[geos-commits] [SCM] GEOS branch master updated. 0eb1c4cfce5ce66c3cd9e6924cf56b1364f1bbfc
Tue Sep 8 14:50:48 PDT 2020
the project "GEOS".
       via  0eb1c4cfce5ce66c3cd9e6924cf56b1364f1bbfc (commit)
      from  40e89b9f4d0c2caf35b433d3df823d423eddc932 (commit)
revisions in full, below.
commit 0eb1c4cfce5ce66c3cd9e6924cf56b1364f1bbfc
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Sep 8 14:14:35 2020 -0700
    Port https://github.com/dr-jts/jts/commit/ea45557987f4e992094842e7badde65811ea75cd, Cleanup of mixed result logic
diff --git a/include/geos/operation/overlayng/OverlayNG.h b/include/geos/operation/overlayng/OverlayNG.h
index d25a6f0..96ff5fc 100644
--- a/include/geos/operation/overlayng/OverlayNG.h
+++ b/include/geos/operation/overlayng/OverlayNG.h
@@ -126,7 +126,7 @@ public:
     static constexpr int UNION          = overlay::OverlayOp::opUNION;
     static constexpr int DIFFERENCE     = overlay::OverlayOp::opDIFFERENCE;
     static constexpr int SYMDIFFERENCE  = overlay::OverlayOp::opSYMDIFFERENCE;
-    static constexpr bool ALLOW_INT_MIXED_INT_RESULT = true;
+    static constexpr bool ALLOW_INT_MIXED_RESULT = true;
     * Creates an overlay operation on the given geometries,
diff --git a/src/operation/overlayng/LineBuilder.cpp b/src/operation/overlayng/LineBuilder.cpp
index ea0773b..f2fdd86 100644
--- a/src/operation/overlayng/LineBuilder.cpp
+++ b/src/operation/overlayng/LineBuilder.cpp
@@ -76,7 +76,7 @@ LineBuilder::isResultLine(const OverlayLabel* lbl) const
         return false;
-    if (OverlayNG::ALLOW_INT_MIXED_INT_RESULT &&
+    if (OverlayNG::ALLOW_INT_MIXED_RESULT &&
         opCode == OverlayNG::INTERSECTION &&
         lbl->isBoundaryTouch()) {
         return true;
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index 096f07e..96da319 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -234,25 +234,25 @@ OverlayNG::extractResult(int p_opCode, OverlayGraph* graph)
     std::vector<OverlayEdge*> resultAreaEdges = graph->getResultAreaEdges();
     PolygonBuilder polyBuilder(resultAreaEdges, geomFact);
     std::vector<std::unique_ptr<Polygon>> resultPolyList = polyBuilder.getPolygons();
-    bool hasResultComponents = resultPolyList.size() > 0;
+    bool hasResultAreaComponents = resultPolyList.size() > 0;
     //--- Build lines
-    bool allowMixedIntResult = ! hasResultComponents || ALLOW_INT_MIXED_INT_RESULT;
     std::vector<std::unique_ptr<LineString>> resultLineList;
-    if (p_opCode != INTERSECTION || allowMixedIntResult) {
-        LineBuilder lineBuilder(&inputGeom, graph, hasResultComponents, p_opCode, geomFact);
+    bool allowResultLines = ! hasResultAreaComponents || ALLOW_INT_MIXED_RESULT;
+    if(allowResultLines) {
+        LineBuilder lineBuilder(&inputGeom, graph, hasResultAreaComponents, p_opCode, geomFact);
         resultLineList = lineBuilder.getLines();
-    hasResultComponents = hasResultComponents || resultLineList.size() > 0;
+    bool hasResultComponents = hasResultAreaComponents || resultLineList.size() > 0;
-     * Since operations with point inputs are handled elsewhere,
-     * this only handles the case where non-point inputs
-     * intersect in points.
+     * Operations with point inputs are handled elsewhere.
+     * Only an intersection op can produce point results
+     * from non-point inputs.
     std::vector<std::unique_ptr<Point>> resultPointList;
-    allowMixedIntResult = ! hasResultComponents || ALLOW_INT_MIXED_INT_RESULT;
-    if (opCode == INTERSECTION && allowMixedIntResult) {
+    bool allowResultPoints = ! hasResultComponents || ALLOW_INT_MIXED_RESULT;
+    if (opCode == INTERSECTION && allowResultPoints) {
         IntersectionPointBuilder pointBuilder(graph, geomFact);
         resultPointList = pointBuilder.getPoints();
Summary of changes:
 include/geos/operation/overlayng/OverlayNG.h |  2 +-
 src/operation/overlayng/LineBuilder.cpp      |  2 +-
 src/operation/overlayng/OverlayNG.cpp        | 20 ++++++++++----------
 3 files changed, 12 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
