[geos-commits] [SCM] GEOS branch master updated. abf6a57227ef11d41477ae9900a2ee5380a977b1
Thu Mar 14 10:55:54 PDT 2019
the project "GEOS".
       via  abf6a57227ef11d41477ae9900a2ee5380a977b1 (commit)
      from  5c30d3d696b0292961813e4254a3b1f59fc578ee (commit)
revisions in full, below.
commit abf6a57227ef11d41477ae9900a2ee5380a977b1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Mar 14 10:54:13 2019 -0700
    Rename more tests
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index f49d369..9d1c9c9 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -86,12 +86,14 @@ if(GEOS_ENABLE_TESTS)
     ${XMLTESTS_DIR}/general/TestValid2-big.xml
     ${XMLTESTS_DIR}/general/TestValid2.xml
     ${XMLTESTS_DIR}/general/TestWithinDistance.xml
-    ${XMLTESTS_DIR}/misc/TestBufferExternal.xml
-    ${XMLTESTS_DIR}/misc/TestBufferExternal2.xml
+    ${XMLTESTS_DIR}/misc/Buffer-1.xml
+    ${XMLTESTS_DIR}/misc/Buffer-2.xml
+    ${XMLTESTS_DIR}/misc/InvalidRelates.xml
+    ${XMLTESTS_DIR}/misc/Segfaults.xml
+    ${XMLTESTS_DIR}/misc/TestBufferExternal-1.xml
+    ${XMLTESTS_DIR}/misc/TestBufferExternal-2.xml
     ${XMLTESTS_DIR}/misc/TestIsValid.xml
-    ${XMLTESTS_DIR}/misc/badguy3.xml
     ${XMLTESTS_DIR}/misc/buildarea.xml
-    ${XMLTESTS_DIR}/misc/buffer.xml
     ${XMLTESTS_DIR}/misc/fme.xml
     ${XMLTESTS_DIR}/misc/heisenbugs.xml
     ${XMLTESTS_DIR}/misc/hexwkb.xml
@@ -104,12 +106,10 @@ if(GEOS_ENABLE_TESTS)
     ${XMLTESTS_DIR}/misc/safe-16596.xml
     ${XMLTESTS_DIR}/misc/safe-TestBufferJagged.xml
     ${XMLTESTS_DIR}/misc/singlesidedbuffer.xml
-    ${XMLTESTS_DIR}/misc/stmlf-cases-20061020-invalid-output.xml
-    ${XMLTESTS_DIR}/misc/stmlf-cases-20061020.xml
-    ${XMLTESTS_DIR}/misc/stmlf-cases-20070119.xml
+    ${XMLTESTS_DIR}/misc/stmlf-20061020-invalid-output.xml
+    ${XMLTESTS_DIR}/misc/stmlf-20061020.xml
+    ${XMLTESTS_DIR}/misc/stmlf-20070119.xml
     ${XMLTESTS_DIR}/misc/split.xml
-    ${XMLTESTS_DIR}/misc/InvalidRelates.xml
-    ${XMLTESTS_DIR}/misc/Segfaults.xml
     ${XMLTESTS_DIR}/robust/TestRobustOverlayFixed.xml
     ${XMLTESTS_DIR}/robust/TestRobustRelate.xml
     ${XMLTESTS_DIR}/issue/issue-geos-176.xml
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index b4f9425..ab6e7fe 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -54,11 +54,13 @@ SAFE_XMLTESTS= \
 	$(srcdir)/tests/general/TestValid2-big.xml \
 	$(srcdir)/tests/general/TestValid2.xml \
 	$(srcdir)/tests/general/TestWithinDistance.xml \
-	$(srcdir)/tests/misc/TestBufferExternal.xml \
-	$(srcdir)/tests/misc/TestBufferExternal2.xml \
+	$(srcdir)/tests/misc/Buffer-1.xml \
+	$(srcdir)/tests/misc/Buffer-2.xml \
+	$(srcdir)/tests/misc/InvalidRelates \
+	$(srcdir)/tests/misc/Segfaults.xml \
+	$(srcdir)/tests/misc/TestBufferExternal-1.xml \
+	$(srcdir)/tests/misc/TestBufferExternal-2.xml \
 	$(srcdir)/tests/misc/TestIsValid.xml \
-	$(srcdir)/tests/misc/badguy3.xml \
-	$(srcdir)/tests/misc/buffer.xml \
 	$(srcdir)/tests/misc/buildarea.xml \
 	$(srcdir)/tests/misc/fme.xml \
 	$(srcdir)/tests/misc/heisenbugs.xml \
@@ -72,12 +74,10 @@ SAFE_XMLTESTS= \
 	$(srcdir)/tests/misc/safe-16596.xml \
 	$(srcdir)/tests/misc/safe-TestBufferJagged.xml \
 	$(srcdir)/tests/misc/singlesidedbuffer.xml \
-	$(srcdir)/tests/misc/stmlf-cases-20061020-invalid-output.xml \
-	$(srcdir)/tests/misc/stmlf-cases-20061020.xml \
-	$(srcdir)/tests/misc/stmlf-cases-20070119.xml \
