[geos-commits] [SCM] GEOS branch master updated. 5c30d3d696b0292961813e4254a3b1f59fc578ee
git at osgeo.org
git at osgeo.org
Thu Mar 14 10:46:21 PDT 2019
the project "GEOS".
via 5c30d3d696b0292961813e4254a3b1f59fc578ee (commit)
via d7015c227e5d423a348a26e7b33a7837ddb9b847 (commit)
via b0a391a260f9699ef078aa354b1ad6a06539d70b (commit)
via 16e7193b62ec6f42b8f13029b5e6e9737268eaee (commit)
from 93b3eb637e75e96f223e6e440b4aa6ec960fa914 (commit)
revisions in full, below.
commit 5c30d3d696b0292961813e4254a3b1f59fc578ee
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Mar 14 10:46:04 2019 -0700
Just the unique tests from old test cases
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index f733b67..f49d369 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -108,8 +108,8 @@ if(GEOS_ENABLE_TESTS)
${XMLTESTS_DIR}/misc/stmlf-cases-20061020.xml
${XMLTESTS_DIR}/misc/stmlf-cases-20070119.xml
${XMLTESTS_DIR}/misc/split.xml
- ${XMLTESTS_DIR}/misc/test.xml
- ${XMLTESTS_DIR}/misc/testLeaksBig.xml
+ ${XMLTESTS_DIR}/misc/InvalidRelates.xml
+ ${XMLTESTS_DIR}/misc/Segfaults.xml
${XMLTESTS_DIR}/robust/TestRobustOverlayFixed.xml
${XMLTESTS_DIR}/robust/TestRobustRelate.xml
${XMLTESTS_DIR}/issue/issue-geos-176.xml
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 336bd13..b4f9425 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -76,8 +76,8 @@ SAFE_XMLTESTS= \
$(srcdir)/tests/misc/stmlf-cases-20061020.xml \
$(srcdir)/tests/misc/stmlf-cases-20070119.xml \
$(srcdir)/tests/misc/split.xml \
- $(srcdir)/tests/misc/test.xml \
- $(srcdir)/tests/misc/testLeaksBig.xml \
+ $(srcdir)/tests/misc/InvalidRelates \
+ $(srcdir)/tests/misc/Segfaults.xml \
$(srcdir)/tests/robust/TestRobustOverlayFixed.xml \
$(srcdir)/tests/robust/TestRobustRelate.xml \
$(srcdir)/tests/issue/issue-geos-176.xml \
diff --git a/tests/xmltester/tests/misc/InvalidRelates.xml b/tests/xmltester/tests/misc/InvalidRelates.xml
new file mode 100644
index 0000000..5fc48ec
--- /dev/null
+++ b/tests/xmltester/tests/misc/InvalidRelates.xml
@@ -0,0 +1,89 @@
+<run>
+ <precisionModel type="FLOATING" />
+ <case>
+ <desc>A/A-3-1-8: the closing point of a polygon touching the boundary of another polygon where the closing point touching the boundary at a vertex [dim(0){A.A.Bdy.CP = B.A.Bdy.TP}]</desc>
+ <a>
+ POLYGON((160 200, 210 70, 120 70, 160 200))
+ </a>
+ <b>
+ POLYGON((160 200, 260 40, 70 40, 160 200, 20 20, 310 20, 160 200))
+ </b>
+ <test>
+ <op arg1="A" arg2="B" arg3="FF2F01212" name="relate">true</op>
+ </test>
+ </case>
+ <case>
+ <desc>A/A-3-1-9: the closing point of a polygon touching the boundary of another polygon where the closing point intersecting the boundary at a non-vertex [dim(0){A.A.Bdy.CP = B.A.Bdy.TP}]</desc>
+ <a>
+ POLYGON((110 140, 200 70, 200 160, 110 140))
+ </a>
+ <b>
+ POLYGON((110 140, 110 50, 60 50, 60 90, 160 190, 20 110, 20 20, 200 20, 110 140))
+ </b>
+ <test>
+ </test>
+ </case>
+ <case>
+ <desc>LC - intersection (containment) along mod-2 A-Int line segment</desc>
+ <a>
+ LINESTRING(40 180, 140 180)
+ </a>
+ <b>
+ MULTIPOLYGON(
+ ((20 320, 180 320, 180 180, 20 180, 20 320)),
+ ((20 180, 20 80, 180 80, 180 180, 20 180)))
+ </b>
+ <test>
+ <op arg1="A" arg2="B" arg3="1FF0FF212" name="relate">true</op>
+ </test>
+ </case>
+ <case>
+ <desc>LC - intersection (overlap) along mod-2 A-Int line segment</desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOLYGON(
+ ((60 180, 60 80, 180 80, 180 180, 60 180)))
+ </b>
+ <test>
+ <op arg1="A" arg2="B" arg3="11F00F212" name="relate">true</op>
+ </test>
+ </case>
+ <case>
+ <desc>P/A-2-2: a point outside a converx polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
+ <a>
+ POINT(70 170)
+ </a>
+ <b>
+ POLYGON((110 230, 80 160, 20 160, 20 20, 200 20, 200 160, 140 160, 110 230))
+ </b>
+ <test>
+ <op arg1="A" arg2="B" arg3="FF0FFF212" name="relate">true</op>
+ </test>
+ </case>
+ <case>
+ <desc>
+ P/A-3-4: a point on the touching point of boudary [dim(0){A.P.Int = B.A.Bdy.TP}
+ </desc>
+ <a>
+ POINT(100 150)
+ </a>
+ <b>
+ POLYGON(
+ (20 150, 100 150, 40 50, 160 50, 100 150, 180 150, 180 20, 20 20, 20 150))
+ </b>
+ <test>
+ <op arg1="A" arg2="B" arg3="F0FFFF212" name="relate">true</op>
+ </test>
+ </case>
+</run>
diff --git a/tests/xmltester/tests/misc/Segfaults.xml b/tests/xmltester/tests/misc/Segfaults.xml
index 0000000..687079b
--- /dev/null
+++ b/tests/xmltester/tests/misc/Segfaults.xml
@@ -0,0 +1,36 @@
+<run>
+ <precisionModel offsetx="0.0" offsety="0.0" scale="1.0" />
+ <case>
+ <desc>SegFault</desc>
+ <a>
+ POLYGON((1033707.6 1048313.1,1033694.9 1048315.7,1033659.9 1048344.3,1033627.6 1048388.8,1033620.9 1048426.8,1033623.6 1048471.3,1033623.6 1048480.8,1033616.8 1048503.2,1033629.1 1048541.3,1033668.3 1048707.6,1033696.3 1048755.6,1033721.4 1048771.6,1033724.5 1048772,1033737.2 1048772,1033772.1 1048756.4,1033794.6 1048721.9,1033811.1 1048667.4,1033814.8 1048613.6,1033815.1 1048597.5,1033809.2 1048556.1,1033809.3 1048549.6,1033797.1 1048501.9,1033790.9 1048492.2,1033773 1048399.6,1033760.6 1048377.6,1033741.8 1048357.8,1033742.1 1048341.8,1033713.9 1048313.4,1033707.6 1048313.1))
+ </a>
+ <test>
+ <op arg1="A" name="isValid">true</op>
+ </test>
+ </case>
+ <case>
+ <desc>Multipoint buffer</desc>
+ <a>MULTIPOINT(0 0, 5 5)</a>
+ <test>
+ <op arg1="a" arg2="10" name="buffer">
+ POLYGON ((-10.0 -2.0, -10.0 -0.0, -10.0 2.0, -9.0 4.0, -8.0 6.0, -7.0 7.0, -6.0 8.0, -4.0 9.0, -3.0 11.0, -2.0 12.0, -1.0 13.0, 1.0 14.0, 3.0 15.0, 5.0 15.0, 7.0 15.0, 9.0 14.0, 11.0 13.0, 12.0 12.0, 13.0 11.0, 14.0 9.0, 15.0 7.0, 15.0 5.0, 15.0 3.0, 14.0 1.0, 13.0 -1.0, 12.0 -2.0, 11.0 -3.0, 9.0 -4.0, 8.0 -6.0, 7.0 -7.0, 6.0 -8.0, 4.0 -9.0, 2.0 -10.0, 0.0 -10.0, -2.0 -10.0, -4.0 -9.0, -6.0 -8.0, -7.0 -7.0, -8.0 -6.0, -9.0 -4.0, -10.0 -2.0))
+ </op>
+ </test>
+ </case>
+ <case>
+ <desc>Multipolygon buffering</desc>
+ <a>
+ MULTIPOLYGON (((10 10, 10 20, 20 20, 20 15, 10 10)), ((60 60, 70 7, 80 60, 60 60)))
+ </a>
+ <test>
+ <op arg1="a" arg2="0" name="buffer">
+ </op>
+ </test>
+ </case>
+</run>
commit d7015c227e5d423a348a26e7b33a7837ddb9b847
Date: Thu Mar 14 10:37:57 2019 -0700
Remove old duplicative test files
diff --git a/tests/xmltester/tests/misc/test.xml b/tests/xmltester/tests/misc/test.xml
deleted file mode 100644
index 23a85c4..0000000
--- a/tests/xmltester/tests/misc/test.xml
+++ /dev/null
@@ -1,6597 +0,0 @@
-<run>
-<precisionModel type="FLOATING"/>
-<case>
-<desc>A/A-6-18: a polygon overlapping a very skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(100 100, 100 200, 200 200, 200 100, 100 100))
-</a>
-<b>
-POLYGON(
-(100 100, 1000000000000000 110, 1000000000000000 100, 100 100))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="212111212">true</op>
-</test>
-</case>
-<case>
-<desc>A/A-6-24: a polygon overlapping a very skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(120 100, 120 200, 200 200, 200 100, 120 100))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-1-1: same polygons [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
-<a>
-POLYGON(
-(20 20, 20 100, 120 100, 140 20, 20 20))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="2FFF1FFF2">true</op>
-</test>
-</case>
-<case>
-<desc>A/A-1-2: same polygons with reverse sequence of points [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.EP-SP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 140 20, 120 100, 20 100, 20 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-1-3: same polygons with different sequence of points [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(120 100, 140 20, 20 20, 20 100, 120 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-1-4: same polygons with different number of points [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 100, 60 100, 120 100, 140 20, 80 20, 20 20, 20 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-2: different polygons [dim(2){A.A.Int = B.A.Ext}]</desc>
-<a>
-POLYGON(
-(0 0, 80 0, 80 80, 0 80, 0 0))
-</a>
-<b>
-POLYGON(
-(100 200, 100 140, 180 140, 180 200, 100 200))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF2FF1212">true</op>
-</test>
-</case>
-<case>
-<desc>A/A-3-1-1: the closing point of a polygon touching the closing point of another polygon [dim(0){A.A.Bdy.CP = B.A.Bdy.CP}]</desc>
-<a>
-POLYGON(
-(140 120, 160 20, 20 20, 20 120, 140 120))
-</a>
-<b>
-POLYGON(
-(140 120, 140 200, 240 200, 240 120, 140 120))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF2F01212">true</op>
-</test>
-</case>
-<case>
-<desc>A/A-3-1-2: the closing point of a polygon touching the boundary (at a non-vertex) of another polygon [dim(0){A.A.Bdy.CP = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(80 180, 140 260, 260 200, 200 60, 80 180))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-1-3: the closing point of a polygon touching the boundary (at a vertex) of another polygon [dim(0){A.A.Bdy.CP = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(240 80, 140 120, 180 240, 280 200, 240 80))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-1-4: the boundary (at a non-vertex) of a polygon touching the closing point of another polygon [dim(0){A.A.Bdy.NV = B.A.Bdy.CP}]</desc>
-<a>
-POLYGON(
-(140 160, 20 20, 270 20, 150 160, 230 40, 60 40, 140 160))
-</a>
-<b>
-POLYGON(
-(140 40, 180 80, 120 100, 140 40))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-1-5: the boundary (at a non-vertex) of a polygon touching the boundary (at a vertex) of another polygon [dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(120 100, 180 80, 130 40, 120 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-1-6: the boundary (at a vertex) of a polygon touching the boundary (at a non-vertex) of another polygon [dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(20 20, 180 20, 140 140, 20 140, 20 20))
-</a>
-<b>
-POLYGON(
-(180 100, 80 200, 180 280, 260 200, 180 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-1-7: the boundary (at a vertex) of a polygon touching the boundary (at a vertex) of another polygon [dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(140 140, 20 120, 0 220, 120 240, 140 140))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-1-8: the closing point of a polygon touching the boundary of another polygon where the closing point touching the boundary at a vertex [dim(0){A.A.Bdy.CP = B.A.Bdy.TP}]</desc>
-<a>
-POLYGON(
-(160 200, 210 70, 120 70, 160 200))
-</a>
-<b>
-POLYGON(
-(160 200, 260 40, 70 40, 160 200, 20 20, 310 20, 160 200))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-1-9: the closing point of a polygon touching the boundary of another polygon where the closing point intersecting the boundary at a non-vertex [dim(0){A.A.Bdy.CP = B.A.Bdy.TP}]</desc>
-<a>
-POLYGON(
-(110 140, 200 70, 200 160, 110 140))
-</a>
-<b>
-POLYGON(
-(110 140, 110 50, 60 50, 60 90, 160 190, 20 110, 20 20, 200 20, 110 140))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-2-1: two polygons touching at multiple points [dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-(20 120, 20 20, 260 20, 260 120, 200 40, 140 120, 80 40, 20 120))
-</a>
-<b>
-POLYGON(
-(20 120, 20 240, 260 240, 260 120, 200 200, 140 120, 80 200, 20 120))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-2-2: two polygons touching at multiple points [dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(20 120, 20 20, 260 20, 260 120, 180 40, 140 120, 100 40, 20 120))
-</a>
-<b>
-POLYGON(
-(20 120, 300 120, 140 240, 20 120))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-2-3: two polygons touching at multiple points [dim(0){A.A.Bdy.CP = B.A.Bdy.NV}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(20 20, 20 300, 280 300, 280 260, 220 260, 60 100, 60 60, 280 60, 280 20,
-20 20))
-</a>
-<b>
-POLYGON(
-(100 140, 160 80, 280 180, 200 240, 220 160, 160 200, 180 120, 100 140))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-2-4: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-20 20))
-</a>
-<b>
-POLYGON(
-(260 200, 180 80, 120 160, 200 160, 180 220, 260 200))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-2-5: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(20 20, 280 20, 280 140, 220 60, 140 140, 80 60, 20 140, 20 20))
-</a>
-<b>
-POLYGON(
-(0 140, 300 140, 140 240, 0 140))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-2-6: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 240, 20 140, 320 140, 180 240, 20 240))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-2-7: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 240, 20 140, 80 180, 140 140, 220 180, 280 140, 280 240, 20 240))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-1: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-NV}]</desc>
-<a>
-POLYGON(
-(120 120, 180 60, 20 20, 20 120, 120 120))
-</a>
-<b>
-POLYGON(
-(120 120, 220 20, 280 20, 240 160, 120 120))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF2F11212">true</op>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-2: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(140 120, 160 20, 260 120, 220 200, 140 120))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-3: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.NV-V}]</desc>
-<a>
-POLYGON(
-(20 140, 120 40, 20 40, 20 140))
-</a>
-<b>
-POLYGON(
-(190 140, 190 20, 140 20, 20 140, 190 140))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-4: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.NV-V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(300 20, 220 20, 120 120, 260 160, 300 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-5: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-EP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(140 120, 240 160, 280 60, 160 20, 140 120))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-6: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(280 60, 180 60, 120 120, 260 180, 280 60))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-7: two polygons touching along a boundary [dim(1){A.A.Bdy.NV-NV = B.A.Bdy.V-V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(120 200, 120 120, 40 120, 40 200, 120 200))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-8: two polygons touching along a boundary [dim(1){A.A.Bdy.NV-EP = B.A.Bdy.V-V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(160 220, 140 120, 60 120, 40 220, 160 220))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-9: two polygons touching along a boundary [dim(1){A.A.Bdy.V-EP = B.A.Bdy.V-SP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(140 120, 20 120, 20 220, 140 220, 140 120))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-3-3-10: two polygons touching along a boundary [dim(1){A.A.Bdy.V-V = B.A.Bdy.NV-NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(320 20, 220 20, 80 160, 240 140, 320 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Int}]</desc>
-<a>
-POLYGON(
-(20 20, 20 180, 220 180, 220 20, 20 20))
-</a>
-<b>
-POLYGON(
-(60 40, 60 140, 180 140, 180 40, 60 40))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="212FF1FF2">true</op>
-</test>
-</case>
-<case>
-<desc>A/A-5-2-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 80 140, 160 60, 20 20))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="212F01FF2">true</op>
-</test>
-</case>
-<case>
-<desc>A/A-5-2-2: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(160 60, 20 20, 100 140, 160 60))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-2-3: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 100, 140 160, 160 40, 20 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-2-4: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(160 40, 20 100, 160 160, 160 40))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-2-5: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.CP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 180, 180 120, 80 40, 20 180))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-2-6: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(180 120, 100 40, 20 180, 180 120))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-3-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 140 40, 140 120, 20 160, 80 80, 20 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-3-2: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 140 40, 140 140, 20 180, 80 100, 20 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-3-3: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(40 180, 60 100, 180 100, 200 180, 120 120, 40 180))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-3-4: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 180, 60 80, 180 80, 220 180, 120 120, 20 180))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-3-5: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(40 60, 20 180, 100 100, 140 180, 160 120, 220 100, 140 40, 40 60))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-3-6: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(60 100, 180 100, 220 180, 120 140, 20 180, 60 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-4-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-NV = B.A.Bdy.SP-V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 20 140, 120 120, 120 40, 20 20))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="212F11FF2">true</op>
-</test>
-</case>
-<case>
-<desc>A/A-5-4-2: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-V)}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 20 180, 140 140, 140 60, 20 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-4-3: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-NV = B.A.Bdy.V-EP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 120 40, 120 120, 20 140, 20 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-4-4: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-NV = B.A.Bdy.V-V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(120 40, 20 20, 20 140, 120 120, 120 40))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-4-5: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-EP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 140 60, 140 140, 20 180, 20 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-4-6: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(140 60, 20 20, 20 180, 140 140, 140 60))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-4-7: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.NV-EP = B.A.Bdy.V-EP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 60 120, 140 120, 180 20, 20 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-4-8: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.NV-NV = B.A.Bdy.V-EP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 40, 120 40, 120 120, 20 140, 20 40))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-5-5-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-V}, dim(1){A.A.Bdy.(NV, V) = B.A.Bdy.(V, V)}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 20, 20 180, 60 120, 100 180, 140 120, 220 180, 200 120, 140 60, 20 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-1: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}]</desc>
-<a>
-POLYGON(
-(150 150, 330 150, 250 70, 70 70, 150 150))
-</a>
-<b>
-POLYGON(
-(150 150, 270 150, 140 20, 20 20, 150 150))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-2: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}]</desc>
-<a>
-POLYGON(
-(150 150, 270 150, 330 150, 250 70, 190 70, 70 70, 150 150))
-</a>
-<b>
-POLYGON(
-(150 150, 270 150, 190 70, 140 20, 20 20, 70 70, 150 150))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-3: spiky polygons overlapping; boundary <-> boundary intersecting at 0 dimension [dim(2){A.A.Int = B.A.Int}]</desc>
-<a>
-POLYGON(
-(20 20, 60 50, 20 40, 60 70, 20 60, 60 90, 20 90, 70 110, 20 130,
-80 130, 20 150, 80 160, 20 170, 80 180, 20 200, 80 200, 30 240, 80 220, 50 260,
-100 220, 100 260, 120 220, 130 260, 140 220, 150 280, 150 190, 160 280, 170 190, 180 280,
-190 190, 200 280, 210 190, 220 280, 230 190, 240 260, 250 230, 260 260, 260 220, 290 270,
-290 220, 330 260, 300 210, 340 240, 290 180, 340 210, 290 170, 350 170, 240 150, 350 150,
-240 140, 350 130, 240 120, 350 120, 240 110, 350 110, 240 100, 350 100, 240 90, 350 90,
-240 80, 350 80, 300 70, 340 60, 290 60, 340 40, 300 50, 340 20, 270 60, 310 20,
-250 60, 270 20, 230 60, 240 20, 210 60, 210 20, 190 70, 190 20, 180 90, 170 20,
-160 90, 150 20, 140 90, 130 20, 120 90, 110 20, 100 90, 100 20, 90 60, 80 20,
-70 40, 20 20))
-</a>
-<b>
-POLYGON(
-(190 140, 140 130, 200 160, 130 150, 210 170, 130 170, 210 180, 120 190, 220 200,
-120 200, 250 210, 120 210, 250 220, 120 220, 250 230, 120 240, 230 240, 120 250, 240 260,
-120 260, 240 270, 120 270, 270 290, 120 290, 230 300, 150 310, 250 310, 180 320, 250 320,
-200 360, 260 330, 240 360, 280 320, 290 370, 290 320, 320 360, 310 320, 360 360, 310 310,
-380 340, 310 290, 390 330, 310 280, 410 310, 310 270, 420 280, 310 260, 430 250, 300 250,
-440 240, 300 240, 450 230, 280 220, 440 220, 280 210, 440 210, 300 200, 430 190, 300 190,
-440 180, 330 180, 430 150, 320 180, 420 130, 300 180, 410 120, 280 180, 400 110, 280 170,
-390 90, 280 160, 400 70, 270 160, 450 30, 260 160, 420 30, 250 160, 390 30, 240 160,
-370 30, 230 160, 360 30, 230 150, 330 50, 240 130, 330 30, 230 130, 310 30, 220 130,
-280 30, 230 100, 270 40, 220 110, 250 30, 210 130, 240 30, 210 100, 220 40, 200 90,
-200 20, 190 100, 180 30, 20 20, 180 40, 20 30, 180 50, 20 50, 180 60, 30 60,
-180 70, 20 70, 170 80, 80 80, 170 90, 20 80, 180 100, 40 100, 200 110, 60 110,
-200 120, 120 120, 190 140))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="212101212">true</op>
-</test>
-</case>
-<case>
-<desc>A/A-6-4: spiky polygons overlapping; boundary <-> boundary intersecting at 1 dimension at a few locations [dim(2){A.A.Int = B.A.Int}]</desc>
-<a>
-POLYGON(
-(70 150, 20 160, 110 160, 20 180, 100 200, 20 200, 190 210, 20 210, 160 220,
-20 220, 150 230, 60 240, 180 250, 20 260, 170 260, 60 270, 160 270, 100 310, 170 280,
-200 260, 180 230, 210 260, 130 330, 230 250, 210 290, 240 250, 230 210, 260 300, 250 230,
-270 300, 270 240, 300 340, 280 250, 320 330, 290 250, 340 350, 290 240, 350 360, 270 190,
-350 340, 290 200, 350 330, 300 190, 360 320, 310 190, 360 300, 320 200, 360 280, 330 200,
-360 260, 340 200, 370 260, 340 180, 390 290, 340 170, 400 260, 350 170, 400 250, 350 160,
-410 240, 350 150, 400 170, 350 140, 310 170, 340 140, 270 180, 330 140, 260 170, 310 140,
-240 170, 290 140, 200 190, 270 140, 180 190, 260 140, 170 190, 260 130, 170 180, 250 130,
-170 170, 240 120, 170 160, 210 120, 170 150, 210 110, 340 130, 230 110, 420 140, 220 100,
-410 130, 220 90, 400 120, 220 80, 390 110, 220 70, 420 110, 240 70, 420 100, 260 70,
-420 90, 280 70, 430 80, 230 60, 430 60, 270 50, 450 40, 210 50, 370 40, 260 40,
-460 30, 160 40, 210 60, 200 110, 190 60, 190 120, 170 50, 180 130, 150 30, 170 130,
-140 20, 160 120, 130 20, 160 150, 120 20, 160 170, 110 20, 160 190, 100 20, 150 190,
-90 20, 140 180, 80 20, 120 140, 70 20, 120 150, 60 20, 110 150, 50 20, 100 140,
-50 30, 90 130, 40 30, 80 120, 30 30, 80 130, 30 40, 80 140, 20 40, 70 140,
-40 90, 60 130, 20 90, 60 140, 20 130, 70 150))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-5: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-(60 160, 220 160, 220 20, 60 20, 60 160))
-</a>
-<b>
-POLYGON(
-(60 160, 20 200, 260 200, 220 160, 140 80, 60 160))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-6: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(60 160, 20 200, 260 200, 140 80, 60 160))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-7: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.NV}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 200, 140 80, 260 200, 20 200))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-8: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 200, 60 160, 140 80, 220 160, 260 200, 20 200))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-9: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(20 200, 60 160, 140 80, 260 200, 20 200))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-10: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(0 0, 0 200, 200 200, 200 0, 0 0))
-</a>
-<b>
-POLYGON(
-(100 100, 1000000 110, 10000000 100, 100 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-11: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(100 0, 100 200, 200 200, 200 0, 100 0))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-12: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(120 0, 120 200, 200 200, 200 0, 120 0))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-13: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(0 0, 0 200, 110 200, 110 0, 0 0))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-14: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(100 100, 2100 110, 2100 100, 100 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-15: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(100 100, 2101 110, 2101 100, 100 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-16: two skinny polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(100 100, 200 200, 200 100, 100 100))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-17: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(100 100, 1000000 110, 1000000 100, 100 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-19: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(100 100, 500 110, 500 100, 100 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-20: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(100 100, 501 110, 501 100, 100 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-21: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(120 100, 130 200, 200 200, 200 100, 120 100))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-22: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(120 100, 17 200, 200 200, 200 100, 120 100))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-23: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-25: two skinny polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(101 99, 101 1000000, 102 1000000, 101 99))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-26: two skinny polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(100 100, 200 101, 200 100, 100 100))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/A-6-26: two polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
-<a>
-POLYGON(
-(16 319, 150 39, 25 302, 160 20, 265 20, 127 317, 16 319))
-</a>
-<b>
-POLYGON(
-(10 307, 22 307, 153 34, 22 34, 10 307))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-1: the closing point of a polygon touching the closing points of another polygon and its hole [dim(0){A.A.Bdy.CP = B.A.oBdy.CP}, dim(0){A.A.Bdy.CP = B.A.iBdy.CP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-(160 200, 310 20, 20 20, 160 200),
-(160 200, 260 40, 70 40, 160 200))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-2: the boundary of a polygon touching the inner boundary of another polygon at two spots [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.SP}, dim(0){A.A.oBdy.V = B.A.iBdy.V}]</desc>
-<a>
-POLYGON(
-(170 120, 240 100, 260 50, 190 70, 170 120))
-</a>
-<b>
-POLYGON(
-(150 150, 410 150, 280 20, 20 20, 150 150),
-(170 120, 330 120, 260 50, 100 50, 170 120))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-3: the boundary of a polygon touching the inner boundary of another polygon at two spots [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.SP}, dim(0){A.A.oBdy.V = B.A.iBdy.V}]</desc>
-<a>
-POLYGON(
-(270 90, 200 50, 150 80, 210 120, 270 90))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-4: the boundary of a polygon touching the inner boundary of another polygon at one spot [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.SP}]</desc>
-<a>
-POLYGON(
-(170 120, 260 100, 240 60, 150 80, 170 120))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-5: the boundary of a polygon touching the inner boundary of another polygon at one spot [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.NV}]</desc>
-<a>
-POLYGON(
-(220 120, 270 80, 200 60, 160 100, 220 120))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-6: the boundary of a polygon touching the inner boundary of another polygon at one spot [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.V}]</desc>
-<a>
-POLYGON(
-(260 50, 180 70, 180 110, 260 90, 260 50))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-7: the boundary of a polygon touching the inner boundary of another polygon at two spots [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.V = B.A.iBdy.NV}, dim(0){A.A.oBdy.V = B.A.iBdy.NV}]</desc>
-<a>
-POLYGON(
-(230 110, 290 80, 190 60, 140 90, 230 110))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-8: the boundary of a polygon touching the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.SP-EP = B.A.iBdy.SP-EP}]</desc>
-<a>
-POLYGON(
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF2F1F212">true</op>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-9: part of the boundary of a polygon touching part of the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.SP-V = B.A.iBdy.SP-NV}, dim(1){A.A.oBdy.V-EP = B.A.iBdy.NV-EP}]</desc>
-<a>
-POLYGON(
-(170 120, 330 120, 280 70, 120 70, 170 120))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-10: part of the boundary of a polygon touching part of the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.SP-V = B.A.iBdy.SP-NV}, dim(1){A.A.oBdy.V-EP = B.A.iBdy.NV-EP}]</desc>
-<a>
-POLYGON(
-(170 120, 300 120, 250 70, 120 70, 170 120))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-3-11: part of the boundary of a polygon touching part of the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.V-V-V = B.A.iBdy.NV-V-NV}]</desc>
-<a>
-POLYGON(
-(190 100, 310 100, 260 50, 140 50, 190 100))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-5-1: an entire polygon within another polygon which has a hole [dim(2){A.A.Ext = B.A.Int}, dim(2){A.A.Int = B.A.Int}]</desc>
-<a>
-POLYGON(
-(280 130, 360 130, 270 40, 190 40, 280 130))
-</a>
-<b>
-POLYGON(
-(170 120, 250 120, 180 50, 100 50, 170 120))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="2FF1FF212">true</op>
-</test>
-</case>
-<case>
-<desc>A/Ah-5-2: an entire polygon within another polygon which has a hole [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}]</desc>
-<a>
-POLYGON(
-(220 80, 180 40, 80 40, 170 130, 270 130, 230 90, 300 90, 250 30, 280 30,
-390 140, 150 140, 40 30, 230 30, 280 80, 220 80))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-5-3: polygon A within polygon B, the boundary of A touching the inner boundary of B [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}, dim(1){A.A.Bdy.NV-NV = B.A.iBdy.V-V}]</desc>
-<a>
-POLYGON(
-(260 130, 360 130, 280 40, 170 40, 260 130))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="2FF11F212">true</op>
-</test>
-</case>
-<case>
-<desc>A/Ah-5-4: polygon A within polygon B, the boundary of A touching the inner boundary of B [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}, dim(1){A.A.Bdy.V-V = B.A.iBdy.NV-NV}]</desc>
-<a>
-POLYGON(
-(240 110, 340 110, 290 60, 190 60, 240 110))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/Ah-5-5: polygon A within polygon B, the boundary of A touching the inner boundary of B [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}, dim(1){A.A.Bdy.V-V = B.A.iBdy.V-V}]</desc>
-<a>
-POLYGON(
-(250 120, 350 120, 280 50, 180 50, 250 120))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>Ah/Ah-1-1: same polygons (with a hole) [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.oBdy.SP-EP = B.A.oBdy.SP-EP}, dim(1){A.A.iBdy.SP-EP = B.A.iBdy.SP-EP}]</desc>
-<a>
-POLYGON(
-(230 210, 230 20, 20 20, 20 210, 230 210),
-(120 180, 50 50, 200 50, 120 180))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A2h/A2h-1-1: same polygons (with two holes) [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.oBdy.SP-EP = B.A.oBdy.SP-EP}, dim(1){A.A.iBdy.SP-EP = B.A.iBdy.SP-EP}]</desc>
-<a>
-POLYGON(
-(140 40, 40 40, 40 170, 140 40),
-(110 190, 210 190, 210 50, 110 190))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/mA-3-1: a polygon touching multipolygon at two points [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.CP = B.2A2.oBdy.NV}, dim(0){A.A.oBdy.V = B.2A1.oBdy.NV}]</desc>
-<a>
-POLYGON(
-(280 190, 330 150, 200 110, 150 150, 280 190))
-</a>
-<b>
