[geos-commits] [SCM] GEOS branch master updated. dae18d6c6555b4b129ec053af3a50f7045fd5413
Fri Jan 15 19:59:09 PST 2021
the project "GEOS".
       via  dae18d6c6555b4b129ec053af3a50f7045fd5413 (commit)
       via  907d3b0b51484ddad0403217ac47c7bcc2a50eef (commit)
       via  29802a665505aa5fa00f942754d6d16ddfed5823 (commit)
      from  228ba06f8503132fa9d16509df0e1e843f2ab413 (commit)
revisions in full, below.
commit dae18d6c6555b4b129ec053af3a50f7045fd5413
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Jan 15 21:09:03 2021 -0500
    [CMake] Disable issue-geos-837 test on 32-bit builds
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index b99cc0b..9b8040c 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -24,6 +24,7 @@ target_include_directories(test_xmltester
   PRIVATE
     $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>/tinyxml)
+# Scan the directories of XML tests and create a test for each.
 foreach(_testdir general issue misc robust validate)
     file(GLOB_RECURSE _testfiles ${CMAKE_CURRENT_LIST_DIR}/tests/${_testdir}/*.xml CONFIGURE_DEPEND)
     foreach(_testfile ${_testfiles})
@@ -31,6 +32,10 @@ foreach(_testdir general issue misc robust validate)
         add_test(NAME ${_testdir}-${_testname} COMMAND test_xmltester -v --test-valid-output ${_testfile})
     endforeach()
 endforeach()
+# Disable tests that are known to fail on 32-bit systems.
+set_tests_properties(issue-issue-geos-837 PROPERTIES DISABLED $<EQUAL:4,${CMAKE_SIZEOF_VOID_P}>)
 unset(_testdir)
 unset(_testname)
 unset(_testfile)
commit 907d3b0b51484ddad0403217ac47c7bcc2a50eef
Date:   Fri Jan 15 20:29:45 2021 -0500
    [CMake] Add -ffloat-store to 32-bit build
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 2d3dd8c..342da91 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -168,6 +168,11 @@ target_compile_options(geos_cxx_flags INTERFACE
 	"$<$<CXX_COMPILER_ID:MSVC>:/fp:precise>"
+# Use -ffloat-store for 32-bit builds (needed to make some tests pass)
+target_compile_options(geos_cxx_flags INTERFACE
+  $<$<AND:$<CXX_COMPILER_ID:GNU>,$<EQUAL:4,${CMAKE_SIZEOF_VOID_P}>>:-ffloat-store>
 # Target geos_cxx_flags: common compilation flags
commit 29802a665505aa5fa00f942754d6d16ddfed5823
Date:   Thu Jan 14 16:26:12 2021 -0500
    Remove autotools configuration
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
index 52b5357..73d30a2 100644
--- a/.drone-1.0.yml
+++ b/.drone-1.0.yml
@@ -16,8 +16,9 @@ steps:
     image: *test-image
     pull: always
     commands:
-      - ./autogen.sh
-      - CXXFLAGS="-O0" ./configure
+      - mkdir build
+      - cd build
+      - CXXFLAGS="-O0" cmake ..
       - make V=0
   - name: check
     image: *test-image
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 2007c7f..04b9619 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -8,7 +8,6 @@ on: [push, pull_request]
 env:
   BUILD_TYPE: 'Release'
-  MAKEFLAGS: '-j2'
 jobs:
   linux:
@@ -26,18 +25,10 @@ jobs:
           compiler: g++,
-          build: autotools,
-          cxxstd: 11,
-          arch: 64,
-          packages: 'g++ automake doxygen git2cl',
-          os: ubuntu-18.04
-          compiler: g++,
-          build: autotools,
+          build: cmake,
           cxxstd: 11,
           arch: 32,
-          packages: 'g++-4.8-multilib gcc-4.8-multilib g++-multilib gcc-multilib doxygen automake git2cl',
+          packages: 'g++-4.8-multilib gcc-4.8-multilib g++-multilib gcc-multilib cmake doxygen',
           os: ubuntu-18.04
@@ -88,26 +79,18 @@ jobs:
       uses: actions/checkout at v2
     - name: 'Build'
+      env:
+        CFLAGS: "-m${{ matrix.ci.arch }}"
+        CXXFLAGS: "-m${{ matrix.ci.arch }}"
       run: |
         set -e
-        if [ ${{ matrix.ci.build }} == 'cmake' ];
-        then
-          mkdir build.cmake
-          cd build.cmake
-          cmake --version
-          cmake -DCMAKE_CXX_COMPILER=${{ matrix.ci.compiler }} -DCMAKE_CXX_STANDARD=${{ matrix.ci.cxxstd }} -DBUILD_DOCUMENTATION=YES -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-          make
-          cmake --build . --target docs
-          ctest --output-on-failure .
-        else
-          set -e
-          ./autogen.sh
-          mkdir build.autotools
-          cd build.autotools
-          CFLAGS="-std=c++${{ matrix.ci.cxxstd }} -m${{ matrix.ci.arch }}"
-          ../configure CC=${{ matrix.ci.compiler }} CXX=${{ matrix.ci.compiler }} CXXFLAGS="$CFLAGS" CFLAGS="$CFLAGS"
-          make && make check && make distcheck
-        fi
+        mkdir build.cmake
+        cd build.cmake
+        cmake --version
+        cmake -DCMAKE_CXX_COMPILER=${{ matrix.ci.compiler }} -DCMAKE_CXX_STANDARD=${{ matrix.ci.cxxstd }} -DBUILD_DOCUMENTATION=YES -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
+        cmake --build . -j 2
+        cmake --build . --target docs
+        ctest --output-on-failure .
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index c0ce10c..65f76c7 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -1,13 +1,14 @@
 before_script:
     - apt-get update -qq
-    - apt-get install -y --allow-unauthenticated build-essential autoconf automake libtool lsb-release
+    - apt-get install -y --allow-unauthenticated build-essential cmake lsb-release
     - lsb_release -a
     - uname -a
 test:
   script:
-    - ./autogen.sh
-    - ./configure
+    - mkdir build
+    - cd build
+    - cmake ..
     - make V=0
     - make check V=0
     - install -m 755 /bin/true /usr/local/bin/git2cl
diff --git a/.travis.yml b/.travis.yml
index 0cac68f..707fc74 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -51,18 +51,6 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-7','ccache','git2cl','doxygen']
-      env:
-        - E="TOOL=autotools && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
-    - os: linux
-      cache:
-        apt: true
-        directories:
-          - $HOME/.ccache
-      addons:
-        apt:
-          sources: *sources
           packages: ['g++-4.8','cmake','ccache','doxygen']
       env:
         - E="TOOL=cmake && BUILD_TYPE=Release && CXX=g++-4.8 && ARCH=-m64 && CC=gcc-4.8"
@@ -75,18 +63,6 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-4.8-multilib','gcc-4.8-multilib','g++-multilib','gcc-multilib','ccache','git2cl','doxygen']
-      env:
-        - E="TOOL=autotools && CXX=g++-4.8 && ARCH=-m32 && CC=gcc-4.8"
-    - os: linux
-      cache:
-        apt: true
-        directories:
-          - $HOME/.ccache
-      addons:
-        apt:
-          sources: *sources
           packages: ['clang-3.9','cmake','ccache','doxygen']
       env:
         - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++-3.9 && ARCH=-m64 && CC=clang-3.9"
@@ -104,21 +80,6 @@ matrix:
         - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++ && ARCH=-m64 && CC=clang"
     - os: linux
-      cache:
-        apt: true
-        directories:
-          - $HOME/.ccache
-      addons:
-        apt:
-          sources:
-            - ubuntu-toolchain-r-test
-            - sourceline: 'deb https://apt.llvm.org/xenial/ llvm-toolchain-xenial-9 main'
-              key_url: 'https://apt.llvm.org/llvm-snapshot.gpg.key'
-          packages: ['clang-9', 'clang-tools-9', 'ccache','doxygen']
-      env:
-        - E="TOOL=autotools_scanbuild && BUILD_TYPE=Release && ARCH=-m64"
-    - os: linux
       dist: bionic
       arch: arm64
       cache:
@@ -148,9 +109,6 @@ matrix:
     #   env:
     #     - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++ && CC=clang"
-  allow_failures:
-    - env: E="TOOL=autotools_scanbuild && BUILD_TYPE=Release && ARCH=-m64"
 before_install:
   - eval "${E}"
   - export CXXFLAGS=${ARCH}
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 2e356bc..2500fa5 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -18,12 +18,11 @@
 5. Run 'make dist-bzip2'.
-   $ ./autogen.sh && ./configure && make dist-bzip2
+   $ mkdir build && cd build && cmake .. && cmake --build . --target dist
 6. Verify that you can un-pack and build the tarball.
-   - autotools: ./configure && make check
-   - cmake: mkdir build && cd build && cmake .. && make && make check
+   - mkdir build && cd build && cmake .. && make && make check
 7. Copy the tarball to upload.osgeo.org:/osgeo/download/geos
diff --git a/Makefile.am b/Makefile.am
deleted file mode 100644
index dac8e06..0000000
--- a/Makefile.am
+++ /dev/null
@@ -1,79 +0,0 @@
-# This file is part of project GEOS (http://trac.osgeo.org/geos/)
-# NOTE: Make sure that 'src' appears first.
-# 'capi' and 'doc' surely rely on availability of libgeos
-# which is built under 'src' and it seems that automake
-# is not able to detect required build order but blindly
-# relies on the order items in SUBDIRS appear.
-# foreign is needed to avoid enforced ChangeLog in EXTRA_DIST
-# (we'll still take care of adding it ourselves)
-AUTOMAKE_OPTIONS = foreign
-SUBDIRS = \
-	include \
-	src     \
-	capi    \
-	doc     \
-	macros  \
-	tests   \
-	benchmarks \
-	util \
-	tools
-BUILT_SOURCES =
-EXTRA_DIST = \
-	README.md \
-	acsite.m4 \
-	.editorconfig \
-	Version.txt \
-	CMakeLists.txt \
-	cmake/cmake_uninstall.cmake.in \
-	cmake/geos-config.cmake \
-	cmake/FindMakeDistCheck.cmake
-pkgconfigdir = $(libdir)/pkgconfig
-pkgconfig_DATA = tools/geos.pc
-ACLOCAL_AMFLAGS = -I macros
-dist-hook: gen-ChangeLog
-gen-ChangeLog:
-	cd $(distdir) && owd=`pwd` && \
-  cd ../ && cd $(srcdir) && \
-	if test -d .git; then \
-		git log --pretty --numstat --summary | git2cl > $${owd}/ChangeLog; \
-	elif test -d .svn; then \
-		svn2cl --authors=authors.svn -i -o $${owd}/ChangeLog; \
-	elif test -f ChangeLog; then \
-		cp ChangeLog  $${owd}/ChangeLog; \
-	fi
-apidoc doxygen:
-	cd doc && make $@
-doxygen-checked:
-	( set -o pipefail; \
-		! make doxygen 2>&1 > /dev/null | \
-		grep -v '\(not documented\|ignoring unsupported tag\)'; \
-authors.git: authors.svn
-	cd $(srcdir) && sed -e 's/:/ = /' authors.svn > authors.git
-svnrebase: authors.git
-	cd $(srcdir) && git svn rebase --authors-file authors.git
-VALGRIND = $(LIBTOOL) --mode=execute valgrind --leak-check=full --error-exitcode=1
-valgrindcheck:
-	$(VALGRIND) tests/unit/geos_unit
-check-local:
-	! find $(srcdir) -name '*.cpp' -o -name '*.h' | \
-		grep -v tests/xmltester/tinyxml | \
-		xargs grep -n '[[:space:]]$$'
diff --git a/acsite.m4 b/acsite.m4
index 2b8d2df..0000000
--- a/acsite.m4
+++ /dev/null
@@ -1,55 +0,0 @@
-# This has been taken from postgres-9.1+ local macros
-# ( REL9_1_BETA2-1484-g293ec33 )
-# PGAC_TYPE_64BIT_INT(TYPE)
-# Check if TYPE is a working 64 bit integer type. Set HAVE_TYPE_64 to
-# yes or no respectively, and define HAVE_TYPE_64 if yes.
-AC_DEFUN([PGAC_TYPE_64BIT_INT],
-[define([Ac_define], [translit([have_$1_64], [a-z *], [A-Z_P])])dnl
-define([Ac_cachevar], [translit([pgac_cv_type_$1_64], [ *], [_p])])dnl
-AC_CACHE_CHECK([whether $1 is 64 bits], [Ac_cachevar],
-[AC_TRY_RUN(
-[typedef $1 ac_int64;
- * These are globals to discourage the compiler from folding all the
- * arithmetic tests down to compile-time constants.
-ac_int64 a = 20000001;
-ac_int64 b = 40000005;
-int does_int64_work()
-  ac_int64 c,d;
-  if (sizeof(ac_int64) != 8)
-    return 0;			/* definitely not the right size */
-  /* Do perfunctory checks to see if 64-bit arithmetic seems to work */
-  c = a * b;
-  d = (c + b) / b;
-  if (d != a+1)
-    return 0;
-  return 1;
-main() {
-  if (does_int64_work())
-    exit(0);
-  exit(-1);
-[Ac_cachevar=yes],
-[Ac_cachevar=no],
-[# If cross-compiling, check the size reported by the compiler and
-# trust that the arithmetic works.
-AC_COMPILE_IFELSE([AC_LANG_BOOL_COMPILE_TRY([], [sizeof($1) == 8])],
-                  Ac_cachevar=yes,
-                  Ac_cachevar=no)])])
-Ac_define=$Ac_cachevar
-if test x"$Ac_cachevar" = xyes ; then
-  AC_DEFINE(Ac_define, 1, [Define to 1 if `]$1[' works and is 64 bits.])
-fi
-undefine([Ac_define])dnl
-undefine([Ac_cachevar])dnl
-])# PGAC_TYPE_64BIT_INT
diff --git a/autogen.sh b/autogen.sh
deleted file mode 100755
index b2950c1..0000000
--- a/autogen.sh
+++ /dev/null
@@ -1,96 +0,0 @@
-#!/bin/sh
-# GEOS Bootstrapping Script
-giveup()
-        echo
-        echo "  Something went wrong, giving up!"
-        echo
-        exit 1
-OSTYPE=`uname -s`
-AUTOCONF=`which autoconf 2>/dev/null`
-if [ ! ${AUTOCONF} ]; then
-    echo "Missing autoconf!"
-    exit
-fi
-AUTOCONF_VER=`${AUTOCONF} --version | grep -E "^.*[0-9]$" | sed 's/^.* //'`
-AUTOHEADER=`which autoheader 2>/dev/null`
-if [ ! ${AUTOHEADER} ]; then
-    echo "Missing autoheader!"
-    exit
-fi
-for aclocal in aclocal aclocal-1.10 aclocal-1.9; do
-    ACLOCAL=`which $aclocal 2>/dev/null`
-    if test -x "${ACLOCAL}"; then
-        break;
-    fi
-done
-if [ ! ${ACLOCAL} ]; then
-    echo "Missing aclocal!"
-    exit
-fi
-ACLOCAL_VER=`${ACLOCAL} --version | grep -E "^.*[0-9]$" | sed 's/^.* //'`
-for automake in automake automake-1.10 automake-1.9; do
-    AUTOMAKE=`which $automake 2>/dev/null`
-    if test -x "${AUTOMAKE}"; then
-        break;
-    fi
-done
-if [ ! ${AUTOMAKE} ]; then
-    echo "Missing automake!"
-    exit
-fi
-AUTOMAKE_VER=`${AUTOMAKE} --version | grep -E "^.*[0-9]$" | sed 's/^.* //'`
-for libtoolize in libtoolize glibtoolize; do
-    LIBTOOLIZE=`which $libtoolize 2>/dev/null`
-    if test -x "${LIBTOOLIZE}"; then
-        break;
-    fi
-done
-if [ ! ${LIBTOOLIZE} ]; then
-    echo "Missing libtoolize!"
-    exit
-fi
-LIBTOOLIZE_VER=`${LIBTOOLIZE} --version | grep -E "^.*[0-9]\.[0-9]" | sed 's/^.* //'`
-AMOPTS="--add-missing --copy -Woverride"
-if test "$OSTYPE" = "IRIX" -o "$OSTYPE" = "IRIX64"; then
-   AMOPTS=$AMOPTS" --include-deps";
-fi
-LTOPTS="--force --copy"
-echo "* Running ${LIBTOOLIZE} (${LIBTOOLIZE_VER})"
-echo "   OPTIONS = ${LTOPTS}"
-${LIBTOOLIZE} ${LTOPTS} || giveup
-echo "* Running $ACLOCAL (${ACLOCAL_VER})"
-${ACLOCAL} -I macros || giveup
-echo "* Running ${AUTOHEADER} (${AUTOCONF_VER})"
-${AUTOHEADER} || giveup
-echo "* Running ${AUTOMAKE} (${AUTOMAKE_VER})"
-echo "   OPTIONS = ${AMOPTS}"
-${AUTOMAKE} ${AMOPTS} || giveup
-echo "* Running ${AUTOCONF} (${AUTOCONF_VER})"
-${AUTOCONF} || giveup
-if test -f "${PWD}/configure"; then
-    echo "======================================"
-    echo "Now you are ready to run './configure'"
-else
-    echo "  Failed to generate ./configure script!"
-    giveup
-fi
diff --git a/benchmarks/Makefile.am b/benchmarks/Makefile.am
index 82f124d..0000000
--- a/benchmarks/Makefile.am
+++ /dev/null
@@ -1,17 +0,0 @@
-SUBDIRS = \
-	algorithm \
-	operation \
-	capi
-LIBS = $(top_builddir)/src/libgeos.la
-AM_CPPFLAGS = -I$(top_srcdir)/include
-noinst_PROGRAMS = ClassSizes
-ClassSizes_SOURCES = ClassSizes.cpp
-EXTRA_DIST = CMakeLists.txt
diff --git a/benchmarks/algorithm/Makefile.am b/benchmarks/algorithm/Makefile.am
index 226f3d8..0000000
--- a/benchmarks/algorithm/Makefile.am
+++ /dev/null
@@ -1,25 +0,0 @@
-prefix=@prefix@
-top_srcdir=@top_srcdir@
-top_builddir=@top_builddir@
-noinst_PROGRAMS = \
-	InteriorPointAreaPerfTest \
-	VoronoiPerfTest \
-	UnaryUnionSegmentsPerfTest
-InteriorPointAreaPerfTest_SOURCES = InteriorPointAreaPerfTest.cpp
-InteriorPointAreaPerfTest_LDADD = $(top_builddir)/src/libgeos.la
-VoronoiPerfTest_SOURCES = VoronoiPerfTest.cpp
-VoronoiPerfTest_LDADD = $(top_builddir)/src/libgeos.la
-UnaryUnionSegmentsPerfTest_SOURCES = UnaryUnionSegmentsPerfTest.cpp
-UnaryUnionSegmentsPerfTest_LDADD = $(top_builddir)/src/libgeos.la
-AM_CPPFLAGS += -I$(top_srcdir)/src/io/markup
diff --git a/benchmarks/capi/Makefile.am b/benchmarks/capi/Makefile.am
index 9463c3f..0000000
--- a/benchmarks/capi/Makefile.am
+++ /dev/null
@@ -1,30 +0,0 @@
-prefix=@prefix@
-check_PROGRAMS = \
-	memleak_mp_prep \
-	GEOSPreparedContainsPerfTest \
-	IntersectionPerfTest \
-	UnaryOpPerfTest
-LIBS = $(top_builddir)/capi/libgeos_c.la
-AM_CPPFLAGS = -I$(top_builddir)/capi -I$(top_srcdir)/include
-memleak_mp_prep_SOURCES = memleak_mp_prep.c
-memleak_mp_prep_LDADD = $(LIBS)
-GEOSPreparedContainsPerfTest_SOURCES = GEOSPreparedContainsPerfTest.cpp
-GEOSPreparedContainsPerfTest_LDADD = $(top_builddir)/src/libgeos.la
-IntersectionPerfTest_SOURCES = IntersectionPerfTest.cpp
-IntersectionPerfTest_LDADD = $(top_builddir)/src/libgeos.la
-UnaryOpPerfTest_SOURCES = UnaryOpPerfTest.cpp
-UnaryOpPerfTest_LDADD = $(top_builddir)/src/libgeos.la
diff --git a/benchmarks/operation/Makefile.am b/benchmarks/operation/Makefile.am
index 36ff948..0000000
--- a/benchmarks/operation/Makefile.am
+++ /dev/null
@@ -1,9 +0,0 @@
-SUBDIRS = \
-	buffer \
-	predicate
diff --git a/benchmarks/operation/buffer/Makefile.am b/benchmarks/operation/buffer/Makefile.am
index f270b5f..0000000
--- a/benchmarks/operation/buffer/Makefile.am
+++ /dev/null
@@ -1,17 +0,0 @@
-prefix=@prefix@
-noinst_PROGRAMS = IteratedBufferStressTest
-IteratedBufferStressTest_SOURCES = IteratedBufferStressTest.cpp
-IteratedBufferStressTest_LDADD = $(LIBS)
diff --git a/benchmarks/operation/predicate/Makefile.am b/benchmarks/operation/predicate/Makefile.am
index 621456e..0000000
--- a/benchmarks/operation/predicate/Makefile.am
+++ /dev/null
@@ -1,17 +0,0 @@
-prefix=@prefix@
-noinst_PROGRAMS = RectangleIntersectsPerfTest
-RectangleIntersectsPerfTest_SOURCES = RectangleIntersectsPerfTest.cpp
-RectangleIntersectsPerfTest_LDADD = $(LIBS)
diff --git a/capi/Makefile.am b/capi/Makefile.am
index 3e5f7be..0000000
--- a/capi/Makefile.am
+++ /dev/null
@@ -1,33 +0,0 @@
-prefix=@prefix@
-GEOS_CAPI_VERSION="@VERSION at -CAPI-@CAPI_VERSION@"
-GEOS_JTS_PORT="@JTS_PORT@"
-capidir = $(includedir)
-nodist_capi_HEADERS = \
-    geos_c.h
-lib_LTLIBRARIES = libgeos_c.la
-DIR_SOURCES = \
-    geos_c.cpp \
-    geos_ts_c.cpp \
-    $(NULL)
-libgeos_c_la_SOURCES = $(DIR_SOURCES)
-libgeos_c_la_CPPFLAGS = $(AM_CPPFLAGS) -DGEOS_CAPI_VERSION='$(GEOS_CAPI_VERSION)' -DGEOS_JTS_PORT='$(GEOS_JTS_PORT)'
-libgeos_c_la_LIBADD = $(top_builddir)/src/libgeos.la
-libgeos_c_la_LDFLAGS = \
-    -version-info @CAPI_INTERFACE_CURRENT@:@CAPI_INTERFACE_REVISION@:@CAPI_INTERFACE_AGE@ \
-    -no-undefined
-dist-local:
-	cp -p $(DIST_SOURCES) Makefile.am Makefile.in $(distdir)
diff --git a/configure.ac b/configure.ac
index 91732b1..0000000
--- a/configure.ac
+++ /dev/null
@@ -1,434 +0,0 @@
-dnl
-dnl configure.in - autoconf input template to produce ./configure script
-dnl
-dnl version 2.52 is required for Cygwin libtool support
-AC_PREREQ([2.63])
-dnl local vars to hold user's preferences --------------------------------
-AC_INIT([include/geos.h])
-AC_CANONICAL_SYSTEM
-AC_CONFIG_MACRO_DIR([macros])
-dnl
-dnl -- Release versions / C++ library SONAME will use these
-dnl -- encoding ABI break at every release
-dnl
-VERTXT=${srcdir}/Version.txt
-VERSION_MAJOR=`cat $VERTXT | awk -F= '/^GEOS_VERSION_MAJOR/ {print $2}'`
-VERSION_MINOR=`cat $VERTXT | awk -F= '/^GEOS_VERSION_MINOR/ {print $2}'`
-VERSION_PATCH=`cat $VERTXT | awk -F= '/^GEOS_VERSION_PATCH/ {print $2}'`
-PATCH_WORD=`cat $VERTXT    | awk -F= '/^GEOS_PATCH_WORD/ {print $2}'`
-VERSION_PATCH=${VERSION_PATCH}${PATCH_WORD}
-VERSION="$VERSION_MAJOR.$VERSION_MINOR.$VERSION_PATCH"
-VERSION_RELEASE=`echo "$VERSION" | sed -E 's/^([[0-9]+\.[0-9]+\.[0-9]+]).*$/\1/'`
-AC_MSG_CHECKING([for GEOS version])
-AC_MSG_RESULT(["$VERSION"])
-CAPI_INTERFACE_CURRENT=`cat $VERTXT  | awk -F= '/^CAPI_INTERFACE_CURRENT/ {print $2}'`
-CAPI_INTERFACE_REVISION=`cat $VERTXT | awk -F= '/^CAPI_INTERFACE_REVISION/ {print $2}'`
-CAPI_INTERFACE_AGE=`cat $VERTXT      | awk -F= '/^CAPI_INTERFACE_AGE/ {print $2}'`
-dnl CAPI_VERSION_MAJOR=$(($CAPI_INTERFACE_CURRENT-$CAPI_INTERFACE_AGE))
-dnl the following should be more portable
-CAPI_VERSION_MAJOR=`expr $CAPI_INTERFACE_CURRENT - $CAPI_INTERFACE_AGE`
-CAPI_VERSION_MINOR=$CAPI_INTERFACE_AGE
-CAPI_VERSION_PATCH=$CAPI_INTERFACE_REVISION
-CAPI_VERSION="$CAPI_VERSION_MAJOR.$CAPI_VERSION_MINOR.$CAPI_VERSION_PATCH"
-AC_MSG_CHECKING([for GEOS CAPI version])
-AC_MSG_RESULT(["$CAPI_VERSION"])
-AM_INIT_AUTOMAKE([geos], [$VERSION], [no-define])
-AM_MAINTAINER_MODE
-m4_ifdef([AM_SILENT_RULES], [AM_SILENT_RULES])
-AC_CONFIG_HEADERS([include/config.h])
-AC_PROG_CC
-AC_CONFIG_LINKS([tools/astyle.sh:tools/astyle.sh])
-dnl -- JTS_PORT: the version of JTS this release is bound to
-dnl JTS_PORT=1.13.0
-JTS_PORT=`cat $VERTXT | awk -F= '/^JTS_PORT/ {print $2}'`
-DOXYGEN_LOGFILE=
-AC_SUBST(DOXYGEN_LOGFILE)
-dnl Hush warnings
-AC_DEFINE(USE_UNSTABLE_GEOS_CPP_API, [1], [We know])
-dnl use libtool ----------------------------------------------------------
-AC_LIBTOOL_DLOPEN
-AC_LIBTOOL_WIN32_DLL
-AC_PROG_LIBTOOL
-dnl check for programs ----------------------------------------------------
-AC_PROG_CXX
-AC_ISC_POSIX
-AC_PROG_INSTALL
-AC_PROG_MAKE_SET
-dnl function checks ------------------------------------------------------
-AC_FUNC_CLOSEDIR_VOID
-AC_FUNC_MEMCMP
-AC_FUNC_STRFTIME
-AC_FUNC_VPRINTF
-AC_FUNC_ALLOCA
-AC_HEADER_DIRENT
-AC_HEADER_STDC
-AC_CHECK_HEADERS([memory.h])
-AC_CHECK_HEADERS([unistd.h])
-AC_CHECK_HEADERS([ieeefp.h])
-AC_CHECK_HEADERS([sys/file.h])
-AC_CHECK_HEADERS([sys/time.h])
-AC_CHECK_FUNCS([strchr memcpy gettimeofday])
-AC_HEADER_STAT
-AC_STRUCT_TM
-AC_TYPE_SIZE_T
-AC_C_CONST
-dnl --------------------------------------------------------------------
-dnl - Check for inline and cassert settings
-AC_ARG_ENABLE([inline],
-	[  --disable-inline        Disable inlining],
-	[case "${enableval}" in
-		yes) enable_inline=true ;;
-		no)  enable_inline=false ;;
-		*) AC_MSG_ERROR(bad value ${enableval} for --enable-inline);;
-	esac],
-	[enable_inline=true]
-AC_ARG_ENABLE([cassert],
-	[  --disable-cassert       Disable assertion checking],
-		yes) enable_cassert=true ;;
-		no)  enable_cassert=false ;;
-		*) AC_MSG_ERROR(bad value ${enableval} for --enable-cassert);;
-	esac],
-	[enable_cassert=true]
-AC_ARG_ENABLE([glibcxx-debug],
-	[  --enable-glibcxx-debug  Enable libstdc++ debug mode],
-		yes) enable_glibcxx_debug=true ;;
-		no)  enable_glibcxx_debug=false ;;
-		*) AC_MSG_ERROR(bad value ${enableval} for --enable-glibcxx-debug);;
-	esac],
-	[enable_glibcxx_debug=false]
-AC_MSG_CHECKING([if requested to force inline functions])
-INLINE_FLAGS=
-AC_SUBST(INLINE_FLAGS)
-if test x"$enable_inline" = xtrue; then
-	INLINE_FLAGS="-DGEOS_INLINE"
-	AM_CXXFLAGS="$AM_CXXFLAGS $INLINE_FLAGS"
-    AC_MSG_RESULT([yes])
-else
-    AC_MSG_RESULT([no])
-fi
-AC_MSG_CHECKING([if requested to enable assert macros])
-if test x"$enable_cassert" = xfalse; then
-	AM_CXXFLAGS="$AM_CXXFLAGS -DNDEBUG"
-else
-fi
-AC_MSG_CHECKING([if requested libstdc++ debug mode])
-if test x"$enable_glibcxx_debug" = xtrue; then
-    AM_CXXFLAGS="$AM_CXXFLAGS -D_GLIBCXX_DEBUG=1 -D_GLIBCXX_DEBUG_PEDANTIC=1"
-else
-fi
-dnl - check whether user has requested overlayng
-dnl
-dnl AC_ARG_ENABLE([overlayng],
-dnl 	[  --disable-overlayng     Disable use of new overlay],
-dnl 	[case "${enableval}" in
-dnl 		yes) use_overlayng=true ;;
-dnl 		no)  use_overlayng=false ;;
-dnl 		*) AC_MSG_ERROR(bad value ${enableval} for --disable-overlayng) ;;
-dnl 	esac],
-dnl 	[use_overlayng=true]
-dnl )
-dnl
-dnl if test x"$use_overlayng" = xtrue; then
-dnl OVERLAYNG_FLAGS=""
-dnl else
-dnl 	OVERLAYNG_FLAGS="-DDISABLE_OVERLAYNG"
-dnl fi
-dnl - Append default C++ and C flags
-AC_PROG_CXX
-AX_CXX_COMPILE_STDCXX(11, noext, mandatory)
-WARNFLAGS=""
-AC_LANG_PUSH([C++])
-dnl Available in GCC 5.1
-AX_CHECK_COMPILE_FLAG([-Wsuggest-override -Werror], [WARNFLAGS="$WARNFLAGS -Wsuggest-override"])
-dnl Available in clang 3.5
-AX_CHECK_COMPILE_FLAG([-Wmissing-override -Werror], [WARNFLAGS="$WARNFLAGS -Wmissing-override"])
-AC_LANG_POP([C++])
-dnl In order for AC_LIBTOOL_COMPILER_OPTION to use
-dnl the C compiler we need the hack below.
