[geos-commits] [SCM] GEOS branch master updated. e1982464794e489eccd5732d23ad19da6f054a6c
Thu Oct 1 15:39:41 PDT 2020
the project "GEOS".
       via  e1982464794e489eccd5732d23ad19da6f054a6c (commit)
       via  67defdfd5ffa2d1141992213b9630fb782d1a885 (commit)
       via  be391bde3774b0d97590497079f827dbee9f76b7 (commit)
       via  6e5f477a4017097248379591a72c1d9adde49b88 (commit)
       via  f90a44dff629786bc2f6ce9c7c676a1024c27800 (commit)
      from  79e011013e7223f822832e39473048320e35f6f2 (commit)
revisions in full, below.
commit e1982464794e489eccd5732d23ad19da6f054a6c
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Sat Jun 27 22:16:46 2020 +0200
    .azure-pipelines.yml: add a job to run tools/cppcheck.sh
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml
index 2d4d4e9..bbf5d62 100644
--- a/.azure-pipelines.yml
+++ b/.azure-pipelines.yml
@@ -258,3 +258,14 @@ stages:
         ctest -V --output-on-failure -C $BUILD_TYPE
       displayName: 'Build C++20'
       condition: contains(variables['CXXSTD'], '20')
+  - job: Code_quality_checks
+    pool:
+      vmImage: 'ubuntu-18.04'
+    steps:
+    - script: |
+        set -e
+        sudo -E apt-get update
+        sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
+        ./tools/cppcheck.sh
+      displayName: 'cppcheck'
commit 67defdfd5ffa2d1141992213b9630fb782d1a885
Date:   Sat Jun 27 22:16:33 2020 +0200
    Add tools/cppcheck.sh
diff --git a/tools/cppcheck.sh b/tools/cppcheck.sh
new file mode 100755
index 0000000..8fc4025
--- /dev/null
+++ b/tools/cppcheck.sh
@@ -0,0 +1,76 @@
+#!/bin/sh
+set -eu
+SCRIPT_DIR=$(dirname "$0")
+case $SCRIPT_DIR in
+        SCRIPT_DIR=$(pwd)
+        SCRIPT_DIR=$(pwd)/$(dirname "$0")
+esac
+LOG_FILE=/tmp/cppcheck_geos.txt
+rm -f ${LOG_FILE}
+echo "Checking ${SCRIPT_DIR}/../src ..."
+cppcheck --inline-suppr \
+         --template='{file}:{line},{severity},{id},{message}' \
+         --enable=all --inconclusive --std=c++11 \
+         -j $(nproc) \
+         ${SCRIPT_DIR}/../src \
+         >>${LOG_FILE} 2>&1 &
+PID=$!
+while kill -0 $PID 2>/dev/null; do
+    printf "."
+    sleep 1
+done
+echo " done"
+if ! wait $PID; then
+    echo "cppcheck failed"
+    exit 1
+fi
+ret_code=0
+cat ${LOG_FILE} | grep -v -e "syntaxError," -e "cppcheckError," > ${LOG_FILE}.tmp
+mv ${LOG_FILE}.tmp ${LOG_FILE}
+for category in "style" "performance" "portability"; do
+    if grep "${category}," ${LOG_FILE} >/dev/null; then
+        echo "INFO: Issues in '${category}' category found, but not considered as making script to fail:"
+        grep "${category}," ${LOG_FILE} | grep -v -e "clarifyCalculation," -e "duplicateExpressionTernary," -e "redundantCondition," -e "unusedPrivateFunction," -e "postfixOperator,"
+        echo ""
+    fi
+done
+# unusedPrivateFunction not reliable enough in cppcheck 1.72 of Ubuntu 16.04
+if test "$(cppcheck --version)" = "Cppcheck 1.72"; then
+    UNUSED_PRIVATE_FUNCTION=""
+else
+    UNUSED_PRIVATE_FUNCTION="unusedPrivateFunction"
+fi
+for category in "error" "warning" "clarifyCalculation" "duplicateExpressionTernary" "redundantCondition" "postfixOperator" "${UNUSED_PRIVATE_FUNCTION}"; do
+    if test "${category}" != ""; then
+            echo "ERROR: Issues in '${category}' category found:"
+            echo ""
+            echo "${category} check failed !"