-MULTIPOLYGON(
-(140 110, 260 110, 170 20, 50 20, 140 110)),
-(300 270, 420 270, 340 190, 220 190, 300 270)))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/mA-3-2: a polygon touching multipolygon at two points [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.V = B.2A1.oBdy.CP}, dim(0){A.A.oBdy.V = B.2A2.oBdy.V}]</desc>
-<a>
-POLYGON(
-(80 190, 220 190, 140 110, 0 110, 80 190))
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/mA-3-3: a polygon touching multipolygon at two points [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.V = B.2A2.oBdy.NV}, dim(0){A.A.oBdy.V = B.2A1.oBdy.NV}]</desc>
-<a>
-POLYGON(
-(330 150, 200 110, 150 150, 280 190, 330 150))
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/mA-3-4: a polygon touching multipolygon at one spoint [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.V = B.2A2.oBdy.NV}]</desc>
-<a>
-POLYGON(
-(290 190, 340 150, 220 120, 170 170, 290 190))
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/mA-3-5: a polygon touching multipolygon along boundaries [dim(2){A.A.Int = B.2A.Ext}, dim(1){A.A.oBdy.SP-V = B.2A2.oBdy.V-V}, dim(1){A.A.oBdy.V-V = B.2A1.oBdy.V-SP}]</desc>
-<a>
-POLYGON(
-(220 190, 340 190, 260 110, 140 110, 220 190))
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/mA-3-6: a polygon touching multipolygon along boundaries and at a point [dim(2){A.A.Int = B.2A.Ext}, dim(1){A.A.oBdy.V-NV = B.2A1.oBdy.NV-SP}, dim(0){A.A.oBdy.V = B.2A2.oBdy.V}]</desc>
-<a>
-POLYGON(
-(140 190, 220 190, 100 70, 20 70, 140 190))
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>A/mA-6-1: a polygon overlapping multipolygon [dim(2){A.A.Int = B.4A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}]</desc>
-<a>
-POLYGON(
-(140 220, 60 140, 140 60, 220 140, 140 220))
-</a>
-<b>
-MULTIPOLYGON(
-(100 20, 180 20, 180 100, 100 100, 100 20)),
-(20 100, 100 100, 100 180, 20 180, 20 100)),
-(100 180, 180 180, 180 260, 100 260, 100 180)),
-(180 100, 260 100, 260 180, 180 180, 180 100)))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="21210F212">true</op>
-</test>
-</case>
-<case>
-<desc>mA/mA-3-1: MultiPolygon touching MultiPolygon [dim(0){A.mA.Bdy.TP = B.mA.Bdy.TP}]</desc>
-<a>
-MULTIPOLYGON(
-(110 110, 70 200, 150 200, 110 110)),
-(110 110, 150 20, 70 20, 110 110)))
-</a>
-<b>
-MULTIPOLYGON(
-(110 110, 160 160, 210 110, 160 60, 110 110)),
-(110 110, 60 60, 10 110, 60 160, 110 110)))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mAh/mAh-3-1: MultiPolygon touching MultiPolygon [dim(0){A.mA.Bdy.TP = B.mA.Bdy.TP}]</desc>
-<a>
-MULTIPOLYGON(
-(110 110, 70 200, 150 200, 110 110),
-(110 110, 100 180, 120 180, 110 110)),
-(110 110, 150 20, 70 20, 110 110),
-(110 110, 120 40, 100 40, 110 110)))
-</a>
-<b>
-MULTIPOLYGON(
-(110 110, 160 160, 210 110, 160 60, 110 110),
-(110 110, 160 130, 160 90, 110 110)),
-(110 110, 60 60, 10 110, 60 160, 110 110),
-(110 110, 60 90, 60 130, 110 110)))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mAh/mAh-3-2: MultiPolygon touching MultiPolygon [dim(1){A.mA.Bdy.NV-EP = B.mA.Bdy.V-SP}, dim(1){A.mA.Bdy.SP-NV = B.mA.Bdy.EP-V}]</desc>
-<a>
-MULTIPOLYGON(
-(110 110, 70 200, 200 200, 110 110),
-(110 110, 200 20, 70 20, 110 110),
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mAh/mAh-3-3: MultiPolygon touching MultiPolygon [dim(1){A.mA.Bdy.SP-NV = B.mA.Bdy.EP-V}, dim(1){A.mA.Bdy.NV-EP = B.mA.Bdy.V-SP}, dim(1){A.mA.Bdy.NV-EP = B.mA.Bdy.V-SP}, dim(1){A.mA.Bdy.SP-NV = B.mA.Bdy.EP-V}]</desc>
-<a>
-MULTIPOLYGON(
-(110 110, 20 200, 200 200, 110 110),
-(110 110, 200 20, 20 20, 110 110),
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mAh/mAh-6-1: MultiPolygon touching MultiPolygon [dim(2){A.mA.Int = B.mA.Int}]</desc>
-<a>
-MULTIPOLYGON(
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mAh/mAh-6-2: MultiPolygon touching MultiPolygon [dim(2){A.mA.Int = B.mA.Int}]</desc>
-<a>
-MULTIPOLYGON(
-</a>
-<b>
-MULTIPOLYGON(
-(110 110, 70 200, 210 110, 70 20, 110 110),
-(110 110, 110 140, 150 110, 110 80, 110 110)),
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>AC A-shells overlapping B-shell at A-vertex</desc>
-<a>
-POLYGON(
-(100 60, 140 100, 100 140, 60 100, 100 60))
-</a>
-<b>
-MULTIPOLYGON(
-(80 40, 120 40, 120 80, 80 80, 80 40)),
-(120 80, 160 80, 160 120, 120 120, 120 80)),
-(80 120, 120 120, 120 160, 80 160, 80 120)),
-(40 80, 80 80, 80 120, 40 120, 40 80)))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A-3-1: a line touching the closing point of a polygon [dim(0){A.L.Bdy.SP = B.oBdy.CP}]</desc>
-<a>
-LINESTRING(150 150, 40 230)
-</a>
-<b>
-POLYGON(
-(150 150, 410 150, 280 20, 20 20, 150 150))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF1F00212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-3-2: the start and end points of a LineString touching the boundary (at non-vertices) of a polygon [dim(0){A.L.Bdy.SP = B.oBdy.NV}, dim(0){A.L.Bdy.EP = B.oBdy.NV}]</desc>
-<a>
-LINESTRING(40 40, 50 130, 130 130)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF1F0F212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-3-3: the end point of a line touching the closing point of a polygon [dim(0){A.L.Bdy.EP = B.oBdy.CP}]</desc>
-<a>
-LINESTRING(40 230, 150 150)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A-3-4: an entire LineString touching the boundary (at non-vertices) of a polygon [dim(1){A.L.Int.SP-EP = B.oBdy.NV-NV}]</desc>
-<a>
-LINESTRING(210 150, 330 150)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F1FF0F212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-3-5: the start portion of a LineString touching the boundary (at non-vertices) of a polygon [dim(1){A.L.Int.SP-V = B.oBdy.NV-NV}]</desc>
-<a>
-LINESTRING(200 150, 310 150, 360 220)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F11F00212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-3-6: the start portion and the end point of a LineString touching the boundary of a polygon [dim(1){A.L.Int.SP-V = B.oBdy.NV-NV}, dim(0){A.L.Bdy.EP = B.A.oBdy.V}]</desc>
-<a>
-LINESTRING(180 150, 250 150, 230 250, 370 250, 410 150)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F11F0F212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-3-7: the middle portion of a LineString touching the boundary (at non-vertices) of a polygon [dim(1){A.L.Int.V-V = B.oBdy.NV-NV}]</desc>
-<a>
-LINESTRING(210 210, 220 150, 320 150, 370 210)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F11FF0212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-4-1: a line at non-vertex crossing non-vertex boundary of polygon [dim(0){A.L.Int.NV = B.A.oBdy.NV}, dim(1){A.L.Int.NV-EP = B.A.Int}]</desc>
-<a>
-LINESTRING(20 60, 150 60)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1010F0212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-4-2: a line at non-vertex crossing non-vertex boundaries of polygon twice [dim(0){A.L.Int.NV = B.A.oBdy.NV}, dim(1){A.L.Int.NV-NV = B.A.Int}]</desc>
-<a>
-LINESTRING(60 90, 310 180)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="101FF0212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-4-3: a line at non-vertex crossing vertex boundary of polygon [dim(0){A.L.Int.NV = B.A.oBdy.V}, dim(1){A.L.Int.NV-EP = B.A.Int}]</desc>
-<a>
-LINESTRING(90 210, 210 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A-4-4: a line at non-vertex crossing vertex boundaries of polygon twice [dim(0){A.L.Int.NV = B.A.oBdy.V}, dim(1){A.L.Int.NV-NV = B.A.Int}, dim(0){A.L.Int.NV = B.A.oBdy.CP}]</desc>
-<a>
-LINESTRING(290 10, 130 170)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A-4-5: a line at vertex crossing non-vertex boundary of polygon [dim(0){A.L.Int.V = B.A.oBdy.NV}, dim(1){A.L.Int.V-EP = B.A.Int}]</desc>
-<a>
-LINESTRING(30 100, 100 100, 180 100)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A-4-6: a line at vertex crossing non-vertex boundaries of polygon twice [dim(0){A.L.Int.V = B.A.oBdy.NV}, dim(1){A.L.Int.V-V = B.A.Int}]</desc>
-<a>
-LINESTRING(20 100, 100 100, 360 100, 410 100)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A-4-7: a line at vertex crossing vertex boundary of polygon [dim(0){A.L.Int.V = B.A.oBdy.V}, dim(1){A.L.Int.V-EP = B.A.Int}]</desc>
-<a>
-LINESTRING(90 210, 150 150, 210 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A-5-1: an entire line within a polygon [dim(1){A.L.Int.SP-EP = B.A.Int}]</desc>
-<a>
-LINESTRING(180 90, 280 120)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1FF0FF212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-5-2: a line within a polygon but the line's both ends touching the boundary of the polygon [dim(1){A.L.Int.SP-EP = B.A.Int}, dim(0){A.L.Bdy.SP = B.oBdy.NV}, dim(0){A.L.Bdy.EP = B.oBdy.NV}]</desc>
-<a>
-LINESTRING(70 70, 80 20)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1FFF0F212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-5-3: a line within a polygon but the line's start point touching the boundary of the polygon [dim(1){A.L.Int.SP-EP = B.A.Int}, dim(0){A.L.Bdy.SP = B.oBdy.NV}]</desc>
-<a>
-LINESTRING(130 20, 150 60)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1FF00F212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-5-4: a line within a polygon but the line's start point and middle portion touching the boundary of the polygon [dim(1){A.L.Int.SP-V = B.A.Int}, dim(1){A.L.Int.V-V = B.oBdy.NV-NV}, dim(1){A.L.Int.V-EP = B.A.Int}, dim(0){A.L.Bdy.SP = B.A.oBdy.NV}]</desc>
-<a>
-LINESTRING(70 70, 80 20, 140 20, 150 60)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="11F00F212">true</op>
-</test>
-</case>
-<case>
-<desc>L/A-5-5: a line within a polygon but the line's middle portion touching the boundary of the polygon [dim(1){A.L.Int.SP-V = B.A.Int}, dim(1){A.L.Int.V-V = B.A.oBdy.NV-NV}, dim(1){A.L.Int.V-EP = B.A.Int}]</desc>
-<a>
-LINESTRING(170 50, 170 20, 240 20, 260 60)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="11F0FF212">true</op>
-</test>
-</case>
-<case>
-<desc>L/Ah-2-1: a line outside a polygon [dim(1){A.L.Int.SP-EP = B.A.Ext}]</desc>
-<a>
-LINESTRING(50 100, 140 190, 280 190)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF1FF0212">true</op>
-</test>
-</case>
-<case>
-<desc>L/Ah-2-2: a line inside a polygon's hole [dim(1){A.L.Int.SP-EP = B.A.Ext.h}]</desc>
-<a>
-LINESTRING(140 60, 180 100, 290 100)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-1: the start point of a line touching the inner boundary of a polygon [dim(0){A.L.Bdy.SP = B.A.iBdy.CP}, dim(1){A.L.Int.SP-EP = B.A.Ext.h}]</desc>
-<a>
-LINESTRING(170 120, 210 80, 270 80)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-2: both ends of a line touching the inner boundary of a polygon [dim(0){A.L.Bdy.SP = B.A.iBdy.CP}, dim(1){A.L.Int.SP-EP = B.A.Ext.h}, dim(0){A.L.Bdy.SP = B.A.iBdy.CP}]</desc>
-<a>
-LINESTRING(170 120, 260 50)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-1: both ends of a line touching the inner boundary of a polygon [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
-<a>
-LINESTRING(190 90, 190 270)
-</a>
-<b>
-POLYGON(
-(190 190, 360 20, 20 20, 190 190),
-(190 190, 280 50, 100 50, 190 190))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F01FF0212">true</op>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-2: a line at a non-vertex crossing the boundary of a polygon where the closing point of the hole touches the shell at a non-vertex [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
-<a>
-LINESTRING(60 160, 150 70)
-</a>
-<b>
-POLYGON(
-(110 110, 250 100, 140 30, 110 110))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-3: a line at a non-vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a non-vertex [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
-<a>
-</a>
-<b>
-POLYGON(
-(190 190, 20 20, 360 20, 190 190),
-(250 100, 110 110, 140 30, 250 100))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-4: a line at a non-vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a vertex [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
-<a>
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-5: a line crossing polygon boundary where the closing point of the hole touches the shell at a vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
-<a>
-LINESTRING(190 90, 190 190, 190 270)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-6: a line at a vertex crossing the boundary of a polygon where closing point of the hole touches the shell at a non-vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
-<a>
-LINESTRING(60 160, 110 110, 150 70)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-7: a line at a vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a non-vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
-<a>
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/Ah-3-8: a line at a non-vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
-<a>
-</a>
-<b>
-POLYGON(
-(190 190, 110 110, 20 20, 360 20, 190 190),
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A2h-3-1: the start point a line touching the closing points of two connected holes in a polygon [dim(0){A.L.Int.SP = B.A.iBdy.TP}]</desc>
-<a>
-LINESTRING(130 110, 180 110, 190 60)
-</a>
-<b>
-POLYGON(
-(20 200, 240 200, 240 20, 20 20, 20 200),
-(130 110, 60 180, 60 40, 130 110),
-(130 110, 200 40, 200 180, 130 110))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A2h-3-2: the interior (at a non-vertex) of a line touching the closing points of two connected holes in a polygon [dim(0){A.L.Int.NV = B.A.iBdy.TP}]</desc>
-<a>
-LINESTRING(80 110, 180 110)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A2h-3-3: the interior (at a non-vertex) of a line touching the closing point and at a vertex of two connected holes in a polygon [dim(0){A.L.Int.NV = B.A.iBdy1.TP}]</desc>
-<a>
-</a>
-<b>
-POLYGON(
-(20 200, 20 20, 240 20, 240 200, 20 200),
-(60 180, 130 110, 60 40, 60 180),
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A2h-3-4: the interior (at a non-vertex) of a line touching the closing point and at a non-vertex of two connected holes in a polygon [dim(0){A.L.Int.NV = B.A.iBdy.TP}]</desc>
-<a>
-LINESTRING(80 110, 170 110)
-</a>
-<b>
-POLYGON(
-(130 110, 60 40, 60 180, 130 110),
-(130 180, 130 40, 200 110, 130 180))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A2h-3-5: the start point a line touching the closing point and a non-vertex of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy.TP}]</desc>
-<a>
-LINESTRING(80 110, 130 110, 170 110)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A2h-3-6: the interior (at a vertex) of a line touching the closing points of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy.TP}]</desc>
-<a>
-LINESTRING(80 110, 130 110, 180 110)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A2h-3-7: the interior (at a vertex) of a line touching the closing point and at a vertex of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy1.TP}]</desc>
-<a>
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/A2h-3-8: the interior (at a vertex) of a line touching the closing point and at a non-vertex of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy.TP}]</desc>
-<a>
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/mA-4-1: a line intersecting the interior and exterior of MultiPolygon [dim(1){A.L.Int.SP-NV = B.2A1.Int}, dim (1){A.L.Int.NV-EP = B.2A2.Int}]</desc>
-<a>
-LINESTRING(160 70, 320 230)
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1010FF212">true</op>
-</test>
-</case>
-<case>
-<desc>L/mA-4-2: a line intersecting the interior and exterior of MultiPolygon [dim(1){A.L.Int.SP-V = B.2A1.Int}, dim (1){A.L.Int.V-EP = B.2A2.Int}]</desc>
-<a>
-LINESTRING(160 70, 200 110, 280 190, 320 230)
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/mA-5-1: a line within two connected polygons [dim(1){A.L.Int = B.2A.Int}, dim(0){A.L.Int.NV = B.2A.Bdy.TP]</desc>
-<a>
-LINESTRING(70 50, 70 150)
-</a>
-<b>
-MULTIPOLYGON(
-(0 0, 0 100, 140 100, 140 0, 0 0)),
-(20 170, 70 100, 130 170, 20 170)))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="10F0FF212">true</op>
-</test>
-</case>
-<case>
-<desc>RL/A-3-1: a LinearRing touching a polygon's closing point [dim(0){A.RL.Int.CP = B.A.Bdy.CP}]</desc>
-<a>
-LINESTRING(110 110, 20 200, 200 200, 110 110)
-</a>
-<b>
-POLYGON(
-(20 20, 200 20, 110 110, 20 20))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F01FFF212">true</op>
-</test>
-</case>
-<case>
-<desc>RL/A-3-2: a LinearRing touching a polygon's boundary at a non-vertex [dim(0){A.RL.Int.CP = B.A.Bdy.NV}]</desc>
-<a>
-LINESTRING(150 70, 160 110, 200 60, 150 70)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>RL/A-3-3: a LinearRing touching a polygon's boundary at a non-vertex [dim(0){A.RL.Int.CP = B.A.iBdy.NV}]</desc>
-<a>
-LINESTRING(80 60, 120 40, 120 70, 80 60)
-</a>
-<b>
-POLYGON(
-(110 90, 50 30, 170 30, 110 90))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>RL/A-3-4: a LinearRing on the boundary of a polygon [dim(1){A.RL.Int.SP-EP = B.A.Bdy.SP-EP}]</desc>
-<a>
-LINESTRING(20 20, 200 20, 110 110, 20 20)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F1FFFF2F2">true</op>
-</test>
-</case>
-<case>
-<desc>RL/A-3-5: a LinearRing on the inner boundary of a polygon [dim(1){A.RL.Int.SP-EP = B.A.iBdy.SP-EP}]</desc>
-<a>
-LINESTRING(110 90, 170 30, 50 30, 110 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F1FFFF212">true</op>
-</test>
-</case>
-<case>
-<desc>RL/A-3-6: a LinearRing on the inner boundary of a polygon [dim(1){A.RL.Int.SP-V = B.A.oBdy.SP-NV}]</desc>
-<a>
-LINESTRING(110 110, 170 50, 170 110, 110 110)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F11FFF212">true</op>
-</test>
-</case>
-<case>
-<desc>RL/A-3-7: a LinearRing on the inner boundary of a polygon [dim(1){A.RL.Int.SP-V = B.A.iBdy.SP-NV}]</desc>
-<a>
-LINESTRING(110 90, 70 50, 130 50, 110 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>RL/A-4-1: a LinearRing crossing a polygon [dim(1){A.RL.Int.CP-NV = B.A.Int}, dim(0){A.L.Int.NV = B.A.Bdy.NV}]</desc>
-<a>
-LINESTRING(110 60, 20 150, 200 150, 110 60)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="101FFF212">true</op>
-</test>
-</case>
-<case>
-<desc>RL/A-4-2: a LinearRing crossing a polygon with a hole [dim(1){A.RL.Int.NV-NV = B.A.Int}, dim(0){A.RL.Int.NV = B.A.oBdy.CP}, dim(0){A.RL.Int.NV = B.A.iBdy.CP}, dim(0){A.RL.Int.NV = B.A.oBdy.NV}, dim(0){A.RL.Int.NV = B.A.iBdy.NV}]</desc>
-<a>
-LINESTRING(110 130, 110 70, 200 100, 110 130)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>RL/A-5-1: a LinearRing within a polygon [dim(1){A.RL.Int.SP-EP = B.A.Int}]</desc>
-<a>
-LINESTRING(110 90, 160 40, 60 40, 110 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1FFFFF212">true</op>
-</test>
-</case>
-<case>
-<desc>RL/A-5-2: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}]</desc>
-<a>
-LINESTRING(110 100, 40 30, 180 30, 110 100)
-</a>
-<b>
-POLYGON(
-(110 90, 60 40, 160 40, 110 90))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>RL/A-5-3: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}, dim(0){A.L.Int.CP = B.A.oBdy.CP}]</desc>
-<a>
-LINESTRING(110 110, 180 30, 40 30, 110 110)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="10FFFF212">true</op>
-</test>
-</case>
-<case>
-<desc>RL/A-5-4: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}, dim(0){A.RL.Int.CP = B.A.iBdy.CP}]</desc>
-<a>
-LINESTRING(110 90, 180 30, 40 30, 110 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>RL/A-5-5: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}, dim(1){A.RL.Int.SP-NV = B.A.Bdy.iBdy.SP-V}]</desc>
-<a>
-LINESTRING(110 90, 50 30, 180 30, 110 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="11FFFF212">true</op>
-</test>
-</case>
-<case>
-<desc>nsL/A-3-1: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SP = B.A.Bdy.CP}]</desc>
-<a>
-LINESTRING(110 110, 200 200, 200 110, 110 200)
-</a>
-<b>
-POLYGON(
-(110 110, 200 20, 20 20, 110 110))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/A-3-2: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SPb = B.A.Bdy.CP}]</desc>
-<a>
-LINESTRING(110 110, 200 200, 110 110, 20 200, 20 110, 200 110)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/A-3-3: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SPo = B.A.Bdy.CP}]</desc>
-<a>
-LINESTRING(110 110, 20 110, 200 110, 50 110, 110 170)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/A-3-4: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SPx = B.A.Bdy.CP}]</desc>
-<a>
-LINESTRING(110 110, 20 200, 110 200, 110 110, 200 200)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/A-3-5: a non-simple LineString touching a polygon [dim(1){A.nsL.Int.SPb-Vo = B.A.Bdy.SP-NV}]</desc>
-<a>
-LINESTRING(110 110, 170 50, 20 200, 20 110, 200 110)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/A-4-1: a non-simple LineString crossing a polygon [dim(1){A.nsL.Int.V-V-NV = B.A.Int}, dim(1){A.nsL.SPx-V = B.A.Bdy.SP-NV}]</desc>
-<a>
-LINESTRING(110 110, 180 40, 110 40, 110 180)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="111F00212">true</op>
-</test>
-</case>
-<case>
-<desc>nsL/A-5-1: a non-simple LineString within a polygon [dim(1){A.nsL.Int.SPx-EP = B.A.Int}]</desc>
-<a>
-LINESTRING(110 60, 50 30, 170 30, 90 70)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/A-5-2: a non-simple LineString within a polygon [dim(1){A.nsL.Int.SPx-EP = B.A.Int}, dim(1){A.nsL.Int.SPx-V = B.A.Bdy.SP-NV}]</desc>
-<a>
-LINESTRING(110 110, 180 40, 110 40, 110 110, 70 40)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/Ah: the self-crossing point of a non-simple LineString touching the closing point of the inner boundary of a polygon [dim(0){A.nsL.Int.V = B.A.iBdy.CP}]</desc>
-<a>
-LINESTRING(230 70, 170 120, 190 60, 140 60, 170 120, 270 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/A-3-1: MultiLineString touching a polygon's closing point [dim(0){A.mL.Bdy.SPb = B.A.Bdy.CP}]</desc>
-<a>
-MULTILINESTRING(
-(20 110, 200 110),
-(200 200, 110 110, 20 210, 110 110))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/A-3-2: MultiLineString touching a polygon's closing point [dim(0){A.mL.Bdy.SPo = B.A.Bdy.CP}]</desc>
-<a>
-MULTILINESTRING(
-(20 110, 200 110),
-(60 180, 60 110, 160 110, 110 110))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/A-3-3: MultiLineString touching a polygon's closing point [dim(0){A.mL.Bdy.SPx = B.A.Bdy.CP}]</desc>
-<a>
-MULTILINESTRING(
-(20 110, 200 110),
-(200 200, 110 110, 20 200, 110 200, 110 110))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/A-4-1: MultiLineString crossing a polygon [dim(1){A.mL.Int.SP-NVb = B.A.Int}, dim(0){A.mL.Int.NVb = B.A.Bdy.CP}]</desc>
-<a>
-MULTILINESTRING(
-(20 110, 200 110),
-(110 50, 110 170, 110 70, 110 150, 200 150))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/A-4-2: MultiLineString crossing a polygon [dim(1){A.mL.Int.SP-NVo = B.A.Int}, dim(0){A.mL.Int.NVo = B.A.Bdy.CP}]</desc>
-<a>
-MULTILINESTRING(
-(20 110, 200 110),
-(50 110, 170 110, 110 170, 110 50, 110 170, 110 50))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/A-4-3: MultiLineString crossing a polygon [dim(1){A.mL.Int.SP-NVx = B.A.Int}, dim(0){A.mL.Int.NVx = B.A.Bdy.CP}]</desc>
-<a>
-MULTILINESTRING(
-(20 110, 200 110),
-(110 60, 110 160, 200 160))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/A-4-4: MultiLineString crossing a polygon [dim(1){A.mL.Int.Vb-Vb = B.A.Int}, dim(0){A.mL.Int.Vb = B.A.oBdy.CP}, dim(0){A.mL.Int.Vb = B.A.iBdy.CP}]</desc>
-<a>
-MULTILINESTRING(
-(20 110, 200 110),
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/A-5-1: MultiLineString within a polygon [dim(1){A.mL.Int.SP-EP = B.A.Int}]</desc>
-<a>
-MULTILINESTRING(
-(110 100, 40 30, 180 30),
-(170 30, 110 90, 50 30))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/A-5-2: MultiLineString within a polygon [dim(1){A.mL.Int.SP-EP = B.A.Int}]</desc>
-<a>
-MULTILINESTRING(
-(110 110, 60 40, 70 20, 150 20, 170 40),
-(180 30, 40 30, 110 80))
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mA-3-1: MultiLineString within a MultiPolygon [dim(0){A.mL.Bdy.SPb = B.mA.Bdy.TP}]</desc>
-<a>
-MULTILINESTRING(
-(20 110, 200 110, 200 160),
-(110 110, 200 110, 200 70, 20 150))
-</a>
-<b>
-MULTIPOLYGON(
-(110 110, 20 20, 200 20, 110 110)),
-(110 110, 20 200, 200 200, 110 110)))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mA-3-2: MultiLineString within a MultiPolygon [dim(0){A.mL.Bdy.SPo = B.mA.Bdy.TP}]</desc>
-<a>
-MULTILINESTRING(
-(20 160, 70 110, 150 110, 200 160),
-(110 110, 20 110, 50 80, 70 110, 200 110))
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mA-3-3: MultiLineString within a MultiPolygon [dim(0){A.mL.Bdy.SPx = B.mA.Bdy.TP}]</desc>
-<a>
-MULTILINESTRING(
-(20 110, 200 110),
-(110 110, 20 170, 20 130, 200 90))
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LC - topographically equal with no boundary</desc>
-<a>
-LINESTRING(0 0, 0 50, 50 50, 50 0, 0 0)
-</a>
-<b>
-MULTILINESTRING(
-(0 0, 0 50),
-(0 50, 50 50),
-(50 50, 50 0),
-(50 0, 0 0))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1FFFFFFF2">true</op>
-</test>
-</case>
-<case>
-<desc>LC - intersection (containment) along mod-2 A-Int line segment</desc>
-<a>
-LINESTRING(40 180, 140 180)
-</a>
-<b>
-MULTIPOLYGON(
-(20 320, 180 320, 180 180, 20 180, 20 320)),
-(20 180, 20 80, 180 80, 180 180, 20 180)))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LC - intersection (overlap) along mod-2 A-Int line segment</desc>
-<a>
-</a>
-<b>
-MULTIPOLYGON(
-(60 180, 60 80, 180 80, 180 180, 60 180)))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LC - equal with boundary intersection</desc>
-<a>
-LINESTRING(0 0, 60 0, 60 60, 60 0, 120 0)
-</a>
-<b>
-MULTILINESTRING(
-(0 0, 60 0),
-(60 0, 120 0),
-(60 0, 60 60))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="10FF0FFF2">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.1-3-1: touching at the start points of two lines [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}]</desc>
-<a>
-LINESTRING(40 40, 120 120)
-</a>
-<b>
-LINESTRING(40 40, 60 120)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF1F00102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.1-3-2: start point of one line touching end point of another line [dim(0){A.L.Bdy.SP = B.L.Bdy.EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(60 240, 40 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.1-3-3: start point of a line touching the interior of another line at a non-vertex [dim(0){A.L.Bdy.SP = B.L.Int.NV}]</desc>
-<a>
-LINESTRING(40 40, 180 180)
-</a>
-<b>
-LINESTRING(120 120, 20 200)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F01FF0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.1-3-4: touching at the end points of two lines [dim(0){A.L.Bdy.EP = B.L.Bdy.EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(60 240, 120 120)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.1-3-5: end point of a line touching the interior of another line at a non-vertex [dim(0){A.L.Bdy.EP = B.L.Int.NV}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(20 180, 140 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.1-4-1: two lines crossing at non-vertex [dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(40 120, 120 40)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F1FF0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.1-1-1: equal pointwise [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
-<a>
-LINESTRING(40 40, 100 100)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1FFF0FFF2">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.1-1-2: equal lines but points in reverse sequence [dim(1){A.L.Int.SP-EP = B.L.Int.EP-SP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(100 100, 40 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.1-2-1: dim(1){A.L.Int.SP-EP = B.L.Ext}</desc>
-<a>
-</a>
-<b>
-LINESTRING(40 120, 120 160)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF1FF0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.1-5-1: line A containing line B [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
-<a>
-LINESTRING(20 20, 180 180)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.1-5-2: line B is part of line A [dim(1){A.L.Int.SP-NV) = B.L.Int.SP-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(20 20, 110 110)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="101F00FF2">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.1-5-3: Line B is part of line A (in the middle portion) [dim(1){A.L.Int.NV-NV = B.L.Int.SP-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(50 50, 140 140)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="101FF0FF2">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.1-6-1: start portions of two lines overlapping [dim(1){A.L.Int.SP-NV = B.L.Int.SP-NV]</desc>
-<a>
-LINESTRING(180 180, 40 40)
-</a>
-<b>
-LINESTRING(120 120, 260 260)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1010F0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.1-6-2: end portions of two lines overlapping [dim(1){A.L.Int.NV-EP = B.L.Int.NV-EP]</desc>
-<a>
-</a>
-<b>
-LINESTRING(260 260, 120 120)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.1-6-3: end portion of line A overlapping the start portion of line B [dim(1){A.L.Int.NV-EP = B.L.Int.SP-NV]</desc>
-<a>
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-1: two LineStrings touching at start points [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}]</desc>
-<a>
-LINESTRING(40 40, 100 100, 200 120, 80 240)
-</a>
-<b>
-LINESTRING(40 40, 20 100, 40 160, 20 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-2: start point of LineStrings A touching the end point of LineString B [dim(0){A.L.Bdy.SP = B.L.Bdy.EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(20 200, 40 160, 20 100, 40 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-3: two LineStrings touching at end points [dim(0){A.L.Bdy.EP = B.L.Bdy.EP}]</desc>
-<a>
-LINESTRING(80 240, 200 120, 100 100, 40 40)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-4: both the start and end points of LineString A touching the interior of LineString B at two vertices [dim(0){A.L.Bdy.SP = B.L.Int.V}, dim(0){A.L.Bdy.EP = B.L.Int.V}]</desc>
-<a>
-LINESTRING(60 60, 60 230, 140 230, 250 160)
-</a>
-<b>
-LINESTRING(20 20, 60 60, 250 160, 310 230)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF10FF102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-5: both the start and end points of LineString A touching the interior of LineString B at two non-vertices [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Bdy.EP = B.L.Int.NV}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(20 20, 110 110, 200 110, 320 230)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-6: the start and end points of two LineStrings touching each other [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}, dim(0){A.L.Bdy.EP = B.L.Bdy.EP}]</desc>
-<a>
-LINESTRING(60 110, 60 250, 360 210)
-</a>
-<b>
-LINESTRING(60 110, 110 160, 250 160, 310 160, 360 210)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF1F0F1F2">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-7: the start and end points of two LineStrings touching each other [dim(0){A.L.Bdy.SP = B.L.Bdy.EP}, dim(0){A.L.Bdy.EP = B.L.Bdy.SP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(360 210, 310 160, 110 160, 60 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-8: start point of LineString B touching LineString A at a non-vertex [dim(0){A.L.Int.NV = B.L.Bdy.SP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(160 160, 240 240)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-9: end point of LineString B touching LineString A at a non-vertex [dim(0){A.L.Int.NV = B.L.Bdy.EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(240 240, 160 160)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-10: both the start and end points of LineString B touching the interior of LineString A at two non-vertices [dim(0){A.L.Int.NV = B.L.Bdy.SP}, dim(0){A.L.Int.NV = B.L.Bdy.EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(60 150, 110 100, 170 100, 110 230)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F01FF01F2">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-11: the start point of LineString B touching the interior of LineString A at a non-vertex and the end point of LineString A touching the interior of LineString B at a vertex [dim(0){A.L.Int.NV = B.L.Bdy.SP}, dim(0){A.L.Bdy.EP = B.L.Int.V}]</desc>
