[geos-commits] [SCM] GEOS branch master updated. a91dedcb41b6f3d2e2f6355b72ff221e3ceba7da
Thu Jan 21 11:26:05 PST 2021
the project "GEOS".
       via  a91dedcb41b6f3d2e2f6355b72ff221e3ceba7da (commit)
      from  98641ab14e01a6b5a6339f49fa6f1bee4424c7d0 (commit)
revisions in full, below.
commit a91dedcb41b6f3d2e2f6355b72ff221e3ceba7da
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jan 21 11:24:16 2021 -0800
    Add doxygen content for all the functions in the CAPI.
    Re-entrant variants are just cross-referenced to their
    simple variants. Deprecated functions still exist but
    with deprecation markings and recommended replacements.
    Order of functions in the .h file might be improved,
    perhaps with simple variants up front, followed by
    re-entrants, then deprecated.
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 7cb3d57..e5e478b 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1,6 +1,5 @@
  * C-Wrapper for GEOS library
  * Copyright (C) 2010 2011 Sandro Santilli <strk at kbt.io>
@@ -10,27 +9,33 @@
  * the terms of the GNU Lesser General Public Licence as published
  * by the Free Software Foundation.
  * See the COPYING file for more information.
- * Author: Sandro Santilli <strk at kbt.io>
- * GENERAL NOTES:
- *	- Remember to call initGEOS() before any use of this library's
- *	  functions, and call finishGEOS() when done.
- *	- Currently you have to explicitly GEOSGeom_destroy() all
- *	  GEOSGeom objects to avoid memory leaks, and GEOSFree()
- *	  all returned char * (unless const).
- *	- Functions ending with _r are thread safe; see details in RFC 3
- *	  http://trac.osgeo.org/geos/wiki/RFC3.
- *	  To avoid using by accident non _r functions,
- *	  define GEOS_USE_ONLY_R_API before including geos_c.h
+* \file geos_c.h
+* \brief C API for the GEOS geometry algorithms library.
+* The C API is the preferred API to use when integration GEOS into
+* you program/language/etc. While the C++ API is available, the ABI
+* will not be stable between versions, and the API may also change.
+* The GEOS team makes an effort to keep the C API stable, and to
+* deprecate function signatures only over a long time period to allow
+* transition time.
+* Important programming notes:
+* - Remember to call initGEOS() before any use of this library's
+*   functions, and call finishGEOS() when done.
+* - Currently you have to explicitly GEOSGeom_destroy() all
+*   GEOSGeom objects to avoid memory leaks, and GEOSFree()
+*   all returned char * (unless const).
+* - Functions ending with _r are thread safe (reentrant);
+*   see details in http://trac.osgeo.org/geos/wiki/RFC3.
+*   To avoid accidental use of non-reentrant functions,
+*   define GEOS_USE_ONLY_R_API before including geos_c.h.
 #ifndef GEOS_C_H_INCLUDED
 #define GEOS_C_H_INCLUDED
@@ -45,11 +50,11 @@ using std::size_t;
 extern "C" {
 #endif
- * Version
+/* Version */
+/** \cond */
 #ifndef GEOS_VERSION_MAJOR
 #define GEOS_VERSION_MAJOR @VERSION_MAJOR@
@@ -75,717 +80,791 @@ extern "C" {
 #define GEOS_CAPI_FIRST_INTERFACE GEOS_CAPI_VERSION_MAJOR
 #define GEOS_CAPI_LAST_INTERFACE (GEOS_CAPI_VERSION_MAJOR+GEOS_CAPI_VERSION_MINOR)
+/** \endcond */
- * (Abstract) type definitions
+#include <geos/export.h>
+* Type returned by GEOS_init_r(), for use in multi-threaded
+* applications.
+* There should be only one GEOSContextHandle_t per thread.
 typedef struct GEOSContextHandle_HS *GEOSContextHandle_t;
+* Callback function for passing GEOS error messages to parent process.
+* Set the GEOSMessageHandler for error and notice messages in \ref initGEOS
+* for single-threaded programs, or using \ref initGEOS_r for threaded
+* programs
+* \param fmt the message format template
 typedef void (*GEOSMessageHandler)(const char *fmt, ...);
- * A GEOS message handler function.
- * @param message the message contents
- * @param userdata the user data pointer that was passed to GEOS when registering this message handler.
- * @see GEOSContext_setErrorMessageHandler
- * @see GEOSContext_setNoticeMessageHandler
+* A GEOS message handler function.
+* \param message the message contents
+* \param userdata the user data pointer that was passed to GEOS when
+* registering this message handler.
+* \see GEOSContext_setErrorMessageHandler
+* \see GEOSContext_setNoticeMessageHandler
 typedef void (*GEOSMessageHandler_r)(const char *message, void *userdata);
-/* When we're included by geos_c.cpp, those are #defined to the original
- * JTS definitions via preprocessor. We don't touch them to allow the
- * compiler to cross-check the declarations. However, for all "normal"
- * C-API users, we need to define them as "opaque" struct pointers, as
- * those clients don't have access to the original C++ headers, by design.
+* When we're included by geos_c.cpp, these types are #defined to the
+* C++ definitions via preprocessor. We don't touch them to allow the
+* compiler to cross-check the declarations. However, for all "normal"
+* C-API users, we need to define these types as "opaque" struct pointers, as
+* those clients don't have access to the original C++ headers, by design.
 #ifndef GEOSGeometry
+Geometry generic type. Geometry can be a point, linestring, polygon,
+multipoint, multilinestring, multipolygon, or geometrycollection.
+Geometry type can be read with \ref GEOSGeomTypeId. Most functions
+in GEOS either have GEOSGeometry* as a parameter or a return type.
+\see GEOSGeom_createPoint
+\see GEOSGeom_createLineString
+\see GEOSGeom_createPolygon
+\see GEOSGeom_createCollection
+\see GEOSGeom_destroy
 typedef struct GEOSGeom_t GEOSGeometry;
+/** Prepared geometry type. \see GEOSPrepare */
 typedef struct GEOSPrepGeom_t GEOSPreparedGeometry;
+/** Coordinate sequence. \see GEOSCoordSeq_create */
 typedef struct GEOSCoordSeq_t GEOSCoordSequence;
+/** STRTree index. \see GEOSSTRtree_create */
 typedef struct GEOSSTRtree_t GEOSSTRtree;
+/** Paramter object for buffering. \see GEOSBufferParams_create */
 typedef struct GEOSBufParams_t GEOSBufferParams;
 #endif
-/* Those are compatibility definitions for source compatibility
- * with GEOS 2.X clients relying on that type.
+/** \cond */
+* These are compatibility definitions for source compatibility
+* with GEOS 2.X clients relying on that type.
 typedef GEOSGeometry* GEOSGeom;
 typedef GEOSCoordSequence* GEOSCoordSeq;
-/* Supported geometry types
- * This was renamed from GEOSGeomTypeId in GEOS 2.2.X, which might
- * break compatibility, this issue is still under investigation.
+/** \endcond */
+* Geometry type number, used by functions returning or
+* consuming geometry types.
+* \see GEOSGeomType
+* \see GEOSGeomTypeId
 enum GEOSGeomTypes {
+    /** Point */
     GEOS_POINT,
+    /** Linestring */
     GEOS_LINESTRING,
+    /** Linear ring, used within polygons */
     GEOS_LINEARRING,
+    /** Polygon */
     GEOS_POLYGON,
+    /** Multipoint, a homogeneous collection of points */
     GEOS_MULTIPOINT,
+    /** Multilinestring, a homogeneous collection of linestrings */
     GEOS_MULTILINESTRING,
+    /** Multipolygon, a homogeneous collection of polygons */
     GEOS_MULTIPOLYGON,
+    /** Geometry collection, a heterogeneous collection of geometry */
     GEOS_GEOMETRYCOLLECTION
-/* Byte orders exposed via the C API */
+* Well-known binary byte orders used when
+* writing to WKB.
+* \see GEOSWKBWriter_setByteOrder
 enum GEOSByteOrders {
-    GEOS_WKB_XDR = 0, /* Big Endian */
-    GEOS_WKB_NDR = 1 /* Little Endian */
+    /** Big Endian */
+    GEOS_WKB_XDR = 0,
+    /** Little Endian */
+    GEOS_WKB_NDR = 1
+* Callback function for use in spatial index search calls. Pass into
+* the query function and handle query results as the index
+* returns them.
+* \see GEOSSTRtree_query
 typedef void (*GEOSQueryCallback)(void *item, void *userdata);
-typedef int (*GEOSDistanceCallback)(const void *item1, const void* item2, double* distance, void* userdata);
- * Initialization, cleanup, version
+* Callback function for use in spatial index nearest neighbor calculations.
+* Allows custom distance to be calculated between items in the
+* index. Is passed two items, and sets the calculated distance
+* between the items into the distance pointer. Extra data for the
+* calculation can be passed via the userdata.
+* \param item1 first of the pair of items to calculate distance between
+* \param item2 second of the pair of items to calculate distance between
+* \param return distance the distance between the items here
+* \param userdata extra data for the calculation
+* \return zero if distance calculation succeeded, non-zero otherwise
+* \see GEOSSTRtree_nearest_generic
+* \see GEOSSTRtree_iterate
+typedef int (*GEOSDistanceCallback)(
+    const void* item1,
+    const void* item2,
+    double* distance,
+    void* userdata);
-#include <geos/export.h>
+/* ========== Interruption ========== */
- * Register an interruption checking callback
- * The callback will be invoked _before_ checking for
- * interruption, so can be used to request it.
+* Callback function for use in interruption. The callback will be invoked _before_ checking for
+* interruption, so can be used to request it.
+* \see GEOS_interruptRegisterCallback
+* \see GEOS_interruptRequest
+* \see GEOS_interruptCancel
 typedef void (GEOSInterruptCallback)();
-extern GEOSInterruptCallback GEOS_DLL *GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb);
-/* Request safe interruption of operations */
-extern void GEOS_DLL GEOS_interruptRequest();
-/* Cancel a pending interruption request */
-extern void GEOS_DLL GEOS_interruptCancel();
- * @deprecated in 3.5.0
- *     initialize using GEOS_init_r() and set the message handlers using
- *     GEOSContext_setNoticeHandler_r and/or GEOSContext_setErrorHandler_r
-extern GEOSContextHandle_t GEOS_DLL initGEOS_r(
-                                    GEOSMessageHandler notice_function,
-                                    GEOSMessageHandler error_function);
- * @deprecated in 3.5.0 replaced by GEOS_finish_r.
-extern void GEOS_DLL finishGEOS_r(GEOSContextHandle_t handle);
-extern GEOSContextHandle_t GEOS_DLL GEOS_init_r();
-extern void GEOS_DLL GEOS_finish_r(GEOSContextHandle_t handle);
+* Register a function to be called when processing is interrupted.
+* \param cb Callback function to invoke
+* \return the previously configured callback
+* \see GEOSInterruptCallback
+extern GEOSInterruptCallback* GEOS_DLL GEOS_interruptRegisterCallback(
+    GEOSInterruptCallback* cb);
-extern GEOSMessageHandler GEOS_DLL GEOSContext_setNoticeHandler_r(GEOSContextHandle_t extHandle,
-        GEOSMessageHandler nf);
-extern GEOSMessageHandler GEOS_DLL GEOSContext_setErrorHandler_r(GEOSContextHandle_t extHandle,
-        GEOSMessageHandler ef);
- * Sets a notice message handler on the given GEOS context.
- * @param extHandle the GEOS context
- * @param nf the message handler
- * @param userData optional user data pointer that will be passed to the message handler
- * @return the previously configured message handler or NULL if no message handler was configured
-extern GEOSMessageHandler_r GEOS_DLL GEOSContext_setNoticeMessageHandler_r(GEOSContextHandle_t extHandle,
-        GEOSMessageHandler_r nf,
-        void *userData);
- * Sets an error message handler on the given GEOS context.
- * @param ef the message handler
-extern GEOSMessageHandler_r GEOS_DLL GEOSContext_setErrorMessageHandler_r(GEOSContextHandle_t extHandle,
-        GEOSMessageHandler_r ef,
-        void *userData);
-extern const char GEOS_DLL *GEOSversion();
+* Request safe interruption of operations
+extern void GEOS_DLL GEOS_interruptRequest();
+* Cancel a pending interruption request
+extern void GEOS_DLL GEOS_interruptCancel();
- * NOTE - These functions are DEPRECATED.  Please use the new Reader and
- * writer APIS!
+/* ========== Initialization and Cleanup ========== */
-extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKT_r(GEOSContextHandle_t handle,
-                                                const char *wkt);
-extern char GEOS_DLL *GEOSGeomToWKT_r(GEOSContextHandle_t handle,
-                                      const GEOSGeometry* g);
+* Initialize a context for this thread. Pass this context into
+* your other calls of `*_r` functions.
+* \return a GEOS context for this thread
+extern GEOSContextHandle_t GEOS_DLL GEOS_init_r();
- * Specify whether output WKB should be 2d or 3d.
- * Return previously set number of dimensions.
+* Free the memory associated with a \ref GEOSContextHandle_t
+* when you are finished calling GEOS functions.
+* \param handle to be freed
+extern void GEOS_DLL GEOS_finish_r(GEOSContextHandle_t handle);
-extern int GEOS_DLL GEOS_getWKBOutputDims_r(GEOSContextHandle_t handle);
-extern int GEOS_DLL GEOS_setWKBOutputDims_r(GEOSContextHandle_t handle,
-                                            int newDims);
+* Set the notice handler callback function for run-time notice messages.
+* \param extHandle the context returned by \ref GEOS_init_r.
+* \param nf the handler callback
+* \return the previously configured message handler or NULL if no message handler was configured
+extern GEOSMessageHandler GEOS_DLL GEOSContext_setNoticeHandler_r(
+    GEOSContextHandle_t extHandle,
+    GEOSMessageHandler nf);
- * Specify whether the WKB byte order is big or little endian.
- * The return value is the previous byte order.
-extern int GEOS_DLL GEOS_getWKBByteOrder_r(GEOSContextHandle_t handle);
-extern int GEOS_DLL GEOS_setWKBByteOrder_r(GEOSContextHandle_t handle,
-                                           int byteOrder);
+* Set the notice handler callback function for run-time error messages.
+* \param extHandle the GEOS context from \ref GEOS_init_r
+* \param ef the handler callback
+extern GEOSMessageHandler GEOS_DLL GEOSContext_setErrorHandler_r(
+    GEOSMessageHandler ef);
-extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKB_buf_r(GEOSContextHandle_t handle,
-                                                    const unsigned char *wkb,
-                                                    size_t size);
-extern unsigned char GEOS_DLL *GEOSGeomToWKB_buf_r(GEOSContextHandle_t handle,
-                                                   const GEOSGeometry* g,
-                                                   size_t *size);
+* Sets a notice message handler on the given GEOS context.
+* \param nf the message handler
+* \param userData optional user data pointer that will be passed to the message handler
+extern GEOSMessageHandler_r GEOS_DLL GEOSContext_setNoticeMessageHandler_r(
+    GEOSMessageHandler_r nf,
+    void *userData);
-extern GEOSGeometry GEOS_DLL *GEOSGeomFromHEX_buf_r(GEOSContextHandle_t handle,
-                                                    const unsigned char *hex,
-                                                    size_t size);
-extern unsigned char GEOS_DLL *GEOSGeomToHEX_buf_r(GEOSContextHandle_t handle,
-                                                   size_t *size);
+* Sets an error message handler on the given GEOS context.
+* \param ef the message handler
+extern GEOSMessageHandler_r GEOS_DLL GEOSContext_setErrorMessageHandler_r(
+    GEOSMessageHandler_r ef,
+    void *userData);
- * Coordinate Sequence functions
+/* ========== Coordinate Sequence functions ========== */
- * Create a Coordinate sequence with ``size'' coordinates
- * of ``dims'' dimensions.
- * Return NULL on exception.
+/** \see GEOSCoordSeq_create */
 extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_create_r(
-                                                GEOSContextHandle_t handle,
-                                                unsigned int size,
-                                                unsigned int dims);
+    GEOSContextHandle_t handle,
+    unsigned int size,
+    unsigned int dims);
- * Clone a Coordinate Sequence.