+            ret_code=1
+        fi
+    fi
+done
+if [ ${ret_code} = 0 ]; then
+    echo "cppcheck succeeded"
+fi
+exit ${ret_code}
commit be391bde3774b0d97590497079f827dbee9f76b7
Date:   Sat Jun 27 22:12:14 2020 +0200
    Fix cppcheck warnings related to postfixOperator
diff --git a/src/geomgraph/EdgeIntersectionList.cpp b/src/geomgraph/EdgeIntersectionList.cpp
index d38eaa7..9b89e64 100644
--- a/src/geomgraph/EdgeIntersectionList.cpp
+++ b/src/geomgraph/EdgeIntersectionList.cpp
@@ -115,7 +115,7 @@ EdgeIntersectionList::addSplitEdges(std::vector<Edge*>* edgeList)
         Edge* newEdge = createSplitEdge(eiPrev, ei);
         edgeList->push_back(newEdge);
         eiPrev = ei;
-        it++;
+        ++it;
diff --git a/src/geomgraph/NodeMap.cpp b/src/geomgraph/NodeMap.cpp
index c74ecd6..6a6800c 100644
--- a/src/geomgraph/NodeMap.cpp
+++ b/src/geomgraph/NodeMap.cpp
@@ -49,9 +49,8 @@ NodeMap::NodeMap(const NodeFactory& newNodeFact)
 NodeMap::~NodeMap()
-    NodeMap::const_iterator it = nodeMap.begin();
-    for(; it != nodeMap.end(); it++) {
-        delete it->second;
+    for(auto& it: nodeMap) {
+        delete it.second;
@@ -143,9 +142,8 @@ NodeMap::find(const Coordinate& coord) const
 void
 NodeMap::getBoundaryNodes(int geomIndex, vector<Node*>& bdyNodes) const
-        Node* node = it->second;
+        Node* node = it.second;
         if(node->getLabel().getLocation(geomIndex) == Location::BOUNDARY) {
             bdyNodes.push_back(node);
@@ -156,9 +154,8 @@ string
 NodeMap::print() const
     string out = "";
         out += node->print();
     return out;
diff --git a/src/geomgraph/PlanarGraph.cpp b/src/geomgraph/PlanarGraph.cpp
index 48ac0b3..5cc06c6 100644
--- a/src/geomgraph/PlanarGraph.cpp
+++ b/src/geomgraph/PlanarGraph.cpp
@@ -164,7 +164,7 @@ PlanarGraph::getNodes(vector<Node*>& values)
     while(it != nodes->nodeMap.end()) {
         assert(it->second);
         values.push_back(it->second);
-        it++;
+        ++it;
@@ -233,9 +233,8 @@ PlanarGraph::linkResultDirectedEdges()
 #if GEOS_DEBUG
     cerr << "PlanarGraph::linkResultDirectedEdges called" << endl;
 #endif
-    NodeMap::iterator nodeit = nodes->nodeMap.begin();
-    for(; nodeit != nodes->nodeMap.end(); nodeit++) {
-        Node* node = nodeit->second;
+    for(auto& nodeIt: nodes->nodeMap) {
+        Node* node = nodeIt.second;
         assert(node);
         EdgeEndStar* ees = node->getEdges();
@@ -258,9 +257,8 @@ PlanarGraph::linkAllDirectedEdges()
 #if GEOS_DEBUG
     cerr << "PlanarGraph::linkAllDirectedEdges called" << endl;
 #endif
         assert(node);
diff --git a/src/geomgraph/index/SegmentIntersector.cpp b/src/geomgraph/index/SegmentIntersector.cpp
index b369046..88b4f39 100644
--- a/src/geomgraph/index/SegmentIntersector.cpp
+++ b/src/geomgraph/index/SegmentIntersector.cpp
@@ -163,8 +163,7 @@ SegmentIntersector::isBoundaryPoint(LineIntersector* p_li,
         return false;
-    for(std::vector<Node*>::iterator i = tstBdyNodes->begin(); i < tstBdyNodes->end(); i++) {
-        Node* node = *i;
+    for(const Node* node: *tstBdyNodes) {
         const Coordinate& pt = node->getCoordinate();
         if(p_li->isIntersection(pt)) {
             return true;
diff --git a/src/index/strtree/AbstractSTRtree.cpp b/src/index/strtree/AbstractSTRtree.cpp
index fd04cad..ca4722c 100644
--- a/src/index/strtree/AbstractSTRtree.cpp
+++ b/src/index/strtree/AbstractSTRtree.cpp
@@ -72,13 +72,8 @@ AbstractSTRtree::createParentBoundables(BoundableList* childBoundables,
     std::unique_ptr< BoundableList > sortedChildBoundables(sortBoundables(childBoundables));