-<a>
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F010F0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-12: start point of LineString B touching LineString A at a vertex [dim(0){A.L.Int.V = B.L.Bdy.SP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(200 120, 200 190, 150 240, 200 240)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-13: end point of LineString B touching LineString A at a vertex [dim(0){A.L.Int.V = B.L.Bdy.EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(200 240, 150 240, 200 200, 200 120)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-3-14: both the start and end points of LineString B touching the interior of LineString A at two vertices [dim(0){A.L.Int.V = B.L.Bdy.SP}, dim(0){A.L.Int.V = B.L.Bdy.EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(60 230, 80 140, 120 140, 140 230)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-1: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
-<a>
-LINESTRING(60 110, 200 110, 250 160, 300 210)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F1F00102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-2: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.SP}, dim(0){A.L.Int.V = B.L.Int.V}, dim(0){A.L.Bdy.EP = B.L.Int.EP}]</desc>
-<a>
-LINESTRING(60 110, 200 110, 250 160, 300 210, 360 210)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F1F0F1F2">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-3: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
-<a>
-LINESTRING(60 110, 220 110, 250 160, 280 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-4: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Int.SP}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Bdy.EP = B.L.Int.EP}]</desc>
-<a>
-LINESTRING(60 110, 150 110, 200 160, 250 110, 360 110, 360 210)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-5: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
-<a>
-LINESTRING(130 160, 160 110, 220 110, 250 160, 250 210)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F10F0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-6: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
-<a>
-LINESTRING(130 160, 160 110, 190 110, 230 210)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-7: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Bdy.SP = B.L.Bdy.EP}]</desc>
-<a>
-LINESTRING(130 160, 160 110, 200 110, 230 160, 260 210, 360 210)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F100F102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-8: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Bdy.EP}]</desc>
-<a>
-LINESTRING(130 160, 160 110, 200 110, 230 160, 260 210, 360 210, 380 210)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0010F0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-9: two LineStrings crossing at three points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Int.NV = B.L.Bdy.EP}]</desc>
-<a>
-LINESTRING(130 160, 160 110, 200 110, 230 160, 260 210, 380 210)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-10: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.V}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
-<a>
-LINESTRING(110 160, 160 110, 200 110, 250 160, 250 210)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-11: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Int.V}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
-<a>
-LINESTRING(110 160, 180 110, 250 160, 320 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-12: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}]</desc>
-<a>
-LINESTRING(140 160, 180 80, 220 160, 250 80)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-13: two LineStrings crossing at a vertex for one of the LineStrings [dim(0){A.L.Int.V = B.L.Int.NV}]</desc>
-<a>
-LINESTRING(40 40, 100 100, 200 120, 130 190)
-</a>
-<b>
-LINESTRING(20 130, 70 130, 160 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-14: two LineStrings crossing at non-vertices for both of the LineStrings [dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(40 160, 40 100, 110 40, 170 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-15: two LineStrings crossing on one side [dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}]</desc>
-<a>
-LINESTRING(130 110, 180 160, 230 110, 280 160, 330 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-16: two LineStrings crossing at vertices for both LineString [dim(0){A.L.Int.V = B.L.Int.V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(30 140, 80 140, 100 100, 200 30)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-17: two LineStrings crossing on one side [dim(0){A.L.Int.V = B.L.Int.V}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
-<a>
-LINESTRING(110 110, 110 160, 180 110, 250 160, 250 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-18: multiple crossings [dim(0){A.L.Int.V = B.L.Int.V}, dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
-<a>
-LINESTRING(20 20, 80 80, 160 80, 240 80, 300 140)
-</a>
-<b>
-LINESTRING(20 60, 60 60, 60 140, 80 80, 100 20, 140 140, 180 20, 200 80, 220 20,
-240 80, 300 80, 270 110, 200 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-4-19: spiky LineStrings with multiple crossing [dim(0){A.L.Int.V = B.L.Int.V}]</desc>
-<a>
-LINESTRING(20 20, 230 20, 20 30, 170 30, 20 40, 230 40, 20 50, 230 60, 60 60,
-230 70, 20 70, 180 80, 60 80, 230 90, 20 90, 230 100, 30 100, 210 110, 20 110,
-80 120, 20 130, 170 130, 90 120, 230 130, 170 140, 230 140, 80 150, 160 140, 20 140,
-70 150, 20 150, 230 160, 80 160, 230 170, 20 160, 180 170, 20 170, 230 180, 20 180,
-40 190, 230 190, 20 200, 230 200)
-</a>
-<b>
-LINESTRING(30 210, 30 60, 40 210, 40 30, 50 190, 50 20, 60 160, 60 50, 70 220,
-70 50, 80 20, 80 210, 90 50, 90 150, 100 30, 100 210, 110 20, 110 190, 120 50,
-120 180, 130 210, 120 20, 140 210, 130 50, 150 210, 130 20, 160 210, 140 30, 170 210,
-150 20, 180 210, 160 20, 190 210, 180 80, 170 50, 170 20, 180 70, 180 20, 190 190,
-190 30, 200 210, 200 30, 210 210, 210 20, 220 150, 220 20)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="001FF0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-1-1: two equal LineStrings with equal pointwise [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
-<a>
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-1-2: two equal LineStrings with points in reverse sequence [dim(1){A.L.Int.SP-EP = B.L.Int.EP-SP}]</desc>
-<a>
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-1-3: two equal LineStrings with different number of points [dim(1){A.L.Int.SP-EP = B.L.Int.EP-SP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(80 240, 120 200, 200 120, 100 100, 80 80, 40 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-2-1: disjoint [dim(1){A.L.Int.SP-EP = B.L.Ext}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(260 210, 240 130, 280 120, 260 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-2-2: wrapping around but still disjoint [dim(1){A.L.Int.SP-EP = B.L.Ext}]</desc>
-<a>
-LINESTRING(100 20, 20 20, 20 160, 210 160, 210 20, 110 20, 50 120, 120 150, 200 150)
-</a>
-<b>
-LINESTRING(140 130, 100 110, 120 60, 170 60)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-5-1: LineString A containing LineString B, same pointwise [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
-<a>
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-5-2: LineString A containing LineString B, LineString A with less points [dim(1){A.L.Int.SP-V = B.L.Int.SP-EP}]</desc>
-<a>
-LINESTRING(60 110, 110 160, 310 160, 360 210)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-5-3: LineString A containing LineString B [dim(1){A.L.Int.SP-V = B.L.Int.SP-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(60 110, 110 160, 250 160)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-5-4: LineString A containing LineString B [dim(1){A.L.Int.NV-NV = B.L.Int.SP-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(110 160, 310 160, 340 190)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-5-5: LineString A containing LineString B [dim(1){A.L.Int.V-NV = B.L.Int.SP-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(140 160, 250 160, 310 160, 340 190)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-5-6: LineString A containing LineString B [dim(1){A.L.Int.V-V = B.L.Int.SP-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(110 160, 250 160, 310 160)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-1: start portions of two LineStrings overlapping [dim(1){A.L.Int.SP-V = B.L.Int.SP-V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(200 120, 100 100, 40 40, 140 80, 200 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-2: start portion of LineString A overlapping end portion of LineString B, intersecting at the middle of LineString A [dim(1){A.L.Int.SP-V = B.L.Int.V-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(280 240, 240 140, 200 120, 100 100, 40 40)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1F1F00102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-3: start portion of LineString A overlapping end portion of LineString B, intersecting at the middle of LineString A [dim(1){A.L.Int.SP-V = B.L.Int.NV-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(80 190, 140 140, 40 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-4: end portions of two LineStrings overlapping [dim(1){A.L.Int.NV-EP = B.L.Int.V-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(240 200, 200 260, 80 240, 140 180)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-5: end portion of LineString A overlapping start portion of LineString B [dim(1){A.L.Int.NV-EP = B.L.Int.SP-V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(140 180, 80 240, 200 260, 240 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-6: end portion of LineString A overlapping end portion of LineString B, intersecting at the middle of LineString A [dim(1){A.L.Int.V-EP = B.L.Int.V-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(280 240, 240 140, 200 120, 80 240)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-7: middle portions of two LineStrings overlapping [dim(1){A.L.Int.V-NV = B.L.Int.NV-V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(20 80, 120 80, 200 80, 260 20)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1F1FF0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-8: middle portion of LineString A overlapping start portion of LineString B [dim(1){A.L.Int.V-V = B.L.Int.SP-V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(100 100, 200 120, 240 140, 280 240)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="101FF0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-9: middle portion of LineString A overlapping end portion of LineString B [dim(1){A.L.Int.V-V = B.L.Int.V-EP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(280 240, 240 140, 200 120, 100 100)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-10: middle portions of two LineStrings overlapping [dim(1){A.L.Int.V-V = B.L.Int.V-V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(80 20, 80 80, 240 80, 300 20)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/L.2-6-11: middle portions of two LineStrings overlapping, multiple intersects [dim(1){A.L.Int.V-V = B.L.Int.V-NV}, dim(1){A.L.Int.V-V = B.L.Int.V-NV}, dim(1){A.L.Int.V-V = B.L.Int.V-NV}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(20 80, 80 80, 120 80, 140 140, 160 80, 200 80, 220 20, 240 80, 270 110,
-300 80)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/LR-3-1: a LineString touching a LinearRing [dim(0){A.L.Bdy.SP = B.LR.Int.CP}]</desc>
-<a>
-LINESTRING(100 100, 20 180, 180 180)
-</a>
-<b>
-LINESTRING(100 100, 180 20, 20 20, 100 100)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF10F01F2">true</op>
-</test>
-</case>
-<case>
-<desc>L/LR-4-1: a LineString crossing a LinearRing [dim(0){A.L.Int.NV = B.LR.Int.CP}]</desc>
-<a>
-LINESTRING(20 100, 180 100, 100 180)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F1FF01F2">true</op>
-</test>
-</case>
-<case>
-<desc>L/LR-4-2: a LineString crossing a LinearRing [dim(0){A.L.Int.NV = B.LR.Int.CP}]</desc>
-<a>
-LINESTRING(100 40, 100 160, 180 160)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/LR-4-3: a LineString crossing a LinearRing [dim(0){A.L.Int.V = B.LR.Int.CP}]</desc>
-<a>
-LINESTRING(20 100, 100 100, 180 100, 100 180)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/LR-5-1: a LineString within a LinearRing [dim(1){A.L.Int.SP-EP = B.LR.Int.SP-NV}]</desc>
-<a>
-LINESTRING(100 100, 160 40)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1FF0FF1F2">true</op>
-</test>
-</case>
-<case>
-<desc>L/LR-5-2: a LineString within a LinearRing [dim(1){A.L.Int.SP-EP = B.LR.Int.SP-NV}]</desc>
-<a>
-LINESTRING(100 100, 180 20)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/LR-5-3: a LineString within a LinearRing [dim(1){A.L.Int.SP-V-EP = B.LR.Int.NV-CP-NV}]</desc>
-<a>
-LINESTRING(60 60, 100 100, 140 60)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/LR-6-1: a LineString crossing a LinearRing [dim(1){A.L.Int.SP-NV = B.LR.Int.SP-V}]</desc>
-<a>
-LINESTRING(100 100, 190 10, 190 100)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1F10F01F2">true</op>
-</test>
-</case>
-<case>
-<desc>L/LR-6-2: a LineString crossing a LinearRing [dim(1){A.L.Int.SP-V = B.LR.Int.SP-NV}]</desc>
-<a>
-LINESTRING(100 100, 160 40, 160 100)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/LR-6-3: a LineString crossing a LinearRing [dim(1){A.L.Int.NV-V = B.LR.Int.SP-NV}]</desc>
-<a>
-LINESTRING(60 140, 160 40, 160 140)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1F1FF01F2">true</op>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's end point with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Bdy.EPb}]</desc>
-<a>
-LINESTRING(20 20, 140 140)
-</a>
-<b>
-LINESTRING(80 80, 20 80, 140 80, 80 20, 80 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's end point with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Bdy.EPo}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(80 80, 20 80, 140 80)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's end point with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Bdy.EPx}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(80 80, 140 80, 80 20, 80 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's closing point with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.CPb}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(80 80, 20 80, 140 80, 80 20, 80 80)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's closing point with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.CPo}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(80 80, 20 80, 140 80, 80 80)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's closing point with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Int.CPx}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(80 80, 20 80, 20 140, 140 20, 80 20, 80 80)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex [dim(0){A.L.Int.NV = B.nsL.Int.NV}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(20 140, 140 20, 100 20, 100 80)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.NVb}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(140 80, 20 80, 120 80, 80 20, 80 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.NVo}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(140 80, 20 80, 140 80)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Int.NVx}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(140 80, 20 80, 80 140, 80 20)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex [dim(0){A.L.Int.NV = B.nsL.Int.V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(140 80, 80 80, 20 80, 50 140, 50 60)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.Vb}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(140 80, 20 80, 120 80, 80 20, 80 80, 80 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.Vo}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(140 80, 20 80, 80 80, 140 80)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Int.Vx}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(140 80, 20 80, 80 140, 80 80, 80 20)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL.1-3-1: start point of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Bdy.SP = B.nsL.Bdy.EPx}]</desc>
-<a>
-LINESTRING(130 150, 220 150, 220 240)
-</a>
-<b>
-LINESTRING(130 240, 130 150, 220 20, 50 20, 130 150)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL.1-3-2: the interior of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Int.V = B.nsL.Bdy.EPx}]</desc>
-<a>
-LINESTRING(30 150, 130 150, 250 150)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL.1-3-3: the interior of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Int.NV = B.nsL.Bdy.EPx}]</desc>
-<a>
-LINESTRING(30 150, 250 150)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL.1-3-4: the interior of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Int.V = B.nsL.Bdy.EPx}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(130 240, 130 20, 30 20, 130 150)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL.1-4: a Line crossing a non-simple LineString at non-vertices [dim(0){A.L.Int.NV = B.nsL.Int.NV}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(120 240, 120 20, 20 20, 120 170)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL.5/L-3-1: switching the geometries for case L/nsL.5-3-1 [dim(0){A.nsL.Bdy.EPx = B.L.Bdy.SP}]</desc>
-<a>
-LINESTRING(200 200, 20 20, 200 20, 110 110, 20 200, 110 200, 110 110)
-</a>
-<b>
-LINESTRING(110 110, 200 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL.5-3-2: the start point of a line touching the self-intersecting and self-crossing point of a non-simple LineString [dim(0){A.L.Bdy.SP = B.nsL.Bdy.EPx}]</desc>
-<a>
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL.5-3-3: the interior of a line touching the self-intersecting and self-crossing point of a non-simple LineString [dim(0){A.L.Int.NV = B.nsL.Bdy.EPx}]</desc>
-<a>
-LINESTRING(20 110, 200 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL.5/L-3-4 touches dim(0){A.nsL.Bdy.EPx = B.L.Int.NV}</desc>
-<a>
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF10F0102">true</op>
-</test>
-</case>
-<case>
-<desc>L/nsL.10-6-1: the middle portion of a line overlapping from the self-intersecting to the self-crossing a non-simple LineString [dim(1){A.L.Int.V-V = B.nsL.Int.EPx-NVx}]</desc>
-<a>
-LINESTRING(90 200, 90 130, 110 110, 150 200)
-</a>
-<b>
-LINESTRING(200 200, 20 20, 200 20, 20 200, 20 130, 90 130)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/nsL.10-6-2: the middle portion of a line overlapping from the self-intersecting to the self-crossing a non-simple LineString [dim(1){A.L.Int.V-V = B.nsL.Int.NVx-EPx}]</desc>
-<a>
-LINESTRING(200 110, 110 110, 90 130, 90 200)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>L/mL-3-1: a line's end point touching a non-vertex with crossing line segments of a MultiLineString [dim(0){A.L.Bdy.SP = B.mL.Int.NVx]</desc>
-<a>
-LINESTRING(80 80, 150 80, 210 80)
-</a>
-<b>
-MULTILINESTRING(
-(20 20, 140 140),
-(20 140, 140 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-1-1: two equal LinearRings, pointwise [dim(1){A.LR.Int.SP-EP = B.LR.Int.SP-EP}, dim(0){A.LR.Int.CP = B.LR.Int.CP}]</desc>
-<a>
-LINESTRING(40 80, 160 200, 260 20, 40 80)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-1-2: two equal LinearRings with points in reverse sequence [dim(1){A.LR.Int.SP-EP = B.LR.Int.EP-SP}, dim(0){A.LR.Int.CP = B.LR.Int.CP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(40 80, 260 20, 160 200, 40 80)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-1-3: two equal LinearRings with points in different sequence [dim(1){A.LR.Int.SP-EP = B.LR.Int.SP-EP}, dim(0){A.LR.Int.CP = B.LR.Int.V}, dim(0){A.LR.Int.V = B.LR.Int.CP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(260 20, 40 80, 160 200, 260 20)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-1-4: two equal LinearRings with different number of points [dim(1){A.LR.Int.SP-EP = B.LR.Int.SP-EP}, dim(0){A.LR.Int.CP = B.LR.Int.V}, dim(0){A.LR.Int.NV = B.LR.Int.CP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(100 140, 160 200, 260 20, 40 80, 100 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-4-1: two LinearRings crossing at closing points [dim(0){A.LR.Int.CP = B.LR.Int.CP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(100 100, 180 180, 20 180, 100 100)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F1FFF1F2">true</op>
-</test>
-</case>
-<case>
-<desc>LR/LR-4-2: two LinearRings crossing at two points [dim(0){A.LR.Int.CP = B.LR.Int.CP}, dim(0){A.LR.Int.V = B.LR.Int.V},]</desc>
-<a>
-LINESTRING(40 150, 40 40, 150 40, 150 150, 40 150)
-</a>
-<b>
-LINESTRING(40 150, 150 40, 170 20, 170 190, 40 150)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-4-3: two LinearRings crossing at the closing and a non-vertex [dim(0){A.LR.Int.CP = B.LR.Int.NV}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(180 100, 20 100, 100 180, 180 100)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-4-4: two LinearRings crossing at the closing and a vertex [dim(0){A.LR.Int.CP = B.LR.Int.V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(180 180, 100 100, 20 180, 180 180)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-4-5: two LinearRings crossing at a vertex and a non-vertex [dim(0){A.LR.Int.V = B.LR.Int.NV}]</desc>
-<a>
-LINESTRING(20 180, 100 100, 20 20, 20 180)
-</a>
-<b>
-LINESTRING(100 20, 100 180, 180 100, 100 20)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-4-6: two LinearRings crossing at two points [dim(0){A.LR.Int.V = B.LR.Int.NV}, dim(0){A.LR.Int.V = B.LR.Int.NV},]</desc>
-<a>
-</a>
-<b>
-LINESTRING(170 20, 20 170, 170 170, 170 20)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-6-1: two LinearRings overlapping [dim(1){A.LR.Int.CP-V = B.LR.Int.CP-V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(40 150, 150 150, 90 210, 40 150)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="1F1FFF1F2">true</op>
-</test>
-</case>
-<case>
-<desc>LR/LR-6-2: two LinearRings overlapping [dim(1){A.LR.Int.CP-V = B.LR.Int.NV-NV}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(20 150, 170 150, 90 230, 20 150)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/LR-6-3: two LinearRings overlapping [dim(1){A.LR.Int.(V-V-V-EP) = B.LR.Int.(NV-V-V-SP)}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(40 150, 150 150, 150 40, 20 40, 20 150, 40 150)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/nsL-3-1: a LinearRing touching a non-simple LineString [dim(0){A.nsL.Int.CP = B.nsL.Bdy.SPb}]</desc>
-<a>
-LINESTRING(110 110, 200 20, 20 20, 110 110)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F01FFF102">true</op>
-</test>
-</case>
-<case>
-<desc>LR/nsL-3-1: a LinearRing touching a non-simple LineString [dim(0){A.nsL.Int.CP = B.nsL.Bdy.SPo}]</desc>
-<a>
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/nsL-3-1: a LinearRing touching a non-simple LineString [dim(0){A.nsL.Int.CP = B.nsL.Bdy.SPx}]</desc>
-<a>
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>LR/nsL-6-1: a LinearRing and a non-simple LineString overlapping [dim(1){A.nsL.Int.SP-V = B.nsL.Int.NVx-SP}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(200 20, 20 200, 200 200, 110 110, 110 40)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="101FFF102">true</op>
-</test>
-</case>
-<case>
-<desc>LR/nsL-6-2: a LinearRing and a non-simple LineString overlapping [dim(1){A.nsL.Int.SP-V = B.nsL.Int.NVx-SP}, dim(1){A.nsL.Int.V-EP = B.nsL.Int.EP-NVx}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(200 20, 20 200, 200 200, 20 20)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="101FFF1F2">true</op>
-</test>
-</case>
-<case>
-<desc>nsL/nsL-4-1: non-simple LineStrings crossing at closing points [dim(0){A.nsL.Int.CP = B.nsL.Int.CP}]</desc>
-<a>
-LINESTRING(110 110, 20 110, 110 20, 20 20, 110 110)
-</a>
-<b>
-LINESTRING(110 110, 200 200, 110 200, 200 110, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/nsL-4-2: non-simple LineStrings crossing at two points without vertices [dim(0){A.nsL.Int.NV = B.nsL.Int.NV}]</desc>
-<a>
-LINESTRING(20 120, 120 120, 20 20, 120 20, 20 120)
-</a>
-<b>
-LINESTRING(170 100, 70 100, 170 170, 70 170, 170 100)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/nsL-4-3: non-simple LineStrings crossing at a point [dim(0){A.nsL.Int.NV = B.nsL.Int.V}]</desc>
-<a>
-LINESTRING(20 110, 110 110, 20 20, 110 20, 20 110)
-</a>
-<b>
-LINESTRING(110 160, 70 110, 60 160, 20 130, 110 160)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/nsL-4-4: non-simple LineStrings crossing at self-crossing points [dim(0){A.nsL.Int.NVx = B.nsL.Int.NVx}]</desc>
-<a>
-LINESTRING(20 200, 200 200, 20 20, 200 20, 20 200)
-</a>
-<b>
-LINESTRING(20 110, 200 110, 200 160, 20 60, 20 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/nsL-4-5: non-simple LineStrings crossing at vertices [dim(0){A.nsL.Int.V = B.nsL.Int.V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(200 200, 110 110, 200 110, 110 200, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>nsL/nsL-4-6: non-simple LineStrings crossing at two points with vertices [dim(0){A.nsL.Int.V = B.nsL.Int.V}]</desc>
-<a>
-</a>
-<b>
-LINESTRING(220 120, 120 20, 220 20, 120 120, 220 120)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-1: MultiLineString [dim(1){A.mL.Int.SP-EP = B.mL.Int.SP-EP}]</desc>
-<a>
-MULTILINESTRING(
-(70 20, 20 90, 70 170),
-(70 170, 120 90, 70 20))
-</a>
-<b>
-MULTILINESTRING(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-1-1: non-simple MultiLineString [dim(1){A.mL.Int.SP-EP = B.mL.Int.SP-EP}]</desc>
-<a>
-MULTILINESTRING(
-(20 20, 90 20, 170 20),
-(90 20, 90 80, 90 140))
-</a>
-<b>
-MULTILINESTRING(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-1-2: equal non-simple MultiLineString with different sequence of lines and points [dim(1){A.mL.Int.SP-EP = B.mL.Int.EP-SP}]</desc>
-<a>
-MULTILINESTRING(
-</a>
-<b>
-MULTILINESTRING(
-(90 140, 90 60, 90 20),
-(170 20, 130 20, 20 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-3-1: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPb}]</desc>
-<a>
-MULTILINESTRING(
-</a>
-<b>
-MULTILINESTRING(
-(90 20, 170 100, 170 140),
-(170 60, 90 20, 20 60),
-(130 100, 130 60, 90 20, 50 90))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-3-2: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPo}]</desc>
-<a>
-MULTILINESTRING(
-</a>
-<b>
-MULTILINESTRING(
-(130 140, 130 60, 90 20, 20 90, 90 20, 130 60, 170 60))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-3-3: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPx}]</desc>
-<a>
-MULTILINESTRING(
-</a>
-<b>
-MULTILINESTRING(
-(170 60, 90 20, 20 60))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-3-4: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPx}]</desc>
-<a>
-MULTILINESTRING(
-</a>
-<b>
-MULTILINESTRING(
-(130 100, 90 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-3-5: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPx}]</desc>
-<a>
-MULTILINESTRING(
-</a>
-<b>
-MULTILINESTRING(
-(120 100, 170 100, 90 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-3-6: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Int.SPb}]</desc>
-<a>
-MULTILINESTRING(
-</a>
-<b>
-MULTILINESTRING(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-3-7: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Int.SPo}]</desc>
-<a>
-MULTILINESTRING(
-</a>
-<b>
-MULTILINESTRING(
-(130 140, 130 60, 90 20, 20 90, 90 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-3-8: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Int.SPx}]</desc>
-<a>
-MULTILINESTRING(
-</a>
-<b>
-MULTILINESTRING(
-(170 60, 90 20, 20 60, 20 140, 90 20))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-4-1: non-simple MultiLineStrings crossing [dim(0){A.mL.Int.Vx = B.mL.Int.Vb}]</desc>
-<a>
-MULTILINESTRING(
-(20 20, 90 90, 20 160),
-(90 160, 90 20))
-</a>
-<b>
-MULTILINESTRING(
-(160 160, 90 90, 160 20),
-(160 120, 120 120, 90 90, 160 60))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-4-2: non-simple MultiLineStrings crossing [dim(0){A.mL.Int.Vx = B.mL.Int.Vo}]</desc>
-<a>
-MULTILINESTRING(
-(90 160, 90 20))
-</a>
-<b>
-MULTILINESTRING(
-(160 120, 120 120, 90 90, 120 60, 160 60))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mL/mL-4-3: non-simple MultiLineStrings crossing [dim(0){A.mL.Int.Vx = B.mL.Int.Vx}]</desc>
-<a>
-MULTILINESTRING(
-(90 160, 90 20))
-</a>
-<b>
-MULTILINESTRING(
-(160 120, 90 90, 160 60))
-</b>
-<test>
-</test>
-</case>
-<precisionModel type="FLOATING"/>
-<case>
-<desc>P/A-2-1: a point outside a polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
-<a>
-POINT(20 20)
-</a>
-<b>
-POLYGON(
-(60 120, 60 40, 160 40, 160 120, 60 120))
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF0FFF212">true</op>
-</test>
-</case>
-<case>
-<desc>P/A-2-2: a point outside a converx polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
-<a>
-POINT(70 170)
-</a>
-<b>
-POLYGON(
-(110 230, 80 160, 20 160, 20 20, 200 20, 200 160, 140 160, 110 230))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/A-2-3: a point outside a concave polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
-<a>
-POINT(110 130)
-</a>
-<b>
-POLYGON(
-(20 160, 80 160, 110 100, 140 160, 200 160, 200 20, 20 20, 20 160))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/A-2-4: dim(0){A.P.Int = B.A.Ext}</desc>
-<a>
-POINT(100 70)
-</a>
-<b>
-POLYGON(
-(20 150, 100 150, 40 50, 170 50, 110 150, 190 150, 190 20, 20 20, 20 150))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/A-2-5: a point outside a concave polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
-<a>
-POINT(100 70)
-</a>
-<b>
-POLYGON(
-(20 150, 100 150, 40 50, 160 50, 100 150, 180 150, 180 20, 20 20, 20 150))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/A-3-1: a point on the closing point of a polygon [dim(0){A.P.Int = B.A.Bdy.CP}]</desc>
-<a>
-POINT(60 120)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F0FFFF212">true</op>
-</test>
-</case>
-<case>
-<desc>P/A-3-2: a point on the boudary of a polygon at a non-vertex [dim(0){A.P.Int = B.A.Bdy.NV}]</desc>
-<a>
-POINT(110 120)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/A-3-3: a point on the boundary of a polygon at a vertex [dim(0){A.P.Int = B.A.Bdy.V]</desc>
-<a>
-POINT(160 120)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/A-3-4: a point on the touching point of boudary [dim(0){A.P.Int = B.A.Bdy.TP}]</desc>
-<a>
-POINT(100 150)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/A-5: a point on the interior of a polygon [dim(0){A.P.Int = B.A.Int}]</desc>
-<a>
-POINT(100 80)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0FFFFF212">true</op>
-</test>
-</case>
-<case>
-<desc>P/Ah-2-1: a point outside of polygon with a hole [dim(0){A.P.Int = B.A.Ext}]</desc>
-<a>
-POINT(60 160)
-</a>
-<b>
-POLYGON(
-(280 50, 100 50, 190 140, 280 50))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/Ah-2-2: a point inside the hole of the polygon [dim(0){A.P.Int = B.A.Ext.h}]</desc>
-<a>
-POINT(190 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/Ah-3-1: a point on the closing point of the outer boundary of a polygon with a hole [dim(0){A.P.Int = B.A.oBdy.CP}]</desc>
-<a>
-POINT(190 190)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/Ah-3-2: a point on the outer boundary of a polygon at a vertex [dim(0){A.P.Int = B.A.oBdy.V}]</desc>
-<a>
-POINT(360 20)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/Ah-3-3: a point on the outer boundary of a polygon at a non-vertex [dim(0){A.P.Int = B.A.oBdy.NV}]</desc>
-<a>
-POINT(130 130)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/Ah-3-4: a point on the closing point of the inner boundary of a polygon [dim(0){A.P.Int = B.A.iBdy.CP}]</desc>
-<a>
-POINT(280 50)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/Ah-3-5: a point on the inner boundary of a polygon at a non-vertex [dim(0){A.P.Int = B.A.iBdy.NV}]</desc>
-<a>
-POINT(150 100)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/Ah-3-6: a point on the inner boundary of a polygon at a vertex [dim(0){A.P.Int = B.A.iBdy.V}]</desc>
-<a>