+/** \see GEOSCoordSeq_clone */
 extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_clone_r(
-                                                const GEOSCoordSequence* s);
- * Destroy a Coordinate Sequence.
-extern void GEOS_DLL GEOSCoordSeq_destroy_r(GEOSContextHandle_t handle,
-                                            GEOSCoordSequence* s);
- * Set ordinate values in a Coordinate Sequence.
- * Return 0 on exception.
-extern int GEOS_DLL GEOSCoordSeq_setX_r(GEOSContextHandle_t handle,
-                                        GEOSCoordSequence* s, unsigned int idx,
-                                        double val);
-extern int GEOS_DLL GEOSCoordSeq_setY_r(GEOSContextHandle_t handle,
-                                        double val);
-extern int GEOS_DLL GEOSCoordSeq_setZ_r(GEOSContextHandle_t handle,
-                                        double val);
-extern int GEOS_DLL GEOSCoordSeq_setXY_r(GEOSContextHandle_t handle,
-                                        double x, double y);
-extern int GEOS_DLL GEOSCoordSeq_setXYZ_r(GEOSContextHandle_t handle,
-                                        double x, double y, double z);
-extern int GEOS_DLL GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t handle,
-                                               unsigned int idx,
-                                               unsigned int dim, double val);
- * Get ordinate values from a Coordinate Sequence.
-extern int GEOS_DLL GEOSCoordSeq_getX_r(GEOSContextHandle_t handle,
-                                        const GEOSCoordSequence* s,
-                                        unsigned int idx, double *val);
-extern int GEOS_DLL GEOSCoordSeq_getY_r(GEOSContextHandle_t handle,
-extern int GEOS_DLL GEOSCoordSeq_getZ_r(GEOSContextHandle_t handle,
-extern int GEOS_DLL GEOSCoordSeq_getXY_r(GEOSContextHandle_t handle,
-                                         unsigned int idx, double *x, double *y);
-extern int GEOS_DLL GEOSCoordSeq_getXYZ_r(GEOSContextHandle_t handle,
-                                          unsigned int idx, double *x, double *y, double *z);
-extern int GEOS_DLL GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t handle,
-                                               unsigned int idx,
-                                               unsigned int dim, double *val);
- * Get size and dimensions info from a Coordinate Sequence.
-extern int GEOS_DLL GEOSCoordSeq_getSize_r(GEOSContextHandle_t handle,
-                                           unsigned int *size);
-extern int GEOS_DLL GEOSCoordSeq_getDimensions_r(GEOSContextHandle_t handle,
-                                                 unsigned int *dims);
- * Check orientation of a CoordinateSequence and set 'is_ccw' to 1
- * if it has counter-clockwise orientation, 0 otherwise.
- * Return 0 on exception, 1 on success.
-extern int GEOS_DLL GEOSCoordSeq_isCCW_r(GEOSContextHandle_t handle,
-                                         char* is_ccw);
+    const GEOSCoordSequence* s);
+/** \see GEOSCoordSeq_destroy */
+extern void GEOS_DLL GEOSCoordSeq_destroy_r(
+    GEOSCoordSequence* s);
+/** \see GEOSCoordSeq_setX */
+extern int GEOS_DLL GEOSCoordSeq_setX_r(
+    GEOSCoordSequence* s, unsigned int idx,
+    double val);
+/** \see GEOSCoordSeq_setY */
+extern int GEOS_DLL GEOSCoordSeq_setY_r(
+    double val);
+/** \see GEOSCoordSeq_setZ */
+extern int GEOS_DLL GEOSCoordSeq_setZ_r(
+    double val);
+/** \see GEOSCoordSeq_setXY */
+extern int GEOS_DLL GEOSCoordSeq_setXY_r(
+    double x, double y);
+/** \see GEOSCoordSeq_setXYZ */
+extern int GEOS_DLL GEOSCoordSeq_setXYZ_r(
+    double x, double y, double z);
+/** \see GEOSCoordSeq_setOrdinate */
+extern int GEOS_DLL GEOSCoordSeq_setOrdinate_r(
+    unsigned int idx,
+    unsigned int dim, double val);
+/** \see GEOSCoordSeq_getX */
+extern int GEOS_DLL GEOSCoordSeq_getX_r(
+    const GEOSCoordSequence* s,
+    unsigned int idx, double *val);
- *  Linear referencing functions -- there are more, but these are
- *  probably sufficient for most purposes
+/** \see GEOSCoordSeq_getY */
+extern int GEOS_DLL GEOSCoordSeq_getY_r(
- * GEOSGeometry ownership is retained by caller
+/** \see GEOSCoordSeq_getZ */
+extern int GEOS_DLL GEOSCoordSeq_getZ_r(
+/** \see GEOSCoordSeq_getXY */
+extern int GEOS_DLL GEOSCoordSeq_getXY_r(
+    unsigned int idx,
+    double *x, double *y);
+/** \see GEOSCoordSeq_getXYZ */
+extern int GEOS_DLL GEOSCoordSeq_getXYZ_r(
+    unsigned int idx,
+    double *x, double *y, double *z);
+/** \see GEOSCoordSeq_getOrdinate */
+extern int GEOS_DLL GEOSCoordSeq_getOrdinate_r(
+    unsigned int idx,
+    unsigned int dim, double *val);
+/** \see GEOSCoordSeq_getSize */
+extern int GEOS_DLL GEOSCoordSeq_getSize_r(
+    unsigned int *size);
-/* Return distance of point 'p' projected on 'g' from origin
- * of 'g'. Geometry 'g' must be a lineal geometry.
- * Return -1 on exception*/
-extern double GEOS_DLL GEOSProject_r(GEOSContextHandle_t handle,
-                                     const GEOSGeometry *g,
-                                     const GEOSGeometry *p);
+/** \see GEOSCoordSeq_getDimensions */
+extern int GEOS_DLL GEOSCoordSeq_getDimensions_r(
+    unsigned int *dims);
-/* Return closest point to given distance within geometry
- * Geometry must be a LineString */
-extern GEOSGeometry GEOS_DLL *GEOSInterpolate_r(GEOSContextHandle_t handle,
-                                                double d);
+/** \see GEOSCoordSeq_isCCW */
+extern int GEOS_DLL GEOSCoordSeq_isCCW_r(
+    char* is_ccw);
+/* ========= Linear referencing functions ========= */
+/** \see GEOSProject */
+extern double GEOS_DLL GEOSProject_r(
+    const GEOSGeometry *line,
+    const GEOSGeometry *point);
+/** \see GEOSInterpolate */
+extern GEOSGeometry GEOS_DLL *GEOSInterpolate_r(
+    double d);
+/** \see GEOSProjectNormalized */
+extern double GEOS_DLL GEOSProjectNormalized_r(
+    const GEOSGeometry *g,
+    const GEOSGeometry *p);
+/** \see GEOSInterpolateNormalized */
+extern GEOSGeometry GEOS_DLL *GEOSInterpolateNormalized_r(
+    double d);
-extern double GEOS_DLL GEOSProjectNormalized_r(GEOSContextHandle_t handle,
+/* ========== Buffer related functions ========== */
-extern GEOSGeometry GEOS_DLL *GEOSInterpolateNormalized_r(
-                                                double d);
+/** \see GEOSBuffer */
+extern GEOSGeometry GEOS_DLL *GEOSBuffer_r(
+    const GEOSGeometry* g,
+    double width, int quadsegs);
- * Buffer related functions
+* Cap styles control the ends of buffered lines.
+* \see GEOSBuffer
+enum GEOSBufCapStyles {
+    /** End is rounded, with end point of original line in the centre of the round cap. */
+	GEOSBUF_CAP_ROUND = 1,
-/* @return NULL on exception */
-extern GEOSGeometry GEOS_DLL *GEOSBuffer_r(GEOSContextHandle_t handle,
-                                           double width, int quadsegs);
+    /** End is flat, with end point of original line at the end of the buffer */
+	GEOSBUF_CAP_FLAT = 2,
-enum GEOSBufCapStyles {
-	GEOSBUF_CAP_ROUND=1,
-	GEOSBUF_CAP_FLAT=2,
-	GEOSBUF_CAP_SQUARE=3
+    /** End is flat, with end point of original line in the middle of a square enclosing that point */
+	GEOSBUF_CAP_SQUARE = 3
+* Join styles control the buffer shape at bends in a line.
+* \see GEOSBuffer
 enum GEOSBufJoinStyles {
-	GEOSBUF_JOIN_ROUND=1,
-	GEOSBUF_JOIN_MITRE=2,
-	GEOSBUF_JOIN_BEVEL=3
+    * Join is rounded, essentially each line is terminated
+    * in a round cap. Form round corner.
+	GEOSBUF_JOIN_ROUND = 1,
+    * Join is flat, with line between buffer edges,
+    * through the join point. Forms flat corner.
+	GEOSBUF_JOIN_MITRE = 2,
+    * Join is the point at which the two buffer edges intersect.
+    * Forms sharp corner.
+	GEOSBUF_JOIN_BEVEL = 3
-/* @return 0 on exception */
+/** \see GEOSBufferParams_create */
 extern GEOSBufferParams GEOS_DLL *GEOSBufferParams_create_r(
-                                              GEOSContextHandle_t handle);
+    GEOSContextHandle_t handle);
+/** \see GEOSBufferParams_destroy */
 extern void GEOS_DLL GEOSBufferParams_destroy_r(
-                                              GEOSBufferParams* parms);
+    GEOSBufferParams* parms);
+/** \see GEOSBufferParams_setEndCapStyle */
 extern int GEOS_DLL GEOSBufferParams_setEndCapStyle_r(
-                                              GEOSBufferParams* p,
-                                              int style);
+    GEOSBufferParams* p,
+    int style);
+/** \see GEOSBufferParams_setJoinStyle */
 extern int GEOS_DLL GEOSBufferParams_setJoinStyle_r(
-                                              int joinStyle);
+    int joinStyle);
+/** \see GEOSBufferParams_setMitreLimit */
 extern int GEOS_DLL GEOSBufferParams_setMitreLimit_r(
-                                              double mitreLimit);
+    double mitreLimit);
+/** \see GEOSBufferParams_setQuadrantSegments */
 extern int GEOS_DLL GEOSBufferParams_setQuadrantSegments_r(
-                                              int quadSegs);
+    int quadSegs);
-/* @param singleSided: 1 for single sided, 0 otherwise */
+/** \see GEOSBufferParams_setSingleSided */
 extern int GEOS_DLL GEOSBufferParams_setSingleSided_r(
-                                              int singleSided);
+    int singleSided);
+/** \see GEOSBufferWithParams */
 extern GEOSGeometry GEOS_DLL *GEOSBufferWithParams_r(
-                                              const GEOSBufferParams* p,
-                                              double width);
-/* These functions return NULL on exception. */
-extern GEOSGeometry GEOS_DLL *GEOSBufferWithStyle_r(GEOSContextHandle_t handle,
-	const GEOSGeometry* g, double width, int quadsegs, int endCapStyle,
+    const GEOSBufferParams* p,
+    double width);
+/** \see GEOSBufferWithStyle */
+extern GEOSGeometry GEOS_DLL *GEOSBufferWithStyle_r(
+    double width, int quadsegs, int endCapStyle,
 	int joinStyle, double mitreLimit);
-/* These functions return NULL on exception. Only LINESTRINGs are accepted. */
-/* @deprecated in 3.3.0: use GEOSOffsetCurve instead */
-extern GEOSGeometry GEOS_DLL *GEOSSingleSidedBuffer_r(
-	int joinStyle, double mitreLimit, int leftSide);
- * Only LINESTRINGs are accepted.
- * @param width : offset distance.
- *                negative for right side offset.
- *                positive for left side offset.
- * @return NULL on exception
-extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve_r(GEOSContextHandle_t handle,
+/** \see GEOSOffsetCurve */
+extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve_r(
- * Geometry Constructors.
- * GEOSCoordSequence* arguments will become ownership of the returned object.
- * All functions return NULL on exception.
+/* ========= Geometry Constructors ========= */
+/** \see GEOSGeom_createPoint */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createPoint_r(
+/** \see GEOSGeom_createPointFromXY */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createPointFromXY_r(
-                                       double x,
-                                       double y);
+/** \see GEOSGeom_createEmptyPoint */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPoint_r(
+/** \see GEOSGeom_createLinearRing */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing_r(
+/** \see GEOSGeom_createLineString */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createLineString_r(
+/** \see GEOSGeom_createEmptyLineString */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyLineString_r(
- * Second argument is an array of GEOSGeometry* objects.
- * The caller remains owner of the array, but pointed-to
- * objects become ownership of the returned GEOSGeometry.
+/** \see GEOSGeom_createEmptyPolygon */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPolygon_r(
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon_r(
-                                       GEOSGeometry* shell,
-                                       GEOSGeometry** holes,
-                                       unsigned int nholes);
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection_r(
-                                       GEOSContextHandle_t handle, int type,
-                                       GEOSGeometry* *geoms,
-                                       unsigned int ngeoms);
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCollection_r(
-                                       GEOSContextHandle_t handle, int type);
-extern GEOSGeometry GEOS_DLL *GEOSGeom_clone_r(GEOSContextHandle_t handle,
- * Memory management
-extern void GEOS_DLL GEOSGeom_destroy_r(GEOSContextHandle_t handle,
-                                        GEOSGeometry* g);
- * Topology operations - return NULL on exception.
-extern GEOSGeometry GEOS_DLL *GEOSEnvelope_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSIntersection_r(GEOSContextHandle_t handle,
-                                                 const GEOSGeometry* g1,
-                                                 const GEOSGeometry* g2);
-extern GEOSGeometry GEOS_DLL *GEOSIntersectionPrec_r(GEOSContextHandle_t handle,
-                                                 const GEOSGeometry* g2,
-                                                 double gridSize);
-extern GEOSGeometry GEOS_DLL *GEOSConvexHull_r(GEOSContextHandle_t handle,
-/* Returns the minimum rotated rectangular POLYGON which encloses the input geometry. The rectangle
- * has width equal to the minimum diameter, and a longer length. If the convex hill of the input is
- * degenerate (a line or point) a LINESTRING or POINT is returned. The minimum rotated rectangle can
- * be used as an extremely generalized representation for the given geometry.
-extern GEOSGeometry GEOS_DLL *GEOSMinimumRotatedRectangle_r(GEOSContextHandle_t handle,
+/** \see GEOSGeom_createPolygon */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon_r(
+    GEOSGeometry* shell,
+    GEOSGeometry** holes,
+    unsigned int nholes);
-extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle_r(GEOSContextHandle_t handle, const GEOSGeometry* g, double tolerance);
-extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle_r(GEOSContextHandle_t handle, const GEOSGeometry* g, const GEOSGeometry* boundary, double tolerance);
+/** \see GEOSGeom_createCollection */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection_r(
+    int type,
+    GEOSGeometry* *geoms,
+    unsigned int ngeoms);
-/* Returns a LINESTRING geometry which represents the minimum diameter of the geometry.
- * The minimum diameter is defined to be the width of the smallest band that
- * contains the geometry, where a band is a strip of the plane defined
- * by two parallel lines. This can be thought of as the smallest hole that the geometry
- * can be moved through, with a single rotation.