-dnl It is likely a bug in the libtool macro file to
-dnl require AC_LIBTOOL_LANG_CXX_CONFIG in *addition*
-dnl to AC_LANG(CXX) or AC_LANG_PUSH(CXX)/AC_LANG_POP()
-dnl
-AC_LIBTOOL_LANG_CXX_CONFIG
-dnl Set default AM_CXXFLAGS and AM_CFLAGS
-dnl -pedantic: ISO does not support long long
-dnl we add -Wno-long-long to avoid those messages
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -pedantic], [dummy_cv_pedantic], [-pedantic], [], [WARNFLAGS="$WARNFLAGS -pedantic"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [dummy_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wno-long-long], [dummy_cv_wno_long_long], [-Wno-long-long], [], [WARNFLAGS="$WARNFLAGS -Wno-long-long"], [])
-dnl -----------------------------------------------------------------------------
-dnl To make numerical computation more stable, we use --ffloat-store
-dnl on 32-bit platforms
-NUMERICFLAGS=""
-dnl 32-bit platforms have a 4-byte pointer
-AC_CHECK_SIZEOF([void *])
-if test $ac_cv_sizeof_void_p -eq 4 ; then
-  AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ffloat-store], [dummy_cv_ffloat_store], [-ffloat-store], [], [NUMERICFLAGS="$NUMERICFLAGS -ffloat-store"], [])
-fi
-dnl Add flags to prevent 'fused multiply-add' operations on targets (ARM64)
-dnl that allow it, as it breaks calculations in math/DD.cpp.
-dnl TODO: Replace DD calculations with 'long float' where target supports
-dnl true long float, and remove other cases where FMA causes regression
-dnl failures.
-dnl     https://gcc.gnu.org/bugzilla/show_bug.cgi?id=98207
-NUMERICFLAGS="$NUMERICFLAGS -ffp-contract=off"
-HUSHWARNING="-DUSE_UNSTABLE_GEOS_CPP_API"
-DEFAULTFLAGS="${WARNFLAGS} ${NUMERICFLAGS} ${HUSHWARNING}"
-AM_CXXFLAGS="${AM_CXXFLAGS} ${DEFAULTFLAGS}"
-AM_CFLAGS="${AM_CFLAGS} ${DEFAULTFLAGS}"
-AC_SUBST(AM_CXXFLAGS)
-AC_SUBST(AM_CFLAGS)
-LIBS=$save_LIBS
-dnl - Look for a 64bit integer (do after CFLAGS is set)
-dnl Find a working 64bit integer
-PGAC_TYPE_64BIT_INT([int64_t])
-if test x"$HAVE_INT64_T_64" = x"no" ; then
-  PGAC_TYPE_64BIT_INT([long long int])
-  if test x"$HAVE_LONG_LONG_INT_64" = x"no" ; then
-    PGAC_TYPE_64BIT_INT([long int])
-    if test x"$HAVE_LONG_INT_64" = x"no" ; then
-      AC_MSG_WARN([Could not find a working 64bit int type, you may experience weird bugs (undefined behaviour)]);
-    fi
-  fi
-fi
-dnl - do operating-system specific things
-AC_MSG_CHECKING([OS-specific settings])
-case "${host_os}" in
-	*darwin*)
-		AC_MSG_RESULT([${host_os}])
-		AC_MSG_CHECKING([for OS/X version])
-		kernel=`uname -r`
-		# "Darwin 9.6.0" is Mac OSX 10.5.6
-		# "Darwin 10.x" would presumably be Mac OS X 10.6.x
-		case "${kernel}" in
-			8.*)
-				AC_MSG_RESULT([Mac OS X 10.4 Tiger])
-			9.*)
-				AC_MSG_RESULT([Mac OS X 10.5 Leopard])
-			10.*)
-dnl				AM_CXXFLAGS="$AM_CXXFLAGS -Wnon-virtual-dtor -Woverloaded-virtual"
-				AC_MSG_RESULT([Mac OS X 10.6 Snow Leopard])
-				AC_MSG_RESULT([Mac OS X (Darwin ${kernel} kernel)])
-		esac
-esac
-dnl things to substitute in output ----------------------------------------
-AC_SUBST(VERSION)
-AC_SUBST(VERSION_MAJOR)
-AC_SUBST(VERSION_MINOR)
-AC_SUBST(VERSION_PATCH)
-AC_SUBST(VERSION_RELEASE)
-AC_SUBST(JTS_PORT)
-AC_SUBST(CAPI_VERSION)
-AC_SUBST(CAPI_VERSION_MAJOR)
-AC_SUBST(CAPI_VERSION_MINOR)
-AC_SUBST(CAPI_VERSION_PATCH)
-AC_SUBST(CAPI_INTERFACE_CURRENT)
-AC_SUBST(CAPI_INTERFACE_REVISION)
-AC_SUBST(CAPI_INTERFACE_AGE)
-dnl pkg-config file -------------------------------------------------------
-AC_CONFIG_FILES([tools/geos.pc])
-dnl output stuff ----------------------------------------------------------
-AC_OUTPUT([
-	Makefile
-	capi/Makefile
-	capi/geos_c.h
-	doc/Doxyfile
-	doc/Makefile
-	macros/Makefile
-	src/Makefile
-	src/algorithm/Makefile
-	src/algorithm/construct/Makefile
-	src/algorithm/distance/Makefile
-	src/algorithm/locate/Makefile
-	src/deps/Makefile
-	src/deps/ryu/Makefile
-	src/edgegraph/Makefile
-	src/geom/Makefile
-	src/geom/prep/Makefile
-	src/geom/util/Makefile
-	src/geomgraph/Makefile
-	src/geomgraph/index/Makefile
-	include/Makefile
-	include/geos/Makefile
-	include/geos/algorithm/Makefile
-	include/geos/algorithm/locate/Makefile
-	include/geos/algorithm/distance/Makefile
-	include/geos/algorithm/construct/Makefile
-	include/geos/edgegraph/Makefile
-	include/geos/geom/Makefile
-	include/geos/geom/prep/Makefile
-	include/geos/geom/util/Makefile
-	include/geos/geomgraph/Makefile
-	include/geos/geomgraph/index/Makefile
-	include/geos/index/Makefile
-	include/geos/index/bintree/Makefile
-	include/geos/index/kdtree/Makefile
-	include/geos/index/chain/Makefile
-	include/geos/index/intervalrtree/Makefile
-	include/geos/index/quadtree/Makefile
-	include/geos/index/strtree/Makefile
-	include/geos/index/sweepline/Makefile
-	include/geos/io/Makefile
-	include/geos/linearref/Makefile
-	include/geos/math/Makefile
-	include/geos/noding/Makefile
-	include/geos/noding/snap/Makefile
-	include/geos/noding/snapround/Makefile
-	include/geos/operation/Makefile
-	include/geos/operation/buffer/Makefile
-	include/geos/operation/distance/Makefile
-	include/geos/operation/intersection/Makefile
-	include/geos/operation/linemerge/Makefile
-	include/geos/operation/overlay/Makefile
-	include/geos/operation/overlay/snap/Makefile
-	include/geos/operation/overlayng/Makefile
-	include/geos/operation/polygonize/Makefile
-	include/geos/operation/predicate/Makefile
-	include/geos/operation/relate/Makefile
-	include/geos/operation/sharedpaths/Makefile
-	include/geos/operation/union/Makefile
-	include/geos/operation/valid/Makefile
-	include/geos/planargraph/Makefile
-	include/geos/planargraph/algorithm/Makefile
-	include/geos/precision/Makefile
-	include/geos/simplify/Makefile
-	include/geos/triangulate/Makefile
-	include/geos/triangulate/quadedge/Makefile
-	include/geos/shape/Makefile
-	include/geos/shape/fractal/Makefile
-	include/geos/util/Makefile
-	include/geos/version.h
-	src/index/Makefile
-	src/index/bintree/Makefile
-	src/index/kdtree/Makefile
-	src/index/chain/Makefile
-	src/index/intervalrtree/Makefile
-	src/index/quadtree/Makefile
-	src/index/strtree/Makefile
-	src/index/sweepline/Makefile
-	src/io/Makefile
-	src/linearref/Makefile
-	src/math/Makefile
-	src/noding/Makefile
-	src/noding/snap/Makefile
-	src/noding/snapround/Makefile
-	src/operation/Makefile
-	src/operation/buffer/Makefile
-	src/operation/distance/Makefile
-	src/operation/intersection/Makefile
-	src/operation/linemerge/Makefile
-	src/operation/overlay/Makefile
-	src/operation/overlayng/Makefile
-	src/operation/polygonize/Makefile
-	src/operation/predicate/Makefile
-	src/operation/relate/Makefile
-	src/operation/sharedpaths/Makefile
-	src/operation/union/Makefile
-	src/operation/valid/Makefile
-	src/planargraph/Makefile
-	src/precision/Makefile
-	src/simplify/Makefile
-	src/triangulate/Makefile
-	src/triangulate/quadedge/Makefile
-	src/shape/Makefile
-	src/shape/fractal/Makefile
-	src/util/Makefile
-	tests/Makefile
-	tests/bigtest/Makefile
-	tests/unit/Makefile
-	benchmarks/Makefile
-	benchmarks/algorithm/Makefile
-	benchmarks/operation/Makefile
-	benchmarks/operation/buffer/Makefile
-	benchmarks/operation/predicate/Makefile
-	benchmarks/capi/Makefile
-	tests/xmltester/Makefile
-	tests/geostest/Makefile
-	tests/thread/Makefile
-	tools/Makefile
-	tools/geos-config
-	tools/astyle/Makefile
-	util/Makefile
-	util/geosop/Makefile
-dnl AC_MSG_RESULT([ ------------ GEOS Build ------------ ])
-dnl AC_MSG_RESULT([  Version:      ${VERSION}])
-dnl AC_MSG_RESULT([  Inlining:     ${enable_inline}])
-dnl AC_MSG_RESULT([ ------------------------------------ ])
diff --git a/doc/Makefile.am b/doc/Makefile.am
index 31723d3..0000000
--- a/doc/Makefile.am
+++ /dev/null
@@ -1,26 +0,0 @@
-prefix=@prefix@
-noinst_PROGRAMS = example
-example_SOURCES = example.cpp
-example_LDADD = $(LIBS)
-DOXYGEN = doxygen
-doxygen-html apidoc doxygen: Doxyfile
-	$(DOXYGEN) $<
-clean-local:
-	rm -Rf doxygen_docs
-EXTRA_DIST = Doxyfile \
-	CMakeLists.txt
diff --git a/include/Makefile.am b/include/Makefile.am
index c8e3434..0000000
--- a/include/Makefile.am
+++ /dev/null
@@ -1,10 +0,0 @@
-SUBDIRS = \
-    geos
-include_HEADERS = \
-    geos.h
diff --git a/include/geos/Makefile.am b/include/geos/Makefile.am
index 09ba8db..0000000
--- a/include/geos/Makefile.am
+++ /dev/null
@@ -1,37 +0,0 @@
-SUBDIRS = \
-    algorithm \
-    edgegraph \
-    geom \
-    geomgraph \
-    index \
-    io \
-    linearref \
-    math \
-    noding \
-    operation \
-    planargraph \
-    precision \
-    simplify \
-    triangulate \
-    shape \
-    util
-EXTRA_DIST =
-geosdir = $(includedir)/geos
-geos_HEADERS = \
-    constants.h \
-    export.h \
-    geom.h \
-    inline.h \
-    namespaces.h \
-    profiler.h \
-    unload.h \
-    util.h
-nodist_geos_HEADERS = \
-    version.h
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 1d1360f..0000000
--- a/include/geos/algorithm/Makefile.am
+++ /dev/null
@@ -1,41 +0,0 @@
-SUBDIRS = \
-	locate \
-	distance \
-	construct
-EXTRA_DIST =
-geosdir = $(includedir)/geos/algorithm
-geos_HEADERS = \
-	Angle.h \
-	Area.h \
-	BoundaryNodeRule.h \
-	CGAlgorithmsDD.h \
-	CGAlgorithmsDD.inl \
-	CentralEndpointIntersector.h \
-	Centroid.h \
-	ConvexHull.h \
-	ConvexHull.inl \
-	Distance.h \
-	HCoordinate.h \
-	InteriorPointArea.h \
-	InteriorPointLine.h \
-	InteriorPointPoint.h \
-	Intersection.h \
-	Length.h \
-	LineIntersector.h \
-	LineIntersector.inl \
-	MinimumBoundingCircle.h \
-	MinimumDiameter.h \
-	NotRepresentableException.h \
-	Orientation.h \
-	PointLocation.h \
-	PointLocator.h \
-	RayCrossingCounter.h \
-	RayCrossingCounterDD.h \
-	RobustDeterminant.h
diff --git a/include/geos/algorithm/construct/Makefile.am b/include/geos/algorithm/construct/Makefile.am
index 5986e03..0000000
--- a/include/geos/algorithm/construct/Makefile.am
+++ /dev/null
@@ -1,12 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/algorithm/construct
-geos_HEADERS = \
-    LargestEmptyCircle.h \
-    MaximumInscribedCircle.h
diff --git a/include/geos/algorithm/distance/Makefile.am b/include/geos/algorithm/distance/Makefile.am
index 7764b0e..0000000
--- a/include/geos/algorithm/distance/Makefile.am
+++ /dev/null
@@ -1,14 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/algorithm/distance
-geos_HEADERS = \
-    DiscreteHausdorffDistance.h \
-    DiscreteFrechetDistance.h \
-    DistanceToPoint.h \
-    PointPairDistance.h
diff --git a/include/geos/algorithm/locate/Makefile.am b/include/geos/algorithm/locate/Makefile.am
index 91e5a24..0000000
--- a/include/geos/algorithm/locate/Makefile.am
+++ /dev/null
@@ -1,13 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/algorithm/locate
-geos_HEADERS = \
-    IndexedPointInAreaLocator.h \
-    PointOnGeometryLocator.h \
-    SimplePointInAreaLocator.h
diff --git a/include/geos/edgegraph/Makefile.am b/include/geos/edgegraph/Makefile.am
index 473aa45..0000000
--- a/include/geos/edgegraph/Makefile.am
+++ /dev/null
@@ -1,11 +0,0 @@
-geosdir = $(includedir)/geos/edgegraph
-geos_HEADERS = \
-	EdgeGraph.h \
-	EdgeGraphBuilder.h \
-	HalfEdge.h \
-	MarkHalfEdge.h
diff --git a/include/geos/geom/Makefile.am b/include/geos/geom/Makefile.am
index d7afb62..0000000
--- a/include/geos/geom/Makefile.am
+++ /dev/null
@@ -1,54 +0,0 @@
-SUBDIRS = \
-    util \
-    prep
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/geom
-geos_HEADERS = \
-    HeuristicOverlay.h \
-    CoordinateArraySequenceFactory.h \
-    CoordinateArraySequenceFactory.inl \
-    CoordinateArraySequence.h \
-    CoordinateFilter.h \
-    Coordinate.h \
-    Coordinate.inl \
-    CoordinateList.h \
-    CoordinateSequenceFactory.h \
-    CoordinateSequenceFilter.h \
-    CoordinateSequence.h \
-    DefaultCoordinateSequenceFactory.h \
-    Dimension.h \
-    Envelope.h \
-    Envelope.inl \
-    FixedSizeCoordinateSequence.h \
-    GeometryCollection.h \
-    GeometryCollection.inl \
-    GeometryComponentFilter.h \
-    GeometryFactory.h \
-    GeometryFactory.inl \
-    GeometryFilter.h \
-    Geometry.h \
-    IntersectionMatrix.h \
-    LinearRing.h \
-    LineSegment.h \
-    LineSegment.inl \
-    LineString.h \
-    Location.h \
-    MultiLineString.h \
-    MultiLineString.inl \
-    MultiPoint.h \
-    MultiPolygon.h \
-    MultiPolygon.inl \
-    Point.h \
-    Polygon.h \
-    Position.h \
-    PrecisionModel.h \
-    PrecisionModel.inl \
-    Quadrant.h \
-    Quadrant.inl \
-    Triangle.h
diff --git a/include/geos/geom/prep/Makefile.am b/include/geos/geom/prep/Makefile.am
index edae9b0..0000000
--- a/include/geos/geom/prep/Makefile.am
+++ /dev/null
@@ -1,26 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/geom/prep
-geos_HEADERS = \
-    AbstractPreparedPolygonContains.h \
-    BasicPreparedGeometry.h \
-    PreparedGeometryFactory.h \
-    PreparedGeometry.h \
-    PreparedLineString.h \
-    PreparedLineStringDistance.h \
-    PreparedLineStringIntersects.h \
-    PreparedLineStringNearestPoints.h \
-    PreparedPoint.h \
-    PreparedPolygonContains.h \
-    PreparedPolygonContainsProperly.h \
-    PreparedPolygonCovers.h \
-    PreparedPolygonDistance.h \
-    PreparedPolygon.h \
-    PreparedPolygonIntersects.h \
-    PreparedPolygonPredicate.h
diff --git a/include/geos/geom/util/Makefile.am b/include/geos/geom/util/Makefile.am
index 32cdd32..0000000
--- a/include/geos/geom/util/Makefile.am
+++ /dev/null
@@ -1,23 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/geom/util
-geos_HEADERS = \
-    ComponentCoordinateExtracter.h \
-    CoordinateOperation.h \
-    GeometryCombiner.h \
-    GeometryEditor.h \
-    GeometryEditorOperation.h \
-    GeometryExtracter.h \
-    GeometryTransformer.h \
-    LinearComponentExtracter.h \
-    PointExtracter.h \
-    PolygonExtracter.h \
-    ShortCircuitedGeometryVisitor.h \
-    SineStarFactory.h \
-    Densifier.h
diff --git a/include/geos/geomgraph/Makefile.am b/include/geos/geomgraph/Makefile.am
index 94d7265..0000000
--- a/include/geos/geomgraph/Makefile.am
+++ /dev/null
@@ -1,34 +0,0 @@
-SUBDIRS = index
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/geomgraph
-geos_HEADERS = \
-    Depth.h \
-    Depth.inl \
-    DirectedEdge.h \
-    DirectedEdge.inl \
-    DirectedEdgeStar.h \
-    EdgeEnd.h \
-    EdgeEndStar.h \
-    Edge.h \
-    EdgeIntersection.h \
-    EdgeIntersectionList.h \
-    EdgeList.h \
-    EdgeNodingValidator.h \
-    EdgeRing.h \
-    GeometryGraph.h \
-    GeometryGraph.inl \
-    GraphComponent.h \
-    Label.h \
-    Label.inl \
-    NodeFactory.h \
-    Node.h \
-    NodeMap.h \
-    PlanarGraph.h \
-    TopologyLocation.h \
-    TopologyLocation.inl
diff --git a/include/geos/geomgraph/index/Makefile.am b/include/geos/geomgraph/index/Makefile.am
index 280fde3..0000000
--- a/include/geos/geomgraph/index/Makefile.am
+++ /dev/null
@@ -1,22 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/geomgraph/index
-geos_HEADERS = \
-    EdgeSetIntersector.h \
-    MonotoneChain.h \
-    MonotoneChainEdge.h \
-    MonotoneChainIndexer.h \
-    SegmentIntersector.h \
-    SegmentIntersector.inl \
-    SimpleEdgeSetIntersector.h \
-    SimpleMCSweepLineIntersector.h \
-    SimpleSweepLineIntersector.h \
-    SweepLineEvent.h \
-    SweepLineEventObj.h \
-    SweepLineSegment.h
diff --git a/include/geos/index/Makefile.am b/include/geos/index/Makefile.am
index d9bc0d4..0000000
--- a/include/geos/index/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-SUBDIRS = \
-    intervalrtree \
-    sweepline \
-    strtree \
-    quadtree \
-    bintree \
-    kdtree \
-    chain
-EXTRA_DIST =
-geosdir = $(includedir)/geos/index
-geos_HEADERS = \
-    ItemVisitor.h \
-    SpatialIndex.h
diff --git a/include/geos/index/bintree/Makefile.am b/include/geos/index/bintree/Makefile.am
index b11bba3..0000000
--- a/include/geos/index/bintree/Makefile.am
+++ /dev/null
@@ -1,17 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/index/bintree
-geos_HEADERS = \
-    Bintree.h \
-    Interval.h \
-    Key.h \
-    NodeBase.h \
-    Node.h \
-    Root.h
diff --git a/include/geos/index/chain/Makefile.am b/include/geos/index/chain/Makefile.am
index cf1952b..0000000
--- a/include/geos/index/chain/Makefile.am
+++ /dev/null
@@ -1,14 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/index/chain
-geos_HEADERS = \
-    MonotoneChain.h \
-    MonotoneChainBuilder.h \
-    MonotoneChainOverlapAction.h \
-    MonotoneChainSelectAction.h
diff --git a/include/geos/index/intervalrtree/Makefile.am b/include/geos/index/intervalrtree/Makefile.am
index 25c63e3..0000000
--- a/include/geos/index/intervalrtree/Makefile.am
+++ /dev/null
@@ -1,14 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/index/intervalrtree
-geos_HEADERS = \
-    IntervalRTreeBranchNode.h \
-    IntervalRTreeLeafNode.h \
-    IntervalRTreeNode.h \
-    SortedPackedIntervalRTree.h
diff --git a/include/geos/index/kdtree/Makefile.am b/include/geos/index/kdtree/Makefile.am
index 0c01057..0000000
--- a/include/geos/index/kdtree/Makefile.am
+++ /dev/null
@@ -1,15 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/index/kdtree
-geos_HEADERS = \
-    KdNode.h \
-    KdNodeVisitor.h \
-    KdTree.h
diff --git a/include/geos/index/quadtree/Makefile.am b/include/geos/index/quadtree/Makefile.am
index 04ace02..0000000
--- a/include/geos/index/quadtree/Makefile.am
+++ /dev/null
@@ -1,16 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/index/quadtree
-geos_HEADERS = \
-    IntervalSize.h \
-    Key.h \
-    NodeBase.h \
-    Node.h \
-    Quadtree.h \
-    Root.h
diff --git a/include/geos/index/strtree/Makefile.am b/include/geos/index/strtree/Makefile.am
index 204059d..0000000
--- a/include/geos/index/strtree/Makefile.am
+++ /dev/null
@@ -1,24 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/index/strtree
-geos_HEADERS = \
-    AbstractNode.h \
-    AbstractSTRtree.h \
-    Boundable.h \
-    BoundablePair.h \
-    EnvelopeUtil.h \
-    GeometryItemDistance.h \
-    Interval.h \
-    ItemBoundable.h \
-    ItemDistance.h \
-    SIRtree.h \
-    STRtree.h \
-    SimpleSTRtree.h \
-    SimpleSTRnode.h \
-    SimpleSTRdistance.h
diff --git a/include/geos/index/sweepline/Makefile.am b/include/geos/index/sweepline/Makefile.am
index c0bbab6..0000000
--- a/include/geos/index/sweepline/Makefile.am
+++ /dev/null
@@ -1,14 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/index/sweepline