-POINT(100 50)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/Ah-5: a point inside the interior of a polygon with a hole [dim(0){A.P.Int = B.A.Int}]</desc>
-<a>
-POINT(140 120)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/A2h-3-1: a point on the touching point of two holes in a polygon [dim(0){A.P.Int = B.A.iBdy.TP}]</desc>
-<a>
-POINT(190 50)
-</a>
-<b>
-POLYGON(
-(90 50, 150 110, 190 50, 90 50),
-(190 50, 230 110, 290 50, 190 50))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/A2h-3-2: a point on the touching point of two holes in a polygon [dim(0){A.P.Int = B.A.iBdy.TP}]</desc>
-<a>
-POINT(180 90)
-</a>
-<b>
-POLYGON(
-(180 140, 180 40, 80 40, 180 140),
-(180 90, 210 140, 310 40, 230 40, 180 90))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-2: 3 points outside a polygon [dim(0){A.2P.Int = B.A.Ext}]</desc>
-<a>
-MULTIPOINT(20 80, 110 160, 20 160)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-3-1: one of 3 points on the closing point of the boundary of a polygon [dim(0){A.3P1.Int = B.A.Bdy.CP}]</desc>
-<a>
-MULTIPOINT(20 80, 60 120, 20 160)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F00FFF212">true</op>
-</test>
-</case>
-<case>
-<desc>mP/A-3-2: one of 3 points on the boundary of a polygon at a non-vertex [dim(0){A.3P3 = B.A.Bdy.NV}]</desc>
-<a>
-MULTIPOINT(10 80, 110 170, 110 120)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-3-3: one of 3 points on the boundary of a polygon at a vertex [dim(0){A.3P1.Int = B.A.Bdy.V}]</desc>
-<a>
-MULTIPOINT(10 80, 110 170, 160 120)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-3-4: 3 of the 5 points on the boundary of a polygon [dim(0){A.5P2.Int = B.A.Bdy.CP}, dim(0){A.5P3.Int = B.A.Bdy.NV}, dim(0){A.5P4.Int = B.A.Bdy.V}]</desc>
-<a>
-MULTIPOINT(20 120, 60 120, 110 120, 160 120, 200 120)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-3-5: all 3 points on the boundary of a polygon [dim(0){A.3P1.Int = B.A.Bdy.CP}, dim(0){A.3P2.Int = B.A.Bdy.NV}, dim(0){A.3P3.Int = B.A.Bdy.V}]</desc>
-<a>
-MULTIPOINT(60 120, 110 120, 160 120)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-3-6: all 4 points on the boundary of a polygon [dim(0){A.4P = B.A.Bdy}]</desc>
-<a>
-MULTIPOINT(60 120, 160 120, 160 40, 60 40)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-4-1: 1 point outside a polygon, 1 point on the boundary and 1 point inside [dim(0){A.3P1.Int = B.A.Ext}, dim(0){A.3P2.Int = B.A.Bdy.CP}, dim(0){A.3P3.Int = B.A.Int}]</desc>
-<a>
-MULTIPOINT(20 150, 60 120, 110 80)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="000FFF212">true</op>
-</test>
-</case>
-<case>
-<desc>mP/A-4-2: 1 point outside a polygon, 1 point on the boundary and 1 point inside [dim(0){A.3P1.Int = B.A.Ext}, dim(0){A.3P2.Int = B.A.Bdy.V}, dim(0){A.3P3.Int = B.A.Int}]</desc>
-<a>
-MULTIPOINT(110 80, 160 120, 200 160)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-4-3: 1 point outside a polygon, 1 point on the boundary and 1 point inside [dim(0){A.3P1.Int = B.A.Ext}, dim(0){A.3P2.Int = B.A.Bdy.NV}, dim(0){A.3P3.Int = B.A.Int}]</desc>
-<a>
-MULTIPOINT(110 80, 110 120, 110 160)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-4-4: 1 point outside a polygon, 1 point inside [dim(0){A.2P1.Int = B.A.Ext}, dim(0){A.2P2.Int = B.A.Int}]</desc>
-<a>
-MULTIPOINT(110 170, 110 80)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F0FFF212">true</op>
-</test>
-</case>
-<case>
-<desc>mP/A-4-5: 1 point outside a polygon, 2 points on the boundary and 1 point inside [dim(0){A.4P1.Int = B.A.Ext}, dim(0){A.4P2.Int = B.A.Bdy.CP}, dim(0){A.4P3.Int = B.A.Bdy.V}, dim(0){A.4P4.Int = B.A.Int}]</desc>
-<a>
-MULTIPOINT(60 120, 160 120, 110 80, 110 170)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-5-1: 2 points within a polygon [dim(0){A.2P.Int = B.A.Int]</desc>
-<a>
-MULTIPOINT(90 80, 130 80)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/A-5-2: 1 point on the boundary and 1 point inside a polygon [dim(0){A.2P1.Int = B.A.Bdy.CP}, dim(0){A.2P2.Int = B.A.Int}]</desc>
-<a>
-MULTIPOINT(60 120, 160 120, 110 80)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="00FFFF212">true</op>
-</test>
-</case>
-<case>
-<desc>mP/Ah-2-1: 3 points outside a polygon [dim(0){A.3P.Int = B.Ah.Ext}]</desc>
-<a>
-MULTIPOINT(40 170, 40 90, 130 170)
-</a>
-<b>
-POLYGON(
-(190 190, 360 20, 20 20, 190 190),
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/Ah-2-2: 2 points outside a polygon and 1 point inside the hole of the polygon [dim(0){A.3P1.Int = B.Ah.Ext}, dim(0){A.3P2.Int = B.Ah.Ext}, dim(0){A.3P3.Int = B.Ah.Ext.h}]</desc>
-<a>
-MULTIPOINT(90 170, 280 170, 190 90)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/Ah-2-3: all 3 points in polygon's hole [dim(0){A.3P.Int = B.Ah.Ext.h}]</desc>
-<a>
-MULTIPOINT(190 110, 150 70, 230 70)
-</a>
-<b>
-POLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/mA-3-1: a point on the touching point of two polygons [dim(0){A.P.Int = B.2A.Bdy}]</desc>
-<a>
-POINT(100 100)
-</a>
-<b>
-MULTIPOLYGON(
-(20 100, 20 20, 100 20, 100 100, 20 100)),
-(100 180, 100 100, 180 100, 180 180, 100 180)))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/mA-3-2: a point on the boundary of one of the 2 polygons [dim(0){A.P.Int = B.2A1.Bdy.CP}]</desc>
-<a>
-POINT(20 100)
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/mA-3-3: a point on the boundary of one of the 2 polygons [dim(0){A.P.Int = B.2A1.Bdy.V}]</desc>
-<a>
-POINT(60 100)
-</a>
-<b>
-MULTIPOLYGON(
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/mA-3-4: a point touching a polygon's boundary where the boundaries touch at a point [dim(0){A.P.Int = B.2A.Bdy.TP}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-MULTIPOLYGON(
-(110 110, 20 200, 200 200, 110 110),
-(110 110, 80 180, 140 180, 110 110)),
-(110 110, 20 20, 200 20, 110 110),
-(110 110, 80 40, 140 40, 110 110)))
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/L-2: a point and a line disjoint [dim(0){A.P.Int = B.L.Ext}]</desc>
-<a>
-POINT(110 200)
-</a>
-<b>
-LINESTRING(90 80, 160 150, 300 150, 340 150, 340 240)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF0FFF102">true</op>
-</test>
-</case>
-<case>
-<desc>P/L-3-1: a point touching the start point of a line [dim(0){A.P.Int = B.L.Bdy.SP}]</desc>
-<a>
-POINT(90 80)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F0FFFF102">true</op>
-</test>
-</case>
-<case>
-<desc>P/L-3-2: a point touching the end point of a line [dim(0){A.P.Int = B.L.Bdy.EP}]</desc>
-<a>
-POINT(340 240)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/L-5-1: a point on the line at a non-vertex [dim(0){A.P.Int = B.L.Int.NV}]</desc>
-<a>
-POINT(230 150)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0FFFFF102">true</op>
-</test>
-</case>
-<case>
-<desc>P/L-5-2: a point on the line at a vertex [dim(0){A.P.Int = B.L.Int.V}]</desc>
-<a>
-POINT(160 150)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/LR-2-1: a point outside a LinearRing [dim(0){A.P.Int = B.LR.Ext}]</desc>
-<a>
-POINT(90 150)
-</a>
-<b>
-LINESTRING(150 150, 20 20, 280 20, 150 150)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF0FFF1F2">true</op>
-</test>
-</case>
-<case>
-<desc>P/LR-2-2: a point inside a LinearRing [dim(0){A.P.Int = B.LR.Ext}]</desc>
-<a>
-POINT(150 80)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/LR-5-1: a point on the closing point of a LinearRing [dim(0){A.P.Int = B.LR.Int.CP}]</desc>
-<a>
-POINT(150 150)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0FFFFF1F2">true</op>
-</test>
-</case>
-<case>
-<desc>P/LR-5-2: a point on a LinearRing at a non-vertex [dim(0){A.P.Int = B.L.Int.NV}]</desc>
-<a>
-POINT(100 20)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/LR-5-3: a point on a LinearRing at a vertex [dim(0){A.P.Int = B.L.Int.V}]</desc>
-<a>
-POINT(20 20)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.1-3-1: a point on a non-simple LineString's end point [dim(0){A.P.Int = B.nsL.Bdy.EP}]</desc>
-<a>
-POINT(220 220)
-</a>
-<b>
-LINESTRING(110 110, 220 20, 20 20, 110 110, 220 220)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.1-5-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.1-5-2: a point a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 220 20, 20 20, 220 220)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.1-5-3: a point on a non-simple LineString's interior at a non-vertex [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
-<a>
-POINT(110 20)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.1-5-4: a point on a non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
-<a>
-POINT(220 20)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.2-5-2: a point on a non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
-<a>
-POINT(110 20)
-</a>
-<b>
-LINESTRING(220 220, 20 20, 220 20, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.2-5-3: a point on a non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
-<a>
-POINT(20 20)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.2-5-4: a point on a non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
-<a>
-POINT(20 110)
-</a>
-<b>
-LINESTRING(20 200, 20 20, 110 20, 20 110, 110 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.3-3-1: a point on a non-simple LineString's start point [dim(0){A.P.Int = B.nsL.Bdy.SP}]</desc>
-<a>
-POINT(20 200)
-</a>
-<b>
-LINESTRING(20 200, 200 20, 20 20, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.3-5-1: a point on a non-simple LineString's interior at a non-vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(20 200, 200 20, 140 20, 140 80, 80 140, 20 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.3-5-2: a point on a non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.3-5-3: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
-<a>
-POINT(80 140)
-</a>
-<b>
-LINESTRING(20 200, 110 110, 200 20, 140 20, 140 80, 110 110, 80 140, 20 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.3-5-4: a point on a non-simple LineString's interior at a two-vertex point with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vo}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.3-5-5: a point on a non-simple LineString's interior at a vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vo}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(20 200, 200 20, 140 20, 140 80, 110 110, 80 140, 20 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.3-5-6: a point on a non-simple LineString's interior at a two-vertex point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(20 200, 110 110, 200 20, 20 20, 110 110, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.3-5-7: a point on a non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(20 200, 200 20, 20 20, 110 110, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.3-5-8: a point on a non-simple LineString's interior at a two-vertex point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(20 200, 110 110, 20 20, 200 20, 110 110, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.4-3-1: a point on a non-simple LineString's start point with crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 110 200, 20 200, 110 110, 200 20, 140 20, 140 80, 110 110, 80 140,
-20 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.4-3-2: a point on a non-simple LineString's start point with crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 110 200, 20 200, 200 20, 140 20, 140 80, 110 110, 80 140, 20 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.4-3-3:a point on a non-simple LineString's start point with crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 110 200, 20 200, 200 20, 140 20, 140 80, 80 140, 20 140)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.4-3-4: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 110 200, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.4-3-5: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 110 200, 20 200, 200 20, 20 20, 110 110, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.4-3-6: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 110 200, 20 200, 200 20, 20 20, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.4-3-7: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 110 200, 20 200, 110 110, 20 20, 200 20, 110 110, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.4-3-8: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 110 200, 20 200, 200 20, 200 110, 110 110, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.5-3-1: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(200 200, 110 110, 20 20, 200 20, 110 110, 20 200, 110 200, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.5-3-2: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.5-3-3: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(200 200, 20 20, 200 20, 20 200, 110 200, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.5-3-4: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(200 200, 110 110, 200 20, 20 20, 110 110, 20 200, 110 200, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.5-3-5: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(200 200, 20 20, 20 110, 110 110, 20 200, 110 200, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.6-3-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(110 160)
-</a>
-<b>
-LINESTRING(110 160, 200 250, 110 250, 110 160, 110 110, 110 20, 20 20, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.6-3-2: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(110 160)
-</a>
-<b>
-LINESTRING(110 160, 200 250, 110 250, 110 110, 110 20, 20 20, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.6-3-3: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.6-3-4: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 160, 200 250, 110 250, 110 160, 110 20, 20 20, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.7-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 200 200, 110 200, 110 110, 110 20, 20 20, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.7-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 200 200, 110 200, 110 20, 20 20, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.7-5-3: a point on a closed non-simple LineString's interior at a non-vertex [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
-<a>
-POINT(140 200)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.7-5-4: a point on a closed non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
-<a>
-POINT(110 200)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.8-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 200 200, 110 200, 110 110, 110 20, 200 20, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.8-5-2: a point on the interior (at a non-vertex) of a closed non-simple LineString [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
-<a>
-POINT(140 200)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.8-5-3: a point on a closed non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
-<a>
-POINT(110 200)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.9-3-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-LINESTRING(90 130, 20 130, 20 200, 90 130, 200 20, 20 20, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.9-5-1: a point on a non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.10-3-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-LINESTRING(90 130, 20 130, 20 200, 200 20, 20 20, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.10-5-1: a point on a non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.11-3-1: a point on a closed non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-LINESTRING(200 200, 20 20, 200 20, 90 130, 20 200, 20 130, 90 130)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.11-5-1: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.12-3-1: a point on a closed non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.12-5-1: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.13-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 20 130, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 200 130,
-110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.13-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 20 130, 20 200, 200 20, 20 20, 200 200, 200 130, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.14-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 80 200, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 140 200,
-110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.14-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(110 110, 80 200, 20 200, 200 20, 20 20, 200 200, 140 200, 110 110)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.15-5-1: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(200 200, 20 20, 200 20, 20 200, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.15-5-2: a point on a closed non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(200 200, 110 110, 20 20, 200 20, 110 110, 20 200, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.15-5-3: a point on a closed non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-LINESTRING(200 200, 110 110, 200 20, 20 20, 110 110, 20 200, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.16-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-LINESTRING(90 130, 20 130, 20 200, 90 130, 110 110, 200 20, 20 20, 110 110, 200 200,
-90 130)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.16-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-LINESTRING(90 130, 20 130, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 90 130)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.17-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-LINESTRING(90 130, 90 200, 20 200, 90 130, 110 110, 200 20, 20 20, 110 110, 200 200,
-90 130)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.17-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-LINESTRING(90 130, 90 200, 20 200, 200 20, 20 20, 200 200, 90 130)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.17-5-3: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-LINESTRING(90 130, 90 200, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 90 130)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.17-5-4: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
-<a>
-POINT(90 130)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.17-5-5: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.18-5-1: a point on a non-simple LineString's start point with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb)}]</desc>
-<a>
-POINT(110 200)
-</a>
-<b>
-LINESTRING(110 200, 110 110, 20 20, 200 20, 110 110, 110 200, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.18-5-2: a point on a non-simple LineString's interior at a non-vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
-<a>
-POINT(110 150)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.18-5-3: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.19-5-1: a point on a non-simple LineString's closing point with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.CPo}]</desc>
-<a>
-POINT(110 200)
-</a>
-<b>
-LINESTRING(110 200, 110 110, 20 20, 200 20, 110 110, 110 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.19-5-2: a point on a non-simple LineString's interior at a non-vertex overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
-<a>
-POINT(110 150)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.19-5-3: a point on a non-simple LineString interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.20-5-1: a point on a non-simple LineString's interior at a non-vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
-<a>
-POINT(110 150)
-</a>
-<b>
-LINESTRING(20 200, 110 200, 110 110, 20 20, 200 20, 110 110, 110 200, 200 200)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsL.20-5-2: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
-<a>
-POINT(110 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/nsl.20-5-3: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
-<a>
-POINT(110 200)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-2-1: MultiPoint and a line disjoint (points on one side of the line) [dim(0){A.3P.Int = B.L.Ext}]</desc>
-<a>
-MULTIPOINT(50 250, 90 220, 130 190)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-2-2: MultiPoint and a line disjoint (points over the line but no intersection) [dim(0){A.3P.Int = B.L.Ext}]</desc>
-<a>
-MULTIPOINT(180 180, 230 130, 280 80)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-3-1: one of the points intersecting the start point of a line [dim(0){A.3P2.Int = B.L.Bdy.SP}]</desc>
-<a>
-MULTIPOINT(50 120, 90 80, 130 40)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="F00FFF102">true</op>
-</test>
-</case>
-<case>
-<desc>mP/L-3-2: one of the points intersecting the end point of a line [dim(0){A.3P2 = B.L.Bdy.EP}]</desc>
-<a>
-MULTIPOINT(300 280, 340 240, 380 200)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-4-1: one of the points intersecting the interior of a line at a non-vertex (points on one side of the line) [dim(0){A.3P1.Int = B.L.Int.NV]</desc>
-<a>
-MULTIPOINT(230 150, 260 120, 290 90)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F0FFF102">true</op>
-</test>
-</case>
-<case>
-<desc>mP/L-4-2: one of the points intersecting the interior of a line at a non-vertex (points over the line) [dim(0){A.3P2.Int = B.L.Int.NV]</desc>
-<a>
-MULTIPOINT(200 190, 240 150, 270 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-4-3: one of the points intersecting the interior of a line at a vertex (points on one side of the line) [dim(0){A.3P1.Int = B.L.Int.V]</desc>
-<a>
-MULTIPOINT(160 150, 190 120, 220 90)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-4-4: one of the points intersecting the interior of a line at a vertex (points over the line) [dim(0){A.3P2.Int = B.L.Int.V]</desc>
-<a>
-MULTIPOINT(120 190, 160 150, 200 110)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-5-1: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Bdy.EP}]</desc>
-<a>
-MULTIPOINT(90 80, 160 150, 340 240)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="00FFFF1F2">true</op>
-</test>
-</case>
-<case>
-<desc>mP/L-5-2: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.V}]</desc>
-<a>
-MULTIPOINT(90 80, 160 150, 300 150)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="00FFFF102">true</op>
-</test>
-</case>
-<case>
-<desc>mP/L-5-3: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
-<a>
-MULTIPOINT(90 80, 160 150, 240 150)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-5-4: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.NV}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
-<a>
-MULTIPOINT(90 80, 130 120, 210 150)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-5-5: all the points on a line [dim(0){A.3P1.Int = B.L.Int.NV}, dim(0){A.3P2.Int = B.L.Int.NV}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
-<a>
-MULTIPOINT(130 120, 210 150, 340 200)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-5-6: all the points on a line [dim(0){A.3P1.Int = B.L.Int.V}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
-<a>
-MULTIPOINT(160 150, 240 150, 340 210)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-5-7: all the points on a line [dim(0){A.3P1.Int = B.L.Int.V}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.V}]</desc>
-<a>
-MULTIPOINT(160 150, 300 150, 340 150)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/L-5-8: all the points on a line [dim(0){A.3P1.Int = B.L.Int.V}, dim(0){A.3P2.Int = B.L.Int.NV}, dim(0){A.3P3.Int = B.Bdy.EP}]</desc>
-<a>
-MULTIPOINT(160 150, 240 150, 340 240)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/P: same point [dim(0){A.P.Int = B.P.Int}]</desc>
-<a>
-POINT(20 20)
-</a>
-<b>
-POINT(20 20)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0FFFFFFF2">true</op>
-</test>
-</case>
-<case>
-<desc>P/P: different point [dim(0){A.P.Int = B.P.Ext}]</desc>
-<a>
-POINT(20 20)
-</a>
-<b>
-POINT(40 60)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="FF0FFF0F2">true</op>
-</test>
-</case>
-<case>
-<desc>P/mP: different points [dim(0){A.P.Int = B.3P.Ext}]</desc>
-<a>
-POINT(40 40)
-</a>
-<b>
-MULTIPOINT(20 20, 80 80, 20 120)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>P/mP: point A within one of B points [dim(0){A.P.Int = B.3P1.Int}]</desc>
-<a>
-POINT(20 20)
-</a>
-<b>
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0FFFFF0F2">true</op>
-</test>
-</case>
-<case>
-<desc>mP/mP-1-1: same points [dim(0){A.3P1.Int = B.3P1.Int}, dim(0){A.3P2.Int = B.3P2.Int}, dim(0){A.3P3.Int = B.3P3.Int}]</desc>
-<a>
-MULTIPOINT(40 40, 80 60, 120 100)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/mP-1-2: same but different sequence of points [dim(0){A.3P1.Int = B.3P1.Int}, dim(0){A.3P1.Int = B.3P3.Int}, dim(0){A.3P3.Int = B.3P2.Int}]</desc>
-<a>
-</a>
-<b>
-MULTIPOINT(40 40, 120 100, 80 60)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/mP-2: different points [dim(0){A.4P.Int = B.4P.Ext}]</desc>
-<a>
-MULTIPOINT(40 40, 60 100, 100 60, 120 120)
-</a>
-<b>
-MULTIPOINT(20 120, 60 60, 100 100, 140 40)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/mP-5-1: same points [dim(0){A.4P.Int = B.4P.Int}]</desc>
-<a>
-MULTIPOINT(20 20, 80 70, 140 120, 200 170)
-</a>
-<b>
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/mP-5-2: same points but different sequence [dim(0){A.4P.Int = B.4P.Int}]</desc>
-<a>
-MULTIPOINT(20 20, 140 120, 80 70, 200 170)
-</a>
-<b>
-MULTIPOINT(80 70, 20 20, 200 170, 140 120)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/mP-5-3: some points same [dim(0){A.4P2.Int = B.2P1.Int}, dim(0){A.4P3.Int = B.2P2.Int}]</desc>
-<a>
-</a>
-<b>
-MULTIPOINT(80 70, 140 120)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F0FFFFF2">true</op>
-</test>
-</case>
-<case>
-<desc>mP/mP-5-4: some points same, in a different sequence [dim(0){A.4P1.Int = B.2P2.Int}, dim(0){A.4P4.Int = B.2P1.Int}]</desc>
-<a>
-</a>
-<b>
-MULTIPOINT(140 120, 80 70)
-</b>
-<test>
-</test>
-</case>
-<case>
-<desc>mP/mP-6-1: some points same, some different [dim(0){A.4P4.Int = B.3P2.Int}]</desc>
-<a>
-</a>
-<b>
-MULTIPOINT(80 170, 140 120, 200 80)
-</b>
-<test>
-<op name="relate" arg1="A" arg2="B" arg3="0F0FFF0F2">true</op>
-</test>
-</case>
-<case>
-<desc>mP/mP-6-2: dim(0){A.4P1.Int = B.4P4.Int}, dim(0){A.4P4.Int = B.4P2.Int}</desc>
-<a>
-</a>
-<b>
-MULTIPOINT(80 170, 140 120, 200 80, 80 70)
-</b>
-<test>
-</test>
-</case>
-</run>
diff --git a/tests/xmltester/tests/misc/testLeaksBig.xml b/tests/xmltester/tests/misc/testLeaksBig.xml
deleted file mode 100644
index 616ef90..0000000
--- a/tests/xmltester/tests/misc/testLeaksBig.xml
+++ /dev/null
@@ -1,7094 +0,0 @@
-<run>
- <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/>
- <case>
- <desc>SegFault</desc>
- <a>POLYGON((1033707.6 1048313.1,1033694.9 1048315.7,1033659.9 1048344.3,1033627.6 1048388.8,1033620.9 1048426.8,1033623.6 1048471.3,1033623.6 1048480.8,1033616.8 1048503.2,1033629.1 1048541.3,1033668.3 1048707.6,1033696.3 1048755.6,1033721.4 1048771.6,1033724.5 1048772,1033737.2 1048772,1033772.1 1048756.4,1033794.6 1048721.9,1033811.1 1048667.4,1033814.8 1048613.6,1033815.1 1048597.5,1033809.2 1048556.1,1033809.3 1048549.6,1033797.1 1048501.9,1033790.9 1048492.2,1033773 1048399.6,1033760.6 1048377.6,1033741.8 1048357.8,1033742.1 1048341.8,1033713.9 1048313.4,1033707.6 1048313.1))</a>
- <test>
- <op name="isValid" arg1="A">true</op>
- </test>
- </case>
-<case>
-<desc>A/A-1-1: same polygons [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
- <a>
- POLYGON(
- (20 20, 20 100, 120 100, 140 20, 20 20))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="2FFF1FFF2">true</op>
- </test>
-</case>
-<case>
-<desc>A/A-1-2: same polygons with reverse sequence of points [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.EP-SP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 140 20, 120 100, 20 100, 20 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-1-3: same polygons with different sequence of points [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (120 100, 140 20, 20 20, 20 100, 120 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-1-4: same polygons with different number of points [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 100, 60 100, 120 100, 140 20, 80 20, 20 20, 20 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-2: different polygons [dim(2){A.A.Int = B.A.Ext}]</desc>
- <a>
- POLYGON(
- (0 0, 80 0, 80 80, 0 80, 0 0))
- </a>
- <b>
- POLYGON(
- (100 200, 100 140, 180 140, 180 200, 100 200))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF2FF1212">true</op>
- </test>
-</case>
-<case>
-<desc>A/A-3-1-1: the closing point of a polygon touching the closing point of another polygon [dim(0){A.A.Bdy.CP = B.A.Bdy.CP}]</desc>
- <a>
- POLYGON(
- (140 120, 160 20, 20 20, 20 120, 140 120))
- </a>
- <b>
- POLYGON(
- (140 120, 140 200, 240 200, 240 120, 140 120))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF2F01212">true</op>
- </test>
-</case>
-<case>
-<desc>A/A-3-1-2: the closing point of a polygon touching the boundary (at a non-vertex) of another polygon [dim(0){A.A.Bdy.CP = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (80 180, 140 260, 260 200, 200 60, 80 180))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-1-3: the closing point of a polygon touching the boundary (at a vertex) of another polygon [dim(0){A.A.Bdy.CP = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (240 80, 140 120, 180 240, 280 200, 240 80))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-1-4: the boundary (at a non-vertex) of a polygon touching the closing point of another polygon [dim(0){A.A.Bdy.NV = B.A.Bdy.CP}]</desc>
- <a>
- POLYGON(
- (140 160, 20 20, 270 20, 150 160, 230 40, 60 40, 140 160))
- </a>
- <b>
- POLYGON(
- (140 40, 180 80, 120 100, 140 40))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-1-5: the boundary (at a non-vertex) of a polygon touching the boundary (at a vertex) of another polygon [dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (120 100, 180 80, 130 40, 120 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-1-6: the boundary (at a vertex) of a polygon touching the boundary (at a non-vertex) of another polygon [dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (20 20, 180 20, 140 140, 20 140, 20 20))
- </a>
- <b>
- POLYGON(
- (180 100, 80 200, 180 280, 260 200, 180 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-1-7: the boundary (at a vertex) of a polygon touching the boundary (at a vertex) of another polygon [dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (140 140, 20 120, 0 220, 120 240, 140 140))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-1-8: the closing point of a polygon touching the boundary of another polygon where the closing point touching the boundary at a vertex [dim(0){A.A.Bdy.CP = B.A.Bdy.TP}]</desc>
- <a>
- POLYGON(
- (160 200, 210 70, 120 70, 160 200))
- </a>
- <b>
- POLYGON(
- (160 200, 260 40, 70 40, 160 200, 20 20, 310 20, 160 200))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-1-9: the closing point of a polygon touching the boundary of another polygon where the closing point intersecting the boundary at a non-vertex [dim(0){A.A.Bdy.CP = B.A.Bdy.TP}]</desc>
- <a>
- POLYGON(
- (110 140, 200 70, 200 160, 110 140))
- </a>
- <b>
- POLYGON(
- (110 140, 110 50, 60 50, 60 90, 160 190, 20 110, 20 20, 200 20, 110 140))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-2-1: two polygons touching at multiple points [dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- (20 120, 20 20, 260 20, 260 120, 200 40, 140 120, 80 40, 20 120))
- </a>
- <b>
- POLYGON(
- (20 120, 20 240, 260 240, 260 120, 200 200, 140 120, 80 200, 20 120))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-2-2: two polygons touching at multiple points [dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (20 120, 20 20, 260 20, 260 120, 180 40, 140 120, 100 40, 20 120))
- </a>
- <b>
- POLYGON(
- (20 120, 300 120, 140 240, 20 120))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-2-3: two polygons touching at multiple points [dim(0){A.A.Bdy.CP = B.A.Bdy.NV}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (20 20, 20 300, 280 300, 280 260, 220 260, 60 100, 60 60, 280 60, 280 20,
- 20 20))
- </a>
- <b>
- POLYGON(
- (100 140, 160 80, 280 180, 200 240, 220 160, 160 200, 180 120, 100 140))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-2-4: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- 20 20))
- </a>
- <b>
- POLYGON(