-extern GEOSGeometry GEOS_DLL *GEOSMinimumWidth_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSMinimumClearanceLine_r(GEOSContextHandle_t handle,
-extern int GEOS_DLL GEOSMinimumClearance_r(GEOSContextHandle_t handle,
-                                           double* distance);
-extern GEOSGeometry GEOS_DLL *GEOSDifference_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSDifferencePrec_r(GEOSContextHandle_t handle,
-                                                   double gridSize);
-extern GEOSGeometry GEOS_DLL *GEOSSymDifference_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSSymDifferencePrec_r(GEOSContextHandle_t handle,
-                                                      double gridSize);
-extern GEOSGeometry GEOS_DLL *GEOSBoundary_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSUnion_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSUnionPrec_r(GEOSContextHandle_t handle,
-                                              double gridSize);
-extern GEOSGeometry GEOS_DLL *GEOSUnaryUnion_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSUnaryUnionPrec_r(GEOSContextHandle_t handle,
-                                          double gridSize);
-/* GEOSCoverageUnion is an optimized union algorithm for polygonal inputs that are correctly
- * noded and do not overlap. It will not generate an error (return NULL) for inputs that
- * do not satisfy this constraint. */
-extern GEOSGeometry GEOS_DLL *GEOSCoverageUnion_r(GEOSContextHandle_t handle,
-/* @deprecated in 3.3.0: use GEOSUnaryUnion_r instead */
-extern GEOSGeometry GEOS_DLL *GEOSUnionCascaded_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSGetCentroid_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSMinimumBoundingCircle_r(GEOSContextHandle_t handle,
-                                                const GEOSGeometry* g, double* radius,
-                                                GEOSGeometry** center);
-extern GEOSGeometry GEOS_DLL *GEOSNode_r(GEOSContextHandle_t handle,
-/* Fast, non-robust intersection between an arbitrary geometry and
- * a rectangle. The returned geometry may be invalid. */
-extern GEOSGeometry GEOS_DLL *GEOSClipByRect_r(GEOSContextHandle_t handle,
-                                                 double xmin, double ymin,
-                                                 double xmax, double ymax);
+/** \see GEOSGeom_createEmptyCollection */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCollection_r(
+    GEOSContextHandle_t handle, int type);
+/** \see GEOSGeom_clone */
+extern GEOSGeometry GEOS_DLL *GEOSGeom_clone_r(
+    const GEOSGeometry* g);
+/* ========= Memory management ========= */
+/** \see GEOSGeom_destroy */
+extern void GEOS_DLL GEOSGeom_destroy_r(
+    GEOSGeometry* g);
+/* ========= Topology Operations ========= */
+/** \see GEOSEnvelope */
+extern GEOSGeometry GEOS_DLL *GEOSEnvelope_r(
+/** \see GEOSIntersection */
+extern GEOSGeometry GEOS_DLL *GEOSIntersection_r(
+    const GEOSGeometry* g1,
+    const GEOSGeometry* g2);
+/** \see GEOSIntersectionPrec */
+extern GEOSGeometry GEOS_DLL *GEOSIntersectionPrec_r(
+    const GEOSGeometry* g2,
+    double gridSize);
+/** \see GEOSConvexHull */
+extern GEOSGeometry GEOS_DLL *GEOSConvexHull_r(
+/** \see GEOSMinimumRotatedRectangle */
+extern GEOSGeometry GEOS_DLL *GEOSMinimumRotatedRectangle_r(
+/** \see GEOSMaximumInscribedCircle */
+extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle_r(
+    double tolerance);
- * all arguments remain ownership of the caller
- * (both Geometries and pointers)
- * Polygonizes a set of Geometries which contain linework that
- * represents the edges of a planar graph.
- * All types of Geometry are accepted as input; the constituent
- * linework is extracted as the edges to be polygonized.
- * The edges must be correctly noded; that is, they must only meet
- * at their endpoints. Polygonization will accept incorrectly noded
- * input but will not form polygons from non-noded edges, and reports
- * them as errors.
- * The Polygonizer reports the follow kinds of errors:
- * - Dangles - edges which have one or both ends which are
- *   not incident on another edge endpoint
- * - Cut Edges - edges which are connected at both ends but
- *   which do not form part of a polygon
- * - Invalid Ring Lines - edges which form rings which are invalid
- *   (e.g. the component lines contain a self-intersection)
- * Errors are reported to output parameters "cuts", "dangles" and
- * "invalid" (if not-null). Formed polygons are returned as a
- * collection. NULL is returned on exception. All returned
- * geometries must be destroyed by caller.
- * The GEOSPolygonize_valid_r variant allows extracting only polygons
- * which form a valid polygonal result. The set of extracted polygons
- * is guaranteed to be edge-disjoint. This is useful when it is known
- * that the input lines form a valid polygonal geometry (which may
- * include holes or nested polygons).
+/** \see GEOSLargestEmptyCircle */
+extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle_r(
+    const GEOSGeometry* boundary,
-extern GEOSGeometry GEOS_DLL *GEOSPolygonize_r(GEOSContextHandle_t handle,
-                              const GEOSGeometry *const geoms[],
-extern GEOSGeometry GEOS_DLL *GEOSPolygonize_valid_r(GEOSContextHandle_t handle,
-                                                     unsigned int ngems);
+/** \see GEOSMinimumWidth */
+extern GEOSGeometry GEOS_DLL *GEOSMinimumWidth_r(
+/** \see GEOSMinimumClearanceLine */
+extern GEOSGeometry GEOS_DLL *GEOSMinimumClearanceLine_r(
+/** \see GEOSMinimumClearance */
+extern int GEOS_DLL GEOSMinimumClearance_r(
+    double* distance);
+/** \see GEOSDifference */
+extern GEOSGeometry GEOS_DLL *GEOSDifference_r(
+/** \see GEOSDifferencePrec */
+extern GEOSGeometry GEOS_DLL *GEOSDifferencePrec_r(
+    double gridSize);
+/** \see GEOSSymDifference */
+extern GEOSGeometry GEOS_DLL *GEOSSymDifference_r(
+/** \see GEOSSymDifferencePrec */
+extern GEOSGeometry GEOS_DLL *GEOSSymDifferencePrec_r(
+    double gridSize);
+/** \see GEOSBoundary */
+extern GEOSGeometry GEOS_DLL *GEOSBoundary_r(
+/** \see GEOSUnion */
+extern GEOSGeometry GEOS_DLL *GEOSUnion_r(
+/** \see GEOSUnionPrec */
+extern GEOSGeometry GEOS_DLL *GEOSUnionPrec_r(
+    double gridSize);
+/** \see GEOSUnaryUnion */
+extern GEOSGeometry GEOS_DLL *GEOSUnaryUnion_r(
+/** \see GEOSUnaryUnionPrec */
+extern GEOSGeometry GEOS_DLL *GEOSUnaryUnionPrec_r(
+    double gridSize);
+/** \see GEOSCoverageUnion */
+extern GEOSGeometry GEOS_DLL *GEOSCoverageUnion_r(
+/** \see GEOSPointOnSurface */
+extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface_r(
+/** \see GEOSGetCentroid */
+extern GEOSGeometry GEOS_DLL *GEOSGetCentroid_r(
+/** \see GEOSMinimumBoundingCircle */
+extern GEOSGeometry GEOS_DLL *GEOSMinimumBoundingCircle_r(
+    double* radius,
+    GEOSGeometry** center);
+/** \see GEOSNode */
+extern GEOSGeometry GEOS_DLL *GEOSNode_r(
+/** \see GEOSClipByRect */
+extern GEOSGeometry GEOS_DLL *GEOSClipByRect_r(
+    double xmin, double ymin,
+    double xmax, double ymax);
+/** \see GEOSPolygonize */
+extern GEOSGeometry GEOS_DLL *GEOSPolygonize_r(
+    const GEOSGeometry *const geoms[],
+/** \see GEOSPolygonize_valid */
+extern GEOSGeometry GEOS_DLL *GEOSPolygonize_valid_r(
+    unsigned int ngems);
+/** \see GEOSPolygonizer_getCutEdges */
 extern GEOSGeometry GEOS_DLL *GEOSPolygonizer_getCutEdges_r(
-                              const GEOSGeometry * const geoms[],
-extern GEOSGeometry GEOS_DLL *GEOSPolygonize_full_r(GEOSContextHandle_t handle,
-                              const GEOSGeometry* input, GEOSGeometry** cuts,
-                              GEOSGeometry** dangles, GEOSGeometry** invalidRings);
+    const GEOSGeometry * const geoms[],
+/** \see GEOSPolygonize_full */
+extern GEOSGeometry GEOS_DLL *GEOSPolygonize_full_r(
+    const GEOSGeometry* input,
+    GEOSGeometry** cuts,
+    GEOSGeometry** dangles,
+    GEOSGeometry** invalidRings);
+/** \see GEOSBuildArea */
 extern GEOSGeometry GEOS_DLL *GEOSBuildArea_r(
-extern GEOSGeometry GEOS_DLL *GEOSLineMerge_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSReverse_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSSimplify_r(GEOSContextHandle_t handle,
-                                             double tolerance);
+/** \see GEOSLineMerge */
+extern GEOSGeometry GEOS_DLL *GEOSLineMerge_r(
+/** \see GEOSReverse */
+extern GEOSGeometry GEOS_DLL *GEOSReverse_r(
+/** \see GEOSSimplify */
+extern GEOSGeometry GEOS_DLL *GEOSSimplify_r(
+/** \see GEOSTopologyPreserveSimplify */
 extern GEOSGeometry GEOS_DLL *GEOSTopologyPreserveSimplify_r(
-                              const GEOSGeometry* g, double tolerance);
+    const GEOSGeometry* g, double tolerance);
- * Return all distinct vertices of input geometry as a MULTIPOINT.
- * Note that only 2 dimensions of the vertices are considered when
- * testing for equality.
+/** \see GEOSGeom_extractUniquePoints */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_extractUniquePoints_r(
- * Find paths shared between the two given lineal geometries.
- * Returns a GEOMETRYCOLLECTION having two elements:
- * - first element is a MULTILINESTRING containing shared paths
- *   having the _same_ direction on both inputs
- * - second element is a MULTILINESTRING containing shared paths
- *   having the _opposite_ direction on the two inputs
- * Returns NULL on exception
-extern GEOSGeometry GEOS_DLL *GEOSSharedPaths_r(GEOSContextHandle_t handle,
-  const GEOSGeometry* g1, const GEOSGeometry* g2);
- * Snap first geometry on to second with given tolerance
- * Returns a newly allocated geometry, or NULL on exception
-extern GEOSGeometry GEOS_DLL *GEOSSnap_r(GEOSContextHandle_t handle,
-  const GEOSGeometry* g1, const GEOSGeometry* g2, double tolerance);
+/** \see GEOSSharedPaths */
+extern GEOSGeometry GEOS_DLL *GEOSSharedPaths_r(
+/** \see GEOSSnap */
+extern GEOSGeometry GEOS_DLL *GEOSSnap_r(
- * Return a Delaunay triangulation of the vertex of the given geometry
- * @param g the input geometry whose vertex will be used as "sites"
- * @param tolerance optional snapping tolerance to use for improved robustness
- * @param onlyEdges if non-zero will return a MULTILINESTRING, otherwise it will
- *                  return a GEOMETRYCOLLECTION containing triangular POLYGONs.
- * @return  a newly allocated geometry, or NULL on exception
+/** \see GEOSDelaunayTriangulation */
 extern GEOSGeometry GEOS_DLL * GEOSDelaunayTriangulation_r(
-                                  double tolerance,
-                                  int onlyEdges);
+    double tolerance,
+    int onlyEdges);
- * Returns the Voronoi polygons of a set of Vertices given as input
- * @param g the input geometry whose vertex will be used as sites.
- * @param tolerance snapping tolerance to use for improved robustness
- * @param onlyEdges whether to return only edges of the Voronoi cells
- * @param env clipping envelope for the returned diagram, automatically
- *            determined if NULL.
- *            The diagram will be clipped to the larger
- *            of this envelope or an envelope surrounding the sites.
- * @return a newly allocated geometry, or NULL on exception.
+/** \see GEOSVoronoiDiagram */
 extern GEOSGeometry GEOS_DLL * GEOSVoronoiDiagram_r(
-				GEOSContextHandle_t extHandle,
-				const GEOSGeometry *env,
-				double tolerance,
-				int onlyEdges);
- * Computes the coordinate where two line segments intersect, if any
- * @param ax0 x-coordinate of first point in first segment
- * @param ay0 y-coordinate of first point in first segment
- * @param ax1 x-coordinate of second point in first segment
- * @param ay1 y-coordinate of second point in first segment
- * @param bx0 x-coordinate of first point in second segment
- * @param by0 y-coordinate of first point in second segment
- * @param bx1 x-coordinate of second point in second segment
- * @param by1 y-coordinate of second point in second segment
- * @param cx x-coordinate of intersection point
- * @param cy y-coordinate of intersection point
- * @return 0 on error, 1 on success, -1 if segments do not intersect
+    const GEOSGeometry *env,
+    double tolerance,
+    int onlyEdges);
+/** \see GEOSSegmentIntersection */
 extern int GEOS_DLL GEOSSegmentIntersection_r(
        double ax0, double ay0,
@@ -794,1036 +873,1843 @@ extern int GEOS_DLL GEOSSegmentIntersection_r(
        double bx1, double by1,
        double* cx, double* cy);
- *  Binary predicates - return 2 on exception, 1 on true, 0 on false
+/* ========= Binary predicates ========= */
+/** \see GEOSDisjoint */
+extern char GEOS_DLL GEOSDisjoint_r(
+/** \see GEOSTouches */
+extern char GEOS_DLL GEOSTouches_r(
+/** \see GEOSIntersects */
+extern char GEOS_DLL GEOSIntersects_r(
+/** \see GEOSCrosses */
+extern char GEOS_DLL GEOSCrosses_r(
+/** \see GEOSWithin */
+extern char GEOS_DLL GEOSWithin_r(
+/** \see GEOSContains */
+extern char GEOS_DLL GEOSContains_r(
+/** \see GEOSOverlaps */
+extern char GEOS_DLL GEOSOverlaps_r(
+/** \see GEOSEquals */
+extern char GEOS_DLL GEOSEquals_r(
+/** \see GEOSEqualsExact */
+extern char GEOS_DLL GEOSEqualsExact_r(
-extern char GEOS_DLL GEOSDisjoint_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSTouches_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSIntersects_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSCrosses_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSWithin_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSContains_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSOverlaps_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSEquals_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSEqualsExact_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSCovers_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSCoveredBy_r(GEOSContextHandle_t handle,
+/** \see GEOSCovers */
+extern char GEOS_DLL GEOSCovers_r(
- *  Prepared Geometry Binary predicates - return 2 on exception, 1 on true, 0 on false
+/** \see GEOSCoveredBy */
+extern char GEOS_DLL GEOSCoveredBy_r(
+/* ========= Prepared Geometry Binary Predicates ========== */
+/** \see GEOSPrepare */
 extern const GEOSPreparedGeometry GEOS_DLL *GEOSPrepare_r(
-extern void GEOS_DLL GEOSPreparedGeom_destroy_r(GEOSContextHandle_t handle,
-                                                const GEOSPreparedGeometry* g);
-extern char GEOS_DLL GEOSPreparedContains_r(GEOSContextHandle_t handle,
-                                            const GEOSPreparedGeometry* pg1,
-extern char GEOS_DLL GEOSPreparedContainsProperly_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSPreparedCoveredBy_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSPreparedCovers_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSPreparedCrosses_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSPreparedDisjoint_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSPreparedIntersects_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSPreparedOverlaps_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSPreparedTouches_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSPreparedWithin_r(GEOSContextHandle_t handle,
-/* Return 0 on exception, the closest points of the two geometries otherwise.
- * The first point comes from pg1 geometry and the second point comes from g2.