-geos_HEADERS =              \
-    SweepLineIndex.h        \
-    SweepLineInterval.h     \
-    SweepLineOverlapAction.h
diff --git a/include/geos/io/Makefile.am b/include/geos/io/Makefile.am
index a59d32d..0000000
--- a/include/geos/io/Makefile.am
+++ /dev/null
@@ -1,23 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/io
-geos_HEADERS = \
-    ByteOrderDataInStream.h \
-    ByteOrderDataInStream.inl \
-    ByteOrderValues.h \
-    CLocalizer.h \
-    ParseException.h \
-    StringTokenizer.h \
-    WKBConstants.h \
-    WKBReader.h \
-    WKBWriter.h \
-    WKTReader.h \
-    WKTReader.inl \
-    WKTWriter.h \
-    Writer.h
diff --git a/include/geos/linearref/Makefile.am b/include/geos/linearref/Makefile.am
index 5a16f4e..0000000
--- a/include/geos/linearref/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-EXTRA_DIST =
-geosdir = $(includedir)/geos/linearref
-geos_HEADERS = \
-    ExtractLineByLocation.h \
-    LengthIndexedLine.h \
-    LengthIndexOfPoint.h \
-    LengthLocationMap.h \
-    LinearIterator.h \
-    LinearGeometryBuilder.h \
-    LinearLocation.h \
-    LocationIndexedLine.h \
-    LocationIndexOfLine.h \
-    LocationIndexOfPoint.h
diff --git a/include/geos/math/Makefile.am b/include/geos/math/Makefile.am
index 5396b95..0000000
--- a/include/geos/math/Makefile.am
+++ /dev/null
@@ -1,11 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/math
-geos_HEADERS = \
-    DD.h
diff --git a/include/geos/noding/Makefile.am b/include/geos/noding/Makefile.am
index bd32ea2..0000000
--- a/include/geos/noding/Makefile.am
+++ /dev/null
@@ -1,45 +0,0 @@
-SUBDIRS = \
-	snapround \
-	snap
-EXTRA_DIST =
-geosdir = $(includedir)/geos/noding
-geos_HEADERS = \
-	BasicSegmentString.h \
-	BasicSegmentString.inl \
-	FastNodingValidator.h \
-	FastSegmentSetIntersectionFinder.h \
-	GeometryNoder.h \
-	IntersectionAdder.h \
-	IntersectionFinderAdder.h \
-	IteratedNoder.h \
-	MCIndexNoder.h \
-	MCIndexNoder.inl \
-	MCIndexSegmentSetMutualIntersector.h \
-	NodableSegmentString.h \
-	NodedSegmentString.h \
-	NodedSegmentString.inl \
-	Noder.h \
-	NodingValidator.h \
-	Octant.h \
-	OrientedCoordinateArray.h \
-	ScaledNoder.h \
-	SegmentIntersectionDetector.h \
-	SegmentNode.h \
-	SegmentNode.inl \
-	SegmentNodeList.h \
-	SegmentPointComparator.h \
-	SegmentSetMutualIntersector.h \
-	SegmentString.h \
-	SegmentStringUtil.h \
-	SimpleNoder.h \
-	SinglePassNoder.h \
-	NodingIntersectionFinder.h \
-	NodingIntersectionFinder.inl \
-	ValidatingNoder.h
diff --git a/include/geos/noding/snap/Makefile.am b/include/geos/noding/snap/Makefile.am
index de6c74c..0000000
--- a/include/geos/noding/snap/Makefile.am
+++ /dev/null
@@ -1,13 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/noding/snap
-geos_HEADERS = \
-    SnappingIntersectionAdder.h \
-    SnappingNoder.h \
-    SnappingPointIndex.h
diff --git a/include/geos/noding/snapround/Makefile.am b/include/geos/noding/snapround/Makefile.am
index df40461..0000000
--- a/include/geos/noding/snapround/Makefile.am
+++ /dev/null
@@ -1,17 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/noding/snapround
-geos_HEADERS = \
-    HotPixel.h \
-    HotPixel.inl \
-    HotPixelIndex.h \
-    MCIndexPointSnapper.h \
-    MCIndexSnapRounder.h \
-    SnapRoundingNoder.h \
-    SnapRoundingIntersectionAdder.h
diff --git a/include/geos/operation/Makefile.am b/include/geos/operation/Makefile.am
index d6927bf..0000000
--- a/include/geos/operation/Makefile.am
+++ /dev/null
@@ -1,24 +0,0 @@
-SUBDIRS = \
-    buffer \
-    distance \
-    intersection \
-    linemerge \
-    polygonize \
-    overlay \
-    overlayng \
-    predicate \
-    relate \
-    union \
-    sharedpaths \
-    valid
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation
-geos_HEADERS = \
-    GeometryGraphOperation.h \
-    IsSimpleOp.h
diff --git a/include/geos/operation/buffer/Makefile.am b/include/geos/operation/buffer/Makefile.am
index fcfb3d4..0000000
--- a/include/geos/operation/buffer/Makefile.am
+++ /dev/null
@@ -1,21 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/buffer
-geos_HEADERS = \
-	BufferBuilder.h \
-	BufferInputLineSimplifier.h \
-	BufferOp.h \
-	BufferParameters.h \
-	BufferSubgraph.h \
-	OffsetCurveBuilder.h \
-	OffsetCurveSetBuilder.h \
-	OffsetSegmentGenerator.h \
-	OffsetSegmentString.h \
-	RightmostEdgeFinder.h \
-	SubgraphDepthLocater.h
diff --git a/include/geos/operation/distance/Makefile.am b/include/geos/operation/distance/Makefile.am
index 16cff8f..0000000
--- a/include/geos/operation/distance/Makefile.am
+++ /dev/null
@@ -1,17 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/distance
-geos_HEADERS = \
-	ConnectedElementLocationFilter.h \
-	ConnectedElementPointFilter.h \
-	DistanceOp.h \
-	IndexedFacetDistance.h \
-	FacetSequence.h \
-	FacetSequenceTreeBuilder.h \
-	GeometryLocation.h
diff --git a/include/geos/operation/intersection/Makefile.am b/include/geos/operation/intersection/Makefile.am
index 75d12f4..0000000
--- a/include/geos/operation/intersection/Makefile.am
+++ /dev/null
@@ -1,13 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/intersection
-geos_HEADERS = \
-  Rectangle.h \
-  RectangleIntersection.h \
-  RectangleIntersectionBuilder.h
diff --git a/include/geos/operation/linemerge/Makefile.am b/include/geos/operation/linemerge/Makefile.am
index 5f290c5..0000000
--- a/include/geos/operation/linemerge/Makefile.am
+++ /dev/null
@@ -1,16 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/linemerge
-geos_HEADERS = \
-	EdgeString.h \
-	LineMergeDirectedEdge.h \
-	LineMergeEdge.h \
-	LineMergeGraph.h \
-	LineMerger.h \
-	LineSequencer.h
diff --git a/include/geos/operation/overlay/Makefile.am b/include/geos/operation/overlay/Makefile.am
index 6f2425f..0000000
--- a/include/geos/operation/overlay/Makefile.am
+++ /dev/null
@@ -1,24 +0,0 @@
-SUBDIRS = snap
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/overlay
-geos_HEADERS = \
-    EdgeSetNoder.h \
-    ElevationMatrixCell.h \
-    ElevationMatrix.h \
-    LineBuilder.h \
-    MaximalEdgeRing.h \
-    MinimalEdgeRing.h \
-    MinimalEdgeRing.inl \
-    OverlayNodeFactory.h \
-    OverlayOp.h \
-    PointBuilder.h \
-    PolygonBuilder.h \
-    validate/FuzzyPointLocator.h \
-    validate/OffsetPointGenerator.h \
-    validate/OverlayResultValidator.h
diff --git a/include/geos/operation/overlay/snap/Makefile.am b/include/geos/operation/overlay/snap/Makefile.am
index d95beb3..0000000
--- a/include/geos/operation/overlay/snap/Makefile.am
+++ /dev/null
@@ -1,14 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/overlay/snap
-geos_HEADERS = \
-    GeometrySnapper.h \
-    LineStringSnapper.h \
-    SnapIfNeededOverlayOp.h \
-    SnapOverlayOp.h
diff --git a/include/geos/operation/overlayng/Makefile.am b/include/geos/operation/overlayng/Makefile.am
index 1e56fe2..0000000
--- a/include/geos/operation/overlayng/Makefile.am
+++ /dev/null
@@ -1,42 +0,0 @@
-SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/overlayng
-geos_HEADERS = \
-    Edge.h \
-    Edge.inl \
-    EdgeKey.h \
-    EdgeKey.inl \
-    EdgeMerger.h \
-    EdgeNodingBuilder.h \
-    EdgeSourceInfo.h \
-    ElevationModel.h \
-    IndexedPointOnLineLocator.h \
-    InputGeometry.h \
-    IntersectionPointBuilder.h \
-    LineBuilder.h \
-    LineLimiter.h \
-    OverlayEdge.h \
-    OverlayEdge.inl \
-    OverlayEdgeRing.h \
-    OverlayGraph.h \
-    OverlayLabel.h \
-    OverlayLabel.inl \
-    OverlayLabeller.h \
-    OverlayMixedPoints.h \
-    OverlayPoints.h \
-    OverlayNG.h \
-    OverlayNGRobust.h \
-    OverlayUtil.h \
-    PrecisionReducer.h \
-    PrecisionUtil.h \
-    RingClipper.h \
-    RobustClipEnvelopeComputer.h \
-    UnaryUnionNG.h
diff --git a/include/geos/operation/polygonize/Makefile.am b/include/geos/operation/polygonize/Makefile.am
index d55ed0d..0000000
--- a/include/geos/operation/polygonize/Makefile.am
+++ /dev/null
@@ -1,17 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/polygonize
-geos_HEADERS = \
-    BuildArea.h \
-    EdgeRing.h \
-    HoleAssigner.h \
-    PolygonizeDirectedEdge.h \
-    PolygonizeEdge.h \
-    PolygonizeGraph.h \
-    Polygonizer.h
diff --git a/include/geos/operation/predicate/Makefile.am b/include/geos/operation/predicate/Makefile.am
index cb667b5..0000000
--- a/include/geos/operation/predicate/Makefile.am
+++ /dev/null
@@ -1,13 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/predicate
-geos_HEADERS = \
-	RectangleContains.h	\
-	RectangleIntersects.h \
-	SegmentIntersectionTester.h
diff --git a/include/geos/operation/relate/Makefile.am b/include/geos/operation/relate/Makefile.am
index c7f3160..0000000
--- a/include/geos/operation/relate/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/relate
-geos_HEADERS =          \
-    EdgeEndBuilder.h    \
-    EdgeEndBundle.h     \
-    EdgeEndBundleStar.h \
-    RelateComputer.h    \
-    RelateNodeFactory.h \
-    RelateNodeGraph.h   \
-    RelateNode.h        \
-    RelateOp.h
diff --git a/include/geos/operation/sharedpaths/Makefile.am b/include/geos/operation/sharedpaths/Makefile.am
index 2e4af88..0000000
--- a/include/geos/operation/sharedpaths/Makefile.am
+++ /dev/null
@@ -1,11 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/sharedpaths
-geos_HEADERS = \
-    SharedPathsOp.h
diff --git a/include/geos/operation/union/Makefile.am b/include/geos/operation/union/Makefile.am
index 9b019f0..0000000
--- a/include/geos/operation/union/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/union
-geos_HEADERS = \
-    CascadedPolygonUnion.h \
-    CascadedUnion.h \
-    CoverageUnion.h \
-    OverlapUnion.h \
-    GeometryListHolder.h \
-    PointGeometryUnion.h \
-    UnaryUnionOp.h \
-    UnionStrategy.h
diff --git a/include/geos/operation/valid/Makefile.am b/include/geos/operation/valid/Makefile.am
index aed363d..0000000
--- a/include/geos/operation/valid/Makefile.am
+++ /dev/null
@@ -1,21 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/operation/valid
-geos_HEADERS = \
-    ConnectedInteriorTester.h   \
-    ConsistentAreaTester.h      \
-    IsValidOp.h                 \
-    IndexedNestedShellTester.h  \
-    MakeValid.h                 \
-    QuadtreeNestedRingTester.h  \
-    RepeatedPointRemover.h      \
-    RepeatedPointTester.h       \
-    SimpleNestedRingTester.h    \
-    SweeplineNestedRingTester.h \
-    TopologyValidationError.h
diff --git a/include/geos/planargraph/Makefile.am b/include/geos/planargraph/Makefile.am
index eb7de27..0000000
--- a/include/geos/planargraph/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-SUBDIRS = algorithm
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/planargraph
-geos_HEADERS = \
-    DirectedEdge.h \
-    Edge.h \
-    Node.h \
-    NodeMap.h \
-    PlanarGraph.h \
-    Subgraph.h
diff --git a/include/geos/planargraph/algorithm/Makefile.am b/include/geos/planargraph/algorithm/Makefile.am
index cd92549..0000000
--- a/include/geos/planargraph/algorithm/Makefile.am
+++ /dev/null
@@ -1,11 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/planargraph/algorithm
-geos_HEADERS = \
-    ConnectedSubgraphFinder.h
diff --git a/include/geos/precision/Makefile.am b/include/geos/precision/Makefile.am
index 6f88675..0000000
--- a/include/geos/precision/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/precision
-geos_HEADERS = \
-    CommonBits.h \
-    CommonBitsOp.h \
-    CommonBitsRemover.h \
-    EnhancedPrecisionOp.h \
-    GeometryPrecisionReducer.h \
-    MinimumClearance.h \
-    PrecisionReducerCoordinateOperation.h \
-    SimpleGeometryPrecisionReducer.h
diff --git a/include/geos/shape/Makefile.am b/include/geos/shape/Makefile.am
index 1c303f2..0000000
--- a/include/geos/shape/Makefile.am
+++ /dev/null
@@ -1,11 +0,0 @@
-SUBDIRS = \
-    fractal
-EXTRA_DIST =
-geosdir = $(includedir)/geos/shape
-geos_HEADERS =
diff --git a/include/geos/shape/fractal/Makefile.am b/include/geos/shape/fractal/Makefile.am
index 105a0d3..0000000
--- a/include/geos/shape/fractal/Makefile.am
+++ /dev/null
@@ -1,13 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/shape/fractal
-geos_HEADERS = \
-    HilbertCode.h \
-    HilbertEncoder.h \
-    MortonCode.h
diff --git a/include/geos/simplify/Makefile.am b/include/geos/simplify/Makefile.am
index ad250de..0000000
--- a/include/geos/simplify/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-SUBDIRS =
-geosdir = $(includedir)/geos/simplify
-EXTRA_DIST =
-geos_HEADERS = \
-    DouglasPeuckerLineSimplifier.h \
-    DouglasPeuckerSimplifier.h \
-    LineSegmentIndex.h \
-    TaggedLineSegment.h \
-    TaggedLinesSimplifier.h \
-    TaggedLineString.h \
-    TaggedLineStringSimplifier.h \
-    TopologyPreservingSimplifier.h
diff --git a/include/geos/triangulate/Makefile.am b/include/geos/triangulate/Makefile.am
index ed9c3a0..0000000
--- a/include/geos/triangulate/Makefile.am
+++ /dev/null
@@ -1,14 +0,0 @@
-SUBDIRS = \
-    quadedge
-EXTRA_DIST =
-geosdir = $(includedir)/geos/triangulate
-geos_HEADERS = \
-	IncrementalDelaunayTriangulator.h \
-	DelaunayTriangulationBuilder.h \
-	VoronoiDiagramBuilder.h
diff --git a/include/geos/triangulate/quadedge/Makefile.am b/include/geos/triangulate/quadedge/Makefile.am
index 1c05bed..0000000
--- a/include/geos/triangulate/quadedge/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/triangulate/quadedge
-geos_HEADERS = \
-    QuadEdge.h \
-    Vertex.h \
-	TrianglePredicate.h \
-	QuadEdgeQuartet.h \
-	QuadEdgeSubdivision.h \
-	QuadEdgeLocator.h \
-	LastFoundQuadEdgeLocator.h \
-	LocateFailureException.h \
-	TriangleVisitor.h
diff --git a/include/geos/util/Makefile.am b/include/geos/util/Makefile.am
index 3256095..0000000
--- a/include/geos/util/Makefile.am
+++ /dev/null
@@ -1,23 +0,0 @@
-#SUBDIRS =
-#EXTRA_DIST =
-geosdir = $(includedir)/geos/util
-geos_HEADERS = \
-    Assert.h \
-    AssertionFailedException.h \
-    CoordinateArrayFilter.h \
-    GeometricShapeFactory.h \
-    GEOSException.h \
-    IllegalArgumentException.h \
-    IllegalStateException.h \
-    Interrupt.h \
-    math.h \
-    Machine.h \
-    TopologyException.h \
-    UniqueCoordinateArrayFilter.h \
-    UnsupportedOperationException.h
diff --git a/macros/Makefile.am b/macros/Makefile.am
index 57c7ed6..0000000
--- a/macros/Makefile.am
+++ /dev/null
@@ -1,8 +0,0 @@
-prefix=@prefix@
-GEOS_VERSION=@GEOS_VERSION@
-EXTRA_DIST = geos.m4
diff --git a/macros/ax_check_compile_flag.m4 b/macros/ax_check_compile_flag.m4
index 89d3b93..0000000
--- a/macros/ax_check_compile_flag.m4
+++ /dev/null
@@ -1,74 +0,0 @@
-#   http://www.gnu.org/software/autoconf-archive/ax_check_compile_flag.html
-# SYNOPSIS
-#   AX_CHECK_COMPILE_FLAG(FLAG, [ACTION-SUCCESS], [ACTION-FAILURE], [EXTRA-FLAGS], [INPUT])
-# DESCRIPTION
-#   Check whether the given FLAG works with the current language's compiler
-#   or gives an error.  (Warnings, however, are ignored)
-#   ACTION-SUCCESS/ACTION-FAILURE are shell commands to execute on
-#   success/failure.
-#   If EXTRA-FLAGS is defined, it is added to the current language's default
-#   flags (e.g. CFLAGS) when the check is done.  The check is thus made with
-#   the flags: "CFLAGS EXTRA-FLAGS FLAG".  This can for example be used to
-#   force the compiler to issue an error when a bad flag is given.
-#   INPUT gives an alternative input source to AC_COMPILE_IFELSE.
-#   NOTE: Implementation based on AX_CFLAGS_GCC_OPTION. Please keep this
-#   macro in sync with AX_CHECK_{PREPROC,LINK}_FLAG.
-# LICENSE
-#   Copyright (c) 2008 Guido U. Draheim <guidod at gmx.de>
-#   Copyright (c) 2011 Maarten Bosmans <mkbosmans at gmail.com>
-#   This program is free software: you can redistribute it and/or modify it
-#   under the terms of the GNU General Public License as published by the
-#   Free Software Foundation, either version 3 of the License, or (at your
-#   option) any later version.
-#   This program is distributed in the hope that it will be useful, but
-#   WITHOUT ANY WARRANTY; without even the implied warranty of
-#   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General
-#   Public License for more details.
-#   You should have received a copy of the GNU General Public License along
-#   with this program. If not, see <http://www.gnu.org/licenses/>.
-#   As a special exception, the respective Autoconf Macro's copyright owner
-#   gives unlimited permission to copy, distribute and modify the configure
-#   scripts that are the output of Autoconf when processing the Macro. You
-#   need not follow the terms of the GNU General Public License when using
-#   or distributing such scripts, even though portions of the text of the
-#   Macro appear in them. The GNU General Public License (GPL) does govern
-#   all other use of the material that constitutes the Autoconf Macro.
-#   This special exception to the GPL applies to versions of the Autoconf
-#   Macro released by the Autoconf Archive. When you make and distribute a
-#   modified version of the Autoconf Macro, you may extend this special
-#   exception to the GPL to apply to your modified version as well.
-#serial 4
-AC_DEFUN([AX_CHECK_COMPILE_FLAG],
-[AC_PREREQ(2.63)dnl for _AC_LANG_PREFIX and AS_VAR_IF
-AS_VAR_PUSHDEF([CACHEVAR],[ax_cv_check_[]_AC_LANG_ABBREV[]flags_$4_$1])dnl
-AC_CACHE_CHECK([whether _AC_LANG compiler accepts $1], CACHEVAR, [
-  ax_check_save_flags=$[]_AC_LANG_PREFIX[]FLAGS
-  _AC_LANG_PREFIX[]FLAGS="$[]_AC_LANG_PREFIX[]FLAGS $4 $1"
-  AC_COMPILE_IFELSE([m4_default([$5],[AC_LANG_PROGRAM()])],
-    [AS_VAR_SET(CACHEVAR,[yes])],
-    [AS_VAR_SET(CACHEVAR,[no])])
-  _AC_LANG_PREFIX[]FLAGS=$ax_check_save_flags])
-AS_VAR_IF(CACHEVAR,yes,
-  [m4_default([$2], :)],
-  [m4_default([$3], :)])
-AS_VAR_POPDEF([CACHEVAR])dnl
-])dnl AX_CHECK_COMPILE_FLAGS
diff --git a/macros/ax_cxx_compile_stdcxx.m4 b/macros/ax_cxx_compile_stdcxx.m4
index 9e9eaed..0000000
--- a/macros/ax_cxx_compile_stdcxx.m4
+++ /dev/null
@@ -1,948 +0,0 @@
-#  https://www.gnu.org/software/autoconf-archive/ax_cxx_compile_stdcxx.html
-# SYNOPSIS
-#   AX_CXX_COMPILE_STDCXX(VERSION, [ext|noext], [mandatory|optional])
-# DESCRIPTION
-#   Check for baseline language coverage in the compiler for the specified
-#   version of the C++ standard.  If necessary, add switches to CXX and
-#   CXXCPP to enable support.  VERSION may be '11' (for the C++11 standard)
-#   or '14' (for the C++14 standard).
