at keybit.net>
- * [r2495] Don't wipe out closest locations after computing them
- (doh). Fixes bug #236. Takes the chance to make the
- GeometryLocation retrival function private as we don't install
- GeometryLocation.h header anyway (for future cleanups), and to
- rename a function to follow current JTS naming (more renames to
- come for proper sync)
-2009-05-08 10:10 Sandro Santilli <strk at keybit.net>
- * [r2494] Add isWithinDistance() to DistanceOp, reaching rev 1.17
- of JTS
-2009-05-08 09:39 Sandro Santilli <strk at keybit.net>
- * [r2493] Port info for DistanceOp
-2009-05-08 08:44 Sandro Santilli <strk at keybit.net>
- * [r2492] Always include stddef.h. Closes bug #213
-2009-05-07 16:15 Sandro Santilli <strk at keybit.net>
- * [r2491] Add "thread-safe" version of GEOSGeom_setSRID. Closes bug
- #242.
-2009-05-07 16:00 Sandro Santilli <strk at keybit.net>
- * [r2490] minor debug output improvement
-2009-05-07 15:57 Sandro Santilli <strk at keybit.net>
- * [r2489] Skip empty components when building GeometryGraph. Fixes
- bug #234. Add non-automated test for it, and README file in the
- directory containing it...
-2009-05-07 15:36 Sandro Santilli <strk at keybit.net>
- * [r2488] Add XML testcase for bug 188
- * [r2487] remove code duplication on buffer result validation
-2009-05-07 08:52 Sandro Santilli <strk at keybit.net>
- * [r2486] Port info, doxygen cleanups
-2009-05-07 08:45 Sandro Santilli <strk at keybit.net>
- * [r2485] Add test for creating a CoordinateSequence with at least
- 2 dimension
-2009-05-06 20:47 Sandro Santilli <strk at keybit.net>
- * [r2484] Fix bug #135, give an hint about GEOSGeom_getDimensions
- being related to GEOSCoordSeq_getDimensions, fix signed vs.
- unsigned compiler warning.
-2009-05-06 20:22 Sandro Santilli <strk at keybit.net>
- * [r2483] Fix compilation warnings thrown by GCC 4.3.x. Patch by
- Mateus, closes bug #92.
-2009-05-06 20:12 Mateusz Loskot <mateusz at loskot.net>
- * [r2482] Updated svn:ignore property.
-2009-05-06 17:54 Sandro Santilli <strk at keybit.net>
- * [r2481] findCollapsesFromExistingVertices: don't choke on sets of
- < 2 points. Fixes bug #219.
-2009-05-06 17:52 Sandro Santilli <strk at keybit.net>
- * [r2480] minor indentation thing
-2009-05-06 17:42 Sandro Santilli <strk at keybit.net>
- * [r2479] Cleanup MonotoneChainOverlapAction, reduce heap
- allocations. Cascade changes.
-2009-05-06 17:14 Sandro Santilli <strk at keybit.net>
- * [r2478] Port info (to be worked on for heap allocations
- reduction)
-2009-05-06 17:10 Sandro Santilli <strk at keybit.net>
- * [r2477] MonotoneChainSelectAction port review, heap allocation
- reduced, const-corrected.
-2009-05-06 16:44 Sandro Santilli <strk at keybit.net>
- * [r2476] MonotoneChain const-correctness and interface cleanups,
- cascaded changes. Possibly discovered a leak in MCPointInRing
- algorithm, needs some unit testing.
-2009-05-06 16:36 Sandro Santilli <strk at keybit.net>
- * [r2475] Const-correctness for bintree Interval
-2009-05-06 15:47 Sandro Santilli <strk at keybit.net>
- * [r2474] Port MonotoneChain up to JTS-1.10, plus minor dox
- improvement (memory-oriented)
-2009-05-06 15:31 Sandro Santilli <strk at keybit.net>
- * [r2473] Port MonotoneChainBuilder up to JTS-1.10. Tweak some
- signatures to use stricter signedness.
-2009-05-06 14:55 Sandro Santilli <strk at keybit.net>
- * [r2472] Port to 1.9, fixing an out of boundary access in
- findEdgeEnd
-2009-05-06 14:42 Sandro Santilli <strk at keybit.net>
- * [r2471] Add port info. We're 4 revision old (catching up next)
-2009-05-05 14:28 Sandro Santilli <strk at keybit.net>
- * [r2470] Sync Envelope to JTS-1.10
-2009-05-05 10:30 Sandro Santilli <strk at keybit.net>
- * [r2469] Add compile-time support to skip use of BinaryOp thus
- engaging SnapIfNeededOverlayOp used by Geometry methods. Shows
- that BinaryOp (GEOS-specific original work) gives better
- numerical stability.
-2009-05-05 10:14 Sandro Santilli <strk at keybit.net>
- * [r2468] Found old GeometrySnapper/LineStringSnapper classes in an
- unexpected directory. Move them where they belong, sync with
- JTS-1.10.
-2009-05-05 00:04 Sandro Santilli <strk at keybit.net>
- * [r2467] Fix memory leak on exception
-2009-05-04 23:43 Sandro Santilli <strk at keybit.net>
- * [r2466] Fix memory bug
-2009-05-04 23:23 Sandro Santilli <strk at keybit.net>
- * [r2465] Geometry up to 1.112 with a minor bugfix and performance
- improvement in Geometry::covers
-2009-05-04 23:04 Sandro Santilli <strk at keybit.net>
- * [r2464] Bring Geometry port up a revision by having it use
- SnapIfNeededOp for overlay operations. Note that currently this
- doesn't affect the C-API nor the XMLTester codes, both using the
- BinaryOp original class (not JTS-ported) doing about the same
- thing as the SnapIfNeededOp class.
-2009-05-04 22:03 Sandro Santilli <strk at keybit.net>
- * [r2463] Port SnapIfNeededOverlayOp
-2009-05-04 21:28 Sandro Santilli <strk at keybit.net>
- * [r2462] Move overlay.validate package files where they belong
-2009-05-04 21:02 Sandro Santilli <strk at keybit.net>
- * [r2461] Port overlay.snap.SnapOverlayOp, update GeometrySnapper
- to be more useful
-2009-05-04 19:54 Sandro Santilli <strk at keybit.net>
- * [r2460] Port overlay.snap.GeometrySnapper
-2009-05-04 19:51 Sandro Santilli <strk at keybit.net>
- * [r2459] Extend to accept a vector of const Coordinate pointers
- for snap pointers, fix typo making it clone snap points rather
- than source points on snapping...
-2009-05-02 11:01 Sandro Santilli <strk at keybit.net>
- * [r2458] Port overlay.snap.LineStringSnapper from JTS-1.10
-2009-05-02 10:59 Sandro Santilli <strk at keybit.net>
- * [r2457] Add an insert-like virtual method to CoordinateSequence.
- This comes from CoordinateList of JTS, historically bound to
- CoordinateSequence in GEOS. Add test for that interface.
-2009-05-02 09:44 Sandro Santilli <strk at keybit.net>
- * [r2456] Copy last portable JTS general test, add a file with info
- about what's missing
-2009-05-02 09:42 Sandro Santilli <strk at keybit.net>
- * [r2455] Drop test also found in TestFunctionPLPrec.xml
-2009-05-02 09:40 Sandro Santilli <strk at keybit.net>
- * [r2454] Add support for testing within, covers and coveredby.
- Properly use 'arg1' and 'arg2' for these tests.
-2009-05-02 09:25 Sandro Santilli <strk at keybit.net>
- * [r2453] Copy TestWithinDistance.xml test, drop duplicates from
- testLeaksBig.xml
-2009-05-02 09:20 Sandro Santilli <strk at keybit.net>
- * [r2452] More tests from JTS (TestFunction*)
-2009-05-02 09:17 Sandro Santilli <strk at keybit.net>
- * [r2451] Boundary test
-2009-05-02 09:16 Sandro Santilli <strk at keybit.net>
- * [r2450] ConvexHull tests
-2009-05-02 09:11 Sandro Santilli <strk at keybit.net>
- * [r2449] Add support for testing 'contains' in XMLTester, add all
- Relate tests from JTS
-2009-05-02 09:01 Sandro Santilli <strk at keybit.net>
- * [r2448] More organization of xml tests: 'general' subdir
- following JTS
-2009-05-02 08:44 Sandro Santilli <strk at keybit.net>
- * [r2447] Put stml testcases under their own dir (like in JTS)
-2009-05-02 08:37 Sandro Santilli <strk at keybit.net>
- * [r2446] Add a 'split.xml' testcase to confirm 'difference' may be
- used to split linestrings; add TestRobustRelate.xml from JTS,
- organize robust-related tests as in JTS repository.
-2009-04-30 12:42 Sandro Santilli <strk at keybit.net>
- * [r2444] drop duplicated (and old) port info
-2009-04-30 12:33 Sandro Santilli <strk at keybit.net>
- * [r2443] Update port info
-2009-04-30 12:17 Sandro Santilli <strk at keybit.net>
- * [r2442] Point full up to JTS-1.0 (rev 1.37) : adds reverse()
-2009-04-30 12:07 Sandro Santilli <strk at keybit.net>
- * [r2441] LineString to rev 1.46 : don't override isSimple, always
- return MultiPoint as bondary
-2009-04-30 11:47 Sandro Santilli <strk at keybit.net>
- * [r2440] Polygon to rev 1.50 (getBoundary always return
- MultiLineString)
-2009-04-30 11:42 Sandro Santilli <strk at keybit.net>
- * [r2439] MultiPoint up to rev 1.30 (drop isSimple override)
-2009-04-30 11:36 Sandro Santilli <strk at keybit.net>
- * [r2438] MultiLineString port info and sync to 1.40 (don't
- override isSimple)
-2009-04-30 11:29 Sandro Santilli <strk at keybit.net>
- * [r2437] MultiPolygon up to rev 1.34 (getBoundary always returns a
- MultiLineString now)
-2009-04-30 11:19 Sandro Santilli <strk at keybit.net>
- * [r2436] Oops, *now* we're at 1.14 (drop isSimple, rely on the one
- in base class)
-2009-04-30 11:15 Sandro Santilli <strk at keybit.net>
- * [r2435] Port info. It's at 1.41 now, JTS is at 1.42
-2009-04-30 11:03 Sandro Santilli <strk at keybit.net>
- * [r2434] Geometry class up to JTS rev 1.104 (need reach 1.127...)
-2009-04-30 10:59 Sandro Santilli <strk at keybit.net>
- * [r2433] Add some info about things changed (might have missed
- something)
-2009-04-30 10:51 Sandro Santilli <strk at keybit.net>
- * [r2432] Sync to rev 1.22 (JTS-1.10)
-2009-04-30 10:47 Sandro Santilli <strk at keybit.net>
- * [r2431] EndpointInfo.h header is gone (it's always been private
- in JTS)
-2009-04-30 10:46 Sandro Santilli <strk at keybit.net>
- * [r2430] Port revision 1.9 of IsSimplOp : allow inspecting
- non-simple location coordinate.
-2009-04-30 10:43 Sandro Santilli <strk at keybit.net>
- * [r2429] Sync to revision 1.5 (JTS-1.10) : add accessors
-2009-04-30 09:54 Sandro Santilli <strk at keybit.net>
- * [r2428] port to rev 1.8 (use of BoundaryNodeRule)
-2009-04-30 09:49 Sandro Santilli <strk at keybit.net>
- * [r2427] Import TestSimple.xml from JTS, drop duplicated tests
- from testLeaksBig.xml
-2009-04-30 09:26 Sandro Santilli <strk at keybit.net>
- * [r2426] Port algorithm::BoundaryNodeRule from JTS-1.10 (needed
- for IsSimpleOp sync)
-2009-04-30 08:33 Sandro Santilli <strk at keybit.net>
- * [r2425] Port info, and sync from 1.14 to 1.17 (more to do, need
- more classes)
-2009-04-29 23:52 Mateusz Loskot <mateusz at loskot.net>
- * [r2424] test/unit/capi: re-tab all .cpp files to use spaces.
-2009-04-29 23:46 Mateusz Loskot <mateusz at loskot.net>
- * [r2423] Removed unused <memory> header from C API tests.
-2009-04-29 23:44 Mateusz Loskot <mateusz at loskot.net>
- * [r2422] Added new unit tests for C API: GEOSWithinTest and
- GEOSContainsTest. This is check and response for problems
- reporting in Ticket #250. Running the new tests does not
- reproduce the problem, so it likely has been fixed or the bug is
- somewhere else (i.e. Django layers).
-2009-04-29 09:44 Sandro Santilli <strk at keybit.net>
- * [r2421] Sync GeometricShapeFactory to JTS-1.10 (createArcPolygon
- added)
-2009-04-29 08:56 Sandro Santilli <strk at keybit.net>
- * [r2420] Bring all geom::prep package in sync with JTS-1.10
-2009-04-29 08:22 Sandro Santilli <strk at keybit.net>
- * [r2419] Sync BasicPreparedGeometry to JTS-1.10 (short-circuit in
- containsProperly)
-2009-04-29 08:15 Sandro Santilli <strk at keybit.net>
- * [r2418] Add port information for geom::prep package. Next stop:
- sync to JTS-1.10.
-2009-04-27 19:47 Sandro Santilli <strk at keybit.net>
- * [r2417] Plug last one. All heap blocks were freed -- no leaks are
- possible.
-2009-04-27 19:42 Sandro Santilli <strk at keybit.net>
- * [r2416] Fix leak in testcase
-2009-04-27 19:38 Sandro Santilli <strk at keybit.net>
- * [r2415] Refactor signatures to make ownership transfers more
- explicit. Fixed another leak in Node::insertNode.
-2009-04-27 19:22 Sandro Santilli <strk at keybit.net>
- * [r2414] Fix memory leak in NodeBase::remove, exposed by unit
- testing
-2009-04-27 15:52 Sandro Santilli <strk at keybit.net>
- * [r2413] Port info for quadtree::root
-2009-04-27 15:47 Sandro Santilli <strk at keybit.net>
- * [r2412] Port info for quadtree::Node
-2009-04-27 15:39 Sandro Santilli <strk at keybit.net>
- * [r2411] Port info and check, doxygen.
-2009-04-27 15:30 Sandro Santilli <strk at keybit.net>
- * [r2410] Sync to JTS-1.10, reduce heap allocations and pointers
- usage. Includes a bugfix in collectStats.
-2009-04-27 15:00 Sandro Santilli <strk at keybit.net>
- * [r2409] DoubleBits didn't change in JTS, update port info
- accordingly
-2009-04-27 14:58 Sandro Santilli <strk at keybit.net>
- * [r2408] Quadtree's NodeBase: check port sync, add port info, drop
- unneeded pointers and virtuals, document objects ownership.
-2009-04-25 00:23 Sandro Santilli <strk at keybit.net>
- * [r2407] Const-correctness, reduced heap allocations and port info
- for quadtree::Key class, a few more cleanups in user classes, to
- be continued.
-2009-04-24 23:44 Sandro Santilli <strk at keybit.net>
- * [r2406] Fix memory leak in Quadtree::remove
-2009-04-23 15:26 Sandro Santilli <strk at keybit.net>
- * [r2405] Apply Single-sided buffer patch, issue #215. UNTESTED.
-2009-04-21 16:11 Sandro Santilli <strk at keybit.net>
- * [r2404] Port ValidSelfTouchingRingFormingHoleTest
-2009-04-21 15:30 Sandro Santilli <strk at keybit.net>
- * [r2403] Port ValidClosedRingTest
-2009-04-21 15:13 Sandro Santilli <strk at keybit.net>
- * [r2402] ::reverse returns a Geometry now (to be available up in
- base class)
-2009-04-21 15:12 Sandro Santilli <strk at keybit.net>
- * [r2401] Sync LinearRing to JTS-1.10 (fixing a bug in isClosed)
-2009-04-21 14:03 Sandro Santilli <strk at keybit.net>
- * [r2400] Port IsValidOp unit test
-2009-04-21 11:14 Sandro Santilli <strk at keybit.net>
- * [r2399] Configure for CXX, not C. Should fix unknown tag and link
- issues on telascience.
-2009-04-21 09:06 Sandro Santilli <strk at keybit.net>
- * [r2398] Add an AC_LIBTOOL_LANG_C_CONFIG call right before the
- AC_LIBTOOL_COMPILER_OPTION calls. Seems to fix compiler selection
- on telascience (whereas AC_LANG and AC_LANG_PUSH didn't work)
-2009-04-20 20:32 Sandro Santilli <strk at keybit.net>
- * [r2397] Use JTS heuristic for distance-0 buffer checking
-2009-04-20 11:04 Mateusz Loskot <mateusz at loskot.net>
- * [r2396] Updated svn:ignore patterns.
-2009-04-20 10:37 Sandro Santilli <strk at keybit.net>
- * [r2395] Port IteratedBufferStessTest
-2009-04-20 09:37 Sandro Santilli <strk at keybit.net>
- * [r2394] Add named constants, sync to JTS-1.10
-2009-04-20 09:24 Mateusz Loskot <mateusz at loskot.net>
- * [r2393] Updated svn:ignore patterns.
-2009-04-18 07:55 Sandro Santilli <strk at keybit.net>
- * [r2392] Use BufferResultMatcher for buffer operations. No
- failures.
-2009-04-18 07:49 Sandro Santilli <strk at keybit.net>
- * [r2391] Imported cleaned-up version of fme.xml -- this one fails
- (the one we have is actually expecting a wrong result)
-2009-04-18 07:46 Sandro Santilli <strk at keybit.net>
- * [r2390] Don't densify coordinates if buffer distance is 0
-2009-04-17 16:50 Sandro Santilli <strk at keybit.net>
- * [r2389] comment out debugging lines
-2009-04-17 16:49 Sandro Santilli <strk at keybit.net>
- * [r2388] Port DiscreteHausdorffDistance unit test
-2009-04-17 16:47 Sandro Santilli <strk at keybit.net>
- * [r2387] Offline some more
-2009-04-17 16:46 Sandro Santilli <strk at keybit.net>
- * [r2386] Fix typo
-2009-04-17 16:26 Sandro Santilli <strk at keybit.net>
- * [r2385] Add missing implementation bits
-2009-04-17 15:47 Sandro Santilli <strk at keybit.net>
- * [r2384] Port BufferResultMatcher. Gives 31 new failures !!
-2009-04-17 15:37 Sandro Santilli <strk at keybit.net>
- * [r2383] proper inline check_valid
- source/headers/geos/geom/BinaryOp.h
-2009-04-17 15:34 Sandro Santilli <strk at keybit.net>
- * [r2382] Header guard
-2009-04-17 13:59 Sandro Santilli <strk at keybit.net>
- * [r2381] renamed intersection constants
-2009-04-17 09:56 Sandro Santilli <strk at keybit.net>
- * [r2380] Add debugging output of variables used by
- AC_LIBTOOL_COMPILER_OPTION. Surprisingly, the buildbots try to
- use a fortran compiler there
-2009-04-17 07:50 Sandro Santilli <strk at keybit.net>
- * [r2379] Differentiate variable used in AC_LIBTOOL_COMPILE_OPTION
- for proper use of configuration cache
-2009-04-16 18:05 Sandro Santilli <strk at keybit.net>
- * [r2378] Use -ffloat-store flag when available. See
- http://lists.osgeo.org/pipermail/geos-devel/2009-April/004089.html
-2009-04-16 12:56 Sandro Santilli <strk at keybit.net>
- * [r2377] Make enum values explicit, as JTS tests rely on those..
-2009-04-16 12:54 Sandro Santilli <strk at keybit.net>
- * [r2376] Port RobustLineIntersectorTest from JTS
-2009-04-16 12:08 Sandro Santilli <strk at keybit.net>
- * [r2375] better isolation of test-specific functions
-2009-04-16 10:48 Sandro Santilli <strk at keybit.net>
- * [r2374] Port RobustLineIntersectionTest (mostly failing, but
- reported by Martin Davis to be expected)
-2009-04-15 15:58 Sandro Santilli <strk at keybit.net>
- * [r2373] New class rename, following JTS
-2009-04-15 12:56 Sandro Santilli <strk at keybit.net>
- * [r2372] typo in disabled section
-2009-04-15 11:17 Sandro Santilli <strk at keybit.net>
- * [r2371] Few more docs about memory management in quadtree
- indexing; fix a potential leak in quadtree::Key
-2009-04-15 10:43 Sandro Santilli <strk at keybit.net>
- * [r2370] Document ownership of quadtree::NodeBase subnodes
-2009-04-15 10:18 Sandro Santilli <strk at keybit.net>
- * [r2369] Fix memory leak in unit test
-2009-04-15 10:02 Sandro Santilli <strk at keybit.net>
- * [r2368] Fix leak in SimpleGeometryPrecisionReducer, improve
- memory management docs where topic.
-2009-04-15 09:29 Sandro Santilli <strk at keybit.net>
- * [r2367] Document ownership of DistanceOp::closestPoints return,
- fix leak in unit test.
-2009-04-15 09:25 Sandro Santilli <strk at keybit.net>
- * [r2366] Fix leak in PolygonBuilder (overlay operation). The leak
- was exposed by the stmlf-cases-20061020.xml testcase. This commit
- also adds some doc-only throw specs related to the bug.
-2009-04-15 07:52 Sandro Santilli <strk at keybit.net>
- * [r2365] Fix memory leaks in IsValid operation
-2009-04-15 00:27 Sandro Santilli <strk at keybit.net>
- * [r2364] Explain why unrolled computation is turned off, and keep
- it off
-2009-04-15 00:14 Sandro Santilli <strk at keybit.net>
- * [r2363] Fix typo in computing angleOrientation
-2009-04-14 19:11 Sandro Santilli <strk at keybit.net>
- * [r2362] Temporarly revert the unrolled computation in
- HCoordinate::intersection. Added mitred join buffer test from JTS
- (failed with the unrolled comp, to be further inspected).
-2009-04-14 16:43 Sandro Santilli <strk at keybit.net>
- * [r2361] Port the algorithm::distance package from JTS 1.9
-2009-04-14 15:25 Sandro Santilli <strk at keybit.net>
- * [r2360] Add CoordinateSequenceFilter support, fix default
- GeometryComponentFilter moving the logic to the correct place (a
- Geometry private class).
-2009-04-14 13:35 Sandro Santilli <strk at keybit.net>
- * [r2359] Sync (Robust)LineIntersector to JTS-1.9
-2009-04-14 13:23 Sandro Santilli <strk at keybit.net>
- * [r2358] Sync CGAlgorithms with JTS-1.9
-2009-04-14 12:55 Sandro Santilli <strk at keybit.net>
- * [r2357] Fix memory leak in RayCrossingCounter; update signatures
- to avoid pointers when unneeded; add a locatePointInRing taking a
- vector of coordinate pointers, for use by CGAlgorithms
-2009-04-14 12:42 Sandro Santilli <strk at keybit.net>
- * [r2356] Update port info, checked against JTS-1.9
-2009-04-14 11:03 Sandro Santilli <strk at keybit.net>
- * [r2355] Move XML tests under their own directory
-2009-04-14 10:50 Sandro Santilli <strk at keybit.net>
- * [r2354] Fix memory leak in BufferBuilder (due to just-ported
- short-circuit)
-2009-04-14 10:27 Sandro Santilli <strk at keybit.net>
- * [r2353] Add support for bufferMitredJoin tests
-2009-04-14 09:53 Sandro Santilli <strk at keybit.net>
- * [r2352] Fix XML for Buffer testing to match jts layout (arg2 for
- distance, arg3 for quadrant segments); copy buffer-related tests
- from jts: they succeed w/out editing.
-2009-04-14 09:22 Sandro Santilli <strk at keybit.net>
- * [r2351] Update port info of SubgraphDepthLocater
-2009-04-14 09:19 Sandro Santilli <strk at keybit.net>
- * [r2350] Update port info for RightmostEdgeFinder (checked)
-2009-04-14 09:14 Sandro Santilli <strk at keybit.net>
- * [r2349] Sync BufferSubgraph to JTS-1.9
-2009-04-14 08:52 Sandro Santilli <strk at keybit.net>
- * [r2348] Port OffsetCurveBuilder from JTS-1.9. Twenty time faster
- completion of fme.xml testcase !
-2009-04-10 20:22 Sandro Santilli <strk at keybit.net>
- * [r2347] Port BufferInputLineSimplifier from JTS 1.9
-2009-04-10 15:15 Mateusz Loskot <mateusz at loskot.net>
- * [r2346] Do not generate Makefile for tests/unit/tut. Fixed bug
- reported as #247.
-2009-04-10 12:08 Sandro Santilli <strk at keybit.net>
- * [r2345] Sync LineSegment with JTS-1.9
-2009-04-09 21:46 Mateusz Loskot <mateusz at loskot.net>
- * [r2344] Updated tests/unit package with latest relase of C++ TUT
- Framework from 2008-11-30.
-2009-04-09 19:39 Mateusz Loskot <mateusz at loskot.net>
- * [r2343] Moved tests/tut to tests/unit/tut. Preparing for update
- to latest version of C++ TUT Framework.
-2009-04-09 16:22 Sandro Santilli <strk at keybit.net>
- * [r2342] Port algorithm.Angle from JTS-1.9
-2009-04-09 11:45 Sandro Santilli <strk at keybit.net>
- * [r2341] Sync BufferBuilder and BufferOp classes to JTS-1.9. Adapt
- OffsetCurveBuilder to use of BufferParameter (needs more work for
- JTS-sync).
-2009-04-09 10:21 Sandro Santilli <strk at keybit.net>
- * [r2340] typo
-2009-04-09 09:45 Sandro Santilli <strk at keybit.net>
- * [r2339] Port BufferParameters from JTS-1.9
-2009-04-09 08:54 Sandro Santilli <strk at keybit.net>
- * [r2338] Sync port of OffsetCurveVertexList to JTS-1.9, improve
- memory management documentation (would need some
- refactoring/love)
-2009-04-08 16:52 Sandro Santilli <strk at keybit.net>
- * [r2337] Improve duplicate edge detection performance (JTS-1.9
- sync) - fme.xml runs 3 times as fast now.
-2009-04-08 16:17 Sandro Santilli <strk at keybit.net>
- * [r2332] const correctness
-2009-04-08 15:38 Sandro Santilli <strk at keybit.net>
- * [r2329] Fix documentation for GEOSPrepare, GEOSPrepare_r
-2009-04-08 14:54 Sandro Santilli <strk at keybit.net>
- * [r2328] OrientedCoordinateArray ported from JTS
-2009-04-08 14:41 Sandro Santilli <strk at keybit.net>
- * [r2327] Add increasingDirection static method, from JTS's
- CoordinateArray (GEOS puts all of them in CoordinateSequence for
- historical reasons)
-2009-04-08 13:16 Sandro Santilli <strk at keybit.net>
- * [r2326] Complete porting of SimpleSnapRounder (refactoring for
- adding snapped nodes)
-2009-04-08 13:02 Sandro Santilli <strk at keybit.net>
- * [r2325] Improve documentation about memory usage for
- SegmentStringUtil class
-2009-04-08 12:58 Sandro Santilli <strk at keybit.net>
- * [r2324] Stub initial unit tests for C-API's GEOSPreparedGeometry
- operations. Helped fixing issue 147 of postgis
-2009-04-08 12:55 Sandro Santilli <strk at keybit.net>
- * [r2323] Don't access deleted memory. Fixes issue 147.
-2009-04-08 10:53 Sandro Santilli <strk at keybit.net>
- * [r2322] Fix typo
-2009-04-08 10:06 Sandro Santilli <strk at keybit.net>
- * [r2321] Add a couple more tests to SegmentNode unit test
-2009-04-08 09:42 Sandro Santilli <strk at keybit.net>
- * [r2320] Port SegmentNode to JTS-1.9
-2009-04-07 19:00 Sandro Santilli <strk at keybit.net>
- * [r2319] Refactor SegmentString to be an abstract class, to be in
- sync with JTS-1.9.
-2009-04-07 12:36 Sandro Santilli <strk at keybit.net>
- * [r2318] update copyright notice
-2009-04-07 11:11 Sandro Santilli <strk at keybit.net>
- * [r2317] Sync HotPixel to JTS-1.9 (rev 1.3); fix a few bugs and
- use standard algorithms for min/max
-2009-04-07 10:48 Sandro Santilli <strk at keybit.net>
- * [r2316] Fix signed vs. unsigned compiler warning
-2009-04-07 10:18 Sandro Santilli <strk at keybit.net>
- * [r2315] Port info, indenting
-2009-04-07 09:56 Sandro Santilli <strk at keybit.net>
- * [r2314] Port IndexedNestedRingTester and have IsValidOp use it,
- syncing the operation to JTS-1.9
-2009-04-07 09:55 Sandro Santilli <strk at keybit.net>
- * [r2313] Update port info, minor tweaks to doxygen comments
-2009-04-07 08:14 Sandro Santilli <strk at keybit.net>
- * [r2312] Sync HCoordinate class to JTS-1.9 (rev 1.18)
-2009-04-03 15:27 Mateusz Loskot <mateusz at loskot.net>
- * [r2311] Added _NMAKE_VER 9.00.21022.08 to nmake.opt. Fixed bug
- with using BUILD_DEBUG instead of BUILD_BATCH in nmake.opt.
-2009-03-27 02:39 Mateusz Loskot <mateusz at loskot.net>
- * [r2310] Updated build/msvc80.
-2009-03-27 02:38 Mateusz Loskot <mateusz at loskot.net>
- * [r2309] Forgotten nmake.opt in last commit.
-2009-03-26 21:52 Mateusz Loskot <mateusz at loskot.net>
- * [r2308] Refactored NMAKE makefiles. Added nmake.opt file - GDAL
- style. Added some auto-magic to determine version of Visual C++
- compiler and set version specific compilation flags. No need to
- specify Visual C++ version in cmd line, but just run: nmake -f
- makefile.vc in root dir of the tree.
-2009-03-26 21:07 Mateusz Loskot <mateusz at loskot.net>
- * [r2307] CascadedPolygonUnion.cpp: added missing std headers.
-2009-03-26 01:53 Mateusz Loskot <mateusz at loskot.net>
- * [r2306] Dummy commit - testing buildbot resurection.
-2009-03-24 16:49 Mateusz Loskot <mateusz at loskot.net>
- * [r2304] Fixed bug introduced in recent refactoring work (r2281).
- This is the reason of PostGIS regression test failing (Issue 143)
-2009-03-24 15:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2303] Allow version test to work in glibtoolize
-2009-03-24 00:48 Mateusz Loskot <mateusz at loskot.net>
- * [r2302] capi/geos_ts_c.cpp: refactoring, assert() to test against
- nullptr where it is forbidden.
-2009-03-24 00:30 Mateusz Loskot <mateusz at loskot.net>
- * [r2301] REVERTED r2299: Fixed GEOSSetSRID_r missing, GEOSSetSRID
- duplicated (Ticket #242). A little of refactoring.
-2009-03-24 00:19 Mateusz Loskot <mateusz at loskot.net>
- * [r2300] Fixed GEOSSetSRID_r missing, GEOSSetSRID duplicated
- (Ticket #242). A little of refactoring.
-2009-03-23 23:50 Mateusz Loskot <mateusz at loskot.net>
- * [r2299] capi/geos_ts_c.cpp: refactoring, use single return
- expression per function, added assert() to test against nullptr
- where it is forbidden.
-2009-03-23 23:29 Mateusz Loskot <mateusz at loskot.net>
- * [r2298] capi/geos_ts_c.cpp: refactoring, use single return
- where it is forbidden, addd some comments.
-2009-03-23 22:19 Mateusz Loskot <mateusz at loskot.net>
- * [r2297] capi/geos_ts_c.cpp: refactoring, use single return
-2009-03-23 21:07 Mateusz Loskot <mateusz at loskot.net>
- * [r2296] capi/geos_ts_c.cpp: refactoring, replace manual strdup
- with gstrdup, use single return expression per function, added
- some comments.
-2009-03-23 20:31 Mateusz Loskot <mateusz at loskot.net>
- * [r2295] dummy commit
-2009-03-23 20:03 Mateusz Loskot <mateusz at loskot.net>
- * [r2294] autogen.sh: Fixed typo in tab character.
-2009-03-23 17:08 Mateusz Loskot <mateusz at loskot.net>
- * [r2293] autogen.sh: be more verbose about versions, check for
- autoconf, check if ./configure is really generated.
-2009-03-23 16:28 Mateusz Loskot <mateusz at loskot.net>
- * [r2292] configure.in: mloskot made a stupid mistake, mloskot has
- fixed it.
-2009-03-23 14:38 Mateusz Loskot <mateusz at loskot.net>
- * [r2291] configure.in: wrap macro arguments with proper M4 quote
- characters.
-2009-03-23 14:08 Mateusz Loskot <mateusz at loskot.net>
- * [r2290] autogen.sh: Call libtool *before* aclocal and automake
- (see Automake manual,8.3.9.1).
-2009-03-23 14:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2289] autogen.sh: verbose check if autotools versions.
-2009-03-22 20:29 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2288] Show what versions of things we're running
-2009-03-21 02:17 Mateusz Loskot <mateusz at loskot.net>
- * [r2287] capi/geos_ts_c.cpp: refactoring - removed redundant
- return expressions, replaced bloated use of malloc + memcpy with
- single call to gstrdup, use of C++ cast operators, removed
- unnecessary allocation of std::string objects.
-2009-03-21 01:37 Mateusz Loskot <mateusz at loskot.net>
- * [r2286] capi/geos_ts_c.cpp: added gstrdup and gstrdup_s helper
- functions to get rid of bloated code in future. Started
- eliminating redundant return expressions.
-2009-03-21 01:10 Mateusz Loskot <mateusz at loskot.net>
- * [r2285] macros: Updated svn:ignore property.
-2009-03-21 01:08 Mateusz Loskot <mateusz at loskot.net>
- * [r2284] capi/geos_ts_c.cpp: Use of spaces instead of tabs
- applied.
-2009-03-21 01:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2283] source/operation/polygonize/edgering.cpp: cleaned
- compiler warnings about mixed integral types.
-2009-03-21 01:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2282] Fixed deprecated conversion from string constant to char*
- in GEOSisValidReason_r. Small refactoring.
-2009-03-21 00:47 Mateusz Loskot <mateusz at loskot.net>
- * [r2281] capi/geos_ts_c.cpp: refactoring, use c++ cast operators.
-2009-03-20 23:37 Mateusz Loskot <mateusz at loskot.net>
- * [r2280] Updated svn:ignore property.
-2009-03-20 23:35 Mateusz Loskot <mateusz at loskot.net>
- * [r2279] Updated build/msvc80 project.
-2009-03-19 16:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2278] Fix spellingn mistake.
-2009-03-19 16:19 Mateusz Loskot <mateusz at loskot.net>
- * [r2277] * tests/unit/capi: added GEOSGeomFromWKBTest with test
- cases (see comment) reported as a bug (See
- http://postgis.refractions.net/pipermail/postgis-devel/2009-March/005199.html).
- TODO: Reproduce and ask the reporter to submit a ticket if
- necessary.
- * test/unit/utility.h: Added helper class wkb_hex_decoder.
- * Updated build/msvc90 projects.
-2009-03-11 12:51 Mateusz Loskot <mateusz at loskot.net>
- * [r2276] BUG in DistanceOp:
- * Test case and explanation of existing bug in
- DistanceOp::closestPoints() recently reported by Aya (Ticket
- #236).
- * Refactored closestPoints() method to clearly present where is
- the bug. Again, chain calls are evil! Bless clear code!
- * tests/unit/operation/distance/DistanceOpTest.cpp: see test case
- test<17>, read FIXME comments. Uncomment closestPoints() to run
- and reproduce the bug.
- * A dirty fix: if loc0 or loc1 are nullptr, return nullptr
- CoordinatesSequence from closestPoints().
-2009-03-11 12:18 Mateusz Loskot <mateusz at loskot.net>
- * [r2275] Number of assertions in CoordinateArraySequence class.
-2009-03-10 17:29 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2274] svn:ignore
-2009-03-10 17:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2273] svn:ignore
-2009-03-10 17:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2272] Update NEWS for 3.1.0
-2009-03-10 16:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2271] Update ChangeLog for 3.1.0 release
-2009-02-07 23:29 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2269] Include GeometrySnapper.h in distribution package.
-2009-02-02 22:58 Sean Gillies <sgillies at frii.com>
- * [r2268] Note lack of Python support since 3.0
-2009-02-02 22:53 Sean Gillies <sgillies at frii.com>
- * [r2267] Notes on state of scripting language bindings
-2009-01-30 20:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2266] Add new msvc targets to build
-2009-01-29 19:22 Mateusz Loskot <mateusz at loskot.net>
- * [r2265] Added build/msvc90 with solution and project files for
- Microsoft Visual C++ 2009 (9.0). Successfully built and tested
- GEOS with Visual C++ 9.0.
-2009-01-29 19:02 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2264] update autogen.bat ref
-2009-01-29 18:56 Mateusz Loskot <mateusz at loskot.net>
- * [r2263] Fixed broken svn:keyword Id
-2009-01-29 18:51 Mateusz Loskot <mateusz at loskot.net>
- * [r2262] Renamed bootstrap.bat to autogen.bat for easier guass of
- the script purpose. Wiki updated.
-2009-01-28 01:06 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2261] Add to win32 instructions
-2009-01-27 18:10 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2260] Add GeometryCombiner.h to include dist
-2009-01-27 00:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2259] Revert some junk from an old commit, per issue #220
-2009-01-26 20:44 Frank Warmerdam <warmerdam at pobox.com>
- * [r2258] added two new files related to cascaded polygon union
- (#226)
-2009-01-24 05:03 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2257] Update
-2009-01-24 05:02 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2256] Update changelog
-2009-01-24 01:33 Mateusz Loskot <mateusz at loskot.net>
- * [r2255] Fixed mixed signed/unsigned integral types in
- geos_ts_c.cpp, so no compilers should flood with warnings now.
-2009-01-24 01:30 Mateusz Loskot <mateusz at loskot.net>
- * [r2254] Updated projects for Visual Studio 2005 adding new
- .h/.cpp files.
-2009-01-23 23:58 Mateusz Loskot <mateusz at loskot.net>
- * [r2253] Updated svn:keywords property on C/C++ files.
-2009-01-21 22:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2252] Remove geometryCollection protection from
- Union/Relate/Intersection/Difference.
-2009-01-20 01:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2251] Add GEOSUnionCascaded(*GEOSGeometry) to CAPI in
- preparation for PostGIS hook-up.
-2009-01-19 23:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2250] Formatting changes to function decls.
-2009-01-19 20:41 Howard Butler <hobu.inc at gmail.com>
- * [r2249] fixes to allow building in msvc 2003
-2009-01-19 20:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2248] Make warning flags conditional behind a compiler test...
- fix to bug #192 ?
-2009-01-19 16:44 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2247] Added patch from hkaiser to allow cascadedunion to be run
- directly on a multipolygon.
-2009-01-19 00:12 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2246] Fix error left behind from testing.
-2009-01-18 23:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2245] Add some more info on missing tools.
-2009-01-18 23:07 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2244] Add msvc files to distribution target, and update release
- notes to include updating
- version in .vc headers.
-2009-01-18 22:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2243] Add a couple extra program checks.
-2009-01-18 21:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2241] Add version test for aclocal and automake to allow
- OpenSolaris to work.
-2009-01-18 20:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2240] Apply cascaded union patch, for issue #225
-2009-01-15 01:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2239] Remove XMLTester from list of installed programs.
-2009-01-14 20:25 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2238] Remove strdup use from code for compilation in mingw
-2009-01-13 20:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2237] Add [macros] include to configure.in directly. Seems to
- make more recent aclocals happy
-2009-01-13 20:43 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2236] Change AC_SUBST to one-per-line instead of
- one-line-for-all. Seems to make more recent autoconf's happier.
-2009-01-13 19:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2235] Change return values for GEOSWKBWriter_getIncludeSRID_r
- to match function signature.
-2009-01-13 17:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2234] More files missing from commit.
-2009-01-13 15:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2233] Add missing file to SVN.
-2009-01-13 01:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2232] Apply patch for issue #210 (thread safe c-api) submitted
- by Chuck Thibert.
-2009-01-05 23:42 Stephen Wong <swongu at gmail.com>
- * [r2231] Fixed memory leak in BufferBuilder (#218); added
- read-only coordinates function in OffsetCurveVertexList;
- explicity pass ownership in LineMerger.
-2008-11-26 19:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2229] Octant.h error (#185) from Denise Macleod.
-2008-11-26 19:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2228] Allow proper writing out of z ordinates. From Justin
- Bronn (#216)
-2008-11-26 19:25 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2227] Allow readpoint to look at input dimension and fill
- higher ordinates. (#217)
-2008-11-26 19:06 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2226] Expose GEOSIsValidReason to CAPI
-2008-11-18 03:09 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2221] Cygwin build fix from MCA
-2008-11-11 17:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2220] Memory leak on invalid polygons in intersection(). (#170)
- from Denise MacLeod.
-2008-11-05 20:52 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2218] Another minor memory leak removed.
-2008-10-28 15:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2217] Cygwin/Mingw patch from Mark Cave-Ayland
-2008-10-23 17:33 Frank Warmerdam <warmerdam at pobox.com>
- * [r2210] set isChecked flag after checking to fix memory leak
- (#169)
-2008-10-16 00:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2203] change info to point to osgeo.org
-2008-10-14 15:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2200] Consistent const declarations in c-api ($#209)
-2008-10-13 22:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2199] Add CLocalizer.h to build so it gets packaged in make
- dist
-2008-10-10 17:46 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2198] One last memory leak fix.
-2008-10-09 16:39 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2197] Memory leak fix for for prepared intersects. (#207)
-2008-10-04 18:14 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2196] Memory leak fix for prepared geometry, from Hartmut
- Kaiser. (#207)
-2008-09-29 19:24 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2195] Put function sig on one line
-2008-09-23 23:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2194] Moved some ctor/dctor bodies from headers to translation
- units. Improved source code readability. TODO: We need to run a
- beast like AStyle on all GEOS code because many places are very
- hard to read.
-2008-09-23 22:55 Mateusz Loskot <mateusz at loskot.net>
- * [r2193] MCIndexSegmentSetMutualIntersector::addToIndex: Completed
- BWJ's comment on memory leaks with important observations about
- objects relation & lifetime. The note is a diagnosis of roots of
- the problem. Improved source code readability.
-2008-09-22 21:48 Mateusz Loskot <mateusz at loskot.net>
- * [r2192] Use conditional operators instead of cast bool to int.
-2008-09-22 20:16 Mateusz Loskot <mateusz at loskot.net>
- * [r2191] Removed unnecessary std::endl from debug messages in
- TopologyPreservingSimplifier.cpp.
-2008-09-21 21:32 Mateusz Loskot <mateusz at loskot.net>
- * [r2190] Patched NMAKE makefiles: replaced lib.exe with link.exe
- /lib command to enabled compilation using Microsoft Visual C++
- Toolkit 2003
-2008-09-16 21:09 Mateusz Loskot <mateusz at loskot.net>
- * [r2189] Patch fixing build problems on Solaris (Ticket #205).
-2008-09-16 21:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2188] Fixed EOL to LF.
-2008-09-16 20:58 Mateusz Loskot <mateusz at loskot.net>
- * [r2187] Fixed crash of Prepared Geometry construction with
- nullptr to Geometry object (Ticket #197).
-2008-09-16 20:55 Mateusz Loskot <mateusz at loskot.net>
- * [r2186] Added PreparedGeometryFactoryTest to geos_unit.vcproj.
-2008-09-16 20:15 Mateusz Loskot <mateusz at loskot.net>
- * [r2185] Added CLocalizer to geos_lib.vcproj project for Visual
- C++ 2005/2008.
-2008-09-16 20:13 Mateusz Loskot <mateusz at loskot.net>
- * [r2184] Include missing <cassert> in isPointInRingTest.cpp
-2008-09-16 20:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2183] Fixed undeclared std::locale in CLocalizer when building
- using Visual C++ (Ticket #201)
-2008-08-31 20:28 Mateusz Loskot <mateusz at loskot.net>
- * [r2182] Replaced incorrect <cmath> with <cstdlib> in
- geos_unit.cpp.