- (260 200, 180 80, 120 160, 200 160, 180 220, 260 200))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-2-5: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (20 20, 280 20, 280 140, 220 60, 140 140, 80 60, 20 140, 20 20))
- </a>
- <b>
- POLYGON(
- (0 140, 300 140, 140 240, 0 140))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-2-6: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 240, 20 140, 320 140, 180 240, 20 240))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-2-7: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 240, 20 140, 80 180, 140 140, 220 180, 280 140, 280 240, 20 240))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-1: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-NV}]</desc>
- <a>
- POLYGON(
- (120 120, 180 60, 20 20, 20 120, 120 120))
- </a>
- <b>
- POLYGON(
- (120 120, 220 20, 280 20, 240 160, 120 120))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF2F11212">true</op>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-2: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (140 120, 160 20, 260 120, 220 200, 140 120))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-3: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.NV-V}]</desc>
- <a>
- POLYGON(
- (20 140, 120 40, 20 40, 20 140))
- </a>
- <b>
- POLYGON(
- (190 140, 190 20, 140 20, 20 140, 190 140))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-4: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.NV-V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (300 20, 220 20, 120 120, 260 160, 300 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-5: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-EP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (140 120, 240 160, 280 60, 160 20, 140 120))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-6: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (280 60, 180 60, 120 120, 260 180, 280 60))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-7: two polygons touching along a boundary [dim(1){A.A.Bdy.NV-NV = B.A.Bdy.V-V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (120 200, 120 120, 40 120, 40 200, 120 200))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-8: two polygons touching along a boundary [dim(1){A.A.Bdy.NV-EP = B.A.Bdy.V-V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (160 220, 140 120, 60 120, 40 220, 160 220))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-9: two polygons touching along a boundary [dim(1){A.A.Bdy.V-EP = B.A.Bdy.V-SP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (140 120, 20 120, 20 220, 140 220, 140 120))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-3-3-10: two polygons touching along a boundary [dim(1){A.A.Bdy.V-V = B.A.Bdy.NV-NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (320 20, 220 20, 80 160, 240 140, 320 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Int}]</desc>
- <a>
- POLYGON(
- (20 20, 20 180, 220 180, 220 20, 20 20))
- </a>
- <b>
- POLYGON(
- (60 40, 60 140, 180 140, 180 40, 60 40))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="212FF1FF2">true</op>
- </test>
-</case>
-<case>
-<desc>A/A-5-2-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 80 140, 160 60, 20 20))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="212F01FF2">true</op>
- </test>
-</case>
-<case>
-<desc>A/A-5-2-2: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (160 60, 20 20, 100 140, 160 60))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-2-3: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 100, 140 160, 160 40, 20 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-2-4: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (160 40, 20 100, 160 160, 160 40))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-2-5: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.CP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 180, 180 120, 80 40, 20 180))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-2-6: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (180 120, 100 40, 20 180, 180 120))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-3-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 140 40, 140 120, 20 160, 80 80, 20 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-3-2: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 140 40, 140 140, 20 180, 80 100, 20 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-3-3: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (40 180, 60 100, 180 100, 200 180, 120 120, 40 180))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-3-4: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 180, 60 80, 180 80, 220 180, 120 120, 20 180))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-3-5: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (40 60, 20 180, 100 100, 140 180, 160 120, 220 100, 140 40, 40 60))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-3-6: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (60 100, 180 100, 220 180, 120 140, 20 180, 60 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-4-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-NV = B.A.Bdy.SP-V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 20 140, 120 120, 120 40, 20 20))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="212F11FF2">true</op>
- </test>
-</case>
-<case>
-<desc>A/A-5-4-2: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-V)}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 20 180, 140 140, 140 60, 20 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-4-3: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-NV = B.A.Bdy.V-EP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 120 40, 120 120, 20 140, 20 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-4-4: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-NV = B.A.Bdy.V-V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (120 40, 20 20, 20 140, 120 120, 120 40))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-4-5: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-EP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 140 60, 140 140, 20 180, 20 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-4-6: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (140 60, 20 20, 20 180, 140 140, 140 60))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-4-7: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.NV-EP = B.A.Bdy.V-EP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 60 120, 140 120, 180 20, 20 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-4-8: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.NV-NV = B.A.Bdy.V-EP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 40, 120 40, 120 120, 20 140, 20 40))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-5-5-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-V}, dim(1){A.A.Bdy.(NV, V) = B.A.Bdy.(V, V)}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 20, 20 180, 60 120, 100 180, 140 120, 220 180, 200 120, 140 60, 20 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-1: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}]</desc>
- <a>
- POLYGON(
- (150 150, 330 150, 250 70, 70 70, 150 150))
- </a>
- <b>
- POLYGON(
- (150 150, 270 150, 140 20, 20 20, 150 150))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="212111212">true</op>
- </test>
-</case>
-<case>
-<desc>A/A-6-2: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}]</desc>
- <a>
- POLYGON(
- (150 150, 270 150, 330 150, 250 70, 190 70, 70 70, 150 150))
- </a>
- <b>
- POLYGON(
- (150 150, 270 150, 190 70, 140 20, 20 20, 70 70, 150 150))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-3: spiky polygons overlapping; boundary <-> boundary intersecting at 0 dimension [dim(2){A.A.Int = B.A.Int}]</desc>
- <a>
- POLYGON(
- (20 20, 60 50, 20 40, 60 70, 20 60, 60 90, 20 90, 70 110, 20 130,
- 80 130, 20 150, 80 160, 20 170, 80 180, 20 200, 80 200, 30 240, 80 220, 50 260,
- 100 220, 100 260, 120 220, 130 260, 140 220, 150 280, 150 190, 160 280, 170 190, 180 280,
- 190 190, 200 280, 210 190, 220 280, 230 190, 240 260, 250 230, 260 260, 260 220, 290 270,
- 290 220, 330 260, 300 210, 340 240, 290 180, 340 210, 290 170, 350 170, 240 150, 350 150,
- 240 140, 350 130, 240 120, 350 120, 240 110, 350 110, 240 100, 350 100, 240 90, 350 90,
- 240 80, 350 80, 300 70, 340 60, 290 60, 340 40, 300 50, 340 20, 270 60, 310 20,
- 250 60, 270 20, 230 60, 240 20, 210 60, 210 20, 190 70, 190 20, 180 90, 170 20,
- 160 90, 150 20, 140 90, 130 20, 120 90, 110 20, 100 90, 100 20, 90 60, 80 20,
- 70 40, 20 20))
- </a>
- <b>
- POLYGON(
- (190 140, 140 130, 200 160, 130 150, 210 170, 130 170, 210 180, 120 190, 220 200,
- 120 200, 250 210, 120 210, 250 220, 120 220, 250 230, 120 240, 230 240, 120 250, 240 260,
- 120 260, 240 270, 120 270, 270 290, 120 290, 230 300, 150 310, 250 310, 180 320, 250 320,
- 200 360, 260 330, 240 360, 280 320, 290 370, 290 320, 320 360, 310 320, 360 360, 310 310,
- 380 340, 310 290, 390 330, 310 280, 410 310, 310 270, 420 280, 310 260, 430 250, 300 250,
- 440 240, 300 240, 450 230, 280 220, 440 220, 280 210, 440 210, 300 200, 430 190, 300 190,
- 440 180, 330 180, 430 150, 320 180, 420 130, 300 180, 410 120, 280 180, 400 110, 280 170,
- 390 90, 280 160, 400 70, 270 160, 450 30, 260 160, 420 30, 250 160, 390 30, 240 160,
- 370 30, 230 160, 360 30, 230 150, 330 50, 240 130, 330 30, 230 130, 310 30, 220 130,
- 280 30, 230 100, 270 40, 220 110, 250 30, 210 130, 240 30, 210 100, 220 40, 200 90,
- 200 20, 190 100, 180 30, 20 20, 180 40, 20 30, 180 50, 20 50, 180 60, 30 60,
- 180 70, 20 70, 170 80, 80 80, 170 90, 20 80, 180 100, 40 100, 200 110, 60 110,
- 200 120, 120 120, 190 140))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="212101212">true</op>
- </test>
-</case>
-<case>
-<desc>A/A-6-4: spiky polygons overlapping; boundary <-> boundary intersecting at 1 dimension at a few locations [dim(2){A.A.Int = B.A.Int}]</desc>
- <a>
- POLYGON(
- (70 150, 20 160, 110 160, 20 180, 100 200, 20 200, 190 210, 20 210, 160 220,
- 20 220, 150 230, 60 240, 180 250, 20 260, 170 260, 60 270, 160 270, 100 310, 170 280,
- 200 260, 180 230, 210 260, 130 330, 230 250, 210 290, 240 250, 230 210, 260 300, 250 230,
- 270 300, 270 240, 300 340, 280 250, 320 330, 290 250, 340 350, 290 240, 350 360, 270 190,
- 350 340, 290 200, 350 330, 300 190, 360 320, 310 190, 360 300, 320 200, 360 280, 330 200,
- 360 260, 340 200, 370 260, 340 180, 390 290, 340 170, 400 260, 350 170, 400 250, 350 160,
- 410 240, 350 150, 400 170, 350 140, 310 170, 340 140, 270 180, 330 140, 260 170, 310 140,
- 240 170, 290 140, 200 190, 270 140, 180 190, 260 140, 170 190, 260 130, 170 180, 250 130,
- 170 170, 240 120, 170 160, 210 120, 170 150, 210 110, 340 130, 230 110, 420 140, 220 100,
- 410 130, 220 90, 400 120, 220 80, 390 110, 220 70, 420 110, 240 70, 420 100, 260 70,
- 420 90, 280 70, 430 80, 230 60, 430 60, 270 50, 450 40, 210 50, 370 40, 260 40,
- 460 30, 160 40, 210 60, 200 110, 190 60, 190 120, 170 50, 180 130, 150 30, 170 130,
- 140 20, 160 120, 130 20, 160 150, 120 20, 160 170, 110 20, 160 190, 100 20, 150 190,
- 90 20, 140 180, 80 20, 120 140, 70 20, 120 150, 60 20, 110 150, 50 20, 100 140,
- 50 30, 90 130, 40 30, 80 120, 30 30, 80 130, 30 40, 80 140, 20 40, 70 140,
- 40 90, 60 130, 20 90, 60 140, 20 130, 70 150))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-5: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- (60 160, 220 160, 220 20, 60 20, 60 160))
- </a>
- <b>
- POLYGON(
- (60 160, 20 200, 260 200, 220 160, 140 80, 60 160))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-6: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (60 160, 20 200, 260 200, 140 80, 60 160))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-7: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.NV}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 200, 140 80, 260 200, 20 200))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-8: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 200, 60 160, 140 80, 220 160, 260 200, 20 200))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-9: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (20 200, 60 160, 140 80, 260 200, 20 200))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-10: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (0 0, 0 200, 200 200, 200 0, 0 0))
- </a>
- <b>
- POLYGON(
- (100 100, 1000000 110, 10000000 100, 100 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-11: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (100 0, 100 200, 200 200, 200 0, 100 0))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-12: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (120 0, 120 200, 200 200, 200 0, 120 0))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-13: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (0 0, 0 200, 110 200, 110 0, 0 0))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-14: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (100 100, 100 200, 200 200, 200 100, 100 100))
- </a>
- <b>
- POLYGON(
- (100 100, 2100 110, 2100 100, 100 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-15: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (100 100, 2101 110, 2101 100, 100 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-16: two skinny polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (100 100, 200 200, 200 100, 100 100))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-17: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (100 100, 1000000 110, 1000000 100, 100 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-18: a polygon overlapping a very skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (100 100, 1000000000000000 110, 1000000000000000 100, 100 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-19: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (120 100, 120 200, 200 200, 200 100, 120 100))
- </a>
- <b>
- POLYGON(
- (100 100, 500 110, 500 100, 100 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-20: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (100 100, 501 110, 501 100, 100 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-21: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (120 100, 130 200, 200 200, 200 100, 120 100))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-22: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (120 100, 17 200, 200 200, 200 100, 120 100))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-23: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-24: a polygon overlapping a very skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-25: two skinny polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (101 99, 101 1000000, 102 1000000, 101 99))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-26: two skinny polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (100 100, 200 101, 200 100, 100 100))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/A-6-26: two polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
- <a>
- POLYGON(
- (16 319, 150 39, 25 302, 160 20, 265 20, 127 317, 16 319))
- </a>
- <b>
- POLYGON(
- (10 307, 22 307, 153 34, 22 34, 10 307))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-1: the closing point of a polygon touching the closing points of another polygon and its hole [dim(0){A.A.Bdy.CP = B.A.oBdy.CP}, dim(0){A.A.Bdy.CP = B.A.iBdy.CP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- (160 200, 310 20, 20 20, 160 200),
- (160 200, 260 40, 70 40, 160 200))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-2: the boundary of a polygon touching the inner boundary of another polygon at two spots [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.SP}, dim(0){A.A.oBdy.V = B.A.iBdy.V}]</desc>
- <a>
- POLYGON(
- (170 120, 240 100, 260 50, 190 70, 170 120))
- </a>
- <b>
- POLYGON(
- (150 150, 410 150, 280 20, 20 20, 150 150),
- (170 120, 330 120, 260 50, 100 50, 170 120))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-3: the boundary of a polygon touching the inner boundary of another polygon at two spots [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.SP}, dim(0){A.A.oBdy.V = B.A.iBdy.V}]</desc>
- <a>
- POLYGON(
- (270 90, 200 50, 150 80, 210 120, 270 90))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-4: the boundary of a polygon touching the inner boundary of another polygon at one spot [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.SP}]</desc>
- <a>
- POLYGON(
- (170 120, 260 100, 240 60, 150 80, 170 120))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-5: the boundary of a polygon touching the inner boundary of another polygon at one spot [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.NV}]</desc>
- <a>
- POLYGON(
- (220 120, 270 80, 200 60, 160 100, 220 120))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-6: the boundary of a polygon touching the inner boundary of another polygon at one spot [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.V}]</desc>
- <a>
- POLYGON(
- (260 50, 180 70, 180 110, 260 90, 260 50))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-7: the boundary of a polygon touching the inner boundary of another polygon at two spots [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.V = B.A.iBdy.NV}, dim(0){A.A.oBdy.V = B.A.iBdy.NV}]</desc>
- <a>
- POLYGON(
- (230 110, 290 80, 190 60, 140 90, 230 110))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-8: the boundary of a polygon touching the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.SP-EP = B.A.iBdy.SP-EP}]</desc>
- <a>
- POLYGON(
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF2F1F212">true</op>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-9: part of the boundary of a polygon touching part of the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.SP-V = B.A.iBdy.SP-NV}, dim(1){A.A.oBdy.V-EP = B.A.iBdy.NV-EP}]</desc>
- <a>
- POLYGON(
- (170 120, 330 120, 280 70, 120 70, 170 120))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-10: part of the boundary of a polygon touching part of the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.SP-V = B.A.iBdy.SP-NV}, dim(1){A.A.oBdy.V-EP = B.A.iBdy.NV-EP}]</desc>
- <a>
- POLYGON(
- (170 120, 300 120, 250 70, 120 70, 170 120))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-3-11: part of the boundary of a polygon touching part of the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.V-V-V = B.A.iBdy.NV-V-NV}]</desc>
- <a>
- POLYGON(
- (190 100, 310 100, 260 50, 140 50, 190 100))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-5-1: an entire polygon within another polygon which has a hole [dim(2){A.A.Ext = B.A.Int}, dim(2){A.A.Int = B.A.Int}]</desc>
- <a>
- POLYGON(
- (280 130, 360 130, 270 40, 190 40, 280 130))
- </a>
- <b>
- POLYGON(
- (170 120, 250 120, 180 50, 100 50, 170 120))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="2FF1FF212">true</op>
- </test>
-</case>
-<case>
-<desc>A/Ah-5-2: an entire polygon within another polygon which has a hole [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}]</desc>
- <a>
- POLYGON(
- (220 80, 180 40, 80 40, 170 130, 270 130, 230 90, 300 90, 250 30, 280 30,
- 390 140, 150 140, 40 30, 230 30, 280 80, 220 80))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-5-3: polygon A within polygon B, the boundary of A touching the inner boundary of B [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}, dim(1){A.A.Bdy.NV-NV = B.A.iBdy.V-V}]</desc>
- <a>
- POLYGON(
- (260 130, 360 130, 280 40, 170 40, 260 130))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="2FF11F212">true</op>
- </test>
-</case>
-<case>
-<desc>A/Ah-5-4: polygon A within polygon B, the boundary of A touching the inner boundary of B [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}, dim(1){A.A.Bdy.V-V = B.A.iBdy.NV-NV}]</desc>
- <a>
- POLYGON(
- (240 110, 340 110, 290 60, 190 60, 240 110))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/Ah-5-5: polygon A within polygon B, the boundary of A touching the inner boundary of B [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}, dim(1){A.A.Bdy.V-V = B.A.iBdy.V-V}]</desc>
- <a>
- POLYGON(
- (250 120, 350 120, 280 50, 180 50, 250 120))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>Ah/Ah-1-1: same polygons (with a hole) [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.oBdy.SP-EP = B.A.oBdy.SP-EP}, dim(1){A.A.iBdy.SP-EP = B.A.iBdy.SP-EP}]</desc>
- <a>
- POLYGON(
- (230 210, 230 20, 20 20, 20 210, 230 210),
- (120 180, 50 50, 200 50, 120 180))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A2h/A2h-1-1: same polygons (with two holes) [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.oBdy.SP-EP = B.A.oBdy.SP-EP}, dim(1){A.A.iBdy.SP-EP = B.A.iBdy.SP-EP}]</desc>
- <a>
- POLYGON(
- (140 40, 40 40, 40 170, 140 40),
- (110 190, 210 190, 210 50, 110 190))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/mA-3-1: a polygon touching multipolygon at two points [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.CP = B.2A2.oBdy.NV}, dim(0){A.A.oBdy.V = B.2A1.oBdy.NV}]</desc>
- <a>
- POLYGON(
- (280 190, 330 150, 200 110, 150 150, 280 190))
- </a>
- <b>
- MULTIPOLYGON(
- (140 110, 260 110, 170 20, 50 20, 140 110)),
- (300 270, 420 270, 340 190, 220 190, 300 270)))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/mA-3-2: a polygon touching multipolygon at two points [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.V = B.2A1.oBdy.CP}, dim(0){A.A.oBdy.V = B.2A2.oBdy.V}]</desc>
- <a>
- POLYGON(
- (80 190, 220 190, 140 110, 0 110, 80 190))
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/mA-3-3: a polygon touching multipolygon at two points [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.V = B.2A2.oBdy.NV}, dim(0){A.A.oBdy.V = B.2A1.oBdy.NV}]</desc>
- <a>
- POLYGON(
- (330 150, 200 110, 150 150, 280 190, 330 150))
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/mA-3-4: a polygon touching multipolygon at one spoint [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.V = B.2A2.oBdy.NV}]</desc>
- <a>
- POLYGON(
- (290 190, 340 150, 220 120, 170 170, 290 190))
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/mA-3-5: a polygon touching multipolygon along boundaries [dim(2){A.A.Int = B.2A.Ext}, dim(1){A.A.oBdy.SP-V = B.2A2.oBdy.V-V}, dim(1){A.A.oBdy.V-V = B.2A1.oBdy.V-SP}]</desc>
- <a>
- POLYGON(
- (220 190, 340 190, 260 110, 140 110, 220 190))
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/mA-3-6: a polygon touching multipolygon along boundaries and at a point [dim(2){A.A.Int = B.2A.Ext}, dim(1){A.A.oBdy.V-NV = B.2A1.oBdy.NV-SP}, dim(0){A.A.oBdy.V = B.2A2.oBdy.V}]</desc>
- <a>
- POLYGON(
- (140 190, 220 190, 100 70, 20 70, 140 190))
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>A/mA-6-1: a polygon overlapping multipolygon [dim(2){A.A.Int = B.4A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}]</desc>
- <a>
- POLYGON(
- (140 220, 60 140, 140 60, 220 140, 140 220))
- </a>
- <b>
- MULTIPOLYGON(
- (100 20, 180 20, 180 100, 100 100, 100 20)),
- (20 100, 100 100, 100 180, 20 180, 20 100)),
- (100 180, 180 180, 180 260, 100 260, 100 180)),
- (180 100, 260 100, 260 180, 180 180, 180 100)))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="21210F212">true</op>
- </test>
-</case>
-<case>
-<desc>mA/mA-3-1: MultiPolygon touching MultiPolygon [dim(0){A.mA.Bdy.TP = B.mA.Bdy.TP}]</desc>
- <a>
- MULTIPOLYGON(
- (110 110, 70 200, 150 200, 110 110)),
- (110 110, 150 20, 70 20, 110 110)))
- </a>
- <b>
- MULTIPOLYGON(
- (110 110, 160 160, 210 110, 160 60, 110 110)),
- (110 110, 60 60, 10 110, 60 160, 110 110)))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mAh/mAh-3-1: MultiPolygon touching MultiPolygon [dim(0){A.mA.Bdy.TP = B.mA.Bdy.TP}]</desc>
- <a>
- MULTIPOLYGON(
- (110 110, 70 200, 150 200, 110 110),
- (110 110, 100 180, 120 180, 110 110)),
- (110 110, 150 20, 70 20, 110 110),
- (110 110, 120 40, 100 40, 110 110)))
- </a>
- <b>
- MULTIPOLYGON(
- (110 110, 160 160, 210 110, 160 60, 110 110),
- (110 110, 160 130, 160 90, 110 110)),
- (110 110, 60 60, 10 110, 60 160, 110 110),
- (110 110, 60 90, 60 130, 110 110)))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mAh/mAh-3-2: MultiPolygon touching MultiPolygon [dim(1){A.mA.Bdy.NV-EP = B.mA.Bdy.V-SP}, dim(1){A.mA.Bdy.SP-NV = B.mA.Bdy.EP-V}]</desc>
- <a>
- MULTIPOLYGON(
- (110 110, 70 200, 200 200, 110 110),
- (110 110, 200 20, 70 20, 110 110),
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mAh/mAh-3-3: MultiPolygon touching MultiPolygon [dim(1){A.mA.Bdy.SP-NV = B.mA.Bdy.EP-V}, dim(1){A.mA.Bdy.NV-EP = B.mA.Bdy.V-SP}, dim(1){A.mA.Bdy.NV-EP = B.mA.Bdy.V-SP}, dim(1){A.mA.Bdy.SP-NV = B.mA.Bdy.EP-V}]</desc>
- <a>
- MULTIPOLYGON(
- (110 110, 20 200, 200 200, 110 110),
- (110 110, 200 20, 20 20, 110 110),
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mAh/mAh-6-1: MultiPolygon touching MultiPolygon [dim(2){A.mA.Int = B.mA.Int}]</desc>
- <a>
- MULTIPOLYGON(
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mAh/mAh-6-2: MultiPolygon touching MultiPolygon [dim(2){A.mA.Int = B.mA.Int}]</desc>
- <a>
- MULTIPOLYGON(
- </a>
- <b>
- MULTIPOLYGON(
- (110 110, 70 200, 210 110, 70 20, 110 110),
- (110 110, 110 140, 150 110, 110 80, 110 110)),
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>AC A-shells overlapping B-shell at A-vertex</desc>
- <a>
- POLYGON(
- (100 60, 140 100, 100 140, 60 100, 100 60))
- </a>
- <b>
- MULTIPOLYGON(
- (80 40, 120 40, 120 80, 80 80, 80 40)),
- (120 80, 160 80, 160 120, 120 120, 120 80)),
- (80 120, 120 120, 120 160, 80 160, 80 120)),
- (40 80, 80 80, 80 120, 40 120, 40 80)))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A-3-1: a line touching the closing point of a polygon [dim(0){A.L.Bdy.SP = B.oBdy.CP}]</desc>
- <a>
- LINESTRING(150 150, 40 230)
- </a>
- <b>
- POLYGON(
- (150 150, 410 150, 280 20, 20 20, 150 150))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF1F00212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-3-2: the start and end points of a LineString touching the boundary (at non-vertices) of a polygon [dim(0){A.L.Bdy.SP = B.oBdy.NV}, dim(0){A.L.Bdy.EP = B.oBdy.NV}]</desc>
- <a>
- LINESTRING(40 40, 50 130, 130 130)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF1F0F212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-3-3: the end point of a line touching the closing point of a polygon [dim(0){A.L.Bdy.EP = B.oBdy.CP}]</desc>
- <a>
- LINESTRING(40 230, 150 150)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A-3-4: an entire LineString touching the boundary (at non-vertices) of a polygon [dim(1){A.L.Int.SP-EP = B.oBdy.NV-NV}]</desc>
- <a>
- LINESTRING(210 150, 330 150)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F1FF0F212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-3-5: the start portion of a LineString touching the boundary (at non-vertices) of a polygon [dim(1){A.L.Int.SP-V = B.oBdy.NV-NV}]</desc>
- <a>
- LINESTRING(200 150, 310 150, 360 220)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F11F00212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-3-6: the start portion and the end point of a LineString touching the boundary of a polygon [dim(1){A.L.Int.SP-V = B.oBdy.NV-NV}, dim(0){A.L.Bdy.EP = B.A.oBdy.V}]</desc>
- <a>
- LINESTRING(180 150, 250 150, 230 250, 370 250, 410 150)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F11F0F212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-3-7: the middle portion of a LineString touching the boundary (at non-vertices) of a polygon [dim(1){A.L.Int.V-V = B.oBdy.NV-NV}]</desc>
- <a>
- LINESTRING(210 210, 220 150, 320 150, 370 210)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F11FF0212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-4-1: a line at non-vertex crossing non-vertex boundary of polygon [dim(0){A.L.Int.NV = B.A.oBdy.NV}, dim(1){A.L.Int.NV-EP = B.A.Int}]</desc>
- <a>
- LINESTRING(20 60, 150 60)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1010F0212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-4-2: a line at non-vertex crossing non-vertex boundaries of polygon twice [dim(0){A.L.Int.NV = B.A.oBdy.NV}, dim(1){A.L.Int.NV-NV = B.A.Int}]</desc>
- <a>
- LINESTRING(60 90, 310 180)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="101FF0212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-4-3: a line at non-vertex crossing vertex boundary of polygon [dim(0){A.L.Int.NV = B.A.oBdy.V}, dim(1){A.L.Int.NV-EP = B.A.Int}]</desc>
- <a>
- LINESTRING(90 210, 210 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A-4-4: a line at non-vertex crossing vertex boundaries of polygon twice [dim(0){A.L.Int.NV = B.A.oBdy.V}, dim(1){A.L.Int.NV-NV = B.A.Int}, dim(0){A.L.Int.NV = B.A.oBdy.CP}]</desc>
- <a>
- LINESTRING(290 10, 130 170)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A-4-5: a line at vertex crossing non-vertex boundary of polygon [dim(0){A.L.Int.V = B.A.oBdy.NV}, dim(1){A.L.Int.V-EP = B.A.Int}]</desc>
- <a>
- LINESTRING(30 100, 100 100, 180 100)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A-4-6: a line at vertex crossing non-vertex boundaries of polygon twice [dim(0){A.L.Int.V = B.A.oBdy.NV}, dim(1){A.L.Int.V-V = B.A.Int}]</desc>
- <a>
- LINESTRING(20 100, 100 100, 360 100, 410 100)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A-4-7: a line at vertex crossing vertex boundary of polygon [dim(0){A.L.Int.V = B.A.oBdy.V}, dim(1){A.L.Int.V-EP = B.A.Int}]</desc>
- <a>
- LINESTRING(90 210, 150 150, 210 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A-5-1: an entire line within a polygon [dim(1){A.L.Int.SP-EP = B.A.Int}]</desc>
- <a>
- LINESTRING(180 90, 280 120)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1FF0FF212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-5-2: a line within a polygon but the line's both ends touching the boundary of the polygon [dim(1){A.L.Int.SP-EP = B.A.Int}, dim(0){A.L.Bdy.SP = B.oBdy.NV}, dim(0){A.L.Bdy.EP = B.oBdy.NV}]</desc>
- <a>
- LINESTRING(70 70, 80 20)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1FFF0F212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-5-3: a line within a polygon but the line's start point touching the boundary of the polygon [dim(1){A.L.Int.SP-EP = B.A.Int}, dim(0){A.L.Bdy.SP = B.oBdy.NV}]</desc>
- <a>
- LINESTRING(130 20, 150 60)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1FF00F212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-5-4: a line within a polygon but the line's start point and middle portion touching the boundary of the polygon [dim(1){A.L.Int.SP-V = B.A.Int}, dim(1){A.L.Int.V-V = B.oBdy.NV-NV}, dim(1){A.L.Int.V-EP = B.A.Int}, dim(0){A.L.Bdy.SP = B.A.oBdy.NV}]</desc>
- <a>
- LINESTRING(70 70, 80 20, 140 20, 150 60)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="11F00F212">true</op>
- </test>
-</case>
-<case>
-<desc>L/A-5-5: a line within a polygon but the line's middle portion touching the boundary of the polygon [dim(1){A.L.Int.SP-V = B.A.Int}, dim(1){A.L.Int.V-V = B.A.oBdy.NV-NV}, dim(1){A.L.Int.V-EP = B.A.Int}]</desc>
- <a>
- LINESTRING(170 50, 170 20, 240 20, 260 60)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="11F0FF212">true</op>
- </test>
-</case>
-<case>
-<desc>L/Ah-2-1: a line outside a polygon [dim(1){A.L.Int.SP-EP = B.A.Ext}]</desc>
- <a>
- LINESTRING(50 100, 140 190, 280 190)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF1FF0212">true</op>
- </test>
-</case>
-<case>
-<desc>L/Ah-2-2: a line inside a polygon's hole [dim(1){A.L.Int.SP-EP = B.A.Ext.h}]</desc>
- <a>
- LINESTRING(140 60, 180 100, 290 100)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-1: the start point of a line touching the inner boundary of a polygon [dim(0){A.L.Bdy.SP = B.A.iBdy.CP}, dim(1){A.L.Int.SP-EP = B.A.Ext.h}]</desc>
- <a>
- LINESTRING(170 120, 210 80, 270 80)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-2: both ends of a line touching the inner boundary of a polygon [dim(0){A.L.Bdy.SP = B.A.iBdy.CP}, dim(1){A.L.Int.SP-EP = B.A.Ext.h}, dim(0){A.L.Bdy.SP = B.A.iBdy.CP}]</desc>
- <a>
- LINESTRING(170 120, 260 50)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-1: both ends of a line touching the inner boundary of a polygon [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
- <a>
- LINESTRING(190 90, 190 270)
- </a>
- <b>
- POLYGON(
- (190 190, 360 20, 20 20, 190 190),