-    for(BoundableList::iterator i = sortedChildBoundables->begin(),
-            e = sortedChildBoundables->end();
-            i != e; i++)
-        //for(std::size_t i=0, scbsize=sortedChildBoundables->size(); i<scbsize; ++i)
+    for(Boundable* childBoundable: *sortedChildBoundables)
-        Boundable* childBoundable = *i; // (*sortedChildBoundables)[i];
         AbstractNode* last = lastNode(parentBoundables.get());
         if(last->getChildBoundables()->size() == nodeCapacity) {
             last = createNode(newLevel);
@@ -160,9 +155,7 @@ AbstractSTRtree::query(const void* searchBounds, const AbstractNode& node,
     const BoundableList& boundables = *(node.getChildBoundables());
-    for(BoundableList::const_iterator i = boundables.begin(), e = boundables.end();
-            i != e; i++) {
-        const Boundable* childBoundable = *i;
+    for(const Boundable* childBoundable: boundables) {
         if(!getIntersectsOp()->intersects(childBoundable->getBounds(), searchBounds)) {
             continue;
diff --git a/src/noding/SegmentNodeList.cpp b/src/noding/SegmentNodeList.cpp
index 283084a..9ebb740 100644
--- a/src/noding/SegmentNodeList.cpp
+++ b/src/noding/SegmentNodeList.cpp
@@ -190,7 +190,7 @@ SegmentNodeList::addSplitEdges(std::vector<SegmentString*>& edgeList)
     iterator it = begin();
     SegmentNode* eiPrev = *it;
     assert(eiPrev);
-    it++;
+    ++it;
     for(iterator itEnd = end(); it != itEnd; ++it) {
         SegmentNode* ei = *it;
         assert(ei);
@@ -327,12 +327,7 @@ operator<< (std::ostream& os, const SegmentNodeList& nlist)
     os << "Intersections: (" << nlist.nodeMap.size() << "):" << std::endl;
-    std::set<SegmentNode*, SegmentNodeLT>::const_iterator
-    it = nlist.nodeMap.begin(),
-    itEnd = nlist.nodeMap.end();
-    for(; it != itEnd; it++) {
-        SegmentNode* ei = *it;
+    for(const SegmentNode* ei: nlist.nodeMap) {
         os << " " << *ei;
     return os;
diff --git a/src/operation/IsSimpleOp.cpp b/src/operation/IsSimpleOp.cpp
index 5f32254..c91a1a8 100644
--- a/src/operation/IsSimpleOp.cpp
+++ b/src/operation/IsSimpleOp.cpp
@@ -203,8 +203,7 @@ bool
 IsSimpleOp::hasNonEndpointIntersection(GeometryGraph& graph)
     vector<Edge*>* edges = graph.getEdges();
-    for(vector<Edge*>::iterator i = edges->begin(); i < edges->end(); i++) {
-        Edge* e = *i;
+    for(Edge* e: *edges) {
         auto maxSegmentIndex = e->getMaximumSegmentIndex();
         EdgeIntersectionList& eiL = e->getEdgeIntersectionList();
         for(const EdgeIntersection& ei : eiL) {
@@ -290,8 +289,7 @@ IsSimpleOp::hasClosedEndpointIntersection(GeometryGraph& graph)
     map<const Coordinate*, EndpointInfo*, CoordinateLessThen> endPoints;
-        Edge* e = *i;
         //int maxSegmentIndex=e->getMaximumSegmentIndex();
         bool isClosed = e->isClosed();
         const Coordinate* p0 = &e->getCoordinate(0);
diff --git a/src/operation/relate/EdgeEndBuilder.cpp b/src/operation/relate/EdgeEndBuilder.cpp
index af0c9bd..546a72e 100644
--- a/src/operation/relate/EdgeEndBuilder.cpp
+++ b/src/operation/relate/EdgeEndBuilder.cpp
@@ -65,14 +65,14 @@ EdgeEndBuilder::computeEdgeEnds(Edge* edge, std::vector<EdgeEnd*>* l)
     const EdgeIntersection* eiCurr = nullptr;
     const EdgeIntersection* eiNext = &*it;
-    it++;
+    ++it;
     do {
         eiPrev = eiCurr;
         eiCurr = eiNext;
         eiNext = nullptr;
         if(it != eiList.end()) {
             eiNext = &*it;
-            it++;
+            ++it;
         if(eiCurr != nullptr) {