-2008-08-31 20:23 Mateusz Loskot <mateusz at loskot.net>
- * [r2181] Added missing include <cmath> in geos_unit.cpp.
-2008-08-31 19:54 Mateusz Loskot <mateusz at loskot.net>
- * [r2180] Removed use of strdup function to fix compilation with
- GCC 4.3.1 (Ticket #204).
-2008-08-29 18:17 Mateusz Loskot <mateusz at loskot.net>
- * [r2179] Removed redundant return expressions from geos_c.cpp.
- Testing changes notifications for buildbot.
-2008-08-29 00:30 Mateusz Loskot <mateusz at loskot.net>
- * [r2176] Fixed execution paths and removed redundant return expr
- in some C API calls.
-2008-08-29 00:29 Mateusz Loskot <mateusz at loskot.net>
- * [r2175] Added missing virtual destructor to WKBWriter class.
-2008-08-28 22:20 Sean Gillies <sgillies at frii.com>
- * [r2174] Added CLocalizer class that switches to C locale and
- restores to the outer context's locale when deleted (#201)
-2008-08-28 21:35 Mateusz Loskot <mateusz at loskot.net>
- * [r2173] tests/unit: added GEOSGeomToWKTTest.
-2008-08-28 19:16 Sean Gillies <sgillies at frii.com>
- * [r2172] Switch to C locale while reading and writing WKT and
- restore to the original context's locale afterward (#201)
-2008-08-22 17:25 Frank Warmerdam <warmerdam at pobox.com>
- * [r2171] include cmath for std::pow() and std:log() on MSVC7.1
- (#199)
-2008-08-22 16:10 Mateusz Loskot <mateusz at loskot.net>
- * [r2170] Added build/bjam/README with status note.
-2008-08-19 17:02 Mateusz Loskot <mateusz at loskot.net>
- * [r2169] LineStringTest: fixed memory leak.
-2008-08-19 17:00 Mateusz Loskot <mateusz at loskot.net>
- * [r2168] geos/geom/util: Prefer strict static_cast than C-style
- cast. Commented ownership transfer of coordinates object.
-2008-08-19 00:18 Mateusz Loskot <mateusz at loskot.net>
- * [r2167] tests/unit/algorithm/ConvexHullTest.cpp: Fixed memory
- leaks.
-2008-08-19 00:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2166] tests/unit/algorithm/CGAlgorithms: Fixed memory leaks.
-2008-08-18 23:45 Mateusz Loskot <mateusz at loskot.net>
- * [r2165] tests/unit/algorithm/CGAlgorithms: Fixed number of memory
- leaks.
-2008-08-18 23:30 Mateusz Loskot <mateusz at loskot.net>
- * [r2164] tests/unit/capi: Fixed number of memory leaks.
-2008-08-18 16:32 Mateusz Loskot <mateusz at loskot.net>
- * [r2163] tests/bigtest: Pointed out number of memory leaks but not
- fixing them, waiting for comments.
-2008-08-18 16:30 Mateusz Loskot <mateusz at loskot.net>
- * [r2162] tests/unit: added tests cases to
- PreparedGeometryFactoryTest, refactored casting utils and
- geometry comparators, small cleanup.
-2008-08-18 16:29 Mateusz Loskot <mateusz at loskot.net>
- * [r2161] Fixed svn:keywords.
-2008-08-18 16:27 Mateusz Loskot <mateusz at loskot.net>
- * [r2160] Fixed UNREFERENCED_PARAMETER macro.
- * [r2159] Fixed svn:keywords.
-2008-08-18 16:24 Mateusz Loskot <mateusz at loskot.net>
- * [r2158] geom/prep: Refactored kamikaze casts to more readable
- form. Fixed svn:keywords.
-2008-08-12 00:25 Mateusz Loskot <mateusz at loskot.net>
- * [r2157] Fixed Id keywords.
-2008-08-12 00:23 Mateusz Loskot <mateusz at loskot.net>
- * [r2156] Fixed EOL to LF in trunk/tests.
-2008-08-12 00:09 Mateusz Loskot <mateusz at loskot.net>
- * [r2155] Updated svn:keywords property.
-2008-08-12 00:03 Mateusz Loskot <mateusz at loskot.net>
- * [r2154] Updated svn:keywords property.
-2008-08-11 23:54 Mateusz Loskot <mateusz at loskot.net>
- * [r2153] Refactored tabs vs spaces in PreparedGeometryFactoryTest.
-2008-08-11 23:52 Mateusz Loskot <mateusz at loskot.net>
- * [r2152] PreparedGeometry must be a complete type where it is
- destroyed by the factory (Ticket #198).
-2008-08-11 23:42 Mateusz Loskot <mateusz at loskot.net>
- * [r2151] Completed PreparedGeometryFactory class with missing
- named destructor for PreparedGeometry (Ticket #198)
-2008-08-11 23:35 Mateusz Loskot <mateusz at loskot.net>
- * [r2150] Removed .PreparedGeometryFactoryTest.cpp.swp that must
- sneaked accidentally.
-2008-08-11 22:48 Mateusz Loskot <mateusz at loskot.net>
- * [r2149] Added PreparedGeometryFactoryTest with first test cases
- included. FIXME: The test causes memory leak because we don't
- know how to destroy PreparedGeometry objects returned by the
- factory, discussing on the geos-devel list now.
-2008-08-07 16:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2148] Added original author to main copyright block.
-2008-08-07 16:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2147] Change to standard header, with (c) credit to author.
-2008-08-01 23:23 Mateusz Loskot <mateusz at loskot.net>
- * [r2146] Updated ChangeLog with latest submissions. Hmm, should we
- stil maintain the ChangeLog file?
-2008-07-31 17:08 Mateusz Loskot <mateusz at loskot.net>
- * [r2145] Fixed tabs, hopefully. Updated svn:keywords property.
-2008-07-31 17:01 Mateusz Loskot <mateusz at loskot.net>
- * [r2144] Patch completing C API interface with wrapper on
- Polygonizer::getCutEdges (Ticket #195). Unit test included in
- tests/unit/capi/GEOSPolygonizer_getCutEdgeTest.cpp. Thanks to
- Jurgen E. Fischer for this patch.
-2008-07-26 23:06 Mateusz Loskot <mateusz at loskot.net>
- * [r2143] Number of fixes enabling GEOS compilation with GCC 4.3
- (Ticket #167).
-2008-07-26 21:00 Mateusz Loskot <mateusz at loskot.net>
- * [r2142] Guarded version macros with #ifndef conditions to avoid
- redefinition errors (Ticket #167).
-2008-07-26 20:47 Mateusz Loskot <mateusz at loskot.net>
- * [r2141] Guarded version macros with #ifndef conditions to avoid
-2008-07-26 20:24 Mateusz Loskot <mateusz at loskot.net>
- * [r2140] Fixed problems with finding libpython on Mac Darwin
- (Ticket #191).
-2008-07-26 19:57 Mateusz Loskot <mateusz at loskot.net>
- * [r2139] Updated svn:keywords property.
-2008-07-26 19:56 Mateusz Loskot <mateusz at loskot.net>
- * [r2138] Fixed autogen.sh for OpenSolaris (Ticket #192).
-2008-07-25 21:00 Mateusz Loskot <mateusz at loskot.net>
- * [r2137] Updated svn:keywords property
-2008-07-25 20:56 Mateusz Loskot <mateusz at loskot.net>
- * [r2136] Updated svn:keywords property
-2008-07-19 19:11 Frank Warmerdam <warmerdam at pobox.com>
- * [r2135] added manifest handling for DLLs (#193)
-2008-07-19 19:07 Frank Warmerdam <warmerdam at pobox.com>
- * [r2134] added rules to create platform.h, version.h and geos_c.h
- from templates on win32
-2008-07-15 22:04 Mateusz Loskot <mateusz at loskot.net>
- * [r2131] Fixed compilation on with Sun Studio compiler on Solaris
- x86 and Sparc (Ticket #189). Thanks to Magne Mahre for the patch.
-2008-07-15 13:35 Mateusz Loskot <mateusz at loskot.net>
- * [r2130] For building with Visual C++, added new flag DEBUG=1 (see
- GEOS building instructions on GEOS Wiki). Added missing flags for
- Visual C++ compiler, in release and debug configuration.
-2008-05-20 21:34 Mateusz Loskot <mateusz at loskot.net>
- * [r2129] Added missing subdirs to source/dirlist.mk
-2008-05-20 21:31 Mateusz Loskot <mateusz at loskot.net>
- * [r2128] Updated svn:ignore patterns.
-2008-05-20 21:25 Mateusz Loskot <mateusz at loskot.net>
- * [r2127] * source\headers\geos\util.h: Add UNREFERENCED_PARAMETER
- macro.
- * source\geom\PrecisionModel.cpp,
- source\geom\GeometryComponentFilter.cpp,
- source\geom\util\GeometryTransformer.cpp,
- source\precision\GeometrySnapper.cpp,
- source\precision\CommonBitsRemover.cpp,
- source\simplify\DouglasPeuckerSimplifier.cpp,
- source\operation\overlay\OverlayOp.cpp,
- source\operation\overlay\FuzzyPointLocator.cpp,
- source\index\quadtree\NodeBase.cpp,
- source\headers\geos\geom\BinaryOp.h,
- source\headers\geos\operation\overlay\PointBuilder.h,
- source\headers\geos\noding\MCIndexNoder.h,
- source\headers\geos\noding\ScaledNoder.h,
- source\headers\geos\noding\Octant.h,
- source\noding\ScaledNoder.cpp,
- source\noding\snapround\MCIndexPointSnapper.cpp,
- source\noding\SegmentString.cpp,
- tests\unit\geom\DimensionTest.cpp: Use UNREFERENCED_PARAMETER
- macro to get rid of C4100 warning when building with Visual C++.
- * build\msvc80\geos_lib\geos_lib.vcproj: Remove non-existing
- source files.
-2008-05-20 20:45 Mateusz Loskot <mateusz at loskot.net>
- * [r2126] source/makefile.vc: Removed non-existing file entry:
- PreparedPolygonLineIntersects.obj.
-2008-05-20 20:33 Mateusz Loskot <mateusz at loskot.net>
- * [r2125] * bootstrap.bat: Added script generating headers for use
- with Visual C++ compiler. DO NOT include this script in GEOS
- source distribution. * source/makefile.vc: Do not make copies of
- 3 dynamic headers but let users to use bootstrap.bat instead.
-2008-02-07 22:59 Frank Warmerdam <warmerdam at pobox.com>
- * [r2123] make sure makefile.vc gets distributed
-2008-02-06 22:17 Frank Warmerdam <warmerdam at pobox.com>
- * [r2122] try to fix up the files include in distribution, and
- remove unused files from Makefile.vc (#175)
-2008-01-30 22:34 Ben Jubb <benjubb at refractions.net>
- * [r2120] Added documentation, for benefit of doxygen.
-2008-01-30 22:30 Ben Jubb <benjubb at refractions.net>
- * [r2119] deleted out-commented line.
-2008-01-30 22:29 Ben Jubb <benjubb at refractions.net>
- * [r2118] removed ref to PreparedPolygonLineIntersection
-2008-01-30 22:18 Ben Jubb <benjubb at refractions.net>
- * [r2117] Removed refs to PreparedPolygonLineIntersection.
-2008-01-30 22:17 Ben Jubb <benjubb at refractions.net>
- * [r2116] Deleted. not used, not needed.
-2008-01-30 19:09 Ben Jubb <benjubb at refractions.net>
- * [r2115] Added for benefit of doxygen.
-2008-01-29 17:55 Ben Jubb <benjubb at refractions.net>
- * [r2114] Some small changes to improve the memory management.
- These changes plug a few leaks, but not all.
-2008-01-29 17:49 Ben Jubb <benjubb at refractions.net>
- * [r2113] Fix a bug in the shortcut test for containment in a
- rectangle. This test wasn't correctly testing for case of a point
- on the boundary.
- Was also a bug in JTS (now fixed).
-2008-01-29 17:37 Ben Jubb <benjubb at refractions.net>
- * [r2112] Patch to fix bug in ticket #171
-2008-01-22 19:34 Ben Jubb <benjubb at refractions.net>
- * [r2111] Updated for VC to give correct version
- (3.1.0-CAPI-1.5.0).
-2008-01-18 00:37 Ben Jubb <benjubb at refractions.net>
- * [r2110] Added to CAPI interface, cleared CAPI_INTERFACE_REV,
- bumped AGE & CURRENT
-2008-01-18 00:35 Ben Jubb <benjubb at refractions.net>
- * [r2109] Fixed a bug in the handling of line strings with repeated
- points.
- -This line, and those below, will be ignored--
- M MonotoneChainBuilder.cpp
-2008-01-17 19:15 Ben Jubb <benjubb at refractions.net>
- * [r2108] Fixed a misspelling, GEOSPreparedContainsProperty =>
- GEOSPreparedContainsProperly
-2008-01-16 18:36 Frank Warmerdam <warmerdam at pobox.com>
- * [r2107] updated to include post 3.0 classes
-2008-01-09 23:49 Ben Jubb <benjubb at refractions.net>
- * [r2106] Added support for prepared geometry
-2008-01-09 23:48 Ben Jubb <benjubb at refractions.net>
- * [r2105] removed extraneous 'using namespace'
-2008-01-03 21:11 Ben Jubb <benjubb at refractions.net>
- * [r2104] commented out some delete's in
- MCIndexSegmentSetMutualIntersector::addToIndex, to fix a bug in
- prepared contains() predicate.
-2008-01-02 23:23 Sean Gillies <sgillies at frii.com>
- * [r2102] Conditionally add swig/python,ruby to SUBDIRS
-2007-12-22 00:04 Mateusz Loskot <mateusz at loskot.net>
- * [r2101] Updated configuration of experimental builder based on
- Boost.Build. GEOS compiles with bjam successfully as static
- library.
-2007-12-21 23:50 Mateusz Loskot <mateusz at loskot.net>
- * [r2100] Updated Visual C++ makefiles with new submissions from
- Ben. Now, new GEOS features compiles with NMAKE too.
-2007-12-21 23:31 Mateusz Loskot <mateusz at loskot.net>
- * [r2099] Removed SimplePointInAreaLocator.h from
- algorithm/Makefile.am (header migrated to algorithm/locate).
-2007-12-21 23:26 Mateusz Loskot <mateusz at loskot.net>
- * [r2098] Added comment about deprecated translation units in
- source/algorithm.
-2007-12-21 23:26 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2097] remove trailing backslash
-2007-12-21 23:21 Mateusz Loskot <mateusz at loskot.net>
- * [r2096] Updated svn:ignore property.
-2007-12-21 23:18 Mateusz Loskot <mateusz at loskot.net>
- * [r2095] Fixed extra qualifications in
- /geom/prep/PreparedPolygonContainsProperly.
-2007-12-21 23:12 Mateusz Loskot <mateusz at loskot.net>
- * [r2094] Fixed extra qualifications in PreparedGeometryFactory
- class.
-2007-12-21 22:57 Mateusz Loskot <mateusz at loskot.net>
- * [r2093] Fixed GeometryTypeId misused in
- geos/geom/util/ComponentCoordinateExtracter.h.
-2007-12-21 22:49 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2092] remove .cpp files that weren't there before
-2007-12-21 22:49 Mateusz Loskot <mateusz at loskot.net>
- * [r2091] Reverted changes appled in r2089 to three files from
- source/geom.
-2007-12-21 22:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2090] type subdir typo
-2007-12-21 22:43 Mateusz Loskot <mateusz at loskot.net>
- * [r2089] Updated svn:ignore property.
-2007-12-21 22:41 Mateusz Loskot <mateusz at loskot.net>
- * [r2088] Added missing <iostream> header to
- CustomPointCoordinateSequence.cpp.
-2007-12-21 22:40 Mateusz Loskot <mateusz at loskot.net>
- * [r2087] Removed unused SimplePointInAreaLocator.cpp. This unit
- migrated to algorithm/locate module.
-2007-12-21 22:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2086] Updated configure.in with new locations.
-2007-12-21 22:14 Mateusz Loskot <mateusz at loskot.net>
- * [r2085] Updated configure.in with new locations.
-2007-12-21 22:12 Mateusz Loskot <mateusz at loskot.net>
- * [r2084] Updated configure.in with new locations.
-2007-12-21 22:09 Mateusz Loskot <mateusz at loskot.net>
- * [r2083] Updated configure.in with new locations.
-2007-12-21 22:07 Mateusz Loskot <mateusz at loskot.net>
- * [r2082] Updated configure.in with new locations.
-2007-12-21 22:02 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2081] Add headers/geos/algorithm/locate to automake
-2007-12-21 22:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2080] Add files to automake
-2007-12-21 21:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2079] Added headers/index/intervalrtree to automake
-2007-12-21 21:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2078] Added headers/geom/prep headers/geom/util to automake
-2007-12-21 21:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2077] Added index/intervalrtree to automake
-2007-12-21 21:43 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2076] added geom/util/ComponentCoordinateExtracter.h
-2007-12-21 21:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2075] Add geom/prep to automake
-2007-12-21 21:36 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2074] Add algorithm/location to automake
-2007-12-21 21:31 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2073] Added new files
-2007-12-21 20:50 Ben Jubb <benjubb at refractions.net>
- * [r2072]
-2007-12-21 20:48 Ben Jubb <benjubb at refractions.net>
- * [r2071]
-2007-12-21 20:47 Ben Jubb <benjubb at refractions.net>
- * [r2070] Added from JTS 1.9 to support prepared geometry
- * [r2069] Added from JTS 1.9 to support prepared geometry
-2007-12-21 20:44 Ben Jubb <benjubb at refractions.net>
- * [r2068] Added from JTS 1.9 to support prepared geometry
- * [r2067] Added from JTS 1.9 to support prepared geometry
-2007-12-21 20:42 Ben Jubb <benjubb at refractions.net>
- * [r2066] modified because SimplePointInAreaLocator.h moved
-2007-12-21 20:41 Ben Jubb <benjubb at refractions.net>
- * [r2065] Added from JTS 1.9 to support prepared geometry
- * [r2064] Added from JTS 1.9 to support prepared geometry
-2007-12-21 20:40 Ben Jubb <benjubb at refractions.net>
- * [r2063] Added from JTS 1.9 to support prepared geometry
-2007-12-21 20:39 Ben Jubb <benjubb at refractions.net>
- * [r2062] modified because SimplePointInAreaLocator.h moved
-2007-12-21 20:38 Ben Jubb <benjubb at refractions.net>
- * [r2061] Moved into geos::algorithm::locate
-2007-12-21 20:37 Ben Jubb <benjubb at refractions.net>
- * [r2060] Added from JTS 1.9 to support prepared geometry
-2007-12-21 20:35 Ben Jubb <benjubb at refractions.net>
- * [r2059] Added from JTS 1.9 to support prepared geometry
-2007-12-21 20:34 Ben Jubb <benjubb at refractions.net>
- * [r2058] Added from JTS 1.9 to support prepared geometry
-2007-12-21 20:33 Ben Jubb <benjubb at refractions.net>
- * [r2057] changed destructor to be virtual
-2007-12-21 20:31 Ben Jubb <benjubb at refractions.net>
- * [r2056] Added a covers() predicate, from JTS 1.9, to support
- prepared geometry
-2007-12-21 20:30 Ben Jubb <benjubb at refractions.net>
- * [r2055] changed IsRectangle to be public
-2007-12-21 20:03 Ben Jubb <benjubb at refractions.net>
- * [r2054] Added a covers() predicate, from JTS 1.9, to support
- prepared geometry
-2007-12-21 20:00 Ben Jubb <benjubb at refractions.net>
- * [r2053] Moved from geos::algorithm as in JTS 1.9
-2007-12-21 19:55 Ben Jubb <benjubb at refractions.net>
- * [r2052] New namaspace geos::algorithm::locate, as in JTS 1.9..
-2007-12-21 19:52 Ben Jubb <benjubb at refractions.net>
- * [r2051] Added a public constructor, and a method to bring in line
- with JTS 1.9. Changed namespace to geos::algorithm::locate
-2007-12-21 18:44 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2050] version numbering for next release (3.1.0)
-2007-12-21 18:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2046] 3.0.0 release
-2007-12-19 20:18 Mateusz Loskot <mateusz at loskot.net>
- * [r2045] Improved warning message about using DEPRECATED headers
-2007-12-17 23:09 Mateusz Loskot <mateusz at loskot.net>
- * [r2044] Fixed std::tolower usage in XMLTester.cpp (Ticket #163).
-2007-12-17 23:05 Mateusz Loskot <mateusz at loskot.net>
- * [r2043] Replaced finite function with std::numeric_limits (Ticket
- #162).
-2007-12-17 21:52 Mateusz Loskot <mateusz at loskot.net>
- * [r2042] source\Makefile.vc: Fixed MSVC_VER condition for
- Microsoft Visual C++ 2008 (9.0).
-2007-12-13 16:11 Mateusz Loskot <mateusz at loskot.net>
- * [r2041] Added Id keyword at the top of ChangeLog file.
-2007-12-13 16:09 Mateusz Loskot <mateusz at loskot.net>
- * [r2040] * build\msvc80\geos_unit\geos_unit.vcproj: fixed
- post-build event
- * source\geom\GeometryCollection.cpp: removed unreachable code,
- shorten exception message.
- * source\geom\Geometry.cpp: purified condition based on
- dynamic_cast
- * tests\unit\geom\GeometryFactoryTest.cpp: use std::size_t
- instead of
- int where unsigned integral type required.
-2007-12-09 00:02 Mateusz Loskot <mateusz at loskot.net>
- * [r2038] Added test suite for class
- geos::precision::SimpleGeometryPrecisionReducer.
-2007-12-08 22:59 Mateusz Loskot <mateusz at loskot.net>
- * [r2037] Updated svn:keyword property.
-2007-11-26 16:26 Mateusz Loskot <mateusz at loskot.net>
- * [r2036] Added geos.vsprops - property sheet for Visual C++
- projects.
-2007-11-26 15:19 Mateusz Loskot <mateusz at loskot.net>
- * [r2035] Added common Property Sheet for Visual C++ projects where
- Python and Ruby macros/locations are defined. Fixed include of
- Python.h, see Ticket #164 for details.
-2007-11-26 06:21 Mateusz Loskot <mateusz at loskot.net>
- * [r2034] Updated svn:ignore patterns.
-2007-11-26 06:16 Mateusz Loskot <mateusz at loskot.net>
- * [r2033] Enabled target copying version.h.vc and geos_c.h.vc to
- headers used by Visual C++. Added test if version.h.vc is used
- with Visual C++.
-2007-11-23 02:33 Mateusz Loskot <mateusz at loskot.net>
- * [r2032] A bit of purification with explicit casting int to bool
- type.
-2007-11-02 22:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2031] urls updated to point to osgeo locations
-2007-11-02 22:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2030] add the web site content to svn for collaborative
- management
-2007-09-21 17:42 Charlie Savage <cfis at savagexi.com>
- * [r2029] Update the CAPI and GEOS version numbers based on
- Reader/Writer additions to the CAPI and EWKB support for the C++
- api.
-2007-09-21 17:40 Charlie Savage <cfis at savagexi.com>
- * [r2028] Updated the SWIG bindings and tests to use the new
- Reader/Writer classes exposed in the CAPI.
- * [r2027] Update the CAPI to expose WKTReader/WBTWriter and
- WKBReader/WBKWriter in the CAPI. This is an improvement over the
- existing API since it avoids the use of the static variable used
- to control byte order and # of dimenions, and gives clients more
- control over the creation/destruction of readers and writers.
- Finally, exposed the ability to output the EWKB format (set SRID
- to true in the WKBWriter).
-2007-09-21 17:35 Charlie Savage <cfis at savagexi.com>
- * [r2026] Switched back to using < because the fuzzy comparison now
- in use trips assertion errors in VC++. See comments in code for
- more information. Note this change may cause problems. Strk left
- a note in the code saying that the '<' comparison sometimes gives
- unstable results. But that seems better than an assertion
- failure.
-2007-09-21 17:32 Charlie Savage <cfis at savagexi.com>
- * [r2025] Updated the WKBWriter so it can output EWKB format
- similar to PostGIS. Also added a few getter/setter methods that
- allow clients to specify the reader's number of dimensions, byte
- order and whether srid values should be output. These
- getters/setters make it easier to wrap the reader in the CAPI.
-2007-09-14 15:34 Charlie Savage <cfis at savagexi.com>
- * [r2024]
- * [r2023] Told SVN to ignore MSCV++ Python swig build directories.
-2007-09-14 15:25 Charlie Savage <cfis at savagexi.com>
- * [r2022] Set unknown SRID values to 0 instead of -1 to be more
- consistent with the rest of GEOS (srid values are initialized to
- 0 by default).
-2007-09-11 02:02 Charlie Savage <cfis at savagexi.com>
- * [r2021] Don't include config.h for MSVC++ builds.
-2007-09-07 17:32 Charlie Savage <cfis at savagexi.com>
- * [r2020] The test for SWIG was incorrect. Fixed by patch from Mark
- Cave-Ayland.
-2007-09-06 23:24 Charlie Savage <cfis at savagexi.com>
- * [r2019] Applied patch from Mark Cave-Ayland's to make older
- versions of MingW that don't have struct timezone defined compile
- again. Also fixed issues with more recent versions of MingW that
- don't correctly compile with the -ansi compiler switch.
-2007-09-06 23:22 Charlie Savage <cfis at savagexi.com>
- * [r2018] Applied patches from Mark Cave-Ayland's that
- reorganize/improve the SWIG support in the generated configure
- file.\
-2007-08-31 20:44 Charlie Savage <cfis at savagexi.com>
- * [r2017] For MSVC++ builds the CAPI version was set in geos_c.cpp
- instead of geos_c.h and it was set incorrectly. This patch fixes
- the MSVC++ version number and centralizes the various versoin
- #defines in the geos_c.h.
-2007-08-31 20:18 Charlie Savage <cfis at savagexi.com>
- * [r2016] Update swig makefiles to make the wrappers dependent on
- the SWIG interface files even if SWIG is disabled. Doing this
- means that Make will correctly recognize that a user has modified
- an I file, but that the .cxx wrapper cannot be regenerated since
- SWIG is not available.
-2007-08-30 20:06 Charlie Savage <cfis at savagexi.com>
- * [r2015] MingW now includes the gettimeofday function - so
- reworked includes to only use custom version when building with
- VC++.
-2007-08-30 17:00 Charlie Savage <cfis at savagexi.com>
- * [r2014] Added RUBY_BIN_DIR to autoconf macros - simplified auto
- make input file for ruby bindings.
-2007-08-30 06:19 Charlie Savage <cfis at savagexi.com>
- * [r2013] The last attempt to fix this file failed - instead keep
- the code that queries the swig libraries but use sed to merge
- multiple lines together. If this is not done, then the swig
- output causes ./configure to blow up on msys.
-2007-08-30 05:31 Charlie Savage <cfis at savagexi.com>
- * [r2012] Fixes sed issue with swig on msys. For more info see:
- http://lists.refractions.net/pipermail/geos-devel/2007-August/002956.html
-2007-08-30 03:18 Charlie Savage <cfis at savagexi.com>
- * [r2011] Changed from dos to unix line feeds.
-2007-08-29 01:41 Charlie Savage <cfis at savagexi.com>
- * [r2010] New VC++ project for the python SWIG bindings.
-2007-08-29 01:29 Charlie Savage <cfis at savagexi.com>
- * [r2009] Ruby SWIG bindings - mapped eql? to == so that you can do
- point == point2 in ruby. Removed a hard-coded path from VC++
- project. Updated out-of-date copyright notices for no
- particularly good reason.
-2007-08-28 21:29 Charlie Savage <cfis at savagexi.com>
- * [r2008] Added release as an ignored directory for VC++, similar
- to the debug directory.
-2007-08-28 21:28 Charlie Savage <cfis at savagexi.com>
- * [r2007] Added new ruby VC++ project to solution file.
-2007-08-28 21:27 Charlie Savage <cfis at savagexi.com>
- * [r2006] Fixed c api include for VC++ - it should be #include
- <geos/version.h> instead of #include <version.h>.
- * [r2005] Added new ruby VC++ project to solution file.
-2007-08-28 21:26 Charlie Savage <cfis at savagexi.com>
- * [r2004] Follow lead of geos_lib project - copy geos/geos_c.h.in
- to geos/geos_c.h when building with VC++.
-2007-08-28 21:25 Charlie Savage <cfis at savagexi.com>
- * [r2003] Added new vc++ project for building ruby bindings. Its
- not perfect since it hard-codes the path to Ruby, but its enough
- to get one started.
-2007-08-28 21:22 Charlie Savage <cfis at savagexi.com>
- * [r2002] Updated SWIG wrappers based on changed interface file.
- Also generated with SWIG 1.3.31
-2007-08-28 20:42 Charlie Savage <cfis at savagexi.com>
- * [r2001] SWIG bindings - updated Ruby tests based on name changes.
-2007-08-28 20:41 Charlie Savage <cfis at savagexi.com>
- * [r2000] Updated Ruby swig bindings to more closely match Ruby
- style names. So eql? instead of equals, dimensions instead of
- get_dimensions, etc.
-2007-08-28 20:40 Charlie Savage <cfis at savagexi.com>
- * [r1999] Exposed Geometry::Clone method in SWIG bindings. Added
- check for NULL string in geomFromWKT wrapper.
-2007-08-23 20:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r1998] Memory leak patches from Robert Coup
-2007-08-22 23:45 Mateusz Loskot <mateusz at loskot.net>
- * [r1997] Cleaned compilation warnings from VC++.
-2007-06-11 07:43 Mateusz Loskot <mateusz at loskot.net>
- * [r1996] Replaced post-increment operators with pre-increment
- operators where standard iterators are incremented in loops.
- NOTE: Prefer pre-incr. over post-inc. when working with standard
- iterators.
-2007-06-11 07:39 Mateusz Loskot <mateusz at loskot.net>
- * [r1995] Added unit test for geos::operation::IsSimpleOp class.
-2007-06-10 13:03 Mateusz Loskot <mateusz at loskot.net>
- * [r1994] Updated tests/unit/Makefile.am with new files.
-2007-06-10 11:53 Mateusz Loskot <mateusz at loskot.net>
- * [r1993] Added unit test for
- geos::algorithm::CGAlgorithms::computeOrientation() function.
-2007-06-10 11:29 Mateusz Loskot <mateusz at loskot.net>
- * [r1992] Updated svn:ignore property for the whole tree adding
- VC++ and Windows specific patterns.
-2007-06-10 11:18 Mateusz Loskot <mateusz at loskot.net>
- * [r1991] Added unit test for CGAlgorithms::isCCW() function.
-2007-06-10 11:08 Mateusz Loskot <mateusz at loskot.net>
- * [r1990] Added unit test for geos::algorithm::ConvexHull.
-2007-06-10 11:03 Mateusz Loskot <mateusz at loskot.net>
- * [r1989] Added custom operators for static and dynamic casts of
- pointers wrapped with std::auto_ptr<T> type.
-2007-06-08 17:13 Mateusz Loskot <mateusz at loskot.net>
- * [r1988] Identified test case failing because of
- geos::index::strtree::yComparator() instability.
-2007-06-08 17:10 Mateusz Loskot <mateusz at loskot.net>
- * [r1987] Analysis of instability of the yComparator, there are
- some new important questions to answer.
-2007-06-08 15:27 Mateusz Loskot <mateusz at loskot.net>
- * [r1986] Cleaned signed/unsigned types mixtures, got rid from
- annoying compiler warnings.
-2007-06-08 14:50 Mateusz Loskot <mateusz at loskot.net>
- * [r1985] Applied Konstantin Baumann's suggestion about including
- version.h in C API header for Visual C++.
- * [r1984] Applied Konstantin Baumann's suggestion about including
-2007-06-01 13:53 Mateusz Loskot <mateusz at loskot.net>
- * [r1983] Added Boost.Build configuration for GEOS (experimental).
- The idea is to enable users to build GEOS with bjam tool from
- Boost.Build package.
-2007-06-01 13:43 Mateusz Loskot <mateusz at loskot.net>
- * [r1982] Set missing svn:keywords property.
-2007-06-01 13:06 Mateusz Loskot <mateusz at loskot.net>
- * [r1981] Applied patch with pre-build events generating platform.h
- and version.h headers. Thanks to Konstantin Baumann for this
- patch.
-2007-05-06 02:42 Mateusz Loskot <mateusz at loskot.net>
- * [r1980] Updated svn:ignore property for build\msvc80.
-2007-05-06 02:40 Mateusz Loskot <mateusz at loskot.net>
- * [r1979] Added source/headers/geos/version.h.vc file for Visual
- C++ compiler.
-2007-04-22 04:44 Mateusz Loskot <mateusz at loskot.net>
- * [r1978] Added assertion validating ordinateIndex in setOrdinate()
- function. Extended GEOSCoordSeqTest with swapped and non-swapped
- calls of coordiantes assignment functions.
-2007-04-15 18:02 Mateusz Loskot <mateusz at loskot.net>
- * [r1977] Added detection of glibtoolize under Mac OS X.
-2007-03-05 09:58 Sandro Santilli <strk at keybit.net>
- * [r1976] Add new testcases by Carl Anderson
-2007-02-26 10:46 Sandro Santilli <strk at keybit.net>
- * [r1975] Patch by Tom Elwertowski:
- * source/inlines.cpp: fix for MingW32 builds.
-2007-02-21 10:14 Sandro Santilli <strk at keybit.net>
- * [r1974] Patch by Carl Anderson:
- * source/operation/buffer/SubgraphDepthLocater.cpp
- (findStabbedSegments):
- Implement short-circuit to avoid inner defective
- logic.
- Fixes badguy3.xml
-2007-02-21 10:12 Sandro Santilli <strk at keybit.net>
- * [r1973] * tests/xmltester/: Makefile.am, badguy3.xml:
- Added simplified version of nasty buffer bug test.
-2007-02-08 23:33 Sandro Santilli <strk at keybit.net>
- * [r1972] Patch by Mark Cave-Ayland:
- * configure.in: Allow configure to continue with use_python
- set to false if a python binary is not found, as per
- http://sources.redhat.com/automake/automake.html#Python.
-2007-02-07 00:34 Sandro Santilli <strk at keybit.net>
- * [r1971] General refactoring aimed at making the code cleaner
- to read and maintain; use iterators rather then random
- accessing containers to allow easy future switch to std::list
- from std::vector; use a tolerance-based strict weak ordering
- operator for sorting child boundables in STRtree, this
- fixes the heisenbug when building with inlines disabled.
-2007-02-06 02:05 Sandro Santilli <strk at keybit.net>
- * [r1970] * tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp:
- Expect result of POLYGON simplification to always be
- a polygon, even if collapsed to the empty geom.
-2007-02-06 01:57 Sandro Santilli <strk at keybit.net>
- * [r1969] * operation::buffer::BufferBuilder,
- operation::buffer::BufferOp:
- Fixed buffer operation to always return polygonal
- geometry
-2007-02-03 02:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r1967] 3.0.0rc4 tagging
-2007-02-01 11:11 Sandro Santilli <strk at keybit.net>
- * [r1966] * operation::buffer::BufferOp: set MAX_PRECISION_DIGITS
- so to match JTS.
-2007-01-26 01:19 Sandro Santilli <strk at keybit.net>
- * [r1965] * tests/xmltester/: Makefile.am,
- stmlf-cases-20070119.xml:
- New overlay test.
-2007-01-26 00:57 Sandro Santilli <strk at keybit.net>
- * [r1964] * tests/xmltester/XMLTester.cpp: improved buffer
- result validator.
- * source/operation/buffer/BufferBuilder.cpp (computeNodedEdges):
- remove repeated points from noded SegmentStrings, skip collapsed
- edges.
-2007-01-17 11:59 Sandro Santilli <strk at keybit.net>
- * [r1963] New testcase for bug fixed by previous commit.
-2007-01-17 01:05 Sandro Santilli <strk at keybit.net>
- * [r1962] * source/index/strtree/STRtree.cpp (yComparator):
- Use static_cast<> and make code more readable.
- A side effect seems to be fixing a segfault :!
-2007-01-17 00:45 Sandro Santilli <strk at keybit.net>
- * [r1961] * source/headers/geos/index/strtree/STRtree.h (centreY):
- const-corrected.
-2007-01-16 14:12 Sandro Santilli <strk at keybit.net>
- * [r1960] * tests/xmltester/XMLTester.cpp: don't include catch-all
- headers.
-2007-01-09 17:34 Sandro Santilli <strk at keybit.net>
- * [r1959] * source/operation/buffer/: Makefile.am,
- OffsetCurveVertexList.h:
- New helper class for OffsetCurveBuilder
- * operation::buffer::OffsetCurveBuilder:
- Move vertexlist management to external class.
- * tests/xmltester/: Makefile.am, TestBufferExternal.xml:
- added test for above changes (imported from JTS and
- modified to work with GEOS).
- * tests/xmltester/XMLTester.cpp: change buffer
- validator again: check area of topological
- difference between expected and obtained result
- to be smaller then 1/1000 of expected geometry
- area.
-2007-01-09 15:08 Sandro Santilli <strk at keybit.net>
- * [r1958] * source/geom/CoordinateArraySequence.cpp,
- source/headers/geos/geom/CoordinateSequence.h,
- source/headers/geos/geom/CoordinateArraySequence.h:
- add(Coordinate, bool) made a virtual method and overrridden
- for CoordinateArraySequence, for better performance
- (single virtual call vs. multiple); added front() and
- back() methods.
-2007-01-09 10:27 Sandro Santilli <strk at keybit.net>
- * [r1957] * tests/xmltester/XMLTester.cpp: add areatest to buffer
- test handler.
-2007-01-05 01:01 Sandro Santilli <strk at keybit.net>
- * [r1956] * configure.in: prepared for version to 3.0.0rc4,
- fixed swig python errors as suggested by hint
- (AM_PATH_PYTHON).
-2007-01-04 22:43 Sandro Santilli <strk at keybit.net>
- * [r1955] * configure.in, swig/geos.i.in, swig/geos.i:
- geos.i generated at configure time from geos.i.in
- (so we don't have to manually update versions there).
-2007-01-04 22:38 Sandro Santilli <strk at keybit.net>
- * [r1954] Patch by dev-zero at gentoo dot org:
- * swig/geos.i: use unsigned int when CAPI signatures
- expect unsigned int (not size_t).
-2007-01-03 20:11 Sandro Santilli <strk at keybit.net>
- * [r1953] * tests/xmltester/: fme.xml, Makefile.am: added buffer
- testcase.
-2007-01-03 20:06 Sandro Santilli <strk at keybit.net>
- * [r1952] * tests/xmltester/XMLTester.cpp: use a tolerance of 10E-6
- for buffer validation (~10cm at worst when using latlong
- projections); create sql tables with oid to work around a
- bug in qgis 0.7.4.
-2007-01-03 19:18 Sandro Santilli <strk at keybit.net>
- * [r1951] Applied patch by Mark Cave-Ayland
- <mark.cave-ayland at ilande.co.uk>:
- * source/inlines.cpp, source/algorithm/HCoordinate.cpp:
- Fixes for MingW builds. See geos-devel/2007-January/002766.html.
-2007-01-03 14:56 Sandro Santilli <strk at keybit.net>
- * [r1950] * source/operation/buffer/BufferOp.cpp
- (bufferReducedPrecision):
- Fixed computation of reduced PrecisionModel scale.
-2006-12-18 20:04 Sandro Santilli <strk at keybit.net>
- * [r1949] * tests/xmltester/robustness.xml: added
- testcase reported to fail with 2.2.3 on
- postgis-users/2006-November/014013.html.
-2006-12-18 18:44 Sandro Santilli <strk at keybit.net>
- * [r1948] Geometry snapping synced with JTS.
-2006-12-18 14:27 Sandro Santilli <strk at keybit.net>
- * [r1947] * HOWTO_RELEASE: add ChangeLog's release mark step.
-2006-12-18 14:19 Sandro Santilli <strk at keybit.net>
- * [r1946] * source/precision/GeometrySnapper.cpp
- (computeSnapTolerance):
- properly compute snap tolerance for fixed precision geometries.
- * tests/xmltester/: Makefile.am, TestRobustOverlayFixed.xml:
- new test for fixed precision snapping.
-2006-12-15 10:50 Sandro Santilli <strk at keybit.net>
- * [r1945] release 3.0.0rc3 marked
-2006-12-14 19:12 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r1943] bumped version numbers for 3.0.0rc3
-2006-12-13 11:05 Mateusz Loskot <mateusz at loskot.net>
- * [r1942] Updated makefile and project files for Visual C++.
-2006-12-13 10:55 Sandro Santilli <strk at keybit.net>
- * [r1941] Updated port information.
-2006-12-13 10:51 Sandro Santilli <strk at keybit.net>
- * [r1940] * precision::GeometrySnapper,
- precision::LineStringSnapper:
- Updated port information.
-2006-12-11 17:42 Sandro Santilli <strk at keybit.net>
- * [r1939] * source/headers/geos/noding/SegmentIntersector.h: added
- virtual
- isDone() function, always returning false by default.
- * source/noding/MCIndexNoder.cpp (intersectChains):
- short-circuit from JTS-1.8, based on the new
- SegmentIntersector::isDone() method.
- * source/noding/Makefile.am,
- source/noding/FastNodingValidator.cpp,
- source/noding/SingleInteriorIntersectionFinder.cpp,
- source/headers/geos/noding/Makefile.am,
- source/headers/geos/noding/FastNodingValidator.h,
- source/headers/geos/noding/SingleInteriorIntersectionFinder.h:
- New ports from JTS-1.8-cvs.
- * source/headers/geos/geomgraph/EdgeNodingValidator.h:
- use a FastNodingValidator rather then a simple NodingValidator.
-2006-12-07 10:45 Sandro Santilli <strk at keybit.net>
- * [r1938] * source/headers/geos/algorithm/:
- CentralEndpointIntersector.h,
- Makefile.am: new port from JTS-1.8.
- * algorithm::LineIntersector: robustness improvements
- from JTS-1.8.
-2006-12-05 11:22 Mateusz Loskot <mateusz at loskot.net>
- * [r1937] Fixed indentantion in tests/unit/capi.
-2006-12-05 11:10 Mateusz Loskot <mateusz at loskot.net>
- * [r1936] Fixed typos in changelog.
-2006-12-05 11:05 Mateusz Loskot <mateusz at loskot.net>
- * [r1935] Set svn:keyword property on CAPI tests.
-2006-12-05 11:02 Mateusz Loskot <mateusz at loskot.net>
- * [r1934] Purifying CAPI unit tests.
-2006-12-05 10:59 Mateusz Loskot <mateusz at loskot.net>
- * [r1933] Added CAPI tests to VC++ project.
-2006-12-05 10:42 Sandro Santilli <strk at keybit.net>
- * [r1932] * source/operation/overlay/OverlayOp.cpp: Use
- EdgeNodingValidator
- instead of OverlayResultValidator (faster and more effective).
- Note that compile-time defines can select use of either or both
- ones.
- * source/headers/geos/geom/BinaryOp.h: be quiet if not in DEBUG
- mode.
-2006-12-05 09:59 Sandro Santilli <strk at keybit.net>
- * [r1931] * noding::NodingValidator.h: throw TopologyException
- rather then a generic GEOSException.
-2006-12-04 12:41 Sandro Santilli <strk at keybit.net>
- * [r1930] * source/headers/geos/geomgraph/EdgeNodingValidator.h:
- fix members initialization order.
-2006-12-04 11:38 Sandro Santilli <strk at keybit.net>
- * [r1929] * geomgraph::EdgeNodingValidator: minor cleanup
- to use references args instead of pointers for
- method that doesn't handle NULLs anyway.
-2006-12-04 10:31 Sandro Santilli <strk at keybit.net>
- * [r1928] * tests/unit/capi/: GEOSCoordSeq.cpp =>
- GEOSCoordSeqTest.cpp
- * tests/unit/capi/GEOSSimplifyTest.cpp: new test
- for GEOSSimplify (just a test for bug #134).
- * source/simplify/DouglasPeuckerLineSimplifier.cpp (simplify):
- don't try to simplify empty coordinate lists. Fixes bug #134.