- (190 190, 280 50, 100 50, 190 190))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F01FF0212">true</op>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-2: a line at a non-vertex crossing the boundary of a polygon where the closing point of the hole touches the shell at a non-vertex [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
- <a>
- LINESTRING(60 160, 150 70)
- </a>
- <b>
- POLYGON(
- (110 110, 250 100, 140 30, 110 110))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-3: a line at a non-vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a non-vertex [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
- <a>
- </a>
- <b>
- POLYGON(
- (190 190, 20 20, 360 20, 190 190),
- (250 100, 110 110, 140 30, 250 100))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-4: a line at a non-vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a vertex [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
- <a>
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-5: a line crossing polygon boundary where the closing point of the hole touches the shell at a vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
- <a>
- LINESTRING(190 90, 190 190, 190 270)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-6: a line at a vertex crossing the boundary of a polygon where closing point of the hole touches the shell at a non-vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
- <a>
- LINESTRING(60 160, 110 110, 150 70)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-7: a line at a vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a non-vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
- <a>
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/Ah-3-8: a line at a non-vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
- <a>
- </a>
- <b>
- POLYGON(
- (190 190, 110 110, 20 20, 360 20, 190 190),
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A2h-3-1: the start point a line touching the closing points of two connected holes in a polygon [dim(0){A.L.Int.SP = B.A.iBdy.TP}]</desc>
- <a>
- LINESTRING(130 110, 180 110, 190 60)
- </a>
- <b>
- POLYGON(
- (20 200, 240 200, 240 20, 20 20, 20 200),
- (130 110, 60 180, 60 40, 130 110),
- (130 110, 200 40, 200 180, 130 110))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A2h-3-2: the interior (at a non-vertex) of a line touching the closing points of two connected holes in a polygon [dim(0){A.L.Int.NV = B.A.iBdy.TP}]</desc>
- <a>
- LINESTRING(80 110, 180 110)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A2h-3-3: the interior (at a non-vertex) of a line touching the closing point and at a vertex of two connected holes in a polygon [dim(0){A.L.Int.NV = B.A.iBdy1.TP}]</desc>
- <a>
- </a>
- <b>
- POLYGON(
- (20 200, 20 20, 240 20, 240 200, 20 200),
- (60 180, 130 110, 60 40, 60 180),
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A2h-3-4: the interior (at a non-vertex) of a line touching the closing point and at a non-vertex of two connected holes in a polygon [dim(0){A.L.Int.NV = B.A.iBdy.TP}]</desc>
- <a>
- LINESTRING(80 110, 170 110)
- </a>
- <b>
- POLYGON(
- (130 110, 60 40, 60 180, 130 110),
- (130 180, 130 40, 200 110, 130 180))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A2h-3-5: the start point a line touching the closing point and a non-vertex of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy.TP}]</desc>
- <a>
- LINESTRING(80 110, 130 110, 170 110)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A2h-3-6: the interior (at a vertex) of a line touching the closing points of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy.TP}]</desc>
- <a>
- LINESTRING(80 110, 130 110, 180 110)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A2h-3-7: the interior (at a vertex) of a line touching the closing point and at a vertex of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy1.TP}]</desc>
- <a>
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/A2h-3-8: the interior (at a vertex) of a line touching the closing point and at a non-vertex of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy.TP}]</desc>
- <a>
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/mA-4-1: a line intersecting the interior and exterior of MultiPolygon [dim(1){A.L.Int.SP-NV = B.2A1.Int}, dim (1){A.L.Int.NV-EP = B.2A2.Int}]</desc>
- <a>
- LINESTRING(160 70, 320 230)
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1010FF212">true</op>
- </test>
-</case>
-<case>
-<desc>L/mA-4-2: a line intersecting the interior and exterior of MultiPolygon [dim(1){A.L.Int.SP-V = B.2A1.Int}, dim (1){A.L.Int.V-EP = B.2A2.Int}]</desc>
- <a>
- LINESTRING(160 70, 200 110, 280 190, 320 230)
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/mA-5-1: a line within two connected polygons [dim(1){A.L.Int = B.2A.Int}, dim(0){A.L.Int.NV = B.2A.Bdy.TP]</desc>
- <a>
- LINESTRING(70 50, 70 150)
- </a>
- <b>
- MULTIPOLYGON(
- (0 0, 0 100, 140 100, 140 0, 0 0)),
- (20 170, 70 100, 130 170, 20 170)))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="10F0FF212">true</op>
- </test>
-</case>
-<case>
-<desc>RL/A-3-1: a LinearRing touching a polygon's closing point [dim(0){A.RL.Int.CP = B.A.Bdy.CP}]</desc>
- <a>
- LINESTRING(110 110, 20 200, 200 200, 110 110)
- </a>
- <b>
- POLYGON(
- (20 20, 200 20, 110 110, 20 20))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F01FFF212">true</op>
- </test>
-</case>
-<case>
-<desc>RL/A-3-2: a LinearRing touching a polygon's boundary at a non-vertex [dim(0){A.RL.Int.CP = B.A.Bdy.NV}]</desc>
- <a>
- LINESTRING(150 70, 160 110, 200 60, 150 70)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>RL/A-3-3: a LinearRing touching a polygon's boundary at a non-vertex [dim(0){A.RL.Int.CP = B.A.iBdy.NV}]</desc>
- <a>
- LINESTRING(80 60, 120 40, 120 70, 80 60)
- </a>
- <b>
- POLYGON(
- (110 90, 50 30, 170 30, 110 90))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>RL/A-3-4: a LinearRing on the boundary of a polygon [dim(1){A.RL.Int.SP-EP = B.A.Bdy.SP-EP}]</desc>
- <a>
- LINESTRING(20 20, 200 20, 110 110, 20 20)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F1FFFF2F2">true</op>
- </test>
-</case>
-<case>
-<desc>RL/A-3-5: a LinearRing on the inner boundary of a polygon [dim(1){A.RL.Int.SP-EP = B.A.iBdy.SP-EP}]</desc>
- <a>
- LINESTRING(110 90, 170 30, 50 30, 110 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F1FFFF212">true</op>
- </test>
-</case>
-<case>
-<desc>RL/A-3-6: a LinearRing on the inner boundary of a polygon [dim(1){A.RL.Int.SP-V = B.A.oBdy.SP-NV}]</desc>
- <a>
- LINESTRING(110 110, 170 50, 170 110, 110 110)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F11FFF212">true</op>
- </test>
-</case>
-<case>
-<desc>RL/A-3-7: a LinearRing on the inner boundary of a polygon [dim(1){A.RL.Int.SP-V = B.A.iBdy.SP-NV}]</desc>
- <a>
- LINESTRING(110 90, 70 50, 130 50, 110 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>RL/A-4-1: a LinearRing crossing a polygon [dim(1){A.RL.Int.CP-NV = B.A.Int}, dim(0){A.L.Int.NV = B.A.Bdy.NV}]</desc>
- <a>
- LINESTRING(110 60, 20 150, 200 150, 110 60)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="101FFF212">true</op>
- </test>
-</case>
-<case>
-<desc>RL/A-4-2: a LinearRing crossing a polygon with a hole [dim(1){A.RL.Int.NV-NV = B.A.Int}, dim(0){A.RL.Int.NV = B.A.oBdy.CP}, dim(0){A.RL.Int.NV = B.A.iBdy.CP}, dim(0){A.RL.Int.NV = B.A.oBdy.NV}, dim(0){A.RL.Int.NV = B.A.iBdy.NV}]</desc>
- <a>
- LINESTRING(110 130, 110 70, 200 100, 110 130)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>RL/A-5-1: a LinearRing within a polygon [dim(1){A.RL.Int.SP-EP = B.A.Int}]</desc>
- <a>
- LINESTRING(110 90, 160 40, 60 40, 110 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1FFFFF212">true</op>
- </test>
-</case>
-<case>
-<desc>RL/A-5-2: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}]</desc>
- <a>
- LINESTRING(110 100, 40 30, 180 30, 110 100)
- </a>
- <b>
- POLYGON(
- (110 90, 60 40, 160 40, 110 90))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>RL/A-5-3: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}, dim(0){A.L.Int.CP = B.A.oBdy.CP}]</desc>
- <a>
- LINESTRING(110 110, 180 30, 40 30, 110 110)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="10FFFF212">true</op>
- </test>
-</case>
-<case>
-<desc>RL/A-5-4: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}, dim(0){A.RL.Int.CP = B.A.iBdy.CP}]</desc>
- <a>
- LINESTRING(110 90, 180 30, 40 30, 110 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>RL/A-5-5: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}, dim(1){A.RL.Int.SP-NV = B.A.Bdy.iBdy.SP-V}]</desc>
- <a>
- LINESTRING(110 90, 50 30, 180 30, 110 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="11FFFF212">true</op>
- </test>
-</case>
-<case>
-<desc>nsL/A-3-1: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SP = B.A.Bdy.CP}]</desc>
- <a>
- LINESTRING(110 110, 200 200, 200 110, 110 200)
- </a>
- <b>
- POLYGON(
- (110 110, 200 20, 20 20, 110 110))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/A-3-2: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SPb = B.A.Bdy.CP}]</desc>
- <a>
- LINESTRING(110 110, 200 200, 110 110, 20 200, 20 110, 200 110)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/A-3-3: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SPo = B.A.Bdy.CP}]</desc>
- <a>
- LINESTRING(110 110, 20 110, 200 110, 50 110, 110 170)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/A-3-4: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SPx = B.A.Bdy.CP}]</desc>
- <a>
- LINESTRING(110 110, 20 200, 110 200, 110 110, 200 200)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/A-3-5: a non-simple LineString touching a polygon [dim(1){A.nsL.Int.SPb-Vo = B.A.Bdy.SP-NV}]</desc>
- <a>
- LINESTRING(110 110, 170 50, 20 200, 20 110, 200 110)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/A-4-1: a non-simple LineString crossing a polygon [dim(1){A.nsL.Int.V-V-NV = B.A.Int}, dim(1){A.nsL.SPx-V = B.A.Bdy.SP-NV}]</desc>
- <a>
- LINESTRING(110 110, 180 40, 110 40, 110 180)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="111F00212">true</op>
- </test>
-</case>
-<case>
-<desc>nsL/A-5-1: a non-simple LineString within a polygon [dim(1){A.nsL.Int.SPx-EP = B.A.Int}]</desc>
- <a>
- LINESTRING(110 60, 50 30, 170 30, 90 70)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/A-5-2: a non-simple LineString within a polygon [dim(1){A.nsL.Int.SPx-EP = B.A.Int}, dim(1){A.nsL.Int.SPx-V = B.A.Bdy.SP-NV}]</desc>
- <a>
- LINESTRING(110 110, 180 40, 110 40, 110 110, 70 40)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/Ah: the self-crossing point of a non-simple LineString touching the closing point of the inner boundary of a polygon [dim(0){A.nsL.Int.V = B.A.iBdy.CP}]</desc>
- <a>
- LINESTRING(230 70, 170 120, 190 60, 140 60, 170 120, 270 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/A-3-1: MultiLineString touching a polygon's closing point [dim(0){A.mL.Bdy.SPb = B.A.Bdy.CP}]</desc>
- <a>
- MULTILINESTRING(
- (20 110, 200 110),
- (200 200, 110 110, 20 210, 110 110))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/A-3-2: MultiLineString touching a polygon's closing point [dim(0){A.mL.Bdy.SPo = B.A.Bdy.CP}]</desc>
- <a>
- MULTILINESTRING(
- (60 180, 60 110, 160 110, 110 110))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/A-3-3: MultiLineString touching a polygon's closing point [dim(0){A.mL.Bdy.SPx = B.A.Bdy.CP}]</desc>
- <a>
- MULTILINESTRING(
- (200 200, 110 110, 20 200, 110 200, 110 110))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/A-4-1: MultiLineString crossing a polygon [dim(1){A.mL.Int.SP-NVb = B.A.Int}, dim(0){A.mL.Int.NVb = B.A.Bdy.CP}]</desc>
- <a>
- MULTILINESTRING(
- (110 50, 110 170, 110 70, 110 150, 200 150))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/A-4-2: MultiLineString crossing a polygon [dim(1){A.mL.Int.SP-NVo = B.A.Int}, dim(0){A.mL.Int.NVo = B.A.Bdy.CP}]</desc>
- <a>
- MULTILINESTRING(
- (50 110, 170 110, 110 170, 110 50, 110 170, 110 50))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/A-4-3: MultiLineString crossing a polygon [dim(1){A.mL.Int.SP-NVx = B.A.Int}, dim(0){A.mL.Int.NVx = B.A.Bdy.CP}]</desc>
- <a>
- MULTILINESTRING(
- (110 60, 110 160, 200 160))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/A-4-4: MultiLineString crossing a polygon [dim(1){A.mL.Int.Vb-Vb = B.A.Int}, dim(0){A.mL.Int.Vb = B.A.oBdy.CP}, dim(0){A.mL.Int.Vb = B.A.iBdy.CP}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/A-5-1: MultiLineString within a polygon [dim(1){A.mL.Int.SP-EP = B.A.Int}]</desc>
- <a>
- MULTILINESTRING(
- (110 100, 40 30, 180 30),
- (170 30, 110 90, 50 30))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/A-5-2: MultiLineString within a polygon [dim(1){A.mL.Int.SP-EP = B.A.Int}]</desc>
- <a>
- MULTILINESTRING(
- (110 110, 60 40, 70 20, 150 20, 170 40),
- (180 30, 40 30, 110 80))
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mA-3-1: MultiLineString within a MultiPolygon [dim(0){A.mL.Bdy.SPb = B.mA.Bdy.TP}]</desc>
- <a>
- MULTILINESTRING(
- (20 110, 200 110, 200 160),
- (110 110, 200 110, 200 70, 20 150))
- </a>
- <b>
- MULTIPOLYGON(
- (110 110, 20 20, 200 20, 110 110)),
- (110 110, 20 200, 200 200, 110 110)))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mA-3-2: MultiLineString within a MultiPolygon [dim(0){A.mL.Bdy.SPo = B.mA.Bdy.TP}]</desc>
- <a>
- MULTILINESTRING(
- (20 160, 70 110, 150 110, 200 160),
- (110 110, 20 110, 50 80, 70 110, 200 110))
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mA-3-3: MultiLineString within a MultiPolygon [dim(0){A.mL.Bdy.SPx = B.mA.Bdy.TP}]</desc>
- <a>
- MULTILINESTRING(
- (110 110, 20 170, 20 130, 200 90))
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LC - topographically equal with no boundary</desc>
- <a>
- LINESTRING(0 0, 0 50, 50 50, 50 0, 0 0)
- </a>
- <b>
- MULTILINESTRING(
- (0 0, 0 50),
- (0 50, 50 50),
- (50 50, 50 0),
- (50 0, 0 0))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1FFFFFFF2">true</op>
- </test>
-</case>
-<case>
-<desc>LC - intersection (containment) along mod-2 A-Int line segment</desc>
- <a>
- LINESTRING(40 180, 140 180)
- </a>
- <b>
- MULTIPOLYGON(
- (20 320, 180 320, 180 180, 20 180, 20 320)),
- (20 180, 20 80, 180 80, 180 180, 20 180)))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LC - intersection (overlap) along mod-2 A-Int line segment</desc>
- <a>
- </a>
- <b>
- MULTIPOLYGON(
- (60 180, 60 80, 180 80, 180 180, 60 180)))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LC - equal with boundary intersection</desc>
- <a>
- LINESTRING(0 0, 60 0, 60 60, 60 0, 120 0)
- </a>
- <b>
- MULTILINESTRING(
- (0 0, 60 0),
- (60 0, 120 0),
- (60 0, 60 60))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="10FF0FFF2">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.1-3-1: touching at the start points of two lines [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}]</desc>
- <a>
- LINESTRING(40 40, 120 120)
- </a>
- <b>
- LINESTRING(40 40, 60 120)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF1F00102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.1-3-2: start point of one line touching end point of another line [dim(0){A.L.Bdy.SP = B.L.Bdy.EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(60 240, 40 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.1-3-3: start point of a line touching the interior of another line at a non-vertex [dim(0){A.L.Bdy.SP = B.L.Int.NV}]</desc>
- <a>
- LINESTRING(40 40, 180 180)
- </a>
- <b>
- LINESTRING(120 120, 20 200)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F01FF0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.1-3-4: touching at the end points of two lines [dim(0){A.L.Bdy.EP = B.L.Bdy.EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(60 240, 120 120)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.1-3-5: end point of a line touching the interior of another line at a non-vertex [dim(0){A.L.Bdy.EP = B.L.Int.NV}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(20 180, 140 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.1-4-1: two lines crossing at non-vertex [dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(40 120, 120 40)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F1FF0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.1-1-1: equal pointwise [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
- <a>
- LINESTRING(40 40, 100 100)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1FFF0FFF2">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.1-1-2: equal lines but points in reverse sequence [dim(1){A.L.Int.SP-EP = B.L.Int.EP-SP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(100 100, 40 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.1-2-1: dim(1){A.L.Int.SP-EP = B.L.Ext}</desc>
- <a>
- </a>
- <b>
- LINESTRING(40 120, 120 160)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF1FF0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.1-5-1: line A containing line B [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
- <a>
- LINESTRING(20 20, 180 180)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.1-5-2: line B is part of line A [dim(1){A.L.Int.SP-NV) = B.L.Int.SP-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(20 20, 110 110)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="101F00FF2">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.1-5-3: Line B is part of line A (in the middle portion) [dim(1){A.L.Int.NV-NV = B.L.Int.SP-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(50 50, 140 140)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="101FF0FF2">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.1-6-1: start portions of two lines overlapping [dim(1){A.L.Int.SP-NV = B.L.Int.SP-NV]</desc>
- <a>
- LINESTRING(180 180, 40 40)
- </a>
- <b>
- LINESTRING(120 120, 260 260)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1010F0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.1-6-2: end portions of two lines overlapping [dim(1){A.L.Int.NV-EP = B.L.Int.NV-EP]</desc>
- <a>
- </a>
- <b>
- LINESTRING(260 260, 120 120)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.1-6-3: end portion of line A overlapping the start portion of line B [dim(1){A.L.Int.NV-EP = B.L.Int.SP-NV]</desc>
- <a>
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-1: two LineStrings touching at start points [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}]</desc>
- <a>
- LINESTRING(40 40, 100 100, 200 120, 80 240)
- </a>
- <b>
- LINESTRING(40 40, 20 100, 40 160, 20 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-2: start point of LineStrings A touching the end point of LineString B [dim(0){A.L.Bdy.SP = B.L.Bdy.EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(20 200, 40 160, 20 100, 40 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-3: two LineStrings touching at end points [dim(0){A.L.Bdy.EP = B.L.Bdy.EP}]</desc>
- <a>
- LINESTRING(80 240, 200 120, 100 100, 40 40)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-4: both the start and end points of LineString A touching the interior of LineString B at two vertices [dim(0){A.L.Bdy.SP = B.L.Int.V}, dim(0){A.L.Bdy.EP = B.L.Int.V}]</desc>
- <a>
- LINESTRING(60 60, 60 230, 140 230, 250 160)
- </a>
- <b>
- LINESTRING(20 20, 60 60, 250 160, 310 230)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF10FF102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-5: both the start and end points of LineString A touching the interior of LineString B at two non-vertices [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Bdy.EP = B.L.Int.NV}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(20 20, 110 110, 200 110, 320 230)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-6: the start and end points of two LineStrings touching each other [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}, dim(0){A.L.Bdy.EP = B.L.Bdy.EP}]</desc>
- <a>
- LINESTRING(60 110, 60 250, 360 210)
- </a>
- <b>
- LINESTRING(60 110, 110 160, 250 160, 310 160, 360 210)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF1F0F1F2">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-7: the start and end points of two LineStrings touching each other [dim(0){A.L.Bdy.SP = B.L.Bdy.EP}, dim(0){A.L.Bdy.EP = B.L.Bdy.SP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(360 210, 310 160, 110 160, 60 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-8: start point of LineString B touching LineString A at a non-vertex [dim(0){A.L.Int.NV = B.L.Bdy.SP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(160 160, 240 240)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-9: end point of LineString B touching LineString A at a non-vertex [dim(0){A.L.Int.NV = B.L.Bdy.EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(240 240, 160 160)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-10: both the start and end points of LineString B touching the interior of LineString A at two non-vertices [dim(0){A.L.Int.NV = B.L.Bdy.SP}, dim(0){A.L.Int.NV = B.L.Bdy.EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(60 150, 110 100, 170 100, 110 230)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F01FF01F2">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-11: the start point of LineString B touching the interior of LineString A at a non-vertex and the end point of LineString A touching the interior of LineString B at a vertex [dim(0){A.L.Int.NV = B.L.Bdy.SP}, dim(0){A.L.Bdy.EP = B.L.Int.V}]</desc>
- <a>
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F010F0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-12: start point of LineString B touching LineString A at a vertex [dim(0){A.L.Int.V = B.L.Bdy.SP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(200 120, 200 190, 150 240, 200 240)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-13: end point of LineString B touching LineString A at a vertex [dim(0){A.L.Int.V = B.L.Bdy.EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(200 240, 150 240, 200 200, 200 120)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-3-14: both the start and end points of LineString B touching the interior of LineString A at two vertices [dim(0){A.L.Int.V = B.L.Bdy.SP}, dim(0){A.L.Int.V = B.L.Bdy.EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(60 230, 80 140, 120 140, 140 230)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-1: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
- <a>
- LINESTRING(60 110, 200 110, 250 160, 300 210)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F1F00102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-2: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.SP}, dim(0){A.L.Int.V = B.L.Int.V}, dim(0){A.L.Bdy.EP = B.L.Int.EP}]</desc>
- <a>
- LINESTRING(60 110, 200 110, 250 160, 300 210, 360 210)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F1F0F1F2">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-3: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
- <a>
- LINESTRING(60 110, 220 110, 250 160, 280 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-4: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Int.SP}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Bdy.EP = B.L.Int.EP}]</desc>
- <a>
- LINESTRING(60 110, 150 110, 200 160, 250 110, 360 110, 360 210)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-5: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
- <a>
- LINESTRING(130 160, 160 110, 220 110, 250 160, 250 210)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F10F0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-6: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
- <a>
- LINESTRING(130 160, 160 110, 190 110, 230 210)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-7: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Bdy.SP = B.L.Bdy.EP}]</desc>
- <a>
- LINESTRING(130 160, 160 110, 200 110, 230 160, 260 210, 360 210)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F100F102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-8: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Bdy.EP}]</desc>
- <a>
- LINESTRING(130 160, 160 110, 200 110, 230 160, 260 210, 360 210, 380 210)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0010F0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-9: two LineStrings crossing at three points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Int.NV = B.L.Bdy.EP}]</desc>
- <a>
- LINESTRING(130 160, 160 110, 200 110, 230 160, 260 210, 380 210)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-10: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.V}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
- <a>
- LINESTRING(110 160, 160 110, 200 110, 250 160, 250 210)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-11: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Int.V}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
- <a>
- LINESTRING(110 160, 180 110, 250 160, 320 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-12: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}]</desc>
- <a>
- LINESTRING(140 160, 180 80, 220 160, 250 80)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-13: two LineStrings crossing at a vertex for one of the LineStrings [dim(0){A.L.Int.V = B.L.Int.NV}]</desc>
- <a>
- LINESTRING(40 40, 100 100, 200 120, 130 190)
- </a>
- <b>
- LINESTRING(20 130, 70 130, 160 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-14: two LineStrings crossing at non-vertices for both of the LineStrings [dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(40 160, 40 100, 110 40, 170 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-15: two LineStrings crossing on one side [dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}]</desc>
- <a>
- LINESTRING(130 110, 180 160, 230 110, 280 160, 330 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-16: two LineStrings crossing at vertices for both LineString [dim(0){A.L.Int.V = B.L.Int.V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(30 140, 80 140, 100 100, 200 30)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-17: two LineStrings crossing on one side [dim(0){A.L.Int.V = B.L.Int.V}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
- <a>
- LINESTRING(110 110, 110 160, 180 110, 250 160, 250 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-18: multiple crossings [dim(0){A.L.Int.V = B.L.Int.V}, dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
- <a>
- LINESTRING(20 20, 80 80, 160 80, 240 80, 300 140)
- </a>
- <b>
- LINESTRING(20 60, 60 60, 60 140, 80 80, 100 20, 140 140, 180 20, 200 80, 220 20,
- 240 80, 300 80, 270 110, 200 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-4-19: spiky LineStrings with multiple crossing [dim(0){A.L.Int.V = B.L.Int.V}]</desc>
- <a>
- LINESTRING(20 20, 230 20, 20 30, 170 30, 20 40, 230 40, 20 50, 230 60, 60 60,
- 230 70, 20 70, 180 80, 60 80, 230 90, 20 90, 230 100, 30 100, 210 110, 20 110,
- 80 120, 20 130, 170 130, 90 120, 230 130, 170 140, 230 140, 80 150, 160 140, 20 140,
- 70 150, 20 150, 230 160, 80 160, 230 170, 20 160, 180 170, 20 170, 230 180, 20 180,
- 40 190, 230 190, 20 200, 230 200)
- </a>
- <b>
- LINESTRING(30 210, 30 60, 40 210, 40 30, 50 190, 50 20, 60 160, 60 50, 70 220,
- 70 50, 80 20, 80 210, 90 50, 90 150, 100 30, 100 210, 110 20, 110 190, 120 50,
- 120 180, 130 210, 120 20, 140 210, 130 50, 150 210, 130 20, 160 210, 140 30, 170 210,
- 150 20, 180 210, 160 20, 190 210, 180 80, 170 50, 170 20, 180 70, 180 20, 190 190,
- 190 30, 200 210, 200 30, 210 210, 210 20, 220 150, 220 20)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="001FF0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-1-1: two equal LineStrings with equal pointwise [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
- <a>
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-1-2: two equal LineStrings with points in reverse sequence [dim(1){A.L.Int.SP-EP = B.L.Int.EP-SP}]</desc>
- <a>
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-1-3: two equal LineStrings with different number of points [dim(1){A.L.Int.SP-EP = B.L.Int.EP-SP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(80 240, 120 200, 200 120, 100 100, 80 80, 40 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-2-1: disjoint [dim(1){A.L.Int.SP-EP = B.L.Ext}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(260 210, 240 130, 280 120, 260 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-2-2: wrapping around but still disjoint [dim(1){A.L.Int.SP-EP = B.L.Ext}]</desc>
- <a>
- LINESTRING(100 20, 20 20, 20 160, 210 160, 210 20, 110 20, 50 120, 120 150, 200 150)
- </a>
- <b>
- LINESTRING(140 130, 100 110, 120 60, 170 60)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-5-1: LineString A containing LineString B, same pointwise [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
- <a>
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-5-2: LineString A containing LineString B, LineString A with less points [dim(1){A.L.Int.SP-V = B.L.Int.SP-EP}]</desc>
- <a>
- LINESTRING(60 110, 110 160, 310 160, 360 210)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-5-3: LineString A containing LineString B [dim(1){A.L.Int.SP-V = B.L.Int.SP-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(60 110, 110 160, 250 160)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-5-4: LineString A containing LineString B [dim(1){A.L.Int.NV-NV = B.L.Int.SP-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(110 160, 310 160, 340 190)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-5-5: LineString A containing LineString B [dim(1){A.L.Int.V-NV = B.L.Int.SP-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(140 160, 250 160, 310 160, 340 190)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-5-6: LineString A containing LineString B [dim(1){A.L.Int.V-V = B.L.Int.SP-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(110 160, 250 160, 310 160)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-1: start portions of two LineStrings overlapping [dim(1){A.L.Int.SP-V = B.L.Int.SP-V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(200 120, 100 100, 40 40, 140 80, 200 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-2: start portion of LineString A overlapping end portion of LineString B, intersecting at the middle of LineString A [dim(1){A.L.Int.SP-V = B.L.Int.V-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(280 240, 240 140, 200 120, 100 100, 40 40)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1F1F00102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-3: start portion of LineString A overlapping end portion of LineString B, intersecting at the middle of LineString A [dim(1){A.L.Int.SP-V = B.L.Int.NV-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(80 190, 140 140, 40 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-4: end portions of two LineStrings overlapping [dim(1){A.L.Int.NV-EP = B.L.Int.V-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(240 200, 200 260, 80 240, 140 180)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-5: end portion of LineString A overlapping start portion of LineString B [dim(1){A.L.Int.NV-EP = B.L.Int.SP-V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(140 180, 80 240, 200 260, 240 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-6: end portion of LineString A overlapping end portion of LineString B, intersecting at the middle of LineString A [dim(1){A.L.Int.V-EP = B.L.Int.V-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(280 240, 240 140, 200 120, 80 240)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-7: middle portions of two LineStrings overlapping [dim(1){A.L.Int.V-NV = B.L.Int.NV-V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(20 80, 120 80, 200 80, 260 20)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1F1FF0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-8: middle portion of LineString A overlapping start portion of LineString B [dim(1){A.L.Int.V-V = B.L.Int.SP-V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(100 100, 200 120, 240 140, 280 240)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="101FF0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-9: middle portion of LineString A overlapping end portion of LineString B [dim(1){A.L.Int.V-V = B.L.Int.V-EP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(280 240, 240 140, 200 120, 100 100)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-10: middle portions of two LineStrings overlapping [dim(1){A.L.Int.V-V = B.L.Int.V-V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(80 20, 80 80, 240 80, 300 20)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/L.2-6-11: middle portions of two LineStrings overlapping, multiple intersects [dim(1){A.L.Int.V-V = B.L.Int.V-NV}, dim(1){A.L.Int.V-V = B.L.Int.V-NV}, dim(1){A.L.Int.V-V = B.L.Int.V-NV}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(20 80, 80 80, 120 80, 140 140, 160 80, 200 80, 220 20, 240 80, 270 110,