+/** \see GEOSPreparedGeom_destroy */
+extern void GEOS_DLL GEOSPreparedGeom_destroy_r(
+    const GEOSPreparedGeometry* g);
+/** \see GEOSPreparedContains */
+extern char GEOS_DLL GEOSPreparedContains_r(
+    const GEOSPreparedGeometry* pg1,
+/** \see GEOSPreparedContainsProperly */
+extern char GEOS_DLL GEOSPreparedContainsProperly_r(
+/** \see GEOSPreparedCoveredBy */
+extern char GEOS_DLL GEOSPreparedCoveredBy_r(
+/** \see GEOSPreparedCovers */
+extern char GEOS_DLL GEOSPreparedCovers_r(
+/** \see GEOSPreparedCrosses */
+extern char GEOS_DLL GEOSPreparedCrosses_r(
+/** \see GEOSPreparedDisjoint */
+extern char GEOS_DLL GEOSPreparedDisjoint_r(
+/** \see GEOSPreparedIntersects */
+extern char GEOS_DLL GEOSPreparedIntersects_r(
+/** \see GEOSPreparedOverlaps */
+extern char GEOS_DLL GEOSPreparedOverlaps_r(
+/** \see GEOSPreparedTouches */
+extern char GEOS_DLL GEOSPreparedTouches_r(
+/** \see GEOSPreparedWithin */
+extern char GEOS_DLL GEOSPreparedWithin_r(
+/** \see GEOSPreparedNearestPoints */
 extern GEOSCoordSequence GEOS_DLL *GEOSPreparedNearestPoints_r(
+/** \see GEOSPreparedDistance */
 extern int GEOS_DLL GEOSPreparedDistance_r(
-                                const GEOSGeometry* g2, double *dist);
- *  STRtree functions
+    const GEOSGeometry* g2, double *dist);
+/* ========== STRtree ========== */
+/** \see GEOSSTRtree_create */
 extern GEOSSTRtree GEOS_DLL *GEOSSTRtree_create_r(
-                                    size_t nodeCapacity);
-extern void GEOS_DLL GEOSSTRtree_insert_r(GEOSContextHandle_t handle,
-                                          GEOSSTRtree *tree,
-                                          void *item);
-extern void GEOS_DLL GEOSSTRtree_query_r(GEOSContextHandle_t handle,
-                                         GEOSQueryCallback callback,
-                                         void *userdata);
-extern const GEOSGeometry GEOS_DLL *GEOSSTRtree_nearest_r(GEOSContextHandle_t handle,
-                                                  const GEOSGeometry* geom);
-extern const void GEOS_DLL *GEOSSTRtree_nearest_generic_r(GEOSContextHandle_t handle,
-                                                          const void* item,
-                                                          const GEOSGeometry* itemEnvelope,
-                                                          GEOSDistanceCallback distancefn,
-                                                          void* userdata);
-extern void GEOS_DLL GEOSSTRtree_iterate_r(GEOSContextHandle_t handle,
-                                       void *userdata);
-extern char GEOS_DLL GEOSSTRtree_remove_r(GEOSContextHandle_t handle,
-                                          void *item);
-extern void GEOS_DLL GEOSSTRtree_destroy_r(GEOSContextHandle_t handle,
-                                           GEOSSTRtree *tree);
- *  Unary predicate - return 2 on exception, 1 on true, 0 on false
-extern char GEOS_DLL GEOSisEmpty_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSisSimple_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSisRing_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSHasZ_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSisClosed_r(GEOSContextHandle_t handle,
-                                const GEOSGeometry *g);
+    size_t nodeCapacity);
+/** \see GEOSSTRtree_insert */
+extern void GEOS_DLL GEOSSTRtree_insert_r(
+    GEOSSTRtree *tree,
+    void *item);
+/** \see GEOSSTRtree_query */
+extern void GEOS_DLL GEOSSTRtree_query_r(
+    GEOSQueryCallback callback,
+    void *userdata);
+/** \see GEOSSTRtree_nearest */
+extern const GEOSGeometry GEOS_DLL *GEOSSTRtree_nearest_r(
+    const GEOSGeometry* geom);
+/** \see GEOSSTRtree_nearest_generic */
+extern const void GEOS_DLL *GEOSSTRtree_nearest_generic_r(
+    const void* item,
+    const GEOSGeometry* itemEnvelope,
+    GEOSDistanceCallback distancefn,
+    void* userdata);
+/** \see GEOSSTRtree_iterate */
+extern void GEOS_DLL GEOSSTRtree_iterate_r(
+    void *userdata);
+/** \see GEOSSTRtree_remove */
+extern char GEOS_DLL GEOSSTRtree_remove_r(
+    void *item);
+/** \see GEOSSTRtree_destroy */
+extern void GEOS_DLL GEOSSTRtree_destroy_r(
+    GEOSSTRtree *tree);
+/* ========= Unary predicate ========= */
+/** \see GEOSisEmpty */
+extern char GEOS_DLL GEOSisEmpty_r(
+/** \see GEOSisSimple */
+extern char GEOS_DLL GEOSisSimple_r(
+/** \see GEOSisRing */
+extern char GEOS_DLL GEOSisRing_r(
+/** \see GEOSHasZ */
+extern char GEOS_DLL GEOSHasZ_r(
+/** \see GEOSisClosed */
+extern char GEOS_DLL GEOSisClosed_r(
+    const GEOSGeometry *g);
+/* ========== Dimensionally Extended 9 Intersection Model ========== */
- *  Dimensionally Extended 9 Intersection Model related
-/* These are for use with GEOSRelateBoundaryNodeRule (flags param) */
+* Controls the behavior of the result of GEOSRelate when returning
+* DE9IM results for two geometries.
 enum GEOSRelateBoundaryNodeRules {
-	/* MOD2 and OGC are the same rule, and is the default
-	 * used by GEOSRelatePattern
-	GEOSRELATE_BNR_MOD2=1,
-	GEOSRELATE_BNR_OGC=1,
-	GEOSRELATE_BNR_ENDPOINT=2,
-	GEOSRELATE_BNR_MULTIVALENT_ENDPOINT=3,
-	GEOSRELATE_BNR_MONOVALENT_ENDPOINT=4
+    /** See geos::algorithm::BoundaryNodeRule::getBoundaryRuleMod2() */
+    GEOSRELATE_BNR_MOD2 = 1,
+    /** Same as \ref GEOSRELATE_BNR_MOD2 */
+    GEOSRELATE_BNR_OGC = 1,
+    /** See geos::algorithm::BoundaryNodeRule::getBoundaryEndPoint() */
+	GEOSRELATE_BNR_ENDPOINT = 2,
+    /** See geos::algorithm::BoundaryNodeRule::getBoundaryMultivalentEndPoint() */
+	GEOSRELATE_BNR_MULTIVALENT_ENDPOINT = 3,
+    /** See geos::algorithm::BoundaryNodeRule::getBoundaryMonovalentEndPoint() */
+	GEOSRELATE_BNR_MONOVALENT_ENDPOINT = 4
-/* return 2 on exception, 1 on true, 0 on false */
-extern char GEOS_DLL GEOSRelatePattern_r(GEOSContextHandle_t handle,
-                                         const char *pat);
-/* return NULL on exception, a string to GEOSFree otherwise */
-extern char GEOS_DLL *GEOSRelate_r(GEOSContextHandle_t handle,
-extern char GEOS_DLL GEOSRelatePatternMatch_r(GEOSContextHandle_t handle,
-                                         const char *mat,
-                                         const char *pat);
-extern char GEOS_DLL *GEOSRelateBoundaryNodeRule_r(GEOSContextHandle_t handle,
-                                                   int bnr);
- *  Validity checking
-/* These are for use with GEOSisValidDetail (flags param) */
-enum GEOSValidFlags {
-	GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE=1
+/** \see GEOSRelatePattern */
+extern char GEOS_DLL GEOSRelatePattern_r(
+    const char *pat);
+/** \see GEOSRelate */
+extern char GEOS_DLL *GEOSRelate_r(
+/** \see GEOSRelatePatternMatch */
+extern char GEOS_DLL GEOSRelatePatternMatch_r(
+    const char *mat,
+    const char *pat);
+/** \see GEOSRelateBoundaryNodeRule */
+extern char GEOS_DLL *GEOSRelateBoundaryNodeRule_r(
+    int bnr);
+/* ========= Validity checking ========= */
+/** Change behaviour of validity testing in \ref GEOSisValidDetail */
+enum GEOSValidFlags
+    /** Allow self-touching rings to form a hole in a polygon. */
+	GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE = 1
-extern char GEOS_DLL GEOSisValid_r(GEOSContextHandle_t handle,
+/** \see GEOSisValid */
+extern char GEOS_DLL GEOSisValid_r(
-extern char GEOS_DLL *GEOSisValidReason_r(GEOSContextHandle_t handle,
+/** \see GEOSisValidReason */
+extern char GEOS_DLL *GEOSisValidReason_r(
- * Caller has the responsibility to destroy 'reason' (GEOSFree)
- * and 'location' (GEOSGeom_destroy) params
- * return 2 on exception, 1 when valid, 0 when invalid
-extern char GEOS_DLL GEOSisValidDetail_r(GEOSContextHandle_t handle,
-                                         int flags,
-                                         char** reason,
-                                         GEOSGeometry** location);
+/** \see GEOSisValidDetail */
+extern char GEOS_DLL GEOSisValidDetail_r(
+    int flags,
+    char** reason,
+    GEOSGeometry** location);
-extern GEOSGeometry GEOS_DLL *GEOSMakeValid_r(GEOSContextHandle_t handle,
+/** \see GEOSMakeValid */
+extern GEOSGeometry GEOS_DLL *GEOSMakeValid_r(
- *  Geometry info
+/* ========== Geometry info ========== */
+/** \see GEOSGeomType */
 /* Return NULL on exception, result must be freed by caller. */
-extern char GEOS_DLL *GEOSGeomType_r(GEOSContextHandle_t handle,
-/* Return -1 on exception */
-extern int GEOS_DLL GEOSGeomTypeId_r(GEOSContextHandle_t handle,
-/* Return 0 on exception */
-extern int GEOS_DLL GEOSGetSRID_r(GEOSContextHandle_t handle,
-extern void GEOS_DLL GEOSSetSRID_r(GEOSContextHandle_t handle,
-                                   GEOSGeometry* g, int SRID);
-extern void GEOS_DLL *GEOSGeom_getUserData_r(GEOSContextHandle_t handle,
-const GEOSGeometry* g);
-extern void GEOS_DLL GEOSGeom_setUserData_r(GEOSContextHandle_t handle,
-                                   GEOSGeometry* g, void* userData);
-/* May be called on all geometries in GEOS 3.x, returns -1 on error and 1
- * for non-multi geometries. Older GEOS versions only accept
- * GeometryCollections or Multi* geometries here, and are likely to crash
- * when fed simple geometries, so beware if you need compatibility with
- * old GEOS versions.
-extern int GEOS_DLL GEOSGetNumGeometries_r(GEOSContextHandle_t handle,
- * Returned object is a pointer to internal storage:
- * it must NOT be destroyed directly.
- * Up to GEOS 3.2.0 the input geometry must be a Collection, in
- * later version it doesn't matter (getGeometryN(0) for a single will
- * return the input).
+extern char GEOS_DLL *GEOSGeomType_r(
+/** \see GEOSGeomTypeId */
+extern int GEOS_DLL GEOSGeomTypeId_r(
+/** \see GEOSGetSRID */
+extern int GEOS_DLL GEOSGetSRID_r(
+/** \see GEOSSetSRID */
+extern void GEOS_DLL GEOSSetSRID_r(
+    GEOSGeometry* g, int SRID);
+/** \see GEOSGeom_getUserData */
+extern void GEOS_DLL *GEOSGeom_getUserData_r(
+/** \see GEOSGeom_setUserData */
+extern void GEOS_DLL GEOSGeom_setUserData_r(
+    GEOSGeometry* g,
+    void* userData);
+/** \see GEOSGetNumGeometries */
+extern int GEOS_DLL GEOSGetNumGeometries_r(
+/** \see GEOSGetGeometryN */
 extern const GEOSGeometry GEOS_DLL *GEOSGetGeometryN_r(
-                                    const GEOSGeometry* g, int n);
+    const GEOSGeometry* g, int n);
-extern int GEOS_DLL GEOSNormalize_r(GEOSContextHandle_t handle,
-                                    GEOSGeometry* g);
-/** This option causes #GEOSGeom_setPrecision_r()
-  * to not attempt at preserving the topology */
-#define GEOS_PREC_NO_TOPO         (1<<0)
-  * to retain collapsed elements */
-#define GEOS_PREC_KEEP_COLLAPSED  (1<<1)
+/** \see GEOSNormalize */
+extern int GEOS_DLL GEOSNormalize_r(
+    GEOSGeometry* g);
- * Set the geometry's precision, optionally rounding all its
- * coordinates to the precision grid (if it changes).
- * Note that operations will always be performed in the precision
- * of the geometry with higher precision (smaller "gridSize").
- * That same precision will be attached to the operation outputs.
- * @param gridSize size of the precision grid, or 0 for FLOATING
- *                 precision.
- * @param flags The bitwise OR of one of more of the
- *              @ref GEOS_PREC_NO_TOPO "precision options"
- * @retuns NULL on exception or a new GEOSGeometry object
+* Controls the behavior of GEOSGeometry_setPrecision()
+* when altering the precision of a geometry.
+enum GEOSPrecisionRules {
+    /** This option causes GEOSGeom_setPrecision_r() to not attempt at preserving the topology */
+    GEOS_PREC_NO_TOPO = 1,
+    /** This option causes GEOSGeom_setPrecision_r() to retain collapsed elements */
+    GEOS_PREC_KEEP_COLLAPSED = 2
+/** \see GEOSGeom_setPrecision */
 extern GEOSGeometry GEOS_DLL *GEOSGeom_setPrecision_r(
-                                       double gridSize, int flags);
+    double gridSize,
+    int flags);
- * Get a geometry's precision
- * @return the size of the geometry's precision grid, 0 for FLOATING
- *         precision or -1 on exception
+/** \see GEOSGeom_getPrecision */
 extern double GEOS_DLL GEOSGeom_getPrecision_r(
-extern int GEOS_DLL GEOSGetNumInteriorRings_r(GEOSContextHandle_t handle,
-/* Return -1 on exception, Geometry must be a LineString. */
-extern int GEOS_DLL GEOSGeomGetNumPoints_r(GEOSContextHandle_t handle,
-/* Return 0 on exception, otherwise 1, Geometry must be a Point. */
-extern int GEOS_DLL GEOSGeomGetX_r(GEOSContextHandle_t handle, const GEOSGeometry *g, double *x);
-extern int GEOS_DLL GEOSGeomGetY_r(GEOSContextHandle_t handle, const GEOSGeometry *g, double *y);
-extern int GEOS_DLL GEOSGeomGetZ_r(GEOSContextHandle_t handle, const GEOSGeometry *g, double *z);
- * Return NULL on exception, Geometry must be a Polygon.
+/** \see GEOSGetNumInteriorRings */
+extern int GEOS_DLL GEOSGetNumInteriorRings_r(
+/** \see GEOSGeomGetNumPoints */
+extern int GEOS_DLL GEOSGeomGetNumPoints_r(
+/** \see GEOSGeomGetX */
+extern int GEOS_DLL GEOSGeomGetX_r(
+    double *x);
+/** \see GEOSGeomGetY */
+extern int GEOS_DLL GEOSGeomGetY_r(
+    double *y);
+/** \see GEOSGeomGetZ */
+extern int GEOS_DLL GEOSGeomGetZ_r(
+    double *z);
+/** \see GEOSGetInteriorRingN */
 extern const GEOSGeometry GEOS_DLL *GEOSGetInteriorRingN_r(
+/** \see GEOSGetExteriorRing */
 extern const GEOSGeometry GEOS_DLL *GEOSGetExteriorRing_r(
-extern int GEOS_DLL GEOSGetNumCoordinates_r(GEOSContextHandle_t handle,
+/** \see GEOSGetNumCoordinates */
+extern int GEOS_DLL GEOSGetNumCoordinates_r(
- * Geometry must be a LineString, LinearRing or Point.
+/** \see GEOSGeom_getCoordSeq */
 extern const GEOSCoordSequence GEOS_DLL *GEOSGeom_getCoordSeq_r(
+/** \see GEOSGeom_getDimensions */
+extern int GEOS_DLL GEOSGeom_getDimensions_r(
+/** \see GEOSGeom_getCoordinateDimension */
+extern int GEOS_DLL GEOSGeom_getCoordinateDimension_r(
+/** \see GEOSGeom_getXMin */
+extern int GEOS_DLL GEOSGeom_getXMin_r(
+    double* value);
+/** \see GEOSGeom_getYMin */
+extern int GEOS_DLL GEOSGeom_getYMin_r(
+    double* value);
+/** \see GEOSGeom_getXMax */
+extern int GEOS_DLL GEOSGeom_getXMax_r(
+    double* value);
+/** \see GEOSGeom_getYMax */
+extern int GEOS_DLL GEOSGeom_getYMax_r(
+    double* value);
+/** \see GEOSGeomGetPointN */
+extern GEOSGeometry GEOS_DLL *GEOSGeomGetPointN_r(
+    int n);
+/** \see GEOSGeomGetStartPoint */
+extern GEOSGeometry GEOS_DLL *GEOSGeomGetStartPoint_r(
+/** \see GEOSGeomGetEndPoint */
+extern GEOSGeometry GEOS_DLL *GEOSGeomGetEndPoint_r(
+/* ========= Misc functions ========= */
+/** \see GEOSArea */
+extern int GEOS_DLL GEOSArea_r(
+    double *area);
+/** \see GEOSLength */
+extern int GEOS_DLL GEOSLength_r(
+    double *length);
+/** \see GEOSDistance */
+extern int GEOS_DLL GEOSDistance_r(
+    double *dist);
- * Return 0 on exception (or empty geometry)
-extern int GEOS_DLL GEOSGeom_getDimensions_r(GEOSContextHandle_t handle,
+/** \see GEOSDistanceIndexed */
+extern int GEOS_DLL GEOSDistanceIndexed_r(
+    double *dist);
- * Return 2 or 3.