-2006-12-04 10:14 Sandro Santilli <strk at keybit.net>
- * [r1927] Other tests using setOrdinate instead of set{X,Y,Z}
-2006-12-04 10:12 Sandro Santilli <strk at keybit.net>
- * [r1926] * source/geom/CoordinateArraySequence.cpp (setOrdinate):
- fix bug #133.
-2006-12-04 10:00 Sandro Santilli <strk at keybit.net>
- * [r1925] * tests/unit/capi/GEOSCoordSeq.cpp: add test for bug #133
- (failing).
-2006-12-04 09:57 Sandro Santilli <strk at keybit.net>
- * [r1924] * tests/unit/geom/CoordinateArraySequenceTest.cpp: added
- tests for setOrdinate()
-2006-11-30 14:49 Sandro Santilli <strk at keybit.net>
- * [r1923] * tests/unit/: Makefile.am, capi/GEOSCoordSeq.cpp:
- new experimental test for C-API GEOSCoordSeq.
- * capi/geos_c.cpp (GEOSCoordSeq_create): removed
- suspicious static cast.
-2006-11-28 19:13 Mateusz Loskot <mateusz at loskot.net>
- * [r1922] Added Visual C++ 2005 project files.
-2006-11-23 20:17 Sandro Santilli <strk at keybit.net>
- * [r1921] * source/geom/Point.cpp (equalsExact): don't segfault on
- empty points. Fixes bug #132.
-2006-11-23 12:25 Sandro Santilli <strk at keybit.net>
- * [r1920] Added short descripion of testcases provenience
-2006-11-22 20:29 Sandro Santilli <strk at keybit.net>
- * [r1919] * tests/xmltester/: stmlf-cases-20061020.xml,
- Makefile.am: add more robustness testcases.
-2006-11-22 12:26 Sandro Santilli <strk at keybit.net>
- * [r1918] Patch by dron at ak4719.spb.edu:
- * autogen.sh: call 'autoheader' after 'aclocal'.
- Fixes bug #131
-2006-11-18 15:30 Mateusz Loskot <mateusz at loskot.net>
- * [r1917] Fixed path to geos_c.h in source/makefile.vc.
-2006-11-15 18:26 Sandro Santilli <strk at keybit.net>
- * [r1916] * configure.in: don't generate geos_c.h.vc
- * source/Makefile.vc: don't generate geos_c.h and version.h
- * source/headers/geos/version.h.vc, capi/geos_c.h.vc.in:
- removed, will NOT be needed by Makefile.vc
- * source/headers/geos/Makefile.am: distribute version.h
- * capi/Makefile.am: distribute geos_c.h
-2006-11-15 14:42 Sandro Santilli <strk at keybit.net>
- * [r1915] * capi/geos_c.h.in: hopefully fixed GEOS_DLL use.
-2006-11-15 11:28 Sandro Santilli <strk at keybit.net>
- * [r1914] * capi/geos_c.cpp (GEOSGeom_getDimensions): Fix a
- segfault on empty geometry input (fix bug #126).
-2006-11-11 05:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r1913] Retreived original .vc file and put in MACRO
- substitutions. Somehow GNU version replaced .vc version during
- file shuffles to get macros in.
-2006-11-10 18:24 Sandro Santilli <strk at keybit.net>
- * [r1912] fixed timewarp
-2006-11-10 17:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r1911] noted .vc change
-2006-11-10 17:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r1910] Made sure geos_c.h.vc is part of 'make dist' since VC
- users won't have .configure
-2006-11-10 17:38 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r1909] Added substitution strings to .in files for .vc
- generation.
-2006-11-10 17:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r1908] Changes for capi .vc generation
-2006-11-10 14:50 Howard Butler <hobu.inc at gmail.com>
- * [r1907] update
-2006-11-09 09:10 Sandro Santilli <strk at keybit.net>
- * [r1906] * test/xmltester/XMLTester.cpp: improved 'testarea' test.
-2006-11-08 11:54 Sandro Santilli <strk at keybit.net>
- * [r1905] added 'release-separator' tag
-2006-11-08 11:51 Sandro Santilli <strk at keybit.net>
- * [r1904] * tests/xmltester/robustness.xml: made test safe to
- run by using the new 'areatest' operation; added
- new testcases just raised on the mailing list.
- * tests/xmltester/Makefile.am: robustness.xml is now safe
- to run, so run it on make check.
-2006-11-08 10:40 Sandro Santilli <strk at keybit.net>
- * [r1903] * source/headers/geos/geom/BinaryOp.h: enable
- COMMONBITS-removal heuristic so it is attempted
- before geometry snapping.
-2006-11-05 20:34 Sandro Santilli <strk at keybit.net>
- * [r1900] * capi/Makefile.am: distribute files needed for testing,
- proper cleanup (make distcheck works now)
-2006-11-05 00:24 Charlie Savage <cfis at savagexi.com>
- * [r1899] Updated ruby swig wrapper for changes in header files.
- * [r1898] Updated python swig wrapper for changes in header files.
-2006-11-05 00:23 Charlie Savage <cfis at savagexi.com>
- * [r1897] Fixes for changes in header files.
-2006-11-03 12:35 Sandro Santilli <strk at keybit.net>
- * [r1896] redirect 'diff' output to stderr
-2006-11-03 10:54 Sandro Santilli <strk at keybit.net>
- * [r1895] hopefully fixed proper quoting
-2006-11-03 10:30 Sandro Santilli <strk at keybit.net>
- * [r1894] Report non-zero return from ./geostest run
-2006-11-02 10:08 Sandro Santilli <strk at keybit.net>
- * [r1893] * source/headers/geos/geom/BinaryOp.h: disable debugging
- output by default.
-2006-11-02 10:02 Sandro Santilli <strk at keybit.net>
- * [r1892] * capi/geostest.c: updated to use the new GEOSGeometry
- typedef, so to build w/out warnings and fully respecting current
- const specification.
-2006-11-02 09:48 Sandro Santilli <strk at keybit.net>
- * [r1891] * capi/geos_c.cpp, capi/geos_c.h.in: const-corrected and
- documented GEOSPolygonize function.
-2006-11-02 09:38 Sandro Santilli <strk at keybit.net>
- * [r1890] * capi/test.expected: updated expected version
- * capi/testrunner.sh: be happy with geostest running w/out
- segfaulting, still run diff for reference.
-2006-11-02 09:33 Sandro Santilli <strk at keybit.net>
- * [r1889] * configure.in: updated versions to 3.0.0rc2 / CAPI-1.3.0
-2006-11-02 08:32 Sandro Santilli <strk at keybit.net>
- * [r1888] Patch by Markus Schaber <schabi at logix-tt.com>:
- * capi/geos_c.h.in: add GEOSGeometry and GEOSCoordSequence
- typedef, to unhide the pointer type and allow fine-grained
- const specification, use the new typedefs in function signatures
- (fix some const-specifications accordingly)
- * capi/geos_c.cpp: define GEOSGeometry and GEOSCoordSequence
- for cross-checking of types in header.
-2006-10-30 15:14 Sandro Santilli <strk at keybit.net>
- * [r1887] Patch by Markus Schaber <schabi at logix-tt.com>
- * capi/geos_c.cpp: more focused 'using' directives.
- * capi/geos_c.h.in: let the enum visible by geos_c.cpp
- now that there are no more name clashes.
-2006-10-30 13:20 Sandro Santilli <strk at keybit.net>
- * [r1886] removed useless GEOSGeomTypes define
-2006-10-30 13:00 Sandro Santilli <strk at keybit.net>
- * [r1885] reduce default verbosity
-2006-10-30 12:49 Sandro Santilli <strk at keybit.net>
- * [r1884] * capi/geos_c.cpp:
- Remove a typedef which is also included via Header;
- Use dynamic_cast instead of C cast in 2 cases to allow the RTTI
- type check;
- Replace "geoms" temp vector in polygonizer function with a loop,
- this saves us at least one of the two vector copies;
- Drop 2 unneded const_cast occurences;
- Allow calling getNumGeometries against non-collections;
- 2 comment / whitespace cleanups.
- Added a comment explaining ou #ifndef magic;
- Unified the two #ifndef into a single one.
-2006-10-30 10:29 Sandro Santilli <strk at keybit.net>
- * [r1883] * capi/: test.expected, testrunner.sh, Makefile.am: Added
- a run of ./geostest as part of 'make check'
-2006-10-30 10:15 Sandro Santilli <strk at keybit.net>
- * [r1882] Patch submitted by Markus Schaber <schabi at logix-tt.com> (
- reviewed and fixed )
- * capi/: geos_c.cpp, geos_c.h.in:
- Changed the C-API implementation to actually include the header
- that's included by the clients, this allows the compiler to check
- declarations and implementation for consistency, fixed geos_c.cpp
- accordingly (const-correctness, mainly).
-2006-10-30 09:49 Sandro Santilli <strk at keybit.net>
- * [r1881] * capi/geostest.c: added some checks of return from CAPI
- functions returning GEOSGeom (not all, just a few)
-2006-10-27 11:54 Sandro Santilli <strk at keybit.net>
- * [r1880] Patch by Markus Schaber <schabi at logix-tt.com>
- * algorithm::InteriorPointLine (ctor): take Geometry by
- const-pointer.
- * geom::Geometry (getInteriorPoint): made a const-method
- * operation::polygonize::Polygonizer: implement filter_ro rather
- then filter_rw, as it doesn't change the Geometry, propagated
- change to internal interfaces (add methods)
-2006-10-26 09:22 Sandro Santilli <strk at keybit.net>
- * [r1879] * capi/geos_c.h.in: reverted all changes of 'int' types
- to 'size_t' types (the lib never changed, and still expects
- ints)
-2006-10-24 16:54 Sandro Santilli <strk at keybit.net>
- * [r1878] * source/headers/geos/geom/BinaryOp.h: try original geoms
- first by default.
-2006-10-24 16:53 Sandro Santilli <strk at keybit.net>
- * [r1877] * operation::overlay::OverlayResultValidator.cpp
- (isValid): run the test even if inputs and output are not areal.
-2006-10-24 16:49 Sandro Santilli <strk at keybit.net>
- * [r1876] * operation::overlay::FuzzyPointLocator: eliminate
- non-polygonal components from consideration when testing the
- location of points.
-2006-10-24 10:16 Sandro Santilli <strk at keybit.net>
- * [r1875] * precision::GeometrySnapper: snapPrecisionFactor
- augmented from 10e-12 to 10e-10.
-2006-10-24 09:49 Sandro Santilli <strk at keybit.net>
- * [r1874] * precision::LineStringSnapper (findSegmentToSnap):
- return the *closest* segment, don't snap if the closest
- segment *intersects* the snap points, consider a distance
- of exactly snapTolerance as non-tolerated (got in sync with JTS)
-2006-10-23 10:23 Sandro Santilli <strk at keybit.net>
- * [r1873] * source/headers/geos/geom/BinaryOp.h (SnapOp): document
- and add optional CBR step (snap after applying common bits
- removal - this is the default); (check_valid): add validity
- checker function.
-2006-10-20 11:18 Sandro Santilli <strk at keybit.net>
- * [r1872] * noding::SegmentString: added notifyCoordinatesChange
- method.
- * noding::ScaledNoder: notify possible coordinates change to
- SegmentString after removing repeated points.
-2006-10-19 18:26 Sandro Santilli <strk at keybit.net>
- * [r1871] * configure.in: use 'expr' for arithmetics (more
- portable)
-2006-10-18 19:21 Mateusz Loskot <mateusz at loskot.net>
- * [r1870] Refactored Visual C++ makefiles.
-2006-10-18 17:53 Mateusz Loskot <mateusz at loskot.net>
- * [r1869] Updated source\makefile.vc and source\dirlist.mk files.
- * [r1868] Added top-level makefile.vc.
-2006-10-18 14:28 Sandro Santilli <strk at keybit.net>
- * [r1867] fixed svn:ignore property
-2006-10-18 12:08 Sandro Santilli <strk at keybit.net>
- * [r1866] disable non-JTS overlay result validators (to more
- closely track JTS at this stage)
-2006-10-17 14:26 Sandro Santilli <strk at keybit.net>
- * [r1865] * source/headers/geos/geom/BinaryOp.h (SnapOp): fixed
- horrible
- bug applying overlay of first geom to itself :(
-2006-10-17 10:15 Sandro Santilli <strk at keybit.net>
- * [r1864] really fixed 'extra tokens at end of #endif directive'
- warning
-2006-10-17 10:10 Sandro Santilli <strk at keybit.net>
- * [r1863] fixed 'extra tokens at end of #endif directive' warning
-2006-10-17 08:44 Sandro Santilli <strk at keybit.net>
- * [r1862] * capi/Makefile.am: don't directly link geostest against
- both libgeos.so and libstdc++ (should be derived by
- libgeos_c.so).
-2006-10-12 15:33 Sandro Santilli <strk at keybit.net>
- * [r1861] * tests/bigtest/GeometryTestFactory.cpp,
- tests/bigtest/bigtest.h, tests/bigtest/TestSweepLineSpeed.cpp:
- fixed header inclusion, to reduce compiler noise.
-2006-10-09 16:39 Sandro Santilli <strk at keybit.net>
- * [r1860] * source/headers/geos/geom/BinaryOp.h: always snap geoms
- to each-other before applying an overlay (temp hack).
-2006-10-09 16:35 Sandro Santilli <strk at keybit.net>
- * [r1859] * source/operation/overlay/OverlayOp.cpp: enable all
- overlay result validators, make it disablable at compile time.
-2006-10-05 10:58 Mateusz Loskot <mateusz at loskot.net>
- * [r1858] Added inclusion guards to geos_c.h files.
-2006-10-05 09:46 Sandro Santilli <strk at keybit.net>
- * [r1857] increment areatest verbosity (needs -v -v)
-2006-10-02 18:53 Howard Butler <hobu.inc at gmail.com>
- * [r1856] GEOSEnvelope wasn't in the PROTOTYPES section in
- geos_c.cpp
-2006-09-27 07:48 Sandro Santilli <strk at keybit.net>
- * [r1855] updated tag item
-2006-09-27 07:43 Sandro Santilli <strk at keybit.net>
- * [r1854] added info about svn tags
-2006-09-19 06:54 Sandro Santilli <strk at keybit.net>
- * [r1853] Added <algorithm> include
-2006-09-08 23:13 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r1851] Added information about funders of the 3.0.0 series: Safe
- Software, Autodesk,
- Bavarian State Ministry of Agriculture and Forestry and the State
- Survey of Bavaria.
-2006-09-08 09:38 Sandro Santilli <strk at keybit.net>
- * [r1850] updated
-2006-09-08 09:31 Sandro Santilli <strk at keybit.net>
- * [r1849] more debugging output
-2006-09-08 09:21 Sandro Santilli <strk at keybit.net>
- * [r1848] More testcases
-2006-09-07 18:07 Sandro Santilli <strk at keybit.net>
- * [r1847] New unit test for OverlayResultValidator class
- * [r1846] more debugging output
-2006-09-07 17:52 Sandro Santilli <strk at keybit.net>
- * [r1845] Added addVertices private method (unused, as in JTS, but
- possibly useful in the future)
-2006-09-07 17:41 Sandro Santilli <strk at keybit.net>
- * [r1844] Added debugging code
-2006-09-07 17:35 Sandro Santilli <strk at keybit.net>
- * [r1843] more testcases (added test for max distance of offset
- points)
-2006-09-07 15:28 Sandro Santilli <strk at keybit.net>
- * [r1842] removed svn:executable prop from all .cpp files
-2006-09-07 15:22 Sandro Santilli <strk at keybit.net>
- * [r1841] removed svn:executable property
-2006-09-07 15:21 Sandro Santilli <strk at keybit.net>
- * [r1840] testing execute bit state
-2006-09-07 12:17 Mateusz Loskot <mateusz at loskot.net>
- * [r1839] Set svn:keyword for $ expansion.
-2006-09-07 11:34 Sandro Santilli <strk at keybit.net>
- * [r1838] Cleaned up OverlayResultValidator call (still disabled
- due to bugs)
-2006-09-07 11:27 Sandro Santilli <strk at keybit.net>
- * [r1837] blindly return positive result if any input or output is
- not an area
-2006-09-07 11:08 Sandro Santilli <strk at keybit.net>
- * [r1836] new test for FuzzyPointLocator
-2006-09-07 10:30 Sandro Santilli <strk at keybit.net>
- * [r1835] Explicit values to LocationValue enum items. Removed CVS
- Log
-2006-09-07 09:33 Sandro Santilli <strk at keybit.net>
- * [r1834] Removed catch-all headers inclusion and use of obsoleted
- Unload class
-2006-09-07 09:24 Sandro Santilli <strk at keybit.net>
- * [r1833] updated
-2006-09-07 09:23 Sandro Santilli <strk at keybit.net>
- * [r1832] comment cleanup
-2006-09-07 09:01 Sandro Santilli <strk at keybit.net>
- * [r1831] Comments about ownership (and lifetime) of returned
- objects
-2006-09-07 08:59 Sandro Santilli <strk at keybit.net>
- * [r1830] New DistanceOp unit test
-2006-09-07 08:57 Sandro Santilli <strk at keybit.net>
- * [r1829] (computeMinDistancePoints): fixed invalid reference.
-2006-09-07 08:23 Sandro Santilli <strk at keybit.net>
- * [r1828] don't giveup on automake failures (testing)
-2006-09-06 18:44 Sandro Santilli <strk at keybit.net>
- * [r1827] Ops, overlay result validation erroenously committed
-2006-09-06 18:41 Sandro Santilli <strk at keybit.net>
- * [r1826] new test for OffsetPointGenerator class
-2006-09-06 18:37 Sandro Santilli <strk at keybit.net>
- * [r1825] Fixed uninitialized memory bug
-2006-09-06 17:59 Sandro Santilli <strk at keybit.net>
- * [r1824] new test for FuzzyPointLocator class
-2006-09-06 17:48 Sandro Santilli <strk at keybit.net>
- * [r1823] updated after GeometrySnapper interface change.
-2006-09-06 17:26 Mateusz Loskot <mateusz at loskot.net>
- * [r1822] Set $ expansion for new files in 'overlay' module.
-2006-09-06 17:22 Sandro Santilli <strk at keybit.net>
- * [r1821] Rest of Overlay validation classes.
-2006-09-06 16:54 Mateusz Loskot <mateusz at loskot.net>
- * [r1820] Set svn:keyword property for Id keyword expansion.
-2006-09-06 15:50 Sandro Santilli <strk at keybit.net>
- * [r1819] Fixed comments and includes
-2006-09-06 15:33 Sandro Santilli <strk at keybit.net>
- * [r1818] new helper class for Overlay op validation.
-2006-09-06 15:21 Sandro Santilli <strk at keybit.net>
- * [r1817] (getBoundary) memory allocations documented
-2006-09-05 16:18 Sandro Santilli <strk at keybit.net>
- * [r1816] updated (last commit log was bogus, refer to ChangeLog
- entry)
-2006-09-05 16:07 Sandro Santilli <strk at keybit.net>
- * [r1815] (OverlayOp::checkObviouslyWrongResult): exceptions
- messages rewording
-2006-08-31 23:13 Sandro Santilli <strk at keybit.net>
- * [r1814] (insertContained): fixed bug reported in
- geos-devel/2006-August/002541.html
-2006-08-31 23:07 Sandro Santilli <strk at keybit.net>
- * [r1813] Reverted last two commits. Darwin host on buildbot seems
- to have its own problems...
-2006-08-31 22:28 Sandro Santilli <strk at keybit.net>
- * [r1812] Ops, it was AM_CONFIG_HEADER the old version - still
- testing
-2006-08-31 22:21 Sandro Santilli <strk at keybit.net>
- * [r1811] AC_CONFIG_HEADERS => AM_CONFIG_HEADER (to support older
- automake versions)
-2006-08-04 20:30 Howard Butler <hobu.inc at gmail.com>
- * [r1810] version should be 3.0.0 instead of 3.3.0
-2006-08-04 20:29 Howard Butler <hobu.inc at gmail.com>
- * [r1809] bump patch to rc1
-2006-08-04 20:23 Howard Butler <hobu.inc at gmail.com>
- * [r1808] give makefile.vc some love
-2006-08-04 16:40 Charlie Savage <cfis at savagexi.com>
- * [r1807] Updated SWIG bindings to expose the equalsExact and
- normalize methods.
-2006-08-03 23:43 Charlie Savage <cfis at savagexi.com>
- * [r1806] Two changes needed to include the correct definitions for
- compiling geos using MingW/msys on Windows.
-2006-08-03 22:46 Sandro Santilli <strk at keybit.net>
- * [r1805] try to keep text within 80 cols
-2006-08-03 22:24 Charlie Savage <cfis at savagexi.com>
- * [r1804] Changed configure.in to use *nix line feeds.
-2006-08-03 22:17 Charlie Savage <cfis at savagexi.com>
- * [r1803] Mistakenly used Geometry* in C api headers instead of
- GEOSGeom.
-2006-08-03 22:13 Charlie Savage <cfis at savagexi.com>
- * [r1802] Removed native line endings for configure.in since CR/LF
- does not work on Windows under msys.
-2006-08-03 22:02 Charlie Savage <cfis at savagexi.com>
- * [r1801] Added equalsExact and normalize to the c api as discussed
- on the mailing list
- (http://geos.refractions.net/pipermail/geos-devel/2006-July/002452.html).
-2006-08-03 21:34 Charlie Savage <cfis at savagexi.com>
- * [r1800] Updated build scripts so that ruby/geos_wrap.cxx,
- python/geos_wrap.cxx and python/geos.py are removed by make
- maintainer-clean but not make clean.
-2006-08-03 16:28 Mateusz Loskot <mateusz at loskot.net>
- * [r1799] Fixed Bug #90
-2006-08-03 16:18 Charlie Savage <cfis at savagexi.com>
- * [r1798] Added SWIG generated wrapper files for Ruby and Python
-2006-07-27 06:18 Mateusz Loskot <mateusz at loskot.net>
- * [r1797] Added svn:ignore property to ignore 'geos-3.0.0rc1' dir
- (testing commit access to SVN).
-2006-07-26 19:06 Sandro Santilli <strk at keybit.net>
- * [r1795] Removed .cvsignore files from repository
-2006-07-26 17:51 Sandro Santilli <strk at keybit.net>
- * [r1794] * capi/Makefile.am: forced link of geostest against
- stdc++ lib
- * tests/xmltester/XMLTester.cpp: added <cmath> include (for fabs
- use)
-2006-07-26 15:28 Sandro Santilli <strk at keybit.net>
- * [r1776] Added geometry snapping heuristic
-2006-07-25 20:45 Sandro Santilli <strk at keybit.net>
- * [r1775] Made autogen.sh errors more visible
-2006-07-21 19:37 Charlie Savage <cfis at savagexi.com>
- * [r1773] Added note about inclusion of version.in.vc. See
- http://geos.refractions.net/pipermail/geos-devel/2006-July/002463.html
- for more info.
-2006-07-21 17:59 Sandro Santilli <strk at keybit.net>
- * [r1772] Added test for GeometrySnapper
- * [r1771] Fixed preprocessor directive use
-2006-07-21 17:09 Sandro Santilli <strk at keybit.net>
- * [r1770] Added new precision::LineStringSnapper class + test
- and precision::GeometrySnapper (w/out test)
-2006-07-21 17:05 Sandro Santilli <strk at keybit.net>
- * [r1769] added operator<< for CoordinateList class
-2006-07-21 17:00 Sandro Santilli <strk at keybit.net>
- * [r1768] Added another distance() test
-2006-07-21 16:45 Mateusz Loskot <mateusz at loskot.net>
- * [r1767] Wrapped FIXME message with #warning directive to shout
- about potential headers removal in future.
-2006-07-21 14:53 Sandro Santilli <strk at keybit.net>
- * [r1766] CoordinateList class re-introduced, for list-based ops
- (not strictly mapped to JTS version, not yet at least)
-2006-07-21 14:49 Sandro Santilli <strk at keybit.net>
- * [r1765] Fixed typo in comment
-2006-07-21 08:33 Sandro Santilli <strk at keybit.net>
- * [r1764] Removed blank space after backslash (automake complained)
-2006-07-19 02:43 Charlie Savage <cfis at savagexi.com>
- * [r1763] Added veresion.h.vc as EXTRA_DIST to ensure it is
- packaged when doing make dist.
-2006-07-15 19:36 Charlie Savage <cfis at savagexi.com>
- * [r1762] Removed python test/cases directory (tests are now just
- in tests directory).
-2006-07-13 08:02 Charlie Savage <cfis at savagexi.com>
- * [r1761] Updated ChangeLog to note additional SWIG tests and
- integration with the GEOS build system.
-2006-07-13 07:49 Charlie Savage <cfis at savagexi.com>
- * [r1760] Updated version number to 3.0.0rc1-CAPI-1.1.1 to match
- the autoconf generated files.
-2006-07-13 07:38 Charlie Savage <cfis at savagexi.com>
- * [r1759] Fixed spelling mistake in test task.
-2006-07-13 07:36 Charlie Savage <cfis at savagexi.com>
- * [r1758] Removed dependency on README.txt since it has been
- removed.
-2006-07-13 07:35 Charlie Savage <cfis at savagexi.com>
- * [r1757] New tests for the buffer operation.
-2006-07-13 07:29 Charlie Savage <cfis at savagexi.com>
- * [r1756] Added SWIG Python and Ruby bindings back into the main
- GEOS build system.
-2006-07-13 07:27 Charlie Savage <cfis at savagexi.com>
- * [r1755] Updated extra_dist for test directories.
-2006-07-13 07:20 Charlie Savage <cfis at savagexi.com>
- * [r1754] Remove the dependency on the cases subdirectory which is
- no longer needed.
-2006-07-13 07:19 Charlie Savage <cfis at savagexi.com>
- * [r1753] Updated test suite to use the correct tests.
-2006-07-13 07:16 Charlie Savage <cfis at savagexi.com>
- * [r1752] Removed old tests cases which are no longer valid (worked
- using the C++ api).
-2006-07-13 07:14 Charlie Savage <cfis at savagexi.com>
- * [r1751] New Python test case to ensure creating coordinate
- sequences and geometries works correctly.
- * [r1750] Removed README.txt files which are no longer applicable
- now that the SWIG bindings have been intergrated into the GEOS
- build system.
-2006-07-13 07:13 Charlie Savage <cfis at savagexi.com>
- * [r1749] Renamed test class.
-2006-07-13 07:09 Charlie Savage <cfis at savagexi.com>
- * [r1748] Removed old, unused code.
- * [r1747] Added tyepmap to support creating polygons with holes.
-2006-07-13 07:08 Charlie Savage <cfis at savagexi.com>
- * [r1746] Added default value for quadsegs parmeter in buffer
- operation.
-2006-07-13 04:47 Charlie Savage <cfis at savagexi.com>
- * [r1745] Manually moved from parent directory.
-2006-07-13 04:46 Charlie Savage <cfis at savagexi.com>
- * [r1744] Updated EXTRA_DIST to include python.i and geos.pth
- * [r1743] Moved file to tests subdirectory.
-2006-07-13 04:45 Charlie Savage <cfis at savagexi.com>
- * [r1742] Installation is now done by autoconf macros instead of
- setup.py
-2006-07-13 04:39 Charlie Savage <cfis at savagexi.com>
- * [r1741] Cleaned up ruby.i, added licenxe to python.i, commented
- back in python.i into geos.i.
-2006-07-13 04:09 Charlie Savage <cfis at savagexi.com>
- * [r1740] Added code to read xml test cases.
-2006-07-13 04:08 Charlie Savage <cfis at savagexi.com>
- * [r1739] Added exception handling for results that return
- geometries. Added normalize and equalsExact, but for the moment
- they are commented out.
-2006-07-13 03:59 Charlie Savage <cfis at savagexi.com>
- * [r1738] Changes to compile on VC++ - fully qualified polygon
- name. Should also work on MingW, will test next.
-2006-07-12 23:17 Charlie Savage <cfis at savagexi.com>
- * [r1737] Disabled test_combinations.rb for the moment since it
- fails.
-2006-07-12 23:16 Charlie Savage <cfis at savagexi.com>
- * [r1736] Fixed serious bug in geom_to_hex and geom_to_wkb type
- maps. Was using temporary variable instead of passed in variable.
-2006-07-12 22:55 Charlie Savage <cfis at savagexi.com>
- * [r1735] Switched GeosBytesOrder to int in api signatures.
-2006-07-12 22:11 Charlie Savage <cfis at savagexi.com>
- * [r1734] A number of changes to fix warning generated by gcc and
- to make sure the bindings compile for Python.
- * [r1733] Updated Python SWIG makefile to build with the c api.
-2006-07-12 22:10 Charlie Savage <cfis at savagexi.com>
- * [r1732] Minor change to fix gcc warning.
- * [r1731] Updated Ruby SWIG makefile to build with the c api.
-2006-07-12 21:03 Charlie Savage <cfis at savagexi.com>
- * [r1730] Fixed an error in the way GEOSByteOrder was declared. It
- is now an enum in geos_c.h
-2006-07-12 19:10 Charlie Savage <cfis at savagexi.com>
- * [r1729] Added %rename directive so that GeomUnion is exposed as
- union is SWIG languages.
-2006-07-12 19:08 Charlie Savage <cfis at savagexi.com>
- * [r1728] Updated tests for combinatins (union, intersection, etc.)
- and operaptions (buffer, centroid, etc.).
-2006-07-12 19:07 Charlie Savage <cfis at savagexi.com>
- * [r1727] These tests are no longer needed.
-2006-07-12 17:51 Charlie Savage <cfis at savagexi.com>
- * [r1726] Ported old tests for relations, such as intersects,
- touches, etc., to new swig bindings.
-2006-07-12 08:30 Charlie Savage <cfis at savagexi.com>
- * [r1725] Added type map needed to create polygons with holes.
- Unfortunately, this is Ruby specific. It needs to be ported to
- Python next.
-2006-07-12 08:29 Charlie Savage <cfis at savagexi.com>
- * [r1724] Removed wrapper classes and replace them with SWIG "fake"
- classes. This makes the interface cleaner, and makes memory
- management much easier. Also added area, dimension, length,
- getExteriorRing, getInteriorRingN methods.
-2006-07-12 08:27 Charlie Savage <cfis at savagexi.com>
- * [r1723] Added test to read from wkb geometry - currently fails,
- needs more investigation.
- * [r1722] Added tests for invalid geometries.
- * [r1721] Updated ruby test suite.
-2006-07-12 08:24 Charlie Savage <cfis at savagexi.com>
- * [r1720] New tests for area, length, distance.
-2006-07-12 05:21 Charlie Savage <cfis at savagexi.com>
- * [r1719] Converted line feeds to Unix style.
- * [r1718] New tests for creating geometries and calling various
- functions such as numGeometries, isValid, etc.
-2006-07-12 05:20 Charlie Savage <cfis at savagexi.com>
- * [r1717] Tests for srid handling.
- * [r1716] Merged tests from test_wkb_reader.rb
-2006-07-12 05:18 Charlie Savage <cfis at savagexi.com>
- * [r1715] Merging into test_io.rb
-2006-07-12 04:46 Charlie Savage <cfis at savagexi.com>
- * [r1714] Tests to verify returned version numbers from C api.
-2006-07-11 18:48 Charlie Savage <cfis at savagexi.com>
- * [r1713] Fixes for coordinate sequences. Fixed bug in range
- checking, chaned clone to be a method instead of copy
- constructor, marked clone as creating a new object.
-2006-07-11 18:44 Charlie Savage <cfis at savagexi.com>
- * [r1712] Tests for SWIG coordinate sequence class.
-2006-07-11 09:07 Charlie Savage <cfis at savagexi.com>
- * [r1711] Added reference to new enum called GEOSByteOrders. The
- enum has two values, GEOS_WKB_NDR and GEOS_WKB_XDR which signify
- big endian and little endian byte orders.
-2006-07-11 09:05 Charlie Savage <cfis at savagexi.com>
- * [r1710] Added 5 methods to the C API as documented in the
- changelong. The new methods are read/write WKB Hex values,
- read/write WKB byte order and read wkb output dimensions.
-2006-07-11 08:55 Charlie Savage <cfis at savagexi.com>
- * [r1709] Test cases for reading and writing geometries to WKT, WKB
- and hex encoded WKB formats via the SWIG bindings.
-2006-07-11 08:54 Charlie Savage <cfis at savagexi.com>
- * [r1708] Updated visual studio header file to match geos_c.h.in
-2006-07-11 08:53 Charlie Savage <cfis at savagexi.com>
- * [r1707] Added 5 methods to the C API as documented in the
-2006-07-11 08:52 Charlie Savage <cfis at savagexi.com>
- * [r1706] Noted additions to the C API and porting of SWIG to use
- the C api.
-2006-07-11 08:44 Charlie Savage <cfis at savagexi.com>
- * [r1705] Ported SWIG bindings to use c-api.
-2006-07-10 22:29 Sandro Santilli <strk at keybit.net>
- * [r1704] Added .cvsignore file
-2006-07-10 21:51 Sandro Santilli <strk at keybit.net>
- * [r1703] don't use dynamic strings as format arg the formatted
- message callbacks.
-2006-07-10 10:16 Sandro Santilli <strk at keybit.net>
- * [r1702] changed vector<bool> to vector<short int> (see bug#101)
-2006-07-09 03:37 Mateusz Loskot <mateusz at loskot.net>
- * [r1701] Added 'testrunner' pattern to tests/xmltester/.cvsignore.
-2006-07-09 03:21 Mateusz Loskot <mateusz at loskot.net>
- * [r1700] Added 'testrunner' to .cvsignore patterns.
- * [r1699] Updated ChangeLog with details about new unit tests.
-2006-07-09 03:16 Mateusz Loskot <mateusz at loskot.net>
- * [r1698] Added new tests to tests/unit/Makefile.am.
-2006-07-09 03:15 Mateusz Loskot <mateusz at loskot.net>
- * [r1697] Added new tests cases to tests/unit/noding. Removed
- zero-to-pointer casts.
-2006-07-09 00:24 Sandro Santilli <strk at keybit.net>
- * [r1696] Added testrunner to CLEANFILES. make distcheck now
- succeeds.
-2006-07-08 00:33 Sandro Santilli <strk at keybit.net>
- * [r1693] * configure.in: incremented CAPI minor version, to avoid
- falling behind any future version from the 2.2. branch.
- * source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
- source/geomgraph/EdgeRing.cpp,
- source/headers/geos/geom/Geometry.h,
- source/headers/geos/geom/GeometryFactory.h,
- source/headers/geos/geom/GeometryFactory.inl,
- source/headers/geos/geomgraph/EdgeRing.h:
- updated doxygen comments (sync with JTS head).
- * source/headers/geos/platform.h.in: include <inttypes.h>
- rather then <stdint.h>
-2006-07-07 20:02 Mateusz Loskot <mateusz at loskot.net>
- * [r1691] Updated ChangeLog with version comparison fix in
- GEOS_UNIT.
-2006-07-07 20:00 Mateusz Loskot <mateusz at loskot.net>
- * [r1690] Fixed versions comparison in the GEOS_UNIT macro.
-2006-07-07 19:33 Sandro Santilli <strk at keybit.net>
- * [r1689] * acsite.m4: include <inttypes.h> rather then <stdint.h>
- (the latter is not available on Solaris 9)
- * configure.in: make sure CFLAGS is set before compiling
- using the 64bit integer detection macro.
-2006-07-06 16:39 Mateusz Loskot <mateusz at loskot.net>
- * [r1688] Fixed version query regexp with escaped dots. Removed
- -lpq from GEOS_LIBS flags.
-2006-07-05 23:27 Mateusz Loskot <mateusz at loskot.net>
- * [r1687] Removed redundant -L and -I from GEOS_LIBS and
- GEOS_CFLAGS.
-2006-07-05 23:10 Mateusz Loskot <mateusz at loskot.net>
- * [r1686] Fixed GEOS_INIT to support full paths to geos-config
- passed to --with-geos. Fixed version decoding.
-2006-07-05 22:54 Sandro Santilli <strk at keybit.net>
- * [r1685] distribute utility.h
-2006-07-05 22:19 Sandro Santilli <strk at keybit.net>
- * [r1684] distribute the TUT framework.
-2006-07-05 21:47 Sandro Santilli <strk at keybit.net>
- * [r1683] Distribute XML tests and tester.
-2006-07-05 21:18 Sandro Santilli <strk at keybit.net>
- * [r1682] Fixed missing SweeplineNestedRingTester.cpp file.
-2006-07-05 20:52 Sandro Santilli <strk at keybit.net>
- * [r1681] Fixed missing backslash, dropping headers from
- distribution.
-2006-07-05 20:20 Sandro Santilli <strk at keybit.net>
- * [r1680] updated
-2006-07-05 20:19 Sandro Santilli <strk at keybit.net>
- * [r1679] added checks for obviously wrong result of difference and
- intersection ops
-2006-06-27 15:59 Sandro Santilli <strk at keybit.net>
- * [r1677] * source/algorithm/HCoordinate.cpp: added support for
- MingW -ansi builds.
-2006-06-27 15:26 Sandro Santilli <strk at keybit.net>
- * [r1676] * capi/geos_c.cpp: fixed forward declaration of
- GEOSCoordSeq_getOrdinate.
- * capi/geos_c.h.in: renamed GEOSGeomTypeId enum to GEOSGeomTypes,
- to make VC++ 2005 happy.
-2006-06-19 23:33 Sandro Santilli <strk at keybit.net>
- * [r1675] Don't *require* CoordinateFilters to define both
- read-only and read-write methods.
-2006-06-19 22:52 Sandro Santilli <strk at keybit.net>
- * [r1674] optimized loops
-2006-06-19 21:20 Sandro Santilli <strk at keybit.net>
- * [r1673] updated port info
-2006-06-19 21:17 Sandro Santilli <strk at keybit.net>
- * [r1672] port info and doxygen dox.
-2006-06-19 20:48 Sandro Santilli <strk at keybit.net>
- * [r1671] parseCase(): make sure to exit the <case> tag before
- returning
-2006-06-14 19:27 Sandro Santilli <strk at keybit.net>
- * [r1670] Let the compiler synthetize copy ctor and assignment op
- for Coordinate class to obtain better numerical stability.
-2006-06-14 19:19 Sandro Santilli <strk at keybit.net>
- * [r1669] Added support for "AreaTest" operations.
-2006-06-14 19:17 Sandro Santilli <strk at keybit.net>
- * [r1668] Fixed bug in findShell() needlessly erasing vector
- elements
-2006-06-14 15:38 Sandro Santilli <strk at keybit.net>
- * [r1667] Fixed just-introduced bug
-2006-06-14 15:03 Sandro Santilli <strk at keybit.net>
- * [r1666] * source/operation/overlay/OverlayOp.cpp: use
- NodeMap::container and related typedefs, removed (int) casts,
- optimized loops.
-2006-06-14 14:32 Sandro Santilli <strk at keybit.net>
- * [r1665] EdgeEnd::getEdge() made non-virtual and inlined.
-2006-06-14 13:59 Sandro Santilli <strk at keybit.net>
- * [r1664] Fixed bug in PolygonBuilder::placePolygonHoles,
- performance improved as a side effect.
-2006-06-13 23:26 Sandro Santilli <strk at keybit.net>
- * [r1663] cleanups
-2006-06-13 22:50 Sandro Santilli <strk at keybit.net>
- * [r1662] * source/headers/geos/io/WKTReader.inl: added missing
- include for GEOS_DEBUG set case, use stderr for debugging output.
-2006-06-13 22:19 Sandro Santilli <strk at keybit.net>
- * [r1661] fixed unused parameter warning
-2006-06-13 22:00 Sandro Santilli <strk at keybit.net>
- * [r1660] Changed GeometryGraph::lineEdgeMap set comparison
- function to be pointer-based. Should be safe and much faster.
- Available tests all succeed.
-2006-06-13 21:42 Sandro Santilli <strk at keybit.net>
- * [r1659] trimmed cvs log, cleanups
-2006-06-13 21:40 Sandro Santilli <strk at keybit.net>
- * [r1658] Cleanups and some more debugging lines
-2006-06-13 21:38 Sandro Santilli <strk at keybit.net>
- * [r1657] Added self comparison check in Geometry::compareTo().
-2006-06-13 19:16 Sandro Santilli <strk at keybit.net>
- * [r1656] fixed mis-assigned commit
-2006-06-12 17:18 Sandro Santilli <strk at keybit.net>
- * [r1655] LineSegmentIndex: explicitly initialized parent class in
- constructors.
-2006-06-12 17:15 Sandro Santilli <strk at keybit.net>
- * [r1654] Removed unused parameters warning
-2006-06-12 17:14 Sandro Santilli <strk at keybit.net>
- * [r1653] added assert(0) version of filter_ro() and filter_rw() to
- allow implementations to only defined the required one.
-2006-06-12 16:59 Sandro Santilli <strk at keybit.net>
- * [r1652] Removed unused parameter warnings
-2006-06-12 16:57 Sandro Santilli <strk at keybit.net>
- * [r1651] Added note about ownership of return from
- getEdgesBetween()
-2006-06-12 16:55 Sandro Santilli <strk at keybit.net>
- * [r1650] fixed compiler warnings, fixed some methods to omit
- unused parameters.
-2006-06-12 16:51 Sandro Santilli <strk at keybit.net>
- * [r1649] Added equality and inequality operators and tests
-2006-06-12 16:36 Sandro Santilli <strk at keybit.net>
- * [r1648] indentation, notes about things to be fixed.
-2006-06-12 15:47 Sandro Santilli <strk at keybit.net>
- * [r1647] implemented missing getEdgesBetween() method (untested).
-2006-06-12 15:46 Sandro Santilli <strk at keybit.net>
- * [r1646] provided a memory friendly version of toEdges() method.
-2006-06-12 15:07 Sandro Santilli <strk at keybit.net>
- * [r1645] explicitly invoked CoordinateSequence (copy) ctor -
- suggested by GCC warning.
-2006-06-12 15:06 Sandro Santilli <strk at keybit.net>
- * [r1644] Added default ctor and copy ctor (protected)
-2006-06-12 13:57 Sandro Santilli <strk at keybit.net>
- * [r1643] Check for int64_t type for int64 typedef.
-2006-06-12 11:29 Sandro Santilli <strk at keybit.net>
- * [r1642] unsigned int => size_t
-2006-06-12 10:49 Sandro Santilli <strk at keybit.net>
- * [r1641] unsigned int => size_t
-2006-06-12 10:39 Sandro Santilli <strk at keybit.net>
- * [r1640] don't print test file precision model if verbosity level
- < 2.
-2006-06-12 10:10 Sandro Santilli <strk at keybit.net>
- * [r1639] Fixed getGeometryN() to take size_t rather then int,
- changed unsigned int parameters to size_t.
-2006-06-09 08:28 Sandro Santilli <strk at keybit.net>
- * [r1638] Removed compiler warning
-2006-06-09 08:17 Sandro Santilli <strk at keybit.net>
- * [r1637] removed signed/unsigned comparison warnings.
-2006-06-09 08:09 Sandro Santilli <strk at keybit.net>
- * [r1636] removed signed/unsigned comparison warnings.
-2006-06-09 08:02 Sandro Santilli <strk at keybit.net>
- * [r1635] Fixed signed/unsigned comparison tests
-2006-06-09 07:42 Sandro Santilli <strk at keybit.net>
- * [r1634] * source/geomgraph/GeometryGraph.cpp,
- source/operation/buffer/OffsetCurveSetBuilder.cpp,
- source/operation/overlay/OverlayOp.cpp,
- source/operation/valid/RepeatedPointTester.cpp: Fixed warning
- after Polygon ring accessor methods changed to work with size_t.
- Small optimizations in loops.
-2006-06-09 06:41 Sandro Santilli <strk at keybit.net>
- * [r1633] Added missing log for mloskot change
-2006-06-08 18:50 Mateusz Loskot <mateusz at loskot.net>
- * [r1632] Fixed no-effect warning in test<1> from
- DimensionTest.cpp.
-2006-06-08 18:18 Sandro Santilli <strk at keybit.net>
- * [r1631] * tests/unit/geom/GeometryFactoryTest.cpp: fixed compiler
- warnings about signed/unsigned comparisons.
-2006-06-08 17:58 Sandro Santilli <strk at keybit.net>
- * [r1630] Polygon::getNumInteriorRing() return size_t,
- Polygon::interiorRingN() takes size_t.