             createEdgeEndForPrev(edge, l, eiCurr, eiPrev);
diff --git a/src/operation/relate/EdgeEndBundle.cpp b/src/operation/relate/EdgeEndBundle.cpp
index 5f95145..0c163c3 100644
--- a/src/operation/relate/EdgeEndBundle.cpp
+++ b/src/operation/relate/EdgeEndBundle.cpp
@@ -81,9 +81,7 @@ EdgeEndBundle::computeLabel(
     // the label must be an area label
     bool isArea = false;
-    for(vector<EdgeEnd*>::iterator it = edgeEnds.begin(), itEnd = edgeEnds.end();
-            it != itEnd; it++) {
-        EdgeEnd* e = *it;
+    for(EdgeEnd* e: edgeEnds) {
         if(e->getLabel().isArea()) {
             isArea = true;
@@ -111,8 +109,7 @@ EdgeEndBundle::computeLabelOn(int geomIndex, const algorithm::BoundaryNodeRule&
     int boundaryCount = 0;
     bool foundInterior = false;
-    for(vector<EdgeEnd*>::iterator it = edgeEnds.begin(); it < edgeEnds.end(); it++) {
-        EdgeEnd* e = *it;
         Location loc = e->getLabel().getLocation(geomIndex);
         if(loc == Location::BOUNDARY) {
             boundaryCount++;
@@ -160,8 +157,7 @@ EdgeEndBundle::computeLabelSides(int geomIndex)
 void
 EdgeEndBundle::computeLabelSide(int geomIndex, int side)
-        EdgeEnd* e = *it;
             Location loc = e->getLabel().getLocation(geomIndex, side);
             if(loc == Location::INTERIOR) {
diff --git a/src/operation/relate/RelateComputer.cpp b/src/operation/relate/RelateComputer.cpp
index 2c8d149..2f60953 100644
--- a/src/operation/relate/RelateComputer.cpp
+++ b/src/operation/relate/RelateComputer.cpp
@@ -234,8 +234,7 @@ RelateComputer::computeIM()
 void
 RelateComputer::insertEdgeEnds(std::vector<EdgeEnd*>* ee)
-    for(std::vector<EdgeEnd*>::iterator i = ee->begin(); i < ee->end(); i++) {
-        EdgeEnd* e = *i;
+    for(EdgeEnd* e: *ee) {
         nodes.add(e);
@@ -311,10 +310,8 @@ void
 RelateComputer::copyNodesAndLabels(int argIndex)
     const NodeMap* nm = (*arg)[argIndex]->getNodeMap();
-    NodeMap::const_iterator nodeIt = nm->begin(), nodeEnd = nm->end();
-    for(; nodeIt != nodeEnd; nodeIt++) {
-        Node* graphNode = nodeIt->second;
+    for(const auto& it: *nm) {
+        const Node* graphNode = it.second;
         Node* newNode = nodes.addNode(graphNode->getCoordinate());
         newNode->setLabel(argIndex,
                           graphNode->getLabel().getLocation(argIndex));
@@ -335,8 +332,7 @@ void
 RelateComputer::computeIntersectionNodes(int argIndex)
     std::vector<Edge*>* edges = (*arg)[argIndex]->getEdges();
-    for(std::vector<Edge*>::iterator i = edges->begin(); i < edges->end(); i++) {
-        Edge* e = *i;
         Location eLoc = e->getLabel().getLocation(argIndex);
         for(const EdgeIntersection & ei : eiL) {
@@ -364,8 +360,7 @@ void
 RelateComputer::labelIntersectionNodes(int argIndex)
-        Edge* e = *i;
@@ -439,8 +434,7 @@ void
 RelateComputer::labelIsolatedEdges(int thisIndex, int targetIndex)
     std::vector<Edge*>* edges = (*arg)[thisIndex]->getEdges();
-        Edge* e = *i;
         if(e->isIsolated()) {
             labelIsolatedEdge(e, targetIndex, (*arg)[targetIndex]->getGeometry());
             isolatedEdges.push_back(e);
@@ -470,9 +464,8 @@ RelateComputer::labelIsolatedEdge(Edge* e, int targetIndex, const Geometry* targ
 void
 RelateComputer::labelIsolatedNodes()
-    NodeMap::iterator nodeIt = nodes.begin(), nodeEnd = nodes.end();
-        Node* n = nodeIt->second;
+    for(const auto& it: nodes) {
+        Node* n = it.second;
         const Label& label = n->getLabel();
         // isolated nodes should always have at least one geometry in their label