- 300 80)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/LR-3-1: a LineString touching a LinearRing [dim(0){A.L.Bdy.SP = B.LR.Int.CP}]</desc>
- <a>
- LINESTRING(100 100, 20 180, 180 180)
- </a>
- <b>
- LINESTRING(100 100, 180 20, 20 20, 100 100)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF10F01F2">true</op>
- </test>
-</case>
-<case>
-<desc>L/LR-4-1: a LineString crossing a LinearRing [dim(0){A.L.Int.NV = B.LR.Int.CP}]</desc>
- <a>
- LINESTRING(20 100, 180 100, 100 180)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F1FF01F2">true</op>
- </test>
-</case>
-<case>
-<desc>L/LR-4-2: a LineString crossing a LinearRing [dim(0){A.L.Int.NV = B.LR.Int.CP}]</desc>
- <a>
- LINESTRING(100 40, 100 160, 180 160)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/LR-4-3: a LineString crossing a LinearRing [dim(0){A.L.Int.V = B.LR.Int.CP}]</desc>
- <a>
- LINESTRING(20 100, 100 100, 180 100, 100 180)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/LR-5-1: a LineString within a LinearRing [dim(1){A.L.Int.SP-EP = B.LR.Int.SP-NV}]</desc>
- <a>
- LINESTRING(100 100, 160 40)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1FF0FF1F2">true</op>
- </test>
-</case>
-<case>
-<desc>L/LR-5-2: a LineString within a LinearRing [dim(1){A.L.Int.SP-EP = B.LR.Int.SP-NV}]</desc>
- <a>
- LINESTRING(100 100, 180 20)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/LR-5-3: a LineString within a LinearRing [dim(1){A.L.Int.SP-V-EP = B.LR.Int.NV-CP-NV}]</desc>
- <a>
- LINESTRING(60 60, 100 100, 140 60)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/LR-6-1: a LineString crossing a LinearRing [dim(1){A.L.Int.SP-NV = B.LR.Int.SP-V}]</desc>
- <a>
- LINESTRING(100 100, 190 10, 190 100)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1F10F01F2">true</op>
- </test>
-</case>
-<case>
-<desc>L/LR-6-2: a LineString crossing a LinearRing [dim(1){A.L.Int.SP-V = B.LR.Int.SP-NV}]</desc>
- <a>
- LINESTRING(100 100, 160 40, 160 100)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/LR-6-3: a LineString crossing a LinearRing [dim(1){A.L.Int.NV-V = B.LR.Int.SP-NV}]</desc>
- <a>
- LINESTRING(60 140, 160 40, 160 140)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1F1FF01F2">true</op>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's end point with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Bdy.EPb}]</desc>
- <a>
- LINESTRING(20 20, 140 140)
- </a>
- <b>
- LINESTRING(80 80, 20 80, 140 80, 80 20, 80 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's end point with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Bdy.EPo}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(80 80, 20 80, 140 80)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's end point with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Bdy.EPx}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(80 80, 140 80, 80 20, 80 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's closing point with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.CPb}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(80 80, 20 80, 140 80, 80 20, 80 80)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's closing point with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.CPo}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(80 80, 20 80, 140 80, 80 80)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's closing point with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Int.CPx}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(80 80, 20 80, 20 140, 140 20, 80 20, 80 80)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex [dim(0){A.L.Int.NV = B.nsL.Int.NV}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(20 140, 140 20, 100 20, 100 80)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.NVb}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(140 80, 20 80, 120 80, 80 20, 80 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.NVo}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(140 80, 20 80, 140 80)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Int.NVx}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(140 80, 20 80, 80 140, 80 20)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex [dim(0){A.L.Int.NV = B.nsL.Int.V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(140 80, 80 80, 20 80, 50 140, 50 60)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.Vb}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(140 80, 20 80, 120 80, 80 20, 80 80, 80 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.Vo}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(140 80, 20 80, 80 80, 140 80)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Int.Vx}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(140 80, 20 80, 80 140, 80 80, 80 20)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL.1-3-1: start point of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Bdy.SP = B.nsL.Bdy.EPx}]</desc>
- <a>
- LINESTRING(130 150, 220 150, 220 240)
- </a>
- <b>
- LINESTRING(130 240, 130 150, 220 20, 50 20, 130 150)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL.1-3-2: the interior of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Int.V = B.nsL.Bdy.EPx}]</desc>
- <a>
- LINESTRING(30 150, 130 150, 250 150)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL.1-3-3: the interior of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Int.NV = B.nsL.Bdy.EPx}]</desc>
- <a>
- LINESTRING(30 150, 250 150)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL.1-3-4: the interior of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Int.V = B.nsL.Bdy.EPx}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(130 240, 130 20, 30 20, 130 150)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL.1-4: a Line crossing a non-simple LineString at non-vertices [dim(0){A.L.Int.NV = B.nsL.Int.NV}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(120 240, 120 20, 20 20, 120 170)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL.5/L-3-1: switching the geometries for case L/nsL.5-3-1 [dim(0){A.nsL.Bdy.EPx = B.L.Bdy.SP}]</desc>
- <a>
- LINESTRING(200 200, 20 20, 200 20, 110 110, 20 200, 110 200, 110 110)
- </a>
- <b>
- LINESTRING(110 110, 200 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL.5-3-2: the start point of a line touching the self-intersecting and self-crossing point of a non-simple LineString [dim(0){A.L.Bdy.SP = B.nsL.Bdy.EPx}]</desc>
- <a>
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL.5-3-3: the interior of a line touching the self-intersecting and self-crossing point of a non-simple LineString [dim(0){A.L.Int.NV = B.nsL.Bdy.EPx}]</desc>
- <a>
- LINESTRING(20 110, 200 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL.5/L-3-4 touches dim(0){A.nsL.Bdy.EPx = B.L.Int.NV}</desc>
- <a>
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF10F0102">true</op>
- </test>
-</case>
-<case>
-<desc>L/nsL.10-6-1: the middle portion of a line overlapping from the self-intersecting to the self-crossing a non-simple LineString [dim(1){A.L.Int.V-V = B.nsL.Int.EPx-NVx}]</desc>
- <a>
- LINESTRING(90 200, 90 130, 110 110, 150 200)
- </a>
- <b>
- LINESTRING(200 200, 20 20, 200 20, 20 200, 20 130, 90 130)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/nsL.10-6-2: the middle portion of a line overlapping from the self-intersecting to the self-crossing a non-simple LineString [dim(1){A.L.Int.V-V = B.nsL.Int.NVx-EPx}]</desc>
- <a>
- LINESTRING(200 110, 110 110, 90 130, 90 200)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>L/mL-3-1: a line's end point touching a non-vertex with crossing line segments of a MultiLineString [dim(0){A.L.Bdy.SP = B.mL.Int.NVx]</desc>
- <a>
- LINESTRING(80 80, 150 80, 210 80)
- </a>
- <b>
- MULTILINESTRING(
- (20 20, 140 140),
- (20 140, 140 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-1-1: two equal LinearRings, pointwise [dim(1){A.LR.Int.SP-EP = B.LR.Int.SP-EP}, dim(0){A.LR.Int.CP = B.LR.Int.CP}]</desc>
- <a>
- LINESTRING(40 80, 160 200, 260 20, 40 80)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-1-2: two equal LinearRings with points in reverse sequence [dim(1){A.LR.Int.SP-EP = B.LR.Int.EP-SP}, dim(0){A.LR.Int.CP = B.LR.Int.CP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(40 80, 260 20, 160 200, 40 80)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-1-3: two equal LinearRings with points in different sequence [dim(1){A.LR.Int.SP-EP = B.LR.Int.SP-EP}, dim(0){A.LR.Int.CP = B.LR.Int.V}, dim(0){A.LR.Int.V = B.LR.Int.CP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(260 20, 40 80, 160 200, 260 20)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-1-4: two equal LinearRings with different number of points [dim(1){A.LR.Int.SP-EP = B.LR.Int.SP-EP}, dim(0){A.LR.Int.CP = B.LR.Int.V}, dim(0){A.LR.Int.NV = B.LR.Int.CP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(100 140, 160 200, 260 20, 40 80, 100 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-4-1: two LinearRings crossing at closing points [dim(0){A.LR.Int.CP = B.LR.Int.CP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(100 100, 180 180, 20 180, 100 100)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F1FFF1F2">true</op>
- </test>
-</case>
-<case>
-<desc>LR/LR-4-2: two LinearRings crossing at two points [dim(0){A.LR.Int.CP = B.LR.Int.CP}, dim(0){A.LR.Int.V = B.LR.Int.V},]</desc>
- <a>
- LINESTRING(40 150, 40 40, 150 40, 150 150, 40 150)
- </a>
- <b>
- LINESTRING(40 150, 150 40, 170 20, 170 190, 40 150)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-4-3: two LinearRings crossing at the closing and a non-vertex [dim(0){A.LR.Int.CP = B.LR.Int.NV}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(180 100, 20 100, 100 180, 180 100)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-4-4: two LinearRings crossing at the closing and a vertex [dim(0){A.LR.Int.CP = B.LR.Int.V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(180 180, 100 100, 20 180, 180 180)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-4-5: two LinearRings crossing at a vertex and a non-vertex [dim(0){A.LR.Int.V = B.LR.Int.NV}]</desc>
- <a>
- LINESTRING(20 180, 100 100, 20 20, 20 180)
- </a>
- <b>
- LINESTRING(100 20, 100 180, 180 100, 100 20)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-4-6: two LinearRings crossing at two points [dim(0){A.LR.Int.V = B.LR.Int.NV}, dim(0){A.LR.Int.V = B.LR.Int.NV},]</desc>
- <a>
- </a>
- <b>
- LINESTRING(170 20, 20 170, 170 170, 170 20)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-6-1: two LinearRings overlapping [dim(1){A.LR.Int.CP-V = B.LR.Int.CP-V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(40 150, 150 150, 90 210, 40 150)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="1F1FFF1F2">true</op>
- </test>
-</case>
-<case>
-<desc>LR/LR-6-2: two LinearRings overlapping [dim(1){A.LR.Int.CP-V = B.LR.Int.NV-NV}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(20 150, 170 150, 90 230, 20 150)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/LR-6-3: two LinearRings overlapping [dim(1){A.LR.Int.(V-V-V-EP) = B.LR.Int.(NV-V-V-SP)}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(40 150, 150 150, 150 40, 20 40, 20 150, 40 150)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/nsL-3-1: a LinearRing touching a non-simple LineString [dim(0){A.nsL.Int.CP = B.nsL.Bdy.SPb}]</desc>
- <a>
- LINESTRING(110 110, 200 20, 20 20, 110 110)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F01FFF102">true</op>
- </test>
-</case>
-<case>
-<desc>LR/nsL-3-1: a LinearRing touching a non-simple LineString [dim(0){A.nsL.Int.CP = B.nsL.Bdy.SPo}]</desc>
- <a>
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/nsL-3-1: a LinearRing touching a non-simple LineString [dim(0){A.nsL.Int.CP = B.nsL.Bdy.SPx}]</desc>
- <a>
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>LR/nsL-6-1: a LinearRing and a non-simple LineString overlapping [dim(1){A.nsL.Int.SP-V = B.nsL.Int.NVx-SP}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(200 20, 20 200, 200 200, 110 110, 110 40)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="101FFF102">true</op>
- </test>
-</case>
-<case>
-<desc>LR/nsL-6-2: a LinearRing and a non-simple LineString overlapping [dim(1){A.nsL.Int.SP-V = B.nsL.Int.NVx-SP}, dim(1){A.nsL.Int.V-EP = B.nsL.Int.EP-NVx}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(200 20, 20 200, 200 200, 20 20)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="101FFF1F2">true</op>
- </test>
-</case>
-<case>
-<desc>nsL/nsL-4-1: non-simple LineStrings crossing at closing points [dim(0){A.nsL.Int.CP = B.nsL.Int.CP}]</desc>
- <a>
- LINESTRING(110 110, 20 110, 110 20, 20 20, 110 110)
- </a>
- <b>
- LINESTRING(110 110, 200 200, 110 200, 200 110, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/nsL-4-2: non-simple LineStrings crossing at two points without vertices [dim(0){A.nsL.Int.NV = B.nsL.Int.NV}]</desc>
- <a>
- LINESTRING(20 120, 120 120, 20 20, 120 20, 20 120)
- </a>
- <b>
- LINESTRING(170 100, 70 100, 170 170, 70 170, 170 100)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/nsL-4-3: non-simple LineStrings crossing at a point [dim(0){A.nsL.Int.NV = B.nsL.Int.V}]</desc>
- <a>
- LINESTRING(20 110, 110 110, 20 20, 110 20, 20 110)
- </a>
- <b>
- LINESTRING(110 160, 70 110, 60 160, 20 130, 110 160)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/nsL-4-4: non-simple LineStrings crossing at self-crossing points [dim(0){A.nsL.Int.NVx = B.nsL.Int.NVx}]</desc>
- <a>
- LINESTRING(20 200, 200 200, 20 20, 200 20, 20 200)
- </a>
- <b>
- LINESTRING(20 110, 200 110, 200 160, 20 60, 20 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/nsL-4-5: non-simple LineStrings crossing at vertices [dim(0){A.nsL.Int.V = B.nsL.Int.V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(200 200, 110 110, 200 110, 110 200, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>nsL/nsL-4-6: non-simple LineStrings crossing at two points with vertices [dim(0){A.nsL.Int.V = B.nsL.Int.V}]</desc>
- <a>
- </a>
- <b>
- LINESTRING(220 120, 120 20, 220 20, 120 120, 220 120)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-1: MultiLineString [dim(1){A.mL.Int.SP-EP = B.mL.Int.SP-EP}]</desc>
- <a>
- MULTILINESTRING(
- (70 20, 20 90, 70 170),
- (70 170, 120 90, 70 20))
- </a>
- <b>
- MULTILINESTRING(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-1-1: non-simple MultiLineString [dim(1){A.mL.Int.SP-EP = B.mL.Int.SP-EP}]</desc>
- <a>
- MULTILINESTRING(
- (20 20, 90 20, 170 20),
- (90 20, 90 80, 90 140))
- </a>
- <b>
- MULTILINESTRING(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-1-2: equal non-simple MultiLineString with different sequence of lines and points [dim(1){A.mL.Int.SP-EP = B.mL.Int.EP-SP}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- MULTILINESTRING(
- (90 140, 90 60, 90 20),
- (170 20, 130 20, 20 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-3-1: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPb}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- MULTILINESTRING(
- (90 20, 170 100, 170 140),
- (170 60, 90 20, 20 60),
- (130 100, 130 60, 90 20, 50 90))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-3-2: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPo}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- MULTILINESTRING(
- (130 140, 130 60, 90 20, 20 90, 90 20, 130 60, 170 60))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-3-3: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPx}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- MULTILINESTRING(
- (170 60, 90 20, 20 60))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-3-4: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPx}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- MULTILINESTRING(
- (130 100, 90 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-3-5: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPx}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- MULTILINESTRING(
- (120 100, 170 100, 90 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-3-6: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Int.SPb}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- MULTILINESTRING(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-3-7: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Int.SPo}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- MULTILINESTRING(
- (130 140, 130 60, 90 20, 20 90, 90 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-3-8: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Int.SPx}]</desc>
- <a>
- MULTILINESTRING(
- </a>
- <b>
- MULTILINESTRING(
- (170 60, 90 20, 20 60, 20 140, 90 20))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-4-1: non-simple MultiLineStrings crossing [dim(0){A.mL.Int.Vx = B.mL.Int.Vb}]</desc>
- <a>
- MULTILINESTRING(
- (20 20, 90 90, 20 160),
- (90 160, 90 20))
- </a>
- <b>
- MULTILINESTRING(
- (160 160, 90 90, 160 20),
- (160 120, 120 120, 90 90, 160 60))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-4-2: non-simple MultiLineStrings crossing [dim(0){A.mL.Int.Vx = B.mL.Int.Vo}]</desc>
- <a>
- MULTILINESTRING(
- (90 160, 90 20))
- </a>
- <b>
- MULTILINESTRING(
- (160 120, 120 120, 90 90, 120 60, 160 60))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mL/mL-4-3: non-simple MultiLineStrings crossing [dim(0){A.mL.Int.Vx = B.mL.Int.Vx}]</desc>
- <a>
- MULTILINESTRING(
- (90 160, 90 20))
- </a>
- <b>
- MULTILINESTRING(
- (160 120, 90 90, 160 60))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A-2-1: a point outside a polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
- <a>
- POINT(20 20)
- </a>
- <b>
- POLYGON(
- (60 120, 60 40, 160 40, 160 120, 60 120))
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF0FFF212">true</op>
- </test>
-</case>
-<case>
-<desc>P/A-2-2: a point outside a converx polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
- <a>
- POINT(70 170)
- </a>
- <b>
- POLYGON(
- (110 230, 80 160, 20 160, 20 20, 200 20, 200 160, 140 160, 110 230))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A-2-3: a point outside a concave polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
- <a>
- POINT(110 130)
- </a>
- <b>
- POLYGON(
- (20 160, 80 160, 110 100, 140 160, 200 160, 200 20, 20 20, 20 160))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A-2-4: dim(0){A.P.Int = B.A.Ext}</desc>
- <a>
- POINT(100 70)
- </a>
- <b>
- POLYGON(
- (20 150, 100 150, 40 50, 170 50, 110 150, 190 150, 190 20, 20 20, 20 150))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A-2-5: a point outside a concave polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
- <a>
- POINT(100 70)
- </a>
- <b>
- POLYGON(
- (20 150, 100 150, 40 50, 160 50, 100 150, 180 150, 180 20, 20 20, 20 150))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A-3-1: a point on the closing point of a polygon [dim(0){A.P.Int = B.A.Bdy.CP}]</desc>
- <a>
- POINT(60 120)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F0FFFF212">true</op>
- </test>
-</case>
-<case>
-<desc>P/A-3-2: a point on the boudary of a polygon at a non-vertex [dim(0){A.P.Int = B.A.Bdy.NV}]</desc>
- <a>
- POINT(110 120)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A-3-3: a point on the boundary of a polygon at a vertex [dim(0){A.P.Int = B.A.Bdy.V]</desc>
- <a>
- POINT(160 120)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A-3-4: a point on the touching point of boudary [dim(0){A.P.Int = B.A.Bdy.TP}]</desc>
- <a>
- POINT(100 150)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A-5: a point on the interior of a polygon [dim(0){A.P.Int = B.A.Int}]</desc>
- <a>
- POINT(100 80)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0FFFFF212">true</op>
- </test>
-</case>
-<case>
-<desc>P/Ah-2-1: a point outside of polygon with a hole [dim(0){A.P.Int = B.A.Ext}]</desc>
- <a>
- POINT(60 160)
- </a>
- <b>
- POLYGON(
- (280 50, 100 50, 190 140, 280 50))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/Ah-2-2: a point inside the hole of the polygon [dim(0){A.P.Int = B.A.Ext.h}]</desc>
- <a>
- POINT(190 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/Ah-3-1: a point on the closing point of the outer boundary of a polygon with a hole [dim(0){A.P.Int = B.A.oBdy.CP}]</desc>
- <a>
- POINT(190 190)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/Ah-3-2: a point on the outer boundary of a polygon at a vertex [dim(0){A.P.Int = B.A.oBdy.V}]</desc>
- <a>
- POINT(360 20)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/Ah-3-3: a point on the outer boundary of a polygon at a non-vertex [dim(0){A.P.Int = B.A.oBdy.NV}]</desc>
- <a>
- POINT(130 130)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/Ah-3-4: a point on the closing point of the inner boundary of a polygon [dim(0){A.P.Int = B.A.iBdy.CP}]</desc>
- <a>
- POINT(280 50)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/Ah-3-5: a point on the inner boundary of a polygon at a non-vertex [dim(0){A.P.Int = B.A.iBdy.NV}]</desc>
- <a>
- POINT(150 100)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/Ah-3-6: a point on the inner boundary of a polygon at a vertex [dim(0){A.P.Int = B.A.iBdy.V}]</desc>
- <a>
- POINT(100 50)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/Ah-5: a point inside the interior of a polygon with a hole [dim(0){A.P.Int = B.A.Int}]</desc>
- <a>
- POINT(140 120)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A2h-3-1: a point on the touching point of two holes in a polygon [dim(0){A.P.Int = B.A.iBdy.TP}]</desc>
- <a>
- POINT(190 50)
- </a>
- <b>
- POLYGON(
- (90 50, 150 110, 190 50, 90 50),
- (190 50, 230 110, 290 50, 190 50))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/A2h-3-2: a point on the touching point of two holes in a polygon [dim(0){A.P.Int = B.A.iBdy.TP}]</desc>
- <a>
- POINT(180 90)
- </a>
- <b>
- POLYGON(
- (180 140, 180 40, 80 40, 180 140),
- (180 90, 210 140, 310 40, 230 40, 180 90))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-2: 3 points outside a polygon [dim(0){A.2P.Int = B.A.Ext}]</desc>
- <a>
- MULTIPOINT(20 80, 110 160, 20 160)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-3-1: one of 3 points on the closing point of the boundary of a polygon [dim(0){A.3P1.Int = B.A.Bdy.CP}]</desc>
- <a>
- MULTIPOINT(20 80, 60 120, 20 160)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F00FFF212">true</op>
- </test>
-</case>
-<case>
-<desc>mP/A-3-2: one of 3 points on the boundary of a polygon at a non-vertex [dim(0){A.3P3 = B.A.Bdy.NV}]</desc>
- <a>
- MULTIPOINT(10 80, 110 170, 110 120)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-3-3: one of 3 points on the boundary of a polygon at a vertex [dim(0){A.3P1.Int = B.A.Bdy.V}]</desc>
- <a>
- MULTIPOINT(10 80, 110 170, 160 120)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-3-4: 3 of the 5 points on the boundary of a polygon [dim(0){A.5P2.Int = B.A.Bdy.CP}, dim(0){A.5P3.Int = B.A.Bdy.NV}, dim(0){A.5P4.Int = B.A.Bdy.V}]</desc>
- <a>
- MULTIPOINT(20 120, 60 120, 110 120, 160 120, 200 120)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-3-5: all 3 points on the boundary of a polygon [dim(0){A.3P1.Int = B.A.Bdy.CP}, dim(0){A.3P2.Int = B.A.Bdy.NV}, dim(0){A.3P3.Int = B.A.Bdy.V}]</desc>
- <a>
- MULTIPOINT(60 120, 110 120, 160 120)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-3-6: all 4 points on the boundary of a polygon [dim(0){A.4P = B.A.Bdy}]</desc>
- <a>
- MULTIPOINT(60 120, 160 120, 160 40, 60 40)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-4-1: 1 point outside a polygon, 1 point on the boundary and 1 point inside [dim(0){A.3P1.Int = B.A.Ext}, dim(0){A.3P2.Int = B.A.Bdy.CP}, dim(0){A.3P3.Int = B.A.Int}]</desc>
- <a>
- MULTIPOINT(20 150, 60 120, 110 80)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="000FFF212">true</op>
- </test>
-</case>
-<case>
-<desc>mP/A-4-2: 1 point outside a polygon, 1 point on the boundary and 1 point inside [dim(0){A.3P1.Int = B.A.Ext}, dim(0){A.3P2.Int = B.A.Bdy.V}, dim(0){A.3P3.Int = B.A.Int}]</desc>
- <a>
- MULTIPOINT(110 80, 160 120, 200 160)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-4-3: 1 point outside a polygon, 1 point on the boundary and 1 point inside [dim(0){A.3P1.Int = B.A.Ext}, dim(0){A.3P2.Int = B.A.Bdy.NV}, dim(0){A.3P3.Int = B.A.Int}]</desc>
- <a>
- MULTIPOINT(110 80, 110 120, 110 160)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-4-4: 1 point outside a polygon, 1 point inside [dim(0){A.2P1.Int = B.A.Ext}, dim(0){A.2P2.Int = B.A.Int}]</desc>
- <a>
- MULTIPOINT(110 170, 110 80)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F0FFF212">true</op>
- </test>
-</case>
-<case>
-<desc>mP/A-4-5: 1 point outside a polygon, 2 points on the boundary and 1 point inside [dim(0){A.4P1.Int = B.A.Ext}, dim(0){A.4P2.Int = B.A.Bdy.CP}, dim(0){A.4P3.Int = B.A.Bdy.V}, dim(0){A.4P4.Int = B.A.Int}]</desc>
- <a>
- MULTIPOINT(60 120, 160 120, 110 80, 110 170)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-5-1: 2 points within a polygon [dim(0){A.2P.Int = B.A.Int]</desc>
- <a>
- MULTIPOINT(90 80, 130 80)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/A-5-2: 1 point on the boundary and 1 point inside a polygon [dim(0){A.2P1.Int = B.A.Bdy.CP}, dim(0){A.2P2.Int = B.A.Int}]</desc>
- <a>
- MULTIPOINT(60 120, 160 120, 110 80)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="00FFFF212">true</op>
- </test>
-</case>
-<case>
-<desc>mP/Ah-2-1: 3 points outside a polygon [dim(0){A.3P.Int = B.Ah.Ext}]</desc>
- <a>
- MULTIPOINT(40 170, 40 90, 130 170)
- </a>
- <b>
- POLYGON(
- (190 190, 360 20, 20 20, 190 190),
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/Ah-2-2: 2 points outside a polygon and 1 point inside the hole of the polygon [dim(0){A.3P1.Int = B.Ah.Ext}, dim(0){A.3P2.Int = B.Ah.Ext}, dim(0){A.3P3.Int = B.Ah.Ext.h}]</desc>
- <a>
- MULTIPOINT(90 170, 280 170, 190 90)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/Ah-2-3: all 3 points in polygon's hole [dim(0){A.3P.Int = B.Ah.Ext.h}]</desc>
- <a>
- MULTIPOINT(190 110, 150 70, 230 70)
- </a>
- <b>
- POLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/mA-3-1: a point on the touching point of two polygons [dim(0){A.P.Int = B.2A.Bdy}]</desc>
- <a>
- POINT(100 100)
- </a>
- <b>
- MULTIPOLYGON(
- (20 100, 20 20, 100 20, 100 100, 20 100)),
- (100 180, 100 100, 180 100, 180 180, 100 180)))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/mA-3-2: a point on the boundary of one of the 2 polygons [dim(0){A.P.Int = B.2A1.Bdy.CP}]</desc>
- <a>
- POINT(20 100)
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/mA-3-3: a point on the boundary of one of the 2 polygons [dim(0){A.P.Int = B.2A1.Bdy.V}]</desc>
- <a>
- POINT(60 100)
- </a>
- <b>
- MULTIPOLYGON(
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/mA-3-4: a point touching a polygon's boundary where the boundaries touch at a point [dim(0){A.P.Int = B.2A.Bdy.TP}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- MULTIPOLYGON(
- (110 110, 20 200, 200 200, 110 110),
- (110 110, 80 180, 140 180, 110 110)),
- (110 110, 20 20, 200 20, 110 110),
- (110 110, 80 40, 140 40, 110 110)))
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/L-2: a point and a line disjoint [dim(0){A.P.Int = B.L.Ext}]</desc>
- <a>
- POINT(110 200)
- </a>
- <b>
- LINESTRING(90 80, 160 150, 300 150, 340 150, 340 240)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF0FFF102">true</op>
- </test>
-</case>
-<case>
-<desc>P/L-3-1: a point touching the start point of a line [dim(0){A.P.Int = B.L.Bdy.SP}]</desc>
- <a>
- POINT(90 80)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F0FFFF102">true</op>
- </test>
-</case>
-<case>
-<desc>P/L-3-2: a point touching the end point of a line [dim(0){A.P.Int = B.L.Bdy.EP}]</desc>
- <a>
- POINT(340 240)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/L-5-1: a point on the line at a non-vertex [dim(0){A.P.Int = B.L.Int.NV}]</desc>
- <a>
- POINT(230 150)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0FFFFF102">true</op>
- </test>
-</case>
-<case>
-<desc>P/L-5-2: a point on the line at a vertex [dim(0){A.P.Int = B.L.Int.V}]</desc>
- <a>
- POINT(160 150)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/LR-2-1: a point outside a LinearRing [dim(0){A.P.Int = B.LR.Ext}]</desc>
- <a>
- POINT(90 150)
- </a>
- <b>
- LINESTRING(150 150, 20 20, 280 20, 150 150)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF0FFF1F2">true</op>
- </test>
-</case>
-<case>
-<desc>P/LR-2-2: a point inside a LinearRing [dim(0){A.P.Int = B.LR.Ext}]</desc>
- <a>
- POINT(150 80)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/LR-5-1: a point on the closing point of a LinearRing [dim(0){A.P.Int = B.LR.Int.CP}]</desc>
- <a>
- POINT(150 150)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0FFFFF1F2">true</op>
- </test>
-</case>
-<case>
-<desc>P/LR-5-2: a point on a LinearRing at a non-vertex [dim(0){A.P.Int = B.L.Int.NV}]</desc>
- <a>
- POINT(100 20)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/LR-5-3: a point on a LinearRing at a vertex [dim(0){A.P.Int = B.L.Int.V}]</desc>
- <a>
- POINT(20 20)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.1-3-1: a point on a non-simple LineString's end point [dim(0){A.P.Int = B.nsL.Bdy.EP}]</desc>
- <a>
- POINT(220 220)
- </a>
- <b>
- LINESTRING(110 110, 220 20, 20 20, 110 110, 220 220)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.1-5-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.1-5-2: a point a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 220 20, 20 20, 220 220)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.1-5-3: a point on a non-simple LineString's interior at a non-vertex [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
- <a>
- POINT(110 20)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.1-5-4: a point on a non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
- <a>
- POINT(220 20)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.2-5-2: a point on a non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
- <a>
- POINT(110 20)
- </a>
- <b>
- LINESTRING(220 220, 20 20, 220 20, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.2-5-3: a point on a non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
- <a>
- POINT(20 20)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.2-5-4: a point on a non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
- <a>
- POINT(20 110)
- </a>
- <b>
- LINESTRING(20 200, 20 20, 110 20, 20 110, 110 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.3-3-1: a point on a non-simple LineString's start point [dim(0){A.P.Int = B.nsL.Bdy.SP}]</desc>
- <a>
- POINT(20 200)
- </a>
- <b>
- LINESTRING(20 200, 200 20, 20 20, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.3-5-1: a point on a non-simple LineString's interior at a non-vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(20 200, 200 20, 140 20, 140 80, 80 140, 20 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.3-5-2: a point on a non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.3-5-3: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
- <a>
- POINT(80 140)
- </a>
- <b>
- LINESTRING(20 200, 110 110, 200 20, 140 20, 140 80, 110 110, 80 140, 20 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.3-5-4: a point on a non-simple LineString's interior at a two-vertex point with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vo}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.3-5-5: a point on a non-simple LineString's interior at a vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vo}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(20 200, 200 20, 140 20, 140 80, 110 110, 80 140, 20 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.3-5-6: a point on a non-simple LineString's interior at a two-vertex point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(20 200, 110 110, 200 20, 20 20, 110 110, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.3-5-7: a point on a non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(20 200, 200 20, 20 20, 110 110, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.3-5-8: a point on a non-simple LineString's interior at a two-vertex point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(20 200, 110 110, 20 20, 200 20, 110 110, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.4-3-1: a point on a non-simple LineString's start point with crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 110 200, 20 200, 110 110, 200 20, 140 20, 140 80, 110 110, 80 140,