-2006-06-08 17:46 Sandro Santilli <strk at keybit.net>
- * [r1629] * tests/unit/geom/CoordinateArraySequenceTest.cpp: fix
- signed/unsigned comparison warning.
-2006-06-08 15:55 Sandro Santilli <strk at keybit.net>
- * [r1628] * tests/xmltester/markup/MarkupSTL.cpp: removed use of
- allocator<char>, which brings in some incompatibilities with
- libstdc++ 6.0.7 (gcc 4.0.2).
-2006-06-08 13:19 Sandro Santilli <strk at keybit.net>
- * [r1627] Commented out ruby and python detection
-2006-06-08 12:58 Sandro Santilli <strk at keybit.net>
- * [r1626] Fixed xml testrunner rule
-2006-06-08 12:16 Sandro Santilli <strk at keybit.net>
- * [r1625] added XML tests run to the 'make check' rule.
-2006-06-08 11:20 Sandro Santilli <strk at keybit.net>
- * [r1624] Added missing virtual destructor to abstract classes.
-2006-06-07 20:04 Sandro Santilli <strk at keybit.net>
- * [r1623] * configure.in: enforce -Wall -ansi -pedantic
- -Wno-long-long to C and CXX flags.
-2006-06-07 19:45 Sandro Santilli <strk at keybit.net>
- * [r1622] Renamed (reserved) TESTS variable to RUBY_TESTS
-2006-06-07 19:26 Sandro Santilli <strk at keybit.net>
- * [r1621] Fixed SUBDIRS order, and added a NOTE about maintaining
- it.
-2006-06-07 17:03 Sandro Santilli <strk at keybit.net>
- * [r1620] * Makefile.am, configure.in, swig/python/Makefile.am,
- swig/ruby/Makefile.am, swig/ruby/test/Makefile.am: swig removed
- from automatic build process.
- * configure.in: removed check for boost availability.
-2006-06-07 16:07 Sandro Santilli <strk at keybit.net>
- * [r1619] Set release version to 3.0.0rc1
-2006-06-07 14:10 Mateusz Loskot <mateusz at loskot.net>
- * [r1618] Update ChangeLog with info about new test case
- isPointInRingTest.cpp.
-2006-06-07 14:06 Mateusz Loskot <mateusz at loskot.net>
- * [r1617] Renamed file isPointInRing.cpp to isPointInRingTest.cpp
- to follow GEOS Unit Test convention.
-2006-06-07 13:52 Mateusz Loskot <mateusz at loskot.net>
- * [r1616] Added new test: CGAlgorithms/isPointInRing.cpp.
-2006-06-07 13:10 Sandro Santilli <strk at keybit.net>
- * [r1615] Removed Triangle.h include from geom.h
-2006-06-07 13:08 Sandro Santilli <strk at keybit.net>
- * [r1614] * source/headers/geos/geom/Makefile.am: removed
- Triangle.h from installed header set.
-2006-06-05 19:42 Sandro Santilli <strk at keybit.net>
- * [r1613] Fixed noinst_geos_HEADERS => noinst_HEADERS.
-2006-06-05 15:36 Sandro Santilli <strk at keybit.net>
- * [r1612] Given OverlayOp funx code enum a name and renamed values
- to have a lowercase prefix. Drop all of noding headers from
- installed header set.
-2006-06-03 22:31 Howard Butler <hobu.inc at gmail.com>
- * [r1611] update to track latest removals
-2006-06-03 22:29 Howard Butler <hobu.inc at gmail.com>
- * [r1610] Use a fully qualified namespace for LineSegment because
- we're inside of geos::simplify at the time
-2006-06-01 11:49 Sandro Santilli <strk at keybit.net>
- * [r1609] Reduced installed headers form geomgraph namespace
-2006-06-01 10:28 Sandro Santilli <strk at keybit.net>
- * [r1608] Reduced number of installed headers for the geos::index
- namespace
-2006-05-25 18:44 Sandro Santilli <strk at keybit.net>
- * [r1607] * tests/unit/geom/TriangleTest.cpp: take floating-point
- rounding error into account.
-2006-05-25 16:11 Mateusz Loskot <mateusz at loskot.net>
- * [r1606] Changed precision constant with epsilon() from
- std::numeric_limits.
-2006-05-25 15:54 Mateusz Loskot <mateusz at loskot.net>
- * [r1605] Added specialization of ensure_equals for double type.
-2006-05-24 16:29 Sandro Santilli <strk at keybit.net>
- * [r1604] * source/index/quadtree/DoubleBits.cpp: handled negative
- or zero values in getExponent().
-2006-05-24 16:01 Sandro Santilli <strk at keybit.net>
- * [r1603] * tests/unit/utility.h: fixed missing return from
- isSameStructure's specialization on GeometryCollection, also
- fixed a signed/unsigned mismatch warning there.
-2006-05-24 15:42 Sandro Santilli <strk at keybit.net>
- * [r1602] * source/util/Makefile.am,
- source/util/CoordinateArrayFiter.cpp,
- source/util/GEOSException.cpp,
- source/util/UniqueCoordinateArrayFilter.cpp: removed empty
- implementation files.
-2006-05-24 15:32 Sandro Santilli <strk at keybit.net>
- * [r1601] * source/headers/geos/simplify/TaggedLinesSimplifier.h:
- added LineSegmentIndex.h include so that every use of the
- templated simplify() function get all the required definitions.
-2006-05-24 15:17 Sandro Santilli <strk at keybit.net>
- * [r1600] Reduced number of installed headers in geos/operation/
- subdir
-2006-05-24 13:44 Sandro Santilli <strk at keybit.net>
- * [r1599] Added a note about unit tests being introduced
-2006-05-24 11:44 Mateusz Loskot <mateusz at loskot.net>
- * [r1598] Added missing entries to ChangeLog.
-2006-05-24 11:41 Sandro Santilli <strk at keybit.net>
- * [r1597] * source/headers/geos/simplify/TaggedLinesSimplifier.h,
- source/simplify/TaggedLinesSimplifier.cpp,
- source/simplify/TopologyPreservingSimplifier.cpp:
- fixed bug in TopologyPreservingSimplifier failing to
- detect intersections, refactored TaggedLinesSimplifier
- class to more closely match JTS and use templated
- functions.
-2006-05-24 08:32 Sandro Santilli <strk at keybit.net>
- * [r1596] * capi/geos_c.h.in: #include <stddef.h> to get size_t
- definition (only #ifndef __cplusplus)
-2006-05-24 05:53 Mateusz Loskot <mateusz at loskot.net>
- * [r1595] Added new test: TopologyPreservingSimplifierTest.cpp.
- Added new utility.cpp helper for Unit Tests (implementes utils
- from JTS Unit Tests).
-2006-05-23 15:06 Sandro Santilli <strk at keybit.net>
- * [r1594] * source/headers/geos/geom/Coordinate.h: added missing
- <string> include.
-2006-05-23 14:44 Sandro Santilli <strk at keybit.net>
- * [r1593] * source/headers/geos/config.h: removed file which is not
- supposed to be in the repository.
-2006-05-23 14:29 Sandro Santilli <strk at keybit.net>
- * [r1592] * source/headers/geos/index/quadtree/DoubleBits.h,
- source/index/quadtree/DoubleBits.cpp: const correctness and
- documentation.
-2006-05-23 13:21 Sandro Santilli <strk at keybit.net>
- * [r1591] Added test for put/get Long values
-2006-05-23 13:16 Sandro Santilli <strk at keybit.net>
- * [r1590] Fixed a bug in WKBWriter::writeByteOrder() failing to
- consider machine's byte order
-2006-05-23 12:57 Sandro Santilli <strk at keybit.net>
- * [r1589] Fixed small typo in label
-2006-05-23 12:33 Sandro Santilli <strk at keybit.net>
- * [r1588] * source/io/ByteOrderValues.cpp: fixed bug in putLong()
- also affecting putDouble()
-2006-05-23 12:23 Sandro Santilli <strk at keybit.net>
- * [r1587] * tests/unit/Makefile.am,
- tests/unit/io/ByteOrderValuesTest.cpp: unit test for
- ByteOrderValues class.
-2006-05-23 11:07 Sandro Santilli <strk at keybit.net>
- * [r1586] * source/io/WKBWriter.cpp: fixed bug in ::writeInt
- missing to honour the requested byte order.
-2006-05-23 10:56 Sandro Santilli <strk at keybit.net>
- * [r1585] Fixed top comment
-2006-05-23 10:48 Sandro Santilli <strk at keybit.net>
- * [r1584] * tests/unit/io/WKBReaderTest.cpp: cleaned up and added
- both XDR and NDR tests.
-2006-05-23 09:24 Sandro Santilli <strk at keybit.net>
- * [r1583] * source/io/ByteOrderValues.cpp: changed ENDIAN_BIG and
- ENDIAN_LITTLE values to match WKBConstants::XDR and
- WKBConstants::NDR respectively.
- * source/headers/geos/io/WKBConstants.h: added comments about
- meaning of XDR/NDR.
-2006-05-22 15:08 Sandro Santilli <strk at keybit.net>
- * [r1582] Print colon after exception name (as it has always been)
-2006-05-19 17:44 Sandro Santilli <strk at keybit.net>
- * [r1581] * source/simplify/TopologyPreservingSimplifier.cpp:
- removed friend specification in
- TopologyPreservingSimplifier helper class
- (no more needed)
-2006-05-19 17:39 Sandro Santilli <strk at keybit.net>
- * [r1580] * tests/unit/geom/Geometry/coversTest.cpp:
- keep tests in 'tut' namespace.
-2006-05-19 16:38 Sandro Santilli <strk at keybit.net>
- * [r1579] * tests/xmltester/XMLTester.cpp: report
- error on load of requested tests.
-2006-05-18 10:19 Sandro Santilli <strk at keybit.net>
- * [r1578] * source/headers/geos/geom.h: fixed doxygen header for
- mainpage.
-2006-05-18 10:16 Sandro Santilli <strk at keybit.net>
- * [r1577] Added note about the new BinaryOp class and its uses.
-2006-05-18 10:13 Sandro Santilli <strk at keybit.net>
- * [r1576] * source/headers/geos/geom/BinaryOp.h: added compile-time
- defines to avoid precision-reduction and simplify based policies
- (default to enabled).
-2006-05-18 09:32 Sandro Santilli <strk at keybit.net>
- * [r1575] added note about new Geometry predicates
-2006-05-18 09:00 Sandro Santilli <strk at keybit.net>
- * [r1574] Added tests for coveredBy(), fixed ChangeLog entry
-2006-05-18 08:56 Sandro Santilli <strk at keybit.net>
- * [r1573] * source/geom/Geometry.cpp,
- source/headers/geos/geom/Geometry.h: added
- covers() and isCoveredBy() predicates.
- * tests/unit/Makefile.am,
- tests/unit/geom/Geometry/coversTest.cpp:
- added test for covers() predicates.
-2006-05-17 17:41 Sandro Santilli <strk at keybit.net>
- * [r1572] Added output operator + test
-2006-05-17 17:24 Sandro Santilli <strk at keybit.net>
- * [r1571] Added port info, fixed isCoveredBy() comment.
-2006-05-17 17:20 Sandro Santilli <strk at keybit.net>
- * [r1570] added isCovers() and isCoveredBy() public methods to
- IntersectionMatrix and associated tests.
-2006-05-17 08:40 Sandro Santilli <strk at keybit.net>
- * [r1569] typo fixed to make description more clear
-2006-05-13 10:42 Mateusz Loskot <mateusz at loskot.net>
- * [r1563] Fixed line-ends in PointLocatorTest.cpp file.
-2006-05-13 08:26 Mateusz Loskot <mateusz at loskot.net>
- * [r1562] Fixed line-ends in isRectangleTest.cpp. Added new
- patterns to .cvsignore.
-2006-05-05 15:40 Sandro Santilli <strk at keybit.net>
- * [r1561] Had nodind validation error throw an exception for
- SimpleSnapRounder
- and MCIndexSnapRounder
-2006-05-05 14:34 Sandro Santilli <strk at keybit.net>
- * [r1560] New SegmentString unit test
-2006-05-05 14:25 Sandro Santilli <strk at keybit.net>
- * [r1559] moved getSegmentOctant out of .inl into .cpp, renamed
- private eiList to nodeList as in JTS, added more assertion
- checking and fixed doxygen comments
-2006-05-05 10:19 Sandro Santilli <strk at keybit.net>
- * [r1558] droppped SegmentString::getContext(), new name is
- getData() to reflect change in JTS
-2006-05-05 09:37 Sandro Santilli <strk at keybit.net>
- * [r1557] * source/headers/geos/geom.h: fixed namespace
- qualification in doxygen page about C++ interface.
-2006-05-04 15:49 Sandro Santilli <strk at keybit.net>
- * [r1556] updated all Geometry::getDimension() methods to return
- Dimension::DimensionType (closes bug#93)
-2006-05-04 14:05 Sandro Santilli <strk at keybit.net>
- * [r1555] * source/headers/geos/util/math.h: provided an
- util::round() method being an inline proxy to call appropriate
- default rounding function for the whole GEOS codebase. Currently
- pointing at util::java_math_round() being the last being used.
-2006-05-04 13:38 Sandro Santilli <strk at keybit.net>
- * [r1554] doxygen comments cleanup
-2006-05-04 12:54 Sandro Santilli <strk at keybit.net>
- * [r1553] Added invariant tester for NodeMap class, fixed comment
- about ownership of NodeFactory
-2006-05-04 12:33 Sandro Santilli <strk at keybit.net>
- * [r1552] Added some comments about RightmostEdgeFinder only
- considering forward DirectedEdge
-2006-05-04 12:19 Sandro Santilli <strk at keybit.net>
- * [r1551] Added note about findEdge() only scanning for forward
- DirectedEdges
-2006-05-04 12:17 Sandro Santilli <strk at keybit.net>
- * [r1550] Added comment about management of newly created
- DirectedEdges
-2006-05-04 10:15 Sandro Santilli <strk at keybit.net>
- * [r1549] Doxygen comments
-2006-05-04 09:16 Sandro Santilli <strk at keybit.net>
- * [r1548] Added JTS debugging, for comparison with JTS
-2006-05-04 08:42 Sandro Santilli <strk at keybit.net>
- * [r1547] Added note about the CoordinateSequence::toVector()
- method.
-2006-05-04 08:35 Sandro Santilli <strk at keybit.net>
- * [r1546] noding/SegmentNodeList.cpp: cleanups, changed output
- operator to be more similar to JTS
-2006-05-04 08:30 Sandro Santilli <strk at keybit.net>
- * [r1545] removed use of SegmentString::setCoordinates() [dropped]
-2006-05-04 08:29 Sandro Santilli <strk at keybit.net>
- * [r1544] * source/noding/ScaledNoder.cpp: removed use of
- SegmentString::setCoordinates().
- * source/headers/geos/noding/SegmentStrign.{h,inl}: removed new
- setCoordinates() interface.
-2006-05-04 07:43 Sandro Santilli <strk at keybit.net>
- * [r1543] output operator for SegmentString class
-2006-05-04 07:41 Sandro Santilli <strk at keybit.net>
- * [r1542] const-correct size() method for SegmentNodeList
-2006-05-04 06:36 Sandro Santilli <strk at keybit.net>
- * [r1541] Extended definition to take new CoordinateSequence
- tracking into account
-2006-05-03 20:05 Sandro Santilli <strk at keybit.net>
- * [r1540] Added SQL debugging output
-2006-05-03 19:47 Sandro Santilli <strk at keybit.net>
- * [r1539] added operator<< for CoordinateSequence
-2006-05-03 18:04 Sandro Santilli <strk at keybit.net>
- * [r1538] added SegmentString::setCoordinates() interface
-2006-05-03 17:54 Sandro Santilli <strk at keybit.net>
- * [r1537] Uncommented correctness checker
-2006-05-03 17:51 Sandro Santilli <strk at keybit.net>
- * [r1536] system headers included after package headers
-2006-05-03 17:50 Sandro Santilli <strk at keybit.net>
- * [r1535] Doxygen comments
-2006-05-03 17:48 Sandro Santilli <strk at keybit.net>
- * [r1534] Forgot a slash
- * [r1533] Doxygen brief
-2006-05-03 16:22 Howard Butler <hobu.inc at gmail.com>
- * [r1532] tweak clean target
-2006-05-03 16:21 Howard Butler <hobu.inc at gmail.com>
- * [r1531] Build the C API and shared lib separate from the normal
- lib
- Add missing files
-2006-05-03 16:19 Sandro Santilli <strk at keybit.net>
- * [r1530] fit in 80 columns
-2006-05-03 16:09 Howard Butler <hobu.inc at gmail.com>
- * [r1529] Maintain a geos_c.h.vc until we come up with a better
- solution
-2006-05-03 15:50 Howard Butler <hobu.inc at gmail.com>
- * [r1528] *** empty log message ***
-2006-05-03 15:49 Sandro Santilli <strk at keybit.net>
- * [r1527] fixed bug in SimpleSnapRounder::computeSnaps, trying to
- access out-of-bound vector element.
-2006-05-03 15:49 Howard Butler <hobu.inc at gmail.com>
- * [r1526] add additional files and change names where necessary
-2006-05-03 15:40 Sandro Santilli <strk at keybit.net>
- * [r1525] test SegmentString invariant before and after scaling
-2006-05-03 15:37 Sandro Santilli <strk at keybit.net>
- * [r1524] Tabs for indent
-2006-05-03 15:32 Howard Butler <hobu.inc at gmail.com>
- * [r1523] *** empty log message ***
-2006-05-03 15:30 Howard Butler <hobu.inc at gmail.com>
- * [r1522] Maintain a version.h.vc until we come up with a better
- solution
-2006-05-03 15:28 Sandro Santilli <strk at keybit.net>
- * [r1521] updated JTS_PORT to 1.7.1
-2006-05-03 15:26 Sandro Santilli <strk at keybit.net>
- * [r1520] testInvariant made public and always inlined
-2006-05-03 15:19 Sandro Santilli <strk at keybit.net>
- * [r1519] Changed sym_round() to java_math_round()
-2006-05-03 15:12 Sandro Santilli <strk at keybit.net>
- * [r1518] Oops, uninitialized value fix
-2006-05-03 15:06 Sandro Santilli <strk at keybit.net>
- * [r1517] Updated
- * [r1516] Better doxygen comment
-2006-05-03 15:05 Sandro Santilli <strk at keybit.net>
- * [r1515] Assertions checking
-2006-05-03 15:04 Sandro Santilli <strk at keybit.net>
- * [r1514] removed reduntant port info
-2006-05-03 15:02 Sandro Santilli <strk at keybit.net>
- * [r1513] moved some implementations from header to .cpp file
- (taken out of inline)
-2006-05-03 15:00 Sandro Santilli <strk at keybit.net>
- * [r1512] Fixed scale() function to remove repeated points *after*
- rounding. Added brief doxygen class description.
-2006-05-03 10:26 Sandro Santilli <strk at keybit.net>
- * [r1511] Fixed misuse of precision model in noder
- (bufferFixedPrecision)
-2006-05-03 09:46 Sandro Santilli <strk at keybit.net>
- * [r1510] buffer headers reduction item
-2006-05-03 09:45 Sandro Santilli <strk at keybit.net>
- * [r1509] Do not install following buffer headers: BufferBuilder.h,
- OffsetCurveSetBuilder.h, BufferSubgraph.h,
- SubgraphDepthLocater.h,
- RightmostEdgeFinder.h
-2006-05-03 09:14 Sandro Santilli <strk at keybit.net>
- * [r1508] * source/operation/buffer/OffsetCurveSetBuilder.cpp: used
- auto_ptr to protect leaks of CoordinateSequence
- * source/noding/ScaledNoder.cpp,
- source/headers/geos/noding/ScaledNoder.h: ported JTS bugfix in
- scale method.
-2006-05-03 08:58 Sandro Santilli <strk at keybit.net>
- * [r1507] added new non-static
- CoordinateSequence::removeRepeatedPoints() mutator.
-2006-05-02 16:22 Sandro Santilli <strk at keybit.net>
- * [r1506] * source/noding/ScaledNoder.cpp: use java_math_round
- instead of sym_round.
-2006-05-02 14:51 Sandro Santilli <strk at keybit.net>
- * [r1505] Added port info and fixed doxygen comments for
- CGAlgorithms class
-2006-05-02 14:32 Sandro Santilli <strk at keybit.net>
- * [r1503] Added port info for polygonize/EdgeRing class,
- polygonize/EdgeRing.h header
- not installed.
-2006-05-02 14:22 Sandro Santilli <strk at keybit.net>
- * [r1502] * source/operation/polygonize/: polygonizeEdgeRing.cpp
- renamed to EdgeRing.cpp, to follow JTS naming.
-2006-05-02 14:01 Sandro Santilli <strk at keybit.net>
- * [r1500] * source/io/WKBReader.cpp: fixed reads of XDR WKB.
-2006-04-28 12:09 Sandro Santilli <strk at keybit.net>
- * [r1497] Added 'verbose-test' rule
-2006-04-28 12:08 Sandro Santilli <strk at keybit.net>
- * [r1496] Added note about Geometry constructors
-2006-04-28 11:56 Sandro Santilli <strk at keybit.net>
- * [r1495] * source/geom/GeometryFactory.cpp,
- source/headers/geos/geom/GeometryFactory.h: added LineString copy
- constructor.
- * source/geom/Polygon.cpp: fixed getBoundary method to always
- return a geometry composed by LineStrings (not LinearRings)
-2006-04-28 11:12 Sandro Santilli <strk at keybit.net>
- * [r1494] removed warnings related to change in getNumPoints()
- return type.
-2006-04-28 10:55 Sandro Santilli <strk at keybit.net>
- * [r1493] Geometry constructors made protected, to ensure all
- constructions use GeometryFactory,
- which has been made friend of all Geometry derivates.
- getNumPoints() changed to return
- size_t.
-2006-04-28 10:51 Sandro Santilli <strk at keybit.net>
- * [r1492] Unit tests: only construct Geoms using GeometryFactory.
-2006-04-27 15:15 Sandro Santilli <strk at keybit.net>
- * [r1491] Z check removed from invariant tester to avoid aborts due
- to differences in FP computations.
-2006-04-27 15:07 Sandro Santilli <strk at keybit.net>
- * [r1490] use output operators in debugging lines
-2006-04-27 15:06 Sandro Santilli <strk at keybit.net>
- * [r1489] (addNode): always use the Node Coordinate as a key in the
- map to reduce likeliness of a premature deletion.
-2006-04-27 15:03 Sandro Santilli <strk at keybit.net>
- * [r1488] standard algorithm used in addZ() for vector seek
-2006-04-26 16:35 Sandro Santilli <strk at keybit.net>
- * [r1485] Had WKTReader accept correct form for MultiPoint
-2006-04-26 10:39 Sandro Santilli <strk at keybit.net>
- * [r1482] Added mloskot item (bug#100)
-2006-04-26 10:26 Sandro Santilli <strk at keybit.net>
- * [r1481] tools/geos-config.in: fixed library path to use layout
- detected by autoconf
-2006-04-24 15:47 Sandro Santilli <strk at keybit.net>
- * [r1480] Public constructors change made permanent
-2006-04-23 11:58 Mateusz Loskot <mateusz at loskot.net>
- * [r1479] Small refactoring of DouglasPeuckerSimplifierTest (prefer
- to use ctor instead of operator= to create objects). Added new
-2006-04-23 11:29 Mateusz Loskot <mateusz at loskot.net>
- * [r1478] Added new patterns to .cvsignore file.
-2006-04-22 17:16 Mateusz Loskot <mateusz at loskot.net>
- * [r1477] Temporar fix of Bug #100. This report requires deeper
- analysis!.
-2006-04-21 17:04 Sandro Santilli <strk at keybit.net>
- * [r1476] Fixed constructor by type to always initialize scale
- factor
-2006-04-20 16:21 Sandro Santilli <strk at keybit.net>
- * [r1475] Added missing debugging output
-2006-04-20 14:27 Sandro Santilli <strk at keybit.net>
- * [r1474] HCoordinate class changed to use long double types
- internally, in order to improve computation precision
-2006-04-20 14:16 Sandro Santilli <strk at keybit.net>
- * [r1473] Added some more doxygen comments
-2006-04-20 11:11 Sandro Santilli <strk at keybit.net>
- * [r1472] source/algorithm/HCoordinate.cpp: added compile time
- define to force storage of intermediate computation values to
- variables (in order to make the -ffloat-store gcc switch
- effective). Disabled by default.
-2006-04-19 09:21 Sandro Santilli <strk at keybit.net>
- * [r1471] Added snapround and simplify tests items
-2006-04-19 09:20 Sandro Santilli <strk at keybit.net>
- * [r1470] updated
-2006-04-14 15:34 Sandro Santilli <strk at keybit.net>
- * [r1469] Had CAPI use new BinaryOp class in an aim to reduce
- robustness problems
-2006-04-14 15:25 Sandro Santilli <strk at keybit.net>
- * [r1468] updated, somehow
-2006-04-14 15:19 Sandro Santilli <strk at keybit.net>
- * [r1467] removed precision reduction code (use BinaryOp for that)
-2006-04-14 15:06 Sandro Santilli <strk at keybit.net>
- * [r1466] Added BinaryOp.h header
-2006-04-14 15:04 Sandro Santilli <strk at keybit.net>
- * [r1465] fixed missing namespace qualification in
- overlay::overlayOp
-2006-04-14 14:57 Sandro Santilli <strk at keybit.net>
- * [r1464] XMLTester binary ops invoked using the new BinaryOp
- template function.
-2006-04-14 14:38 Sandro Santilli <strk at keybit.net>
- * [r1463] new geos::Geom::BinaryOp template function implementing
- various heuristics aimed at making binary geometry ops work
- around robustness issues.
-2006-04-14 14:35 Sandro Santilli <strk at keybit.net>
- * [r1462] Added overlayOp() adapter for use in templates expecting
- binary ops
-2006-04-14 09:02 Sandro Santilli <strk at keybit.net>
- * [r1461] Hadded output operator and debugging prints for
- HCoordinate.
-2006-04-13 23:57 Sandro Santilli <strk at keybit.net>
- * [r1460] Disables reduced precision overlayOp (is broken)
-2006-04-13 23:42 Sandro Santilli <strk at keybit.net>
- * [r1459] Plugged CommonBitsOp attempts in overlay op, before brute
- force precision
- reduction (this is likely going to change)
-2006-04-13 23:28 Sandro Santilli <strk at keybit.net>
- * [r1458] "always build before commit" (forgot a closing paren)
-2006-04-13 23:23 Sandro Santilli <strk at keybit.net>
- * [r1457] fixed bug in binary ops failing to consistently reduce
- operands.
-2006-04-13 21:53 Sandro Santilli <strk at keybit.net>
- * [r1456] fixed bug introduced by previous commit
-2006-04-13 21:52 Sandro Santilli <strk at keybit.net>
- * [r1455] Many debugging lines and assertions added. Fixed bug in
- TaggedLineString class.
-2006-04-13 17:09 Sandro Santilli <strk at keybit.net>
- * [r1454] Use default GeometryFactory instance (finishGEOS() is a
- no-op now)
-2006-04-13 16:48 Sandro Santilli <strk at keybit.net>
- * [r1453] Added GEOSSimplify and GEOSTopologyPreserveSimplify
- interfaces. Removed compiler warnings in geostest
-2006-04-13 16:44 Sandro Santilli <strk at keybit.net>
- * [r1452] Fixed a bug in DPTransformer handling of MultiPolygons
-2006-04-13 16:04 Sandro Santilli <strk at keybit.net>
- * [r1451] Made TopologyPreservingSimplifier implementation
- successfully build
-2006-04-13 14:51 Sandro Santilli <strk at keybit.net>
- * [r1450] Forced NDR output (to not rely on architecture). Removed
- CRs endings.
-2006-04-13 14:25 Sandro Santilli <strk at keybit.net>
- * [r1449] TopologyPreservingSimplifier initial port
-2006-04-13 10:39 Sandro Santilli <strk at keybit.net>
- * [r1448] Initial implementation of TaggedLinesSimplifier class
-2006-04-13 09:28 Mateusz Loskot <mateusz at loskot.net>
- * [r1447] Removed definition of copy ctor and assignment operator
- for LineSegmentString class.
-2006-04-13 09:21 Mateusz Loskot <mateusz at loskot.net>
- * [r1446] Removed definition of copy ctor and assignment operator
- for TaggedLineString class.
- According to following rule: Declaring, but not defining, private
- copy operations has
- the effect of "turning off" copying for the class.
-2006-04-12 17:24 Sandro Santilli <strk at keybit.net>
- * [r1445] Added note about reduction of installed headers in
- simplify namespace
-2006-04-12 17:19 Sandro Santilli <strk at keybit.net>
- * [r1444] Ported TaggedLineStringSimplifier class, made LineSegment
- class
- polymorphic to fix derivation of TaggedLineSegment
-2006-04-12 15:20 Sandro Santilli <strk at keybit.net>
- * [r1443] LineSegmentIndex class
-2006-04-12 14:22 Sandro Santilli <strk at keybit.net>
- * [r1442] Initial implementation of TaggedLineSegment and
- TaggedLineString classes
-2006-04-12 12:20 Sandro Santilli <strk at keybit.net>
- * [r1441] Added support for use of CommonBitsOp in reduced
- precision attempts
- (compile-time option)
-2006-04-12 11:57 Sandro Santilli <strk at keybit.net>
- * [r1440] Fixed debugging line
-2006-04-12 11:39 Sandro Santilli <strk at keybit.net>
- * [r1439] Removed Geometry.h and CoordinateSequence.h includes.
- The former created a circular dependency.
-2006-04-12 11:17 Sandro Santilli <strk at keybit.net>
- * [r1438] Fixed exceptions constructors (were using operator+ with
- strings and const char*)
-2006-04-12 10:57 Sandro Santilli <strk at keybit.net>
- * [r1437] Added WKBReader default ctor using default
- GeometryFactory instance
-2006-04-11 16:04 Sandro Santilli <strk at keybit.net>
- * [r1436] geos::simplify::DouglasPeukerSimplifier class + unit test
-2006-04-11 12:56 Sandro Santilli <strk at keybit.net>
- * [r1435] used typedef for auto_ptr<CoordinateSequence>
-2006-04-11 12:21 Sandro Santilli <strk at keybit.net>
- * [r1434] GeometryTransformer class ported
-2006-04-11 11:55 Sandro Santilli <strk at keybit.net>
- * [r1433] Added CoordinateSequence::AutoPtr typedef
-2006-04-11 11:16 Sandro Santilli <strk at keybit.net>
- * [r1432] Added LineString and LinearRing constructors by auto_ptr
-2006-04-11 09:53 Sandro Santilli <strk at keybit.net>
- * [r1431] Added missing duplicated include sentinel
-2006-04-11 09:41 Sandro Santilli <strk at keybit.net>
- * [r1430] Initial implementation of a GeometryList class, to be
- used to manage
- lists of Geometry pointers.
-2006-04-11 09:31 Sandro Santilli <strk at keybit.net>
- * [r1429] Added Geometry::AutoPtr typedef
-2006-04-11 09:29 Sandro Santilli <strk at keybit.net>
- * [r1428] Fixed initialization list (removed compiler warning)
-2006-04-10 18:15 Sandro Santilli <strk at keybit.net>
- * [r1427] Changed Geometry::envelope member to be of type
- auto_ptr<Envelope>.
- Changed computeEnvelopeInternal() signater to return
-2006-04-10 17:35 Sandro Santilli <strk at keybit.net>
- * [r1426] Changed LineString::points and Point::coordinates to be
- wrapped
- in an auto_ptr<>. This should close bugs #86 and #89
-2006-04-10 15:11 Sandro Santilli <strk at keybit.net>
- * [r1425] First manual edit (will likely update later tonight...
- with changes grouped
- by date)
-2006-04-10 15:05 Sandro Santilli <strk at keybit.net>
- * [r1424] Re-synced with JTS version (so this actually *was* a bug
- * [r1423] Fixed a bug introduced by previous commit in
- getCentroid()
-2006-04-10 14:18 Sandro Santilli <strk at keybit.net>
- * [r1422] Fixed getCentroid(Coordinate&) to round using
- PrecisionModel
- all unit tests succeed.
-2006-04-10 13:40 Sandro Santilli <strk at keybit.net>
- * [r1421] Added default ctor for WKTReader (using GeometryFactory's
- default instance)
-2006-04-10 13:13 Sandro Santilli <strk at keybit.net>
- * [r1420] Removed INLINE flags from geos-config --libs
-2006-04-10 13:09 Sandro Santilli <strk at keybit.net>
- * [r1419] Added GeometryFactory::defaultInstance()
- Made Geometry::INTERNAL_GEOMETRY_FACTORY an alias for it
- removed last deletion from Unload::Release class
-2006-04-10 12:05 Sandro Santilli <strk at keybit.net>
- * [r1418] Added inline-replicator implementation files to make sure
- functions in .inl files are still available out-of-line.
- A side effect is this should fix MingW build.
-2006-04-10 11:34 Sandro Santilli <strk at keybit.net>
- * [r1417] Uncommented required Geometry.h include (for use in
- auto_ptr)
-2006-04-10 09:21 Mateusz Loskot <mateusz at loskot.net>
- * [r1416] Added new test for UniqueCoordinateArrayFilter class.
- Small fixes related to signed/unsigned comparison.
-2006-04-09 11:07 Mateusz Loskot <mateusz at loskot.net>
- * [r1413] Small fixes in doc/example.cpp.
-2006-04-09 04:56 Mateusz Loskot <mateusz at loskot.net>
- * [r1412] Removed redundant semicolons from xmltester sources.
-2006-04-09 04:26 Mateusz Loskot <mateusz at loskot.net>
- * [r1411] Removed redundant semicolon reported by g++ -pedantic.
-2006-04-09 04:09 Mateusz Loskot <mateusz at loskot.net>
- * [r1410] Removed redundant semicolon reported by g++ -pedantic.
-2006-04-09 01:48 Mateusz Loskot <mateusz at loskot.net>
- * [r1409] Added Unit Test for IntersectionMatrix class.
-2006-04-09 01:46 Mateusz Loskot <mateusz at loskot.net>
- * [r1408] [SORRY] Added comments for doxygen based on JTS docs.
- Added row/col dimension consts. Added asserts in functions to
- check if given row/col is in range.
-2006-04-09 01:41 Mateusz Loskot <mateusz at loskot.net>
- * [r1407] Added comments for doxygen based on JTS docs. Added
- row/col dimension consts. Added asserts in functions to check if
- given row/col is in range.
-2006-04-08 15:57 Mateusz Loskot <mateusz at loskot.net>
- * [r1406] Added copyright notice to TUT files. Small cleaning.
-2006-04-08 13:05 Sandro Santilli <strk at keybit.net>
- * [r1405] Added assertion
-2006-04-08 13:00 Sandro Santilli <strk at keybit.net>
- * [r1404] assertion checking, mergeLabel() call fix (bug#91)
-2006-04-07 16:52 Sandro Santilli <strk at keybit.net>
- * [r1403] Port info, doxygen comments, assertion checking
-2006-04-07 16:01 Sandro Santilli <strk at keybit.net>
- * [r1402] Port info, doxygen comments, testInvariant(), many
- assertionss, handling of
- the NULL EdgeEndStar member
-2006-04-07 13:26 Sandro Santilli <strk at keybit.net>
- * [r1401] Use of auto_ptr<> to prevent confusing leaks in tester
-2006-04-07 13:14 Mateusz Loskot <mateusz at loskot.net>
- * [r1400] Fixed annoying warnings from TUT.
-2006-04-07 13:01 Mateusz Loskot <mateusz at loskot.net>
- * [r1399] Fixed line-ends to LF.
-2006-04-07 12:55 Mateusz Loskot <mateusz at loskot.net>
- * [r1398] Uncommented test nr 38 in PolygonTest.cpp.
-2006-04-07 12:37 Mateusz Loskot <mateusz at loskot.net>
- * [r1397] Added java_math_round() function for Asymmetric
- Arithmetic Rounding. Small fixes in Unit Tests.
-2006-04-07 10:42 Mateusz Loskot <mateusz at loskot.net>
- * [r1396] Added test nr 29 to PointTest (JTS conformance). Removed
- inform() calls from GeometryFactoryTest.
-2006-04-07 09:54 Sandro Santilli <strk at keybit.net>
- * [r1395] Geometry::getNumGeometries() changed to return 'unsigned
- int'
- rather then 'int'
-2006-04-07 09:12 Sandro Santilli <strk at keybit.net>
- * [r1394] kept isInSegmentEnvelopes() check even when not debugging
-2006-04-07 08:31 Sandro Santilli <strk at keybit.net>
- * [r1393] Debugging lines
-2006-04-07 08:30 Sandro Santilli <strk at keybit.net>
- * [r1392] made addCommonBits/removeCommonBits interface consistent,
- doxygen comments
-2006-04-07 08:28 Sandro Santilli <strk at keybit.net>
- * [r1391] debugging lines, assertions
-2006-04-07 08:27 Sandro Santilli <strk at keybit.net>
- * [r1390] debugging blocks
-2006-04-07 07:21 Mateusz Loskot <mateusz at loskot.net>
- * [r1389] Add new-line at the EOF some files.
-2006-04-07 05:55 Mateusz Loskot <mateusz at loskot.net>
- * [r1388] Added new objects to .cvsignore.
-2006-04-07 05:44 Mateusz Loskot <mateusz at loskot.net>
- * [r1387] Added name for anonymous enum in Dimension class (bug).
- Added missing new-line at the end of source files. Removed CR
- from line ends.
-2006-04-07 00:05 Mateusz Loskot <mateusz at loskot.net>
- * [r1386] Adding missing isRectangleTest.cpp
-2006-04-06 23:50 Mateusz Loskot <mateusz at loskot.net>
- * [r1385] Adding new Unit Tests.
-2006-04-06 23:35 Sandro Santilli <strk at keybit.net>
- * [r1384] Added Mateusz Loskot
-2006-04-06 23:31 Mateusz Loskot <mateusz at loskot.net>
- * [r1383] [UT Files Renaming] Add PointLocatorTest.cpp
-2006-04-06 23:28 Mateusz Loskot <mateusz at loskot.net>
- * [r1382] [UT Files Renaming] Remove 'io' tests.
-2006-04-06 23:26 Mateusz Loskot <mateusz at loskot.net>
- * [r1381] [UT Files Renaming] Remove 'geom' tests.
-2006-04-06 23:25 Mateusz Loskot <mateusz at loskot.net>
- * [r1380] [UT Files Renaming] Remove file PointLocator.cpp
-2006-04-06 23:20 Mateusz Loskot <mateusz at loskot.net>
- * [r1379] New version of Unit Test runner. Now, it's more GNU style
- compatible
-2006-04-06 22:30 Mateusz Loskot <mateusz at loskot.net>
- * [r1378] Add inform() target in tut.h and new callbacks in
- tut_reporter.h
-2006-04-06 21:31 Sandro Santilli <strk at keybit.net>
- * [r1377] Const correctness for debugging function
-2006-04-06 21:30 Sandro Santilli <strk at keybit.net>
- * [r1376] Added missing rint_vc() forward declaration
-2006-04-06 17:33 Sandro Santilli <strk at keybit.net>
- * [r1375] Added unit test for DoubleBits
-2006-04-06 14:36 Sandro Santilli <strk at keybit.net>
- * [r1374] Cleanup in geos::precision namespace (leaks plugged,
- auto_ptr use, ...)
-2006-04-06 12:58 Sandro Santilli <strk at keybit.net>
- * [r1373] Added printing of EdgeRing if available
-2006-04-06 12:48 Sandro Santilli <strk at keybit.net>
- * [r1372] Added private vector to keep track of allocated
- MaximalEdgeRings objects
-2006-04-06 12:47 Sandro Santilli <strk at keybit.net>
- * [r1371] Fixed output function
-2006-04-06 12:45 Sandro Santilli <strk at keybit.net>
- * [r1370] Delayed deletion of newly allocated MaximalEdgeRings.
- Existing 'valid' operation tests don't should instability with
- this patch.
-2006-04-06 12:36 Sandro Santilli <strk at keybit.net>
- * [r1369] removed spurious lines from previous commi
-2006-04-06 12:34 Sandro Santilli <strk at keybit.net>
- * [r1368] Port info, more debugging lines, doxygen comments
-2006-04-06 12:33 Sandro Santilli <strk at keybit.net>
- * [r1367] More debugging lines
-2006-04-06 12:29 Sandro Santilli <strk at keybit.net>
- * [r1366] Fixed bogus static PrecisionModel variable in
- ::readCoordinate().
-2006-04-06 09:41 Sandro Santilli <strk at keybit.net>
- * [r1365] Added operator<<, added pts!=NULL assertion in
- testInvariant() function
-2006-04-06 09:39 Sandro Santilli <strk at keybit.net>
- * [r1364] Added operator<<
-2006-04-06 09:01 Sandro Santilli <strk at keybit.net>
- * [r1363] Doxygen comments, port info, operator<<, assertion
- checking
-2006-04-06 07:52 Sandro Santilli <strk at keybit.net>
- * [r1362] Fixed bug in ::print() function
-2006-04-05 18:28 Sandro Santilli <strk at keybit.net>
- * [r1361] Moved testInvariant() methods from private to public,
- added
- some comments about them.
-2006-04-05 15:59 Sandro Santilli <strk at keybit.net>
- * [r1360] Removed dead code
-2006-04-05 14:33 Sandro Santilli <strk at keybit.net>
- * [r1359] Removed annoying warnings from external source
-2006-04-05 14:04 Sandro Santilli <strk at keybit.net>
- * [r1358] Fixed copy ctor to support "Null" Envelope copies.
- Drop init(Envelope&) method.
- Port info and various cleanups.
-2006-04-05 10:25 Sandro Santilli <strk at keybit.net>
- * [r1357] Fixed LineString constructor to ensure deletion of
- argument on exception throw
-2006-04-05 09:34 Sandro Santilli <strk at keybit.net>
- * [r1356] GEOSException derived from std::exception again,
- hopefully the correct way now
-2006-04-05 09:20 Sandro Santilli <strk at keybit.net>
- * [r1355] Added port informations and many assertion checking.
- Fixed bug in getRightmostSide() method ( a "testing-only" corner
- case )
-2006-04-04 16:07 Sandro Santilli <strk at keybit.net>
- * [r1353] More assertion checking, less overhead when built with
- NDEBUG defined
-2006-04-04 13:35 Sandro Santilli <strk at keybit.net>
- * [r1352] Port info, assertion checking, indentation
-2006-04-04 12:39 Sandro Santilli <strk at keybit.net>
- * [r1351] Changed NotRepresentableCoordinate exception handler to
- throw
- a TopologyException. This allows further handling.
-2006-04-04 11:37 Sandro Santilli <strk at keybit.net>
- * [r1350] Port information + initialization lists in ctors
-2006-04-04 11:28 Sandro Santilli <strk at keybit.net>
- * [r1349] NotRepresentable condition detected using finite() from
- <cmath>
- rather then using FINITE() macro. Made ::intersection() body
- more readable.
-2006-04-04 09:53 Sandro Santilli <strk at keybit.net>
- * [r1348] Fixed applyCoordinateFilter() templated function body
-2006-04-04 08:16 Sandro Santilli <strk at keybit.net>
- * [r1345] Changed GEOSException hierarchy to be derived from
- std::runtime_exception.
- Removed the GEOSException::toString redundant method (use
- ::what() instead)
-2006-04-04 01:54 Howard Butler <hobu.inc at gmail.com>
- * [r1344] Add in changes/missing from previous rearranging.