-#   The second argument, if specified, indicates whether you insist on an
-#   extended mode (e.g. -std=gnu++11) or a strict conformance mode (e.g.
-#   -std=c++11).  If neither is specified, you get whatever works, with
-#   preference for an extended mode.
-#   The third argument, if specified 'mandatory' or if left unspecified,
-#   indicates that baseline support for the specified C++ standard is
-#   required and that the macro should error out if no mode with that
-#   support is found.  If specified 'optional', then configuration proceeds
-#   regardless, after defining HAVE_CXX${VERSION} if and only if a
-#   supporting mode is found.
-# LICENSE
-#   Copyright (c) 2008 Benjamin Kosnik <bkoz at redhat.com>
-#   Copyright (c) 2012 Zack Weinberg <zackw at panix.com>
-#   Copyright (c) 2013 Roy Stogner <roystgnr at ices.utexas.edu>
-#   Copyright (c) 2014, 2015 Google Inc.; contributed by Alexey Sokolov <sokolov at google.com>
-#   Copyright (c) 2015 Paul Norman <penorman at mac.com>
-#   Copyright (c) 2015 Moritz Klammler <moritz at klammler.eu>
-#   Copyright (c) 2016, 2018 Krzesimir Nowak <qdlacz at gmail.com>
-#   Copying and distribution of this file, with or without modification, are
-#   permitted in any medium without royalty provided the copyright notice
-#   and this notice are preserved.  This file is offered as-is, without any
-#   warranty.
-#serial 10
-dnl  This macro is based on the code from the AX_CXX_COMPILE_STDCXX_11 macro
-dnl  (serial version number 13).
-AC_DEFUN([AX_CXX_COMPILE_STDCXX], [dnl
-  m4_if([$1], [11], [ax_cxx_compile_alternatives="11 0x"],
-        [$1], [14], [ax_cxx_compile_alternatives="14 1y"],
-        [$1], [17], [ax_cxx_compile_alternatives="17 1z"],
-        [m4_fatal([invalid first argument `$1' to AX_CXX_COMPILE_STDCXX])])dnl
-  m4_if([$2], [], [],
-        [$2], [ext], [],
-        [$2], [noext], [],
-        [m4_fatal([invalid second argument `$2' to AX_CXX_COMPILE_STDCXX])])dnl
-  m4_if([$3], [], [ax_cxx_compile_cxx$1_required=true],
-        [$3], [mandatory], [ax_cxx_compile_cxx$1_required=true],
-        [$3], [optional], [ax_cxx_compile_cxx$1_required=false],
-        [m4_fatal([invalid third argument `$3' to AX_CXX_COMPILE_STDCXX])])
-  AC_LANG_PUSH([C++])dnl
-  ac_success=no
-  m4_if([$2], [noext], [], [dnl
-  if test x$ac_success = xno; then
-    for alternative in ${ax_cxx_compile_alternatives}; do
-      switch="-std=gnu++${alternative}"
-      cachevar=AS_TR_SH([ax_cv_cxx_compile_cxx$1_$switch])
-      AC_CACHE_CHECK(whether $CXX supports C++$1 features with $switch,
-                     $cachevar,
-        [ac_save_CXX="$CXX"
-         CXX="$CXX $switch"
-         AC_COMPILE_IFELSE([AC_LANG_SOURCE([_AX_CXX_COMPILE_STDCXX_testbody_$1])],
-          [eval $cachevar=yes],
-          [eval $cachevar=no])
-         CXX="$ac_save_CXX"])
-      if eval test x\$$cachevar = xyes; then
-        if test -n "$CXXCPP" ; then
-          CXXCPP="$CXXCPP $switch"
-        fi
-        ac_success=yes
-        break
-      fi
-    done
-  fi])
-  m4_if([$2], [ext], [], [dnl
-    dnl HP's aCC needs +std=c++11 according to:
-    dnl http://h21007.www2.hp.com/portal/download/files/unprot/aCxx/PDF_Release_Notes/769149-001.pdf
-    dnl Cray's crayCC needs "-h std=c++11"
-      for switch in -std=c++${alternative} +std=c++${alternative} "-h std=c++${alternative}"; do
-                       $cachevar,
-          fi
-          ac_success=yes
-          break
-        fi
-      done
-      if test x$ac_success = xyes; then
-        break
-      fi
-    done
-  fi])
-  AC_LANG_POP([C++])
-  if test x$ax_cxx_compile_cxx$1_required = xtrue; then
-      AC_MSG_ERROR([*** A compiler with support for C++$1 language features is required.])
-    fi
-  fi
-    HAVE_CXX$1=0
-    AC_MSG_NOTICE([No compiler with C++$1 support was found])
-  else
-    HAVE_CXX$1=1
-    AC_DEFINE(HAVE_CXX$1,1,
-              [define if the compiler supports basic C++$1 syntax])
-  fi
-  AC_SUBST(HAVE_CXX$1)
-dnl  Test body for checking C++11 support
-m4_define([_AX_CXX_COMPILE_STDCXX_testbody_11],
-  _AX_CXX_COMPILE_STDCXX_testbody_new_in_11
-dnl  Test body for checking C++14 support
-m4_define([_AX_CXX_COMPILE_STDCXX_testbody_14],
-  _AX_CXX_COMPILE_STDCXX_testbody_new_in_14
-m4_define([_AX_CXX_COMPILE_STDCXX_testbody_17],
-  _AX_CXX_COMPILE_STDCXX_testbody_new_in_17
-dnl  Tests for new features in C++11
-m4_define([_AX_CXX_COMPILE_STDCXX_testbody_new_in_11], [[
-// If the compiler admits that it is not ready for C++11, why torture it?
-// Hopefully, this will speed up the test.
-#ifndef __cplusplus
-#error "This is not a C++ compiler"
-#elif __cplusplus < 201103L
-#error "This is not a C++11 compiler"
-#else
-namespace cxx11
-  namespace test_static_assert
-    template <typename T>
-    struct check
-      static_assert(sizeof(int) <= sizeof(T), "not big enough");
-  namespace test_final_override
-    struct Base
-      virtual void f() {}
-    struct Derived : public Base
-      virtual void f() override {}
-  namespace test_double_right_angle_brackets
-    template < typename T >
-    struct check {};
-    typedef check<void> single_type;
-    typedef check<check<void>> double_type;
-    typedef check<check<check<void>>> triple_type;
-    typedef check<check<check<check<void>>>> quadruple_type;
-  namespace test_decltype
-    int
-    f()
-      int a = 1;
-      decltype(a) b = 2;
-      return a + b;
-  namespace test_type_deduction
-    template < typename T1, typename T2 >
-    struct is_same
-      static const bool value = false;
-    struct is_same<T, T>
-      static const bool value = true;
-    auto
-    add(T1 a1, T2 a2) -> decltype(a1 + a2)
-      return a1 + a2;
-    int
-    test(const int c, volatile int v)
-      static_assert(is_same<int, decltype(0)>::value == true, "");
-      static_assert(is_same<int, decltype(c)>::value == false, "");
-      static_assert(is_same<int, decltype(v)>::value == false, "");
-      auto ac = c;
-      auto av = v;
-      auto sumi = ac + av + 'x';
-      auto sumf = ac + av + 1.0;
-      static_assert(is_same<int, decltype(ac)>::value == true, "");
-      static_assert(is_same<int, decltype(av)>::value == true, "");
-      static_assert(is_same<int, decltype(sumi)>::value == true, "");
-      static_assert(is_same<int, decltype(sumf)>::value == false, "");
-      static_assert(is_same<int, decltype(add(c, v))>::value == true, "");
-      return (sumf > 0.0) ? sumi : add(c, v);
-  namespace test_noexcept
-    int f() { return 0; }
-    int g() noexcept { return 0; }
-    static_assert(noexcept(f()) == false, "");
-    static_assert(noexcept(g()) == true, "");
-  namespace test_constexpr
-    template < typename CharT >
-    unsigned long constexpr
-    strlen_c_r(const CharT *const s, const unsigned long acc) noexcept
-      return *s ? strlen_c_r(s + 1, acc + 1) : acc;
-    strlen_c(const CharT *const s) noexcept
-      return strlen_c_r(s, 0UL);
-    static_assert(strlen_c("") == 0UL, "");
-    static_assert(strlen_c("1") == 1UL, "");
-    static_assert(strlen_c("example") == 7UL, "");
-    static_assert(strlen_c("another\0example") == 7UL, "");
-  namespace test_rvalue_references
-    template < int N >
-    struct answer
-      static constexpr int value = N;
-    answer<1> f(int&)       { return answer<1>(); }
-    answer<2> f(const int&) { return answer<2>(); }
-    answer<3> f(int&&)      { return answer<3>(); }
-    void
-    test()
-      int i = 0;
-      const int c = 0;
-      static_assert(decltype(f(i))::value == 1, "");
-      static_assert(decltype(f(c))::value == 2, "");
-      static_assert(decltype(f(0))::value == 3, "");
-  namespace test_uniform_initialization
-    struct test
-      static const int zero {};
-      static const int one {1};
-    static_assert(test::zero == 0, "");
-    static_assert(test::one == 1, "");
-  namespace test_lambdas
-    void
-    test1()
-      auto lambda1 = [](){};
-      auto lambda2 = lambda1;
-      lambda1();
-      lambda2();
-    int
-    test2()
-      auto a = [](int i, int j){ return i + j; }(1, 2);
-      auto b = []() -> int { return '0'; }();
-      auto c = [=](){ return a + b; }();
-      auto d = [&](){ return c; }();
-      auto e = [a, &b](int x) mutable {
-        const auto identity = [](int y){ return y; };
-        for (auto i = 0; i < a; ++i)
-          a += b--;
-        return x + identity(a + b);
-      }(0);
-      return a + b + c + d + e;
-    int
-    test3()
-      const auto nullary = [](){ return 0; };
-      const auto unary = [](int x){ return x; };
-      using nullary_t = decltype(nullary);
-      using unary_t = decltype(unary);
-      const auto higher1st = [](nullary_t f){ return f(); };
-      const auto higher2nd = [unary](nullary_t f1){
-        return [unary, f1](unary_t f2){ return f2(unary(f1())); };
-      return higher1st(nullary) + higher2nd(nullary)(unary);
-  namespace test_variadic_templates
-    template <int...>
-    struct sum;
-    template <int N0, int... N1toN>
-    struct sum<N0, N1toN...>
-      static constexpr auto value = N0 + sum<N1toN...>::value;
-    template <>
-    struct sum<>
-      static constexpr auto value = 0;
-    static_assert(sum<>::value == 0, "");
-    static_assert(sum<1>::value == 1, "");
-    static_assert(sum<23>::value == 23, "");
-    static_assert(sum<1, 2>::value == 3, "");
-    static_assert(sum<5, 5, 11>::value == 21, "");
-    static_assert(sum<2, 3, 5, 7, 11, 13>::value == 41, "");
-  // http://stackoverflow.com/questions/13728184/template-aliases-and-sfinae
-  // Clang 3.1 fails with headers of libstd++ 4.8.3 when using std::function
-  // because of this.
-  namespace test_template_alias_sfinae
-    struct foo {};
-    template<typename T>
-    using member = typename T::member_type;
-    void func(...) {}
-    void func(member<T>*) {}
-    void test();
-    void test() { func<foo>(0); }
-}  // namespace cxx11
-#endif  // __cplusplus >= 201103L
-dnl  Tests for new features in C++14
-m4_define([_AX_CXX_COMPILE_STDCXX_testbody_new_in_14], [[
-// If the compiler admits that it is not ready for C++14, why torture it?
-#elif __cplusplus < 201402L
-#error "This is not a C++14 compiler"
-#else
-namespace cxx14
-  namespace test_polymorphic_lambdas
-    int
-    test()
-      const auto lambda = [](auto&&... args){
-        const auto istiny = [](auto x){
-          return (sizeof(x) == 1UL) ? 1 : 0;
-        const int aretiny[] = { istiny(args)... };
-        return aretiny[0];
-      return lambda(1, 1L, 1.0f, '1');
-  namespace test_binary_literals
-    constexpr auto ivii = 0b0000000000101010;
-    static_assert(ivii == 42, "wrong value");
-  namespace test_generalized_constexpr
-    constexpr unsigned long
-      auto length = 0UL;
-      for (auto p = s; *p; ++p)
-        ++length;
-      return length;
-    static_assert(strlen_c("x") == 1UL, "");
-    static_assert(strlen_c("test") == 4UL, "");
-    static_assert(strlen_c("another\0test") == 7UL, "");
-  namespace test_lambda_init_capture
-    int
-    test()
-      auto x = 0;
-      const auto lambda1 = [a = x](int b){ return a + b; };
-      const auto lambda2 = [a = lambda1(x)](){ return a; };
-      return lambda2();
-  namespace test_digit_separators
-    constexpr auto ten_million = 100'000'000;
-    static_assert(ten_million == 100000000, "");
-  namespace test_return_type_deduction
-    auto f(int& x) { return x; }
-    decltype(auto) g(int& x) { return x; }
-    struct is_same
-      static constexpr auto value = false;
-      static constexpr auto value = true;
-    int
-    test()
-      auto x = 0;
-      static_assert(is_same<int, decltype(f(x))>::value, "");
-      static_assert(is_same<int&, decltype(g(x))>::value, "");
-      return x;
-}  // namespace cxx14
-#endif  // __cplusplus >= 201402L
-dnl  Tests for new features in C++17
-m4_define([_AX_CXX_COMPILE_STDCXX_testbody_new_in_17], [[
-// If the compiler admits that it is not ready for C++17, why torture it?
-#elif __cplusplus < 201703L
-#error "This is not a C++17 compiler"
-#else
-#include <initializer_list>
-#include <utility>
-#include <type_traits>
-namespace cxx17
-  namespace test_constexpr_lambdas
-    constexpr int foo = [](){return 42;}();
-  namespace test::nested_namespace::definitions
-  namespace test_fold_expression
-    template<typename... Args>
-    int multiply(Args... args)
-      return (args * ... * 1);
-    bool all(Args... args)
-      return (args && ...);
-  namespace test_extended_static_assert
-    static_assert (true);
-  namespace test_auto_brace_init_list
-    auto foo = {5};
-    auto bar {5};
-    static_assert(std::is_same<std::initializer_list<int>, decltype(foo)>::value);
-    static_assert(std::is_same<int, decltype(bar)>::value);
-  namespace test_typename_in_template_template_parameter
-    template<template<typename> typename X> struct D;
-  namespace test_fallthrough_nodiscard_maybe_unused_attributes
-    int f1()
-      return 42;
-    [[nodiscard]] int f2()
-      [[maybe_unused]] auto unused = f1();
-      switch (f1())
-      case 17:
-        f1();
-        [[fallthrough]];
-      case 42:
-        f1();
-      return f1();
-  namespace test_extended_aggregate_initialization
-    struct base1
-      int b1, b2 = 42;
-    struct base2
-      base2() {
-        b3 = 42;
-      int b3;
-    struct derived : base1, base2
-        int d;
-    derived d1 {{1, 2}, {}, 4};  // full initialization
-    derived d2 {{}, {}, 4};      // value-initialized bases
-  namespace test_general_range_based_for_loop
-    struct iter
-      int i;
-      int& operator* ()
-        return i;
-      const int& operator* () const
-        return i;
-      iter& operator++()
-        ++i;
-        return *this;
-    struct sentinel
-      int i;
-    bool operator== (const iter& i, const sentinel& s)
-      return i.i == s.i;
-    bool operator!= (const iter& i, const sentinel& s)
-      return !(i == s);
-    struct range
-      iter begin() const
-        return {0};
-      sentinel end() const
-        return {5};
-    void f()
-      range r {};
-      for (auto i : r)
-        [[maybe_unused]] auto v = i;
-  namespace test_lambda_capture_asterisk_this_by_value
-    struct t
-      int i;
-      int foo()
-        return [*this]()
-          return i;
-  namespace test_enum_class_construction
-    enum class byte : unsigned char
-    byte foo {42};
-  namespace test_constexpr_if
-    template <bool cond>
-    int f ()
-      if constexpr(cond)
-        return 13;
-      else
-        return 42;
-  namespace test_selection_statement_with_initializer
-    int f()
-      return 13;
-    int f2()
-      if (auto i = f(); i > 0)
-        return 3;
-      switch (auto i = f(); i + 4)
-      case 17:
-        return 2;
-      default:
-        return 1;
-  namespace test_template_argument_deduction_for_class_templates
-    template <typename T1, typename T2>
-    struct pair
-      pair (T1 p1, T2 p2)
-        : m1 {p1},
-          m2 {p2}
-      T1 m1;
-      T2 m2;
-    void f()
-      [[maybe_unused]] auto p = pair{13, 42u};
-  namespace test_non_type_auto_template_parameters
-    template <auto n>
-    struct B
-    B<5> b1;
-    B<'a'> b2;
-  namespace test_structured_bindings
-    int arr[2] = { 1, 2 };
-    std::pair<int, int> pr = { 1, 2 };
-    auto f1() -> int(&)[2]
-      return arr;
-    auto f2() -> std::pair<int, int>&
-      return pr;
-    struct S
-      int x1 : 2;
-      volatile double y1;
-    S f3()
-      return {};
-    auto [ x1, y1 ] = f1();
-    auto& [ xr1, yr1 ] = f1();
-    auto [ x2, y2 ] = f2();
-    auto& [ xr2, yr2 ] = f2();
-    const auto [ x3, y3 ] = f3();
-  namespace test_exception_spec_type_system
-    struct Good {};
-    struct Bad {};
-    void g1() noexcept;
-    void g2();
-    Bad
-    f(T*, T*);
-    template<typename T1, typename T2>
-    Good
-    f(T1*, T2*);
-    static_assert (std::is_same_v<Good, decltype(f(g1, g2))>);
-  namespace test_inline_variables
-    template<class T> void f(T)
-    template<class T> inline T g(T)
-      return T{};
-    template<> inline void f<>(int)
-    template<> int g<>(int)
-      return 5;
-}  // namespace cxx17
-#endif  // __cplusplus < 201703L
diff --git a/macros/ax_cxx_compile_stdcxx_11.m4 b/macros/ax_cxx_compile_stdcxx_11.m4
deleted file mode 100755
index 0aadeaf..0000000
--- a/macros/ax_cxx_compile_stdcxx_11.m4
+++ /dev/null
@@ -1,39 +0,0 @@
-#  http://www.gnu.org/software/autoconf-archive/ax_cxx_compile_stdcxx_11.html
-# SYNOPSIS
-#   AX_CXX_COMPILE_STDCXX_11([ext|noext], [mandatory|optional])
-# DESCRIPTION
-#   Check for baseline language coverage in the compiler for the C++11
-#   standard; if necessary, add switches to CXX and CXXCPP to enable
-#   support.
-#   This macro is a convenience alias for calling the AX_CXX_COMPILE_STDCXX
-#   macro with the version set to C++11.  The two optional arguments are
-#   forwarded literally as the second and third argument respectively.
-#   Please see the documentation for the AX_CXX_COMPILE_STDCXX macro for
-#   more information.  If you want to use this macro, you also need to
-#   download the ax_cxx_compile_stdcxx.m4 file.
-# LICENSE
-#   warranty.
-#serial 17
-AX_REQUIRE_DEFINED([AX_CXX_COMPILE_STDCXX])
-AC_DEFUN([AX_CXX_COMPILE_STDCXX_11], [AX_CXX_COMPILE_STDCXX([11], [$1], [$2])])
diff --git a/macros/boost.m4 b/macros/boost.m4
deleted file mode 100644
index 52ba576..0000000
--- a/macros/boost.m4
+++ /dev/null
@@ -1,490 +0,0 @@
-dnl @synopsis AX_BOOST([MINIMUM-VERSION], [ACTION-IF-FOUND], [ACTION-IF-NOT-FOUND])
-dnl
-dnl Test for the Boost C++ libraries of a particular version (or newer)
-dnl
-dnl If no path to the installed boost library is given the macro
-dnl searchs under /usr, /usr/local, and /opt, and evaluates the
-dnl $BOOST_ROOT environment variable.
-dnl
-dnl http://autoconf-archive.cryp.to/ax_boost.m4
-dnl
-dnl This macro calls:
-dnl
-dnl   AC_SUBST(BOOST_CPPFLAGS) / AC_SUBST(BOOST_LDFLAGS)
-dnl   AC_SUBST(BOOST_FILESYSTEM_LIB)
-dnl   AC_SUBST(BOOST_PROGRAM_OPTIONS_LIB)
-dnl   AC_SUBST(BOOST_THREAD_LIB)
-dnl   AC_SUBST(BOOST_IOSTREAMS_LIB)
-dnl   AC_SUBST(BOOST_SERIALIZATION_LIB)
-dnl   AC_SUBST(BOOST_WSERIALIZATION_LIB)
-dnl   AC_SUBST(BOOST_SIGNALS_LIB)
-dnl   AC_SUBST(BOOST_DATE_TIME_LIB)
-dnl   AC_SUBST(BOOST_REGEX_LIB)
-dnl   AC_SUBST(BOOST_UNIT_TEST_FRAMEWORK_LIB)
-dnl
-dnl And sets:
-dnl
-dnl   HAVE_BOOST
-dnl   HAVE_BOOST_FILESYSTEM
-dnl   HAVE_BOOST_PROGRAM_OPTIONS
-dnl   HAVE_BOOST_THREAD
-dnl   HAVE_BOOST_IOSTREAMS
-dnl   HAVE_BOOST_SERIALIZATION
-dnl   HAVE_BOOST_SIGNALS
-dnl   HAVE_BOOST_DATE_TIME
-dnl   HAVE_BOOST_REGEX
-dnl   HAVE_BOOST_UNIT_TEST_FRAMEWORK
-dnl
-dnl @category InstalledPackages
-dnl @author Thomas Porschberg <thomas at randspringer.de>
-dnl @version 2006-01-02
-dnl @license AllPermissive
-AC_DEFUN([AX_BOOST],
-    AC_ARG_WITH([boost],
-                AC_HELP_STRING([--with-boost=DIR],
-                [use boost (default is NO) , specify the root directory for boost library (optional)]),
-                if test "$withval" = "no"; then
-		            want_boost="no"
-                elif test "$withval" = "yes"; then
-                    want_boost="yes"
-                    ac_boost_path=""
-                else
-			        want_boost="yes"
-            		ac_boost_path="$withval"
-		        fi
-                [want_boost="no"])
-    #AC_CANONICAL_BUILD
-	if test "x$want_boost" = "xyes"; then
-		boost_lib_version_req=ifelse([$1], ,1.20.0,$1)
-		boost_lib_version_req_shorten=`expr $boost_lib_version_req : '\([[0-9]]*\.[[0-9]]*\)'`
-		boost_lib_version_req_major=`expr $boost_lib_version_req : '\([[0-9]]*\)'`
-		boost_lib_version_req_minor=`expr $boost_lib_version_req : '[[0-9]]*\.\([[0-9]]*\)'`
-		boost_lib_version_req_sub_minor=`expr $boost_lib_version_req : '[[0-9]]*\.[[0-9]]*\.\([[0-9]]*\)'`
-		if test "x$boost_lib_version_req_sub_minor" = "x" ; then
-			boost_lib_version_req_sub_minor="0"
-    	fi
-		WANT_BOOST_VERSION=`expr $boost_lib_version_req_major \* 100000 \+  $boost_lib_version_req_minor \* 100 \+ $boost_lib_version_req_sub_minor`
-		AC_MSG_CHECKING(for boostlib >= $boost_lib_version_req)
-		succeeded=no
-		dnl first we check the system location for boost libraries
-		dnl this location ist chosen if boost libraries are installed with the --layout=system option
-		dnl or if you install boost with RPM
-		if test "$ac_boost_path" != ""; then
-			BOOST_LDFLAGS="-L$ac_boost_path/lib"
-			BOOST_CPPFLAGS="-I$ac_boost_path/include"
-		else
-			for ac_boost_path_tmp in /usr /usr/local /opt ; do
-				if test -d "$ac_boost_path_tmp/include/boost" && test -r "$ac_boost_path_tmp/include/boost"; then
-					BOOST_LDFLAGS="-L$ac_boost_path_tmp/lib"
-					BOOST_CPPFLAGS="-I$ac_boost_path_tmp/include"
-					break;
-				fi
-			done
-		fi
-		CPPFLAGS_SAVED="$CPPFLAGS"
-		CPPFLAGS="$CPPFLAGS $BOOST_CPPFLAGS"
-		export CPPFLAGS
-		LDFLAGS_SAVED="$LDFLAGS"
-		LDFLAGS="$LDFLAGS $BOOST_LDFLAGS"
-		export LDFLAGS
-     	AC_TRY_COMPILE(
-@%:@include <boost/version.hpp>
-#if BOOST_VERSION >= $WANT_BOOST_VERSION
-// Everything is okay
-#else
-#  error Boost version is too old
-#endif
-         AC_MSG_RESULT(yes)
-		 succeeded=yes
-		 found_system=yes
-         ifelse([$2], , :, [$2])
-		dnl if we found no boost with system layout we search for boost libraries
-		dnl built and installed without the --layout=system option or for a staged(not installed) version
-		if test "x$succeeded" != "xyes"; then
-			_version=0
-				if test -d "$ac_boost_path" && test -r "$ac_boost_path"; then
-					for i in `ls -d $ac_boost_path/include/boost-* 2>/dev/null`; do
-						_version_tmp=`echo $i | sed "s#$ac_boost_path##" | sed 's/\/include\/boost-//' | sed 's/_/./'`
-						V_CHECK=`expr $_version_tmp \> $_version`
-						if test "$V_CHECK" = "1" ; then
-							_version=$_version_tmp
-						fi
-						VERSION_UNDERSCORE=`echo $_version | sed 's/\./_/'`
-						BOOST_CPPFLAGS="-I$ac_boost_path/include/boost-$VERSION_UNDERSCORE"
-					done
-				fi
-			else
-				for ac_boost_path in /usr /usr/local /opt ; do
-								best_path=$ac_boost_path
-							fi
-						done
-					fi
-				done
-				BOOST_CPPFLAGS="-I$best_path/include/boost-$VERSION_UNDERSCORE"
-				BOOST_LDFLAGS="-L$best_path/lib"
-	    		if test "x$BOOST_ROOT" != "x"; then
-					if test -d "$BOOST_ROOT" && test -r "$BOOST_ROOT"; then
-						version_dir=`expr //$BOOST_ROOT : '.*/\(.*\)'`
-						stage_version=`echo $version_dir | sed 's/boost_//' | sed 's/_/./g'`
-						stage_version_shorten=`expr $stage_version : '\([[0-9]]*\.[[0-9]]*\)'`
-						V_CHECK=`expr $stage_version_shorten \>\= $_version`
-							AC_MSG_NOTICE(We will use a staged boost library from $BOOST_ROOT)
-							BOOST_CPPFLAGS="-I$BOOST_ROOT"
-							BOOST_LDFLAGS="-L$BOOST_ROOT/stage/lib"
-						fi
-					fi
-	    		fi
-			fi
-			export CPPFLAGS
-			export LDFLAGS
-     		AC_TRY_COMPILE(
-#else
-#endif
-         AC_MSG_RESULT(yes ($_version))
-		 succeeded=yes
-         AC_MSG_RESULT(no ($_version))
-         ifelse([$3], , :, [$3])
-		fi
-		if test "$succeeded" != "yes" ; then
-			if test "$_version" = "0" ; then
-				AC_MSG_ERROR([[We could not detect the boost libraries (version $boost_lib_version_req_shorten or higher). If you have a staged boost library (still not installed) please specify \$BOOST_ROOT in your environment and do not give a PATH to --with-boost option.  If you are sure you have boost installed, then check your version number looking in <boost/version.hpp>.]])