-extern int GEOS_DLL GEOSGeom_getCoordinateDimension_r(GEOSContextHandle_t handle,
-extern int GEOS_DLL GEOSGeom_getXMin_r(GEOSContextHandle_t handle, const GEOSGeometry* g, double* value);
-extern int GEOS_DLL GEOSGeom_getYMin_r(GEOSContextHandle_t handle, const GEOSGeometry* g, double* value);
-extern int GEOS_DLL GEOSGeom_getXMax_r(GEOSContextHandle_t handle, const GEOSGeometry* g, double* value);
-extern int GEOS_DLL GEOSGeom_getYMax_r(GEOSContextHandle_t handle, const GEOSGeometry* g, double* value);
+/** \see GEOSHausdorffDistance */
+extern int GEOS_DLL GEOSHausdorffDistance_r(
+    const GEOSGeometry *g1,
+    const GEOSGeometry *g2,
+    double *dist);
- * Must be LineString and must be freed by called.
-extern GEOSGeometry GEOS_DLL *GEOSGeomGetPointN_r(GEOSContextHandle_t handle, const GEOSGeometry *g, int n);
-extern GEOSGeometry GEOS_DLL *GEOSGeomGetStartPoint_r(GEOSContextHandle_t handle, const GEOSGeometry *g);
-extern GEOSGeometry GEOS_DLL *GEOSGeomGetEndPoint_r(GEOSContextHandle_t handle, const GEOSGeometry *g);
+/** \see GEOSHausdorffDistanceDensify */
+extern int GEOS_DLL GEOSHausdorffDistanceDensify_r(
+    double densifyFrac, double *dist);
+/** \see GEOSFrechetDistance */
+extern int GEOS_DLL GEOSFrechetDistance_r(
+    double *dist);
- *  Misc functions
+/** \see GEOSFrechetDistanceDensify */
+extern int GEOS_DLL GEOSFrechetDistanceDensify_r(
+    double *dist);
-/* Return 0 on exception, 1 otherwise */
-extern int GEOS_DLL GEOSArea_r(GEOSContextHandle_t handle,
-                               const GEOSGeometry* g, double *area);
-extern int GEOS_DLL GEOSLength_r(GEOSContextHandle_t handle,
-                                 const GEOSGeometry* g, double *length);
-extern int GEOS_DLL GEOSDistance_r(GEOSContextHandle_t handle,
-extern int GEOS_DLL GEOSDistanceIndexed_r(GEOSContextHandle_t handle,
-extern int GEOS_DLL GEOSHausdorffDistance_r(GEOSContextHandle_t handle,
-                                   const GEOSGeometry *g1,
-                                   const GEOSGeometry *g2,
-                                   double *dist);
-extern int GEOS_DLL GEOSHausdorffDistanceDensify_r(GEOSContextHandle_t handle,
-                                   double densifyFrac, double *dist);
-extern int GEOS_DLL GEOSFrechetDistance_r(GEOSContextHandle_t handle,
-                                   double *dist);
-extern int GEOS_DLL GEOSFrechetDistanceDensify_r(GEOSContextHandle_t handle,
-extern int GEOS_DLL GEOSGeomGetLength_r(GEOSContextHandle_t handle,
-                                   const GEOSGeometry *g, double *length);
- * The first point comes from g1 geometry and the second point comes from g2.
+/** \see GEOSGeomGetLength */
+extern int GEOS_DLL GEOSGeomGetLength_r(
+    double *length);
+/** \see GEOSNearestPoints */
 extern GEOSCoordSequence GEOS_DLL *GEOSNearestPoints_r(
-  GEOSContextHandle_t handle, const GEOSGeometry* g1, const GEOSGeometry* g2);
- * Algorithms
+/* ========= Algorithms ========= */
-/* Walking from A to B:
- *  return -1 if reaching P takes a counter-clockwise (left) turn
- *  return  1 if reaching P takes a clockwise (right) turn
- *  return  0 if P is collinear with A-B
- * On exceptions, return 2.
-extern int GEOS_DLL GEOSOrientationIndex_r(GEOSContextHandle_t handle,
-	double Ax, double Ay, double Bx, double By, double Px, double Py);
+/** \see GEOSOrientationIndex */
+extern int GEOS_DLL GEOSOrientationIndex_r(
+	double Ax, double Ay,
+    double Bx, double By,
+    double Px, double Py);
- * Reader and Writer APIs
+/* ========== Reader and Writer APIs ========== */
 #ifndef GEOSWKTReader
+/** Reader object to read Well-Known Text (WKT) format and construct Geometry. */
 typedef struct GEOSWKTReader_t GEOSWKTReader;
+/** Writer object to turn Geometry into Well-Known Text (WKT). */
 typedef struct GEOSWKTWriter_t GEOSWKTWriter;
+/** Reader object to read Well-Known Binary (WKB) format and construct Geometry. */
 typedef struct GEOSWKBReader_t GEOSWKBReader;
+/** Writer object to turn Geometry into Well-Known Binary (WKB). */
 typedef struct GEOSWKBWriter_t GEOSWKBWriter;
 #endif
-/* WKT Reader */
+/* ========== WKT Reader ========== */
+/** \see GEOSWKTReader_create */
 extern GEOSWKTReader GEOS_DLL *GEOSWKTReader_create_r(
+/** \see GEOSWKTReader_destroy */
 extern void GEOS_DLL GEOSWKTReader_destroy_r(GEOSContextHandle_t handle,
-                                             GEOSWKTReader* reader);
-extern GEOSGeometry GEOS_DLL *GEOSWKTReader_read_r(GEOSContextHandle_t handle,
-                                                   GEOSWKTReader* reader,
-                                                   const char *wkt);
+    GEOSWKTReader* reader);
+/** \see GEOSWKTReader_read */
+extern GEOSGeometry GEOS_DLL *GEOSWKTReader_read_r(
+    GEOSWKTReader* reader,
+    const char *wkt);
-/* WKT Writer */
+/* ========== WKT Writer ========== */
 extern GEOSWKTWriter GEOS_DLL *GEOSWKTWriter_create_r(
-extern void GEOS_DLL GEOSWKTWriter_destroy_r(GEOSContextHandle_t handle,
-                                             GEOSWKTWriter* writer);
-extern char GEOS_DLL *GEOSWKTWriter_write_r(GEOSContextHandle_t handle,
-                                            GEOSWKTWriter* writer,
-extern void GEOS_DLL GEOSWKTWriter_setTrim_r(GEOSContextHandle_t handle,
-                                            GEOSWKTWriter *writer,
-                                            char trim);
-extern void GEOS_DLL GEOSWKTWriter_setRoundingPrecision_r(GEOSContextHandle_t handle,
-                                            int precision);
-extern void GEOS_DLL GEOSWKTWriter_setOutputDimension_r(GEOSContextHandle_t handle,
-                                                        int dim);
-extern int  GEOS_DLL GEOSWKTWriter_getOutputDimension_r(GEOSContextHandle_t handle,
-                                                        GEOSWKTWriter *writer);
-extern void GEOS_DLL GEOSWKTWriter_setOld3D_r(GEOSContextHandle_t handle,
-                                              int useOld3D);
-/* WKB Reader */
+/** \see GEOSWKTWriter_destroy */
+extern void GEOS_DLL GEOSWKTWriter_destroy_r(
+    GEOSWKTWriter* writer);
+/** \see GEOSWKTWriter_write */
+extern char GEOS_DLL *GEOSWKTWriter_write_r(
+    GEOSWKTWriter* writer,
+/** \see GEOSWKTWriter_setTrim */
+extern void GEOS_DLL GEOSWKTWriter_setTrim_r(
+    GEOSWKTWriter *writer,
+    char trim);
+/** \see GEOSWKTWriter_setRoundingPrecision */
+extern void GEOS_DLL GEOSWKTWriter_setRoundingPrecision_r(
+    int precision);
+/** \see GEOSWKTWriter_setOutputDimension */
+extern void GEOS_DLL GEOSWKTWriter_setOutputDimension_r(
+    int dim);
+/** \see GEOSWKTWriter_getOutputDimension */
+extern int  GEOS_DLL GEOSWKTWriter_getOutputDimension_r(
+    GEOSWKTWriter *writer);
+/** \see GEOSWKTWriter_setOld3D */
+extern void GEOS_DLL GEOSWKTWriter_setOld3D_r(
+    int useOld3D);
+/* ========== WKB Reader ========== */
+/** \see GEOSWKBReader_create */
 extern GEOSWKBReader GEOS_DLL *GEOSWKBReader_create_r(
-extern void GEOS_DLL GEOSWKBReader_destroy_r(GEOSContextHandle_t handle,
-                                             GEOSWKBReader* reader);
-extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read_r(GEOSContextHandle_t handle,
-                                                   GEOSWKBReader* reader,
-                                                   size_t size);
+/** \see GEOSWKBReader_destroy */
+extern void GEOS_DLL GEOSWKBReader_destroy_r(
+    GEOSWKBReader* reader);
+/** \see GEOSWKBReader_read */
+extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read_r(
+    GEOSWKBReader* reader,
+    const unsigned char *wkb,
+    size_t size);
+/** \see GEOSWKBReader_readHEX */
 extern GEOSGeometry GEOS_DLL *GEOSWKBReader_readHEX_r(
-                                            size_t size);
+    const unsigned char *hex,
+    size_t size);
-/* WKB Writer */
+/* ========== WKB Writer ========== */
+/** \see GEOSWKBWriter_create */
 extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create_r(
-extern void GEOS_DLL GEOSWKBWriter_destroy_r(GEOSContextHandle_t handle,
-                                             GEOSWKBWriter* writer);
+/** \see GEOSWKBWriter_destroy */
+extern void GEOS_DLL GEOSWKBWriter_destroy_r(
+    GEOSWKBWriter* writer);
-/* The caller owns the results for these two methods! */
+/** \see GEOSWKBWriter_write */
 extern unsigned char GEOS_DLL *GEOSWKBWriter_write_r(
-                                             GEOSWKBWriter* writer,
-                                             size_t *size);
+    GEOSWKBWriter* writer,
+    size_t *size);
+/** \see GEOSWKBWriter_writeHEX */
 extern unsigned char GEOS_DLL *GEOSWKBWriter_writeHEX_r(
-                                             size_t *size);
+    size_t *size);
+/** \see GEOSWKBWriter_getOutputDimension */
 extern int GEOS_DLL GEOSWKBWriter_getOutputDimension_r(
-                                  const GEOSWKBWriter* writer);
-extern void GEOS_DLL GEOSWKBWriter_setOutputDimension_r(
-                                   GEOSWKBWriter* writer, int newDimension);
-extern int GEOS_DLL GEOSWKBWriter_getByteOrder_r(GEOSContextHandle_t handle,
-extern void GEOS_DLL GEOSWKBWriter_setByteOrder_r(GEOSContextHandle_t handle,
-                                                  int byteOrder);
- * Specify whether SRID values should be output.
-extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_t handle,
-extern void GEOS_DLL GEOSWKBWriter_setIncludeSRID_r(GEOSContextHandle_t handle,
-                                   GEOSWKBWriter* writer, const char writeSRID);
+    const GEOSWKBWriter* writer);
+/** \see GEOSWKBWriter_setOutputDimension */
+extern void GEOS_DLL GEOSWKBWriter_setOutputDimension_r(
+    GEOSWKBWriter* writer, int newDimension);
+/** \see GEOSWKBWriter_getByteOrder */
+extern int GEOS_DLL GEOSWKBWriter_getByteOrder_r(
+/** \see GEOSWKBWriter_setByteOrder */
+extern void GEOS_DLL GEOSWKBWriter_setByteOrder_r(
+    int byteOrder);
+/** \see GEOSWKBWriter_getIncludeSRID */
+extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID_r(
+/** \see GEOSWKBWriter_setIncludeSRID */
+extern void GEOS_DLL GEOSWKBWriter_setIncludeSRID_r(
+    GEOSWKBWriter* writer, const char writeSRID);
+/** \see GEOSFree */
+extern void GEOS_DLL GEOSFree_r(
+    void *buffer);
- * Free buffers returned by stuff like GEOSWKBWriter_write(),
- * GEOSWKBWriter_writeHEX() and GEOSWKTWriter_write().
-extern void GEOS_DLL GEOSFree_r(GEOSContextHandle_t handle, void *buffer);
-/* External code to GEOS can define GEOS_USE_ONLY_R_API to avoid the */
-/* non _r API to be available */
+* External code to GEOS can define GEOS_USE_ONLY_R_API
+* to strip the non-reentrant API functions from this header,
+* leaving only the "_r" compatible variants.
 #ifndef GEOS_USE_ONLY_R_API
+/* ========== Initialization, cleanup, version ========== */
-extern void GEOS_DLL initGEOS(GEOSMessageHandler notice_function,
+* For non-reentrant code, set up an execution contact, and associate
+* \ref GEOSMessageHandler functions with it, to pass error and notice
+* messages back to the calling application.
+* <pre>
+* typedef void (*GEOSMessageHandler)(const char *fmt, ...);
+* </pre>
+* \param notice_function Handle notice messages
+* \param error_function Handle error messages
+extern void GEOS_DLL initGEOS(
+    GEOSMessageHandler notice_function,
-extern void GEOS_DLL finishGEOS(void);
- * writer APIS!
-extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKT(const char *wkt);
-extern char GEOS_DLL *GEOSGeomToWKT(const GEOSGeometry* g);
-extern int GEOS_DLL GEOS_getWKBOutputDims();
-extern int GEOS_DLL GEOS_setWKBOutputDims(int newDims);
-extern int GEOS_DLL GEOS_getWKBByteOrder();
-extern int GEOS_DLL GEOS_setWKBByteOrder(int byteOrder);
-extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKB_buf(const unsigned char *wkb, size_t size);
-extern unsigned char GEOS_DLL *GEOSGeomToWKB_buf(const GEOSGeometry* g, size_t *size);
+* For non-reentrant code, call when all GEOS operations are complete,
+* cleans up global resources.
+extern void GEOS_DLL finishGEOS(void);
-extern GEOSGeometry GEOS_DLL *GEOSGeomFromHEX_buf(const unsigned char *hex, size_t size);
-extern unsigned char GEOS_DLL *GEOSGeomToHEX_buf(const GEOSGeometry* g, size_t *size);
+* Returns the current GEOS version string. eg: "3.10.0"
+* \return version string
+extern const char GEOS_DLL *GEOSversion(void);
+/* ========= Coordinate Sequence functions ========= */
+* Create a coordinate sequence.
+* \param size number of coordinates in the sequence
+* \param dims dimensionality of the coordinates (2 or 3)
+* \return the sequence or NULL on exception
 extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_create(unsigned int size, unsigned int dims);
+* Clone a coordinate sequence.
+* \param s the coordinate sequence to clone
+* \return a copy of the coordinate sequence or NULL on exception
 extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_clone(const GEOSCoordSequence* s);
+* Destroy a coordinate sequence, freeing all memory.
+* \param s the coordinate sequence to destroy
 extern void GEOS_DLL GEOSCoordSeq_destroy(GEOSCoordSequence* s);
+* Set X ordinate values in a coordinate sequence.
+* \param idx the index of the coordinate to alter, zero based
+* \param val the value to set the ordinate to
+* \return 0 on exception
 extern int GEOS_DLL GEOSCoordSeq_setX(GEOSCoordSequence* s,
     unsigned int idx, double val);
+* Set Y ordinate values in a coordinate sequence.
 extern int GEOS_DLL GEOSCoordSeq_setY(GEOSCoordSequence* s,
+* Set Z ordinate values in a coordinate sequence.
 extern int GEOS_DLL GEOSCoordSeq_setZ(GEOSCoordSequence* s,
+* Set X and Y ordinate values in a coordinate sequence simultaneously.