+	$(srcdir)/tests/misc/stmlf-20061020-invalid-output.xml \
+	$(srcdir)/tests/misc/stmlf-20061020.xml \
+	$(srcdir)/tests/misc/stmlf-20070119.xml \
 	$(srcdir)/tests/misc/split.xml \
-	$(srcdir)/tests/misc/InvalidRelates \
-	$(srcdir)/tests/misc/Segfaults.xml \
 	$(srcdir)/tests/robust/TestRobustOverlayFixed.xml \
 	$(srcdir)/tests/robust/TestRobustRelate.xml \
 	$(srcdir)/tests/issue/issue-geos-176.xml \
diff --git a/tests/xmltester/tests/misc/buffer.xml b/tests/xmltester/tests/misc/Buffer-1.xml
similarity index 100%
rename from tests/xmltester/tests/misc/buffer.xml
rename to tests/xmltester/tests/misc/Buffer-1.xml
diff --git a/tests/xmltester/tests/misc/badguy3.xml b/tests/xmltester/tests/misc/Buffer-2.xml
rename from tests/xmltester/tests/misc/badguy3.xml
rename to tests/xmltester/tests/misc/Buffer-2.xml
diff --git a/tests/xmltester/tests/misc/TestBufferExternal.xml b/tests/xmltester/tests/misc/TestBufferExternal-1.xml
rename from tests/xmltester/tests/misc/TestBufferExternal.xml
rename to tests/xmltester/tests/misc/TestBufferExternal-1.xml
diff --git a/tests/xmltester/tests/misc/TestBufferExternal2.xml b/tests/xmltester/tests/misc/TestBufferExternal-2.xml
rename from tests/xmltester/tests/misc/TestBufferExternal2.xml
rename to tests/xmltester/tests/misc/TestBufferExternal-2.xml
diff --git a/tests/xmltester/tests/misc/stmlf-cases-20061020-invalid-output.xml b/tests/xmltester/tests/misc/stmlf-20061020-invalid-output.xml
rename from tests/xmltester/tests/misc/stmlf-cases-20061020-invalid-output.xml
rename to tests/xmltester/tests/misc/stmlf-20061020-invalid-output.xml
diff --git a/tests/xmltester/tests/misc/stmlf-cases-20061020.xml b/tests/xmltester/tests/misc/stmlf-20061020.xml
rename from tests/xmltester/tests/misc/stmlf-cases-20061020.xml
rename to tests/xmltester/tests/misc/stmlf-20061020.xml
diff --git a/tests/xmltester/tests/misc/stmlf-cases-20070119.xml b/tests/xmltester/tests/misc/stmlf-20070119.xml
rename from tests/xmltester/tests/misc/stmlf-cases-20070119.xml
rename to tests/xmltester/tests/misc/stmlf-20070119.xml
Summary of changes:
 tests/xmltester/CMakeLists.txt                         | 18 +++++++++---------
 tests/xmltester/Makefile.am                            | 18 +++++++++---------
 .../xmltester/tests/misc/{buffer.xml => Buffer-1.xml}  |  0
 .../xmltester/tests/misc/{badguy3.xml => Buffer-2.xml} |  0
 ...TestBufferExternal.xml => TestBufferExternal-1.xml} |  0
 ...estBufferExternal2.xml => TestBufferExternal-2.xml} |  0
 ...id-output.xml => stmlf-20061020-invalid-output.xml} |  0
 .../{stmlf-cases-20061020.xml => stmlf-20061020.xml}   |  0
 .../{stmlf-cases-20070119.xml => stmlf-20070119.xml}   |  0
 9 files changed, 18 insertions(+), 18 deletions(-)
 rename tests/xmltester/tests/misc/{buffer.xml => Buffer-1.xml} (100%)
 rename tests/xmltester/tests/misc/{badguy3.xml => Buffer-2.xml} (100%)
 rename tests/xmltester/tests/misc/{TestBufferExternal.xml => TestBufferExternal-1.xml} (100%)
 rename tests/xmltester/tests/misc/{TestBufferExternal2.xml => TestBufferExternal-2.xml} (100%)
 rename tests/xmltester/tests/misc/{stmlf-cases-20061020-invalid-output.xml => stmlf-20061020-invalid-output.xml} (100%)
 rename tests/xmltester/tests/misc/{stmlf-cases-20061020.xml => stmlf-20061020.xml} (100%)
 rename tests/xmltester/tests/misc/{stmlf-cases-20070119.xml => stmlf-20070119.xml} (100%)
hooks/post-receive
More information about the geos-commits mailing list