-			else
-				AC_MSG_ERROR('Your boost libraries seems to old (version $_version).  We need at least $boost_lib_version_shorten')
-			fi
-		else
-			AC_SUBST(BOOST_CPPFLAGS)
-			AC_SUBST(BOOST_LDFLAGS)
-			AC_DEFINE(HAVE_BOOST,,[define if the Boost library is available])
-			AC_CACHE_CHECK([whether the Boost::Filesystem library is available],
-						   ax_cv_boost_filesystem,
-						[AC_LANG_SAVE
-			 AC_LANG_CPLUSPLUS
-			 AC_COMPILE_IFELSE(AC_LANG_PROGRAM([[@%:@include <boost/filesystem/path.hpp>]],
-                                   [[using namespace boost::filesystem;
-                                   path my_path( "foo/bar/data.txt" );
-                                   return 0;]]),
-            				       ax_cv_boost_filesystem=yes, ax_cv_boost_filesystem=no)
-		 		        			AC_LANG_RESTORE
-			if test "$ax_cv_boost_filesystem" = "yes"; then
-				AC_DEFINE(HAVE_BOOST_FILESYSTEM,,[define if the Boost::FILESYSTEM library is available])
-				BN=boost_filesystem
-				for ax_lib in $BN $BN-$CC $BN-$CC-mt $BN-$CC-mt-s $BN-$CC-s \
-                              lib$BN lib$BN-$CC lib$BN-$CC-mt lib$BN-$CC-mt-s lib$BN-$CC-s \
-                              $BN-mgw $BN-mgw $BN-mgw-mt $BN-mgw-mt-s $BN-mgw-s ; do
-				    AC_CHECK_LIB($ax_lib, main,
-                                 [BOOST_FILESYSTEM_LIB="-l$ax_lib" AC_SUBST(BOOST_FILESYSTEM_LIB) link_filesystem="yes" break],
-                                 [link_filesystem="no"])
-  				done
-				if test "x$link_filesystem" = "xno"; then
-					AC_MSG_NOTICE(Could not link against $ax_lib !)
-				fi
-			fi
-			AC_CACHE_CHECK([whether the Boost::Program_Options library is available],
-						   ax_cv_boost_program_options,
-						   [AC_LANG_SAVE
-                           AC_LANG_CPLUSPLUS
-			               AC_COMPILE_IFELSE(AC_LANG_PROGRAM([[@%:@include <boost/program_options.hpp>]],
-                                   [[boost::program_options::options_description generic("Generic options");
-                                   return 0;]]),
-                           ax_cv_boost_program_options=yes, ax_cv_boost_program_options=no)
-			               AC_LANG_RESTORE
-			if test "$ax_cv_boost_program_options" = yes; then
-				AC_DEFINE(HAVE_BOOST_PROGRAM_OPTIONS,,[define if the Boost::PROGRAM_OPTIONS library is available])
-				BN=boost_program_options
-                                 [BOOST_PROGRAM_OPTIONS_LIB="-l$ax_lib" AC_SUBST(BOOST_PROGRAM_OPTIONS_LIB) link_program_options="yes" break],
-                                 [link_program_options="no"])
-  				done
-				if test "x$link_program_options="no"" = "xno"; then
-				fi
-			fi
-			AC_CACHE_CHECK(whether the Boost::Thread library is available,
-						   ax_cv_boost_thread,
-						[AC_LANG_SAVE
-			 AC_LANG_CPLUSPLUS
-			 CXXFLAGS_SAVE=$CXXFLAGS
-			 if test "x$build_os" = "xsolaris" ; then
-  				 CXXFLAGS="-pthreads $CXXFLAGS"
-			 elif test "x$build_os" = "xming32" ; then
-				 CXXFLAGS="-mthreads $CXXFLAGS"
-			 else
-				CXXFLAGS="-pthread $CXXFLAGS"
-			 fi
-			 AC_COMPILE_IFELSE(AC_LANG_PROGRAM([[@%:@include <boost/thread/thread.hpp>]],
-                                   [[boost::thread_group thrds;
-                                   return 0;]]),
-                   ax_cv_boost_thread=yes, ax_cv_boost_thread=no)
-			 CXXFLAGS=$CXXFLAGS_SAVE
-			 AC_LANG_RESTORE
-			if test "x$ax_cv_boost_thread" = "xyes"; then
- 				  BOOST_CPPFLAGS="-pthreads $BOOST_CPPFLAGS"
- 				  BOOST_CPPFLAGS="-mthreads $BOOST_CPPFLAGS"
-			   else
-				  BOOST_CPPFLAGS="-pthread $BOOST_CPPFLAGS"
-			   fi
-				AC_DEFINE(HAVE_BOOST_THREAD,,[define if the Boost::THREAD library is available])
-				BN=boost_thread
-				    AC_CHECK_LIB($ax_lib, main, [BOOST_THREAD_LIB="-l$ax_lib" AC_SUBST(BOOST_THREAD_LIB) link_thread="yes" break],
-                                 [link_thread="no"])
-  				done
-				if test "x$link_thread" = "xno"; then
-				fi
-			fi
-			AC_CACHE_CHECK(whether the Boost::IOStreams library is available,
-						   ax_cv_boost_iostreams,
-						[AC_LANG_SAVE
-			 AC_LANG_CPLUSPLUS
-			 AC_COMPILE_IFELSE(AC_LANG_PROGRAM([[@%:@include <boost/iostreams/filtering_stream.hpp>
-												 @%:@include <boost/range/iterator_range.hpp>
-                                   [[std::string  input = "Hello World!";
-									 namespace io = boost::iostreams;
-									 io::filtering_istream  in(boost::make_iterator_range(input));
-									 return 0;
-                   ax_cv_boost_iostreams=yes, ax_cv_boost_iostreams=no)
-			 AC_LANG_RESTORE
-			if test "x$ax_cv_boost_iostreams" = "xyes"; then
-				AC_DEFINE(HAVE_BOOST_IOSTREAMS,,[define if the Boost::IOStreams library is available])
-				BN=boost_iostreams
-				    AC_CHECK_LIB($ax_lib, main, [BOOST_IOSTREAMS_LIB="-l$ax_lib" AC_SUBST(BOOST_IOSTREAMS_LIB) link_thread="yes" break],
-  				done
-				fi
-			fi
-			AC_CACHE_CHECK(whether the Boost::Serialization library is available,
-						   ax_cv_boost_serialization,
-						[AC_LANG_SAVE
-			 AC_LANG_CPLUSPLUS
-			 AC_COMPILE_IFELSE(AC_LANG_PROGRAM([[@%:@include <fstream>
-												 @%:@include <boost/archive/text_oarchive.hpp>
-                                                 @%:@include <boost/archive/text_iarchive.hpp>
-                                   [[std::ofstream ofs("filename");
-									boost::archive::text_oarchive oa(ofs);
-									 return 0;
-                   ax_cv_boost_serialization=yes, ax_cv_boost_serialization=no)
-			 AC_LANG_RESTORE
-			if test "x$ax_cv_boost_serialization" = "xyes"; then
-				AC_DEFINE(HAVE_BOOST_SERIALIZATION,,[define if the Boost::Serialization library is available])
-				BN=boost_serialization
-                                 [BOOST_SERIALIZATION_LIB="-l$ax_lib" AC_SUBST(BOOST_SERIALIZATION_LIB) link_thread="yes" break],
-  				done
-				BN=boost_wserialization
-                                 [BOOST_WSERIALIZATION_LIB="-l$ax_lib" AC_SUBST(BOOST_WSERIALIZATION_LIB) link_thread="yes" break],
-  				done
-				fi
-			fi
-			AC_CACHE_CHECK(whether the Boost::Signals library is available,
-						   ax_cv_boost_signals,
-						[AC_LANG_SAVE
-			 AC_LANG_CPLUSPLUS
-			 AC_COMPILE_IFELSE(AC_LANG_PROGRAM([[@%:@include <boost/signal.hpp>
-                                   [[boost::signal<void ()> sig;
-                                     return 0;
-                   ax_cv_boost_signals=yes, ax_cv_boost_signals=no)
-			 AC_LANG_RESTORE
-			if test "x$ax_cv_boost_signals" = "xyes"; then
-				AC_DEFINE(HAVE_BOOST_SIGNALS,,[define if the Boost::Signals library is available])
-				BN=boost_signals
-				    AC_CHECK_LIB($ax_lib, main, [BOOST_SIGNALS_LIB="-l$ax_lib" AC_SUBST(BOOST_SIGNALS_LIB) link_thread="yes" break],
-  				done
-				fi
-			fi
-			AC_CACHE_CHECK(whether the Boost::Date_Time library is available,
-						   ax_cv_boost_date_time,
-						[AC_LANG_SAVE
-			 AC_LANG_CPLUSPLUS
-			 AC_COMPILE_IFELSE(AC_LANG_PROGRAM([[@%:@include <boost/date_time/gregorian/gregorian_types.hpp>
-                                   [[using namespace boost::gregorian; date d(2002,Jan,10);
-                                     return 0;
-                   ax_cv_boost_date_time=yes, ax_cv_boost_date_time=no)
-			 AC_LANG_RESTORE
-			if test "x$ax_cv_boost_date_time" = "xyes"; then
-				AC_DEFINE(HAVE_BOOST_DATE_TIME,,[define if the Boost::Date_Time library is available])
-				BN=boost_date_time
-				    AC_CHECK_LIB($ax_lib, main, [BOOST_DATE_TIME_LIB="-l$ax_lib" AC_SUBST(BOOST_DATE_TIME_LIB) link_thread="yes" break],
-  				done
-				if test "x$link_thread"="no" = "xno"; then
-				fi
-			fi
-			AC_CACHE_CHECK(whether the Boost::Regex library is available,
-						   ax_cv_boost_regex,
-						[AC_LANG_SAVE
-			 AC_LANG_CPLUSPLUS
-			 AC_COMPILE_IFELSE(AC_LANG_PROGRAM([[@%:@include <boost/regex.hpp>
-                                   [[boost::regex r(); return 0;]]),
-                   ax_cv_boost_regex=yes, ax_cv_boost_regex=no)
-			 AC_LANG_RESTORE
-			if test "x$ax_cv_boost_regex" = "xyes"; then
-				AC_DEFINE(HAVE_BOOST_REGEX,,[define if the Boost::Regex library is available])
-				BN=boost_regex
-				    AC_CHECK_LIB($ax_lib, main, [BOOST_REGEX_LIB="-l$ax_lib" AC_SUBST(BOOST_REGEX_LIB) link_thread="yes" break],
-  				done
-				fi
-			fi
-			AC_CACHE_CHECK(whether the Boost::UnitTestFramework library is available,
-						   ax_cv_boost_unit_test_framework,
-						[AC_LANG_SAVE
-			 AC_LANG_CPLUSPLUS
-			 AC_COMPILE_IFELSE(AC_LANG_PROGRAM([[@%:@include <boost/test/unit_test.hpp>]],
-                                    [[using boost::unit_test::test_suite;
-					                 test_suite* test= BOOST_TEST_SUITE( "Unit test example 1" ); return 0;]]),
-                   ax_cv_boost_unit_test_framework=yes, ax_cv_boost_unit_test_framework=no)
-			 AC_LANG_RESTORE
-			if test "x$ax_cv_boost_unit_test_framework" = "xyes"; then
-    		AC_DEFINE(HAVE_BOOST_UNIT_TEST_FRAMEWORK,,[define if the Boost::Unit_test_framework library is available])
-			BN=boost_unit_test_framework
-    		saved_ldflags="${LDFLAGS}"
-                LDFLAGS="${LDFLAGS} -l$ax_lib"
-    			AC_CACHE_CHECK(the name of the Boost::UnitTestFramework library,
-						[AC_LANG_SAVE
-			 AC_LANG_CPLUSPLUS
-               AC_LINK_IFELSE([AC_LANG_PROGRAM([[@%:@include <boost/test/unit_test.hpp>]],
-                               test_suite* test= BOOST_TEST_SUITE( "Unit test example 1" ); return 0;]])],
-                               [link_thread="yes"],[link_thread="no"])
-			 AC_LANG_RESTORE
-                LDFLAGS="${saved_ldflags}"
-			    if test "x$link_thread" = "xyes"; then
-                    BOOST_UNIT_TEST_FRAMEWORK_LIB="-l$ax_lib"
-                    AC_SUBST(BOOST_UNIT_TEST_FRAMEWORK_LIB)
-					break
-				fi
-              done
-				fi
-			fi
-		fi
-        CPPFLAGS="$CPPFLAGS_SAVED"
-        LDFLAGS="$LDFLAGS_SAVED"
-	fi
diff --git a/macros/geos.m4 b/macros/geos.m4
index e4cbbfc..0000000
--- a/macros/geos.m4
+++ /dev/null
@@ -1,93 +0,0 @@
-dnl
-dnl GEOS_INIT (MINIMUM_VERSION)
-dnl
-dnl Test for GEOS: define HAVE_GEOS, GEOS_LIBS, GEOS_C_LIBS, GEOS_CC_LIBS, GEOS_CFLAGS, GEOS_VERSION
-dnl
-dnl Call as GEOS_INIT or GEOS_INIT(minimum version) in configure.in. Test
-dnl HAVE_GEOS (yes|no) afterwards. If yes, all other vars above can be
-dnl used in program.
-dnl
-dnl UPDATE 2006/07/06
-dnl Now, --with-geos takes values: yes or no, or full path to the geos-config
-dnl utility. Note that the utility can have different name,
-dnl e.g. geos-config-cvs.
-dnl Example: --with-geos=/home/foo/usr/bin/geos-config-cvs
-dnl
-AC_DEFUN([GEOS_INIT],[
-	AC_SUBST(GEOS_LIBS)
-	AC_SUBST(GEOS_CFLAGS)
-	AC_SUBST(GEOS_C_LIBS)
-	AC_SUBST(GEOS_CC_LIBS)
-	AC_SUBST(GEOS_C_CFLAGS)
-	AC_SUBST(HAVE_GEOS)
-	AC_SUBST(GEOS_VERSION)
-    if test x"$with_geos" = x"no" ; then
-        AC_MSG_RESULT([GEOS support disabled])
-        GEOS_CONFIG="no"
-        HAVE_GEOS="no"
-    elif test x"$with_geos" = x"yes" -o x"$with_geos" = x"" ; then
-        AC_PATH_PROG([GEOS_CONFIG], [geos-config], [no])
-    else
-        ac_geos_config=`basename $with_geos`
-        ac_geos_config_dir=`dirname $with_geos`
-        AC_CHECK_PROG(
-            GEOS_CONFIG,
-            $ac_geos_config,
-            $with_geos,
-            [no],
-            [$ac_geos_config_dir],
-    fi
-	min_geos_version=ifelse([$1], ,0.0.1,$1)
-    if test "$GEOS_CONFIG" = "no"; then
-      no_geos_config="yes"
-    else
-       AC_MSG_CHECKING(for GEOS version >= $min_geos_version)
-       geos_major_version=`$GEOS_CONFIG --version | \
-          sed 's/\([[0-9]]*\)\.\([[0-9]]*\)\.\([[0-9]]*\).*/\1/'`
-       geos_minor_version=`$GEOS_CONFIG --version | \
-          sed 's/\([[0-9]]*\)\.\([[0-9]]*\)\.\([[0-9]]*\).*/\2/'`
-       geos_micro_version=`$GEOS_CONFIG --version | \
-          sed 's/\([[0-9]]*\)\.\([[0-9]]*\)\.\([[0-9]]*\).*/\3/'`
-    req_major=`echo $min_geos_version | \
-    req_minor=`echo $min_geos_version | \
-    req_micro=`echo $min_geos_version | \
-    version_ok="no"
-    ac_req_version=`expr $req_major \* 100000 \+  $req_minor \* 100 \+ $req_micro`
-    ac_geos_version=`expr $geos_major_version \* 100000 \+  $geos_minor_version \* 100 \+ $geos_micro_version`
-    if test $ac_req_version -le $ac_geos_version; then
-        version_ok="yes"
-    fi
-      if test $version_ok = "no"; then
-         HAVE_GEOS="no"
-      else
-        if $GEOS_CONFIG --libs >/dev/null 2>&1; then
-          HAVE_GEOS="yes"
-          GEOS_LIBS="`$GEOS_CONFIG --libs`"
-          GEOS_C_LIBS="`$GEOS_CONFIG --ldflags` -lgeos_c"
-          GEOS_CC_LIBS="`$GEOS_CONFIG --ldflags` -lgeos"
-          GEOS_CFLAGS="`$GEOS_CONFIG --cflags`"
-          GEOS_VERSION="`$GEOS_CONFIG --version`"
-        else
-          AC_MSG_RESULT(no)
-          HAVE_GEOS="no"
-        fi
-    fi
-fi
diff --git a/src/Makefile.am b/src/Makefile.am
index f19d1b3..0000000
--- a/src/Makefile.am
+++ /dev/null
@@ -1,56 +0,0 @@
-# This file is part of project GEOS (http://trac.osgeo.org/geos/)
-SUBDIRS = \
-	algorithm \
-	edgegraph \
-	geom \
-	index \
-	io \
-	linearref \
-	math \
-	noding \
-	operation \
-	planargraph \
-	geomgraph \
-	precision \
-	simplify \
-	triangulate \
-	shape \
-	util \
-	deps
-EXTRA_DIST = dirlist.mk CMakeLists.txt info.plist.in
-AM_CPPFLAGS = -I$(top_srcdir)/include
-lib_LTLIBRARIES = libgeos.la
-# libgeos uses -release because it is not feasible to know if the ABI
-# has changed between releases; the project chooses not to expend the
-# effort to determine this because GEOS does not promise ABI stability.