+* \param x the value to set the X ordinate to
+* \param y the value to set the Y ordinate to
 extern int GEOS_DLL GEOSCoordSeq_setXY(GEOSCoordSequence* s,
     unsigned int idx, double x, double y);
+* Set X, Y and Z ordinate values in a coordinate sequence simultaneously.
+* \param z the value to set the Z ordinate to
 extern int GEOS_DLL GEOSCoordSeq_setXYZ(GEOSCoordSequence* s,
     unsigned int idx, double x, double y, double z);
+* Set Nth ordinate value in a coordinate sequence.
+* \param dim the dimension number of the ordinate to alter, zero based
 extern int GEOS_DLL GEOSCoordSeq_setOrdinate(GEOSCoordSequence* s,
     unsigned int idx, unsigned int dim, double val);
+* Read X ordinate values from a coordinate sequence.
+* \param val pointer where ordinate value will be placed
 extern int GEOS_DLL GEOSCoordSeq_getX(const GEOSCoordSequence* s,
+* Read Y ordinate values from a coordinate sequence.
 extern int GEOS_DLL GEOSCoordSeq_getY(const GEOSCoordSequence* s,
+* Read Z ordinate values from a coordinate sequence.
 extern int GEOS_DLL GEOSCoordSeq_getZ(const GEOSCoordSequence* s,
+* Read X and Y ordinate values from a coordinate sequence.
+* \param x pointer where ordinate X value will be placed
+* \param y pointer where ordinate Y value will be placed
 extern int GEOS_DLL GEOSCoordSeq_getXY(const GEOSCoordSequence* s,
+* \param z pointer where ordinate Z value will be placed
 extern int GEOS_DLL GEOSCoordSeq_getXYZ(const GEOSCoordSequence* s,
+* Read Nth ordinate value from a coordinate sequence.
+* \param[in] s the coordinate sequence
+* \param[in] idx the index of the coordinate to alter, zero based
+* \param[in] dim the dimension number of the ordinate to read, zero based
+* \param[out] val pointer where ordinate value will be placed
 extern int GEOS_DLL GEOSCoordSeq_getOrdinate(const GEOSCoordSequence* s,
     unsigned int idx, unsigned int dim, double *val);
-extern int GEOS_DLL GEOSCoordSeq_getSize(const GEOSCoordSequence* s,
+* Get size info from a coordinate sequence.
+* \param[out] size pointer where size value will be placed
+extern int GEOS_DLL GEOSCoordSeq_getSize(
-extern int GEOS_DLL GEOSCoordSeq_getDimensions(const GEOSCoordSequence* s,
+* Get dimension info from a coordinate sequence.
+* \param[out] dims pointer where dimension value will be placed
+extern int GEOS_DLL GEOSCoordSeq_getDimensions(
+* Check orientation of a coordinate sequence.
+* \param is_ccw pointer for ccw value, 1 if counter-clockwise orientation, 0 otherwise
+* \return 0 on exception, 1 on success
 extern int GEOS_DLL GEOSCoordSeq_isCCW(const GEOSCoordSequence* s, char* is_ccw);
+/* ========== Linear referencing functions */
- * Return -1 on exception */
-extern double GEOS_DLL GEOSProject(const GEOSGeometry *g,
-                                   const GEOSGeometry* p);
+* Distance of point projected onto line from the start of the line.
+* \param line linear target of projection
+* \param point point to be projected onto 'g'
+* \return distance along line that point projects to, -1 on exception
+* \note Line parameter must be a LineString.
+extern double GEOS_DLL GEOSProject(const GEOSGeometry* line,
+                                   const GEOSGeometry* point);
-extern GEOSGeometry GEOS_DLL *GEOSInterpolate(const GEOSGeometry *g,
+* Measuring from start of line, return point that is distance
+* the start. Line parameter must be a LineString.
+* \param d distance from start of line to created point
+* \return The point \ref GEOSGeometry that is distance from the start of line.
+* Caller takes ownership of returned geometry.
+extern GEOSGeometry GEOS_DLL *GEOSInterpolate(const GEOSGeometry* line,
                                               double d);
-extern double GEOS_DLL GEOSProjectNormalized(const GEOSGeometry *g,
-extern GEOSGeometry GEOS_DLL *GEOSInterpolateNormalized(const GEOSGeometry *g,
-                                                        double d);
+* Project point to line and calculate the **proportion** of
+* the line the point is from the start. For example, a point that
+* projects to the middle of a line would be return 0.5.
+* \param point the point to project
+* \return The proportion of the overall line length that the projected
+* point falls at.
+extern double GEOS_DLL GEOSProjectNormalized(const GEOSGeometry* line,
+* Measuring from start of line, return point that is a proportion
+* \param proportion The proportion from the start of line to created point
+extern GEOSGeometry GEOS_DLL *GEOSInterpolateNormalized(
+    double proportion);
+* Buffer a geometry.
+* \param g The input geometry to be buffered.
+* \param width The distance by which to expand the geometry (or contract)
+*        if the value is negative.
+* \param quadsegs The number of segments per quadrant to generate. More
+*        segments provides a more "precise" buffer at the expense of size.
+* \return A \ref GEOSGeometry of the buffered result.
+* NULL on exception. Caller is responsible for freeing with GEOSGeom_destroy().
 extern GEOSGeometry GEOS_DLL *GEOSBuffer(const GEOSGeometry* g,
+* Create a default GEOSBufferParams object for controlling the shape
+* of buffered generated by \ref GEOSBuffer.
+* \return A newly allocated GEOSBufferParams. NULL on exception.
+* Caller is responsible for freeing with GEOSBufferParams_destroy().
 extern GEOSBufferParams GEOS_DLL *GEOSBufferParams_create();
+* Destroy a GEOSBufferParams and free all associated memory.
+* \param parms The object to destroy.
 extern void GEOS_DLL GEOSBufferParams_destroy(GEOSBufferParams* parms);
+* Set the end cap type of a GEOSBufferParams to the desired style,
+* which must be one enumerated in \ref GEOSBufCapStyles.
+* \return 0 on exception, 1 on success.
 extern int GEOS_DLL GEOSBufferParams_setEndCapStyle(
-                                              int style);
+    int style);
+* Set the join type of a GEOSBufferParams to the desired style,
+* which must be one enumerated in \ref GEOSBufJoinStyles.
 extern int GEOS_DLL GEOSBufferParams_setJoinStyle(
-                                              int joinStyle);
+    int joinStyle);
+* Set the mitre limit of a GEOSBufferParams to the desired size.
+* For acute angles, a mitre join can extend very very far from
+* the input geometry, which is probably not desired. The
+* mitre limit places an upper bound on that.
+* \param p The GEOSBufferParams to operate on
+* \param mitreLimit The limit to set
 extern int GEOS_DLL GEOSBufferParams_setMitreLimit(
+* Set the number of segments to use to stroke each quadrant
+* of circular arcs generated by the buffering process. More
+* segments means a smoother output, but with larger size.
+* \param quadSegs Number of segments per quadrant
 extern int GEOS_DLL GEOSBufferParams_setQuadrantSegments(
-                                              int quadSegs);
+    int quadSegs);
+* Sets whether the computed buffer should be single-sided.
+* A single-sided buffer is constructed on only one side of each input line.
+* \see geos::operation::buffer::BufferParameters::setSingleSided
+* \param singleSided Set to 1 for single-sided output 0 otherwise
 extern int GEOS_DLL GEOSBufferParams_setSingleSided(
-                                              int singleSided);
+    int singleSided);
+* Generates a buffer using the special parameters in the GEOSBufferParams
+* \param g The geometry to buffer
+* \param p The parameters to apply to the buffer process
+* \param width The buffer distance
+* \return The buffered geometry, or NULL on exception.
+* Caller is responsible for freeing with GEOSGeom_destroy().
 extern GEOSGeometry GEOS_DLL *GEOSBufferWithParams(
-                                              double width);
+    double width);
-extern GEOSGeometry GEOS_DLL *GEOSBufferWithStyle(const GEOSGeometry* g,
-    double width, int quadsegs, int endCapStyle, int joinStyle,
+* Generate a buffer using the provided style parameters.
+* \param width Width of the buffer
+* \param quadsegs Number of segments per quadrant
+* \param endCapStyle See \ref GEOSBufCapStyles
+* \param joinStyle See \ref GEOSBufJoinStyles
+* \param mitreLimit See GEOSBufferParams_setMitreLimit
+extern GEOSGeometry GEOS_DLL *GEOSBufferWithStyle(
+    double width,
+    int quadsegs,
+    int endCapStyle,
+    int joinStyle,
     double mitreLimit);
-extern GEOSGeometry GEOS_DLL *GEOSSingleSidedBuffer(const GEOSGeometry* g,
-    double width, int quadsegs, int joinStyle, double mitreLimit,
-    int leftSide);
+* Generates offset curve for linear geometry.
+* Only LineStrings accepted as input.
+* \param g The linear geometry to offset from
+* \param width Distance to offset from the curve.
+*        Negative for a right-side offset.
+*        Positive for a left-side offset.
+* \return The offset geometry. Returns NULL on exception.
+* \see geos::operation::buffer::BufferBuilder::bufferLineSingleSided
 extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve(const GEOSGeometry* g,
     double width, int quadsegs, int joinStyle, double mitreLimit);
+* Creates a point geometry from a coordinate sequence.
+* \param s Input coordinate sequence, ownership passes to the geometry
+* \return A newly allocated point geometry. NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createPoint(GEOSCoordSequence* s);
+* Creates a point geometry from a pair of coordinates.
+* \param x The X coordinate
+* \param y The Y coordinate
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createPointFromXY(double x, double y);
+* Creates an empty point.
+* \return A newly allocated empty point geometry. NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPoint();
+* Creates a linear ring geometry, for use in a polygon.
+* \return A newly allocated linear ring geometry. NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing(GEOSCoordSequence* s);
+* Creates a linestring geometry.
+* \return A newly allocated linestring geometry. NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createLineString(GEOSCoordSequence* s);
+* Creates an emptylinestring geometry.
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyLineString();
+* Creates an empty polygon geometry.
+* \return A newly allocated empty polygon geometry. NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPolygon();
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon(GEOSGeometry* shell,
-    GEOSGeometry** holes, unsigned int nholes);
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection(int type,
-    GEOSGeometry* *geoms, unsigned int ngeoms);
+* Creates a polygon geometry from line ring geometries.
+* \param shell A linear ring that is the exterior ring of the polygon.
+* \param holes An array of linear rings that are the holes.
+* \param nholes The number of rings in the holes array.
+* \return A newly allocated geometry. NULL on exception.
+* \note The holes argument is an array of GEOSGeometry* objects.
+*       The caller **retains ownership** of the containing array,
+*       but the ownership of the pointed-to objects is transferred
+*       to the returned \ref GEOSGeometry.
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon(
+* Create a geometry collection.
+* \param type The geometry type, enumerated by \ref GEOSGeomTypes
+* \param geoms A list of geometries that will form the collection
+* \param ngeoms The number of geometries in the geoms list
+* \return A newly allocated geometry collection. NULL on exception.
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection(
+    int type,
+    GEOSGeometry** geoms,
+* Create an empty geometry collection.
+* \return A newly allocated empty geometry collection. NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCollection(int type);
+* Create a new copy of the input geometry.
+* \param g The geometry to copy
 extern GEOSGeometry GEOS_DLL *GEOSGeom_clone(const GEOSGeometry* g);
+/* ========== Memory management ========== */
+* Release the memory associated with a geometry.
+* \param g The geometry to be destroyed.
 extern void GEOS_DLL GEOSGeom_destroy(GEOSGeometry* g);
+/* ========== Topology Operations ========== */
+* Returns minimum rectangular polygon that contains the geometry.
+* \param g The geometry to calculate an envelope for
+* \return A newly allocated polygonal envelope. NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSEnvelope(const GEOSGeometry* g);
+* Returns the intersection of two geometries: the set of points
+* that fall within **both** geometries.
+* \param g1 one of the geometries
+* \param g2 the other geometry
+* \return A newly allocated geometry of the intersection. NULL on exception.
+* \see geos::operation::overlayng::OverlayNG
 extern GEOSGeometry GEOS_DLL *GEOSIntersection(const GEOSGeometry* g1, const GEOSGeometry* g2);
+* that fall within **both** geometries. All the vertices of the output
+* geometry must fall on the grid defined by the gridSize, and the
+* output will be a valid geometry.
+* \param gridSize the cell size of the precision grid
 extern GEOSGeometry GEOS_DLL *GEOSIntersectionPrec(const GEOSGeometry* g1, const GEOSGeometry* g2, double gridSize);
+* Returns the difference of two geometries A and B: the set of points
+* that fall within A but **not** within B.
+* \param ga the base geometry
+* \param gb the geometry to subtract from it
+* \return A newly allocated geometry of the difference. NULL on exception.
+extern GEOSGeometry GEOS_DLL *GEOSDifference(
+    const GEOSGeometry* ga,
+    const GEOSGeometry* gb);
+* All the vertices of the output
+* \param ga one of the geometries
+* \param gb the other geometry
+extern GEOSGeometry GEOS_DLL *GEOSDifferencePrec(
+    const GEOSGeometry* gb,
+    double gridSize);
+* Returns the symmetric difference of two geometries A and B: the set of points
+* that fall in A but **not** within B and the set of points that fall in B but
+* **not** in A.
+* \param ga geometry A
+* \param gb geometry B
+* \return A newly allocated geometry of the symmetric difference. NULL on exception.
+extern GEOSGeometry GEOS_DLL *GEOSSymDifference(
+* **not** in A.
+extern GEOSGeometry GEOS_DLL *GEOSSymDifferencePrec(
+    double gridSize);
+* Returns the union of two geometries A and B: the set of points
+* that fall in A **or** within B.
+* \return A newly allocated geometry of the union. NULL on exception.
+extern GEOSGeometry GEOS_DLL *GEOSUnion(
+extern GEOSGeometry GEOS_DLL *GEOSUnionPrec(
+    double gridSize);
+* Returns the union of all components of a single geometry. Usually
+* used to convert a collection into the smallest set of polygons
+* that cover the same area.
+extern GEOSGeometry GEOS_DLL *GEOSUnaryUnion(const GEOSGeometry* g);
+* \param g input geometry
+extern GEOSGeometry GEOS_DLL *GEOSUnaryUnionPrec(
+    double gridSize);
+* Returns the "boundary" of a geometry, as defined by the DE9IM:
+* - the boundary of a polygon is the linear rings dividing the exterior
+*   from the interior
+* - the boundary of a linestring is the end points
+* - the boundary of a point is the point
+* \return A newly allocated geometry of the boundary. NULL on exception.
+extern GEOSGeometry GEOS_DLL *GEOSBoundary(const GEOSGeometry* g);
+* Returns convex hull of a geometry. The smallest convex Geometry
+* that contains all the points in the input Geometry
+* \return A newly allocated geometry of the convex hull. NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSConvexHull(const GEOSGeometry* g);
+* Returns the minimum rotated rectangular POLYGON which encloses
+* the input geometry. The rectangle has width equal to the
+* minimum diameter, and a longer length. If the convex hill of
+* the input is degenerate (a line or point) a linestring or point
+* is returned. The minimum rotated rectangle can be used as an
+* extremely generalized representation for the given geometry.
+* \return A newly allocated geometry of the rotated envelope. NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSMinimumRotatedRectangle(const GEOSGeometry* g);
-/* Constructs the Maximum Inscribed Circle for a  polygonal geometry, up to a specified tolerance.
- * The Maximum Inscribed Circle is determined by a point in the interior of the area
- * which has the farthest distance from the area boundary, along with a boundary point at that distance.
- * In the context of geography the center of the Maximum Inscribed Circle is known as the
- * Pole of Inaccessibility. A cartographic use case is to determine a suitable point
- * to place a map label within a polygon.
- * The radius length of the Maximum Inscribed Circle is a  measure of how "narrow" a polygon is. It is the
- * distance at which the negative buffer becomes empty.
- * The class supports polygons with holes and multipolygons.
- * The implementation uses a successive-approximation technique over a grid of square cells covering the area geometry.
- * The grid is refined using a branch-and-bound algorithm. Point containment and distance are computed in a performant
- * way by using spatial indexes.
- * Returns a two-point linestring, with one point at the center of the inscribed circle and the other
- * on the boundary of the inscribed circle.
-extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle(const GEOSGeometry* g, double tolerance);
-/* Constructs the Largest Empty Circle for a set of obstacle geometries, up to a
- * specified tolerance. The obstacles are point and line geometries.
- * The Largest Empty Circle is the largest circle which  has its center in the convex hull of the
- * obstacles (the boundary), and whose interior does not intersect with any obstacle.
- * The circle center is the point in the interior of the boundary which has the farthest distance from
- * the obstacles (up to tolerance). The circle is determined by the center point and a point lying on an
- * obstacle indicating the circle radius.
- * The implementation uses a successive-approximation technique over a grid of square cells covering the obstacles and boundary.
-extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle(const GEOSGeometry* g, const GEOSGeometry* boundary, double tolerance);
+* Constructs the "maximum inscribed circle" (MIC) for a polygonal geometry,
+* up to a specified tolerance.
+* The MIC is determined by a point in the interior of the area
+* which has the farthest distance from the area boundary, along with a boundary point at that distance.
+* In the context of geography the center of the MIC is known as the
+* "pole of inaccessibility". A cartographic use case is to determine a suitable point
+* to place a map label within a polygon.
+* The radius length of the MIC is a  measure of how "narrow" a polygon is. It is the
+* distance at which the negative buffer becomes empty.
+* The class supports polygons with holes and multipolygons.
+* The implementation uses a successive-approximation technique over a grid of square cells covering the area geometry.
+* The grid is refined using a branch-and-bound algorithm. Point containment and distance are computed in a performant
+* way by using spatial indexes.
+* Returns a two-point linestring, with one point at the center of the inscribed circle and the other
+* on the boundary of the inscribed circle.
+* \param g Input geometry
+* \param tolerance Stop the algorithm when the search area is smaller than this tolerance
+* \return A newly allocated geometry of the MIC. NULL on exception.
+* \see geos::algorithm::construct::MaximumInscribedCircle
+extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle(
+* Constructs the "largest empty circle" (LEC) for a set of obstacle geometries, up to a
+* specified tolerance. The obstacles are point and line geometries.
+* The LEC is the largest circle which  has its center in the convex hull of the
+* obstacles (the boundary), and whose interior does not intersect with any obstacle.
+* The LEC center is the point in the interior of the boundary which has the farthest distance from
+* the obstacles (up to tolerance). The LEC is determined by the center point and a point lying on an
+* obstacle indicating the circle radius.
+* The implementation uses a successive-approximation technique over a grid of square cells covering the obstacles and boundary.
+* \param obstacles The geometries that the LEC must fit within without covering
+* \param boundary The area within which the LEC must reside
+* \return A newly allocated geometry of the LEC. NULL on exception.
+* \see geos::algorithm::construct::LargestEmptyCircle
+extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle(
+    const GEOSGeometry* obstacles,
+* Returns a linestring geometry which represents the minimum diameter of the geometry.
+* The minimum diameter is defined to be the width of the smallest band that
+* contains the geometry, where a band is a strip of the plane defined
+* by two parallel lines. This can be thought of as the smallest hole that the geometry
+* can be moved through, with a single rotation.
+* \see geos::algorithm::MinimumDiameter
 extern GEOSGeometry GEOS_DLL *GEOSMinimumWidth(const GEOSGeometry* g);
-/* Computes the minimum clearance of a geometry.  The minimum clearance is the smallest amount by which
- * a vertex could be move to produce an invalid polygon, a non-simple linestring, or a multipoint with
- * repeated points.  If a geometry has a minimum clearance of 'eps', it can be said that:
- * -  No two distinct vertices in the geometry are separated by less than 'eps'
- * -  No vertex is closer than 'eps' to a line segment of which it is not an endpoint.
- * If the minimum clearance cannot be defined for a geometry (such as with a single point, or a multipoint
- * whose points are identical, a value of Infinity will be calculated.
- * @param d a double to which the result can be stored
- * @return 0 if no exception occurred
- *         2 if an exception occurred
+* Computes the minimum clearance of a geometry.  The minimum clearance is the smallest amount by which
+* a vertex could be move to produce an invalid polygon, a non-simple linestring, or a multipoint with
+* repeated points.  If a geometry has a minimum clearance of 'eps', it can be said that:
+* -  No two distinct vertices in the geometry are separated by less than 'eps'
+* -  No vertex is closer than 'eps' to a line segment of which it is not an endpoint.
+* If the minimum clearance cannot be defined for a geometry (such as with a single point, or a multipoint
+* whose points are identical, a value of Infinity will be calculated.
+* \param g the input geometry
+* \param d a double to which the result can be stored
+* \return 0 if no exception occurred.
+*         2 if an exception occurred.
+* \see geos::precision::MinimumClearance
 extern int GEOS_DLL GEOSMinimumClearance(const GEOSGeometry* g, double* d);
-/* Returns a LineString whose endpoints define the minimum clearance of a geometry.
- * If the geometry has no minimum clearance, an empty LineString will be returned.
- * @return a LineString, or NULL if an exception occurred.
+* Returns a LineString whose endpoints define the minimum clearance of a geometry.
+* If the geometry has no minimum clearance, an empty LineString will be returned.
+* \return a linestring geometry, or NULL if an exception occurred.
 extern GEOSGeometry GEOS_DLL *GEOSMinimumClearanceLine(const GEOSGeometry* g);
-extern GEOSGeometry GEOS_DLL *GEOSDifference(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern GEOSGeometry GEOS_DLL *GEOSDifferencePrec(const GEOSGeometry* g1, const GEOSGeometry* g2, double gridSize);
-extern GEOSGeometry GEOS_DLL *GEOSSymDifference(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern GEOSGeometry GEOS_DLL *GEOSSymDifferencePrec(const GEOSGeometry* g1, const GEOSGeometry* g2, double gridSize);
-extern GEOSGeometry GEOS_DLL *GEOSBoundary(const GEOSGeometry* g);
-extern GEOSGeometry GEOS_DLL *GEOSUnion(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern GEOSGeometry GEOS_DLL *GEOSUnionPrec(const GEOSGeometry* g1, const GEOSGeometry* g2, double gridSize);
-extern GEOSGeometry GEOS_DLL *GEOSUnaryUnion(const GEOSGeometry* g);
-extern GEOSGeometry GEOS_DLL *GEOSUnaryUnionPrec(const GEOSGeometry* g, double gridSize);
-/* GEOSCoverageUnion is an optimized union algorithm for polygonal inputs that are correctly
- * noded and do not overlap. It will not generate an error (return NULL) for inputs that
- * do not satisfy this constraint. */
+* Optimized union algorithm for polygonal inputs that are correctly
+* noded and do not overlap. It will generate an error (return NULL)
+* for inputs that do not satisfy this constraint.
+* \return A geometry that covers all the points of the input geometry.
 extern GEOSGeometry GEOS_DLL *GEOSCoverageUnion(const GEOSGeometry *g);
-/* @deprecated in 3.3.0: use GEOSUnaryUnion instead */
-extern GEOSGeometry GEOS_DLL *GEOSUnionCascaded(const GEOSGeometry* g);
+* Returns a point that is inside the boundary of a polygonal geometry.
+* \return A point that is inside the input
+* \see geos::algorithm::InteriorPointArea
 extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface(const GEOSGeometry* g);
+* Returns a point at the center of mass of the input.
+* \return A point at the center of mass of the input
+* \see geos::algorithm::Centroid
 extern GEOSGeometry GEOS_DLL *GEOSGetCentroid(const GEOSGeometry* g);
-extern GEOSGeometry GEOS_DLL *GEOSMinimumBoundingCircle(const GEOSGeometry* g, double* radius, GEOSGeometry** center);
+* Returns a geometry which represents the "minimum bounding circle",
+* the smallest circle that contains the input.
+* \param[in] g The input geometry
+* \param[out] radius Pointer will be filled with output radius.
+* \param[out] center Pointer will be filled with output circle center. Caller must free.
+* \return The circle geometry or NULL on exception
+* \see geos::algorithm::MinimumBoundingCircle::getCircle
+extern GEOSGeometry GEOS_DLL *GEOSMinimumBoundingCircle(
+    double* radius,
+* For linear inputs, returns a new geometry in which no lines cross
+* each other, and all touching occurs at end points.
+* \return The noded geometry or NULL on exception
+* \see geos::noding::GeometryNoder::node
 extern GEOSGeometry GEOS_DLL *GEOSNode(const GEOSGeometry* g);
-extern GEOSGeometry GEOS_DLL *GEOSClipByRect(const GEOSGeometry* g, double xmin, double ymin, double xmax, double ymax);
- * all arguments remain ownership of the caller
- * (both Geometries and pointers)
-extern GEOSGeometry GEOS_DLL *GEOSPolygonize(const GEOSGeometry * const geoms[], unsigned int ngeoms);
-extern GEOSGeometry GEOS_DLL *GEOSPolygonize_valid(const GEOSGeometry * const geoms[], unsigned int ngeoms);
-extern GEOSGeometry GEOS_DLL *GEOSPolygonizer_getCutEdges(const GEOSGeometry * const geoms[], unsigned int ngeoms);
-extern GEOSGeometry GEOS_DLL *GEOSPolygonize_full(const GEOSGeometry* input,
-    GEOSGeometry** cuts, GEOSGeometry** dangles, GEOSGeometry** invalid);
+* Intersection optimized for a rectangular clipping polygon.
+* Supposed to be faster than using GEOSIntersection(). Not
+* guaranteed to return valid results.
+* \param g The input geometry to be clipped
+* \param xmin Left bound of clipping rectangle
+* \param ymin Lower bound of clipping rectangle
+* \param xmax Right bound of clipping rectangle
+* \param ymax Upper bound of clipping rectangle
+* \return The clipped geometry or NULL on exception
+* \see geos::operation::intersection::RectangleIntersection
+extern GEOSGeometry GEOS_DLL *GEOSClipByRect(
+    double xmin, double ymin,
+    double xmax, double ymax);
+* Polygonizes a set of Geometries which contain linework that
+* represents the edges of a planar graph.
+* All types of Geometry are accepted as input; the constituent
+* linework is extracted as the edges to be polygonized.
+* The edges must be correctly noded; that is, they must only meet
+* at their endpoints. Polygonization will accept incorrectly noded
+* input but will not form polygons from non-noded edges, and reports
+* them as errors.
+* The Polygonizer reports the following kinds of errors:
+* - Dangles - edges which have one or both ends which are
+*   not incident on another edge endpoint
+* - Cut Edges - edges which are connected at both ends but
+*   which do not form part of a polygon
+* - Invalid Ring Lines - edges which form rings which are invalid
+*   (e.g. the component lines contain a self-intersection)
+* Errors are reported to output parameters "cuts", "dangles" and
+* "invalid" (if not-null). Formed polygons are returned as a
+* collection. NULL is returned on exception. All returned
+* geometries must be destroyed by caller.
+* The GEOSPolygonize_valid() variant allows extracting only polygons
+* which form a valid polygonal result. The set of extracted polygons
+* is guaranteed to be edge-disjoint. This is useful when it is known
+* that the input lines form a valid polygonal geometry (which may
+* include holes or nested polygons).
+* \param geoms Array of linear geometries to polygons. Caller retains ownersihp of both array container and objects.
+* \param ngeoms Size of the geoms array.
+* \return The polygonal output geometry.
+* \see geos::operation::polygonize::Polygonizer
+extern GEOSGeometry GEOS_DLL *GEOSPolygonize(
+    const GEOSGeometry * const geoms[],
+    unsigned int ngeoms);
+* Same polygonizing behavior as GEOSPolygonize(), but only returning results
+* that are valid.
+extern GEOSGeometry GEOS_DLL *GEOSPolygonize_valid(
+* Perform the polygonization as GEOSPolygonize() but return only the
+* "cut edges", the linear features that are connected at both ends,
+* do *not* participate in the final polygon.
+* \return The "cut edges"
+extern GEOSGeometry GEOS_DLL *GEOSPolygonizer_getCutEdges(
+* Perform the polygonization as GEOSPolygonize() and return the
+* polygonal result as well as all extra ouputs.
+* \param[in] input A single geometry with all the input lines to polygonize.
+* \param[out] cuts Pointer to hold "cut edges", connected on both ends but not part of output. Caller must free.
+* \param[out] dangles Pointer to hold "dangles", connected one end but not part of output. Caller must free.
+* \param[out] invalid Pointer to hold invalid outputs, polygons formed but not valid. Caller must free.
+* \return The polygonal valid output
+extern GEOSGeometry GEOS_DLL *GEOSPolygonize_full(
+    const GEOSGeometry* input,
+    GEOSGeometry** cuts,
+    GEOSGeometry** dangles,
+    GEOSGeometry** invalid);
+* Perform a polygonization using all the linework, assuming that
+* rings contained within rings are empty holes, rather then
+* extra polygons.
+* \param g The input linework
+* \see geos::operation::polygonize::BuildArea
 extern GEOSGeometry GEOS_DLL *GEOSBuildArea(const GEOSGeometry* g);
+* Sews together a set of fully noded LineStrings
+* removing any cardinality 2 nodes in the linework.
+* \return The merged linework
+* \see geos::operation::linemerge::LineMerger
 extern GEOSGeometry GEOS_DLL *GEOSLineMerge(const GEOSGeometry* g);
+* For geometries with coordinate sequences, reverses the order
+* of the sequences. Converts CCW rings to CW. Reverses direction
+* of LineStrings.
+* \return The reversed geometry
 extern GEOSGeometry GEOS_DLL *GEOSReverse(const GEOSGeometry* g);
-extern GEOSGeometry GEOS_DLL *GEOSSimplify(const GEOSGeometry* g, double tolerance);
-extern GEOSGeometry GEOS_DLL *GEOSTopologyPreserveSimplify(const GEOSGeometry* g,
+* Apply the
+* [Douglas/Peucker algorithm](https://en.wikipedia.org/wiki/Ramer–Douglas–Peucker_algorithm)
+* to the coordinate sequences of the input geometry.
+* Removes "unnecessary" vertices, vertices
+* that are co-linear within the tolerance distance.
+* \param tolerance The tolerance to apply. Larger tolerance leads to simpler output.
+* \return The simplified geometry
+* \see geos::simplify::DouglasPeuckerSimplifier
+extern GEOSGeometry GEOS_DLL *GEOSSimplify(
     double tolerance);
- * Return all distinct vertices of input geometry as a MULTIPOINT.
- * Note that only 2 dimensions of the vertices are considered when
- * testing for equality.
+* Apply the
+* Returns a valid output geometry, checking for collapses, ring-intersections, etc
+* and attempting to avoid. More computationally expensive than GEOSSimplify()
+extern GEOSGeometry GEOS_DLL *GEOSTopologyPreserveSimplify(
+    double tolerance);
+* Return all distinct vertices of input geometry as a MultiPoint.
+* Note that only 2 dimensions of the vertices are considered when
+* testing for equality.
+* \return The distinct points
 extern GEOSGeometry GEOS_DLL *GEOSGeom_extractUniquePoints(
-                              const GEOSGeometry* g);
+    const GEOSGeometry* g);
- * Find paths shared between the two given lineal geometries.
- * Returns a GEOMETRYCOLLECTION having two elements:
- * - first element is a MULTILINESTRING containing shared paths
- *   having the _same_ direction on both inputs
- * - second element is a MULTILINESTRING containing shared paths
- *   having the _opposite_ direction on the two inputs
- * Returns NULL on exception
-extern GEOSGeometry GEOS_DLL *GEOSSharedPaths(const GEOSGeometry* g1,
-  const GEOSGeometry* g2);
+* Find paths shared between the two given lineal geometries.
+* Returns a GeometryCollection having two elements:
+* - first element is a MultiLineString containing shared paths
+*   having the _same_ direction on both inputs
+* - second element is a MultiLineString containing shared paths
+*   having the _opposite_ direction on the two inputs
+* \param g1 An input geometry
+* \param g2 An input geometry
+* \return The shared paths
+* \see geos::operation::sharedpaths::SharedPathsOp
+extern GEOSGeometry GEOS_DLL *GEOSSharedPaths(
+    const GEOSGeometry* g1,
+    const GEOSGeometry* g2);
- * Snap first geometry on to second with given tolerance
- * Returns a newly allocated geometry, or NULL on exception
-extern GEOSGeometry GEOS_DLL *GEOSSnap(const GEOSGeometry* g1,
-  const GEOSGeometry* g2, double tolerance);
+* Snap first geometry onto second within the given tolerance.