-2006-04-04 01:29 Howard Butler <hobu.inc at gmail.com>
- * [r1343] GEOS_JTS_PORT is in version.h not platform.h
-2006-04-04 01:28 Howard Butler <hobu.inc at gmail.com>
- * [r1342] remove objects that no longer exist
- default to MSVC_VER=1310
-2006-04-03 17:05 Sandro Santilli <strk at keybit.net>
- * [r1341] Assertion checking, port info, cleanups
-2006-04-03 15:54 Sandro Santilli <strk at keybit.net>
- * [r1340] - getArgGeometry() parameter type changed from 'int' to
- 'unsigned int'
- - Added port informations
- - minor assertions checking
- - minor cleanups
-2006-04-03 14:07 Sandro Santilli <strk at keybit.net>
- * [r1339] Commented out obsoleted toInternal() method
-2006-04-03 13:58 Sandro Santilli <strk at keybit.net>
- * [r1337] Applied patch by Charlie Savage:
- - Fixes up the SWIG bindings to use the new GEOS namespaces
- - Fixes a bug in the Python m4 macro
- - Adds the -modern flag for SWIG when compiling a Python
- extension
-2006-04-03 13:56 Sandro Santilli <strk at keybit.net>
- * [r1336] Made externally-owned PrecisionModel const
-2006-04-03 10:56 Sandro Santilli <strk at keybit.net>
- * [r1334] Removed implementation files build spec for fully-inlined
- classes
-2006-04-03 10:44 Sandro Santilli <strk at keybit.net>
- * [r1333] Added missing headers
-2006-04-03 10:16 Sandro Santilli <strk at keybit.net>
- * [r1332] DouglasPeuckerLineSimplifier class port
-2006-04-03 08:43 Sandro Santilli <strk at keybit.net>
- * [r1331] Added port info, minor cleanups
-2006-04-03 08:29 Sandro Santilli <strk at keybit.net>
- * [r1330] Added port info, cleaned up log message, minor assertion
- checking.
-2006-03-31 17:51 Sandro Santilli <strk at keybit.net>
- * [r1329] A few assertion checking, comments cleanup, use of
- initialization lists
- in constructors, handled NULL parameters.
-2006-03-31 16:55 Sandro Santilli <strk at keybit.net>
- * [r1328] Added many assertions checking in LineString
- implementation.
- Changed ::getCoordinate() to return NULL on empty geom.
- Changed ::get{Start,End}Point() to return NULL on empty geom.
-2006-03-31 16:53 Sandro Santilli <strk at keybit.net>
- * [r1327] Added comment about possible NULL return from
- getCoordinate()
-2006-03-31 11:03 Sandro Santilli <strk at keybit.net>
- * [r1325] Fixed NULL-GeometryFactory constructor to use
- INTERNAL_GEOMETRY_FACTORY
- (should fix bug #81)
-2006-03-30 09:26 Sandro Santilli <strk at keybit.net>
- * [r1324] minor cleanup
-2006-03-29 15:48 Sandro Santilli <strk at keybit.net>
- * [r1323] Added missing 'const' in catch std::exception statements
-2006-03-29 15:23 Sandro Santilli <strk at keybit.net>
- * [r1322] Moved GeometryGraph inlines from .h to .inl file
-2006-03-29 14:34 Sandro Santilli <strk at keybit.net>
- * [r1321] Sync'ed testfile with JTS head
-2006-03-29 14:31 Sandro Santilli <strk at keybit.net>
- * [r1320] Added PointLocator unit test
-2006-03-29 13:53 Sandro Santilli <strk at keybit.net>
- * [r1319] EdgeRing equipped with Invariant testing function and
- lots of exceptional assertions. Removed useless heap allocations,
- and pointers usages.
-2006-03-29 11:52 Sandro Santilli <strk at keybit.net>
- * [r1318] const correctness, useless heap allocations removal
-2006-03-29 11:48 Sandro Santilli <strk at keybit.net>
- * [r1317] Removed useless heap allocations in construction,
- enforced const correctness
-2006-03-28 16:49 Sandro Santilli <strk at keybit.net>
- * [r1316] Reintroduced rewind of input parameter in printHEX()
- [dropped by prev commit]
-2006-03-28 16:33 Sandro Santilli <strk at keybit.net>
- * [r1315] Added note about args responsibility in GeometryFactory
- constructor
-2006-03-28 16:11 Sandro Santilli <strk at keybit.net>
- * [r1314] swapped assert_equals() args to get obtained/expected the
- right way.
-2006-03-28 15:27 Sandro Santilli <strk at keybit.net>
- * [r1313] Simplified printHEX() implementation
-2006-03-28 15:19 Sandro Santilli <strk at keybit.net>
- * [r1312] Added macros for sections skip (useful in debugging)
-2006-03-28 14:45 Sandro Santilli <strk at keybit.net>
- * [r1311] Added simple test for WKB reader.
-2006-03-28 14:02 Sandro Santilli <strk at keybit.net>
- * [r1310] added missing header for non-inlined builds
-2006-03-28 14:01 Sandro Santilli <strk at keybit.net>
- * [r1309] forgot to add in previous commit
-2006-03-28 11:26 Sandro Santilli <strk at keybit.net>
- * [r1308] ByteOrderDataInStream inlines moved to .inl file, updated
- implementation files includes.
-2006-03-28 11:25 Sandro Santilli <strk at keybit.net>
- * [r1307] Assertion checking
-2006-03-28 09:14 Sandro Santilli <strk at keybit.net>
- * [r1306] Headers inclusion fix.
-2006-03-28 08:57 Sandro Santilli <strk at keybit.net>
- * [r1305] Comments cleanup, system headers included after project
- headers
-2006-03-28 08:40 Sandro Santilli <strk at keybit.net>
- * [r1304] C-API lib version bumped to 1.1.1 (release 2.2.2 will
- ship 1.1.0)
-2006-03-27 17:59 Sandro Santilli <strk at keybit.net>
- * [r1302] Fixed small leak.
-2006-03-27 17:04 Sandro Santilli <strk at keybit.net>
- * [r1301] Cleanups and explicit initializations
-2006-03-27 16:02 Sandro Santilli <strk at keybit.net>
- * [r1300] Added INL file for MinimalEdgeRing, added many debugging
- blocks,
- fixed memory leak in ConnectedInteriorTester (bug #59)
-2006-03-27 15:57 Sandro Santilli <strk at keybit.net>
- * [r1299] Commented need for platform.h include
-2006-03-27 15:56 Sandro Santilli <strk at keybit.net>
- * [r1298] Added missing platform.h include (for ISNAN macro)
-2006-03-27 14:20 Sandro Santilli <strk at keybit.net>
- * [r1297] Added paranoid assertion checking and a note in header
- about responsibility of return from buildMaximalEdgeRings()
-2006-03-27 10:37 Sandro Santilli <strk at keybit.net>
- * [r1296] Reduced heap allocations and probability of error by
- making LineIntersector
- and RelateNodeGraph part of ConsistentAreaTester class .
-2006-03-27 10:36 Sandro Santilli <strk at keybit.net>
- * [r1295] added missing space in exception message
-2006-03-27 10:34 Sandro Santilli <strk at keybit.net>
- * [r1294] moved external includes after internal ones
-2006-03-27 09:50 Sandro Santilli <strk at keybit.net>
- * [r1293] Added final isValid test from JTS (floating version)
-2006-03-27 09:48 Sandro Santilli <strk at keybit.net>
- * [r1292] Extracted TestValid2.xml from testLeaksBig.xml (target
- file is taken from JTS source tree)
-2006-03-27 09:45 Sandro Santilli <strk at keybit.net>
- * [r1291] Added TestValid.xml test, taken from JTS source tree,
- already present in testLeaksBig (from which tests were removed)
-2006-03-27 09:28 Sandro Santilli <strk at keybit.net>
- * [r1290] added namespaces use and headers split
-2006-03-27 09:05 Sandro Santilli <strk at keybit.net>
- * [r1289] Added note about responsibility of return from
- GEOSGeomType()
-2006-03-27 09:00 Sandro Santilli <strk at keybit.net>
- * [r1288] Bug #79 - Small fix in
- CoordinateArraySequence::toString()
-2006-03-24 11:42 Sandro Santilli <strk at keybit.net>
- * [r1287] reverted default of assertion checking
-2006-03-24 11:11 Sandro Santilli <strk at keybit.net>
- * [r1286] Inlining enabled by default, assertion checking disabled
- by default.
- Added --enable-cassert and --disable-inline configure switches.
- Had geos-config --cflags output appropriate inline flag if
- required (-DGEOS_INLINE)
-2006-03-24 11:04 Sandro Santilli <strk at keybit.net>
- * [r1285] Changed assert() with Assert::isTrue in addReverseSubpath
-2006-03-24 10:44 Sandro Santilli <strk at keybit.net>
- * [r1284] Fixed to build with -DNDEBUG
-2006-03-24 09:52 Sandro Santilli <strk at keybit.net>
- * [r1283] USE_INLINE => GEOS_INLINE
-2006-03-24 09:26 Sandro Santilli <strk at keybit.net>
- * [r1282] Bug #77 - Missing platform.h
-2006-03-24 09:25 Sandro Santilli <strk at keybit.net>
- * [r1281] Bugs #77 and #76: missing <algorithm>
-2006-03-24 09:23 Sandro Santilli <strk at keybit.net>
- * [r1280] Bug #78 - Small fixes and cleaning
-2006-03-23 15:10 Sandro Santilli <strk at keybit.net>
- * [r1278] Dropped by-pointer TopologyException constructor, various
- small cleanups
-2006-03-23 13:31 Sandro Santilli <strk at keybit.net>
- * [r1277] Fixed to allow build with GEOS_DEBUG
-2006-03-23 12:12 Sandro Santilli <strk at keybit.net>
- * [r1276] Fixes to allow build with -DUSE_INLINE
-2006-03-23 10:55 Sandro Santilli <strk at keybit.net>
- * [r1275] Temporarly excluded 'swig' extension from distribution,
- to allow for
- successufull 'dist' rule and distributed testing.
-2006-03-23 10:41 Sandro Santilli <strk at keybit.net>
- * [r1274] Fixed automake files
-2006-03-23 10:09 Sandro Santilli <strk at keybit.net>
- * [r1273] Fixed missing backslash
-2006-03-23 09:17 Sandro Santilli <strk at keybit.net>
- * [r1272] precision.h header split, minor optimizations
-2006-03-22 18:12 Sandro Santilli <strk at keybit.net>
- * [r1271] indexChain.h header split.
-2006-03-22 16:59 Sandro Santilli <strk at keybit.net>
- * [r1270] cleaned up
-2006-03-22 16:58 Sandro Santilli <strk at keybit.net>
- * [r1269] Removed (almost) all inclusions of geom.h.
- Removed obsoleted .cpp files.
- Fixed a bug in WKTReader not using the provided
- implementation, optimized out some memory allocations.
-2006-03-22 16:01 Sandro Santilli <strk at keybit.net>
- * [r1268] indexBintree.h header split, classes renamed to match JTS
-2006-03-22 14:28 Sandro Santilli <strk at keybit.net>
- * [r1267] Filenames renamed to match class names (matching JTS)
-2006-03-22 12:22 Sandro Santilli <strk at keybit.net>
- * [r1266] indexQuadtree.h split
-2006-03-22 11:19 Sandro Santilli <strk at keybit.net>
- * [r1265] opPolygonize.h headers split.
-2006-03-22 11:18 Sandro Santilli <strk at keybit.net>
- * [r1264] Changed back 'unable to find edge to compute depths' from
- assertion to TopologyException
-2006-03-22 10:13 Sandro Santilli <strk at keybit.net>
- * [r1263] opLinemerge.h split
-2006-03-21 21:42 Sandro Santilli <strk at keybit.net>
- * [r1262] planargraph.h header split, planargraph:: classes renamed
- to match JTS symbols
-2006-03-21 17:55 Sandro Santilli <strk at keybit.net>
- * [r1261] opDistance.h header split
-2006-03-21 17:11 Sandro Santilli <strk at keybit.net>
- * [r1260] opPredicate.h header split
-2006-03-21 13:11 Sandro Santilli <strk at keybit.net>
- * [r1259] opRelate.h header split
-2006-03-21 11:20 Sandro Santilli <strk at keybit.net>
- * [r1258] Changed expected result to the obtained one :)
- We're not cheating, it's a 2-vertex linestring for
- which an InteriorPoint is requested, both vertexes
- are correct answer (equidistant from centroid).
-2006-03-21 11:12 Sandro Santilli <strk at keybit.net>
- * [r1257] Cleanups: headers inclusion and Log section
-2006-03-21 10:47 Sandro Santilli <strk at keybit.net>
- * [r1256] indexStrtree.h split
-2006-03-21 10:46 Sandro Santilli <strk at keybit.net>
- * [r1255] streamlined header inclusion, put original copyright on
- top
-2006-03-21 10:01 Sandro Santilli <strk at keybit.net>
- * [r1254] indexSweepline.h header split
-2006-03-20 18:18 Sandro Santilli <strk at keybit.net>
- * [r1253] io.h header split
-2006-03-20 17:40 Sandro Santilli <strk at keybit.net>
- * [r1252] <cmath> included when appropriate
-2006-03-20 17:27 Sandro Santilli <strk at keybit.net>
- * [r1251] Bug #72 - Missing <vector> header
-2006-03-20 17:17 Sandro Santilli <strk at keybit.net>
- * [r1250] Fixed geosdir
-2006-03-20 16:57 Sandro Santilli <strk at keybit.net>
- * [r1249] spatialindex.h and opValid.h headers split
-2006-03-20 16:08 Sandro Santilli <strk at keybit.net>
- * [r1248] redirected find stderr to /dev/null
-2006-03-20 13:20 Sandro Santilli <strk at keybit.net>
- * [r1247] Changed assertion to TopologyException for the "orphaned"
- hole case
- in order to allow for reduced precision ops to catch the case.
-2006-03-20 12:33 Sandro Santilli <strk at keybit.net>
- * [r1246] Simplified some privat methods to use refs instead of
- pointers, added
- debugging section for failiures of holes/shells associations
-2006-03-20 12:32 Sandro Santilli <strk at keybit.net>
- * [r1245] Added note about responsibility of return from
- ::toPolygon
-2006-03-20 12:03 Sandro Santilli <strk at keybit.net>
- * [r1244] Added operator<< for Geometry, writing HEXWKB
-2006-03-20 11:42 Sandro Santilli <strk at keybit.net>
- * [r1243] Added missing <cmath> include
-2006-03-20 10:42 Sandro Santilli <strk at keybit.net>
- * [r1242] Bug #61 - Disambiguated geom::Polygon use
-2006-03-20 10:14 Sandro Santilli <strk at keybit.net>
- * [r1241] Bug #69 - Check for macro WIN32_LEAN_AND_MEAN
-2006-03-20 10:13 Sandro Santilli <strk at keybit.net>
- * [r1240] Bug #71 - Missing <algorithm>
-2006-03-20 10:12 Sandro Santilli <strk at keybit.net>
- * [r1239] Bug #70 - Small fix in fwd decl. of CoordinateLessThen
-2006-03-20 10:11 Sandro Santilli <strk at keybit.net>
- * [r1238] Bug #67 - Debugging helpers in GeometryFactory class
-2006-03-17 16:48 Sandro Santilli <strk at keybit.net>
- * [r1237] LineIntersector and PointLocator made complete components
- of RelateComputer
- (were statics const pointers before). Reduced inclusions from
- opRelate.h
- and opValid.h, updated .cpp files to allow build.
-2006-03-17 14:56 Sandro Santilli <strk at keybit.net>
- * [r1236] Fixed filename normalizer for sql output
-2006-03-17 13:24 Sandro Santilli <strk at keybit.net>
- * [r1235] opOverlay.h header splitted. Reduced header inclusions in
- operation/overlay implementation files. ElevationMatrixFilter
- code moved from own file to ElevationMatrix.cpp (ideally a
- class-private).
-2006-03-16 13:30 Sandro Santilli <strk at keybit.net>
- * [r1234] Added missing testfile
-2006-03-16 13:29 Sandro Santilli <strk at keybit.net>
- * [r1233] new unit test for LineSegment (adding tests would be
- helpful)
-2006-03-16 13:28 Sandro Santilli <strk at keybit.net>
- * [r1232] obsoleted getCoordinate(), replaced by operator[]
-2006-03-16 13:27 Sandro Santilli <strk at keybit.net>
- * [r1231] Added notes about testing
-2006-03-16 10:47 Sandro Santilli <strk at keybit.net>
- * [r1230] Bug #65 - Command line changes and EOL fixes Unit Test
-2006-03-16 10:42 Sandro Santilli <strk at keybit.net>
- * [r1229] Bug #64 - Not all control paths return a value in
- geos::geom::Geometry::getClassSortIndex
-2006-03-16 10:38 Sandro Santilli <strk at keybit.net>
- * [r1228] Bug #63 - Remove unreferenced local variable warning
-2006-03-16 09:37 Sandro Santilli <strk at keybit.net>
- * [r1227] Initial unit tests
-2006-03-15 18:59 Sandro Santilli <strk at keybit.net>
- * [r1226] Bug #62: 'struct' CoordinateLessThen in forward
- declaration
-2006-03-15 18:57 Sandro Santilli <strk at keybit.net>
- * [r1225] small cleanup
- * [r1224] cleanups in DEBUG lines
-2006-03-15 18:56 Sandro Santilli <strk at keybit.net>
- * [r1223] Temporary hack to avoid snapround:: Noders (still using
- ScaledNoder wrapper)
- to allow for buffer_snapround.xml test to succeed
-2006-03-15 18:55 Sandro Santilli <strk at keybit.net>
- * [r1222] Added xml testfile showing bug in snapround:: noders
-2006-03-15 18:44 Sandro Santilli <strk at keybit.net>
- * [r1221] Bug #60 - Missing <cmath> header in some files
-2006-03-15 17:33 Sandro Santilli <strk at keybit.net>
- * [r1220] Changed operator<< to use operator<< for Nodes
-2006-03-15 17:17 Sandro Santilli <strk at keybit.net>
- * [r1219] Added missing forward declarations
-2006-03-15 17:16 Sandro Santilli <strk at keybit.net>
- * [r1218] streamlined headers inclusion
-2006-03-15 16:27 Sandro Santilli <strk at keybit.net>
- * [r1217] operator<< for Node class
-2006-03-15 15:50 Sandro Santilli <strk at keybit.net>
- * [r1216] const correctness, cleanups
-2006-03-15 15:27 Sandro Santilli <strk at keybit.net>
- * [r1215] cleanups
-2006-03-15 15:26 Sandro Santilli <strk at keybit.net>
- * [r1214] Cleanups
-2006-03-15 13:03 Sandro Santilli <strk at keybit.net>
- * [r1213] removed leftover debugging line
-2006-03-15 12:54 Sandro Santilli <strk at keybit.net>
- * [r1212] Removed DepthSegment.h include
- * [r1211] Removed public DepthSegment definition (moved inside
- SubgraphDepthLocater implementation)
-2006-03-15 12:52 Sandro Santilli <strk at keybit.net>
- * [r1210] DepthSegment class moved inside SubgraphDepthLocator
- implementaion
- as it was private to this file in JTS. Also, changed to reduce
- copies of LineSegment copies.
-2006-03-15 11:45 Sandro Santilli <strk at keybit.net>
- * [r1209] doxygen comments
-2006-03-15 11:44 Sandro Santilli <strk at keybit.net>
- * [r1208] debug blocks, dumping SQL when GEOS_DEBUG > 1
-2006-03-15 11:42 Sandro Santilli <strk at keybit.net>
- * [r1207] more debugging lines, with two levels of debugging
- handled
-2006-03-15 11:39 Sandro Santilli <strk at keybit.net>
- * [r1206] comments cleanup, changed computeDepths to use a list<>
- rather then a vector (performance related)
-2006-03-15 10:40 Sandro Santilli <strk at keybit.net>
- * [r1205] Fixed to allow doxygen runs from external builddir
-2006-03-15 09:51 Sandro Santilli <strk at keybit.net>
- * [r1204] streamlined header usage
- * [r1203] streamlined headers usage
-2006-03-15 09:13 Sandro Santilli <strk at keybit.net>
- * [r1202] updated port info
-2006-03-15 09:12 Sandro Santilli <strk at keybit.net>
- * [r1201] isSimple doc
-2006-03-14 17:46 Sandro Santilli <strk at keybit.net>
- * [r1200] Removed unrequired include
-2006-03-14 17:10 Sandro Santilli <strk at keybit.net>
- * [r1199] cleanups
-2006-03-14 17:08 Sandro Santilli <strk at keybit.net>
- * [r1198] comments cleanup, integrity checks
-2006-03-14 16:55 Sandro Santilli <strk at keybit.net>
- * [r1197] oops, GEOS_DEBUG default to 0
- * [r1196] comments cleanup
-2006-03-14 16:53 Sandro Santilli <strk at keybit.net>
- * [r1195] removed endline from printing funx
-2006-03-14 16:08 Sandro Santilli <strk at keybit.net>
- * [r1194] changed buildSubgraphs signature to use refs rather then
- pointers, made it const-correct. Reduced heap allocations in
- createSubgraphs()
-2006-03-14 15:46 Sandro Santilli <strk at keybit.net>
- * [r1193] Added PlanarGraph::getNodes(vector&) func, to reduce
- useless heap allocations
-2006-03-14 15:32 Sandro Santilli <strk at keybit.net>
- * [r1192] Cleaned up toString funx (more WKT friendly)
-2006-03-14 14:16 Sandro Santilli <strk at keybit.net>
- * [r1191] operator<< for BufferSubgraph, more debugging calls
-2006-03-14 12:55 Sandro Santilli <strk at keybit.net>
- * [r1190] Headers split: geomgraphindex.h, nodingSnapround.h
-2006-03-14 11:03 Sandro Santilli <strk at keybit.net>
- * [r1189] Added operator<< for Edge and EdgeList
-2006-03-14 00:37 Sandro Santilli <strk at keybit.net>
- * [r1188] Fixed include filenames
-2006-03-14 00:36 Sandro Santilli <strk at keybit.net>
- * [r1187] Reduced 'buffer' headers inclusion
-2006-03-14 00:19 Sandro Santilli <strk at keybit.net>
- * [r1186] opBuffer.h split, streamlined headers in some (not all)
- files in operation/buffer/
-2006-03-13 22:33 Sandro Santilli <strk at keybit.net>
- * [r1185] Added missing forward declarations
-2006-03-13 21:54 Sandro Santilli <strk at keybit.net>
- * [r1184] Streamlined headers inclusion.
-2006-03-13 21:19 Sandro Santilli <strk at keybit.net>
- * [r1183] Fixed bug in ScaledNoder scaling mechanism (hugly code,
- due to CoordinateSequence visitor pattern design). Tests are
- still failing so this possibly needs some other fix. Streamlined
- includes by implementation file.
-2006-03-13 21:14 Sandro Santilli <strk at keybit.net>
- * [r1182] Added missing forward declarations
-2006-03-13 21:13 Sandro Santilli <strk at keybit.net>
- * [r1181] Added comment about possible refactoring
-2006-03-11 16:58 Sandro Santilli <strk at keybit.net>
- * [r1180] Fixed bug in OffsetCurveBuilder::getCoordinates.
-2006-03-10 15:50 Sandro Santilli <strk at keybit.net>
- * [r1179] Changed 'found null Directed Edge' from an Assertion to a
- TopologyException, to give 'precision-reducing' overlay operation
- a chance to handle it (it seems to work)
-2006-03-10 13:07 Sandro Santilli <strk at keybit.net>
- * [r1178] fine-tuned includes, reverted Assert=>assert due to
- user-input based failure
-2006-03-10 12:50 Sandro Santilli <strk at keybit.net>
- * [r1177] boost detection code fix, first UTF source for testing
- purposes
-2006-03-10 12:43 Sandro Santilli <strk at keybit.net>
- * [r1176] updated
-2006-03-10 12:09 Sandro Santilli <strk at keybit.net>
- * [r1175] Update configure script to work with new boost.m4 file
-2006-03-10 11:49 Sandro Santilli <strk at keybit.net>
- * [r1174] Updated boost detection macro
-2006-03-10 11:41 Sandro Santilli <strk at keybit.net>
- * [r1173] Added missing <algorithm> include (bug#56)
-2006-03-10 11:10 Sandro Santilli <strk at keybit.net>
- * [r1172] Initial boost detection code
-2006-03-10 11:09 Sandro Santilli <strk at keybit.net>
- * [r1171] Comments cleanup
-2006-03-10 10:48 Sandro Santilli <strk at keybit.net>
- * [r1170] Bug #58 - Patch to makefile.vc after big refactoring
- commit
-2006-03-10 10:44 Sandro Santilli <strk at keybit.net>
- * [r1169] Unreferenced exception objects cleanup (#52)
-2006-03-10 10:37 Sandro Santilli <strk at keybit.net>
- * [r1168] Added missing <algorithm> include (#55)
-2006-03-10 10:34 Sandro Santilli <strk at keybit.net>
- * [r1167] Added missing <algorithm> include (#54)
-2006-03-09 18:22 Sandro Santilli <strk at keybit.net>
- * [r1166] Added isvalid test for latest validop patch
-2006-03-09 18:18 Sandro Santilli <strk at keybit.net>
- * [r1165] Added memory-friendly
- MaximalEdgeRing::buildMinimalRings() implementation.
- Applied patch to IsValid operation from JTS-1.7.1
-2006-03-09 17:40 Sandro Santilli <strk at keybit.net>
- * [r1164] Fixed bug#33 (hopefully)
-2006-03-09 16:46 Sandro Santilli <strk at keybit.net>
- * [r1163] geos::geom namespace definition, first pass at headers
- split
-2006-03-09 16:18 Sandro Santilli <strk at keybit.net>
- * [r1162] Fixed to allow tests from external build tree (thanks
- Norman:)
-2006-03-09 16:01 Sandro Santilli <strk at keybit.net>
- * [r1161] Fixed debugging lines
-2006-03-09 15:50 Sandro Santilli <strk at keybit.net>
- * [r1160] Fixed debugging lines, added missing header
-2006-03-09 15:47 Sandro Santilli <strk at keybit.net>
- * [r1159] Fixed debugging lines
-2006-03-09 15:39 Sandro Santilli <strk at keybit.net>
- * [r1158] Fixed debugging lines
-2006-03-09 14:48 Sandro Santilli <strk at keybit.net>
- * [r1157] Added missing INCLUDES line
-2006-03-07 14:21 Sandro Santilli <strk at keybit.net>
- * [r1156] Leak plugged, tweeked output to be nice with --sql-output
-2006-03-07 14:20 Sandro Santilli <strk at keybit.net>
- * [r1155] Big deal of heap allocations reduction
-2006-03-07 14:18 Sandro Santilli <strk at keybit.net>
- * [r1154] Profiler singleton implemented with a function-static
- Profiler instance
-2006-03-07 12:42 Sandro Santilli <strk at keybit.net>
- * [r1153] addedvalidity test for a case with invalid input
-2006-03-07 12:41 Sandro Santilli <strk at keybit.net>
- * [r1152] Added --wkb-output and made --sql-output compatible with
- -v
-2006-03-07 11:22 Sandro Santilli <strk at keybit.net>
- * [r1151] table name for sqlOutput normalized
-2006-03-07 11:06 Sandro Santilli <strk at keybit.net>
- * [r1150] Added --sql-output switch for debugging
-2006-03-07 10:46 Sandro Santilli <strk at keybit.net>
- * [r1149] verbose validity errors
-2006-03-06 21:27 Sandro Santilli <strk at keybit.net>
- * [r1148] Cascading fixed after Unload definition moved to geos::io
- namespace
-2006-03-06 19:43 Sandro Santilli <strk at keybit.net>
- * [r1147] Fixed Unload class definition namespace (geos::io)
-2006-03-06 19:40 Sandro Santilli <strk at keybit.net>
- * [r1146] geos::util namespace. New GeometryCollection::iterator
- interface, many cleanups.
-2006-03-06 15:23 Sandro Santilli <strk at keybit.net>
- * [r1145] geos::io namespace
-2006-03-06 14:30 Sandro Santilli <strk at keybit.net>
- * [r1143] Validity error include Coordinate
-2006-03-06 13:27 Sandro Santilli <strk at keybit.net>
- * [r1142] Cleaned up equalsExact
-2006-03-06 13:26 Sandro Santilli <strk at keybit.net>
- * [r1141] Fixed equalsExact check, and also reduced tolerance
-2006-03-06 12:47 Sandro Santilli <strk at keybit.net>
- * [r1140] TopologyValidationError error names (enum) renamed to
- avoid conflicts.
-2006-03-06 12:16 Sandro Santilli <strk at keybit.net>
- * [r1139] Added second case for Union
-2006-03-06 12:11 Sandro Santilli <strk at keybit.net>
- * [r1138] precision.h => geos/precision.h (#48)
-2006-03-06 11:39 Sandro Santilli <strk at keybit.net>
- * [r1137] Added test extracted from data provided by Guillaume
- Sueur
-2006-03-06 11:34 Sandro Santilli <strk at keybit.net>
- * [r1136] Dropped unused/unmaintained/platform-problematic serial
- version info for classes (#47)
-2006-03-06 11:17 Sandro Santilli <strk at keybit.net>
- * [r1135] added a compile-time option to get VERBOSE_EXCEPTION
- (print args on exceptions)
- * [r1134] precision reducing overlayOp made compile-time optional
-2006-03-06 11:05 Sandro Santilli <strk at keybit.net>
- * [r1133] Added input and output validity test facilities
-2006-03-03 14:01 Sandro Santilli <strk at keybit.net>
- * [r1132] Experimental precision-reducing overlayOp
-2006-03-03 13:50 Sandro Santilli <strk at keybit.net>
- * [r1131] Cleaned up InteriorPointLine class
-2006-03-03 10:46 Sandro Santilli <strk at keybit.net>
- * [r1130] Removed 'using namespace' from headers, added missing
- headers in .cpp files, removed useless includes in headers
- (bug#46)
-2006-03-02 18:17 Sandro Santilli <strk at keybit.net>
- * [r1129] Added robustness testcases
-2006-03-02 16:22 Sandro Santilli <strk at keybit.net>
- * [r1128] Updated copyright notice
-2006-03-02 16:21 Sandro Santilli <strk at keybit.net>
- * [r1127] geos::precision namespace added
-2006-03-02 14:53 Sandro Santilli <strk at keybit.net>
- * [r1126] SweepLineEvent::DELETE=>DELETE_EVENT,
- INSERT=>INSERT_EVENT (#45)
-2006-03-02 14:34 Sandro Santilli <strk at keybit.net>
- * [r1125] GeometryGraphOperation::li made a non-static member, and
- not more a pointer
-2006-03-02 14:21 Sandro Santilli <strk at keybit.net>
- * [r1124] DEBUG => GEOS_DEBUG [#44]
-2006-03-02 12:12 Sandro Santilli <strk at keybit.net>
- * [r1123] Renamed DEBUG macros to GEOS_DEBUG, all wrapped in
- #ifndef block to allow global override (bug#43)
-2006-03-02 11:03 Sandro Santilli <strk at keybit.net>
- * [r1122] Added assertion in relate test handler
-2006-03-02 11:00 Sandro Santilli <strk at keybit.net>
- * [r1121] Changed IntersectionMatrix funx taking strings to take
- const string& instead
-2006-03-02 10:25 Sandro Santilli <strk at keybit.net>
- * [r1120] Added support for FLOATING_SINGLE precisionmodel in XML
- tests
-2006-03-02 10:03 Sandro Santilli <strk at keybit.net>
- * [r1119] Removed use of strdup, changed GEOSjtsport() to return
- const char* instead of char* (is not advertised in headerfile, so
- no compatibility problems)
-2006-03-02 09:51 Sandro Santilli <strk at keybit.net>
- * [r1118] Fixes in DEBUG lines (bug#42)
-2006-03-02 09:49 Sandro Santilli <strk at keybit.net>
- * [r1117] Changed LineSegment output to use 'LINESEGMENT' label
- rather then 'LINESTRING'
- * [r1116] WINCE implmentation of gettimeofday (bug#40)
-2006-03-02 09:46 Sandro Santilli <strk at keybit.net>
- * [r1115] cleaned up debugging lines
-2006-03-01 18:44 Sandro Santilli <strk at keybit.net>
- * [r1114] added note about getInteriorPoint() possibly returning
- NULL
-2006-03-01 18:43 Sandro Santilli <strk at keybit.net>
- * [r1113] Handled new NULL return from Geometry::getInteriorPoint()
-2006-03-01 18:37 Sandro Santilli <strk at keybit.net>
- * [r1112] Geometry::createPointFromInternalCoord dropped (it's a
- duplication of GeometryFactory::createPointFromInternalCoord).
- Fixed bugs in InteriorPoint* and getCentroid() inserted by
- previous commits.
-2006-03-01 18:19 Sandro Santilli <strk at keybit.net>
- * [r1111] getCentroid() test moved from testLeaksBig.xml to
- TestCentroid.xml (synced with JTS-1.7)
-2006-03-01 18:15 Sandro Santilli <strk at keybit.net>
- * [r1110] Extracted getInteriorPoint() tests out of
- testLeaksBig.xml and into TestInteriorPoint.xml (synced with
- JTS-1.7).
-2006-03-01 18:14 Sandro Santilli <strk at keybit.net>
- * [r1109] Handled NULL return from Geometry::getInteriorPoint()
-2006-03-01 17:16 Sandro Santilli <strk at keybit.net>
- * [r1108] LineSegment class made final and optionally
- (compile-time) inlined.
- Reduced heap allocations in Centroid{Area,Line,Point} and
- InteriorPoint{Area,Line,Point}.
-2006-03-01 16:42 Sandro Santilli <strk at keybit.net>
- * [r1107] Fixed include name (Bug#41)
-2006-03-01 16:01 Sandro Santilli <strk at keybit.net>
- * [r1106] Fixed const correctness of operator<<(ostream&,
- SegmentNodeList&) [bug#37]
-2006-03-01 13:49 Sandro Santilli <strk at keybit.net>
- * [r1105] Fixed debug lines (bug#36)
-2006-03-01 13:48 Sandro Santilli <strk at keybit.net>
- * [r1104] Fixed missing type specifier (bug#35)
-2006-03-01 13:06 Sandro Santilli <strk at keybit.net>
- * [r1103] Used FLOATING precision model in buffer.xml test, added
- expected results,
- changed XMLTester.cpp to use a tolerance when comparing expected
- and obtained
- results from buffer operations.
-2006-03-01 12:12 Sandro Santilli <strk at keybit.net>
- * [r1102] Fixed a bug in verbose output preventing geometry arg 'A'
- from being properly printed
-2006-03-01 11:47 Sandro Santilli <strk at keybit.net>
- * [r1101] Applied patch by Mateusz Loskot (Bug #39)
-2006-03-01 10:48 Sandro Santilli <strk at keybit.net>
- * [r1100] Changed static TopologyValidationError::errMsg[] from
- 'string' to 'const char*'
- to reduce dynamic memory allocations.
-2006-03-01 10:39 Sandro Santilli <strk at keybit.net>
- * [r1099] ctor and dtor made private and inlined
-2006-03-01 09:56 Sandro Santilli <strk at keybit.net>
- * [r1098] Case insensitive operation names and geometry arguments
- names (a/b)
-2006-03-01 09:43 Sandro Santilli <strk at keybit.net>
- * [r1097] Unrecognized tests always printed (was only printed when
- verbose before)
-2006-03-01 08:52 Sandro Santilli <strk at keybit.net>
- * [r1096] File to be included by Makefile.vc
-2006-02-28 19:22 Sandro Santilli <strk at keybit.net>
- * [r1095] Fixed in-place definition of static members in
- OffsetCurveBuilder (bug#33)
-2006-02-28 19:18 Sandro Santilli <strk at keybit.net>
- * [r1094] Added cctype include (bug #34)
-2006-02-28 17:44 Sandro Santilli <strk at keybit.net>
- * [r1093] Added a check in SegmentNode::addSplitEdge to prevent
- attempts
- to build SegmentString with less then 2 points.
- This is a temporary fix for the buffer.xml assertion failure,
- temporary
- as Martin Davis review would really be needed there.
-2006-02-28 15:34 Sandro Santilli <strk at keybit.net>
- * [r1092] Fix for VC++ builds (Bug #32)
-2006-02-28 14:34 Sandro Santilli <strk at keybit.net>
- * [r1091] Added many assertions and debugging output hunting for a
- bug in BufferOp
-2006-02-28 14:05 Sandro Santilli <strk at keybit.net>
- * [r1090] Fixed a bug in a debugging line
-2006-02-28 13:08 Sandro Santilli <strk at keybit.net>
- * [r1089] Added missing definition of IteratedNoder::MAX_ITER,
- moving it to private access level
-2006-02-28 11:15 Sandro Santilli <strk at keybit.net>
- * [r1088] Fixed strchr use (Bug #30)
-2006-02-28 11:11 Sandro Santilli <strk at keybit.net>
- * [r1087] Fixed typo in GEOSLenght function
-2006-02-28 05:03 Sean Gillies <sgillies at frii.com>
- * [r1085] added GEOSLength(), GEOSEnvelope() to the C API
-2006-02-27 14:41 Sandro Santilli <strk at keybit.net>
- * [r1076] More verbose handling of exceptions
-2006-02-27 11:53 Sandro Santilli <strk at keybit.net>
- * [r1075] DirectedEdgeStar made more safe trough assert(), use of
- standard iterator and
- dynamic casts substituting static ones.
-2006-02-27 09:05 Sandro Santilli <strk at keybit.net>
- * [r1074] Doxygen comments, a few inlines and general cleanups
-2006-02-24 16:20 Sandro Santilli <strk at keybit.net>
- * [r1073] Added Mateusz implementation of round() in a new math.cpp
- file
- named sym_round(). Changed use of rint_vc to sym_round in
- PrecisionModel.
- Moved rint_vc to math.cpp (geos::util namespace), to be renamed
- to something more meaningful
-2006-02-24 15:39 Sandro Santilli <strk at keybit.net>
- * [r1072] - operator>> for Coordinate, planarNode and planarEdge
- - Fixed bug in planarGraphComponent::setMarked
- - Added linemerge.xml test (single test, should grow a bit)
-2006-02-24 12:19 Sandro Santilli <strk at keybit.net>
- * [r1071] Fixed typo in config file
-2006-02-23 23:17 Sandro Santilli <strk at keybit.net>
- * [r1070] - Coordinate::nullCoordinate made private
- - Simplified Coordinate inline definitions
- - LMGeometryComponentFilter definition moved to LineMerger.cpp
- file
- - Misc cleanups
-2006-02-23 20:32 Sandro Santilli <strk at keybit.net>
- * [r1069] Added support for LineMerge tests. Exception printed on
- stderr.
-2006-02-23 20:05 Sandro Santilli <strk at keybit.net>
- * [r1068] Fixed bug in MCIndexNoder constructor making memory
- checker go crazy, more
- doxygen-friendly comments, miscellaneous cleanups
-2006-02-23 20:03 Sandro Santilli <strk at keybit.net>
- * [r1067] updated to also show undocumented methods
-2006-02-23 11:54 Sandro Santilli <strk at keybit.net>
- * [r1066] - MCIndexPointSnapper
- - MCIndexSnapRounder
- - SnapRounding BufferOp
- - ScaledNoder
- - GEOSException hierarchy cleanups
- - SpatialIndex memory-friendly query interface
- - GeometryGraph::getBoundaryNodes memory-friendly
- - NodeMap::getBoundaryNodes memory-friendly
- - Cleanups in geomgraph::Edge
- - Added an XML test for snaprounding buffer (shows leaks, working
- on it)
-2006-02-21 16:53 Sandro Santilli <strk at keybit.net>
- * [r1065] MCIndexPointSnapper, MCIndexSnapRounder
-2006-02-20 21:04 Sandro Santilli <strk at keybit.net>
- * [r1064] - namespace geos::index
- - SpatialIndex interface synced
-2006-02-20 10:14 Sandro Santilli <strk at keybit.net>
- * [r1063] - namespaces geos::index::*
- - Doxygen documentation cleanup
-2006-02-19 19:46 Sandro Santilli <strk at keybit.net>
- * [r1062] Packages <-> namespaces mapping for most GEOS internal
- code (uncomplete, but working). Dir-level libs for index/
- subdirs.
-2006-02-18 21:08 Sandro Santilli <strk at keybit.net>
- * [r1061] - new CoordinateSequence::applyCoordinateFilter method
- (slow but useful)
- - SegmentString::getCoordinates() doesn't return a clone anymore.
- - SegmentString::getCoordinatesRO() obsoleted.
- - SegmentString constructor does not promises constness of passed
- CoordinateSequence anymore.
- - NEW ScaledNoder class
- - Stubs for MCIndexPointSnapper and MCIndexSnapRounder
- - Simplified internal interaces of OffsetCurveBuilder and
-2006-02-16 08:41 Sandro Santilli <strk at keybit.net>
- * [r1060] Fixed include: "util.h" => "geos/util.h"
- * [r1059] added <cmath> include for round()
-2006-02-16 08:19 Sandro Santilli <strk at keybit.net>
- * [r1058] Missed from last commit
-2006-02-15 22:48 Sean Gillies <sgillies at frii.com>
- * [r1057] added GEOSGeomType
-2006-02-15 17:19 Sandro Santilli <strk at keybit.net>
- * [r1056] NodingValidator synced with JTS-1.7, added
- CoordinateSequence::operator[]
- and size() to easy port maintainance.
-2006-02-15 14:59 Sandro Santilli <strk at keybit.net>
- * [r1055] JTS-1.7 sync for:
- noding/SegmentNode.cpp
- noding/SegmentNodeList.cpp
- noding/SegmentString.cpp
-2006-02-14 13:28 Sandro Santilli <strk at keybit.net>
- * [r1054] New SnapRounding code ported from JTS-1.7 (not complete
- yet).
- Buffer op optimized by using new snaprounding code.
- Leaks fixed in XMLTester.
-2006-02-09 15:52 Sandro Santilli <strk at keybit.net>
- * [r1053] GEOSException derived from std::exception; always thrown
- and cought by const ref.
-2006-02-09 15:41 Sean Gillies <sgillies at frii.com>
- * [r1052] incrementing C API patch level
-2006-02-09 14:49 Sean Gillies <sgillies at frii.com>
- * [r1051] added GEOSArea() to the C API
-2006-02-09 13:44 Sandro Santilli <strk at keybit.net>
- * [r1050] Added support for SRID in input WKB, undeprecated
- Geometry::setSRID
- and Geometry::getSRID
-2006-02-09 01:47 Frank Warmerdam <warmerdam at pobox.com>
- * [r1049] Botched last fix. Hopefully this is better.
-2006-02-09 01:13 Sandro Santilli <strk at keybit.net>
- * [r1048] Added missing <limits> include
-2006-02-09 00:06 Frank Warmerdam <warmerdam at pobox.com>
- * [r1047] Fixed support for consuming WKB for 'POLYGON EMPTY' with
- numRings==0.
- http://bugzilla.remotesensing.org/show_bug.cgi?id=1064
-2006-02-08 17:18 Sandro Santilli <strk at keybit.net>
- * [r1046] - New WKTWriter::toLineString and ::toPoint convenience
- methods
- - New IsValidOp::setSelfTouchingRingFormingHoleValid method
- - New Envelope::centre()
- - New Envelope::intersection(Envelope)
- - New Envelope::expandBy(distance, [ydistance])
- - New LineString::reverse()
- - New MultiLineString::reverse()
- - New Geometry::buffer(distance, quadSeg, endCapStyle)
- - Obsoleted toInternalGeometry/fromInternalGeometry
- - More const-correctness in Buffer "package"
-2006-02-08 13:07 Sandro Santilli <strk at keybit.net>
- * [r1045] Added note about new LineSequencer class
-2006-02-08 12:59 Sandro Santilli <strk at keybit.net>
- * [r1044] - NEW Geometry::applyComponentFilter() templated method
- - Changed Geometry::getGeometryN() to take unsigned int and
- getNumGeometries
- to return unsigned int.
- - Changed planarNode::getDegree() to return unsigned int.
- - Added Geometry::NonConstVect typedef
- - NEW LineSequencer class
- - Changed planarDirectedEdgeStar::outEdges from protected to
- private
- - added static templated setVisitedMap to change Visited flag
- for all values in a map
- - Added const versions of some planarDirectedEdgeStar methods.
- - Added containers typedefs for planarDirectedEdgeStar
-2006-02-07 13:26 Sandro Santilli <strk at keybit.net>
- * [r1043] Added missing geomgraph SUBDIR
-2006-02-07 12:02 Sandro Santilli <strk at keybit.net>
- * [r1042] Removed TestConvexHull.xml file (already included in
- testLeaksBig.xml
-2006-02-06 11:27 Sandro Santilli <strk at keybit.net>
- * [r1041] new entry
-2006-02-05 17:14 Sandro Santilli <strk at keybit.net>
- * [r1040] - New ConnectedSubgraphFinder class.
