[geos-commits] [SCM] GEOS branch master updated. 395e6c2d2531eda7483dd137058041f830e33825
git at osgeo.org
git at osgeo.org
Sun Jan 17 09:11:53 PST 2021
the project "GEOS".
via 395e6c2d2531eda7483dd137058041f830e33825 (commit)
from dae18d6c6555b4b129ec053af3a50f7045fd5413 (commit)
revisions in full, below.
commit 395e6c2d2531eda7483dd137058041f830e33825
Author: Martin Davis <mtnclimb at gmail.com>
Date: Sun Jan 17 09:11:45 2021 -0800
Add geosop PreparedGeometryCache class
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index ccd1b75..176dbcc 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -46,8 +46,26 @@ using geos::operation::overlayng::OverlayNG;
/* static private */
std::map<std::string, GeomFunction*> GeomFunction::registry;
-static std::unique_ptr<const PreparedGeometry> prepGeomCache;
-static Geometry *cacheKey;
+class PreparedGeometryCache {
+public:
+ const PreparedGeometry* get(const Geometry* key) {
+ if (m_key != key) {
+ m_pg = PreparedGeometryFactory::prepare(key);
+ m_key = key;
+ return m_pg.get();
+private:
+ std::unique_ptr<const PreparedGeometry> m_pg;
+ const Geometry* m_key;
+PreparedGeometryCache prepGeomCache;
+//static std::unique_ptr<const PreparedGeometry> prepGeomCache;
+//static Geometry *cacheKey;
/* static */
void
@@ -236,64 +254,28 @@ GeomFunction::init()
add("containsPrep", "tests if geometry A contains geometry B, using PreparedGeometry", 2, 0,
[](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
- if (cacheKey == nullptr || cacheKey != geom.get()) {
- auto pg = std::unique_ptr<const PreparedGeometry>(
- PreparedGeometryFactory::prepare( geom.get()) );
- prepGeomCache = std::move( pg );
- cacheKey = geom.get();
- return new Result( prepGeomCache->contains( geomB.get() ) );
+ return new Result( prepGeomCache.get(geom.get())->contains( geomB.get() ) );
add("containsProperlyPrep", "tests if geometry A properly contains geometry B using PreparedGeometry", 2, 0,
- return new Result( prepGeomCache->containsProperly( geomB.get() ) );
+ return new Result( prepGeomCache.get(geom.get())->containsProperly( geomB.get() ) );
add("coversPrep", "tests if geometry A covers geometry B using PreparedGeometry", 2, 0,
- return new Result( prepGeomCache->covers( geomB.get() ) );
+ return new Result( prepGeomCache.get(geom.get())->covers( geomB.get() ) );
add("intersectsPrep", "tests if geometry A intersects B using PreparedGeometry", 2, 0,
- return new Result( prepGeomCache->intersects( geomB.get() ) );
+ return new Result( prepGeomCache.get(geom.get())->intersects( geomB.get() ) );
add("distancePrep", "computes distance between geometry A and B using PreparedGeometry", 2, 0,
- return new Result( prepGeomCache->distance( geomB.get() ) );
+ return new Result( prepGeomCache.get(geom.get())->distance( geomB.get() ) );
add("nearestPointsPrep", "computes nearest points of geometry A and B using PreparedGeometry", 2, 0,
- auto cs = prepGeomCache->nearestPoints( geomB.get() );
+ auto cs = prepGeomCache.get(geom.get())->nearestPoints( geomB.get() );
auto factory = geom->getFactory();
auto res = factory->createLineString( std::move(cs) );
return new Result( std::move(res) );
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index ce30bf7..11d71dc 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -333,7 +333,7 @@ void GeosOp::run() {
if (args.isShowTime || args.isVerbose) {
std::cout
- << "Processed " << formatNum( opCount ) << " " << args.opName << " ops ( "
+ << "Ran " << formatNum( opCount ) << " " << args.opName << " ops ( "
<< formatNum( vertexCount ) << " vertices)"
<< " -- " << formatNum( totalTime ) << " usec"
<< " (GEOS " << geosversion() << ")"
Summary of changes:
util/geosop/GeomFunction.cpp | 70 ++++++++++++++++----------------------------
util/geosop/GeosOp.cpp | 2 +-
2 files changed, 27 insertions(+), 45 deletions(-)
hooks/post-receive
More information about the geos-commits
