[geos-commits] [SCM] GEOS branch master updated. 98641ab14e01a6b5a6339f49fa6f1bee4424c7d0
Tue Jan 19 11:48:30 PST 2021
the project "GEOS".
       via  98641ab14e01a6b5a6339f49fa6f1bee4424c7d0 (commit)
      from  395e6c2d2531eda7483dd137058041f830e33825 (commit)
revisions in full, below.
commit 98641ab14e01a6b5a6339f49fa6f1bee4424c7d0
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Jan 19 11:48:24 2021 -0800
    Add geosop isEmpty function
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index 176dbcc..dff83ad 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -124,6 +124,11 @@ GeomFunction::init()
             return new Result( geom->intersects( geomB.get() ) );
+    add("isEmpty", "tests if geometry A is empty", 1, 0,
+        [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
+            return new Result( geom->isEmpty() );
     add("isSimple", "tests if geometry A is simple", 1, 0,
             return new Result( geom->isSimple() );
@@ -157,7 +162,7 @@ GeomFunction::init()
             return new Result( std::move(res) );
-    add("nearestPoints", "computes nearest points of geometry A and B", 2, 0,
+    add("nearestPoints", "computes a line containing the nearest points of geometry A and B", 2, 0,
             std::unique_ptr<CoordinateSequence> cs = geos::operation::distance::DistanceOp::nearestPoints(geom.get(), geomB.get());
             auto factory = geom->getFactory();
@@ -273,7 +278,7 @@ GeomFunction::init()
             return new Result( prepGeomCache.get(geom.get())->distance( geomB.get() ) );
-    add("nearestPointsPrep", "computes nearest points of geometry A and B using PreparedGeometry", 2, 0,
+    add("nearestPointsPrep", "computes a line containing the nearest points of geometry A and B using PreparedGeometry", 2, 0,
             auto cs = prepGeomCache.get(geom.get())->nearestPoints( geomB.get() );
Summary of changes:
 util/geosop/GeomFunction.cpp | 9 +++++++--
 1 file changed, 7 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