         assert(label.getGeometryCount() > 0); // node with empty label found
diff --git a/src/operation/relate/RelateNodeGraph.cpp b/src/operation/relate/RelateNodeGraph.cpp
index f3bb52e..20b79a6 100644
--- a/src/operation/relate/RelateNodeGraph.cpp
+++ b/src/operation/relate/RelateNodeGraph.cpp
@@ -132,8 +132,7 @@ RelateNodeGraph::copyNodesAndLabels(GeometryGraph* geomGraph, int argIndex)
 void
 RelateNodeGraph::insertEdgeEnds(vector<EdgeEnd*>* ee)
-    for(vector<EdgeEnd*>::iterator i = ee->begin(); i < ee->end(); i++) {
-        EdgeEnd* e = *i;
         nodes->add(e);
diff --git a/src/simplify/TopologyPreservingSimplifier.cpp b/src/simplify/TopologyPreservingSimplifier.cpp
index 61885aa..c987ba3 100644
--- a/src/simplify/TopologyPreservingSimplifier.cpp
+++ b/src/simplify/TopologyPreservingSimplifier.cpp
@@ -101,18 +101,12 @@ public:
         return *this;
-    // postfix++
-    void
-    operator++(int)
-        _iter++;
     // ++suffix
-    void
+    LinesMapValueIterator&
     operator++()
         ++_iter;
+        return *this;
     // inequality operator
commit 6e5f477a4017097248379591a72c1d9adde49b88
Date:   Fri Sep 4 08:48:26 2020 +0200
    operator<< on MaximalEdgeRing: remove useless nullptr check
diff --git a/src/operation/overlayng/MaximalEdgeRing.cpp b/src/operation/overlayng/MaximalEdgeRing.cpp
index cba6577..6182d7b 100644
--- a/src/operation/overlayng/MaximalEdgeRing.cpp
+++ b/src/operation/overlayng/MaximalEdgeRing.cpp
@@ -207,8 +207,6 @@ operator<<(std::ostream& os, const MaximalEdgeRing& mer)
     OverlayEdge* edge = mer.startEdge;
     do {
         coords.add(edge->orig());
-        if (edge == nullptr)
-            break;
         if (edge->nextResultMax() == nullptr)
             break;
         edge = edge->nextResultMax();
commit f90a44dff629786bc2f6ce9c7c676a1024c27800
Date:   Sat Jun 27 21:46:25 2020 +0200
    TaggedLineStringSimplifier.cpp: avoid importing whole std namespace to avoid cppcheck confusing the class' remove method with std::remove
diff --git a/src/simplify/TaggedLineStringSimplifier.cpp b/src/simplify/TaggedLineStringSimplifier.cpp
index f778cc9..e3c87e4 100644
--- a/src/simplify/TaggedLineStringSimplifier.cpp
+++ b/src/simplify/TaggedLineStringSimplifier.cpp
@@ -40,7 +40,9 @@
 #endif
 using namespace geos::geom;
-using namespace std;
+using std::pair;
+using std::unique_ptr;
+using std::vector;
 namespace geos {
 namespace simplify { // geos::simplify
Summary of changes:
 .azure-pipelines.yml                          | 11 ++++
 src/geomgraph/EdgeIntersectionList.cpp        |  2 +-
 src/geomgraph/NodeMap.cpp                     | 15 +++---
 src/geomgraph/PlanarGraph.cpp                 | 12 ++---
 src/geomgraph/index/SegmentIntersector.cpp    |  3 +-
 src/index/strtree/AbstractSTRtree.cpp         | 11 +---
 src/noding/SegmentNodeList.cpp                |  9 +---
 src/operation/IsSimpleOp.cpp                  |  6 +--
 src/operation/overlayng/MaximalEdgeRing.cpp   |  2 -
 src/operation/relate/EdgeEndBuilder.cpp       |  4 +-
 src/operation/relate/EdgeEndBundle.cpp        | 10 ++--
 src/operation/relate/RelateComputer.cpp       | 23 +++-----
 src/operation/relate/RelateNodeGraph.cpp      |  3 +-
 src/simplify/TaggedLineStringSimplifier.cpp   |  4 +-
 src/simplify/TopologyPreservingSimplifier.cpp | 10 +---
 tools/cppcheck.sh                             | 76 +++++++++++++++++++++++++++
 16 files changed, 125 insertions(+), 76 deletions(-)
 create mode 100755 tools/cppcheck.sh
hooks/post-receive
More information about the geos-commits mailing list