-libgeos_la_LDFLAGS = \
-	-release @VERSION_RELEASE@ \
-	-no-undefined
-libgeos_la_SOURCES = \
-	inlines.cpp
-libgeos_la_LIBADD = \
-	algorithm/libalgorithm.la \
-	edgegraph/libedgegraph.la \
-	geom/libgeom.la \
-	geomgraph/libgeomgraph.la \
-	index/libindex.la \
-	io/libio.la \
-	linearref/liblinearref.la \
-	math/libmath.la \
-	noding/libnoding.la \
-	operation/liboperation.la \
-	planargraph/libplanargraph.la \
-	precision/libprecision.la \
-	simplify/libsimplify.la \
-	triangulate/libtriangulate.la \
-	shape/libshape.la \
-	util/libutil.la \
-	deps/libdeps.la
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index a4a8180..0000000
--- a/src/algorithm/Makefile.am
+++ /dev/null
@@ -1,41 +0,0 @@
-SUBDIRS = \
-	locate \
-	distance \
-	construct
-noinst_LTLIBRARIES = libalgorithm.la
-libalgorithm_la_SOURCES = \
-	Angle.cpp \
-	Area.cpp \
-	BoundaryNodeRule.cpp \
-	Centroid.cpp \
-	CGAlgorithmsDD.cpp \
-	ConvexHull.cpp \
-	Distance.cpp \
-	HCoordinate.cpp \
-	InteriorPointArea.cpp \
-	InteriorPointLine.cpp \
-	InteriorPointPoint.cpp \
-	Intersection.cpp \
-	LineIntersector.cpp \
-	Length.cpp \
-	MinimumBoundingCircle.cpp \
-	MinimumDiameter.cpp \
-	NotRepresentableException.cpp \
-	Orientation.cpp \
-	PointLocation.cpp \
-	PointLocator.cpp \
-	RayCrossingCounter.cpp \
-	RayCrossingCounterDD.cpp \
-	RobustDeterminant.cpp
-libalgorithm_la_LIBADD = \
-	locate/liblocation.la \
-	distance/libdistance.la \
-	construct/libconstruct.la
diff --git a/src/algorithm/construct/Makefile.am b/src/algorithm/construct/Makefile.am
index d9e47aa..0000000
--- a/src/algorithm/construct/Makefile.am
+++ /dev/null
@@ -1,14 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libconstruct.la
-libconstruct_la_SOURCES = \
-    LargestEmptyCircle.cpp \
-    MaximumInscribedCircle.cpp
-libconstruct_la_LIBADD =
diff --git a/src/algorithm/distance/Makefile.am b/src/algorithm/distance/Makefile.am
index cc7d5ad..0000000
--- a/src/algorithm/distance/Makefile.am
+++ /dev/null
@@ -1,15 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libdistance.la
-libdistance_la_SOURCES = \
-    DiscreteHausdorffDistance.cpp \
-    DiscreteFrechetDistance.cpp \
-    DistanceToPoint.cpp
-libdistance_la_LIBADD =
diff --git a/src/algorithm/locate/Makefile.am b/src/algorithm/locate/Makefile.am
index 7c5d53e..0000000
--- a/src/algorithm/locate/Makefile.am
+++ /dev/null
@@ -1,15 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = liblocation.la
-liblocation_la_SOURCES = \
-	IndexedPointInAreaLocator.cpp \
-	PointOnGeometryLocator.cpp \
-	SimplePointInAreaLocator.cpp
-liblocation_la_LIBADD =
diff --git a/src/deps/Makefile.am b/src/deps/Makefile.am
index 021990d..0000000
--- a/src/deps/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-SUBDIRS=\
-    ryu
-libdeps_la_SOURCES =
-noinst_LTLIBRARIES = \
-    libdeps.la
-AM_CPPFLAGS = -I$(top_srcdir)/src/deps
-libdeps_la_LIBADD = \
-    ryu/libryu.la
diff --git a/src/deps/ryu/Makefile.am b/src/deps/ryu/Makefile.am
index 3da96d2..0000000
--- a/src/deps/ryu/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libryu.la
-libryu_la_SOURCES = \
-    d2s.c
-noinst_HEADERS = \
-    common.h \
-    d2fixed_full_table.h \
-    d2s_full_table.h \
-    d2s_intrinsics.h \
-    digit_table.h \
-    ryu.h
diff --git a/src/edgegraph/Makefile.am b/src/edgegraph/Makefile.am
index 6c4f7ce..0000000
--- a/src/edgegraph/Makefile.am
+++ /dev/null
@@ -1,12 +0,0 @@
-noinst_LTLIBRARIES = libedgegraph.la
-libedgegraph_la_SOURCES = \
-	EdgeGraph.cpp \
-	EdgeGraphBuilder.cpp \
-	HalfEdge.cpp \
-	MarkHalfEdge.cpp
diff --git a/src/geom/Makefile.am b/src/geom/Makefile.am
index 245fd4e..0000000
--- a/src/geom/Makefile.am
+++ /dev/null
@@ -1,44 +0,0 @@
-SUBDIRS=\
-    util \
-    prep
-    libgeom.la
-libgeom_la_SOURCES = \
-    Coordinate.cpp \
-    CoordinateSequence.cpp \
-    CoordinateArraySequence.cpp \
-    CoordinateArraySequenceFactory.cpp \
-    DefaultCoordinateSequenceFactory.cpp \
-    Dimension.cpp \
-    Envelope.cpp \
-    Geometry.cpp \
-    GeometryCollection.cpp \
-    GeometryComponentFilter.cpp \
-    GeometryFactory.cpp \
-    HeuristicOverlay.cpp \
-    IntersectionMatrix.cpp \
-    LinearRing.cpp \
-    LineSegment.cpp \
-    LineString.cpp \
-    Location.cpp \
-    MultiLineString.cpp \
-    MultiPoint.cpp \
-    MultiPolygon.cpp \
-    Point.cpp \
-    Polygon.cpp \
-    PrecisionModel.cpp \
-    Position.cpp \
-    Quadrant.cpp \
-    Triangle.cpp
-libgeom_la_LIBADD = \
-    util/libgeomutil.la \
-    prep/libgeomprep.la
diff --git a/src/geom/prep/Makefile.am b/src/geom/prep/Makefile.am
index abd2bd9..0000000
--- a/src/geom/prep/Makefile.am
+++ /dev/null
@@ -1,29 +0,0 @@
-noinst_LTLIBRARIES = libgeomprep.la
-## these are full inlined
-# PolygonExtracter.cpp
-# PointExtracter.cpp
-# LinearComponentExtracter.cpp
-libgeomprep_la_SOURCES = \
-    AbstractPreparedPolygonContains.cpp \
-    BasicPreparedGeometry.cpp \
-    PreparedGeometry.cpp \
-    PreparedGeometryFactory.cpp \
-    PreparedLineString.cpp \
-    PreparedLineStringDistance.cpp \
-    PreparedLineStringIntersects.cpp \
-    PreparedLineStringNearestPoints.cpp \
-    PreparedPoint.cpp \
-    PreparedPolygon.cpp \
-    PreparedPolygonContains.cpp \
-    PreparedPolygonContainsProperly.cpp \
-    PreparedPolygonCovers.cpp \
-		PreparedPolygonDistance.cpp \
-    PreparedPolygonIntersects.cpp \
-    PreparedPolygonPredicate.cpp
diff --git a/src/geom/util/Makefile.am b/src/geom/util/Makefile.am
index f05171a..0000000
--- a/src/geom/util/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-noinst_LTLIBRARIES = libgeomutil.la
-libgeomutil_la_SOURCES = \
-    ComponentCoordinateExtracter.cpp \
-    CoordinateOperation.cpp \
-    GeometryEditor.cpp \
-    GeometryTransformer.cpp \
-    ShortCircuitedGeometryVisitor.cpp \
-    SineStarFactory.cpp \
-    GeometryCombiner.cpp \
-    LinearComponentExtracter.cpp \
-    PointExtracter.cpp \
-    PolygonExtracter.cpp \
-    Densifier.cpp
diff --git a/src/geomgraph/Makefile.am b/src/geomgraph/Makefile.am
index b1f3849..0000000
--- a/src/geomgraph/Makefile.am
+++ /dev/null
@@ -1,30 +0,0 @@
-SUBDIRS = index
-noinst_LTLIBRARIES = libgeomgraph.la
-libgeomgraph_la_SOURCES = \
-	Depth.cpp \
-	DirectedEdge.cpp \
-	DirectedEdgeStar.cpp \
-	Edge.cpp \
-	EdgeEnd.cpp \
-	EdgeEndStar.cpp \
-	EdgeIntersectionList.cpp \
-	EdgeNodingValidator.cpp \
-	EdgeList.cpp \
-	EdgeRing.cpp \
-	GeometryGraph.cpp \
-	GraphComponent.cpp \
-	Label.cpp \
-	Node.cpp \
-	NodeFactory.cpp \
-	NodeMap.cpp \
-	PlanarGraph.cpp \
-	TopologyLocation.cpp
-libgeomgraph_la_LIBADD = index/libgeomgraphindex.la
diff --git a/src/geomgraph/index/Makefile.am b/src/geomgraph/index/Makefile.am
index d86e948..0000000
--- a/src/geomgraph/index/Makefile.am
+++ /dev/null
@@ -1,16 +0,0 @@
-noinst_LTLIBRARIES = libgeomgraphindex.la
-libgeomgraphindex_la_SOURCES = \
-    MonotoneChainEdge.cpp \
-    MonotoneChainIndexer.cpp \
-    SegmentIntersector.cpp \
-    SimpleEdgeSetIntersector.cpp \
-    SimpleMCSweepLineIntersector.cpp \
-    SimpleSweepLineIntersector.cpp \
-    SweepLineEvent.cpp \
-    SweepLineSegment.cpp
diff --git a/src/index/Makefile.am b/src/index/Makefile.am
index 0bde872..0000000
--- a/src/index/Makefile.am
+++ /dev/null
@@ -1,24 +0,0 @@
-SUBDIRS = \
-	bintree \
-	kdtree \
-	chain \
-	intervalrtree \
-	quadtree \
-	strtree \
-	sweepline
-noinst_LTLIBRARIES = libindex.la
-libindex_la_SOURCES =
-libindex_la_LIBADD = \
-	bintree/libindexbintree.la \
-	kdtree/libindexkdtree.la \
-	chain/libindexchain.la \
-	intervalrtree/libintervalrtree.la \
-	quadtree/libindexquadtree.la \
-	strtree/libindexstrtree.la \
-	sweepline/libindexsweepline.la
diff --git a/src/index/bintree/Makefile.am b/src/index/bintree/Makefile.am
index 7364e0e..0000000
--- a/src/index/bintree/Makefile.am
+++ /dev/null
@@ -1,16 +0,0 @@
-noinst_LTLIBRARIES = libindexbintree.la
-libindexbintree_la_SOURCES = \
-    Bintree.cpp \
-    Interval.cpp \
-    Node.cpp \
-    Key.cpp \
-    NodeBase.cpp \
-    Root.cpp
-libindexbintree_la_LIBADD =
diff --git a/src/index/chain/Makefile.am b/src/index/chain/Makefile.am
index c865161..0000000
--- a/src/index/chain/Makefile.am
+++ /dev/null
@@ -1,12 +0,0 @@
-noinst_LTLIBRARIES = libindexchain.la
-libindexchain_la_SOURCES = \
-	MonotoneChain.cpp \
-	MonotoneChainBuilder.cpp \
-	MonotoneChainOverlapAction.cpp \
-	MonotoneChainSelectAction.cpp
diff --git a/src/index/intervalrtree/Makefile.am b/src/index/intervalrtree/Makefile.am
index 4437fbd..0000000
--- a/src/index/intervalrtree/Makefile.am
+++ /dev/null
@@ -1,11 +0,0 @@
-noinst_LTLIBRARIES = libintervalrtree.la
-libintervalrtree_la_SOURCES = \
-	IntervalRTreeBranchNode.cpp \
-	IntervalRTreeLeafNode.cpp \
-	SortedPackedIntervalRTree.cpp
diff --git a/src/index/kdtree/Makefile.am b/src/index/kdtree/Makefile.am
index 52a8eff..0000000
--- a/src/index/kdtree/Makefile.am
+++ /dev/null
@@ -1,12 +0,0 @@
-noinst_LTLIBRARIES = libindexkdtree.la
-libindexkdtree_la_SOURCES = \
-    KdTree.cpp \
-    KdNode.cpp
-libindexkdtree_la_LIBADD =
diff --git a/src/index/quadtree/Makefile.am b/src/index/quadtree/Makefile.am
index 98d5123..0000000
--- a/src/index/quadtree/Makefile.am
+++ /dev/null
@@ -1,14 +0,0 @@
-noinst_LTLIBRARIES = libindexquadtree.la
-libindexquadtree_la_SOURCES = \
-    IntervalSize.cpp \
-    Quadtree.cpp \
-    Key.cpp \
-    Node.cpp \
-    NodeBase.cpp \
-    Root.cpp
diff --git a/src/index/strtree/Makefile.am b/src/index/strtree/Makefile.am
index 335b673..0000000
--- a/src/index/strtree/Makefile.am
+++ /dev/null
@@ -1,20 +0,0 @@
-noinst_LTLIBRARIES = libindexstrtree.la
-libindexstrtree_la_SOURCES = \
-    AbstractSTRtree.cpp \
-    BoundablePair.cpp \
-    EnvelopeUtil.cpp \
-    GeometryItemDistance.cpp \
-    Interval.cpp \
-    SIRtree.cpp \
-    STRtree.cpp \
-    SimpleSTRtree.cpp \
-    SimpleSTRnode.cpp \
-    SimpleSTRdistance.cpp
-libindexstrtree_la_LIBADD =
diff --git a/src/index/sweepline/Makefile.am b/src/index/sweepline/Makefile.am
index ce83db0..0000000
--- a/src/index/sweepline/Makefile.am
+++ /dev/null
@@ -1,13 +0,0 @@
-noinst_LTLIBRARIES = libindexsweepline.la
-libindexsweepline_la_SOURCES = \
-    SweepLineIndex.cpp \
-    SweepLineInterval.cpp
-libindexsweepline_la_LIBADD =
diff --git a/src/io/Makefile.am b/src/io/Makefile.am
index 9b81f6f..0000000
--- a/src/io/Makefile.am
+++ /dev/null
@@ -1,22 +0,0 @@
-noinst_LTLIBRARIES = libio.la
-AM_CPPFLAGS = -I$(top_srcdir)/include -I$(top_srcdir)/src/deps
-libio_la_SOURCES = \
-	ParseException.cpp \
-	StringTokenizer.cpp \
-	ByteOrderDataInStream.cpp \
-	ByteOrderValues.cpp \
-	WKTReader.cpp \
-	WKTWriter.cpp \
-	WKBReader.cpp \
-	WKBWriter.cpp \
-	Writer.cpp \
-	Unload.cpp \
-	CLocalizer.cpp
-libio_la_LIBADD =
diff --git a/src/linearref/Makefile.am b/src/linearref/Makefile.am
index a2ea79a..0000000
--- a/src/linearref/Makefile.am
+++ /dev/null
@@ -1,22 +0,0 @@
-noinst_LTLIBRARIES = liblinearref.la
-liblinearref_la_SOURCES = \
-    ExtractLineByLocation.cpp \
-    LengthIndexedLine.cpp \
-    LengthIndexOfPoint.cpp \
-    LengthLocationMap.cpp \
-    LinearIterator.cpp \
-    LinearGeometryBuilder.cpp \
-    LinearLocation.cpp \
-    LocationIndexOfLine.cpp \
-    LocationIndexOfPoint.cpp
-# Deprecated files
-# (http://geos.osgeo.org/pipermail/geos-devel/2006-March/001828.html):
-#NonRobustLineIntersector.cpp
-#RobustLineIntersector.cpp
diff --git a/src/math/Makefile.am b/src/math/Makefile.am
index c30e97e..0000000
--- a/src/math/Makefile.am
+++ /dev/null
@@ -1,13 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libmath.la
-libmath_la_SOURCES = \
-	DD.cpp
-libmath_la_LIBADD =
diff --git a/src/noding/Makefile.am b/src/noding/Makefile.am
index 24ce4ed..0000000
--- a/src/noding/Makefile.am
+++ /dev/null
@@ -1,38 +0,0 @@
-SUBDIRS = \
-	snapround \
-	snap
-noinst_LTLIBRARIES = libnoding.la
-libnoding_la_SOURCES = \
-	BasicSegmentString.cpp \
-	FastNodingValidator.cpp \
-	FastSegmentSetIntersectionFinder.cpp \
-	GeometryNoder.cpp \
-	IntersectionAdder.cpp \
-	IntersectionFinderAdder.cpp \
-	IteratedNoder.cpp \
-	MCIndexNoder.cpp \
-	MCIndexSegmentSetMutualIntersector.cpp \
-	NodedSegmentString.cpp \
-	NodingValidator.cpp \
-	Octant.cpp \
-	OrientedCoordinateArray.cpp \
-	ScaledNoder.cpp \
-	SegmentIntersectionDetector.cpp \
-	SegmentNode.cpp \
-	SegmentNodeList.cpp \
-	SegmentString.cpp \
-	SegmentStringUtil.cpp \
-	SimpleNoder.cpp \
-	NodingIntersectionFinder.cpp \
-	ValidatingNoder.cpp
-libnoding_la_LIBADD = \
-	snapround/libsnapround.la \
-	snap/libsnap.la
diff --git a/src/noding/snap/Makefile.am b/src/noding/snap/Makefile.am
index b3734fb..0000000
--- a/src/noding/snap/Makefile.am
+++ /dev/null
@@ -1,15 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libsnap.la
-libsnap_la_SOURCES = \
-    SnappingIntersectionAdder.cpp \
-    SnappingNoder.cpp \
-    SnappingPointIndex.cpp
-libsnap_la_LIBADD =
diff --git a/src/noding/snapround/Makefile.am b/src/noding/snapround/Makefile.am
index 2672ba4..0000000
--- a/src/noding/snapround/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libsnapround.la
-libsnapround_la_SOURCES = \
-    HotPixel.cpp \
-    HotPixelIndex.cpp \
-    MCIndexPointSnapper.cpp \
-    MCIndexSnapRounder.cpp \
-    SnapRoundingNoder.cpp \
-    SnapRoundingIntersectionAdder.cpp
-libsnapround_la_LIBADD =
diff --git a/src/operation/Makefile.am b/src/operation/Makefile.am
index 2810ba3..0000000
--- a/src/operation/Makefile.am
+++ /dev/null
@@ -1,38 +0,0 @@
-SUBDIRS = \
-    buffer \
-    distance \
-    intersection \
-    linemerge \
-    overlay \
-    overlayng \
-    polygonize \
-    predicate \
-    relate \
-    union \
-    sharedpaths \
-    valid
-noinst_LTLIBRARIES = liboperation.la
-liboperation_la_SOURCES = \
-	GeometryGraphOperation.cpp \
-	IsSimpleOp.cpp
-liboperation_la_LIBADD = \
-    buffer/libopbuffer.la \
-    distance/libopdistance.la \
-    intersection/libopintersection.la \
-    linemerge/liboplinemerge.la \
-    overlay/libopoverlay.la \
-    overlayng/libopoverlayng.la \
-    polygonize/liboppolygonize.la \
-    predicate/liboppredicate.la \
-    relate/liboprelate.la \
-    union/libopunion.la \
-    valid/libopvalid.la \
-    sharedpaths/libopsharedpaths.la
diff --git a/src/operation/buffer/Makefile.am b/src/operation/buffer/Makefile.am
index 42ddbb3..0000000
--- a/src/operation/buffer/Makefile.am
+++ /dev/null
@@ -1,23 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libopbuffer.la
-libopbuffer_la_SOURCES = \
-	BufferBuilder.cpp \
-	BufferInputLineSimplifier.cpp \
-	BufferOp.cpp \
-	BufferParameters.cpp \
-	BufferSubgraph.cpp \
-	OffsetCurveBuilder.cpp \
-	OffsetCurveSetBuilder.cpp \
-	OffsetSegmentGenerator.cpp \
-	RightmostEdgeFinder.cpp \
-	SubgraphDepthLocater.cpp \
-	$(NULL)
-libopbuffer_la_LIBADD =
diff --git a/src/operation/distance/Makefile.am b/src/operation/distance/Makefile.am
index e84bfa4..0000000
--- a/src/operation/distance/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libopdistance.la
-libopdistance_la_SOURCES = \
-    ConnectedElementLocationFilter.cpp \
-    ConnectedElementPointFilter.cpp \
-    DistanceOp.cpp \
-    IndexedFacetDistance.cpp \
-    FacetSequence.cpp \
-    FacetSequenceTreeBuilder.cpp \
-    GeometryLocation.cpp
-libopdistance_la_LIBADD =
diff --git a/src/operation/intersection/Makefile.am b/src/operation/intersection/Makefile.am
index 53863d2..0000000
--- a/src/operation/intersection/Makefile.am
+++ /dev/null
@@ -1,15 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libopintersection.la
-libopintersection_la_SOURCES = \
-  Rectangle.cpp \
-  RectangleIntersection.cpp \
-  RectangleIntersectionBuilder.cpp
-libopintersection_la_LIBADD =
diff --git a/src/operation/linemerge/Makefile.am b/src/operation/linemerge/Makefile.am
index 7765e1a..0000000
--- a/src/operation/linemerge/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = liboplinemerge.la
-liboplinemerge_la_SOURCES = \
-	EdgeString.cpp \
-	LineMergeDirectedEdge.cpp \
-	LineMergeEdge.cpp \
-	LineMergeGraph.cpp \
-	LineMerger.cpp \
-	LineSequencer.cpp
-liboplinemerge_la_LIBADD =
diff --git a/src/operation/overlay/Makefile.am b/src/operation/overlay/Makefile.am
index bbe3223..0000000
--- a/src/operation/overlay/Makefile.am
+++ /dev/null
@@ -1,32 +0,0 @@
-AUTOMAKE_OPTIONS = subdir-objects
-SUBDIRS =
-noinst_LTLIBRARIES = libopoverlay.la
-libopoverlay_la_SOURCES = \
-    EdgeSetNoder.cpp \
-    ElevationMatrixCell.cpp \
-    ElevationMatrix.cpp \
-    LineBuilder.cpp \
-    MaximalEdgeRing.cpp \
-    MinimalEdgeRing.cpp \
-    OverlayNodeFactory.cpp \
-    OverlayOp.cpp \
-    PointBuilder.cpp \
-    PolygonBuilder.cpp \
-    snap/GeometrySnapper.cpp \
-    snap/LineStringSnapper.cpp \
-    snap/SnapOverlayOp.cpp \
-    snap/SnapIfNeededOverlayOp.cpp \
-    validate/FuzzyPointLocator.cpp \
-    validate/OffsetPointGenerator.cpp \
-    validate/OverlayResultValidator.cpp
-libopoverlay_la_LIBADD =
diff --git a/src/operation/overlayng/Makefile.am b/src/operation/overlayng/Makefile.am
index ee52fbc..0000000
--- a/src/operation/overlayng/Makefile.am
+++ /dev/null
@@ -1,40 +0,0 @@
-noinst_LTLIBRARIES = libopoverlayng.la
-libopoverlayng_la_SOURCES = \
-    Edge.cpp \
-    EdgeKey.cpp \
-    EdgeMerger.cpp \
-    EdgeNodingBuilder.cpp \
-    EdgeSourceInfo.cpp \
-    ElevationModel.cpp \
-    IndexedPointOnLineLocator.cpp \
-    InputGeometry.cpp \
-    IntersectionPointBuilder.cpp \
-    LineBuilder.cpp \
-    LineLimiter.cpp \
-    OverlayEdge.cpp \
-    OverlayEdgeRing.cpp \
-    OverlayGraph.cpp \
-    OverlayLabel.cpp \
-    OverlayLabeller.cpp \
-    OverlayMixedPoints.cpp \
-    OverlayPoints.cpp \
-    OverlayNG.cpp \
-    OverlayNGRobust.cpp \
-    OverlayUtil.cpp \
-    PrecisionReducer.cpp \
-    PrecisionUtil.cpp \
-    RingClipper.cpp \
-    RobustClipEnvelopeComputer.cpp \
-    UnaryUnionNG.cpp
-libopoverlayng_la_LIBADD =
diff --git a/src/operation/polygonize/Makefile.am b/src/operation/polygonize/Makefile.am
index dbbfa9f..0000000
--- a/src/operation/polygonize/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = liboppolygonize.la
-liboppolygonize_la_SOURCES = \
-    PolygonizeDirectedEdge.cpp \
-    PolygonizeEdge.cpp \
-    PolygonizeGraph.cpp \
-    Polygonizer.cpp \
-    HoleAssigner.cpp \
-    BuildArea.cpp \
-    EdgeRing.cpp
-liboppolygonize_la_LIBADD =
diff --git a/src/operation/predicate/Makefile.am b/src/operation/predicate/Makefile.am
index 4f1a3b1..0000000
--- a/src/operation/predicate/Makefile.am
+++ /dev/null
@@ -1,16 +0,0 @@
-#prefix=@prefix@
-#top_srcdir=@top_srcdir@
-noinst_LTLIBRARIES = liboppredicate.la
-liboppredicate_la_SOURCES = \
-    RectangleIntersects.cpp \
-    RectangleContains.cpp \
-    SegmentIntersectionTester.cpp
-liboppredicate_la_LIBADD =
diff --git a/src/operation/relate/Makefile.am b/src/operation/relate/Makefile.am
index 639a9b5..0000000
--- a/src/operation/relate/Makefile.am
+++ /dev/null
@@ -1,20 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = liboprelate.la
-liboprelate_la_SOURCES = \
-    EdgeEndBuilder.cpp \
-    EdgeEndBundle.cpp \
-    EdgeEndBundleStar.cpp \
-    RelateComputer.cpp \
-    RelateNode.cpp \
-    RelateNodeFactory.cpp \
-    RelateNodeGraph.cpp \
-    RelateOp.cpp
-liboprelate_la_LIBADD =
diff --git a/src/operation/sharedpaths/Makefile.am b/src/operation/sharedpaths/Makefile.am
index e6f8861..0000000
--- a/src/operation/sharedpaths/Makefile.am
+++ /dev/null
@@ -1,11 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libopsharedpaths.la
-libopsharedpaths_la_SOURCES = \
-    SharedPathsOp.cpp
diff --git a/src/operation/union/Makefile.am b/src/operation/union/Makefile.am
index 76b2caa..0000000
--- a/src/operation/union/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libopunion.la
-libopunion_la_SOURCES = \
-    CascadedPolygonUnion.cpp \
-    CascadedUnion.cpp \
-    OverlapUnion.cpp \
-    CoverageUnion.cpp \
-    PointGeometryUnion.cpp \
-    UnaryUnionOp.cpp
-libopunion_la_LIBADD =
diff --git a/src/operation/valid/Makefile.am b/src/operation/valid/Makefile.am
index e5523fe..0000000
--- a/src/operation/valid/Makefile.am
+++ /dev/null
@@ -1,29 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libopvalid.la
-# NOTES:
-# <incomplete>
-libopvalid_la_SOURCES = \
-    ConnectedInteriorTester.cpp \
-    ConsistentAreaTester.cpp \
-    IsValidOp.cpp \
-    QuadtreeNestedRingTester.cpp \
-    RepeatedPointRemover.cpp \
-    RepeatedPointTester.cpp \
-    SimpleNestedRingTester.cpp \
-    SweeplineNestedRingTester.cpp \
-    TopologyValidationError.cpp \
-    IndexedNestedRingTester.cpp \
-    IndexedNestedRingTester.h \
-    IndexedNestedShellTester.cpp \
-    MakeValid.cpp
-libopvalid_la_LIBADD =
diff --git a/src/planargraph/Makefile.am b/src/planargraph/Makefile.am
index 4a514d0..0000000
--- a/src/planargraph/Makefile.am
+++ /dev/null
@@ -1,23 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libplanargraph.la
-libplanargraph_la_SOURCES = \
-    Edge.cpp \
-    Node.cpp \
-    NodeMap.cpp \
-    PlanarGraph.cpp \
-    Subgraph.cpp \
-    algorithm/ConnectedSubgraphFinder.cpp
-libplanargraph_la_LIBADD =
diff --git a/src/precision/Makefile.am b/src/precision/Makefile.am
index 152936f..0000000
--- a/src/precision/Makefile.am
+++ /dev/null
@@ -1,20 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libprecision.la
-libprecision_la_SOURCES = \
-	CommonBits.cpp \
-	CommonBitsOp.cpp \
-	CommonBitsRemover.cpp \
-	EnhancedPrecisionOp.cpp \
-	GeometryPrecisionReducer.cpp \
-	MinimumClearance.cpp \
-	PrecisionReducerCoordinateOperation.cpp \
-	SimpleGeometryPrecisionReducer.cpp
-libprecision_la_LIBADD =
diff --git a/src/shape/Makefile.am b/src/shape/Makefile.am
index 8bdb8aa..0000000
--- a/src/shape/Makefile.am
+++ /dev/null
@@ -1,12 +0,0 @@
-SUBDIRS = \
-	fractal
-noinst_LTLIBRARIES = libshape.la