- - More iterators returning methods, inlining and cleanups
- in planargraph.
-2006-02-04 00:54 Sandro Santilli <strk at keybit.net>
- * [r1039] - Doxygen dox updated
- - LineStringLT struct moved from geomgraph.h to geom.h
- - New planarSubgraph class
- - Fixed ruby Makefiles to avoid running tests when disabled
- - Renamed TESTS variable to XMLTESTS to not confuse 'make check'
- rule
-2006-02-03 09:26 Sandro Santilli <strk at keybit.net>
- * [r1038] Added missing file
-2006-02-02 02:20 Sandro Santilli <strk at keybit.net>
- * [r1037] Fixed bug in isRectangle() failing to detect rectangles.
-2006-02-01 22:22 Sandro Santilli <strk at keybit.net>
- * [r1036] updated
-2006-02-01 22:21 Sandro Santilli <strk at keybit.net>
- * [r1035] - Added rectangle-based optimizations of intersects() and
- contains() ops
- - Inlined all planarGraphComponent class
-2006-01-31 21:42 Sandro Santilli <strk at keybit.net>
- * [r1034] Added DepthSegment object
-2006-01-31 21:36 Sandro Santilli <strk at keybit.net>
- * [r1033] Fixes error in calling read_hex from scripting languages.
-2006-01-31 21:35 Sandro Santilli <strk at keybit.net>
- * [r1032] Erroneusly ended in CVS
-2006-01-31 21:17 Sandro Santilli <strk at keybit.net>
- * [r1031] Added missing file from last commits
-2006-01-31 19:11 Sandro Santilli <strk at keybit.net>
- * [r1030] Another left-over from cleanups
-2006-01-31 19:10 Sandro Santilli <strk at keybit.net>
- * [r1029] Removed leftover files in obsoleted dirs
-2006-01-31 19:07 Sandro Santilli <strk at keybit.net>
- * [r1028] - Renamed DefaultCoordinateSequence to
- CoordinateArraySequence.
- - Moved GetNumGeometries() and GetGeometryN() interfaces
- from GeometryCollection to Geometry class.
- - Added getAt(int pos, Coordinate &to) funtion to
- CoordinateSequence class.
- - Reworked automake scripts to produce a static lib for each
- subdir and
- then link all subsystem's libs togheter
- - Moved C-API in it's own top-level dir capi/
- - Moved source/bigtest and source/test to tests/bigtest and
- test/xmltester
- - Fixed PointLocator handling of LinearRings
- - Changed CoordinateArrayFilter to reduce memory copies
- - Changed UniqueCoordinateArrayFilter to reduce memory copies
- - Added CGAlgorithms::isPointInRing() version working with
- Coordinate::ConstVect type (faster!)
- - Ported JTS-1.7 version of ConvexHull with big attention to
- memory usage optimizations.
- - Improved XMLTester output and user interface
- - geos::geom::util namespace used for geom/util stuff
- - Improved memory use in geos::geom::util::PolygonExtractor
- - New ShortCircuitedGeometryVisitor class
- - New operation/predicate package
-2006-01-30 21:59 Frank Warmerdam <warmerdam at pobox.com>
- * [r1027] yikes! comment out debug define again
-2006-01-30 21:58 Frank Warmerdam <warmerdam at pobox.com>
- * [r1026] fixed up some debug messages
-2006-01-30 16:55 Sandro Santilli <strk at keybit.net>
- * [r1025] More patches from Charlie Savage
-2006-01-27 08:58 Sandro Santilli <strk at keybit.net>
- * [r1024] Python and Ruby build disable by default (until we've
- properly tested it)
-2006-01-27 08:25 Sandro Santilli <strk at keybit.net>
- * [r1023] * Ruby - removes dependency on renames.i file which is no
- longer deleted
- and was removed from CVS last week
- * Python - fixes autoconf search for Python include path
- * Python - fixes autoconf search for Python lib directory on
- MingW/windows
- * Python - adds python library to link line so that python
- extension can
- be built
-2006-01-22 22:48 Sandro Santilli <strk at keybit.net>
- * [r1022] Added Safe's performance improvement idea for
-2006-01-21 16:11 Sandro Santilli <strk at keybit.net>
- * [r1021] updated
-2006-01-21 16:08 Sandro Santilli <strk at keybit.net>
- * [r1020] Fixed integer conversion bug (ported from JTS-1.7).
- Added last port information.
-2006-01-21 16:04 Sandro Santilli <strk at keybit.net>
- * [r1019] Added endian specification to case descriptions.
- All tests are Little Endian, should add the same
- tests with Big Endian format.
-2006-01-20 19:28 Sandro Santilli <strk at keybit.net>
- * [r1018] Updated port information
-2006-01-20 19:21 Sandro Santilli <strk at keybit.net>
- * [r1017] Fixed bug #13
-2006-01-20 19:11 Sandro Santilli <strk at keybit.net>
- * [r1016] Updated last port info
-2006-01-20 17:20 Sandro Santilli <strk at keybit.net>
- * [r1015] More SWIG/python/ruby patches
-2006-01-20 00:59 Sandro Santilli <strk at keybit.net>
- * [r1014] Better debugging
- * [r1013] PrecisionModel made FLOATING
-2006-01-18 17:49 Sandro Santilli <strk at keybit.net>
- * [r1012] Reworked XMLTester to be quiet by default. Use -v switch
- to make it verbose.
-2006-01-18 17:47 Sandro Santilli <strk at keybit.net>
- * [r1011] Added GEOMETRYCOLLECTION test
- * [r1010] Added another local test to the test rule
-2006-01-18 17:46 Sandro Santilli <strk at keybit.net>
- * [r1009] Fixed leak in ::writeFormatted(Geometry *)
-2006-01-18 17:45 Sandro Santilli <strk at keybit.net>
- * [r1008] more debugging lines
-2006-01-18 13:23 Sandro Santilli <strk at keybit.net>
- * [r1007] Set binary flag for stringstream used in ::readHEX()
-2006-01-18 12:54 Sandro Santilli <strk at keybit.net>
- * [r1006] Added HEXWKB support in XMLTester. Added a simple test in
- HEXWKB form
- and a 'test' rule running the locally-available tests and showing
- result summay.
-2006-01-18 10:02 Sandro Santilli <strk at keybit.net>
- * [r1005] Added missing macro file
-2006-01-17 12:03 Sandro Santilli <strk at keybit.net>
- * [r1004] Modified AC_PROG_SWIG macro to set SWIG to the empty
- string
- on error (rather then making it echo an error and return false).
- SWIG version 1.3.28 or up required in order to build SWIG-based
- extensions.
-2006-01-16 18:34 Sandro Santilli <strk at keybit.net>
- * [r1003] Added initial conditional build of python and ruby
- wrappers
-2006-01-15 23:01 Sandro Santilli <strk at keybit.net>
- * [r1001] Added bare build/install/dist scripts support for ruby
- interface
-2006-01-15 21:23 Sandro Santilli <strk at keybit.net>
- * [r1000] Initial import of ruby unit tests
-2006-01-15 21:22 Sandro Santilli <strk at keybit.net>
- * [r999] Added Envelope constructor by string (accepting what's
- returned by ::toString)
-2006-01-15 21:19 Sandro Santilli <strk at keybit.net>
- * [r998] Added WKBWriter::writeHEX() and WKBReader::readHEX()
-2006-01-12 11:44 Sandro Santilli <strk at keybit.net>
- * [r997] synced after 2.2.1 release
- * [r996] Removed double call to ::isValid
-2006-01-08 15:39 Sandro Santilli <strk at keybit.net>
- * [r994] Changed finite() function call with FINITE() macro.
-2006-01-08 15:24 Sandro Santilli <strk at keybit.net>
- * [r993] Changed container-related typedef to class-scoped STL-like
- typedefs.
- Fixed const correctness of EdgeIntersectionList::begin() and
- ::end() consts;
- defined M_PI when undef as suggested by Charlie Savage.
- Removed <stdio.h> include from GeometricShapeFactory.cpp.
-2005-12-22 12:46 Sandro Santilli <strk at keybit.net>
- * [r992] Imported Charlie Savage new ruby wrapper and swig changes
-2005-12-14 11:22 Sandro Santilli <strk at keybit.net>
- * [r991] Added a note about the need to *always* increment CAPI
- version
-2005-12-14 02:32 Sandro Santilli <strk at keybit.net>
- * [r990] New entry
-2005-12-13 23:59 Sandro Santilli <strk at keybit.net>
- * [r989] Removed INTERFACE_* defines (obsoleted).
- Made GEOSCoordSeq_clone() arg const (won't change ABI, it's C
- world, lucky ;)
-2005-12-13 23:03 Sandro Santilli <strk at keybit.net>
- * [r988] Removed conditional blocks based on GEOS version (we're
- always
- in sync). This fixed an annoying problem introduced since
- INTERFACE_LAST
- and INTERFACE_CURREN were taken off geos/version.h
-2005-12-12 09:32 Sandro Santilli <strk at keybit.net>
- * [r987] Switched to -release mode for C++ library versioning.
- Every release will be binary-incompatible with previous.
- Removed GEOS_FIRST_INTERFACE and GEOS_LAST_INTERFACE defines
- from geos/version.h.
-2005-12-11 10:41 Sandro Santilli <strk at keybit.net>
- * [r984] Fixed premature initialization of average Z value in
- ElevationMatrixFilter
-2005-12-11 10:38 Sandro Santilli <strk at keybit.net>
- * [r983] Fixed mungled versions (1.0.0/3.0.1 => 1.0.1/3.0.0)
-2005-12-10 16:07 Sandro Santilli <strk at keybit.net>
- * [r981] Unkown -> Unknown typo fix
-2005-12-09 13:24 Sandro Santilli <strk at keybit.net>
- * [r980] Capi lib version set to 1.0.1 (due to leak fix in
- GEOSHasZ)
-2005-12-09 11:36 Sandro Santilli <strk at keybit.net>
- * [r977] Small leak plugged in CAPI::GEOSHasZ() and in
- invalid input to PolygonizeGraph (again)
-2005-12-09 10:32 Sandro Santilli <strk at keybit.net>
- * [r974] Cleaned up debugging line left over from previous commit
-2005-12-09 10:03 Sandro Santilli <strk at keybit.net>
- * [r972] Fixed a bug making PolygonizeGraph choking on invalid
- LineStrings.
- Minor optimizations in Polygonizer loops.
-2005-12-08 14:14 Sandro Santilli <strk at keybit.net>
- * [r971] ElevationMatrixFilter used for both elevation and Matrix
- fill,
- thus removing CoordinateSequence copy in
- ElevetaionMatrix::add(Geometry *).
- Changed CoordinateFilter::filter_rw to be a const method: updated
- all apply_rw() methods to take a const CoordinateFilter.
-2005-12-08 01:39 Sandro Santilli <strk at keybit.net>
- * [r970] SegmentString::eiList made a real object rather then a
- pointer.
- Adde getter for const and non-const references of it (dropping
- get by pointer)
-2005-12-08 01:11 Sandro Santilli <strk at keybit.net>
- * [r969] minor optimizations in loops
-2005-12-08 00:24 Sandro Santilli <strk at keybit.net>
- * [r968] Reduced coordinate assignments in ::createSplitEdge
-2005-12-08 00:03 Sandro Santilli <strk at keybit.net>
- * [r967] LineBuilder::lineEdgesList made a real vector, rather then
- pointer (private member).
- Small optimizations in LineBuilder loops, cleanups in LineBuilder
- class dox.
-2005-12-07 23:36 Sandro Santilli <strk at keybit.net>
- * [r966] standard indentation
-2005-12-07 22:52 Sandro Santilli <strk at keybit.net>
- * [r965] Added CoordinateSequence::apply_rw(CoordinateFilter *) and
- CoordinateSequence::apply_ro(CoordinateFilter *) const
- to reduce coordinate copies on read-write CoordinateFilter
- applications (previously required getAt()/setAt() calls).
- Undefined PROFILE_COORDINATE_COPIES (erroneously left defined by
- previous commit)
-2005-12-07 21:55 Sandro Santilli <strk at keybit.net>
- * [r964] Optimized memory allocations in ::removeRepeatedPoints
-2005-12-07 20:52 Sandro Santilli <strk at keybit.net>
- * [r963] minor container methods call reduction
-2005-12-07 20:51 Sandro Santilli <strk at keybit.net>
- * [r962] removed dead code
- * [r961] minor cleanups
-2005-12-07 20:49 Sandro Santilli <strk at keybit.net>
- * [r960] Oops, removed Coordinate copies introduced by recent code
- cleanups
-2005-12-07 19:18 Sandro Santilli <strk at keybit.net>
- * [r959] Changed PlanarGraph::addEdges and EdgeList::addAll to take
- a const vector by reference rather then a non-const vector by
- pointer.
- Optimized polygon vector allocations in
- OverlayOp::computeOverlay.
-2005-12-06 10:24 Sandro Santilli <strk at keybit.net>
- * [r958] Added acsite.m4 to distribution.
- Added macros and flags required to build on mingw arch.
-2005-11-30 16:07 Sandro Santilli <strk at keybit.net>
- * [r955] Added geos_c.h
-2005-11-30 16:03 Sandro Santilli <strk at keybit.net>
- * [r951] Added --ldflags
-2005-11-30 16:01 Sandro Santilli <strk at keybit.net>
- * [r949] Updated with C-API usage
-2005-11-30 11:27 Sandro Santilli <strk at keybit.net>
- * [r945] catch std::exception by ref
-2005-11-30 11:25 Sandro Santilli <strk at keybit.net>
- * [r944] includes cleanup
-2005-11-29 23:01 Sandro Santilli <strk at keybit.net>
- * [r942] updated moving some items to 2.2.0
-2005-11-29 15:45 Sandro Santilli <strk at keybit.net>
- * [r936] Fixed signedness of TopologyLocation methods, cleanups.
-2005-11-29 15:16 Sandro Santilli <strk at keybit.net>
- * [r935] Fixed sign-related warnings and signatures.
-2005-11-29 14:49 Sandro Santilli <strk at keybit.net>
- * [r934] More info
-2005-11-29 14:44 Sandro Santilli <strk at keybit.net>
- * [r933] Updated
-2005-11-29 14:39 Sandro Santilli <strk at keybit.net>
- * [r932] Removed number of points cache in Edge, replaced with
- local caches.
- * [r931] More signed/unsigned fixes
-2005-11-29 13:39 Sandro Santilli <strk at keybit.net>
- * [r930] Moved byte typedef from geom.h to io.h.
- Removed useless commas at inlined funx end.
- Changed CoordinateSequenceFactory::create(siz,dims) to use
- unsigned for dims.
-2005-11-29 11:18 Sandro Santilli <strk at keybit.net>
- * [r929] organized changes info
-2005-11-29 00:48 Sandro Santilli <strk at keybit.net>
- * [r928] Removed edgeList cache from EdgeEndRing. edgeMap is
- enough.
- Restructured iterated access by use of standard ::iterator
- abstraction
- with scoped typedefs.
-2005-11-28 18:37 Sandro Santilli <strk at keybit.net>
- * [r927] Minor warning removal
-2005-11-25 12:22 Sandro Santilli <strk at keybit.net>
- * [r926] Made XMLTester able to run multiple test files and keep
- overall
- counters.
-2005-11-25 11:40 Sandro Santilli <strk at keybit.net>
- * [r925] Another getSize in for loop, another int-unsigned int
- warning
-2005-11-25 11:31 Sandro Santilli <strk at keybit.net>
- * [r924] Removed all CoordinateSequence::getSize() calls embedded
- in for loops.
-2005-11-25 11:30 Sandro Santilli <strk at keybit.net>
- * [r923] Fix in ::equals() - this finally passes testLeaksBig.xml
- tests
-2005-11-25 09:57 Sandro Santilli <strk at keybit.net>
- * [r922] Fixed bug in getCoordinates() [ introduced by previous
- commit ]
-2005-11-24 23:43 Sandro Santilli <strk at keybit.net>
- * [r921] Yes another fix, sorry. Missing const-correctness.
-2005-11-24 23:24 Sandro Santilli <strk at keybit.net>
- * [r920] Fixed equals() function [ optimized in previous commit,
- but unchecked ]
- * [r919] Added note about CoordinateSequence signed->unsigned
- change in API
-2005-11-24 23:09 Sandro Santilli <strk at keybit.net>
- * [r918] CoordinateSequence indexes switched from int to the more
- the correct unsigned int. Optimizations here and there
- to avoid calling getSize() in loops.
- Update of all callers is not complete yet.
-2005-11-24 23:07 Sandro Santilli <strk at keybit.net>
- * [r917] CentroidLine made concrete class (only destructor was
- virtual) - avoided heap allocation for owned Coordinate centSum
-2005-11-21 16:03 Sandro Santilli <strk at keybit.net>
- * [r916] Coordinate interface change:
- Removed setCoordinate call, use assignment operator
- instead. Provided a compile-time switch to
- make copy ctor and assignment operators non-inline
- to allow for more accurate profiling.
- Coordinate copies removal:
- NodeFactory::createNode() takes now a Coordinate reference
- rather then real value. This brings coordinate copies
- in the testLeaksBig.xml test from 654818 to 645991
- (tested in 2.1 branch). In the head branch Coordinate
- copies are 222198.
- Removed useless coordinate copies in ConvexHull
- operations
- STL containers heap allocations reduction:
- Converted many containers element from
- pointers to real objects.
- Made some use of .reserve() or size
- initialization when final container size is known
- in advance.
- Stateless classes allocations reduction:
- Provided ::instance() function for
- NodeFactories, to avoid allocating
- more then one (they are all
- stateless).
- HCoordinate improvements:
- Changed HCoordinate constructor by HCoordinates
- take reference rather then real objects.
- Changed HCoordinate::intersection to avoid
- a new allocation but rather return into a provided
- storage. LineIntersector changed to reflect
- the above change.
-2005-11-18 00:55 Sandro Santilli <strk at keybit.net>
- * [r915] Fixed a bug in EdgeRing::containsPoint().
- Changed EdgeRing::getLinearRing() to avoid LinearRing copy and
- updated
- usages from PolygonBuilder.
- Removed CoordinateSequence copy in EdgeRing (ownership is
- transferred
- to its LinearRing).
- Removed heap allocations for EdgeRing containers.
- Initialization lists and cleanups.
-2005-11-16 22:21 Sandro Santilli <strk at keybit.net>
- * [r913] enforced const-correctness and use of initializer lists.
-2005-11-16 15:49 Sandro Santilli <strk at keybit.net>
- * [r912] Reduced gratuitous heap allocations.
-2005-11-15 18:30 Sandro Santilli <strk at keybit.net>
- * [r911] Removed dead code
-2005-11-15 12:14 Sandro Santilli <strk at keybit.net>
- * [r909] Reduced heap allocations, made use of references when
- appropriate,
- small optimizations here and there.
-2005-11-15 10:04 Sandro Santilli <strk at keybit.net>
- * [r908] Reduced heap allocations (vectors, mostly).
- Enforced const-correctness, changed some interfaces
- to use references rather then pointers when appropriate.
-2005-11-15 10:02 Sandro Santilli <strk at keybit.net>
- * [r907] optimized envelope computation reducing virtual calls
-2005-11-14 18:14 Sandro Santilli <strk at keybit.net>
- * [r906] Reduced heap allocations made by TopologyLocation and
- Label objects.
- Enforced const-correctness on GraphComponent.
- Cleanups.
-2005-11-10 16:26 Sandro Santilli <strk at keybit.net>
- * [r904] Fixed printHEX (was printing one char past the WKB)
-2005-11-10 15:20 Sandro Santilli <strk at keybit.net>
- * [r903] Made virtual overloads explicit.
-2005-11-10 10:47 Sandro Santilli <strk at keybit.net>
- * [r902] Renamed MultiPoint::getCoordinate(int) to
- MultiPoint::getCoordinateN(int)
- to avoid hiding of Geometry::getCoordinate().
-2005-11-10 10:24 Sandro Santilli <strk at keybit.net>
- * [r901] Fixed virtual overload of CoordinateArrayFilter::filter*
-2005-11-10 09:33 Sandro Santilli <strk at keybit.net>
- * [r900] Removed virtual overloading
- LineString::compareTo(LineString *)
-2005-11-09 15:14 Sandro Santilli <strk at keybit.net>
- * [r899] Forgot to add this
-2005-11-09 13:44 Sandro Santilli <strk at keybit.net>
- * [r898] Cleanups in Node and NodeMap.
- Optimization of EdgeIntersectionLessThen.
-2005-11-09 08:57 Sandro Santilli <strk at keybit.net>
- * [r897] IntersectionMatrix made a concrete and final type.
- Cleanups in class definition.
-2005-11-08 20:12 Sandro Santilli <strk at keybit.net>
- * [r896] Memory overhead reductions in buffer operations.
-2005-11-08 12:32 Sandro Santilli <strk at keybit.net>
- * [r895] Cleanups, ::setPoint small improvement
-2005-11-08 11:33 Sandro Santilli <strk at keybit.net>
- * [r894] comments cleanup
-2005-11-08 10:26 Sandro Santilli <strk at keybit.net>
- * [r893] Library versioning took back to 3.0.0
-2005-11-08 10:03 Sandro Santilli <strk at keybit.net>
- * [r892] Set library version to 2.2.0.
- Cleaned up Doxygen warnings.
- Inlined more Envelope methods.
- Dropped deprecated Envelope::overlaps methods.
-2005-11-07 18:07 Sandro Santilli <strk at keybit.net>
- * [r890] Removed VisualStudio knowledge from configure script
-2005-11-07 18:05 Sandro Santilli <strk at keybit.net>
- * [r889] Reduced set<> lookups
-2005-11-07 13:17 Frank Warmerdam <warmerdam at pobox.com>
- * [r888] no longer used
- * [r887] removed VisualStudio, no longer distributed
-2005-11-07 13:16 Frank Warmerdam <warmerdam at pobox.com>
- * [r886] obsolete
-2005-11-07 12:31 Sandro Santilli <strk at keybit.net>
- * [r885] Changed EdgeIntersectionList to use a set<> rathern then a
- vector<>, and
- to avoid dynamic allocation of initial header.
- Inlined short SweepLineEvent methods.
-2005-11-07 11:32 Sandro Santilli <strk at keybit.net>
- * [r884] Added const qualifiers to function to reflect paradigm of
- immutable
- Geometry objects.
-2005-11-04 15:42 Sandro Santilli <strk at keybit.net>
- * [r883] Fixed bug in SweepLineEventLessThen functor
- (didn't conform to strict weak ordering).
- Note: this was introduced by previous commit.
-2005-11-04 11:06 Sandro Santilli <strk at keybit.net>
- * [r882] updated
-2005-11-04 11:04 Sandro Santilli <strk at keybit.net>
- * [r881] Ported revision 1.38 of IsValidOp.java (adding closed Ring
- checks).
- Changed NestedRingTester classes to use Coorinate pointers
- rather then actual objects, to speedup NULL tests.
- Added JTS port revision when applicable.
-2005-11-04 08:28 Sandro Santilli <strk at keybit.net>
- * [r880] Ported speedup of OverlayOp::insertUniqueEdge() from
- JTS-1.7 (rev 1.23)
- Updated NEWS file.
-2005-11-03 21:28 Sandro Santilli <strk at keybit.net>
- * [r878] Fixed constructors broke by previous commit
-2005-11-03 19:51 Sandro Santilli <strk at keybit.net>
- * [r877] Indentation changes, small vector memory allocation
- optimization.
-2005-11-03 09:15 Sandro Santilli <strk at keybit.net>
- * [r876] Removed declaration of PointCoordinateSequence and
- PointCoordinateSequenceFactory
-2005-11-01 09:40 Sandro Santilli <strk at keybit.net>
- * [r875] Replaced finite() with FINITE() calls.
-2005-10-27 14:05 Sandro Santilli <strk at keybit.net>
- * [r873] Added a SweepLineEventLessThen functor to be used by sort
- algorithm.
-2005-10-24 13:28 Sandro Santilli <strk at keybit.net>
- * [r872] Changed constructors to take ownership of GEOSGeom and
- GEOSCoordSeq objects.
- Changed inspectors to retain ownership of GEOSGeom and
- Added GEOSGeom_clone() method.
-2005-10-21 15:13 Sandro Santilli <strk at keybit.net>
- * [r871] Added GEOSGeom_clone() function
-2005-10-21 12:14 Sandro Santilli <strk at keybit.net>
- * [r870] Added missing GEOS_DLL specifiers
-2005-10-21 12:07 Sandro Santilli <strk at keybit.net>
- * [r869] Added fine-grained geometry constructors and GEOSCoordSeq
- abstract data type.
- Renamed GEOSmakeCollection to GEOSGeom_createCollection
-2005-10-21 09:02 Sandro Santilli <strk at keybit.net>
- * [r868] typo fixed
-2005-10-21 02:46 Frank Warmerdam <warmerdam at pobox.com>
- * [r867] added myself to authors - isn't that cheeky!
-2005-10-21 02:45 Frank Warmerdam <warmerdam at pobox.com>
- * [r866] added note on source\makefile.vc
-2005-10-21 02:44 Frank Warmerdam <warmerdam at pobox.com>
- * [r865] added a wee readme
-2005-10-21 02:41 Frank Warmerdam <warmerdam at pobox.com>
- * [r864] added DLL building, and geostest.exe
- * [r863] need to DLL export C API
-2005-10-21 02:37 Frank Warmerdam <warmerdam at pobox.com>
- * [r862] DLL Export functions
- * [r861] avoid non-portable vasprintf, make big buffer static
-2005-10-21 01:57 Frank Warmerdam <warmerdam at pobox.com>
- * [r860] updated for 3.0.0 and added C API
-2005-10-20 20:37 Frank Warmerdam <warmerdam at pobox.com>
- * [r859] added getMachineByteOrder(), convert to unix text mode
-2005-10-19 13:07 Sandro Santilli <strk at keybit.net>
- * [r858] Added support for SRID flag in WKB (full EWKB is accepted
- now)
-2005-10-19 12:59 Sandro Santilli <strk at keybit.net>
- * [r857] Added input stream checks in ByteOrderDataInStream,
- throwing ParseException on unexpected EOF
-2005-10-17 15:55 Sandro Santilli <strk at keybit.net>
- * [r856] Added GetGeometryN, GetInteriorRingN, GetExteriorRing
-2005-10-17 14:37 Sandro Santilli <strk at keybit.net>
- * [r855] Added comments on exception returns for Geometry info
- functions
-2005-10-17 14:33 Sandro Santilli <strk at keybit.net>
- * [r854] Added missing exception handlers from previous commit.
- Fixed GEOSGeomTypeId signatures.
-2005-10-17 12:56 Sandro Santilli <strk at keybit.net>
- * [r853] Removed GEOS_VERSION define (Geometry.cpp, the only file
- using this will use the one in version.h)
-2005-10-17 12:55 Sandro Santilli <strk at keybit.net>
- * [r852] Fixed GEOSGeom typedef to be accepted by C++ compilers,
- added extern "C" namespace for inclusion by C++ code (really
- needed?)
-2005-10-17 09:38 Sandro Santilli <strk at keybit.net>
- * [r851] Added GEOSDistance() function.
- Trapped all exceptions and reported using ERROR_MESSAGE rather
- then NOTICE_MESSAGE.
- Changed WKB functions to use 'unsigned char' rather then 'char'
- Added missing GEOS_setWKBOutputDims() function in header file.
-2005-09-28 16:33 Sandro Santilli <strk at keybit.net>
- * [r850] Added GEOS_setWKBOutputDims(int) function to specify
- coordinate
- dimension in WKB output.
-2005-09-28 10:15 Sandro Santilli <strk at keybit.net>
- * [r849] WKBWriter ctor out-lined (will require changes in the near
- future, for higher dimensions support), added support for 3d WKB
- output
-2005-09-28 09:36 Sandro Santilli <strk at keybit.net>
- * [r848] Cleanups in the printHEX function
-2005-09-27 16:29 Sandro Santilli <strk at keybit.net>
- * [r847] Ported JTS-1.7 use of PrecisionModel in WKBReader
-2005-09-27 16:20 Sandro Santilli <strk at keybit.net>
- * [r846] Reverted previous change, fixed the bug by turning
- WKBReader.factory
- into a reference rather then a real object. ABI still breaks, but
- API
- at least is safe (we didn't release any WKB-aware package so
- breaking
- ABI is not a big deal at this stage).
-2005-09-27 16:00 Sandro Santilli <strk at keybit.net>
- * [r845] Fixed bug in WKBReader destroying the GeometryFactory used
- in Geometry
- construction. Changed it's definition to *require* a
- GeometryFactory
- pointer parameter.
-2005-09-27 08:51 Sandro Santilli <strk at keybit.net>
- * [r844] Added XMLTester.h in XMLTester_SOURCES list
-2005-09-26 14:40 Sandro Santilli <strk at keybit.net>
- * [r843] Fixed handling of higher dimensional WKB streams
-2005-09-26 13:46 Sandro Santilli <strk at keybit.net>
- * [r842] Modified GEOS_CAPI_VERSION to include underlying GEOS
- version
-2005-09-26 13:42 Sandro Santilli <strk at keybit.net>
- * [r841] Moved C-api versioning to top-level configure.in
- Added version info in geos_c.h
-2005-09-26 12:25 Sandro Santilli <strk at keybit.net>
- * [r840] Changed LineMerge interface to accept a single Geometry
- and return the simpler Geometry obtainable with the set of merger
- LineStrings. Fixed leaks in geostest, fixed a leak in
- GEOSRelate().
-2005-09-26 12:23 Sandro Santilli <strk at keybit.net>
- * [r839] Initializzation lists in PrecisionModel ctors
-2005-09-26 11:04 Sandro Santilli <strk at keybit.net>
- * [r838] Added changes in LineMerger
-2005-09-26 11:01 Sandro Santilli <strk at keybit.net>
- * [r837] Const correctness changes in LineMerger package, and a few
- speedups.
-2005-09-26 08:18 Sandro Santilli <strk at keybit.net>
- * [r836] Added .lo, .la and geostest
-2005-09-26 08:17 Sandro Santilli <strk at keybit.net>
- * [r835] Removed memory leak from WKB tester
-2005-09-23 17:20 Sandro Santilli <strk at keybit.net>
- * [r834] Made LineMerger graph be a real object (rather then a
- pointer to it)
-2005-09-23 16:07 Sandro Santilli <strk at keybit.net>
- * [r833] Fixed export of GEOSPolygonize() and GEOSMakeCollection()
-2005-09-23 09:49 Sandro Santilli <strk at keybit.net>
- * [r832] Added GEOSMakeCollection.
- Changed GEOSGetCentroid to return an EmptyGeometry when no
- Centroid can be
- computed (Empty input, for example).
-2005-09-19 08:16 Sandro Santilli <strk at keybit.net>
- * [r831] Added C api
-2005-09-14 15:11 Sandro Santilli <strk at keybit.net>
- * [r830] Removed functions returning not-new GEOSGeom objects to
- avoid ambiguity
- whereas when to destroy returns. Added not about memory
- management.
-2005-09-14 14:55 Sandro Santilli <strk at keybit.net>
- * [r829] Added copyright notices and usage notes
-2005-09-14 14:28 Sandro Santilli <strk at keybit.net>
- * [r828] Fixed bug writing WKB for all Multi* geoms as Collections.
-2005-09-14 13:58 Sandro Santilli <strk at keybit.net>
- * [r827] Initial abstract C api.
-2005-09-14 13:56 Sandro Santilli <strk at keybit.net>
- * [r826] Typo fixed
-2005-09-03 21:26 Sandro Santilli <strk at keybit.net>
- * [r825] Reworked WKB I/O to avoid use of templates and make better
- use of STL
-2005-08-22 13:34 Sandro Santilli <strk at keybit.net>
- * [r822] Added 2.1.4 section
-2005-08-22 13:31 Sandro Santilli <strk at keybit.net>
- * [r821] Fixed comparator functions used with STL sort() algorithm
- to
- implement StrictWeakOrdering semantic.
-2005-07-12 14:33 Sandro Santilli <strk at keybit.net>
- * [r819] updated
-2005-07-11 16:21 Sandro Santilli <strk at keybit.net>
- * [r818] Removed '_' prefix from header guards
-2005-07-11 12:17 Sandro Santilli <strk at keybit.net>
- * [r817] Cleaned up syntax
- * [r816] Commented out useless include
-2005-07-11 10:50 Sandro Santilli <strk at keybit.net>
- * [r815] Added parens suggested by compiler
-2005-07-11 10:27 Sandro Santilli <strk at keybit.net>
- * [r814] Cleaned up signed/unsigned mismatches
- * [r813] Fixed initializzazion lists
-2005-07-11 10:26 Sandro Santilli <strk at keybit.net>
- * [r812] Made CoordinateSequence::getDimension return unsigned int
- instead of int
-2005-07-11 10:23 Sandro Santilli <strk at keybit.net>
- * [r811] removed useless assignment
-2005-06-30 18:31 Sandro Santilli <strk at keybit.net>
- * [r807] Ported SubgraphDepthLocator optimizations from JTS code
-2005-06-28 21:13 Sandro Santilli <strk at keybit.net>
- * [r803] Fixed a bug introduced by LineSegment skip - made
- LineSegment skip a compile-time optione
-2005-06-28 16:52 Sandro Santilli <strk at keybit.net>
- * [r802] Added number of points count as a debugging aid
-2005-06-28 11:22 Sandro Santilli <strk at keybit.net>
- * [r801] Added DepthSegmentLT bugfix
-2005-06-28 01:07 Sandro Santilli <strk at keybit.net>
- * [r796] improved extraction of result points in overlay op
-2005-06-28 00:04 Sandro Santilli <strk at keybit.net>
- * [r794] improved ::isIncidentEdgeInResult() method
-2005-06-27 21:58 Sandro Santilli <strk at keybit.net>
- * [r793] Bugfix in DepthSegmentLT as suggested by Graeme Hiebert
-2005-06-27 21:24 Sandro Santilli <strk at keybit.net>
- * [r790] Fixed bug just-introduced with optimization.
-2005-06-27 21:21 Sandro Santilli <strk at keybit.net>
- * [r789] Reduced Coordinate copies due to LineSegment overuse
-2005-06-25 10:20 Sandro Santilli <strk at keybit.net>
- * [r787] OverlayOp speedup (JTS port)
-2005-06-24 11:12 Sandro Santilli <strk at keybit.net>
- * [r786] Added LineIntersector concrete type note
-2005-06-24 11:09 Sandro Santilli <strk at keybit.net>
- * [r785] Dropped RobustLineIntersector, made LineIntersector a
- concrete class.
- Added
- LineIntersector::hasIntersection(Coordinate&,Coordinate&,Coordinate&)
- to avoid computing intersection point (Z) when it's not
- necessary.
-2005-06-23 14:22 Sandro Santilli <strk at keybit.net>
- * [r784] Inlined and added missing ::clone() for Geometry
- subclasses
-2005-06-23 11:23 Sandro Santilli <strk at keybit.net>
- * [r782] performance improvement for CGAlgorithms::isOnLine()
-2005-06-22 00:46 Sandro Santilli <strk at keybit.net>
- * [r779] Shortcircuit tests for Union
- * [r777] Fixed bugus handling of collections in ::buildGeometry
-2005-06-21 12:22 Sandro Santilli <strk at keybit.net>
- * [r773] XMLTester code cleanups
-2005-06-20 10:23 Sandro Santilli <strk at keybit.net>
- * [r772] XMLTester installed by default
-2005-06-17 15:17 Sandro Santilli <strk at keybit.net>
- * [r770] Removed ltmain.sh from repository, will be created by
- autogen.sh
-2005-06-17 15:08 Sandro Santilli <strk at keybit.net>
- * [r766] Polygonizer segfault fix
-2005-06-17 14:58 Sandro Santilli <strk at keybit.net>
- * [r764] Fixed segfault in LinearRing and LineString constructors
-2005-06-14 11:57 Sandro Santilli <strk at keybit.net>
- * [r761] Added workaround for mingw Polygon name clash
-2005-06-10 14:04 Sandro Santilli <strk at keybit.net>
- * [r760] Added libtoolize call
-2005-06-10 13:24 Sandro Santilli <strk at keybit.net>
- * [r758] Added use declaration to make MingW build work
-2005-06-08 09:38 Sandro Santilli <strk at keybit.net>
- * [r754] Added GCC version requirement note
-2005-06-05 10:41 Sandro Santilli <strk at keybit.net>
- * [r752] Changes file renamed back to NEWS, automake insists on
- finding it.
-2005-05-30 16:20 No Body <no at body.net>
- * [r750] Blank news file to molfify new versions of autoconf
-2005-05-24 08:42 Sandro Santilli <strk at keybit.net>
- * [r749] Info moved into CHANGES file
- * [r748] Filled in section from 2.0.0 to 2.1.1
-2005-05-24 07:48 Sandro Santilli <strk at keybit.net>
- * [r744] Initial import
-2005-05-23 16:42 Sandro Santilli <strk at keybit.net>
- * [r728] Added Refractions copyright
-2005-05-23 15:13 Sandro Santilli <strk at keybit.net>
- * [r717] Added debugging output
-2005-05-23 15:04 Sandro Santilli <strk at keybit.net>
- * [r716] Fixed bug in ::reverse()
-2005-05-22 17:45 Sandro Santilli <strk at keybit.net>
- * [r715] Fixed initialization list order
-2005-05-22 17:42 Sandro Santilli <strk at keybit.net>
- * [r714] Added missing WKBWriterT.h
-2005-05-20 16:15 Sandro Santilli <strk at keybit.net>
- * [r713] Code cleanups
-2005-05-20 16:14 Sandro Santilli <strk at keybit.net>
- * [r712] Fixed a bug in addPolygonRing setting wrong depths on
- Edges
-2005-05-19 10:29 Sandro Santilli <strk at keybit.net>
- * [r711] Removed some CGAlgorithms instances substituting them with
- direct calls
- to the static functions. Interfaces accepting CGAlgorithms
- pointers kept
- for backward compatibility but modified to make the argument
- optional.
- Fixed a small memory leak in OffsetCurveBuilder::getRingCurve.
- Inlined some smaller functions encountered during bug hunting.
- Updated Copyright notices in the touched files.
-2005-05-19 10:26 Sandro Santilli <strk at keybit.net>
- * [r710] Added bogus multipolygon buffering test
-2005-05-13 18:06 Sandro Santilli <strk at keybit.net>
- * [r709] Added default tolerance parameter for equalsExact
-2005-05-13 17:15 Sandro Santilli <strk at keybit.net>
- * [r708] cleanups and indentations
-2005-05-13 17:14 Sandro Santilli <strk at keybit.net>
- * [r707] Added comment about 2D-only comparison of
- ::equal(Coordinate, Coordinate, double)
-2005-05-09 21:17 Sandro Santilli <strk at keybit.net>
- * [r706] Second argument to ::write made mandatory.
-2005-05-09 10:35 Sandro Santilli <strk at keybit.net>
- * [r705] Ported JTS robustness patches made by Martin on
- suggestions by Kevin.
-2005-05-03 15:30 Sandro Santilli <strk at keybit.net>
- * [r704] Added WKB TODOs
-2005-04-29 17:40 Sandro Santilli <strk at keybit.net>
- * [r703] Updated Doxygen documentation and some Copyright headers.
-2005-04-29 16:36 Sandro Santilli <strk at keybit.net>
- * [r702] Fixed biostringstream stream output.
- * [r701] Made WKBReader use global_factory, for having WKB reads
- produce
- same context of input geoms.
-2005-04-29 15:34 Sandro Santilli <strk at keybit.net>
- * [r700] Typedef'ed biostringstream, preferred parameter for
- WKB parser templates.
- Added << operator for biostringstream.
- Typedef'ed WKBWriter and WKBReader to be parametrized by
- biostringstream.
- Added WKBtest in doc/example.cpp
-2005-04-29 11:52 Sandro Santilli <strk at keybit.net>
- * [r699] Added new JTS interfaces for CoordinateSequence and
- factories,
- removed example implementations to reduce maintainance costs.
- Added first implementation of WKBWriter, made
- ByteOrderDataInStream
- a template class.
-2005-04-29 11:50 Sandro Santilli <strk at keybit.net>
- * [r698] Added machine byte order extractor
-2005-04-21 15:13 Sandro Santilli <strk at keybit.net>
- * [r697] library version bumped to 3.0.0
-2005-04-21 13:43 Sandro Santilli <strk at keybit.net>
- * [r696] Updated chage logs
-2005-04-21 11:16 Sandro Santilli <strk at keybit.net>
- * [r695] Removed useless Coordinate copies in mergeZ() - patch by
- Safe Software
-2005-04-20 17:56 Sandro Santilli <strk at keybit.net>
- * [r694] Removed NonRobustCGAlgorithms and RobustCGAlgorithms,
- already
- unused (CGAlgorithms replaces both with robust implementation).
-2005-04-20 17:22 Sandro Santilli <strk at keybit.net>
- * [r693] Added initial implementation of WKBReaderT and
- ByteOrderDataInStreamT
- class templates and ByteOrderValues class.
- Work is unfinished as WKBReader requires new interface of
- taking higher dimensions into account.
-2005-04-20 17:18 Sandro Santilli <strk at keybit.net>
- * [r692] Added standard copyright header
-2005-04-19 11:49 Sandro Santilli <strk at keybit.net>
- * [r691] Fixed segfault in ::isEmpty
-2005-04-14 11:49 Sandro Santilli <strk at keybit.net>
- * [r690] Applied slightly modified patch by Cheng Shan to speedup
- WKT parsing.
-2005-04-07 18:43 Sandro Santilli <strk at keybit.net>
- * [r689] Fixed bug throwing an exception when a result could be
- returned instead
- (ported JTS patch)
-2005-04-06 11:09 Sandro Santilli <strk at keybit.net>
- * [r688] Applied patch from Jon Schlueter (math.h => cmath;
- ieeefp.h in "C" block)
-2005-04-02 17:07 Sean Gillies <sgillies at frii.com>
- * [r687] now supporting the win32 platform, thanks to Howard Butler
-2005-03-26 08:19 Sandro Santilli <strk at keybit.net>
- * [r686] Commented out Polygonizer::LineStringAdder friendship
-2005-03-10 17:27 Sandro Santilli <strk at keybit.net>
- * [r685] ported from current JTS
-2005-03-04 07:48 Sandro Santilli <strk at keybit.net>
- * [r684] Removed useless copy from ::isOnLine() - suggested by Dale
- Lutz
-2005-03-02 08:14 Sandro Santilli <strk at keybit.net>
- * [r683] Removed commented line, cousing strange behaviours with
- autotools.
-2005-02-22 18:21 Sandro Santilli <strk at keybit.net>
- * [r682] Changed SegmentNode to contain a *real* Coordinate (not a
- pointer) to reduce
- construction costs.
-2005-02-22 17:10 Sandro Santilli <strk at keybit.net>
- * [r681] Reduced CoordinateSequence::getSize() calls.
-2005-02-22 16:24 Sandro Santilli <strk at keybit.net>
- * [r680] cached number of points in Edge
-2005-02-22 16:23 Sandro Santilli <strk at keybit.net>
- * [r679] Cached number of points in CoordinateSequence.
-2005-02-22 15:49 Sandro Santilli <strk at keybit.net>
- * [r678] Reduced calls to DefaultCoordinateSequence->getSize().
-2005-02-22 15:16 Sandro Santilli <strk at keybit.net>
- * [r677] STRtree::avg() and STRtree::centreY() inlined.
-2005-02-22 10:55 Sandro Santilli <strk at keybit.net>
- * [r676] Optimized Edge::equals(Edge *e)
-2005-02-18 08:20 Sandro Santilli <strk at keybit.net>
- * [r675] Added support for point-per-quadrant argument in buffer
- tests (using arg2).
-2005-02-17 09:56 Sandro Santilli <strk at keybit.net>
- * [r674] Commented out unused variable.
