[geos-commits] [SCM] GEOS branch master updated. 5326316a0daee792def110941c6e656068c8c2bf
git at osgeo.org
git at osgeo.org
Fri Jan 8 08:54:52 PST 2021
the project "GEOS".
via 5326316a0daee792def110941c6e656068c8c2bf (commit)
from 946a75daa4e48b392297e07f45ac0730e2c832e8 (commit)
revisions in full, below.
commit 5326316a0daee792def110941c6e656068c8c2bf
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Jan 8 08:54:46 2021 -0800
Fix geosop op help and negative args
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index 05185b1..9c55d22 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -179,7 +179,7 @@ GeomFunction::init()
geos::operation::polygonize::Polygonizer p;
p.add(geom.get());
- auto polys = p.getPolygons();
+ std::vector<std::unique_ptr<Polygon>> polys = p.getPolygons();
std::vector<std::unique_ptr<const Geometry>> geoms;
for(unsigned int i = 0; i < polys.size(); i++) {
geoms.push_back( std::move(polys[i]) );
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 034312e..5f04bb0 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -57,6 +57,15 @@ void showHelp() {
std::cout << "Usage: geosop [wktfile] opname args..." << std::endl;
+static bool startsWith(const std::string& s, const std::string& prefix) {
+ return s.size() >= prefix.size() && s.compare(0, prefix.size(), prefix) == 0;
+static bool endsWith(const std::string& str, const std::string& suffix)
+ return str.size() >= suffix.size() && 0 == str.compare(str.size()-suffix.size(), suffix.size(), suffix);
int main(int argc, char** argv) {
GeomFunction::init();
@@ -86,9 +95,13 @@ int main(int argc, char** argv) {
if (result.count("help")) {
std::cout << "geosop - GEOS v. " << geosversion() << std::endl;
+ options.positional_help("opName opArg");
std::cout << options.help() << std::endl;
//showHelp();
+ std::cout << "Notes:" << std::endl;
+ std::cout << "- Negative numeric op arguments can be specified with leading N: e.g. N-0.1" << std::endl;
+ std::cout << std::endl;
std::cout << "Operations:" << std::endl;
std::vector<std::string> ops = GeomFunction::list();
for (auto opName : ops) {
@@ -122,6 +135,13 @@ int main(int argc, char** argv) {
auto& v = result["opArgs"].as<std::vector<std::string>>();
if (v.size() >= 1) {
auto val = v[0];
+ * To get around cmdline parset limitation for parsing neg numbers,
+ * allow syntax "Nnum" as well
+ if (startsWith(val, "N")) {
+ val = val.substr(1, val.size()-1);
cmdArgs.opArg1 = std::stod(val);
@@ -148,15 +168,6 @@ std::string timeFormatted(int n)
return fmt + " usec";
-static bool startsWith(const std::string& s, const std::string& prefix) {
- return s.size() >= prefix.size() && s.compare(0, prefix.size(), prefix) == 0;
-static bool endsWith(const std::string& str, const std::string& suffix)
- return str.size() >= suffix.size() && 0 == str.compare(str.size()-suffix.size(), suffix.size(), suffix);
std::vector<std::unique_ptr<Geometry>> collect( std::vector<std::unique_ptr<Geometry>>& geoms ) {
auto gf = GeometryFactory::create();
auto gc = gf->createGeometryCollection( std::move(geoms) );
Summary of changes:
util/geosop/GeomFunction.cpp | 2 +-
util/geosop/GeosOp.cpp | 29 ++++++++++++++++++++---------
2 files changed, 21 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
