[geos-commits] r4285 - branches/3.4
Sandro Santilli
strk at kbt.io
Thu Oct 27 07:54:24 PDT 2016
Author: strk
Date: 2016-10-27 07:54:24 -0700 (Thu, 27 Oct 2016)
New Revision: 4285
branches/3.4/HOWTO_RELEASE
Update to drop the generation of ChangeLog
Modified: branches/3.4/HOWTO_RELEASE
--- branches/3.4/HOWTO_RELEASE 2016-10-27 14:45:20 UTC (rev 4284)
+++ branches/3.4/HOWTO_RELEASE 2016-10-27 14:54:24 UTC (rev 4285)
@@ -1,39 +1,37 @@
-1: Verify that the versions currently set (see 10 and 11 below) make
+- Verify that the versions currently set (see 10 and 11 below) make
sense for this release.
-2: Run 'make distcheck', fix any problem with it.
+- Run 'make distcheck', fix any problem with it.
-3: Generate the ChangeLog by running 'make cl'
+- Update the NEWS file (extract most important things from the
+ repository log). Make sure to update the release date
-4: Update the NEWS file (extract most important things from the ChangeLog)
- Make sure to update the release date
+- Commit the changes in the NEWS file.
-5. Commit the new ChangeLog and NEWS files.
-6: Tag the release:
+- Tag the release:
$ base=http://svn.osgeo.org/geos/
$ svn copy -m "Tagged release MAJOR.MINOR.PATCH" \
$base/trunk $base/tags/MAJOR.MINOR.PATCH
-7: Export the tag and 'make dist-bzip2'.
- $ svn export $base/tags/$rev
- $ cd $rev
- $ ./autogen.sh && ./configure && make dist-bzip2
+- Export the tag and 'make dist-bzip2'.
+ $ svn export $base/tags/$rev
+ $ cd $rev
+ $ ./autogen.sh && ./configure && make dist-bzip2
-8: Verify that you can unpack and build the tarball
+- Verify that you can unpack and build the tarball
-9: Copy the tarball to upload.osgeo.org:/osgeo/download/geos
+- Copy the tarball to upload.osgeo.org:/osgeo/download/geos
-10: Increment all the version numbers for the next release, as below.
+- Increment all the version numbers for the next release, as below.
-11: Increment CAPI_INTERFACE_X in configure.in
+- Increment CAPI_INTERFACE_X in configure.in
- For a release with no interface changes just bump REVISION.
[ Even if *nothing* changed in CAPI ]
- Adding interfaces, bump CURRENT/AGE, set REVISION to 0.
- Deleting interfaces / compatibility issues - bump CURRENT, others to zero
[ THIS MUST BE CAREFULLY AVOIDED ]
-12: Increment release version:
+- Increment release version:
- In configure.in
- In include/geos/version.h.vc
- In capi/geos_c.h.in
@@ -45,9 +43,9 @@
- VERSION_MAJOR, VERSION_MINOR, VERSION_PATCH
- CAPI_INTERFACE_*
-13: Update wiki page http://trac.osgeo.org/geos/ at Download section
+- Update wiki page http://trac.osgeo.org/geos/ at Download section
- Add latest release
- Remove previos patch level release (if any)
-14: Announce
+- Announce
More information about the geos-commits