-libshape_la_SOURCES =
-libshape_la_LIBADD = \
-	fractal/libshapefractal.la
diff --git a/src/shape/fractal/Makefile.am b/src/shape/fractal/Makefile.am
index 4dfa260..0000000
--- a/src/shape/fractal/Makefile.am
+++ /dev/null
@@ -1,13 +0,0 @@
-noinst_LTLIBRARIES = libshapefractal.la
-libshapefractal_la_SOURCES = \
-    HilbertCode.cpp \
-    HilbertEncoder.cpp \
-    MortonCode.cpp
-libshapefractal_la_LIBADD =
diff --git a/src/simplify/Makefile.am b/src/simplify/Makefile.am
index 4821b90..0000000
--- a/src/simplify/Makefile.am
+++ /dev/null
@@ -1,20 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libsimplify.la
-libsimplify_la_SOURCES = \
-    DouglasPeuckerLineSimplifier.cpp \
-    DouglasPeuckerSimplifier.cpp \
-    LineSegmentIndex.cpp \
-    TaggedLineSegment.cpp \
-    TaggedLineString.cpp \
-    TaggedLineStringSimplifier.cpp \
-    TaggedLinesSimplifier.cpp \
-    TopologyPreservingSimplifier.cpp
-libsimplify_la_LIBADD =
diff --git a/src/triangulate/Makefile.am b/src/triangulate/Makefile.am
index 3d82002..0000000
--- a/src/triangulate/Makefile.am
+++ /dev/null
@@ -1,17 +0,0 @@
-SUBDIRS = \
-    quadedge
-noinst_LTLIBRARIES = libtriangulate.la
-libtriangulate_la_SOURCES = \
-	IncrementalDelaunayTriangulator.cpp \
-	DelaunayTriangulationBuilder.cpp \
-	VoronoiDiagramBuilder.cpp
-libtriangulate_la_LIBADD = \
-    quadedge/libquadedge.la
diff --git a/src/triangulate/quadedge/Makefile.am b/src/triangulate/quadedge/Makefile.am
index c58199f..0000000
--- a/src/triangulate/quadedge/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libquadedge.la
-libquadedge_la_SOURCES = \
-	QuadEdge.cpp \
-	Vertex.cpp \
-	TrianglePredicate.cpp \
-	QuadEdgeSubdivision.cpp \
-	LastFoundQuadEdgeLocator.cpp \
-	LocateFailureException.cpp
-libquadedge_la_LIBADD =
diff --git a/src/util/Makefile.am b/src/util/Makefile.am
index c4fbdd1..0000000
--- a/src/util/Makefile.am
+++ /dev/null
@@ -1,17 +0,0 @@
-SUBDIRS =
-noinst_LTLIBRARIES = libutil.la
-libutil_la_SOURCES = \
-	Assert.cpp \
-	GeometricShapeFactory.cpp \
-	Interrupt.cpp \
-	math.cpp \
-	Profiler.cpp
-libutil_la_LIBADD =
diff --git a/tests/Makefile.am b/tests/Makefile.am
index 9f5e00e..0000000
--- a/tests/Makefile.am
+++ /dev/null
@@ -1,11 +0,0 @@
-SUBDIRS = \
-	bigtest		\
-	xmltester	\
-	unit		\
-    geostest    \
-    thread
-EXTRA_DIST = CMakeLists.txt
diff --git a/tests/bigtest/Makefile.am b/tests/bigtest/Makefile.am
index bc9eae2..0000000
--- a/tests/bigtest/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-prefix=@prefix@
-top_srcdir=@top_srcdir@
-top_builddir=@top_builddir@
-check_PROGRAMS = TestSweepLineSpeed
-LIBS = $(top_builddir)/src/libgeos.la
-# -lmpatrol -lbfd -lintl -liberty -limagehlp
-TestSweepLineSpeed_SOURCES = TestSweepLineSpeed.cpp GeometryTestFactory.cpp bigtest.h
-TestSweepLineSpeed_LDADD = $(LIBS)
diff --git a/tests/geostest/Makefile.am b/tests/geostest/Makefile.am
index 55d159c..0000000
--- a/tests/geostest/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-AM_CPPFLAGS = -I$(top_srcdir)/include -I$(top_srcdir)/tests/unit/tut -I$(top_builddir)/capi
-EXTRA_DIST = \
-	brokengrammar \
-	test.wkt \
-	test.expected \
-	testrunner.sh
-# TODO: Enable if sample input WKT file is provided
-#TESTS = geostest
-check_PROGRAMS = geostest
-# The -lstdc++ is needed for --disable-shared to work
-geostest_SOURCES = geostest.c
-geostest_LDADD = $(top_builddir)/capi/libgeos_c.la -lstdc++
diff --git a/tests/thread/Makefile.am b/tests/thread/Makefile.am
index 8fc2ea7..0000000
--- a/tests/thread/Makefile.am
+++ /dev/null
@@ -1,18 +0,0 @@
-#TESTS = threadtest badthreadtest
-check_PROGRAMS = threadtest badthreadtest
-threadtest_SOURCES = threadtest.c
-threadtest_LDADD = $(top_builddir)/capi/libgeos_c.la -lpthread -lstdc++
-badthreadtest_SOURCES = badthreadtest.c
-badthreadtest_LDADD = $(top_builddir)/capi/libgeos_c.la -lpthread -lstdc++
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 9a6a818..0000000
--- a/tests/unit/Makefile.am
+++ /dev/null
@@ -1,239 +0,0 @@
-TESTS = geos_unit
-EXTRA_DIST = \
-	tut/tut_assert.hpp \
-	tut/tut_config.hpp \
-	tut/tut_console_reporter.hpp \
-	tut/tut_cppunit_reporter.hpp \
-	tut/tut_exception.hpp \
-	tut/tut_fpt.hpp \
-	tut/tut.hpp \
-	tut/tut_macros.hpp \
-	tut/tut_main.hpp \
-	tut/tut_posix.hpp \
-	tut/tut_reporter.hpp \
-	tut/tut_restartable.hpp \
-	tut/tut_result.hpp \
-	tut/tut_runner.hpp \
-	tut/tut_xml_reporter.hpp \
-	util/NodingTestUtil.h \
-	capi/capi_test_utils.h \
-	CMakeLists.txt
-#noinst_PROGRAMS = geos_unit
-check_PROGRAMS = geos_unit
-#bin_PROGRAMS = geos_tut
-geos_unit_LDADD = \
-	$(top_builddir)/src/libgeos.la  \
-	$(top_builddir)/capi/libgeos_c.la  \
-	$(NULL)
-geos_unit_SOURCES = \
-	geos_unit.cpp \
-	algorithm/AngleTest.cpp \
-	algorithm/AreaTest.cpp \
-	algorithm/CGAlgorithms/computeOrientationTest.cpp \
-	algorithm/CGAlgorithms/OrientationIsCCWTest.cpp \
-	algorithm/CGAlgorithms/isPointInRingTest.cpp \
-	algorithm/CGAlgorithms/signedAreaTest.cpp \
-	algorithm/ConvexHullTest.cpp \
-	algorithm/construct/LargestEmptyCircleTest.cpp \
-	algorithm/construct/MaximumInscribedCircleTest.cpp \
-	algorithm/distance/DiscreteFrechetDistanceTest.cpp \
-	algorithm/distance/DiscreteHausdorffDistanceTest.cpp \
-	algorithm/InteriorPointAreaTest.cpp \
-	algorithm/IntersectionTest.cpp \
-	algorithm/LengthTest.cpp \
-	algorithm/LocatePointInRingTest.cpp \
-	algorithm/MinimumBoundingCircleTest.cpp \
-	algorithm/MinimumDiameterTest.cpp \
-	algorithm/OrientationIndexFailureTest.cpp \
-	algorithm/PointLocatorTest.cpp \
-	algorithm/RobustLineIntersectionTest.cpp \
-	algorithm/RobustLineIntersectorTest.cpp \
-	algorithm/RobustLineIntersectorZTest.cpp \
-	capi/GEOSBufferTest.cpp \
-	capi/GEOSBuildAreaTest.cpp \
-	capi/GEOSCAPIDefinesTest.cpp \
-	capi/GEOSClipByRectTest.cpp \
-	capi/GEOSContainsTest.cpp \
-	capi/GEOSConvexHullTest.cpp \
-	capi/GEOSCoordSeqTest.cpp \
-	capi/GEOSCoverageUnionTest.cpp \
-	capi/GEOSDelaunayTriangulationTest.cpp \
-	capi/GEOSDifferenceTest.cpp \
-	capi/GEOSDifferencePrecTest.cpp \
-	capi/GEOSDistanceTest.cpp \
-	capi/GEOSEqualsTest.cpp \
-	capi/GEOSFrechetDistanceTest.cpp \
-	capi/GEOSGeom_createCollectionTest.cpp \
-	capi/GEOSGeom_createPolygonTest.cpp \
-	capi/GEOSGeom_createLineStringTest.cpp \
-	capi/GEOSGeom_createTest.cpp \
-	capi/GEOSGeom_extentTest.cpp \
-	capi/GEOSGeom_extractUniquePointsTest.cpp \
-	capi/GEOSGeomFromWKBTest.cpp \
-	capi/GEOSGeom_setPrecisionTest.cpp \
-	capi/GEOSGeomToWKTTest.cpp \
-	capi/GEOSGetCentroidTest.cpp \
-	capi/GEOSHausdorffDistanceTest.cpp \
-	capi/GEOSInterpolateTest.cpp \
-	capi/GEOSInterruptTest.cpp \
-	capi/GEOSIntersectionTest.cpp \
-	capi/GEOSIntersectionPrecTest.cpp \
-	capi/GEOSIntersectsTest.cpp \
-	capi/GEOSisClosedTest.cpp \
-	capi/GEOSisValidDetailTest.cpp \
-	capi/GEOSLineString_PointTest.cpp \
-	capi/GEOSMakeValidTest.cpp \
-	capi/GEOSMaximumInscribedCircleTest.cpp \
-	capi/GEOSMinimumBoundingCircleTest.cpp \
-	capi/GEOSMinimumClearanceTest.cpp \
-	capi/GEOSMinimumRectangleTest.cpp \
-	capi/GEOSMinimumWidthTest.cpp \
-	capi/GEOSNearestPointsTest.cpp \
-	capi/GEOSNodeTest.cpp \
-	capi/GEOSOffsetCurveTest.cpp \
-	capi/GEOSOrientationIndexTest.cpp \
-	capi/GEOSPointOnSurfaceTest.cpp \
-	capi/GEOSPolygonizeTest.cpp \
-	capi/GEOSPreparedDistanceTest.cpp \
-	capi/GEOSPreparedGeometryTest.cpp \
-	capi/GEOSPreparedNearestPointsTest.cpp \
-	capi/GEOSProjectTest.cpp \
-	capi/GEOSRelateBoundaryNodeRuleTest.cpp \
-	capi/GEOSRelatePatternMatchTest.cpp \
-	capi/GEOSReverseTest.cpp \
-	capi/GEOSSegmentIntersectionTest.cpp \
-	capi/GEOSSharedPathsTest.cpp \
-	capi/GEOSSimplifyTest.cpp \
-	capi/GEOSSnapTest.cpp \
-	capi/GEOSSTRtreeTest.cpp \
-	capi/GEOSUnionTest.cpp \
-	capi/GEOSUnionPrecTest.cpp \
-	capi/GEOSUnaryUnionTest.cpp \
-	capi/GEOSUserDataTest.cpp \
-	capi/GEOSVoronoiDiagramTest.cpp \
-	capi/GEOSWithinTest.cpp \
-	edgegraph/EdgeGraphTest.cpp \
-	geom/CoordinateArraySequenceFactoryTest.cpp \
-	geom/CoordinateArraySequenceTest.cpp \
-	geom/CoordinateListTest.cpp \
-	geom/CoordinateTest.cpp \
-	geom/DimensionTest.cpp \
-	geom/EnvelopeTest.cpp \
-	geom/FixedSizeCoordinateSequenceTest.cpp \
-	geom/Geometry/cloneTest.cpp \
-	geom/GeometryCollectionTest.cpp \
-	geom/GeometryComponentFilterTest.cpp \
-	geom/Geometry/coversTest.cpp \
-	geom/Geometry/equalsTest.cpp \
-	geom/GeometryFactoryTest.cpp \
-	geom/GeometryFilterTest.cpp \
-	geom/Geometry/isRectangleTest.cpp \
-	geom/Geometry/normalizeTest.cpp \
-	geom/Geometry/touchesTest.cpp \
-	geom/IntersectionMatrixTest.cpp \
-	geom/LinearRingTest.cpp \
-	geom/LineSegmentTest.cpp \
-	geom/LineStringTest.cpp \
-	geom/LocationTest.cpp \
-	geom/MultiLineStringTest.cpp \
-	geom/MultiPointTest.cpp \
-	geom/MultiPolygonTest.cpp \
-	geom/PointTest.cpp \
-	geom/PolygonTest.cpp \
-	geom/PrecisionModelTest.cpp \
-	geom/prep/PreparedGeometryFactoryTest.cpp \
-	geom/prep/PreparedGeometry/touchesTest.cpp \
-	geom/TriangleTest.cpp \
-	geom/util/GeometryExtracterTest.cpp \
-	index/strtree/SIRtreeTest.cpp \
-	index/strtree/SimpleSTRtreeTest.cpp \
-	index/kdtree/KdTreeTest.cpp \
-	io/ByteOrderValuesTest.cpp \
-	io/WKBReaderTest.cpp \
-	io/WKBWriterTest.cpp \
-	io/WKTReaderTest.cpp \
-	io/WKTWriterTest.cpp \
-	io/WriterTest.cpp \
-	linearref/LengthIndexedLineTest.cpp \
-	math/DDTest.cpp \
-	noding/BasicSegmentStringTest.cpp \
-	noding/NodedSegmentStringTest.cpp \
-	noding/OrientedCoordinateArrayTest.cpp \
-	noding/SegmentNodeTest.cpp \
-	noding/SegmentPointComparatorTest.cpp \
-	noding/snapround/HotPixelTest.cpp \
-	noding/snapround/MCIndexSnapRounderTest.cpp \
-	noding/snapround/SnapRoundingNoderTest.cpp \
-	noding/snap/SnappingNoderTest.cpp \
-	operation/buffer/BufferBuilderTest.cpp \
-	operation/buffer/BufferOpTest.cpp \
-	operation/buffer/BufferParametersTest.cpp \
-	operation/distance/DistanceOpTest.cpp \
-	operation/distance/IndexedFacetDistanceTest.cpp \
-	operation/geounion/CascadedPolygonUnionTest.cpp \
-	operation/geounion/CoverageUnionTest.cpp \
-	operation/geounion/UnaryUnionOpTest.cpp \
-	operation/intersection/RectangleIntersectionTest.cpp \
-	operation/IsSimpleOpTest.cpp \
-	operation/linemerge/LineMergerTest.cpp \
-	operation/linemerge/LineSequencerTest.cpp \
-	operation/overlay/OverlayOpUnionTest.cpp \
-	operation/overlay/snap/GeometrySnapperTest.cpp \
-	operation/overlay/snap/LineStringSnapperTest.cpp \
-	operation/overlay/validate/FuzzyPointLocatorTest.cpp \
-	operation/overlay/validate/OffsetPointGeneratorTest.cpp \
-	operation/overlay/validate/OverlayResultValidatorTest.cpp \
-	operation/overlayng/ElevationModelTest.cpp \
-	operation/overlayng/RingClipperTest.cpp \
-	operation/overlayng/LineLimiterTest.cpp \
-	operation/overlayng/OverlayGraphTest.cpp \
-	operation/overlayng/OverlayNGFloatingNoderTest.cpp \
-	operation/overlayng/OverlayNGMixedPointsTest.cpp \
-	operation/overlayng/OverlayNGPointsTest.cpp \
-	operation/overlayng/OverlayNGRobustTest.cpp \
-	operation/overlayng/OverlayNGSnappingNoderTest.cpp \
-	operation/overlayng/OverlayNGSnappingOneTest.cpp \
-	operation/overlayng/OverlayNGStrictModeTest.cpp \
-	operation/overlayng/OverlayNGTest.cpp \
-	operation/overlayng/OverlayNGZTest.cpp \
-	operation/overlayng/PrecisionReducerTest.cpp \
-	operation/overlayng/PrecisionUtilTest.cpp \
-	operation/overlayng/UnaryUnionNGTest.cpp \
-	operation/polygonize/PolygonizeTest.cpp \
-	operation/sharedpaths/SharedPathsOpTest.cpp \
-	operation/valid/IsValidOpTest.cpp \
-	operation/valid/MakeValidTest.cpp \
-	operation/valid/RepeatedPointRemoverTest.cpp \
-	operation/valid/ValidClosedRingTest.cpp \
-	operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp \
-	precision/CommonBitsTest.cpp \
-	precision/GeometryPrecisionReducerTest.cpp \
-	precision/SimpleGeometryPrecisionReducerTest.cpp \
-	simplify/DouglasPeuckerSimplifierTest.cpp \
-	simplify/TopologyPreservingSimplifierTest.cpp \
-	triangulate/DelaunayTest.cpp \
-	triangulate/quadedge/QuadEdgeSubdivisionTest.cpp \
-	triangulate/quadedge/QuadEdgeTest.cpp \
-	triangulate/quadedge/VertexTest.cpp \
-	triangulate/VoronoiTest.cpp \
-	shape/fractal/HilbertCodeTest.cpp \
-	shape/fractal/MortonCodeTest.cpp \
-	util/NodingTestUtil.cpp \
-	util/UniqueCoordinateArrayFilterTest.cpp
-noinst_HEADERS = \
-	utility.h
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 4a13513..0000000
--- a/tests/xmltester/Makefile.am
+++ /dev/null
@@ -1,221 +0,0 @@
-#prefix=@prefix@
-#top_builddir=@top_builddir@
-TESTS = testrunner
-CLEANFILES = testrunner
-EXTRA_DIST = testrunner.sh CMakeLists.txt
-SAFE_XMLTESTS= \
-	$(srcdir)/tests/general/TestBoundary.xml \
-	$(srcdir)/tests/general/TestBuffer.xml \
-	$(srcdir)/tests/general/TestBufferMitredJoin.xml \
-	$(srcdir)/tests/general/TestCentroid.xml \
-	$(srcdir)/tests/general/TestConvexHull-big.xml \
-	$(srcdir)/tests/general/TestConvexHull.xml \
-	$(srcdir)/tests/general/TestDistance.xml \
-	$(srcdir)/tests/general/TestDensify.xml \
-	$(srcdir)/tests/general/TestEqualsExact.xml \
-	$(srcdir)/tests/general/TestInteriorPoint.xml \
-	$(srcdir)/tests/general/TestIntersectsPL.xml \
-	$(srcdir)/tests/general/TestMinimumClearance.xml \
-	$(srcdir)/tests/general/TestNGOverlayA.xml \
-	$(srcdir)/tests/general/TestNGOverlayAPrec.xml \
-	$(srcdir)/tests/general/TestNGOverlayEmpty.xml \
-	$(srcdir)/tests/general/TestNGOverlayL.xml \
-	$(srcdir)/tests/general/TestNGOverlayLPrec.xml \
-	$(srcdir)/tests/general/TestNGOverlayP.xml \
-	$(srcdir)/tests/general/TestNGOverlayPPrec.xml \
-	$(srcdir)/tests/general/TestOverlayAA.xml \
-	$(srcdir)/tests/general/TestOverlayPLPrec.xml \
-	$(srcdir)/tests/general/TestOverlayLLPrec.xml \
-	$(srcdir)/tests/general/TestOverlayLL.xml \
-	$(srcdir)/tests/general/TestOverlayLA.xml \
-	$(srcdir)/tests/general/TestOverlayAAPrec.xml \
-	$(srcdir)/tests/general/TestOverlayPL.xml \
-	$(srcdir)/tests/general/TestOverlayPA.xml \
-	$(srcdir)/tests/general/TestOverlayEmpty.xml \
-	$(srcdir)/tests/general/TestOverlayPP.xml \
-	$(srcdir)/tests/general/TestOverlayLAPrec.xml \
-	$(srcdir)/tests/general/TestPreparedIntersectsPL.xml \
-	$(srcdir)/tests/general/TestPreparedPointPredicate.xml \
-	$(srcdir)/tests/general/TestPreparedPolygonPredicate.xml \
-	$(srcdir)/tests/general/TestPreparedPredicatesWithGeometryCollection.xml \
-	$(srcdir)/tests/general/TestRectanglePredicate.xml \
-	$(srcdir)/tests/general/TestRelateAA.xml \
-	$(srcdir)/tests/general/TestRelateAC.xml \
-	$(srcdir)/tests/general/TestRelateLA.xml \
-	$(srcdir)/tests/general/TestRelateLC.xml \
-	$(srcdir)/tests/general/TestRelateLL.xml \
-	$(srcdir)/tests/general/TestRelatePA.xml \
-	$(srcdir)/tests/general/TestRelatePL.xml \
-	$(srcdir)/tests/general/TestRelatePP.xml \
-	$(srcdir)/tests/general/TestSimple.xml \
-	$(srcdir)/tests/general/TestUnaryUnion.xml \
-	$(srcdir)/tests/general/TestUnaryUnionFloating.xml \
-	$(srcdir)/tests/general/TestValid.xml \
-	$(srcdir)/tests/general/TestValid2-big.xml \
-	$(srcdir)/tests/general/TestValid2.xml \
-	$(srcdir)/tests/general/TestWithinDistance.xml \
-	$(srcdir)/tests/misc/Buffer-1.xml \
-	$(srcdir)/tests/misc/Buffer-2.xml \
-	$(srcdir)/tests/misc/InvalidRelates.xml \
-	$(srcdir)/tests/misc/Segfaults.xml \
-	$(srcdir)/tests/misc/TestBufferExternal-1.xml \
-	$(srcdir)/tests/misc/TestBufferExternal-2.xml \
-	$(srcdir)/tests/misc/TestIsValid.xml \
-	$(srcdir)/tests/misc/buildarea.xml \
-	$(srcdir)/tests/misc/fme.xml \
-	$(srcdir)/tests/misc/heisenbugs.xml \
-	$(srcdir)/tests/misc/hexwkb.xml \
-	$(srcdir)/tests/misc/hole_from_shell.xml \
-	$(srcdir)/tests/misc/hole_red.xml \
-	$(srcdir)/tests/misc/linemerge.xml \
-	$(srcdir)/tests/misc/makevalid.xml \
-	$(srcdir)/tests/misc/robustness.xml \
-	$(srcdir)/tests/misc/safe-16595.xml \
-	$(srcdir)/tests/misc/safe-16596.xml \
-	$(srcdir)/tests/misc/safe-TestBufferJagged.xml \
-	$(srcdir)/tests/misc/singlesidedbuffer.xml \
-	$(srcdir)/tests/misc/stmlf-20061020-invalid-output.xml \
-	$(srcdir)/tests/misc/stmlf-20061020.xml \
-	$(srcdir)/tests/misc/stmlf-20070119.xml \
-	$(srcdir)/tests/misc/split.xml \
-	$(srcdir)/tests/robust/TestRobustOverlayFixed.xml \
-	$(srcdir)/tests/robust/TestRobustRelate.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-misc-5.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-1034.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-153.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-234.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-275.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-350.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-358.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-360.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-368.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-392-lines.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-392.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-398.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-459.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-488.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-522.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-527.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-586.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-599.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-600-lines.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-615.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-737.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-837.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-838.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-979.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-994.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-997-union-fail.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-997-union-slow.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-1046-union-lines.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-1051.xml
-	$(srcdir)/tests/robust/overlay/TestOverlay-geos-list.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-gisse-345341-lines.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-isochrone.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-jts-300.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-misc-1.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-misc-2.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-misc-3.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-misc-4.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-osmwater.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-pg-4182-2.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-pg-4538.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-pg-list.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-qgis-29400.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-qgis-31552.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-qgis-37032.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-rsf-794.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-shapely-829.xml \
-	$(srcdir)/tests/robust/overlay/TestOverlay-stmlf.xml \
-	$(srcdir)/tests/issue/issue-geos-176.xml \
-	$(srcdir)/tests/issue/issue-geos-188.xml \
-	$(srcdir)/tests/issue/issue-geos-234.xml \
-	$(srcdir)/tests/issue/issue-geos-244.xml \
-	$(srcdir)/tests/issue/issue-geos-275.xml \
-	$(srcdir)/tests/issue/issue-geos-350.xml \
-	$(srcdir)/tests/issue/issue-geos-356.xml \
-	$(srcdir)/tests/issue/issue-geos-358.xml \
-	$(srcdir)/tests/issue/issue-geos-360.xml \
-	$(srcdir)/tests/issue/issue-geos-366.xml \
-	$(srcdir)/tests/issue/issue-geos-392.xml \
-	$(srcdir)/tests/issue/issue-geos-398.xml \
-	$(srcdir)/tests/issue/issue-geos-434.xml \
-	$(srcdir)/tests/issue/issue-geos-459.xml \
-	$(srcdir)/tests/issue/issue-geos-488.xml \
-	$(srcdir)/tests/issue/issue-geos-527.xml \
-	$(srcdir)/tests/issue/issue-geos-569.xml \
-	$(srcdir)/tests/issue/issue-geos-582.xml \
-	$(srcdir)/tests/issue/issue-geos-586.xml \
-	$(srcdir)/tests/issue/issue-geos-599.xml \
-	$(srcdir)/tests/issue/issue-geos-605.xml \
-	$(srcdir)/tests/issue/issue-geos-615.xml \
-	$(srcdir)/tests/issue/issue-geos-716.xml \
-	$(srcdir)/tests/issue/issue-geos-837.xml \
-	$(srcdir)/tests/issue/issue-geos-838.xml \
-	$(srcdir)/tests/issue/issue-geos-990.xml \
-	$(srcdir)/tests/issue/issue-geos-994.xml \
-	$(srcdir)/tests/issue/issue-geos-1018.xml \
-	$(srcdir)/tests/issue/issue-geos-1085.xml \
-	$(srcdir)/tests/validate/TestRelateAA-big.xml \
-	$(srcdir)/tests/validate/TestRelateAA.xml \
-	$(srcdir)/tests/validate/TestRelateAC.xml \
-	$(srcdir)/tests/validate/TestRelateLA.xml \
-	$(srcdir)/tests/validate/TestRelateLC.xml \
-	$(srcdir)/tests/validate/TestRelateLL.xml \
-	$(srcdir)/tests/validate/TestRelatePA.xml \
-	$(srcdir)/tests/validate/TestRelatePL.xml \
-	$(srcdir)/tests/validate/TestRelatePP.xml
-INVALID_OUTPUT_XMLTESTS =
-FAILING_XMLTESTS = \
-	$(srcdir)/tests/failure/robust-overlay-stmlf-failures.xml \
-	$(srcdir)/tests/failure/issue-geos-344.xml \
-	$(srcdir)/tests/failure/misc-TestBigNastyBuffer.xml \
-	$(srcdir)/tests/failure/misc-TestSameDirection.xml \
-	$(srcdir)/tests/failure/robust-TestRobustRelateFloat.xml
-XMLTESTS=$(SAFE_XMLTESTS) $(INVALID_OUTPUT_XMLTESTS) $(FAILING_XMLTESTS)
-EXTRA_DIST += $(XMLTESTS)
-noinst_PROGRAMS = SimpleWKTTester XMLTester
-SimpleWKTTester_SOURCES = SimpleWKTTester.cpp
-SimpleWKTTester_LDADD = $(LIBS)
-XMLTester_SOURCES = \
-	XMLTester.cpp \
-	XMLTester.h \
-	tinyxml2/tinyxml2.h \
-	tinyxml2/tinyxml2.cpp \
-	BufferResultMatcher.h \
-	BufferResultMatcher.cpp \
-	SingleSidedBufferResultMatcher.h \
-	SingleSidedBufferResultMatcher.cpp
-XMLTester_LDADD = $(LIBS)
-AM_CPPFLAGS += -I$(top_srcdir)/src/io/tinyxml -DTIXML_USE_STL
-static:
-	$(CXX) $(CXXFLAGS) -I../include -o staticXMLTester XMLTester.cpp MarkupSTL.o ../../src/geom/.libs/libgeos.a
-testrunner: testrunner.sh Makefile
-	@sh $(srcdir)/testrunner.sh $@ --test-valid-output $(SAFE_XMLTESTS)
