[geos-commits] [SCM] GEOS branch master updated. 946a75daa4e48b392297e07f45ac0730e2c832e8
git at osgeo.org
git at osgeo.org
Thu Jan 7 23:14:31 PST 2021
the project "GEOS".
via 946a75daa4e48b392297e07f45ac0730e2c832e8 (commit)
from 534eebc107a996b51376c25505649a273dbe96a6 (commit)
revisions in full, below.
commit 946a75daa4e48b392297e07f45ac0730e2c832e8
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Jan 7 23:14:25 2021 -0800
Add geosop delaunay and voronoi ops
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index 1779e1b..05185b1 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -31,6 +31,8 @@
#include <geos/operation/overlayng/OverlayNG.h>
#include <geos/operation/polygonize/Polygonizer.h>
#include <geos/precision/GeometryPrecisionReducer.h>
+#include <geos/triangulate/DelaunayTriangulationBuilder.h>
+#include <geos/triangulate/VoronoiDiagramBuilder.h>
#include "GeomFunction.h"
@@ -142,20 +144,49 @@ GeomFunction::init()
return new Result( std::move(res) );
+ add("delaunay", "computes the Delaunay Triangulation of geometry A vertices", 1, 0,
+ [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
+ geos::triangulate::DelaunayTriangulationBuilder builder;
+ builder.setTolerance(0);
+ builder.setSites( *geom );
+ Geometry* out = builder.getTriangles(*(geom->getFactory())).release();
+ std::vector<std::unique_ptr<const Geometry>> geoms;
+ for(unsigned int i = 0; i < out->getNumGeometries(); i++) {
+ geoms.push_back( std::unique_ptr< const Geometry>( out->getGeometryN(i) ) );
+ return new Result( std::move(geoms) ) ;
+ add("voronoi", "computes the Voronoi Diagram of geometry A vertices", 1, 0,
+ geos::triangulate::VoronoiDiagramBuilder builder;
+ Geometry* out = builder.getDiagram(*(geom->getFactory())).release();
add("polygonize",
geos::operation::polygonize::Polygonizer p;
p.add(geom.get());
auto polys = p.getPolygons();
- std::vector<geom::Geometry*>* geoms = new std::vector<geom::Geometry*>;
for(unsigned int i = 0; i < polys.size(); i++) {
- geoms->push_back(polys[i].release());
+ geoms.push_back( std::move(polys[i]) );
- auto factory = geom->getFactory();
- Geometry * res = factory->createGeometryCollection(geoms);
- return new Result( res) ;
add("reverse", "reverses geometry A", 1, 0,
return new Result( geom->reverse() );
@@ -395,6 +426,12 @@ Result::Result(Geometry * val)
typeCode = typeGeometry;
+Result::Result( std::vector<std::unique_ptr<const Geometry>> val )
+ valGeomList = std::move(val);
+ typeCode = typeGeomList;
Result::~Result()
@@ -404,6 +441,11 @@ Result::isGeometry() {
return typeCode == typeGeometry;
+bool
+Result::isGeometryList() {
+ return typeCode == typeGeomList;
std::string
Result::toString() {
std::stringstream converter;
@@ -427,6 +469,9 @@ Result::toString() {
if (valGeom == nullptr)
return "null";
return valGeom->toString();
+ case typeGeomList:
+ return metadata();
return "Value for Unknonwn type";
@@ -443,6 +488,9 @@ Result::metadata() {
return "null";
return valGeom->getGeometryType() + "( " + std::to_string( valGeom->getNumPoints() ) + " )";
+ return "Geometry[" + std::to_string( valGeomList.size()) + "]";
return "Unknonwn type";
diff --git a/util/geosop/GeomFunction.h b/util/geosop/GeomFunction.h
index 6d2708d..5d9938a 100644
--- a/util/geosop/GeomFunction.h
+++ b/util/geosop/GeomFunction.h
@@ -33,22 +33,25 @@ public:
double valDouble;
std::string valStr;
std::unique_ptr<Geometry> valGeom;
+ std::vector<std::unique_ptr<const Geometry>> valGeomList;
Result(bool val);
Result(int val);
Result(std::string val);
Result(double val);
Result(std::unique_ptr<Geometry> val);
+ Result(std::vector<std::unique_ptr<const Geometry>> val);
Result(Geometry * val);
~Result();
bool isGeometry();
+ bool isGeometryList();
std::string metadata();
std::string toString();
private:
enum {
- typeBool = 1, typeInt, typeDouble, typeString, typeGeometry
+ typeBool = 1, typeInt, typeDouble, typeString, typeGeometry, typeGeomList
} typeCode;
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 066b0ff..034312e 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -429,6 +429,9 @@ void GeosOp::output(Result* result) {
outputGeometry( result->valGeom.get() );
+ else if (result->isGeometryList() ) {
+ outputGeometryList( result->valGeomList );
else {
// output as text/WKT
std::cout << result->toString() << std::endl;
@@ -462,3 +465,9 @@ void GeosOp::outputGeometry(const Geometry * geom) {
std::cout << writer.write(geom) << std::endl;
+void GeosOp::outputGeometryList(std::vector<std::unique_ptr<const Geometry>> & list) {
+ for (size_t i = 0; i < list.size(); i++) {
+ outputGeometry( list[i].get() );
diff --git a/util/geosop/GeosOp.h b/util/geosop/GeosOp.h
index 66f7bfe..f38a754 100644
--- a/util/geosop/GeosOp.h
+++ b/util/geosop/GeosOp.h
@@ -79,6 +79,7 @@ private:
void output(Result* result);
void outputExplode(std::unique_ptr<Geometry>& geom);
void outputGeometry( const Geometry* geom);
+ void outputGeometryList(std::vector<std::unique_ptr<const Geometry>> & val);
void log(std::string s);
Summary of changes:
util/geosop/GeomFunction.cpp | 58 ++++++++++++++++++++++++++++++++++++++++----
util/geosop/GeomFunction.h | 5 +++-
util/geosop/GeosOp.cpp | 9 +++++++
util/geosop/GeosOp.h | 1 +
4 files changed, 67 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