- * [r673] Applied patch from Jon Schlueter using <cmath> instead of
- <math.h>
-2005-02-15 17:15 Sandro Santilli <strk at keybit.net>
- * [r672] Inlined most Envelope methods, reserved() memory for some
- vectors when
- the usage was known a priori.
-2005-02-11 08:58 Sandro Santilli <strk at keybit.net>
- * [r671] Applied patch from Curtis Barrett handling --includedir
- and --libdir
- params for configure.
-2005-02-05 05:44 Sandro Santilli <strk at keybit.net>
- * [r670] Changed geomgraph nodeMap to use Coordinate pointers as
- keys, reduces
- lots of other Coordinate copies.
-2005-02-04 23:55 Sandro Santilli <strk at keybit.net>
- * [r669] Envelope destructor made non-virtual to give compiler more
- static
- binding options.
-2005-02-04 18:49 Sandro Santilli <strk at keybit.net>
- * [r668] Changed ::computeDepths to use a set instead of a vector
- for checking
- visited Edges.
-2005-02-04 14:49 Sandro Santilli <strk at keybit.net>
- * [r667] Added rule to build staticXMLTester (for profiling with
- gprof)
-2005-02-03 09:17 Sandro Santilli <strk at keybit.net>
- * [r666] more profiling label
-2005-02-01 16:09 Sandro Santilli <strk at keybit.net>
- * [r665] more profiling labels
-2005-02-01 16:06 Sandro Santilli <strk at keybit.net>
- * [r664] Small optimizations.
-2005-02-01 14:18 Sandro Santilli <strk at keybit.net>
- * [r663] More profiler labels
- * [r662] Made profiler start/stop inline
-2005-02-01 13:44 Sandro Santilli <strk at keybit.net>
- * [r661] More profiling labels.
-2005-01-31 15:41 Sandro Santilli <strk at keybit.net>
- * [r660] Small optimizations.
-2005-01-28 10:01 Sandro Santilli <strk at keybit.net>
- * [r659] substituted sprintf calls with use of ostringstream
-2005-01-28 09:47 Sandro Santilli <strk at keybit.net>
- * [r658] Replaced sprintf uses with ostringstream.
-2005-01-28 08:47 Sandro Santilli <strk at keybit.net>
- * [r657] Removed sprintf usage, replaced with sstream
-2005-01-28 07:58 Sandro Santilli <strk at keybit.net>
- * [r656] removed sprintf usage, ad ::toString call
- Coordinate::toString
-2005-01-18 17:22 Sandro Santilli <strk at keybit.net>
- * [r655] reverted previous change, sign was actually stored in zgap
-2005-01-18 17:09 Sandro Santilli <strk at keybit.net>
- * [r654] Fixed interpolateZ call using final intersection point
- instead of HCoordinate.
-2005-01-14 08:04 Sandro Santilli <strk at keybit.net>
- * [r653] Fixed Z interpolation to use the correct sign
-2005-01-03 16:06 Sandro Santilli <strk at keybit.net>
- * [r652] Changed polygonize op to return a GeometryCollection
-2005-01-03 15:56 Sandro Santilli <strk at keybit.net>
- * [r651] Fixed memory leaks just introduced for Polygonizer test
- case.
-2005-01-03 15:49 Sandro Santilli <strk at keybit.net>
- * [r650] Added Polygonize test handling
-2004-12-30 13:32 Sandro Santilli <strk at keybit.net>
- * [r649] Handled NULL result from getCentroid()
-2004-12-30 13:31 Sandro Santilli <strk at keybit.net>
- * [r648] Fixed a segfault on EMPTYGEOM->getCeontroid()
-2004-12-30 10:14 Sandro Santilli <strk at keybit.net>
- * [r647] never return LinearRing or MultiLinearRing from
- getBoundary
- * [r646] input checking and class promoting in
- createMultiLineString()
-2004-12-22 09:42 Sandro Santilli <strk at keybit.net>
- * [r645] Fixed a premature Geometry destruction, Avoided
- CoordinateSequence copies
- when possible.
-2004-12-16 18:29 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r644] Bumped minor version number for 2.1.1 release.
-2004-12-16 16:27 Sandro Santilli <strk at keybit.net>
- * [r643] Fixed LinearRing::clone() to return LinearRing instead of
- LineString
-2004-12-16 16:08 Sandro Santilli <strk at keybit.net>
- * [r642] New patches from Niki Spahiev <niki.spahiev at gmail.com>
- (still unstable)
-2004-12-16 09:05 Sandro Santilli <strk at keybit.net>
- * [r641] Added python example by Niki Spahiev
- <niki.spahiev at gmail.com>
-2004-12-16 08:56 Sandro Santilli <strk at keybit.net>
- * [r640] Applyed patches by Niki Spahiev <niki.spahiev at gmail.com>
-2004-12-14 10:35 Sandro Santilli <strk at keybit.net>
- * [r638] Comments cleanup. PolygonizeGraph keeps track of generated
- for delayed destruction.
-2004-12-13 13:54 Sandro Santilli <strk at keybit.net>
- * [r637] Added a not about gcc 2.95.4 required friendship
-2004-12-13 13:53 Sandro Santilli <strk at keybit.net>
- * [r636] Fixed uninitialized Coordinate.
-2004-12-12 17:22 Sandro Santilli <strk at keybit.net>
- * [r635] version.h and platform.h installed again (missed when
- removed from dist)
-2004-12-08 14:33 Sandro Santilli <strk at keybit.net>
- * [r634] Checked inner polys getBoundary return for the single
- LineString case.
-2004-12-08 14:32 Sandro Santilli <strk at keybit.net>
- * [r633] cleanups
-2004-12-08 14:31 Sandro Santilli <strk at keybit.net>
- * [r632] adjusted getBoundary expected returns to match OGC specs
- * [r631] elevationMatrix deleted by destructor
-2004-12-08 14:30 Sandro Santilli <strk at keybit.net>
- * [r630] Added default profiler instance cleanup
-2004-12-08 13:54 Sandro Santilli <strk at keybit.net>
- * [r629] gcc warnings checked and fixed, general cleanups.
-2004-12-06 10:54 Sandro Santilli <strk at keybit.net>
- * [r628] Added timeval.h in distribution.
-2004-12-05 10:54 Sandro Santilli <strk at keybit.net>
- * [r627] initial revision
-2004-12-05 10:50 Sandro Santilli <strk at keybit.net>
- * [r626] forgot to add
-2004-12-05 10:48 Sandro Santilli <strk at keybit.net>
- * [r625] Modifications by Alex Bodnaru
-2004-12-05 10:44 Sandro Santilli <strk at keybit.net>
- * [r624] Applied Norman Vine patches for cleaner win32 build.
-2004-12-04 15:56 Sandro Santilli <strk at keybit.net>
- * [r623] Added source/Makefile.vc and
- source/headers/geos/platform.h.in in distribution
-2004-12-04 15:31 Sandro Santilli <strk at keybit.net>
- * [r622] Added VisualStudio dir in distribution, removed platform.h
- and version.h from it.
-2004-12-04 01:20 Frank Warmerdam <warmerdam at pobox.com>
- * [r621] removed dll delete
-2004-12-03 22:52 Sandro Santilli <strk at keybit.net>
- * [r620] enforced const return of CoordinateSequence::toVector()
- method to derivate classes.
-2004-12-03 16:26 Frank Warmerdam <warmerdam at pobox.com>
- * [r619] added headers
-2004-12-03 16:25 Frank Warmerdam <warmerdam at pobox.com>
- * [r618] New
-2004-12-03 16:22 Frank Warmerdam <warmerdam at pobox.com>
- * [r617] update to use I64 on MSVC for 64 bit integer constants,
- also toVector chg.
-2004-12-03 16:21 Frank Warmerdam <warmerdam at pobox.com>
- * [r616] dont try for sys/time.h with MSVC
-2004-12-03 16:19 Frank Warmerdam <warmerdam at pobox.com>
- * [r615] New
-2004-11-30 16:44 Sandro Santilli <strk at keybit.net>
- * [r614] Added gettimeofday implementation for win32, curtesy of Wu
- Yongwei.
-2004-11-30 13:05 Sandro Santilli <strk at keybit.net>
- * [r613] Removed inclusion of stdio.h, which should now be useless.
-2004-11-30 13:04 Sandro Santilli <strk at keybit.net>
- * [r612] Added optional inclusion of ieeefp.h on platform providing
- it.
-2004-11-29 16:05 Sandro Santilli <strk at keybit.net>
- * [r611] Fixed a bug in LineIntersector::interpolateZ causing NaN
- values
- to come out.
- Handled dimensional collapses in ElevationMatrix.
- Added ISNAN macro and changed ISNAN/FINITE macros to avoid
- dispendious isnan() and finite() calls.
-2004-11-27 11:36 Sandro Santilli <strk at keybit.net>
- * [r610] Updated scripts by Alex Bodnaru, added Makefile
-2004-11-26 09:53 Sandro Santilli <strk at keybit.net>
- * [r609] Added more FINITE calls, and added inf and -inf to FINITE
- checks
-2004-11-26 09:22 Sandro Santilli <strk at keybit.net>
- * [r608] Added FINITE(x) macro and its use.
- Made input geoms average Z computation optional in OverlayOp.
-2004-11-24 18:10 Sandro Santilli <strk at keybit.net>
- * [r607] Stricter handling of USE_ELEVATION_MATRIX define
- * [r606] Cleanup of interpolateZ
-2004-11-24 12:29 Sandro Santilli <strk at keybit.net>
- * [r605] Handled boundary cases in ::getCell
-2004-11-24 11:32 Sandro Santilli <strk at keybit.net>
- * [r604] Re-enabled Z propagation in output lines.
-2004-11-23 19:53 Sandro Santilli <strk at keybit.net>
- * [r603] Had LineIntersector compute Z by interpolation.
-2004-11-23 16:22 Sandro Santilli <strk at keybit.net>
- * [r602] Added ElevationMatrix class and components to do
- post-processing draping of overlayed geometries.
-2004-11-22 15:51 Sandro Santilli <strk at keybit.net>
- * [r601] Added interpolation of containing geometry's average Z for
- point_in_poly case.
-2004-11-22 13:02 Sandro Santilli <strk at keybit.net>
- * [r600] Fixed a bug in Collinear intersection Z computation
- * [r599] Forced use if computed intersection point in
- ::createSplitEdge (for Z computation)
-2004-11-22 12:59 Sandro Santilli <strk at keybit.net>
- * [r598] Added debugging lines
-2004-11-22 11:34 Sandro Santilli <strk at keybit.net>
- * [r597] More debugging lines and comments/indentation cleanups
- * [r596] Added Z computation for CollinearIntersections
-2004-11-20 18:54 Sandro Santilli <strk at keybit.net>
- * [r595] Scripts updates from Alex Bodnaru
-2004-11-20 18:17 Sandro Santilli <strk at keybit.net>
- * [r594] Added Z propagation for overlay lines output.
-2004-11-20 17:16 Sandro Santilli <strk at keybit.net>
- * [r593] Handled Z merging for point on polygon boundary case.
-2004-11-20 16:25 Sandro Santilli <strk at keybit.net>
- * [r592] Added Z computation for point on line case.
-2004-11-20 15:46 Sandro Santilli <strk at keybit.net>
- * [r591] Added composing Z management functions and elements for
- class Node
-2004-11-20 15:45 Sandro Santilli <strk at keybit.net>
- * [r590] Fixed Z merging in addNode(Node *)
-2004-11-20 15:41 Sandro Santilli <strk at keybit.net>
- * [r589] Added Z merging in ::addNode
- * [r588] Added management of vector of composing Z values.
-2004-11-20 15:40 Sandro Santilli <strk at keybit.net>
- * [r587] Added Z computation in point-segment intersection.
-2004-11-20 15:39 Sandro Santilli <strk at keybit.net>
- * [r586] Reduced HEAP allocations.
-2004-11-19 16:35 Sandro Santilli <strk at keybit.net>
- * [r585] Added debian package builder scripts.
-2004-11-19 16:15 Sandro Santilli <strk at keybit.net>
- * [r584] Completely removed sprintf usage, substituted by
- stringstream.
-2004-11-19 16:09 Sandro Santilli <strk at keybit.net>
- * [r583] Added <stdio.h> include for sprintf recognition.
-2004-11-19 10:10 Sandro Santilli <strk at keybit.net>
- * [r582] COMPUTE_Z re-enabled by default
-2004-11-19 09:33 Sandro Santilli <strk at keybit.net>
- * [r581] removed useless CoordinateSequence copy in ::addLineString
-2004-11-17 15:09 Sandro Santilli <strk at keybit.net>
- * [r580] Changed COMPUTE_Z defaults to be more conservative
-2004-11-17 08:41 Sandro Santilli <strk at keybit.net>
- * [r579] Fixed a bug in Z computation and removed debugging output
- by default.
-2004-11-17 08:13 Sandro Santilli <strk at keybit.net>
- * [r578] Indentation changes.
- Some Z_COMPUTATION activated by default.
-2004-11-12 18:12 Sandro Santilli <strk at keybit.net>
- * [r576] Changed ::getBoundary() to return LineString if polygon
- has no holes.
- (has required to pass OGC conformance test T20)
-2004-11-09 20:22 Sandro Santilli <strk at keybit.net>
- * [r575] Removed -g -O2 from geos-config --cflags output
-2004-11-08 18:33 Sandro Santilli <strk at keybit.net>
- * [r574] Just another small improvement.
-2004-11-08 15:58 Sandro Santilli <strk at keybit.net>
- * [r573] More performance tuning.
-2004-11-08 13:12 Sandro Santilli <strk at keybit.net>
- * [r572] Added profiler.h
-2004-11-08 12:15 Sandro Santilli <strk at keybit.net>
- * [r571] Added number of gathered timings in output.
-2004-11-08 11:19 Sandro Santilli <strk at keybit.net>
- * [r570] Profiler::get() always return a Profile (new if not
- existant).
-2004-11-08 10:58 Sandro Santilli <strk at keybit.net>
- * [r569] Optimized the ::intersect function to avoid nested
- function calls.
-2004-11-08 10:57 Sandro Santilli <strk at keybit.net>
- * [r568] Moved Log lines at the bottom, and cut oldest
-2004-11-06 08:16 Sandro Santilli <strk at keybit.net>
- * [r567] Fixed CGAlgorithms::isCCW from JTS port.
- Code cleanup in IsValidOp.
-2004-11-05 12:18 Sandro Santilli <strk at keybit.net>
- * [r566] updated
-2004-11-05 11:41 Sandro Santilli <strk at keybit.net>
- * [r565] Made IsValidOp handle IllegalArgumentException throw from
- GeometryGraph
- as a sign of invalidity (just for Polygon geometries).
- Removed leaks generated by this specific exception.
-2004-11-04 19:08 Sandro Santilli <strk at keybit.net>
- * [r564] Cleanups, initializers list, profiling.
-2004-11-04 08:49 Sandro Santilli <strk at keybit.net>
- * [r563] Unlinked new documentation.
-2004-11-03 08:22 Sandro Santilli <strk at keybit.net>
- * [r562] Slightly modified log/log2 based algo to better handle
- numbers in the
- range 0-1.
-2004-11-02 16:38 Sandro Santilli <strk at keybit.net>
- * [r561] Fixed ieee-754 detection switch
-2004-11-02 16:31 Sandro Santilli <strk at keybit.net>
- * [r560] updated
-2004-11-02 16:05 Sandro Santilli <strk at keybit.net>
- * [r559] Autodetect availability of IEEE-754 FP
-2004-11-02 15:49 Sandro Santilli <strk at keybit.net>
- * [r558] Moved ASSUME_IEEE_DOUBLE define from DoubleBits.cpp to
- indexQuadtree.h.
- Fixed a bug in powerOf2(). Made the !IEEE version less prone to
- round-offs (still has approximation errors).
-2004-11-02 14:13 Sandro Santilli <strk at keybit.net>
- * [r557] Fixed bug in IEEE-based exponent and PowerOf2 computation,
- but disabled
- at compile time.
-2004-11-02 14:11 Sandro Santilli <strk at keybit.net>
- * [r556] Added more profiling.
-2004-11-02 09:38 Sandro Santilli <strk at keybit.net>
- * [r555] Added timer for buffer test.
-2004-11-01 16:43 Sandro Santilli <strk at keybit.net>
- * [r554] Added Profiler code.
- Temporarly patched a bug in DoubleBits (must check drawbacks).
- Various cleanups and speedups.
-2004-10-27 13:57 Sandro Santilli <strk at keybit.net>
- * [r553] Added some debugging lines (disabled by default)
-2004-10-27 11:05 Sandro Santilli <strk at keybit.net>
- * [r552] updated
-2004-10-26 17:46 Sandro Santilli <strk at keybit.net>
- * [r551] Removed slash-stars in comments to remove annoying
- compiler warnings.
-2004-10-26 17:14 Sandro Santilli <strk at keybit.net>
- * [r550] current:revision:age set to 3.0.1 (will be release 2.1.0).
- added news.
-2004-10-26 16:22 Sandro Santilli <strk at keybit.net>
- * [r549] updated
-2004-10-26 16:09 Sandro Santilli <strk at keybit.net>
- * [r548] Some more intentation and envelope equality check fix.
-2004-10-21 22:29 Sandro Santilli <strk at keybit.net>
- * [r547] Indentation changes and some more COMPUTE_Z rules
-2004-10-21 17:13 Sandro Santilli <strk at keybit.net>
- * [r546] Fixed bug introduced by previous patch.
-2004-10-21 07:03 Sandro Santilli <strk at keybit.net>
- * [r545] Removed leak in ::readPolygonText reported by Carlos A.
- Rueda
-2004-10-20 17:32 Sandro Santilli <strk at keybit.net>
- * [r544] Initial approach to 2.5d intersection()
-2004-10-19 21:04 Sandro Santilli <strk at keybit.net>
- * [r543] updated
-2004-10-19 19:51 Sandro Santilli <strk at keybit.net>
- * [r542] Fixed many leaks and bugs in Polygonizer.
- Output still bogus.
-2004-10-18 12:43 Sandro Santilli <strk at keybit.net>
- * [r541] swig interface added to distribution.
-2004-10-13 10:03 Sandro Santilli <strk at keybit.net>
- * [r540] Added missing linemerge and polygonize operation.
- Bug fixes and leaks removal from the newly added modules and
- planargraph (used by them).
- Some comments and indentation changes.
-2004-09-23 21:36 Sandro Santilli <strk at keybit.net>
- * [r539] Fixed a bug in ::reverse (thanks to Elliott Edwards)
-2004-09-23 21:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r538] Back minor version back to 2.0.1
-2004-09-23 04:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r537] Bumped minor version to 2.0.2 after 2.0.1 release.
-2004-09-21 09:47 Sandro Santilli <strk at keybit.net>
- * [r536] fixed a mis-initialization bug in ::reduce
- * [r535] Removed useless auto_ptr usage in ::exponent
-2004-09-16 09:50 Sandro Santilli <strk at keybit.net>
- * [r534] updated
-2004-09-16 09:48 Sandro Santilli <strk at keybit.net>
- * [r533] Finer short-circuit tests for equals, within, contains.
- * [r532] Added Envelope::equals
-2004-09-16 07:32 Sandro Santilli <strk at keybit.net>
- * [r531] updated
- * [r530] Added short-circuit tests. Can be disabled at compile-time
-2004-09-13 12:50 Sandro Santilli <strk at keybit.net>
- * [r529] comments cleanup
-2004-09-13 12:40 Sandro Santilli <strk at keybit.net>
- * [r528] updated
- * [r527] Updated version number
-2004-09-13 12:39 Sandro Santilli <strk at keybit.net>
- * [r526] Added missing newline at end of output
- * [r525] Made Point and MultiPoint subject to Validity tests.
-2004-09-13 10:14 Sandro Santilli <strk at keybit.net>
- * [r524] Added INVALID_COORDINATE code num and error message.
-2004-09-13 10:12 Sandro Santilli <strk at keybit.net>
- * [r523] Added invalid coordinates checks in IsValidOp.
- Cleanups.
-2004-09-13 09:18 Sandro Santilli <strk at keybit.net>
- * [r522] Added IsValidOp::isValid(Coordinate &)
-2004-09-13 09:07 Sandro Santilli <strk at keybit.net>
- * [r521] Ported fix in LineString::isCoordinate
-2004-09-12 03:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r520] Casting changes to allow OS/X compilation.
-2004-09-07 08:29 Sandro Santilli <strk at keybit.net>
- * [r519] Fixed doxygen malformed comment for Coordinate class
-2004-08-20 03:20 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r517] Added reference to bigtest.h so 'make dist' includes it
- properly.
-2004-08-20 01:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r516] Removed examples from build directories for release (they
- don't build now).
-2004-08-04 08:26 Sandro Santilli <strk at keybit.net>
- * [r515] comments lift, stack allocation reduced
-2004-07-27 16:35 Sandro Santilli <strk at keybit.net>
- * [r514] Geometry::getEnvelopeInternal() changed to return a const
- Envelope *.
- This should reduce object copies as once computed the envelope of
- a
- geometry remains the same.
-2004-07-26 19:28 Sean Gillies <sgillies at frii.com>
- * [r513] added to AUTHORS
-2004-07-26 18:53 Sean Gillies <sgillies at frii.com>
- * [r512] added simple exception handling on all method calls
-2004-07-26 16:35 Sandro Santilli <strk at keybit.net>
- * [r511] Removed dangling MultiPoint::isClosed() method definition.
-2004-07-26 15:40 Sean Gillies <sgillies at frii.com>
- * [r510] wrapped up WKT reader and writer and added two test cases
- to check that it works. found a bug where the WKT reader crashes
- the program in the case of poorly formatted WKT string.
-2004-07-25 23:45 Sean Gillies <sgillies at frii.com>
- * [r509] SWIG interface for high level language modules, Python
- setup script, and beginning of a unit testing framework under
- swig/python/tests. The build works for today's CVS GEOS, and the
- test passes -- means that a module can be built, installed, and
- imported.
-2004-07-22 16:58 Sandro Santilli <strk at keybit.net>
- * [r508] runtime version extractor functions split. geos::version()
- is now
- geos::geosversion() and geos::jtsport()
-2004-07-22 08:45 Sandro Santilli <strk at keybit.net>
- * [r507] Documentation updates, memory leaks fixed.
-2004-07-22 07:19 Sandro Santilli <strk at keybit.net>
- * [r506] Changed getCoordinatesRO description.
-2004-07-22 07:04 Sandro Santilli <strk at keybit.net>
- * [r505] Documented missing geometry functions.
-2004-07-21 09:55 Sandro Santilli <strk at keybit.net>
- * [r504] CoordinateSequence::atLeastNCoordinatesOrNothing
- definition fix.
- Documentation fixes.
-2004-07-21 09:11 Sandro Santilli <strk at keybit.net>
- * [r503] Updated
-2004-07-20 08:35 Sandro Santilli <strk at keybit.net>
- * [r502] Updated doxygen rule
-2004-07-20 08:34 Sandro Santilli <strk at keybit.net>
- * [r501] Fixed a bug in opDistance.h.
- Removed doxygen tags from obsoleted CoordinateList.cpp.
- Got doxygen to run with no warnings.
-2004-07-19 19:37 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r500] Changed doxygen target to be more "make dist" friendly.
- (and allow autogeneration of CVS snapshot to work again.)
-2004-07-19 13:19 Sandro Santilli <strk at keybit.net>
- * [r499] Documentation fixes
-2004-07-19 10:38 Sandro Santilli <strk at keybit.net>
- * [r498] Added Doxyfile
- * [r497] updated
-2004-07-19 10:37 Sandro Santilli <strk at keybit.net>
- * [r496] Doxygen doc added to default build rules
- * [r495] defaultCoordinateSequenceFactory made module-static (use
- DefaultCoordinateSequenceFactory::instance() instead)
-2004-07-19 10:35 Sandro Santilli <strk at keybit.net>
- * [r494] bigtest.h moved to local dir
-2004-07-19 10:34 Sandro Santilli <strk at keybit.net>
- * [r493] removed doxygen documentation of removed feature
-2004-07-19 10:33 Sandro Santilli <strk at keybit.net>
- * [r492] Class documentation changed to report geos.h as WKT
- writer/parser header file
-2004-07-19 10:30 Sandro Santilli <strk at keybit.net>
- * [r491] acconfig.h moved one directory up
-2004-07-19 10:28 Sandro Santilli <strk at keybit.net>
- * [r490] Excluded example and test dirs from input set
-2004-07-17 10:48 Sandro Santilli <strk at keybit.net>
- * [r489] updated
- * [r488] added Doxyfile (generated)
- * [r487] fixed typo in documentation
-2004-07-17 10:47 Sandro Santilli <strk at keybit.net>
- * [r486] Doxygen configuration created at ./configure time, for
- versioning.
-2004-07-17 09:19 Sandro Santilli <strk at keybit.net>
- * [r485] added GEOS version report
-2004-07-17 09:18 Sandro Santilli <strk at keybit.net>
- * [r484] Added geos::version()
-2004-07-17 09:07 Sandro Santilli <strk at keybit.net>
- * [r483] Added --jtsport
-2004-07-17 09:06 Sandro Santilli <strk at keybit.net>
- * [r482] Added GEOS_FIRST_INTERFACE, GEOS_LAST_INTERFACE and
- GEOS_JTS_PORT
-2004-07-17 09:05 Sandro Santilli <strk at keybit.net>
- * [r481] Added JTS_PORT variable.
- Simplified versioning settings: comments added,
- major/minor/patchlevel
- extracted by CURRENT,AGE,REVISION.
-2004-07-16 17:02 Sandro Santilli <strk at keybit.net>
- * [r480] updated
-2004-07-16 16:20 Sandro Santilli <strk at keybit.net>
- * [r479] Libtool versioning scheme adopted.
-2004-07-16 16:09 Sandro Santilli <strk at keybit.net>
- * [r478] removed useless Includedir
-2004-07-16 15:57 Sandro Santilli <strk at keybit.net>
- * [r477] made includes use <>
-2004-07-16 13:27 Sandro Santilli <strk at keybit.net>
- * [r476] updated
-2004-07-16 10:28 Sandro Santilli <strk at keybit.net>
- * [r475] Dimesions object allocated on the heap
-2004-07-16 10:00 Sandro Santilli <strk at keybit.net>
- * [r474] Bug fixed in GeometricShapeFactory examples.
- Added example of GeometricShapeFactory::createArc.
-2004-07-16 09:58 Sandro Santilli <strk at keybit.net>
- * [r473] updated
- * [r472] Added LINEARRING to LINESTRING conversion
-2004-07-16 09:57 Sandro Santilli <strk at keybit.net>
- * [r471] Modified library version to 1.4.0
-2004-07-15 13:41 Sandro Santilli <strk at keybit.net>
- * [r470] Added createRectangle example.
-2004-07-15 13:40 Sandro Santilli <strk at keybit.net>
- * [r469] Memory leaks fixed, CoordinateSequence use made JTS -
- compatible.
-2004-07-14 21:21 Sandro Santilli <strk at keybit.net>
- * [r468] updated
-2004-07-14 21:20 Sandro Santilli <strk at keybit.net>
- * [r467] Added GeometricShapeFactory note on doxygen mainpage
- * [r466] added geos/io.h and geos/unload.h
-2004-07-14 21:19 Sandro Santilli <strk at keybit.net>
- * [r465] GeometricShapeFactory first pass of bug fixes
-2004-07-14 21:17 Sandro Santilli <strk at keybit.net>
- * [r464] added missing GeometricShapeFactory.cpp
- * [r463] added inequality operator for Coordinate
-2004-07-14 21:15 Sandro Santilli <strk at keybit.net>
- * [r462] Added GeometricShapeFactory example: createCircle.
- Added simple filter to send example output to a postgis table.
-2004-07-13 08:33 Sandro Santilli <strk at keybit.net>
- * [r461] Added missing virtual destructor to virtual classes.
- Fixed implicit unsigned int -> int casts
-2004-07-12 19:16 Sandro Santilli <strk at keybit.net>
- * [r460] Commented out CoordinateList class definition.
-2004-07-12 15:42 Sandro Santilli <strk at keybit.net>
- * [r459] Fixed maximumPreciseValue scope
-2004-07-09 08:01 Sandro Santilli <strk at keybit.net>
- * [r458] updated
-2004-07-08 19:41 Sandro Santilli <strk at keybit.net>
- * [r457] renamed to reflect JTS API.
-2004-07-08 19:38 Sandro Santilli <strk at keybit.net>
- * [r456] renamed from *List* equivalents
-2004-07-08 19:37 Sandro Santilli <strk at keybit.net>
- * [r455] Renamed to PointCoordinateSequence.cpp
- * [r454] Renamed to CoordinateSequenceFactory.cpp
-2004-07-08 19:36 Sandro Santilli <strk at keybit.net>
- * [r453] Renamed to DefaultCoordinateSequence.cpp
-2004-07-08 19:34 Sandro Santilli <strk at keybit.net>
- * [r452] Mirrored JTS interface of CoordinateSequence, factory and
- default implementations.
- Added DefaultCoordinateSequenceFactory::instance() function.
-2004-07-07 18:54 Sandro Santilli <strk at keybit.net>
- * [r451] updated
-2004-07-07 10:29 Sandro Santilli <strk at keybit.net>
- * [r450] Adjusted exceptions documentation.
-2004-07-07 09:38 Sandro Santilli <strk at keybit.net>
- * [r449] Dropped WKTWriter::stringOfChars (implemented by
- std::string).
- Dropped WKTWriter default constructor (internally created
- GeometryFactory).
- Updated XMLTester to respect the changes.
- Main documentation page made nicer.
-2004-07-07 07:52 Sandro Santilli <strk at keybit.net>
- * [r448] Removed note about required speedup in BufferSubgraph.
- I've made tests with 'sets' and there is actually a big slow
- down..
-2004-07-06 17:58 Sandro Santilli <strk at keybit.net>
- * [r447] Removed deprecated Geometry constructors based on
- PrecisionModel and
- SRID specification. Removed SimpleGeometryPrecisionReducer
- capability
- of changing Geometry's factory. Reverted Geometry::factory member
- to be a reference to external factory.
-2004-07-05 19:40 Sandro Santilli <strk at keybit.net>
- * [r446] Added GeometryFactory::destroyGeometry(Geometry *)
-2004-07-05 15:20 Sandro Santilli <strk at keybit.net>
- * [r445] Documentation again.
-2004-07-05 14:23 Sandro Santilli <strk at keybit.net>
- * [r444] More documentation cleanups.
-2004-07-05 11:50 Sandro Santilli <strk at keybit.net>
- * [r443] initial import
-2004-07-05 10:50 Sandro Santilli <strk at keybit.net>
- * [r442] deep-dopy construction taken out of Geometry and
- implemented only
- in GeometryFactory.
- Deep-copy geometry construction takes care of cleaning up copies
- on exception.
- Implemented clone() method for CoordinateList
- Changed createMultiPoint(CoordinateList) signature to reflect
- copy semantic (by-ref instead of by-pointer).
- Cleaned up documentation.
-2004-07-03 12:54 Sandro Santilli <strk at keybit.net>
- * [r441] more entries
-2004-07-03 12:51 Sandro Santilli <strk at keybit.net>
- * [r440] Documentation cleanups for DoxyGen.
-2004-07-02 17:22 Sandro Santilli <strk at keybit.net>
- * [r439] Doxygen configuration file renamed.
-2004-07-02 14:27 Sandro Santilli <strk at keybit.net>
- * [r438] Added deep-copy / take-ownerhship for Point type.
-2004-07-02 13:28 Sandro Santilli <strk at keybit.net>
- * [r437] Fixed all #include lines to reflect headers layout change.
- Added client application build tips in README.
-2004-07-02 13:21 Sandro Santilli <strk at keybit.net>
- * [r436] renamed to geos/version.h.in
-2004-07-02 13:20 Sandro Santilli <strk at keybit.net>
- * [r435] Header files moved under geos/ dir.
-2004-07-01 17:34 Sandro Santilli <strk at keybit.net>
- * [r434] GeometryFactory argument in Geometry constructor reverted
- to its copy-and-destroy semantic.
-2004-07-01 17:07 Sandro Santilli <strk at keybit.net>
- * [r433] Added doxygen_docs generation rule
-2004-07-01 16:49 Sandro Santilli <strk at keybit.net>
- * [r432] re-generated with doxygen 1.2.15
-2004-07-01 15:47 No Body <no at body.net>
- * [r431] Added doxygen file for better doco generation.
-2004-07-01 14:12 Sandro Santilli <strk at keybit.net>
- * [r430] Geometry constructors come now in two flavors:
- - deep-copy args (pass-by-reference)
- - take-ownership of args (pass-by-pointer)
- Same functionality is available through GeometryFactory,
- including buildGeometry().
-2004-06-30 20:59 Sandro Santilli <strk at keybit.net>
- * [r429] Removed GeoemtryFactory copy from geometry constructors.
- Enforced const-correctness on GeometryFactory arguments.
-2004-06-28 21:58 Sandro Santilli <strk at keybit.net>
- * [r428] Constructors speedup.
-2004-06-28 21:11 Sandro Santilli <strk at keybit.net>
- * [r427] Moved getGeometryTypeId() definitions from geom.h to each
- geometry module.
- Added holes argument check in Polygon.cpp.
-2004-06-25 14:26 Sandro Santilli <strk at keybit.net>
- * [r426] fixed --includes
-2004-06-22 16:57 Sandro Santilli <strk at keybit.net>
- * [r425] Written down some news
-2004-06-22 16:56 Sandro Santilli <strk at keybit.net>
- * [r424] Added geos.h file.
-2004-06-21 22:14 Sandro Santilli <strk at keybit.net>
- * [r423] added geos_version.h
-2004-06-21 22:13 Sandro Santilli <strk at keybit.net>
- * [r422] updated
- * [r421] Added VERSION defines
-2004-06-16 13:13 Sandro Santilli <strk at keybit.net>
- * [r420] Changed interface of SegmentString, now copying
- CoordinateList argument.
- Fixed memory leaks associated with this and MultiGeometry
- constructors.
- Other associated fixes.
-2004-06-15 21:35 Sandro Santilli <strk at keybit.net>
- * [r419] fixed buildGeometry to always return a newly allocated
- geometry
-2004-06-15 20:42 Sandro Santilli <strk at keybit.net>
- * [r418] updated to respect deep-copy GeometryCollection interface
-2004-06-15 20:30 Sandro Santilli <strk at keybit.net>
- * [r417] fixed a typo
-2004-06-15 20:20 Sandro Santilli <strk at keybit.net>
- * [r416] updated to respect deep-copy GeometryCollection interface
-2004-06-15 20:07 Sandro Santilli <strk at keybit.net>
- * [r415] GeometryCollections constructors make a deep copy of
- Geometry vector argument.
-2004-06-15 20:01 Sandro Santilli <strk at keybit.net>
- * [r414] Empty geometry creation call made using NULL instead of
- newly created empty vector (will be faster)
-2004-06-15 19:24 Sandro Santilli <strk at keybit.net>
- * [r413] Fixed a bug preventing geos-config from giving correct
- version info
-2004-06-15 07:40 Sandro Santilli <strk at keybit.net>
- * [r412] Added missing <stdio.h> include
- * [r411] Updated
-2004-05-28 18:16 Yury Bychkov <me at yury.ca>
- * [r410] Changed rounding method to make compilable with VC++
-2004-05-27 12:09 Sandro Santilli <strk at keybit.net>
- * [r409] added one buffer test
-2004-05-27 10:27 Sandro Santilli <strk at keybit.net>
- * [r408] Memory leaks fixed.
-2004-05-27 10:26 Sandro Santilli <strk at keybit.net>
- * [r407] set (useless?) recordIsolated member in constructor
-2004-05-27 09:53 Sandro Santilli <strk at keybit.net>
- * [r406] MonotoneChainOverlapAction::overlap(*) funx made virtual
- as they are supposed to be.
-2004-05-27 08:40 Sandro Santilli <strk at keybit.net>
- * [r405] Fixed a memleak in buffer test.
-2004-05-27 08:37 Sandro Santilli <strk at keybit.net>
- * [r404] Fixed a bug preventing OffsetCurveBuilder point list from
- being reset.
-2004-05-26 19:48 Sandro Santilli <strk at keybit.net>
- * [r403] Changed abs() to fabs() when working with doubles.
- Used dynamic_cast<> instead of typeid() when JTS uses instanceof.
-2004-05-26 13:12 Sandro Santilli <strk at keybit.net>
- * [r402] Removed try/catch block from ::buildSubgraphs
-2004-05-26 09:50 Sandro Santilli <strk at keybit.net>
- * [r401] Added comments about OverlayNodeFactory() ownership in
- NodeMap and PlanarGraph constuctors
-2004-05-26 09:49 Sandro Santilli <strk at keybit.net>
- * [r400] PlanarGraph made local to ::buffer instead of Class
- private.
-2004-05-21 14:17 Sandro Santilli <strk at keybit.net>
- * [r399] updated
-2004-05-21 13:58 Sandro Santilli <strk at keybit.net>
- * [r398] ::intersection missed to invalidate geometryCollection
- inputs
-2004-05-21 13:55 Sandro Santilli <strk at keybit.net>
- * [r397] updated
-2004-05-21 13:39 Sandro Santilli <strk at keybit.net>
- * [r396] ::makePrecise make use of nearbyint() now, to be
- compatible with JTS
-2004-05-21 13:37 Sandro Santilli <strk at keybit.net>
- * [r395] first import
-2004-05-20 09:14 Sandro Santilli <strk at keybit.net>
- * [r394] updated
-2004-05-19 19:39 Yury Bychkov <me at yury.ca>
- * [r393] Changed rounding method to make compilable with VC++
-2004-05-19 13:40 Sandro Santilli <strk at keybit.net>
- * [r392] Fixed bug in ::addCircle
-2004-05-19 13:18 Sandro Santilli <strk at keybit.net>
- * [r391] made CoordinateList::toString() a const member function
-2004-05-19 13:01 Sandro Santilli <strk at keybit.net>
- * [r390] avoided assignment operator calls for BufferBuilder
-2004-05-19 12:50 Sandro Santilli <strk at keybit.net>
- * [r389] Removed all try/catch blocks transforming stack
- allocated-vectors to auto-heap-allocations
-2004-05-19 09:57 Yury Bychkov <me at yury.ca>
- * [r388] Bugfix in OffsetCurveSetBuilder::addPolygon (JTS 1.4.1)
-2004-05-18 13:49 Sandro Santilli <strk at keybit.net>
- * [r387] Output made more neat (geometry B is not printed if not
- existent).
- Added support for buffer tests.
-2004-05-18 13:15 Sandro Santilli <strk at keybit.net>
- * [r386] made ::scroll handle already scrolled vect and more
- readable
-2004-05-18 00:02 Yury Bychkov <me at yury.ca>
- * [r385] IsValidOp::checkShellNotNested() bugfix from JTS 1.4.1
- (not released yet) has been added.
-2004-05-17 21:14 Yury Bychkov <me at yury.ca>
- * [r384] JavaDoc updated
-2004-05-17 21:09 Yury Bychkov <me at yury.ca>
- * [r383] toString() performance enhancement
-2004-05-17 21:03 Yury Bychkov <me at yury.ca>
- * [r382] JavaDoc updated
-2004-05-17 12:54 Sandro Santilli <strk at keybit.net>
- * [r381] Added tab in list of blank chars
-2004-05-17 12:53 Sandro Santilli <strk at keybit.net>
- * [r380] Expected result string trimmed for blanks
-2004-05-17 12:37 Sandro Santilli <strk at keybit.net>
- * [r379] Added carriage returns and tabs in set of blanks chars
-2004-05-17 12:36 Sandro Santilli <strk at keybit.net>
- * [r378] ParseException message made more readable
-2004-05-17 10:45 Sandro Santilli <strk at keybit.net>
- * [r377] Fixed bogus FIXED coordinate rounding
-2004-05-17 08:34 Sandro Santilli <strk at keybit.net>
- * [r376] reduced stack allocations, try/catch blocks in ::overlayOp
-2004-05-17 07:42 Sandro Santilli <strk at keybit.net>
- * [r375] CentroidArea::add(const Geometry *geom) uses dynamic_cast
-2004-05-17 07:23 Sandro Santilli <strk at keybit.net>
- * [r374] ::getCeontroid(): reduced dynamic allocations, added
- missing check for isEmpty
-2004-05-14 14:47 Sandro Santilli <strk at keybit.net>
- * [r373] Added LinearRing support
-2004-05-14 14:45 Sandro Santilli <strk at keybit.net>
- * [r372] Fixed bogus inheritance of LinearComponentExtracter
-2004-05-14 13:42 Sandro Santilli <strk at keybit.net>
- * [r371] DistanceOp bug removed, cascading errors fixed.
-2004-05-14 12:14 Sandro Santilli <strk at keybit.net>
- * [r370] const correctness
-2004-05-14 12:10 Sandro Santilli <strk at keybit.net>
- * [r369] avoided leaks on malformed LinearRing
-2004-05-14 09:20 Sandro Santilli <strk at keybit.net>
- * [r368] Mem leaks fixed
-2004-05-14 07:19 Sandro Santilli <strk at keybit.net>
- * [r367] Changed the algorythm for finding precisionModel type
- (current way did
- not work): now if you specify a scale precisionModel will be
- FIXED,
- otherwise it will be FLOATING.
-2004-05-07 14:15 Sandro Santilli <strk at keybit.net>
- * [r366] fixed peekNextToken to avoid incrementing string pointer
-2004-05-07 14:13 Sandro Santilli <strk at keybit.net>
- * [r365] Fixed segfault in ::insert
-2004-05-07 14:12 Sandro Santilli <strk at keybit.net>
- * [r364] Fixed segfault in destructor
-2004-05-07 13:23 Sandro Santilli <strk at keybit.net>
- * [r363] Memory leaks fixed.
-2004-05-07 13:04 Sandro Santilli <strk at keybit.net>
- * [r362] leak removed in MultiLineString::getBoundary()
-2004-05-07 09:05 Sandro Santilli <strk at keybit.net>
- * [r361] Some const correctness added. Fixed bug in
- GeometryFactory::createMultiPoint
- to handle NULL CoordinateList.
-2004-05-07 07:57 Sandro Santilli <strk at keybit.net>
- * [r360] Added missing EdgeNodingValidator to build scripts.
- Changed SegmentString constructor back to its original form
- (takes const void *), implemented local tracking of "contexts"
- in caller objects for proper destruction.
-2004-05-06 16:30 Sandro Santilli <strk at keybit.net>
- * [r359] Kept track of newly allocated objects by ensureExtent for
- Bintree and Quadtree,
- deleted at destruction time. doc/example.cpp runs with no leaks.
-2004-05-06 15:54 Sandro Santilli <strk at keybit.net>
- * [r358] SegmentNodeList keeps track of created splitEdges for
- later destruction.
- SegmentString constructor copies given Label.
- Buffer operation does no more leaks for doc/example.cpp
-2004-05-06 15:00 Sandro Santilli <strk at keybit.net>
- * [r357] Boundable destructor made virtual.
- Added vector <AbstractNode *> *nodes member in AbstractSTRTree,
- used to keep track of created node to cleanly delete them at
- destruction time.
-2004-05-06 13:58 Sandro Santilli <strk at keybit.net>
- * [r356] leak removed from createParentBoundablesFromVerticalSlices
-2004-05-06 08:59 Sandro Santilli <strk at keybit.net>
- * [r355] memory leak fixed
-2004-05-05 17:42 Sandro Santilli <strk at keybit.net>
- * [r354] AbstractNode destructor made virtual. AbstractNode::bounds
- made protected.
- SIRAbstractNode and STRAbstractNode destructors added to get rid
- of
- AbstractNode::bounds in the right way (is a void * casted to
- appropriate
- Class in the subClasses).
-2004-05-05 16:57 Sandro Santilli <strk at keybit.net>
- * [r353] Rewritten static cga allocation to avoid copy constructor
- calls.