diff --git a/tools/Makefile.am b/tools/Makefile.am
index d76ba31..0000000
--- a/tools/Makefile.am
+++ /dev/null
@@ -1,10 +0,0 @@
-bin_SCRIPTS = geos-config
-EXTRA_DIST = \
-	CMakeLists.txt \
-	geos-config.cmake \
-	geos.pc.cmake
-SUBDIRS = astyle
diff --git a/tools/astyle/Makefile.am b/tools/astyle/Makefile.am
index 30ec858..0000000
--- a/tools/astyle/Makefile.am
+++ /dev/null
@@ -1,26 +0,0 @@
-AM_CPPFLAGS =
-EXTRA_DIST = \
-	CMakeLists.txt
-noinst_PROGRAMS = astyle
-astyle_SOURCES = \
-	ASBeautifier.cpp \
-	ASEnhancer.cpp \
-	ASFormatter.cpp \
-	ASLocalizer.cpp \
-	ASResource.cpp \
-	astyle_main.cpp
-noinst_HEADERS = \
-	ASLocalizer.h \
-	astyle.h \
-	astyle_main.h
diff --git a/tools/ci/berrie.sh b/tools/ci/berrie.sh
index ecd8fe8..42b75fe 100644
--- a/tools/ci/berrie.sh
+++ b/tools/ci/berrie.sh
@@ -8,24 +8,12 @@
 # the terms of the GNU Lesser General Public Licence as published
 # by the Free Software Foundation.
 # See the COPYING file for more information.
-# auto tools
-if false; then
-    sh autogen.sh
-    ./configure
-    make
-    make check
-fi
-# cmake
-if true; then
-    rm -rf build
-    mkdir -p build
-    cd build
-    cmake ../
-    make
-    [ -f CMakeCache.txt ] && \
-        ctest --output-on-failure . || \
-        make check
-fi
+rm -rf build
+mkdir -p build
+cd build
+cmake ../
+make
+[ -f CMakeCache.txt ] && \
+ctest --output-on-failure . || \
+make check
diff --git a/tools/ci/berrie64.sh b/tools/ci/berrie64.sh
index 0d3fa39..b7dcfbc 100644
--- a/tools/ci/berrie64.sh
+++ b/tools/ci/berrie64.sh
@@ -9,24 +9,12 @@
-# auto tools
-if false; then
-    sh autogen.sh
-    ./configure
-    make
-    make check
-fi
-# cmake
-if true; then
-    rm -rf build
-    mkdir -p build
-    cd build
-    cmake ../
-    make
-        make check
-fi
+rm -rf build
+mkdir -p build
+cd build
+cmake ../
+make
+make check
diff --git a/tools/ci/bessie.sh b/tools/ci/bessie.sh
index 502f60f..4f97ae3 100755
--- a/tools/ci/bessie.sh
+++ b/tools/ci/bessie.sh
@@ -8,24 +8,12 @@
-# auto tools
-if false; then
-    sh autogen.sh
-    ./configure
-    make
-    make check
-fi
-# cmake
-if true; then
-    rm -rf build
-    mkdir -p build
-    cd build
-    cmake ../
-    make
-        make check
-fi
+rm -rf build
+mkdir -p build
+cd build
+cmake ../
+make
+make check
diff --git a/tools/ci/bessie32.sh b/tools/ci/bessie32.sh
index 193034d..acca9a7 100755
--- a/tools/ci/bessie32.sh
+++ b/tools/ci/bessie32.sh
@@ -8,24 +8,12 @@
-# auto tools
-if false; then
-    sh autogen.sh
-    ./configure
-    make
-    make check
-fi
-# cmake
-if true; then
-    rm -rf build
-    mkdir -p build
-    cd build
-    cmake ../
-    make
-        make check
-fi
+rm -rf build
+mkdir -p build
+cd build
+cmake ../
+make
+make check
diff --git a/tools/ci/script.sh b/tools/ci/script.sh
index 78a5318..5b9e75d 100755
--- a/tools/ci/script.sh
+++ b/tools/ci/script.sh
@@ -24,4 +24,4 @@ mkdir -p ${builddir}
 cd ${builddir}
 # build and run tests
-${TRAVIS_BUILD_DIR}/tools/ci/script_${GEOS_BUILD_TOOL}.sh
+${TRAVIS_BUILD_DIR}/tools/ci/script_cmake.sh
diff --git a/tools/ci/script_autotools.sh b/tools/ci/script_autotools.sh
deleted file mode 100755
index b8b1cd8..0000000
--- a/tools/ci/script_autotools.sh
+++ /dev/null
@@ -1,27 +0,0 @@
-#!/bin/sh
-# Travis CI script for GEOS build with GNU Autotools
-# Copyright (C) 2013 Mateusz Loskot <mateusz at loskot.net>
-# This is free software; you can redistribute and/or modify it under
-# the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
-# See the COPYING file for more information.
-if [ -z "${TRAVIS_BUILD_DIR+x}" ]; then
-  echo TRAVIS_BUILD_DIR not defined
-  exit 1
-fi
-# source common functions
-. ${TRAVIS_BUILD_DIR}/tools/ci/common.sh
-cd ${TRAVIS_BUILD_DIR}
-./autogen.sh
-cd -
-${TRAVIS_BUILD_DIR}/configure
-run_make
-make check
-make distcheck
diff --git a/tools/ci/script_autotools_scanbuild.sh b/tools/ci/script_autotools_scanbuild.sh
index 5cd40d8..0000000
--- a/tools/ci/script_autotools_scanbuild.sh
+++ /dev/null
@@ -1,25 +0,0 @@
-#!/bin/sh
-  exit 1
-fi
-./autogen.sh
-cd -
-scan-build ${TRAVIS_BUILD_DIR}/configure CC=clang-9 CXX=clang++-9 CXXFLAGS="-std=c++11"
-scan-build --keep-cc --status-bugs make -j2
diff --git a/util/Makefile.am b/util/Makefile.am
deleted file mode 100644
index cd08508..0000000
--- a/util/Makefile.am
+++ /dev/null
@@ -1,12 +0,0 @@
-SUBDIRS = \
-	geosop
diff --git a/util/geosop/Makefile.am b/util/geosop/Makefile.am
index 38bca5d..0000000
--- a/util/geosop/Makefile.am
+++ /dev/null
@@ -1,25 +0,0 @@
-prefix=@prefix@
-noinst_PROGRAMS = geosop
-geosop_SOURCES = \
-	GeosOp.cpp \
-	GeosOp.h \
-	cxxopts.hpp \
-	GeomFunction.cpp \
-	GeomFunction.h \
-	WKBStreamReader.cpp \
-	WKBStreamReader.h \
-	WKTStreamReader.cpp \
-	WKTStreamReader.h
-geosop_LDADD = $(top_builddir)/src/libgeos.la
Summary of changes:
 .drone-1.0.yml                                  |   5 +-
 .github/workflows/ci.yml                        |  41 +-
 .gitlab-ci.yml                                  |   7 +-
 .travis.yml                                     |  42 --
 CMakeLists.txt                                  |   5 +
 HOWTO_RELEASE                                   |   5 +-
 Makefile.am                                     |  79 --
 acsite.m4                                       |  55 --
 autogen.sh                                      |  96 ---
 benchmarks/Makefile.am                          |  17 -
 benchmarks/algorithm/Makefile.am                |  25 -
 benchmarks/capi/Makefile.am                     |  30 -
 benchmarks/operation/Makefile.am                |   9 -
 benchmarks/operation/buffer/Makefile.am         |  17 -
 benchmarks/operation/predicate/Makefile.am      |  17 -
 capi/Makefile.am                                |  33 -
 configure.ac                                    | 434 -----------
 doc/Makefile.am                                 |  26 -
 include/Makefile.am                             |  10 -
 include/geos/Makefile.am                        |  37 -
 include/geos/algorithm/Makefile.am              |  41 -
 include/geos/algorithm/construct/Makefile.am    |  12 -
 include/geos/algorithm/distance/Makefile.am     |  14 -
 include/geos/algorithm/locate/Makefile.am       |  13 -
 include/geos/edgegraph/Makefile.am              |  11 -
 include/geos/geom/Makefile.am                   |  54 --
 include/geos/geom/prep/Makefile.am              |  26 -
 include/geos/geom/util/Makefile.am              |  23 -
 include/geos/geomgraph/Makefile.am              |  34 -
 include/geos/geomgraph/index/Makefile.am        |  22 -
 include/geos/index/Makefile.am                  |  19 -
 include/geos/index/bintree/Makefile.am          |  17 -
 include/geos/index/chain/Makefile.am            |  14 -
 include/geos/index/intervalrtree/Makefile.am    |  14 -
 include/geos/index/kdtree/Makefile.am           |  15 -
 include/geos/index/quadtree/Makefile.am         |  16 -
 include/geos/index/strtree/Makefile.am          |  24 -
 include/geos/index/sweepline/Makefile.am        |  14 -
 include/geos/io/Makefile.am                     |  23 -
 include/geos/linearref/Makefile.am              |  18 -
 include/geos/math/Makefile.am                   |  11 -
 include/geos/noding/Makefile.am                 |  45 --
 include/geos/noding/snap/Makefile.am            |  13 -
 include/geos/noding/snapround/Makefile.am       |  17 -
 include/geos/operation/Makefile.am              |  24 -
 include/geos/operation/buffer/Makefile.am       |  21 -
 include/geos/operation/distance/Makefile.am     |  17 -
 include/geos/operation/intersection/Makefile.am |  13 -
 include/geos/operation/linemerge/Makefile.am    |  16 -
 include/geos/operation/overlay/Makefile.am      |  24 -
 include/geos/operation/overlay/snap/Makefile.am |  14 -
 include/geos/operation/overlayng/Makefile.am    |  42 --
 include/geos/operation/polygonize/Makefile.am   |  17 -
 include/geos/operation/predicate/Makefile.am    |  13 -
 include/geos/operation/relate/Makefile.am       |  18 -
 include/geos/operation/sharedpaths/Makefile.am  |  11 -
 include/geos/operation/union/Makefile.am        |  18 -
 include/geos/operation/valid/Makefile.am        |  21 -
 include/geos/planargraph/Makefile.am            |  18 -
 include/geos/planargraph/algorithm/Makefile.am  |  11 -
 include/geos/precision/Makefile.am              |  18 -
 include/geos/shape/Makefile.am                  |  11 -
 include/geos/shape/fractal/Makefile.am          |  13 -
 include/geos/simplify/Makefile.am               |  18 -
 include/geos/triangulate/Makefile.am            |  14 -
 include/geos/triangulate/quadedge/Makefile.am   |  19 -
 include/geos/util/Makefile.am                   |  23 -
 macros/Makefile.am                              |   8 -
 macros/ax_check_compile_flag.m4                 |  74 --
 macros/ax_cxx_compile_stdcxx.m4                 | 948 ------------------------
 macros/ax_cxx_compile_stdcxx_11.m4              |  39 -
 macros/boost.m4                                 | 490 ------------
 macros/geos.m4                                  |  93 ---
 src/Makefile.am                                 |  56 --
 src/algorithm/Makefile.am                       |  41 -
 src/algorithm/construct/Makefile.am             |  14 -
 src/algorithm/distance/Makefile.am              |  15 -
 src/algorithm/locate/Makefile.am                |  15 -
 src/deps/Makefile.am                            |  18 -
 src/deps/ryu/Makefile.am                        |  19 -
 src/edgegraph/Makefile.am                       |  12 -
 src/geom/Makefile.am                            |  44 --
 src/geom/prep/Makefile.am                       |  29 -
 src/geom/util/Makefile.am                       |  19 -
 src/geomgraph/Makefile.am                       |  30 -
 src/geomgraph/index/Makefile.am                 |  16 -
 src/index/Makefile.am                           |  24 -
 src/index/bintree/Makefile.am                   |  16 -
 src/index/chain/Makefile.am                     |  12 -
 src/index/intervalrtree/Makefile.am             |  11 -
 src/index/kdtree/Makefile.am                    |  12 -
 src/index/quadtree/Makefile.am                  |  14 -
 src/index/strtree/Makefile.am                   |  20 -
 src/index/sweepline/Makefile.am                 |  13 -
 src/io/Makefile.am                              |  22 -
 src/linearref/Makefile.am                       |  22 -
 src/math/Makefile.am                            |  13 -
 src/noding/Makefile.am                          |  38 -
 src/noding/snap/Makefile.am                     |  15 -
 src/noding/snapround/Makefile.am                |  18 -
 src/operation/Makefile.am                       |  38 -
 src/operation/buffer/Makefile.am                |  23 -
 src/operation/distance/Makefile.am              |  19 -
 src/operation/intersection/Makefile.am          |  15 -
 src/operation/linemerge/Makefile.am             |  18 -
 src/operation/overlay/Makefile.am               |  32 -
 src/operation/overlayng/Makefile.am             |  40 -
 src/operation/polygonize/Makefile.am            |  19 -
 src/operation/predicate/Makefile.am             |  16 -
 src/operation/relate/Makefile.am                |  20 -
 src/operation/sharedpaths/Makefile.am           |  11 -
 src/operation/union/Makefile.am                 |  18 -
 src/operation/valid/Makefile.am                 |  29 -
 src/planargraph/Makefile.am                     |  23 -
 src/precision/Makefile.am                       |  20 -
 src/shape/Makefile.am                           |  12 -
 src/shape/fractal/Makefile.am                   |  13 -
 src/simplify/Makefile.am                        |  20 -
 src/triangulate/Makefile.am                     |  17 -
 src/triangulate/quadedge/Makefile.am            |  18 -
 src/util/Makefile.am                            |  17 -
 tests/Makefile.am                               |  11 -
 tests/bigtest/Makefile.am                       |  19 -
 tests/geostest/Makefile.am                      |  19 -
 tests/thread/Makefile.am                        |  18 -
 tests/unit/Makefile.am                          | 239 ------
 tests/xmltester/CMakeLists.txt                  |   5 +
 tests/xmltester/Makefile.am                     | 221 ------
 tools/Makefile.am                               |  10 -
 tools/astyle/Makefile.am                        |  26 -
 tools/ci/berrie.sh                              |  28 +-
 tools/ci/berrie64.sh                            |  28 +-
 tools/ci/bessie.sh                              |  28 +-
 tools/ci/bessie32.sh                            |  28 +-
 tools/ci/script.sh                              |   2 +-
 tools/ci/script_autotools.sh                    |  27 -
 tools/ci/script_autotools_scanbuild.sh          |  25 -
 util/Makefile.am                                |  12 -
 util/geosop/Makefile.am                         |  25 -
 139 files changed, 64 insertions(+), 5289 deletions(-)
 delete mode 100644 Makefile.am
 delete mode 100644 acsite.m4
 delete mode 100755 autogen.sh
 delete mode 100644 benchmarks/Makefile.am
 delete mode 100644 benchmarks/algorithm/Makefile.am
 delete mode 100644 benchmarks/capi/Makefile.am
 delete mode 100644 benchmarks/operation/Makefile.am
 delete mode 100644 benchmarks/operation/buffer/Makefile.am
 delete mode 100644 benchmarks/operation/predicate/Makefile.am
 delete mode 100644 capi/Makefile.am
 delete mode 100644 configure.ac
 delete mode 100644 doc/Makefile.am
 delete mode 100644 include/Makefile.am
 delete mode 100644 include/geos/Makefile.am
 delete mode 100644 include/geos/algorithm/Makefile.am
 delete mode 100644 include/geos/algorithm/construct/Makefile.am
 delete mode 100644 include/geos/algorithm/distance/Makefile.am
 delete mode 100644 include/geos/algorithm/locate/Makefile.am
 delete mode 100644 include/geos/edgegraph/Makefile.am
 delete mode 100644 include/geos/geom/Makefile.am
 delete mode 100644 include/geos/geom/prep/Makefile.am
 delete mode 100644 include/geos/geom/util/Makefile.am
 delete mode 100644 include/geos/geomgraph/Makefile.am
 delete mode 100644 include/geos/geomgraph/index/Makefile.am
 delete mode 100644 include/geos/index/Makefile.am
 delete mode 100644 include/geos/index/bintree/Makefile.am
 delete mode 100644 include/geos/index/chain/Makefile.am
 delete mode 100644 include/geos/index/intervalrtree/Makefile.am
 delete mode 100644 include/geos/index/kdtree/Makefile.am
 delete mode 100644 include/geos/index/quadtree/Makefile.am
 delete mode 100644 include/geos/index/strtree/Makefile.am
 delete mode 100644 include/geos/index/sweepline/Makefile.am
 delete mode 100644 include/geos/io/Makefile.am
 delete mode 100644 include/geos/linearref/Makefile.am
 delete mode 100644 include/geos/math/Makefile.am
 delete mode 100644 include/geos/noding/Makefile.am
 delete mode 100644 include/geos/noding/snap/Makefile.am
 delete mode 100644 include/geos/noding/snapround/Makefile.am
 delete mode 100644 include/geos/operation/Makefile.am
 delete mode 100644 include/geos/operation/buffer/Makefile.am
 delete mode 100644 include/geos/operation/distance/Makefile.am
 delete mode 100644 include/geos/operation/intersection/Makefile.am
 delete mode 100644 include/geos/operation/linemerge/Makefile.am
 delete mode 100644 include/geos/operation/overlay/Makefile.am
 delete mode 100644 include/geos/operation/overlay/snap/Makefile.am
 delete mode 100644 include/geos/operation/overlayng/Makefile.am
 delete mode 100644 include/geos/operation/polygonize/Makefile.am
 delete mode 100644 include/geos/operation/predicate/Makefile.am
 delete mode 100644 include/geos/operation/relate/Makefile.am
 delete mode 100644 include/geos/operation/sharedpaths/Makefile.am
 delete mode 100644 include/geos/operation/union/Makefile.am
 delete mode 100644 include/geos/operation/valid/Makefile.am
 delete mode 100644 include/geos/planargraph/Makefile.am
 delete mode 100644 include/geos/planargraph/algorithm/Makefile.am
 delete mode 100644 include/geos/precision/Makefile.am
 delete mode 100644 include/geos/shape/Makefile.am
 delete mode 100644 include/geos/shape/fractal/Makefile.am
 delete mode 100644 include/geos/simplify/Makefile.am
 delete mode 100644 include/geos/triangulate/Makefile.am
 delete mode 100644 include/geos/triangulate/quadedge/Makefile.am
 delete mode 100644 include/geos/util/Makefile.am
 delete mode 100644 macros/Makefile.am
 delete mode 100755 macros/ax_check_compile_flag.m4
 delete mode 100755 macros/ax_cxx_compile_stdcxx.m4
 delete mode 100755 macros/ax_cxx_compile_stdcxx_11.m4
 delete mode 100644 macros/boost.m4
 delete mode 100644 macros/geos.m4
 delete mode 100644 src/Makefile.am
 delete mode 100644 src/algorithm/Makefile.am
 delete mode 100644 src/algorithm/construct/Makefile.am
 delete mode 100644 src/algorithm/distance/Makefile.am
 delete mode 100644 src/algorithm/locate/Makefile.am
 delete mode 100644 src/deps/Makefile.am
 delete mode 100644 src/deps/ryu/Makefile.am
 delete mode 100644 src/edgegraph/Makefile.am
 delete mode 100644 src/geom/Makefile.am
 delete mode 100644 src/geom/prep/Makefile.am
 delete mode 100644 src/geom/util/Makefile.am
 delete mode 100644 src/geomgraph/Makefile.am
 delete mode 100644 src/geomgraph/index/Makefile.am
 delete mode 100644 src/index/Makefile.am
 delete mode 100644 src/index/bintree/Makefile.am
 delete mode 100644 src/index/chain/Makefile.am
 delete mode 100644 src/index/intervalrtree/Makefile.am
 delete mode 100644 src/index/kdtree/Makefile.am
 delete mode 100644 src/index/quadtree/Makefile.am
 delete mode 100644 src/index/strtree/Makefile.am
 delete mode 100644 src/index/sweepline/Makefile.am
 delete mode 100644 src/io/Makefile.am
 delete mode 100644 src/linearref/Makefile.am
 delete mode 100644 src/math/Makefile.am
 delete mode 100644 src/noding/Makefile.am
 delete mode 100644 src/noding/snap/Makefile.am
 delete mode 100644 src/noding/snapround/Makefile.am
 delete mode 100644 src/operation/Makefile.am
 delete mode 100644 src/operation/buffer/Makefile.am
 delete mode 100644 src/operation/distance/Makefile.am
 delete mode 100644 src/operation/intersection/Makefile.am
 delete mode 100644 src/operation/linemerge/Makefile.am
 delete mode 100644 src/operation/overlay/Makefile.am
 delete mode 100644 src/operation/overlayng/Makefile.am
 delete mode 100644 src/operation/polygonize/Makefile.am
 delete mode 100644 src/operation/predicate/Makefile.am
 delete mode 100644 src/operation/relate/Makefile.am
 delete mode 100644 src/operation/sharedpaths/Makefile.am
 delete mode 100644 src/operation/union/Makefile.am
 delete mode 100644 src/operation/valid/Makefile.am
 delete mode 100644 src/planargraph/Makefile.am
 delete mode 100644 src/precision/Makefile.am
 delete mode 100644 src/shape/Makefile.am
 delete mode 100644 src/shape/fractal/Makefile.am
 delete mode 100644 src/simplify/Makefile.am
 delete mode 100644 src/triangulate/Makefile.am
 delete mode 100644 src/triangulate/quadedge/Makefile.am
 delete mode 100644 src/util/Makefile.am
 delete mode 100644 tests/Makefile.am
 delete mode 100644 tests/bigtest/Makefile.am
 delete mode 100644 tests/geostest/Makefile.am
 delete mode 100644 tests/thread/Makefile.am
 delete mode 100644 tests/unit/Makefile.am
 delete mode 100644 tests/xmltester/Makefile.am
 delete mode 100644 tools/Makefile.am
 delete mode 100644 tools/astyle/Makefile.am
 delete mode 100755 tools/ci/script_autotools.sh
 delete mode 100755 tools/ci/script_autotools_scanbuild.sh
 delete mode 100644 util/Makefile.am
 delete mode 100644 util/geosop/Makefile.am
hooks/post-receive
More information about the geos-commits mailing list