- 20 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.4-3-2: a point on a non-simple LineString's start point with crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 110 200, 20 200, 200 20, 140 20, 140 80, 110 110, 80 140, 20 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.4-3-3:a point on a non-simple LineString's start point with crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 110 200, 20 200, 200 20, 140 20, 140 80, 80 140, 20 140)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.4-3-4: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 110 200, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.4-3-5: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 110 200, 20 200, 200 20, 20 20, 110 110, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.4-3-6: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 110 200, 20 200, 200 20, 20 20, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.4-3-7: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 110 200, 20 200, 110 110, 20 20, 200 20, 110 110, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.4-3-8: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 110 200, 20 200, 200 20, 200 110, 110 110, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.5-3-1: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(200 200, 110 110, 20 20, 200 20, 110 110, 20 200, 110 200, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.5-3-2: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.5-3-3: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(200 200, 20 20, 200 20, 20 200, 110 200, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.5-3-4: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(200 200, 110 110, 200 20, 20 20, 110 110, 20 200, 110 200, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.5-3-5: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(200 200, 20 20, 20 110, 110 110, 20 200, 110 200, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.6-3-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(110 160)
- </a>
- <b>
- LINESTRING(110 160, 200 250, 110 250, 110 160, 110 110, 110 20, 20 20, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.6-3-2: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(110 160)
- </a>
- <b>
- LINESTRING(110 160, 200 250, 110 250, 110 110, 110 20, 20 20, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.6-3-3: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.6-3-4: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 160, 200 250, 110 250, 110 160, 110 20, 20 20, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.7-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 200 200, 110 200, 110 110, 110 20, 20 20, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.7-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 200 200, 110 200, 110 20, 20 20, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.7-5-3: a point on a closed non-simple LineString's interior at a non-vertex [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
- <a>
- POINT(140 200)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.7-5-4: a point on a closed non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
- <a>
- POINT(110 200)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.8-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 200 200, 110 200, 110 110, 110 20, 200 20, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.8-5-2: a point on the interior (at a non-vertex) of a closed non-simple LineString [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
- <a>
- POINT(140 200)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.8-5-3: a point on a closed non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
- <a>
- POINT(110 200)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.9-3-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- LINESTRING(90 130, 20 130, 20 200, 90 130, 200 20, 20 20, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.9-5-1: a point on a non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.10-3-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- LINESTRING(90 130, 20 130, 20 200, 200 20, 20 20, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.10-5-1: a point on a non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.11-3-1: a point on a closed non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- LINESTRING(200 200, 20 20, 200 20, 90 130, 20 200, 20 130, 90 130)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.11-5-1: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.12-3-1: a point on a closed non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.12-5-1: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.13-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 20 130, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 200 130,
- 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.13-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 20 130, 20 200, 200 20, 20 20, 200 200, 200 130, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.14-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 80 200, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 140 200,
- 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.14-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(110 110, 80 200, 20 200, 200 20, 20 20, 200 200, 140 200, 110 110)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.15-5-1: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(200 200, 20 20, 200 20, 20 200, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.15-5-2: a point on a closed non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(200 200, 110 110, 20 20, 200 20, 110 110, 20 200, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.15-5-3: a point on a closed non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- LINESTRING(200 200, 110 110, 200 20, 20 20, 110 110, 20 200, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.16-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- LINESTRING(90 130, 20 130, 20 200, 90 130, 110 110, 200 20, 20 20, 110 110, 200 200,
- 90 130)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.16-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- LINESTRING(90 130, 20 130, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 90 130)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.17-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- LINESTRING(90 130, 90 200, 20 200, 90 130, 110 110, 200 20, 20 20, 110 110, 200 200,
- 90 130)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.17-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- LINESTRING(90 130, 90 200, 20 200, 200 20, 20 20, 200 200, 90 130)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.17-5-3: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- LINESTRING(90 130, 90 200, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 90 130)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.17-5-4: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
- <a>
- POINT(90 130)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.17-5-5: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.18-5-1: a point on a non-simple LineString's start point with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb)}]</desc>
- <a>
- POINT(110 200)
- </a>
- <b>
- LINESTRING(110 200, 110 110, 20 20, 200 20, 110 110, 110 200, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.18-5-2: a point on a non-simple LineString's interior at a non-vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
- <a>
- POINT(110 150)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.18-5-3: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.19-5-1: a point on a non-simple LineString's closing point with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.CPo}]</desc>
- <a>
- POINT(110 200)
- </a>
- <b>
- LINESTRING(110 200, 110 110, 20 20, 200 20, 110 110, 110 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.19-5-2: a point on a non-simple LineString's interior at a non-vertex overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
- <a>
- POINT(110 150)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.19-5-3: a point on a non-simple LineString interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.20-5-1: a point on a non-simple LineString's interior at a non-vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
- <a>
- POINT(110 150)
- </a>
- <b>
- LINESTRING(20 200, 110 200, 110 110, 20 20, 200 20, 110 110, 110 200, 200 200)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsL.20-5-2: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
- <a>
- POINT(110 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/nsl.20-5-3: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
- <a>
- POINT(110 200)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-2-1: MultiPoint and a line disjoint (points on one side of the line) [dim(0){A.3P.Int = B.L.Ext}]</desc>
- <a>
- MULTIPOINT(50 250, 90 220, 130 190)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-2-2: MultiPoint and a line disjoint (points over the line but no intersection) [dim(0){A.3P.Int = B.L.Ext}]</desc>
- <a>
- MULTIPOINT(180 180, 230 130, 280 80)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-3-1: one of the points intersecting the start point of a line [dim(0){A.3P2.Int = B.L.Bdy.SP}]</desc>
- <a>
- MULTIPOINT(50 120, 90 80, 130 40)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="F00FFF102">true</op>
- </test>
-</case>
-<case>
-<desc>mP/L-3-2: one of the points intersecting the end point of a line [dim(0){A.3P2 = B.L.Bdy.EP}]</desc>
- <a>
- MULTIPOINT(300 280, 340 240, 380 200)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-4-1: one of the points intersecting the interior of a line at a non-vertex (points on one side of the line) [dim(0){A.3P1.Int = B.L.Int.NV]</desc>
- <a>
- MULTIPOINT(230 150, 260 120, 290 90)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F0FFF102">true</op>
- </test>
-</case>
-<case>
-<desc>mP/L-4-2: one of the points intersecting the interior of a line at a non-vertex (points over the line) [dim(0){A.3P2.Int = B.L.Int.NV]</desc>
- <a>
- MULTIPOINT(200 190, 240 150, 270 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-4-3: one of the points intersecting the interior of a line at a vertex (points on one side of the line) [dim(0){A.3P1.Int = B.L.Int.V]</desc>
- <a>
- MULTIPOINT(160 150, 190 120, 220 90)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-4-4: one of the points intersecting the interior of a line at a vertex (points over the line) [dim(0){A.3P2.Int = B.L.Int.V]</desc>
- <a>
- MULTIPOINT(120 190, 160 150, 200 110)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-5-1: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Bdy.EP}]</desc>
- <a>
- MULTIPOINT(90 80, 160 150, 340 240)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="00FFFF1F2">true</op>
- </test>
-</case>
-<case>
-<desc>mP/L-5-2: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.V}]</desc>
- <a>
- MULTIPOINT(90 80, 160 150, 300 150)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="00FFFF102">true</op>
- </test>
-</case>
-<case>
-<desc>mP/L-5-3: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
- <a>
- MULTIPOINT(90 80, 160 150, 240 150)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-5-4: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.NV}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
- <a>
- MULTIPOINT(90 80, 130 120, 210 150)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-5-5: all the points on a line [dim(0){A.3P1.Int = B.L.Int.NV}, dim(0){A.3P2.Int = B.L.Int.NV}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
- <a>
- MULTIPOINT(130 120, 210 150, 340 200)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-5-6: all the points on a line [dim(0){A.3P1.Int = B.L.Int.V}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
- <a>
- MULTIPOINT(160 150, 240 150, 340 210)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-5-7: all the points on a line [dim(0){A.3P1.Int = B.L.Int.V}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.V}]</desc>
- <a>
- MULTIPOINT(160 150, 300 150, 340 150)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/L-5-8: all the points on a line [dim(0){A.3P1.Int = B.L.Int.V}, dim(0){A.3P2.Int = B.L.Int.NV}, dim(0){A.3P3.Int = B.Bdy.EP}]</desc>
- <a>
- MULTIPOINT(160 150, 240 150, 340 240)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>P/mP: different points [dim(0){A.P.Int = B.3P.Ext}]</desc>
- <a>
- POINT(40 40)
- </a>
- <b>
- MULTIPOINT(20 20, 80 80, 20 120)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="FF0FFF0F2">true</op>
- </test>
-</case>
-<case>
-<desc>P/mP: point A within one of B points [dim(0){A.P.Int = B.3P1.Int}]</desc>
- <a>
- POINT(20 20)
- </a>
- <b>
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0FFFFF0F2">true</op>
- </test>
-</case>
-<case>
-<desc>mP/mP-1-2: same but different sequence of points [dim(0){A.3P1.Int = B.3P1.Int}, dim(0){A.3P1.Int = B.3P3.Int}, dim(0){A.3P3.Int = B.3P2.Int}]</desc>
- <a>
- MULTIPOINT(40 40, 80 60, 120 100)
- </a>
- <b>
- MULTIPOINT(40 40, 120 100, 80 60)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0FFFFFFF2">true</op>
- </test>
-</case>
-<case>
-<desc>mP/mP-2: different points [dim(0){A.4P.Int = B.4P.Ext}]</desc>
- <a>
- MULTIPOINT(40 40, 60 100, 100 60, 120 120)
- </a>
- <b>
- MULTIPOINT(20 120, 60 60, 100 100, 140 40)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/mP-5-1: same points [dim(0){A.4P.Int = B.4P.Int}]</desc>
- <a>
- MULTIPOINT(20 20, 80 70, 140 120, 200 170)
- </a>
- <b>
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/mP-5-2: same points but different sequence [dim(0){A.4P.Int = B.4P.Int}]</desc>
- <a>
- MULTIPOINT(20 20, 140 120, 80 70, 200 170)
- </a>
- <b>
- MULTIPOINT(80 70, 20 20, 200 170, 140 120)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/mP-5-3: some points same [dim(0){A.4P2.Int = B.2P1.Int}, dim(0){A.4P3.Int = B.2P2.Int}]</desc>
- <a>
- </a>
- <b>
- MULTIPOINT(80 70, 140 120)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F0FFFFF2">true</op>
- </test>
-</case>
-<case>
-<desc>mP/mP-5-4: some points same, in a different sequence [dim(0){A.4P1.Int = B.2P2.Int}, dim(0){A.4P4.Int = B.2P1.Int}]</desc>
- <a>
- </a>
- <b>
- MULTIPOINT(140 120, 80 70)
- </b>
- <test>
- </test>
-</case>
-<case>
-<desc>mP/mP-6-1: some points same, some different [dim(0){A.4P4.Int = B.3P2.Int}]</desc>
- <a>
- </a>
- <b>
- MULTIPOINT(80 170, 140 120, 200 80)
- </b>
- <test>
- <op name="relate" arg1="A" arg2="B" arg3="0F0FFF0F2">true</op>
- </test>
-</case>
-<case>
-<desc>mP/mP-6-2: dim(0){A.4P1.Int = B.4P4.Int}, dim(0){A.4P4.Int = B.4P2.Int}</desc>
- <a>
- </a>
- <b>
- MULTIPOINT(80 170, 140 120, 200 80, 80 70)
- </b>
- <test>
- </test>
-</case>
-<case>
- <desc>Multipoint buffer</desc>
- <a>
- MULTIPOINT(0 0, 5 5)
- </a>
-<test>
- <op name="buffer" arg1="a" arg2="10">
- POLYGON ((-10.0 -2.0, -10.0 -0.0, -10.0 2.0, -9.0 4.0, -8.0 6.0, -7.0 7.0, -6.0 8.0, -4.0 9.0, -3.0 11.0, -2.0 12.0, -1.0 13.0, 1.0 14.0, 3.0 15.0, 5.0 15.0, 7.0 15.0, 9.0 14.0, 11.0 13.0, 12.0 12.0, 13.0 11.0, 14.0 9.0, 15.0 7.0, 15.0 5.0, 15.0 3.0, 14.0 1.0, 13.0 -1.0, 12.0 -2.0, 11.0 -3.0, 9.0 -4.0, 8.0 -6.0, 7.0 -7.0, 6.0 -8.0, 4.0 -9.0, 2.0 -10.0, 0.0 -10.0, -2.0 -10.0, -4.0 -9.0, -6.0 -8.0, -7.0 -7.0, -8.0 -6.0, -9.0 -4.0, -10.0 -2.0))
- </op>
-</test>
-</case>
-<case>
- <desc>Multipolygon buffering</desc>
-<!-- this one doesn't works, for incorrect CCW -->
- <a>MULTIPOLYGON (((10 10, 10 20, 20 20, 20 15, 10 10)), ((60 60, 70 7, 80 60, 60 60)))</a>
-<!-- this one works, for correct CCW -->
- <a>MULTIPOLYGON (((10 10, 10 20, 20 20, 20 15, 10 10)), ((60 60, 80 60, 70 7, 60 60)))</a>
-<test>
- <op name="buffer" arg1="a" arg2="0">
- MULTIPOLYGON (((10 10, 10 20, 20 20, 20 15, 10 10)), ((60 60, 70 7, 80 60, 60 60)))
- </op>
-</test>
-</case>
-</run>
commit b0a391a260f9699ef078aa354b1ad6a06539d70b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Mar 14 10:31:55 2019 -0700
Change build files for new ticket names
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 3e909ed..f733b67 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -112,29 +112,29 @@ if(GEOS_ENABLE_TESTS)
${XMLTESTS_DIR}/misc/testLeaksBig.xml
${XMLTESTS_DIR}/robust/TestRobustOverlayFixed.xml
${XMLTESTS_DIR}/robust/TestRobustRelate.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-176.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-188.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-244.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-275.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-350.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-356.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-358.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-360.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-366.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-392.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-398.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-434.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-459.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-527.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-569.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-582.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-586.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-599.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-605.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-615.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-716.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-837.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-838.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-176.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-188.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-244.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-275.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-350.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-356.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-358.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-360.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-366.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-392.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-398.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-434.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-459.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-527.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-569.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-582.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-586.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-599.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-605.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-615.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-716.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-837.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-838.xml
${XMLTESTS_DIR}/validate/TestRelateAA-big.xml
${XMLTESTS_DIR}/validate/TestRelateAA.xml
${XMLTESTS_DIR}/validate/TestRelateAC.xml
@@ -147,8 +147,8 @@ if(GEOS_ENABLE_TESTS)
set(FAILING_XMLTESTS
- ${XMLTESTS_DIR}/ticket/ticket-geos-488.xml
- ${XMLTESTS_DIR}/ticket/ticket-geos-344.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-488.xml
+ ${XMLTESTS_DIR}/issue/issue-geos-344.xml
${XMLTESTS_DIR}/robust/TestRobustRelateFloat.xml
${XMLTESTS_DIR}/failure/TestOverlay.xml
${XMLTESTS_DIR}/misc/TestBigNastyBuffer.xml
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index bfd06bf..336bd13 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -80,29 +80,29 @@ SAFE_XMLTESTS= \
$(srcdir)/tests/misc/testLeaksBig.xml \
$(srcdir)/tests/robust/TestRobustOverlayFixed.xml \
$(srcdir)/tests/robust/TestRobustRelate.xml \
- $(srcdir)/tests/ticket/ticket-geos-176.xml \
- $(srcdir)/tests/ticket/ticket-geos-188.xml \
- $(srcdir)/tests/ticket/ticket-geos-244.xml \
- $(srcdir)/tests/ticket/ticket-geos-275.xml \
- $(srcdir)/tests/ticket/ticket-geos-350.xml \
- $(srcdir)/tests/ticket/ticket-geos-356.xml \
- $(srcdir)/tests/ticket/ticket-geos-358.xml \
- $(srcdir)/tests/ticket/ticket-geos-360.xml \
- $(srcdir)/tests/ticket/ticket-geos-366.xml \
- $(srcdir)/tests/ticket/ticket-geos-392.xml \
- $(srcdir)/tests/ticket/ticket-geos-398.xml \
- $(srcdir)/tests/ticket/ticket-geos-434.xml \
- $(srcdir)/tests/ticket/ticket-geos-459.xml \
- $(srcdir)/tests/ticket/ticket-geos-527.xml \
- $(srcdir)/tests/ticket/ticket-geos-569.xml \
- $(srcdir)/tests/ticket/ticket-geos-582.xml \
- $(srcdir)/tests/ticket/ticket-geos-586.xml \
- $(srcdir)/tests/ticket/ticket-geos-599.xml \
- $(srcdir)/tests/ticket/ticket-geos-605.xml \
- $(srcdir)/tests/ticket/ticket-geos-615.xml \
- $(srcdir)/tests/ticket/ticket-geos-716.xml \
- $(srcdir)/tests/ticket/ticket-geos-837.xml \
- $(srcdir)/tests/ticket/ticket-geos-838.xml \
+ $(srcdir)/tests/issue/issue-geos-176.xml \
+ $(srcdir)/tests/issue/issue-geos-188.xml \
+ $(srcdir)/tests/issue/issue-geos-244.xml \
+ $(srcdir)/tests/issue/issue-geos-275.xml \
+ $(srcdir)/tests/issue/issue-geos-350.xml \
+ $(srcdir)/tests/issue/issue-geos-356.xml \
+ $(srcdir)/tests/issue/issue-geos-358.xml \
+ $(srcdir)/tests/issue/issue-geos-360.xml \
+ $(srcdir)/tests/issue/issue-geos-366.xml \
+ $(srcdir)/tests/issue/issue-geos-392.xml \
+ $(srcdir)/tests/issue/issue-geos-398.xml \
+ $(srcdir)/tests/issue/issue-geos-434.xml \
+ $(srcdir)/tests/issue/issue-geos-459.xml \
+ $(srcdir)/tests/issue/issue-geos-527.xml \
+ $(srcdir)/tests/issue/issue-geos-569.xml \
+ $(srcdir)/tests/issue/issue-geos-582.xml \
+ $(srcdir)/tests/issue/issue-geos-586.xml \
+ $(srcdir)/tests/issue/issue-geos-599.xml \
+ $(srcdir)/tests/issue/issue-geos-605.xml \
+ $(srcdir)/tests/issue/issue-geos-615.xml \
+ $(srcdir)/tests/issue/issue-geos-716.xml \
+ $(srcdir)/tests/issue/issue-geos-837.xml \
+ $(srcdir)/tests/issue/issue-geos-838.xml \
$(srcdir)/tests/validate/TestRelateAA-big.xml \
$(srcdir)/tests/validate/TestRelateAA.xml \
$(srcdir)/tests/validate/TestRelateAC.xml \
@@ -117,8 +117,8 @@ INVALID_OUTPUT_XMLTESTS =
FAILING_XMLTESTS = \
$(srcdir)/tests/failure/TestOverlay.xml \
- $(srcdir)/tests/ticket/ticket-geos-488.xml \
- $(srcdir)/tests/ticket/ticket-geos-344.xml \
+ $(srcdir)/tests/issue/issue-geos-488.xml \
+ $(srcdir)/tests/issue/issue-geos-344.xml \
$(srcdir)/tests/robust/TestRobustRelateFloat.xml \
$(srcdir)/misc/TestBigNastyBuffer.xml \
$(srcdir)/misc/TestSameDirection.xml
commit 16e7193b62ec6f42b8f13029b5e6e9737268eaee
Date: Thu Mar 14 10:29:35 2019 -0700
Rename ticket to issue
diff --git a/tests/xmltester/tests/ticket/ticket-geos-176.xml b/tests/xmltester/tests/issue/issue-geos-176.xml
similarity index 100%
rename from tests/xmltester/tests/ticket/ticket-geos-176.xml
rename to tests/xmltester/tests/issue/issue-geos-176.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-188.xml b/tests/xmltester/tests/issue/issue-geos-188.xml
rename from tests/xmltester/tests/ticket/ticket-geos-188.xml
rename to tests/xmltester/tests/issue/issue-geos-188.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-244.xml b/tests/xmltester/tests/issue/issue-geos-244.xml
rename from tests/xmltester/tests/ticket/ticket-geos-244.xml
rename to tests/xmltester/tests/issue/issue-geos-244.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-275.xml b/tests/xmltester/tests/issue/issue-geos-275.xml
rename from tests/xmltester/tests/ticket/ticket-geos-275.xml
rename to tests/xmltester/tests/issue/issue-geos-275.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-344.xml b/tests/xmltester/tests/issue/issue-geos-344.xml
rename from tests/xmltester/tests/ticket/ticket-geos-344.xml
rename to tests/xmltester/tests/issue/issue-geos-344.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-350.xml b/tests/xmltester/tests/issue/issue-geos-350.xml
rename from tests/xmltester/tests/ticket/ticket-geos-350.xml
rename to tests/xmltester/tests/issue/issue-geos-350.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-356.xml b/tests/xmltester/tests/issue/issue-geos-356.xml
rename from tests/xmltester/tests/ticket/ticket-geos-356.xml
rename to tests/xmltester/tests/issue/issue-geos-356.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-358.xml b/tests/xmltester/tests/issue/issue-geos-358.xml
rename from tests/xmltester/tests/ticket/ticket-geos-358.xml
rename to tests/xmltester/tests/issue/issue-geos-358.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-360.xml b/tests/xmltester/tests/issue/issue-geos-360.xml
rename from tests/xmltester/tests/ticket/ticket-geos-360.xml
rename to tests/xmltester/tests/issue/issue-geos-360.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-366.xml b/tests/xmltester/tests/issue/issue-geos-366.xml
rename from tests/xmltester/tests/ticket/ticket-geos-366.xml
rename to tests/xmltester/tests/issue/issue-geos-366.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-392.xml b/tests/xmltester/tests/issue/issue-geos-392.xml
rename from tests/xmltester/tests/ticket/ticket-geos-392.xml
rename to tests/xmltester/tests/issue/issue-geos-392.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-398.xml b/tests/xmltester/tests/issue/issue-geos-398.xml
rename from tests/xmltester/tests/ticket/ticket-geos-398.xml
rename to tests/xmltester/tests/issue/issue-geos-398.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-434.xml b/tests/xmltester/tests/issue/issue-geos-434.xml
rename from tests/xmltester/tests/ticket/ticket-geos-434.xml
rename to tests/xmltester/tests/issue/issue-geos-434.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-459.xml b/tests/xmltester/tests/issue/issue-geos-459.xml
rename from tests/xmltester/tests/ticket/ticket-geos-459.xml
rename to tests/xmltester/tests/issue/issue-geos-459.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-488.xml b/tests/xmltester/tests/issue/issue-geos-488.xml
rename from tests/xmltester/tests/ticket/ticket-geos-488.xml
rename to tests/xmltester/tests/issue/issue-geos-488.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-527.xml b/tests/xmltester/tests/issue/issue-geos-527.xml
rename from tests/xmltester/tests/ticket/ticket-geos-527.xml
rename to tests/xmltester/tests/issue/issue-geos-527.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-569.xml b/tests/xmltester/tests/issue/issue-geos-569.xml
rename from tests/xmltester/tests/ticket/ticket-geos-569.xml
rename to tests/xmltester/tests/issue/issue-geos-569.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-582.xml b/tests/xmltester/tests/issue/issue-geos-582.xml
rename from tests/xmltester/tests/ticket/ticket-geos-582.xml
rename to tests/xmltester/tests/issue/issue-geos-582.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-586.xml b/tests/xmltester/tests/issue/issue-geos-586.xml
rename from tests/xmltester/tests/ticket/ticket-geos-586.xml
rename to tests/xmltester/tests/issue/issue-geos-586.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-599.xml b/tests/xmltester/tests/issue/issue-geos-599.xml
rename from tests/xmltester/tests/ticket/ticket-geos-599.xml
rename to tests/xmltester/tests/issue/issue-geos-599.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-605.xml b/tests/xmltester/tests/issue/issue-geos-605.xml
rename from tests/xmltester/tests/ticket/ticket-geos-605.xml
rename to tests/xmltester/tests/issue/issue-geos-605.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-615.xml b/tests/xmltester/tests/issue/issue-geos-615.xml
rename from tests/xmltester/tests/ticket/ticket-geos-615.xml
rename to tests/xmltester/tests/issue/issue-geos-615.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-716.xml b/tests/xmltester/tests/issue/issue-geos-716.xml
rename from tests/xmltester/tests/ticket/ticket-geos-716.xml
rename to tests/xmltester/tests/issue/issue-geos-716.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-837.xml b/tests/xmltester/tests/issue/issue-geos-837.xml
rename from tests/xmltester/tests/ticket/ticket-geos-837.xml
rename to tests/xmltester/tests/issue/issue-geos-837.xml
diff --git a/tests/xmltester/tests/ticket/ticket-geos-838.xml b/tests/xmltester/tests/issue/issue-geos-838.xml
rename from tests/xmltester/tests/ticket/ticket-geos-838.xml
rename to tests/xmltester/tests/issue/issue-geos-838.xml
Summary of changes:
tests/xmltester/CMakeLists.txt | 54 +-
tests/xmltester/Makefile.am | 54 +-
.../issue-geos-176.xml} | 0
.../issue-geos-188.xml} | 0
.../issue-geos-244.xml} | 0
.../issue-geos-275.xml} | 0
.../issue-geos-344.xml} | 0
.../issue-geos-350.xml} | 0
.../issue-geos-356.xml} | 0
.../issue-geos-358.xml} | 0
.../issue-geos-360.xml} | 0
.../issue-geos-366.xml} | 0
.../issue-geos-392.xml} | 0
.../issue-geos-398.xml} | 0
.../issue-geos-434.xml} | 0
.../issue-geos-459.xml} | 0
.../issue-geos-488.xml} | 0
.../issue-geos-527.xml} | 0
.../issue-geos-569.xml} | 0
.../issue-geos-582.xml} | 0
.../issue-geos-586.xml} | 0
.../issue-geos-599.xml} | 0
.../issue-geos-605.xml} | 0
.../issue-geos-615.xml} | 0
.../issue-geos-716.xml} | 0
.../issue-geos-837.xml} | 0
.../issue-geos-838.xml} | 0
tests/xmltester/tests/misc/InvalidRelates.xml | 89 +
tests/xmltester/tests/misc/Segfaults.xml | 36 +
tests/xmltester/tests/misc/test.xml | 6597 ------------------
tests/xmltester/tests/misc/testLeaksBig.xml | 7094 --------------------
31 files changed, 179 insertions(+), 13745 deletions(-)
rename tests/xmltester/tests/{ticket/ticket-geos-176.xml => issue/issue-geos-176.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-188.xml => issue/issue-geos-188.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-244.xml => issue/issue-geos-244.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-275.xml => issue/issue-geos-275.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-344.xml => issue/issue-geos-344.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-350.xml => issue/issue-geos-350.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-356.xml => issue/issue-geos-356.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-358.xml => issue/issue-geos-358.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-360.xml => issue/issue-geos-360.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-366.xml => issue/issue-geos-366.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-392.xml => issue/issue-geos-392.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-398.xml => issue/issue-geos-398.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-434.xml => issue/issue-geos-434.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-459.xml => issue/issue-geos-459.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-488.xml => issue/issue-geos-488.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-527.xml => issue/issue-geos-527.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-569.xml => issue/issue-geos-569.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-582.xml => issue/issue-geos-582.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-586.xml => issue/issue-geos-586.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-599.xml => issue/issue-geos-599.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-605.xml => issue/issue-geos-605.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-615.xml => issue/issue-geos-615.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-716.xml => issue/issue-geos-716.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-837.xml => issue/issue-geos-837.xml} (100%)
rename tests/xmltester/tests/{ticket/ticket-geos-838.xml => issue/issue-geos-838.xml} (100%)
create mode 100644 tests/xmltester/tests/misc/InvalidRelates.xml
create mode 100644 tests/xmltester/tests/misc/Segfaults.xml
delete mode 100644 tests/xmltester/tests/misc/test.xml
delete mode 100644 tests/xmltester/tests/misc/testLeaksBig.xml
hooks/post-receive
More information about the geos-commits
