[geos-commits] [SCM] GEOS branch master updated. 675a2905e3cac127b8795ea0dde586e06096f32a
Tue Sep 8 17:44:19 PDT 2020
the project "GEOS".
       via  675a2905e3cac127b8795ea0dde586e06096f32a (commit)
      from  0eb1c4cfce5ce66c3cd9e6924cf56b1364f1bbfc (commit)
revisions in full, below.
commit 675a2905e3cac127b8795ea0dde586e06096f32a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Sep 8 17:22:29 2020 -0700
    Port https://github.com/dr-jts/jts/commit/959a61dcf5c5bb993e9de462f316b14e5c564ed7, Add optimization for line building
diff --git a/include/geos/operation/overlayng/OverlayLabel.h b/include/geos/operation/overlayng/OverlayLabel.h
index a184fcc..73077b7 100644
--- a/include/geos/operation/overlayng/OverlayLabel.h
+++ b/include/geos/operation/overlayng/OverlayLabel.h
@@ -194,6 +194,12 @@ public:
     bool isLineLocationUnknown(int index) const;
+    * Tests whether a label is for an edge which is a boundary of one geometry
+    * and not part of the other.
+    bool isBoundarySingleton() const;
     * Tests if a line edge is inside
     * @param index
     * @return
diff --git a/src/operation/overlayng/LineBuilder.cpp b/src/operation/overlayng/LineBuilder.cpp
index f2fdd86..3306a04 100644
--- a/src/operation/overlayng/LineBuilder.cpp
+++ b/src/operation/overlayng/LineBuilder.cpp
@@ -68,6 +68,13 @@ bool
 LineBuilder::isResultLine(const OverlayLabel* lbl) const
+     * An edge which is a boundary of a single geometry cannot form a line result.
+     * This is a short-circuit for area edges if no collapses or lines are present.
+    if (lbl->isBoundarySingleton())
+        return false;
     * Edges which are collapses along boundaries are not output.
     * I.e a result line edge must be from a input line
     * or two coincident area boundaries.
diff --git a/src/operation/overlayng/MaximalEdgeRing.cpp b/src/operation/overlayng/MaximalEdgeRing.cpp
index b42862c..cba6577 100644
--- a/src/operation/overlayng/MaximalEdgeRing.cpp
+++ b/src/operation/overlayng/MaximalEdgeRing.cpp
@@ -93,11 +93,11 @@ MaximalEdgeRing::attachEdges(OverlayEdge* p_startEdge)
     OverlayEdge* edge = p_startEdge;
     do {
         if (edge == nullptr)
-            throw util::TopologyException("Found null edge in ring");
+            throw util::TopologyException("Ring edge is null");
         if (edge->getEdgeRingMax() == this)
-            throw util::TopologyException("Edge visited twice during ring-building", edge->getCoordinate());
+            throw util::TopologyException("Ring edge visited twice", edge->getCoordinate());
         if (edge->nextResultMax() == nullptr) {
-            throw util::TopologyException("Found null edge in ring", edge->dest());
+            throw util::TopologyException("Ring edge missing", edge->dest());
         edge->setEdgeRingMax(this);
         edge = edge->nextResultMax();
diff --git a/src/operation/overlayng/OverlayLabel.cpp b/src/operation/overlayng/OverlayLabel.cpp
index c3ce312..385dab3 100644
--- a/src/operation/overlayng/OverlayLabel.cpp
+++ b/src/operation/overlayng/OverlayLabel.cpp
@@ -206,6 +206,21 @@ OverlayLabel::isBoundary(int index) const
 /*public*/
 bool
+OverlayLabel::isBoundarySingleton() const
+    if (aDim == DIM_BOUNDARY && bDim == DIM_NOT_PART) {
+        return true;
+    if (bDim == DIM_BOUNDARY && aDim == DIM_NOT_PART) {
+        return true;
+    return false;
+/*public*/
+bool
 OverlayLabel::isLineLocationUnknown(int index) const
     if (index == 0) {
Summary of changes:
 include/geos/operation/overlayng/OverlayLabel.h |  6 ++++++
 src/operation/overlayng/LineBuilder.cpp         |  7 +++++++
 src/operation/overlayng/MaximalEdgeRing.cpp     |  6 +++---
 src/operation/overlayng/OverlayLabel.cpp        | 15 +++++++++++++++
 4 files changed, 31 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
