[geos-commits] [SCM] GEOS branch master updated. 79e011013e7223f822832e39473048320e35f6f2
Thu Oct 1 13:22:54 PDT 2020
the project "GEOS".
       via  79e011013e7223f822832e39473048320e35f6f2 (commit)
      from  fd5f9496f229a489612f0422208dd60d04a77b62 (commit)
revisions in full, below.
commit 79e011013e7223f822832e39473048320e35f6f2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Oct 1 12:28:52 2020 -0700
    Fix HotPixel intersects test https://github.com/locationtech/jts/commit/c1977c8181137e8f705a66f0ea6784f428716953
diff --git a/include/geos/noding/snapround/HotPixel.h b/include/geos/noding/snapround/HotPixel.h
index a694a96..2fca4c1 100644
--- a/include/geos/noding/snapround/HotPixel.h
+++ b/include/geos/noding/snapround/HotPixel.h
@@ -82,7 +82,6 @@ private:
     double hpy;
     double scaleRound(double val) const;
-    geom::Coordinate scaleRound(const geom::Coordinate& p) const;
     double scale(double val) const;
diff --git a/include/geos/noding/snapround/HotPixel.inl b/include/geos/noding/snapround/HotPixel.inl
index d694d75..26e5e55 100644
--- a/include/geos/noding/snapround/HotPixel.inl
+++ b/include/geos/noding/snapround/HotPixel.inl
@@ -34,11 +34,6 @@ HotPixel::scaleRound(double val) const
     return util::round(val * scaleFactor);
-INLINE geom::Coordinate
-HotPixel::scaleRound(const geom::Coordinate& p) const
-    return geom::Coordinate(scaleRound(p.x), scaleRound(p.y));
 INLINE double
 HotPixel::scale(double val) const
diff --git a/src/noding/snapround/HotPixel.cpp b/src/noding/snapround/HotPixel.cpp
index c9740e8..bddafcd 100644
--- a/src/noding/snapround/HotPixel.cpp
+++ b/src/noding/snapround/HotPixel.cpp
@@ -160,13 +160,17 @@ HotPixel::intersectsScaled(double p0x, double p0y, double p1x, double p1y) const
     int orientUL = CGAlgorithmsDD::orientationIndex(px, py, qx, qy, minx, maxy);
     if (orientUL == 0) {
-      if (py < qy) return false;
-      return true;
+        // upward segment does not intersect pixel interior
+        if (py < qy) return false;
+        // downward segment must intersect pixel interior
+        return true;
     int orientUR = CGAlgorithmsDD::orientationIndex(px, py, qx, qy, maxx, maxy);
     if (orientUR == 0) {
+        // downward segment does not intersect pixel interior
         if (py > qy) return false;
+        // upward segment must intersect pixel interior
         return true;
     // check crossing Top side
@@ -175,7 +179,7 @@ HotPixel::intersectsScaled(double p0x, double p0y, double p1x, double p1y) const
     int orientLL = CGAlgorithmsDD::orientationIndex(px, py, qx, qy, minx, miny);
-    if (orientUL == 0) {
+    if (orientLL == 0) {
         // LL corner is the only one in pixel interior
         return true;
@@ -186,7 +190,9 @@ HotPixel::intersectsScaled(double p0x, double p0y, double p1x, double p1y) const
     int orientLR = CGAlgorithmsDD::orientationIndex(px, py, qx, qy, maxx, miny);
     if (orientLR == 0) {
         return true;
diff --git a/tests/unit/noding/snapround/HotPixelTest.cpp b/tests/unit/noding/snapround/HotPixelTest.cpp
index 9392038..e9f1fb0 100644
--- a/tests/unit/noding/snapround/HotPixelTest.cpp
+++ b/tests/unit/noding/snapround/HotPixelTest.cpp
@@ -308,5 +308,67 @@ void object::test<27>
         1.02, 0.98, 1.3, 0.7 );
+// Test segments tangent to a corner
+// testCornerLLTangent
+template<>
+template<>
+void object::test<28>()
+    checkIntersects("testCornerLLTangent", true, 1, 1, 10,
+        0.9, 1, 1, 0.9 );
+// testCornerLLTangentNoTouch
+template<>
+template<>
+void object::test<29>()
+    checkIntersects("testCornerLLTangentNoTouch", false, 1, 1, 10,
+        0.9, 0.9, 1, 0.9 );
+// testCornerULTangent
+template<>
+template<>
+void object::test<30>()
+    // does not intersect due to open top
+    checkIntersects("testCornerULTangent", false, 1, 1, 10,
+        0.9, 1, 1, 1.1 );
+// testCornerURTangent
+template<>
+template<>
+void object::test<31>()
+    checkIntersects("testCornerURTangent", false, 1, 1, 10,
+        1, 1.1, 1.1, 1 );
+// testCornerLRTangent
+template<>
+template<>
+void object::test<32>()
+    // does not intersect due to open right side
+    checkIntersects("testCornerLRTangent", false, 1, 1, 10,
+        1, 0.9, 1.1, 1 );
+// testCornerULTouchEnd
+template<>
+template<>
+void object::test<33>()
+    // does not intersect due to bounding box check for open top
+    checkIntersects("testCornerULTouchEnd", false, 1, 1, 10,
+        0.9, 1.1, 0.95, 1.05 );
 } // namespace tut
Summary of changes:
 include/geos/noding/snapround/HotPixel.h     |  1 -
 include/geos/noding/snapround/HotPixel.inl   |  5 ---
 src/noding/snapround/HotPixel.cpp            | 12 ++++--
 tests/unit/noding/snapround/HotPixelTest.cpp | 62 ++++++++++++++++++++++++++++
 4 files changed, 71 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
