[geos-commits] [SCM] GEOS branch master updated. b77182f363505ccca3969a1f0a4d3e27a69e80b1
git at osgeo.org
git at osgeo.org
Tue Jan 12 14:18:36 PST 2021
the project "GEOS".
via b77182f363505ccca3969a1f0a4d3e27a69e80b1 (commit)
from cc3dfc922408565fcda955882232b21a0c8e2220 (commit)
revisions in full, below.
commit b77182f363505ccca3969a1f0a4d3e27a69e80b1
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Jan 12 14:18:29 2021 -0800
Add geosop simplifyDP and simplifyTP
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index 9c55d22..9e8d407 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -31,6 +31,8 @@
#include <geos/operation/overlayng/OverlayNG.h>
#include <geos/operation/polygonize/Polygonizer.h>
#include <geos/precision/GeometryPrecisionReducer.h>
+#include <geos/simplify/DouglasPeuckerSimplifier.h>
+#include <geos/simplify/TopologyPreservingSimplifier.h>
#include <geos/triangulate/DelaunayTriangulationBuilder.h>
#include <geos/triangulate/VoronoiDiagramBuilder.h>
@@ -269,6 +271,14 @@ GeomFunction::init()
std::unique_ptr<geom::IntersectionMatrix> im(geom->relate( geomB.get() ));
return new Result( im->toString() );
+ add("simplifyDP", "simplifies geometry A using Douglas-Peucker with a distance tolerance", 1, 1,
+ [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
+ return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(geom.get(), d) );
+ add("simplifyTP", "simplifies geometry A using Douglas-Peucker with a distance tolerance, preserving topology", 1, 1,
+ return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(geom.get(), d) );
add("difference", "computes difference of geometry A from B", 2, 0,
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 5f04bb0..108f076 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -77,10 +77,10 @@ int main(int argc, char** argv) {
("b", "source for B geometries (WKT, WKB, file, stdin, stdin.wkb)", cxxopts::value<std::string>( cmdArgs.srcB ))
("alimit", "Limit nunber of A geometries read", cxxopts::value<int>( cmdArgs.limitA ))
("c,collect", "Collect input into single geometry", cxxopts::value<bool>( cmdArgs.isCollect ))
- ("e,explode", "Explode result", cxxopts::value<bool>( cmdArgs.isExplode))
- ("f,format", "Output format", cxxopts::value<std::string>( ))
+ ("e,explode", "Explode results into conponent geometris", cxxopts::value<bool>( cmdArgs.isExplode))
+ ("f,format", "Output format (wkt, wkb or txt)", cxxopts::value<std::string>( ))
("h,help", "Print help")
- ("p,precision", "Sets number of decimal places in WKT output", cxxopts::value<int>( cmdArgs.precision ) )
+ ("p,precision", "Sets number of decimal places in output coordinates", cxxopts::value<int>( cmdArgs.precision ) )
("t,time", "Print execution time", cxxopts::value<bool>( cmdArgs.isShowTime ) )
("v,verbose", "Verbose output", cxxopts::value<bool>( cmdArgs.isVerbose )->default_value("false"))
@@ -92,9 +92,7 @@ int main(int argc, char** argv) {
auto result = options.parse(argc, argv);
if (argc <= 1 || result.count("help")) {
- if (result.count("help")) {
- std::cout << "geosop - GEOS v. " << geosversion() << std::endl;
+ std::cout << "geosop - GEOS " << geosversion() << std::endl;
options.positional_help("opName opArg");
std::cout << options.help() << std::endl;
//showHelp();
@@ -334,6 +332,7 @@ void GeosOp::run() {
<< "Processed " << opCount << " " << args.opName << " ops ( "
<< vertexCount << " vertices)"
<< " -- " << timeFormatted( totalTime )
+ << " (GEOS " << geosversion() << ")"
<< std::endl;
Summary of changes:
util/geosop/GeomFunction.cpp | 10 ++++++++++
util/geosop/GeosOp.cpp | 11 +++++------
2 files changed, 15 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