-2004-05-05 16:51 Sandro Santilli <strk at keybit.net>
- * [r352] avoided copy constructor in
- Geometry::geometryChangedFilter initializzazion
-2004-05-05 16:39 Sandro Santilli <strk at keybit.net>
- * [r351] reduced explicit local objects allocation
-2004-05-05 16:36 Sandro Santilli <strk at keybit.net>
- * [r350] Avoid use of copy c'tors on local objects initializzation
-2004-05-05 15:51 Sandro Santilli <strk at keybit.net>
- * [r349] Fixed big leak in intersectChains()
-2004-05-05 13:08 Sandro Santilli <strk at keybit.net>
- * [r348] Leaks fixed, explicit allocations/deallocations reduced.
-2004-05-05 12:29 Sandro Santilli <strk at keybit.net>
- * [r347] memleak fixed in ::getDepth
-2004-05-05 12:20 Sandro Santilli <strk at keybit.net>
- * [r346] Memory leak plugged in editGeometryCollection
-2004-05-05 10:54 Sandro Santilli <strk at keybit.net>
- * [r345] Removed some private static heap explicit allocation, less
- cleanup done by
- the unloader.
-2004-05-05 10:44 Sandro Santilli <strk at keybit.net>
- * [r344] updated
-2004-05-05 10:22 Sandro Santilli <strk at keybit.net>
- * [r343] Removed dynamic allocations.
-2004-05-05 10:03 Sandro Santilli <strk at keybit.net>
- * [r342] Reduced dynamic allocations in bufferOriginalPrecision and
- bufferFixedPrecision.
-2004-05-03 22:56 Sandro Santilli <strk at keybit.net>
- * [r341] leaks fixed, exception specification omitted.
-2004-05-03 20:49 Sandro Santilli <strk at keybit.net>
- * [r340] Some more leaks fixed
-2004-05-03 17:15 Sandro Santilli <strk at keybit.net>
- * [r339] leaks on exception fixed.
-2004-05-03 16:29 Sandro Santilli <strk at keybit.net>
- * [r338] Added sortBoundables(const vector<Boundable *>) pure
- virtual in AbstractSTRtree,
- implemented in SIRtree and STRtree. Comparator funx made static
- in STRtree.cpp
- and SIRtree.cpp.
-2004-05-03 13:17 Sandro Santilli <strk at keybit.net>
- * [r337] Fixed comparator function to express StrictWeakOrdering.
-2004-05-03 12:09 Sandro Santilli <strk at keybit.net>
- * [r336] newline added at end of file
-2004-05-03 10:43 Sandro Santilli <strk at keybit.net>
- * [r335] Exception specification considered harmful - left as
- comment.
-2004-04-30 09:15 Sandro Santilli <strk at keybit.net>
- * [r334] Enlarged exception specifications to allow for
- AssertionFailedException.
- Added missing initializers.
-2004-04-28 14:58 Sandro Santilli <strk at keybit.net>
- * [r333] Made AbstractSTRtree::query use dynamic_cast<> to simulate
- java's
- instanceof. Previous typeid(*) use missed to catch an
- STRAbstractNode
- as a class derived from AbstractNode. Still have to check if this
- is the correct semantic with Martin, but at least lots of
- SIGABORT
- are no more raised.
-2004-04-26 22:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r332] Bump version number to 1.4 to indicate new changes.
-2004-04-26 12:37 Sandro Santilli <strk at keybit.net>
- * [r331] Some leaks fixed.
-2004-04-23 00:02 Sandro Santilli <strk at keybit.net>
- * [r330] const-correctness changes
-2004-04-21 14:14 Sandro Santilli <strk at keybit.net>
- * [r329] Fixed bug in computeDepths
-2004-04-20 13:24 Sandro Santilli <strk at keybit.net>
- * [r328] More leaks removed.
-2004-04-20 12:47 Sandro Santilli <strk at keybit.net>
- * [r327] MinimumDiameter leaks plugged.
-2004-04-20 10:58 Sandro Santilli <strk at keybit.net>
- * [r326] More memory leaks removed.
-2004-04-20 10:14 Sandro Santilli <strk at keybit.net>
- * [r325] Memory leaks removed.
-2004-04-20 08:52 Sandro Santilli <strk at keybit.net>
- * [r324] GeometryFactory and Geometry const correctness.
- Memory leaks removed from SimpleGeometryPrecisionReducer
- and GeometryFactory.
-2004-04-19 16:14 Sandro Santilli <strk at keybit.net>
- * [r323] Some memory leaks plugged in noding algorithms.
-2004-04-19 15:14 Sandro Santilli <strk at keybit.net>
- * [r322] Added missing virtual destructor in SpatialIndex class.
- Memory leaks fixes. Const and throw specifications added.
-2004-04-19 12:51 Sandro Santilli <strk at keybit.net>
- * [r321] Memory leaks fixes. Throw specifications added.
-2004-04-16 14:12 Sandro Santilli <strk at keybit.net>
- * [r320] Memory leak fix in copy constructor
-2004-04-16 14:09 Sandro Santilli <strk at keybit.net>
- * [r319] Leaks fixes
-2004-04-16 13:03 Sandro Santilli <strk at keybit.net>
- * [r318] More leaks fixed
-2004-04-16 12:48 Sandro Santilli <strk at keybit.net>
- * [r317] Leak fixes.
-2004-04-16 11:04 Sandro Santilli <strk at keybit.net>
- * [r316] Memory leaks plugged on exception thrown
-2004-04-16 10:00 Sandro Santilli <strk at keybit.net>
- * [r315] Memory leak fixed.
-2004-04-16 09:01 Sandro Santilli <strk at keybit.net>
- * [r314] Removed memory leak in CGAlgorithms::isOnline
-2004-04-16 08:52 Sandro Santilli <strk at keybit.net>
- * [r313] Unload::Release final delete (static heap allocations
- should be gone now)
-2004-04-16 08:35 Sandro Santilli <strk at keybit.net>
- * [r312] Memory leaks fixed and const correctness applied for Point
- class.
-2004-04-16 07:42 Sandro Santilli <strk at keybit.net>
- * [r311] PrecisionModel::Type made an enum instead of a Type.
-2004-04-15 15:11 Sandro Santilli <strk at keybit.net>
- * [r310] Commented out deletion that seems to cause segfaults
-2004-04-15 14:00 Sandro Santilli <strk at keybit.net>
- * [r309] Added new cleanup to Unload::Release
-2004-04-14 13:56 Sandro Santilli <strk at keybit.net>
- * [r308] All geometries returned by {from,to}InternalGeometry calls
- are
- now deleted after use (unless NOT new).
- Some 'commented' throw specifications in geom.h
-2004-04-14 13:14 Sandro Santilli <strk at keybit.net>
- * [r307] Removed deletion of externally pointed GeometryFactory
- from OverlayOp destructor
-2004-04-14 12:28 Sandro Santilli <strk at keybit.net>
- * [r306] shouldNeverReachHere exceptions made more verbose
-2004-04-14 11:05 Sandro Santilli <strk at keybit.net>
- * [r305] Added support for LinearRing in GeometryEditor
-2004-04-14 10:56 Sandro Santilli <strk at keybit.net>
- * [r304] Uncommented initializzazion and destruction of
- DistanceOp::minDistanceLocation
-2004-04-14 09:38 Sandro Santilli <strk at keybit.net>
- * [r303] PrecisionModel(double newScale) missed to set the scale
-2004-04-14 09:30 Sandro Santilli <strk at keybit.net>
- * [r302] Private iterated noding funx now use int* instead of
- vector to know
- when it's time to stop.
-2004-04-14 09:11 Sandro Santilli <strk at keybit.net>
- * [r301] endCapStyle was never set in BufferOp contructor
-2004-04-14 08:38 Sandro Santilli <strk at keybit.net>
- * [r300] BufferBuilder constructor missed to initialize
- workingPrecisionModel
- * [r299] BufferOp constructor missed to set argGeom
-2004-04-14 07:29 Sandro Santilli <strk at keybit.net>
- * [r298] Fixed GeometryFactory constructors to copy given
- PrecisionModel. Added GeometryFactory copy constructor. Fixed
- Geometry constructors to copy GeometryFactory.
-2004-04-14 06:04 Yury Bychkov <me at yury.ca>
- * [r297] "geomgraph/index" committ problem fixed.
-2004-04-13 14:45 Sandro Santilli <strk at keybit.net>
- * [r296] Removed faulty assert in constructor
-2004-04-13 14:33 Sandro Santilli <strk at keybit.net>
- * [r295] Added more source files
-2004-04-13 14:28 Sandro Santilli <strk at keybit.net>
- * [r294] Removed spurious line
-2004-04-13 13:31 Sandro Santilli <strk at keybit.net>
- * [r293] prototype mismatch fixed
-2004-04-13 12:29 Sandro Santilli <strk at keybit.net>
- * [r292] GeometryLocation const-correctness.
-2004-04-13 11:04 Sandro Santilli <strk at keybit.net>
- * [r291] Added lost opDistance.h
-2004-04-13 11:03 Sandro Santilli <strk at keybit.net>
- * [r290] Added new header files
-2004-04-13 10:58 Sandro Santilli <strk at keybit.net>
- * [r289] Added new source files
-2004-04-13 10:05 Sandro Santilli <strk at keybit.net>
- * [r288] GeometryLocation constructor made const-correct.
- Fixed erroneus down-casting in
- DistanceOp::computeMinDistancePoints.
-2004-04-13 08:15 Sandro Santilli <strk at keybit.net>
- * [r287] Changed all 'long long' with int64.
- Changed all 'long long' constants to end with two Ls.
-2004-04-10 22:41 Yury Bychkov <me at yury.ca>
- * [r286] "precision" upgraded to JTS 1.4
-2004-04-10 08:40 Yury Bychkov <me at yury.ca>
- * [r285] "operation/buffer" upgraded to JTS 1.4
-2004-04-08 04:53 Yury Bychkov <me at yury.ca>
- * [r284] "operation/polygonize" ported from JTS 1.4
-2004-04-07 06:55 Yury Bychkov <me at yury.ca>
- * [r283] "operation/linemerge" ported from JTS 1.4
-2004-04-05 06:35 Yury Bychkov <me at yury.ca>
- * [r282] "operation/distance" upgraded to JTS 1.4
-2004-04-04 06:29 Yury Bychkov <me at yury.ca>
- * [r281] "planargraph" and "geom/utill" upgraded to JTS 1.4
-2004-04-01 10:44 Yury Bychkov <me at yury.ca>
- * [r280] All "geom" classes from JTS 1.3 upgraded to JTS 1.4
-2004-03-31 07:50 Yury Bychkov <me at yury.ca>
- * [r279] "geom" partially upgraded to JTS 1.4
-2004-03-29 06:59 Yury Bychkov <me at yury.ca>
- * [r278] "noding/snapround" package ported (JTS 1.4);
- "operation", "operation/valid", "operation/relate" and
- "operation/overlay" upgraded to JTS 1.4;
- "geom" partially upgraded.
-2004-03-26 07:48 Yury Bychkov <me at yury.ca>
- * [r277] "noding" package ported (JTS 1.4)
-2004-03-25 02:23 Yury Bychkov <me at yury.ca>
- * [r276] All "index/*" packages upgraded to JTS 1.4
-2004-03-19 09:49 Yury Bychkov <me at yury.ca>
- * [r275] "geomgraph" and "geomgraph/indexl" upgraded to JTS 1.4
-2004-03-18 10:42 Yury Bychkov <me at yury.ca>
- * [r274] "IO" and "Util" upgraded to JTS 1.4
- "Geometry" partially upgraded.
-2004-03-17 02:00 Yury Bychkov <me at yury.ca>
- * [r273] "Algorithm" upgraded to JTS 1.4
-2004-03-01 22:04 Sandro Santilli <strk at keybit.net>
- * [r272] applied const correctness changes by Manuel Prieto
- Villegas <ManuelPrietoVillegas at telefonica.net>
-2004-02-27 17:43 Sandro Santilli <strk at keybit.net>
- * [r271] memory leak fix in Polygon::getArea() - reported by
- 'Manuel Prieto Villegas' <mprieto at dap.es>
-2004-02-27 17:42 Sandro Santilli <strk at keybit.net>
- * [r270] made CGAlgorithms::signedArea() and CGAlgorithms::length()
- arguments const-correct
-2004-02-20 05:44 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r269] Changed to new version of ltmain, that matches the version
- of libtool
- on build box
-2004-01-20 05:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r268] Change platform.h back to AM_CONFIG_HEADER.
-2004-01-20 05:10 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r267] Change AM_CONFIG_HEADER to AC_CONFIG_HEADERS to allow
- autoheader to work
- its magic.
-2003-12-11 17:01 Sandro Santilli <strk at keybit.net>
- * [r266] made buffer(0) back to its *correct* semantic (empy
- collection)
-2003-12-11 16:01 Sandro Santilli <strk at keybit.net>
- * [r265] made buffer operation return a cloned input geom when
- called with 0 as distance
-2003-12-11 15:53 Sandro Santilli <strk at keybit.net>
- * [r264] Fixed bogus copy constructor (making clone bogus)
-2003-11-13 11:57 Sandro Santilli <strk at keybit.net>
- * [r263] bug fixed in relate call
-2003-11-12 22:03 Sandro Santilli <strk at keybit.net>
- * [r262] added relational operators
-2003-11-12 18:02 Sandro Santilli <strk at keybit.net>
- * [r261] Added throw specification. Fixed leaks on exceptions.
-2003-11-12 17:15 Sandro Santilli <strk at keybit.net>
- * [r260] made sure PrecisionModel scale is never 0
-2003-11-12 17:10 Sandro Santilli <strk at keybit.net>
- * [r259] added missing initialization
-2003-11-12 16:14 Sandro Santilli <strk at keybit.net>
- * [r258] Added some more throw specifications and cleanup on
- exception (leaks removed).
-2003-11-12 15:43 Sandro Santilli <strk at keybit.net>
- * [r257] Added some more throw specifications
-2003-11-12 15:02 Sandro Santilli <strk at keybit.net>
- * [r256] more cleanup on exception
-2003-11-12 11:08 Sandro Santilli <strk at keybit.net>
- * [r255] removed old changelog, moved comments in the nice standard
- frame
-2003-11-12 11:05 Sandro Santilli <strk at keybit.net>
- * [r254] added autoheader call
-2003-11-07 17:51 Sandro Santilli <strk at keybit.net>
- * [r253] Memory leak fix in insertEdge()
-2003-11-07 17:49 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r252] Added current ChangeLog
-2003-11-07 17:45 Sandro Santilli <strk at keybit.net>
- * [r251] will be generated with ./autogen.sh
-2003-11-07 14:21 Sandro Santilli <strk at keybit.net>
- * [r250] Made doc/ directory part of distribution. Uniformed doc
- build script to
- autotools.
-2003-11-07 14:19 Sandro Santilli <strk at keybit.net>
- * [r249] added config.h.in (missed before)
-2003-11-07 14:18 Sandro Santilli <strk at keybit.net>
- * [r248] added config.h.in
-2003-11-07 01:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r247] Added people!
-2003-11-07 01:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r245] Add standard CVS headers licence notices and copyrights to
- all cpp and h
- files.
-2003-11-06 19:04 Sandro Santilli <strk at keybit.net>
- * [r244] removed useless Coordinate copy in ::createSplitEdge()
-2003-11-06 18:50 Sandro Santilli <strk at keybit.net>
- * [r243] first import
-2003-11-06 18:48 Sandro Santilli <strk at keybit.net>
- * [r242] updated
- * [r241] added throw information comment in PolygonBuilder
-2003-11-06 18:47 Sandro Santilli <strk at keybit.net>
- * [r240] Added throw specification for BufferOp's
- ::buildSubgraphs() and ::computeBuffer(). Cleanup on exception in
- computeBuffer().
-2003-11-06 18:46 Sandro Santilli <strk at keybit.net>
- * [r239] Added throw specification for BufferOp's
-2003-11-06 18:45 Sandro Santilli <strk at keybit.net>
- * [r238] Added throw specification for
- DirectEdgeStar::linkResultDirectedEdges()
-2003-11-06 18:00 Sandro Santilli <strk at keybit.net>
- * [r237] Cleanup on exception in ::bufferOp()
-2003-11-06 17:59 Sandro Santilli <strk at keybit.net>
- * [r236] Memory leaks fixed in ::containsPoint()
-2003-11-06 17:48 Sandro Santilli <strk at keybit.net>
- * [r235] Fixed memory leaks in ::closePt() and ::addLineEndCap()
-2003-11-06 17:47 Sandro Santilli <strk at keybit.net>
- * [r234] Added support for LinearRing, removed memory leaks in
- ::addLineString
-2003-11-06 17:41 Sandro Santilli <strk at keybit.net>
- * [r233] Added Buffer,Intersection,Difference and Symdifference.
- Exception cleanup
-2003-11-06 17:33 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r232] Small addition of into about LD_LIBRARY_PATH
-2003-11-05 21:52 Sandro Santilli <strk at keybit.net>
- * [r231] Modified example.cpp to make use of vectors instead of
- Geometry * / int
- couples. Added LineString creation example. Added Makefile to
- compile it.
-2003-11-03 16:09 Sandro Santilli <strk at keybit.net>
- * [r230] Removed comments about segfaults, made the simple
- collection creation call
- cleaner by use of the clone() method.
-2003-10-31 16:36 Sandro Santilli <strk at keybit.net>
- * [r229] Re-introduced clone() method. Copy constructor could not
- really replace it.
-2003-10-29 10:38 Sandro Santilli <strk at keybit.net>
- * [r228] Added centroid computation example
- * [r227] Added support for LinearRing types (treated as LineString)
-2003-10-24 21:27 Sandro Santilli <strk at keybit.net>
- * [r226] Added GeometryTypeId enum and getGeometryTypeId abstract
- Geometry method.
-2003-10-23 09:17 Sandro Santilli <strk at keybit.net>
- * [r225] Added stamp-h2 and platform.h
-2003-10-23 09:12 Sandro Santilli <strk at keybit.net>
- * [r224] Made CoordinateArrayFilter destructor virtual.
-2003-10-22 23:58 Sandro Santilli <strk at keybit.net>
- * [r223] Made platform.h be created by configure. In this way we
- will not have
- problems of installed headers trying to include phantom config.h.
-2003-10-22 00:44 Sandro Santilli <strk at keybit.net>
- * [r222] Quadtree bitfield operations made using type int64. Type
- int64 typedef'ed based
- on autoconf detected int type (long or long long). If long is not
- 64bits int64
- will be really 32 bits and INT64_IS_REALLY32 will be defined.
-2003-10-21 23:51 Sandro Santilli <strk at keybit.net>
- * [r221] Added macros to find 64bit integer.
-2003-10-21 16:16 Sandro Santilli <strk at keybit.net>
- * [r220] Uncommented point creation lines. Updated comments about
- segfaults.
-2003-10-21 05:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r219] Added test.xml so it gets picked up by 'make dist'
-2003-10-21 05:09 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r218] Added simple installation directions.
-2003-10-21 04:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r217] Fix up references to header files to 'make dist' works.
-2003-10-20 17:50 Sandro Santilli <strk at keybit.net>
- * [r216] added Union example
-2003-10-20 15:41 Sandro Santilli <strk at keybit.net>
- * [r215] Geometry::checkNotGeometryCollection made static and
- non-distructive.
-2003-10-20 14:02 Sandro Santilli <strk at keybit.net>
- * [r214] more explicit exception thrown on null Directed Edge
- detection
-2003-10-20 13:56 Sandro Santilli <strk at keybit.net>
- * [r213] fixed typo
-2003-10-20 13:53 Sandro Santilli <strk at keybit.net>
- * [r212] LinearRing handled as a LineString in
- GeometryGraph::add(const Geometry *) - more explicit exception
- thrown for unknown geometries
-2003-10-17 05:51 Yury Bychkov <me at yury.ca>
- * [r211] Fixed a small memory leak.
-2003-10-16 17:41 Sandro Santilli <strk at keybit.net>
- * [r210] Fixed a bug in GEOSException that prevented print of the
- type of exception thrown.
-2003-10-16 17:33 Sandro Santilli <strk at keybit.net>
- * [r209] dropped useless string() cast
-2003-10-16 17:05 Sandro Santilli <strk at keybit.net>
- * [r208] Made TopologyException inherit from GEOSException.
- Adjusted IllegalArgumentException subclassing.
-2003-10-16 13:01 Sandro Santilli <strk at keybit.net>
- * [r207] Added call to Unload::Release()
-2003-10-16 12:09 Sandro Santilli <strk at keybit.net>
- * [r206] bug fixed in exception handling
-2003-10-16 08:50 Sandro Santilli <strk at keybit.net>
- * [r205] Memory leak fixes. Improved performance by mean of more
- calls to new getCoordinatesRO() when applicable.
-2003-10-16 08:48 Sandro Santilli <strk at keybit.net>
- * [r204] Exceptions handled
-2003-10-15 16:39 Sandro Santilli <strk at keybit.net>
- * [r203] Made Edge::getCoordinates() return a 'const' value.
- Adapted code set.
-2003-10-15 15:47 Sandro Santilli <strk at keybit.net>
- * [r202] Adapted to new getCoordinatesRO() interface
-2003-10-15 15:30 Sandro Santilli <strk at keybit.net>
- * [r201] Declared a SweepLineEventOBJ from which MonotoneChain and
- SweepLineSegment
- derive to abstract SweepLineEvent object previously done on void
- * pointers.
- No more compiler warnings...
-2003-10-15 11:24 Sandro Santilli <strk at keybit.net>
- * [r200] Use getCoordinatesRO() introduced.
-2003-10-15 11:23 Sandro Santilli <strk at keybit.net>
- * [r199] Formalized const nature of toVector() method and of first
- argument to static removeRepeatedPoints().
-2003-10-15 10:17 Sandro Santilli <strk at keybit.net>
- * [r198] Made setPoints() get a const vector<Coordinate>.
-2003-10-15 09:54 Sandro Santilli <strk at keybit.net>
- * [r197] Added getCoordinatesRO() public method.
-2003-10-15 08:52 Sandro Santilli <strk at keybit.net>
- * [r196] Memory leaks fixed.
-2003-10-15 08:51 Sandro Santilli <strk at keybit.net>
- * [r195] Initial import
-2003-10-15 08:08 Sandro Santilli <strk at keybit.net>
- * [r194] Memory leaks fixed. Partially due to getCoordinates() and
- GeometryCollection()
- changes, partially old dated.
-2003-10-14 15:58 Sandro Santilli <strk at keybit.net>
- * [r193] Useless vector<Geometry *> leaking allocations removed
-2003-10-13 21:26 Sandro Santilli <strk at keybit.net>
- * [r192] Added build time created files to cvsignore lists
-2003-10-13 17:54 Sandro Santilli <strk at keybit.net>
- * [r191] IsValidOp constructor used same name for the arg and a
- private element. Fixed.
-2003-10-13 17:47 Sandro Santilli <strk at keybit.net>
- * [r190] delete statement removed
-2003-10-13 15:39 Sandro Santilli <strk at keybit.net>
- * [r189] Fixed some leak or fault flips (forced copy of a single
- coordinate)
-2003-10-13 15:02 Sandro Santilli <strk at keybit.net>
- * [r188] accept input file as first argument on cmdline
-2003-10-13 12:51 Sandro Santilli <strk at keybit.net>
- * [r187] removed sortedClasses strings array from all geometries.
-2003-10-13 09:24 Sandro Santilli <strk at keybit.net>
- * [r186] long -> long long enlargement of types to allow for
- left/rigth shift of 53 bits
-2003-10-11 03:23 Sandro Santilli <strk at keybit.net>
- * [r185] fixed spurious typos
-2003-10-11 01:56 Sandro Santilli <strk at keybit.net>
- * [r184] Code base padded with 'const' keywords ;)
-2003-10-09 15:35 Sandro Santilli <strk at keybit.net>
- * [r183] added 'const' keyword to GeometryFactory constructor, Log
- on top of geom.h
-2003-10-09 11:20 Sandro Santilli <strk at keybit.net>
- * [r182] moved Log to a better place
-2003-10-09 11:19 Sandro Santilli <strk at keybit.net>
- * [r181] added convexHull and PrecisionModel
-2003-10-09 10:14 Sandro Santilli <strk at keybit.net>
- * [r180] just a style change in top Log comment.
-2003-10-09 10:10 Sandro Santilli <strk at keybit.net>
- * [r179] Throw an exception if scale is 0. Added Log entry.
-2003-10-09 09:42 Sandro Santilli <strk at keybit.net>
- * [r178] Tried to "formalize" constant nature of the first argument
- given to constructor by PrecisionModel and SRID specification.
- Added CVS Log on top.
-2003-10-09 08:58 Sandro Santilli <strk at keybit.net>
- * [r177] Added convexHull() call to example, fixed leaks in
- ConvexHull
-2003-10-09 00:11 Sandro Santilli <strk at keybit.net>
- * [r176] First reference-by-example file.
-2003-10-08 16:51 Sandro Santilli <strk at keybit.net>
- * [r175] Added xie's Unload class with some fixes.
-2003-10-08 13:18 Sandro Santilli <strk at keybit.net>
- * [r174] added missing LinearRing writing capabilities.
-2003-10-08 10:36 Sandro Santilli <strk at keybit.net>
- * [r173] Constructor by vector<Geometry *> * now makes a copy of
- the vector so that call
- ers can safely delete it when done.
-2003-10-07 21:47 Sandro Santilli <strk at keybit.net>
- * [r172] had all getCoordinates() callers free returned value.
-2003-10-07 18:58 Sandro Santilli <strk at keybit.net>
- * [r171] LineString constructor now creates its own copy of given
- CoordinateList object, and returns a new copy with
- getCoordinates().
- will be easier to remove by anyone else.
-2003-10-03 01:20 Yury Bychkov <me at yury.ca>
- * [r170] Memory leak in Overlay fixed.
-2003-09-29 16:25 Sandro Santilli <strk at keybit.net>
- * [r169] Some more cvsignore files. Some entries should probably
- not be
- in the local copy
-2003-09-29 15:07 Sandro Santilli <strk at keybit.net>
- * [r168] Added config.sub, config.guess and autom4te.cache
-2003-09-29 13:15 Sandro Santilli <strk at keybit.net>
- * [r167] Don't wonder about Makefile.in, Makefile, gdal-config
-2003-09-26 17:31 Sandro Santilli <strk at keybit.net>
- * [r166] getConvexHull() made check value returned by reduce()
- before deleting
- it (might be the untouched input).
-2003-09-26 09:17 Yury Bychkov <me at yury.ca>
- * [r165] isValid segfault fixed. Overlay still leaks a bit.
-2003-09-24 02:16 Yury Bychkov <me at yury.ca>
- * [r164] All reported bugs fiexd. Small leak in Overlay remains.
-2003-09-06 08:24 Yury Bychkov <me at yury.ca>
- * [r163] isWithinDistance fixed and tested.
-2003-09-06 00:01 Yury Bychkov <me at yury.ca>
- * [r162] getInteriorPoint bugs fixed.
-2003-09-01 06:32 Yury Bychkov <me at yury.ca>
- * [r161] Some ConvexHull bugs fixed.
-2003-08-30 07:55 Yury Bychkov <me at yury.ca>
- * [r160] Some bugfixes. XMLTester expanded to accomodate
- getBoundary, getCentroid, isSimple.
-2003-08-18 23:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r159] Removed java source file from archive.
-2003-08-18 22:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r158] Change it back :/
-2003-08-18 22:33 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r157] Change version number.
-2003-08-18 20:42 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r156] Return ltmain to distro (oops)
-2003-08-18 20:36 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r155] Remove more autoconf files
-2003-08-18 20:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r154] Removed more autoconf files...
-2003-08-18 20:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r153] Removed 'missing' script.
-2003-08-18 16:38 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r152] Fixed up to treat headers as headers.
-2003-08-17 18:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r151] Norman's patch + global removal of "no newline" + small
- changes
- to make Norman's patch work in the linux build environment.
-2003-08-17 18:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r150] Removed more configuration files per Norman's request.
-2003-08-17 17:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r149] Removed more configure files per Norman's request.
-2003-08-17 17:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r148] Removed Makefile.in files, per Norman's request.
-2003-08-16 06:33 Yury Bychkov <me at yury.ca>
- * [r147] Memory leak fixes.
-2003-06-21 22:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r146] GNU compile fixes from nvine.
-2003-06-19 20:54 Yury Bychkov <me at yury.ca>
- * [r145] 'geos' namespace added.
-2003-06-18 20:08 Yury Bychkov <me at yury.ca>
- * [r144] Buffer is almost fully debugged.
-2003-05-29 00:05 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r143] Final GNU build adjustments.
-2003-05-28 23:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r142] Added new exception class.
-2003-05-28 23:39 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r141] Change reference to spatialIndex.h
-2003-05-28 23:22 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r140] Removed obsolete build entries for removed classes.
-2003-05-28 22:22 Yury Bychkov <me at yury.ca>
- * [r139] Some bugfixes.
-2003-05-28 22:11 Yury Bychkov <me at yury.ca>
- * [r138] no message
-2003-05-28 05:02 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r137] Changed __max/__min to max/min
-2003-05-28 05:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r136] Change __max to max
-2003-05-27 23:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r135] Changed from mistaken cpp file names.
-2003-05-27 23:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r134] Added include for <typeinfo>
-2003-05-27 23:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r133] GNU build support
-2003-05-27 23:42 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r132] Fix reference to spatialIndex header
-2003-05-27 23:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r131] Build updates.
-2003-05-27 23:33 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r130] Add new files into build support
-2003-05-27 23:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r129] Add all new headers into the build process.
-2003-05-27 23:11 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r128] Some updates to synch build with devel.
-2003-05-21 23:28 Yury Bychkov <me at yury.ca>
- * [r127] Several bugs fixed.
-2003-05-19 06:18 Yury Bychkov <me at yury.ca>
- * [r126] All exceptions are now classes.
-2003-05-17 07:47 Yury Bychkov <me at yury.ca>
- * [r125] Last fix for CVS.
-2003-05-17 06:08 Yury Bychkov <me at yury.ca>
- * [r124] Fixing CVS error.
-2003-05-17 00:27 Yury Bychkov <me at yury.ca>
- * [r123] Fixing a commit problem.
-2003-05-17 00:07 Yury Bychkov <me at yury.ca>
- * [r122] SIRtree is done. Distance is done.
-2003-05-07 09:06 Yury Bychkov <me at yury.ca>
- * [r121] Closer to 1.3
-2003-05-04 22:34 Yury Bychkov <me at yury.ca>
- * [r120] Closer to JTS 1.3
-2003-04-28 06:01 Yury Bychkov <me at yury.ca>
- * [r119] Partially upgraded to JTS 1.3
-2003-04-21 22:16 Yury Bychkov <me at yury.ca>
- * [r118] VisualStudio project added.
-2003-04-17 00:37 Yury Bychkov <me at yury.ca>
- * [r117] Changed PrecisionModel to Value type. Removed bounds
- checking from *At methods in CoordinateLists.
-2003-04-12 04:31 Yury Bychkov <me at yury.ca>
- * [r116] Overlay passes all tests (both precise and normal)
-2003-04-11 23:16 Yury Bychkov <me at yury.ca>
- * [r115] Overlay almost works. Fails 2 tests.
-2003-04-10 04:34 Yury Bychkov <me at yury.ca>
- * [r114] Overlay passes all normal tests. Still fails on Precision
- tests.
-2003-04-09 21:52 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r113] Changed destructors to virtual to quiet GNU warnings
-2003-04-04 23:49 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r112] Install all headers at install time.
-2003-04-04 22:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r111] Newlines added to quiet gcc.
-2003-04-04 03:44 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r110] Build support
-2003-04-04 03:43 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r109] Build support.
-2003-04-04 03:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r108] Build support updates.
-2003-04-04 03:11 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r107] Build support for new example programs.
-2003-04-04 00:18 David Blasby <dblasby at gmail.com>
- * [r106] added comment about running ./autogen.sh
-2003-04-02 21:55 Yury Bychkov <me at yury.ca>
- * [r105] Added example on how to wrap internal storage format with
- CoordinateLists.
-2003-04-02 08:02 Yury Bychkov <me at yury.ca>
- * [r104] isValid is debugged (passes all 805 tests).
-2003-03-24 19:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r103] Added newlines to end to quiet gcc
-2003-03-24 19:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r102] Yet more GNU build fiddling. Removed extraneous build
- support from all
- non-geom library directories.
-2003-03-24 03:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r101] More GNU build support
-2003-03-24 03:07 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r100] GNU build support on latest changes.
-2003-03-19 00:34 Yury Bychkov <me at yury.ca>
- * [r99] All Overlay classes are ported. Overlay and isValid have
- not been tested yet.
-2003-03-18 01:42 Yury Bychkov <me at yury.ca>
- * [r98] 90% of Overlay classes ported.
-2003-03-17 18:04 Yury Bychkov <me at yury.ca>
- * [r97] All 'index' packages and part of 'overlay' are done.
-2003-03-17 02:49 Yury Bychkov <me at yury.ca>
- * [r96] IsValid and supporting packages are ported (but NOT
- tested).
-2003-03-12 23:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r95] Build support for valid.
-2003-03-10 10:18 Yury Bychkov <me at yury.ca>
- * [r94] IsValid() and supporting index classes are ported, but
- don't work yet (external dependencies)
-2003-03-10 01:17 Yury Bychkov <me at yury.ca>
- * [r93] IsValid and supporting index classes are almost done.
-2003-03-05 17:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r92] Build support for new coordinateline examples.
-2003-03-05 08:02 Yury Bychkov <me at yury.ca>
- * [r91] CoordinateList interface example.
-2003-03-03 03:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r90] Remove PointInRing
-2003-03-03 03:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r89] Removed unused file.
-2003-03-03 02:41 Yury Bychkov <me at yury.ca>
- * [r88] Some Coordinate& related bugs fixed.
-2003-03-03 02:26 Yury Bychkov <me at yury.ca>
- * [r87] GeometryFactory bug fix.
-2003-03-03 00:46 Yury Bychkov <me at yury.ca>
- * [r86] Second pass of code cleanup. Coordinate references and
- inlining.
-2003-03-02 03:47 Yury Bychkov <me at yury.ca>
- * [r85] First pass of code cleanup completed over all packages.
-2003-03-01 06:10 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r84] Uncommented default constructor for PointInRing
-2003-03-01 06:08 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r83] Fixed call to geometry factory.
-2003-02-26 23:16 Yury Bychkov <me at yury.ca>
- * [r82] All packages except 'graph' has been refactored.
-2003-02-20 03:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r81] Fixed small bug in call to GeometryFactory (instantiate
- PrecisionModel
- with new)
-2003-02-20 03:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r80] GFactory: Move i outside of for loop. Needed to compile GNU
- CListFactory: Add newline to end of file.
-2003-02-20 00:10 Yury Bychkov <me at yury.ca>
- * [r79] Geom and Operation (including Relate) packages are updated.
-2003-02-17 09:38 Yury Bychkov <me at yury.ca>
- * [r78] GEOM package fully updated & bugs fixed.
-2003-02-17 00:40 Yury Bychkov <me at yury.ca>
- * [r77] GEOM package fully updated.
-2003-02-16 22:52 Yury Bychkov <me at yury.ca>
- * [r76] GEOM package partially updated.
-2003-02-12 21:09 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r75] Added two files required by autoconf build process.
-2003-02-12 20:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r74] Commit build support files.
-2003-02-12 19:11 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r73] Change header installation path to $(prefix)/include/geos.
-2003-02-12 06:50 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r72] Added newlines to quiet g++ warnings.
-2003-02-12 06:48 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r71] Added newlines to ends of files to quiet g++ warnings.
-2003-02-12 06:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r70] Fix headers.
-2003-02-12 06:26 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r69] Changed headers.
-2003-02-12 06:24 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r68] Added return value.
- * [r67] Changed headers.
-2003-02-12 06:19 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r66] Make path to test file relative.
-2003-02-12 06:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r65] Change include reference syntax.
-2003-02-12 06:07 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r64] Remove NULL test.
- * [r63] Pass double to log().
- * [r62] Fixed main() return type.
-2003-02-12 06:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r61] Remove old library references.
-2003-02-12 05:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r60] Added stdio reference and newline at end.
-2003-02-12 00:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r59] Added all JTS test cases to the file.
-2003-02-11 23:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r58] Added support for new cpp files.
-2003-02-11 23:33 Yury Bychkov <me at yury.ca>
- * [r57] Some bugs fixed.
-2003-02-11 20:24 Yury Bychkov <me at yury.ca>
- * [r56] Small changes in PointCoordinateList and EdgeEndStar.
-2003-02-11 19:01 Martin Davis <mtnclimb at gmail.com>
- * [r55] fixed duplicate for loop index
-2003-02-05 08:14 Yury Bychkov <me at yury.ca>
- * [r54] Second pass of CoordinateList interface migration.
-2003-01-27 08:04 Yury Bychkov <me at yury.ca>
- * [r53] First pass of CoordinateList interface replacement.
-2003-01-27 07:56 Yury Bychkov <me at yury.ca>
- * [r52] First pass of CoordinateList interface replacement.
-2003-01-27 07:26 Yury Bychkov <me at yury.ca>
- * [r51] First pass of CoordinateList interface replacement.
-2002-12-02 09:48 Yury Bychkov <me at yury.ca>
- * [r50] More performance updates.
-2002-11-24 10:48 Yury Bychkov <me at yury.ca>
- * [r49] Some performance improvements.
-2002-11-14 23:43 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r48] Build support for the bigtest programs.
-2002-11-08 19:49 Yury Bychkov <me at yury.ca>
- * [r47] Preformance is drastically improved
-2002-11-05 23:13 Yury Bychkov <me at yury.ca>
- * [r46] Code for generating large tests added.
-2002-10-31 07:37 Yury Bychkov <me at yury.ca>
- * [r45] XML tester is less fragile now.
-2002-10-30 21:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r44] Added configure support files for building w/o
- automake/autoconf
-2002-10-30 21:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r43] Small changes to make autoconf happy.
-2002-10-30 20:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r42] Edited test file to not crash XMLTester
-2002-10-30 19:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r41] New build changes necessary to build under Linux GNU.
-2002-10-23 02:21 Norman Vine <nhv at cape.com>
- * [r40] GNU portability changes
-2002-10-17 07:12 Yury Bychkov <me at yury.ca>
- * [r39] All test cases now work. Some are still too slow.
-2002-10-06 09:56 Yury Bychkov <me at yury.ca>
- * [r38] Relate() is almost debugged.
-2002-09-12 14:08 Fernando Villa <fvilla at zoo.uvm.edu>
- * [r37] Add makefile support for new files and dir
-2002-09-12 01:27 Yury Bychkov <me at yury.ca>
- * [r36] Relate is finished,but doesn't work yet.
-2002-09-10 13:46 Fernando Villa <fvilla at zoo.uvm.edu>
- * [r35] Added operation/Makefiles
-2002-09-06 20:18 Yury Bychkov <me at yury.ca>
- * [r34] A lot of changes: Code is brought to version 1.2 of JTS.
- Compilable part of Operation added.
-2002-09-05 18:32 Fernando Villa <fvilla at zoo.uvm.edu>
- * [r33] Fixed version numbering. Whenever version numbers are
- bumped up the
- change should be reflected in the AC_INIT_AUTOMAKE macro in
- configure.in.
- I've put it at 0.0.1 - should be changed as appropriate. The
- version is
- #define'd for code being compiled as GEOS_VERSION.
-2002-09-03 16:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r32] Changed reference to 'libgeom' to 'libgeos'
-2002-09-03 13:53 Fernando Villa <fvilla at zoo.uvm.edu>
- * [r31] * Add automake/autoconf support for one-lib compilation
- * add libtool support for shared libraries.
- --enable-shared={yes|no} and
- --enable-static={yes|no} control static and shared lib
- generation.
- * Makefile.in and configure files added to cvs (for users without
- automake)
- * add dir macros/ with a GEOS_INIT macro to be used in
- configure.in
- of other packages using geos (not used by geos itself)
- * add dir tools/ with geos-config script
- * the makefile in source/geom is the only one that generates a
- library - all others have the source files in EXTRA_DIST only
- * small glitch: 'make dist' will give errors trying to add the
- source files non local to source/geom to the archive using
- relative
- paths. Does not have consequences other than the error messages -
- will
- see if I can fix this. In general the one-lib, complex-tree
- solution is not
- easy to work with in automake.
-2002-09-01 18:08 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r30] Minor portability changes.
-2002-09-01 17:53 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r29] Changes to support algorithm directory in build structure.
-2002-09-01 17:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r28] GNU compatibility fixes, changing __min/__max to min/max,
- adding
- stdio.h where needed, small syntax adjustments, newlines at
- end of files.
-2002-08-30 18:33 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r27] Added LGPL licence text.
-2002-08-30 18:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r26] Changed name of authors file as requested by autoconf.
-2002-08-30 18:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r25] Removed --force-missing which did not work for my version
- of autoconf
-2002-08-30 18:16 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r24] Added cvs ignore files.
-2002-08-30 18:15 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r23] Added the testing files back into their new subdirectory.
- * [r22] Added GNU autoconf support files submitted by Norman Vine.
- Moved test
- files to a new subdirectory.
-2002-08-30 15:52 Yury Bychkov <me at yury.ca>
- * [r21] 'algorithm' is almost complete
-2002-08-22 09:23 Yury Bychkov <me at yury.ca>
- * [r20] 'graph/index' finished. Some .h changes.
-2002-08-21 05:49 Yury Bychkov <me at yury.ca>
- * [r19] Some changes in 'graph'
-2002-08-20 21:08 Yury Bychkov <me at yury.ca>
- * [r18] Changed consts to enums
-2002-08-14 07:00 Yury Bychkov <me at yury.ca>
- * [r17] New structure of source.
-2002-07-11 07:57 Yury Bychkov <me at yury.ca>
- * [r16] Assert and some graph classes
-2002-07-03 05:24 Yury Bychkov <me at yury.ca>
- * [r15] started XML tester
-2002-07-02 06:41 Yury Bychkov <me at yury.ca>
- * [r14] 'io' and SimpleTester done
-2002-06-27 02:50 Yury Bychkov <me at yury.ca>
- * [r13] 'io' is almost done
-2002-06-26 09:10 Yury Bychkov <me at yury.ca>
- * [r12] Some 'io' classes done.
-2002-06-21 07:13 Yury Bychkov <me at yury.ca>
- * [r11] 'geos': first pass done. Some external dependencies and
- polishing left.
-2002-06-20 08:58 Yury Bychkov <me at yury.ca>
- * [r10] Only Geometry.java left
-2002-06-19 06:29 Yury Bychkov <me at yury.ca>
- * [r9] 'geom' mostly done.
-2002-06-14 07:46 Yury Bychkov <me at yury.ca>
- * [r8] 'geom' almost done
-2002-06-12 01:47 Yury Bychkov <me at yury.ca>
- * [r7] LineString is 99% finished
-2002-06-11 23:43 Yury Bychkov <me at yury.ca>
- * [r6] 'geom' package 70% done
-2002-06-07 17:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r2] Initial revision
-2002-06-07 17:47 No Body <no at body.net>
- * [r1] New repository initialized by cvs2svn.
Modified: branches/3.4/Makefile.am
--- branches/3.4/Makefile.am 2016-10-27 14:27:26 UTC (rev 4283)
+++ branches/3.4/Makefile.am 2016-10-27 14:45:20 UTC (rev 4284)
@@ -7,6 +7,11 @@
# is not able to detect required build order but blindly
# relies on the order items in SUBDIRS appear.
+# foreign is needed to avoid enforced ChangeLog in EXTRA_DIST
+# (we'll still take care of adding it ourselves)
+AUTOMAKE_OPTIONS = foreign
SUBDIRS = \
include \
src \
@@ -27,9 +32,19 @@
ACLOCAL_AMFLAGS = -I macros
-cl:
- cd $(srcdir) && svn update && svn2cl --authors=authors.svn -i -o ChangeLog
+dist-hook: gen-ChangeLog
+gen-ChangeLog:
+ cd $(distdir) && owd=`pwd` && \
+ cd ../ && cd $(srcdir) && \
+ if test -d .git; then \
+ git2cl > $${owd}/ChangeLog; \
+ elif test -d .svn; then \
+ svn2cl --authors=authors.svn -i -o $${owd}/ChangeLog; \
+ elif test -f ChangeLog; then \
+ cp ChangeLog $${owd}/ChangeLog; \
+ fi
apidoc doxygen:
cd doc && make $@
More information about the geos-commits
