[geos-commits] [SCM] GEOS branch master updated. cc3dfc922408565fcda955882232b21a0c8e2220
git at osgeo.org
git at osgeo.org
Mon Jan 11 18:50:42 PST 2021
the project "GEOS".
via cc3dfc922408565fcda955882232b21a0c8e2220 (commit)
from a03a9ec61629aa68d6f78ff514e759a10db60fcf (commit)
revisions in full, below.
commit cc3dfc922408565fcda955882232b21a0c8e2220
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Jan 11 20:00:29 2021 -0500
[CMake] Make sure that assert() is disabled for any non-Debug build.
This is intended to cover the case where a packager builds with an
undefined build type in order to have all compiler flags drawn from the
environment.
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 89b05ec..2d3dd8c 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -181,6 +181,11 @@ else()
"GEOS: Function inlining DISABLED")
endif()
+# Make sure NDEBUG is defined so that assert() is disabled for
+# any non-debug build. Use a generator expression so that this
+# works with multi-configuration generators.
+target_compile_definitions(geos_cxx_flags INTERFACE $<$<NOT:$<CONFIG:Debug>>:NDEBUG>)
# Target geos_cxx_flags: overlayng code
Summary of changes:
CMakeLists.txt | 5 +++++
1 file changed, 5 insertions(+)
hooks/post-receive
More information about the geos-commits