+* \param input An input geometry
+* \param snap_target A geometry to snap the input to
+* \param tolerance Snapping tolerance
+* \return The snapped verion of the input. NULL on exception.
+extern GEOSGeometry GEOS_DLL *GEOSSnap(
+    const GEOSGeometry* snap_target,
- * Return a Delaunay triangulation of the vertex of the given geometry
- * @param g the input geometry whose vertex will be used as "sites"
- * @param tolerance optional snapping tolerance to use for improved robustness
- * @param onlyEdges if non-zero will return a MULTILINESTRING, otherwise it will
- *                  return a GEOMETRYCOLLECTION containing triangular POLYGONs.
- * @return  a newly allocated geometry, or NULL on exception
+* Return a Delaunay triangulation of the vertices of the given geometry.
+* \param g the input geometry whose vertices will be used as "sites"
+* \param tolerance optional snapping tolerance to use for improved robustness
+* \param onlyEdges if non-zero will return a MultiLineString, otherwise it will
+*                  return a GeometryCollection containing triangular Polygons.
 extern GEOSGeometry GEOS_DLL * GEOSDelaunayTriangulation(
-                                  double tolerance,
-                                  int onlyEdges);
+    const GEOSGeometry *g,
+    double tolerance,
+    int onlyEdges);
- * Returns the Voronoi polygons of a set of Vertices given as input
- * @param g the input geometry whose vertex will be used as sites.
- * @param tolerance snapping tolerance to use for improved robustness
- * @param onlyEdges whether to return only edges of the voronoi cells
- * @param env clipping envelope for the returned diagram, automatically
- *            determined if NULL.
- *            The diagram will be clipped to the larger
- *            of this envelope or an envelope surrounding the sites.
- * @return a newly allocated geometry, or NULL on exception.
+* Returns the Voronoi polygons of the vertices of the given geometry.
+* \param g the input geometry whose vertices will be used as sites.
+* \param tolerance snapping tolerance to use for improved robustness
+* \param onlyEdges whether to return only edges of the voronoi cells
+* \param env clipping envelope for the returned diagram, automatically
+*            determined if env is NULL.
+*            The diagram will be clipped to the larger
+*            of this envelope or an envelope surrounding the sites.
 extern GEOSGeometry GEOS_DLL * GEOSVoronoiDiagram(
-                const GEOSGeometry *env,
-                double tolerance,
-                int onlyEdges);
- * Computes the coordinate where two line segments intersect, if any
- * @param ax0 x-coordinate of first point in first segment
- * @param ay0 y-coordinate of first point in first segment
- * @param ax1 x-coordinate of second point in first segment
- * @param ay1 y-coordinate of second point in first segment
- * @param bx0 x-coordinate of first point in second segment
- * @param by0 y-coordinate of first point in second segment
- * @param bx1 x-coordinate of second point in second segment
- * @param by1 y-coordinate of second point in second segment
- * @param cx x-coordinate of intersection point
- * @param cy y-coordinate of intersection point
- * @return 0 on error, 1 on success, -1 if segments do not intersect
+    const GEOSGeometry *env,
+    double tolerance,
+    int onlyEdges);
+* Computes the coordinate where two line segments intersect, if any
+* \param[in] ax0 x-coordinate of 1st point in 1st segment
+* \param[in] ay0 y-coordinate of 1st point in 1st segment
+* \param[in] ax1 x-coordinate of 2nd point in 1st segment
+* \param[in] ay1 y-coordinate of 2nd point in 1st segment
+* \param[in] bx0 x-coordinate of 1st point in 2nd segment
+* \param[in] by0 y-coordinate of 1st point in 2nd segment
+* \param[in] bx1 x-coordinate of 2nd point in 2nd segment
+* \param[in] by1 y-coordinate of 2nd point in 2nd segment
+* \param[out] cx x-coordinate of intersection point
+* \param[out] cy y-coordinate of intersection point
+* \return 0 on error, 1 on success, -1 if segments do not intersect
 extern int GEOS_DLL GEOSSegmentIntersection(
        double ax0, double ay0,
        double ax1, double ay1,
@@ -1831,438 +2717,1457 @@ extern int GEOS_DLL GEOSSegmentIntersection(
        double bx1, double by1,
        double* cx, double* cy);
- *  Binary predicates - return 2 on exception, 1 on true, 0 on false
+/* ========= Binary Predicates ========= */
+* True if no point of either geometry touchess or is within the other.
+* \param g1 Input geometry
+* \param g2 Input geometry
+* \returns 1 on true, 0 on false, 2 on exception
+* \see geos::geom::Geometry::disjoint
 extern char GEOS_DLL GEOSDisjoint(const GEOSGeometry* g1, const GEOSGeometry* g2);
+* True if geometries share boundaries at one or more points, but do
+* not have interior overlaps.
+* \see geos::geom::Geometry::touches
 extern char GEOS_DLL GEOSTouches(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSIntersects(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSCrosses(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSWithin(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSContains(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSOverlaps(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSEquals(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSCovers(const GEOSGeometry* g1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSCoveredBy(const GEOSGeometry* g1, const GEOSGeometry* g2);
- * Determine pointwise equivalence of two geometries, by checking if each vertex of g2 is
- * within tolerance of the corresponding vertex in g1.
- * Unlike GEOSEquals, geometries that are topologically equivalent but have different
- * representations (e.g., LINESTRING (0 0, 1 1) and MULTILINESTRING ((0 0, 1 1)) ) are not
- * considered equivalent by GEOSEqualsExact.
- * returns 2 on exception, 1 on true, 0 on false
-extern char GEOS_DLL GEOSEqualsExact(const GEOSGeometry* g1, const GEOSGeometry* g2, double tolerance);
+* True if geometries are not disjoint.
+* \see geos::geom::Geometry::intersects
+extern char GEOS_DLL GEOSIntersects(const GEOSGeometry* g1, const GEOSGeometry* g2);
- *  Prepared Geometry Binary predicates - return 2 on exception, 1 on true, 0 on false
+* True if geometries interiors interact but their boundares do not.
+* Most useful for finding line crosses cases.
+* \see geos::geom::Geometry::crosses
+extern char GEOS_DLL GEOSCrosses(const GEOSGeometry* g1, const GEOSGeometry* g2);
- * GEOSGeometry ownership is retained by caller
+* True if geometry g1 is completely within g2, and not
+* touching the boundary of g2.
+* \see geos::geom::Geometry::within
+extern char GEOS_DLL GEOSWithin(const GEOSGeometry* g1, const GEOSGeometry* g2);
+* True if geometry g2 is completely within g1.
+* \see geos::geom::Geometry::contains
+extern char GEOS_DLL GEOSContains(const GEOSGeometry* g1, const GEOSGeometry* g2);
+* True if geometries share interiors but are neither
+* within nor contained.
+* \see geos::geom::Geometry::overlaps
+extern char GEOS_DLL GEOSOverlaps(const GEOSGeometry* g1, const GEOSGeometry* g2);
+* True if geometries cover the same space on the place.
+* \see geos::geom::Geometry::equals
+extern char GEOS_DLL GEOSEquals(const GEOSGeometry* g1, const GEOSGeometry* g2);
+* True if geometry g1 is completely within g2, including possibly
+* \see geos::geom::Geometry::covers
+extern char GEOS_DLL GEOSCovers(const GEOSGeometry* g1, const GEOSGeometry* g2);
+* True if geometry g2 is completely within g1, including possibly
+* touching the boundary of g1.
+* \see geos::geom::Geometry::coveredby
+extern char GEOS_DLL GEOSCoveredBy(const GEOSGeometry* g1, const GEOSGeometry* g2);
+* Determine pointwise equivalence of two geometries, by checking if each vertex of g2 is
+* within tolerance of the corresponding vertex in g1.
+* Unlike GEOSEquals(), geometries that are topologically equivalent but have different
+* representations (e.g., LINESTRING (0 0, 1 1) and MULTILINESTRING ((0 0, 1 1)) ) are not
+* considered equivalent by GEOSEqualsExact().
+* \param tolerance Tolerance to determine vertex equality
+extern char GEOS_DLL GEOSEqualsExact(
+    const GEOSGeometry* g2,
+/* ========== Prepared Geometry Binary predicates ========== */
+* A \ref GEOSPreparedGeometry is a wrapper around \ref GEOSGeometry
+* that adds in a spatial index on the edges of the geometry. This
+* internal index allows spatial predicates to evaluate much faster,
+* so for cases in which the same base geometry will be used over and
+* over again for predicate tests, wrapping it in a \ref GEOSPreparedGeometry
+* is a best practice.
+* The caller retains ownership of the base geometry, and after
+* processing is complete, must destroy **both** the prepared and the
+* base geometry. (Ideally, destroy the prepared geometry first, as
+* it has an internal reference to the base geometry.)
+* \param g The base geometry to wrap in a prepared geometry.
+* \return A prepared geometry. Caller is responsible for freeing with
+*         GEOSPreparedGeom_destroy()
 extern const GEOSPreparedGeometry GEOS_DLL *GEOSPrepare(const GEOSGeometry* g);
+* Free the memory associated with a \ref GEOSPreparedGeometry.
+* Caller must separately free the base \ref GEOSGeometry used
+* to create the prepared geometry.
+* \param g Prepared geometry to destroy.
 extern void GEOS_DLL GEOSPreparedGeom_destroy(const GEOSPreparedGeometry* g);
-extern char GEOS_DLL GEOSPreparedContains(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSPreparedContainsProperly(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSPreparedCoveredBy(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSPreparedCovers(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSPreparedCrosses(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSPreparedDisjoint(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSPreparedIntersects(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSPreparedOverlaps(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSPreparedTouches(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern char GEOS_DLL GEOSPreparedWithin(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern GEOSCoordSequence GEOS_DLL *GEOSPreparedNearestPoints(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
-extern int GEOS_DLL GEOSPreparedDistance(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2, double *dist);
+* Using a \ref GEOSPreparedGeometry do a high performance
+* calculation of whether the provided geometry is contained.
+* \param pg1 The prepared geometry
+* \param g2 The geometry to test
+* \see GEOSContains
+extern char GEOS_DLL GEOSPreparedContains(
+    const GEOSPreparedGeometry* pg1,
- *  STRtree functions
+* calculation of whether the provided geometry is contained properly.
+* \see GEOSContainsProperly
+extern char GEOS_DLL GEOSPreparedContainsProperly(
+* calculation of whether the provided geometry is covered by.
+* \see GEOSCoveredBy
+extern char GEOS_DLL GEOSPreparedCoveredBy(
- * Create a new R-tree using the Sort-Tile-Recursive algorithm (STRtree) for two-dimensional
- * spatial data.
- * @param nodeCapacity the maximum number of child nodes that a node may have.  The minimum
- *            recommended capacity value is 4.  If unsure, use a default node capacity of 10.
- * @return a pointer to the created tree
+* calculation of whether the provided geometry covers.
+* \see GEOSCovers
+extern char GEOS_DLL GEOSPreparedCovers(
+* calculation of whether the provided geometry crosses.
+* \see GEOSCrosses
+extern char GEOS_DLL GEOSPreparedCrosses(
+* Using a \ref GEOSPreparedDisjoint do a high performance
+* calculation of whether the provided geometry is disjoint.
+* \see GEOSDisjoin
+extern char GEOS_DLL GEOSPreparedDisjoint(
+* \see GEOSDisjoin
+extern char GEOS_DLL GEOSPreparedIntersects(
+* calculation of whether the provided geometry overlaps.
+* \see GEOSOverlaps
+extern char GEOS_DLL GEOSPreparedOverlaps(
+* calculation of whether the provided geometry touches.
+* \see GEOSTouches
+extern char GEOS_DLL GEOSPreparedTouches(
+* calculation of whether the provided geometry is within.
+* \see GEOSWithin
+extern char GEOS_DLL GEOSPreparedWithin(
+* calculation to find the nearest points between the
+* prepared and provided geometry.
+* \returns A coordinate sequence containing the nearest points, or NULL on exception.
+*          The first point in the sequence is from the prepared geometry, and the
+*          seconds is from the other argument.
+extern GEOSCoordSequence GEOS_DLL *GEOSPreparedNearestPoints(
+* calculation to find the distance points between the
+* prepared and provided geometry. Useful for situations where
+* one geometry is large and static and needs to be tested
+* against a large number of other geometries.
+* \param[in] pg1 The prepared geometry
+* \param[in] g2 The geometry to test
+* \param[out] dist Pointer to store the result in
+* \return 1 on success
+extern int GEOS_DLL GEOSPreparedDistance(
+    double *dist);
+/* ========== STRtree functions ========== */
+* Create a new \ref GEOSSTRtree using the Sort-Tile-Recursive algorithm
+* ([STRtree](https://en.wikipedia.org/wiki/R-tree))
+* for two-dimensional spatial data.
+* \param nodeCapacity The maximum number of child nodes that a node may have.
+*        The minimum recommended capacity value is 4.
+*        If unsure, use a default node capacity of 10.
+* \return a pointer to the created tree
 extern GEOSSTRtree GEOS_DLL *GEOSSTRtree_create(size_t nodeCapacity);
- * Insert an item into an STRtree
- * @param tree the STRtree in which the item should be inserted
- * @param g a GEOSGeometry whose envelope corresponds to the extent of 'item'
- * @param item the item to insert into the tree
-extern void GEOS_DLL GEOSSTRtree_insert(GEOSSTRtree *tree,
-                                        void *item);
+* Insert an item into an \ref GEOSSTRtree
+* \param tree the \ref GEOSSTRtree in which the item should be inserted
+* \param g a GEOSGeometry whose envelope corresponds to the extent of 'item'
+* \param item the item to insert into the tree
+* \note The tree does **not** take ownership of the geometry or the item.
+extern void GEOS_DLL GEOSSTRtree_insert(
+    GEOSSTRtree *tree,
+    void *item);
- * Query an STRtree for items intersecting a specified envelope
- * @param tree the STRtree to search
- * @param g a GEOSGeomety from which a query envelope will be extracted
- * @param callback a function to be executed for each item in the tree whose envelope intersects
- *            the envelope of 'g'.  The callback function should take two parameters: a void
- *            pointer representing the located item in the tree, and a void userdata pointer.
- * @param userdata an optional pointer to pe passed to 'callback' as an argument
-extern void GEOS_DLL GEOSSTRtree_query(GEOSSTRtree *tree,
-                                       GEOSQueryCallback callback,
-                                       void *userdata);
- * Returns the nearest item in the STRtree to the supplied GEOSGeometry.
- * All items in the tree MUST be of type GEOSGeometry.  If this is not the case, use
- * GEOSSTRtree_nearest_generic instead.
+* Query an \ref GEOSSTRtree for items intersecting a specified envelope
- * @param geom the geometry with which the tree should be queried
- * @return a const pointer to the nearest GEOSGeometry in the tree to 'geom', or NULL in
- *            case of exception
-extern const GEOSGeometry GEOS_DLL *GEOSSTRtree_nearest(GEOSSTRtree *tree, const GEOSGeometry* geom);
+* \param tree the \ref GEOSSTRtree to search
+* \param g a GEOSGeomety from which a query envelope will be extracted
+* \param callback a function to be executed for each item in the tree whose envelope intersects
+*            the envelope of 'g'.  The callback function should take two parameters: a void
+*            pointer representing the located item in the tree, and a void userdata pointer.
+* \param userdata an optional pointer to pe passed to 'callback' as an argument
+extern void GEOS_DLL GEOSSTRtree_query(
+    GEOSQueryCallback callback,
+    void *userdata);
- * Returns the nearest item in the STRtree to the supplied item
- * @param item the item with which the tree should be queried
- * @param itemEnvelope a GEOSGeometry having the bounding box of 'item'
- * @param distancefn a function that can compute the distance between two items
- *            in the STRtree.  The function should return zero in case of error,
- *            and should store the computed distance to the location pointed to by
- *            the 'distance' argument.  The computed distance between two items
- *            must not exceed the Cartesian distance between their envelopes.
- * @param userdata optional pointer to arbitrary data; will be passed to distancefn
- *            each time it is called.
- * @return a const pointer to the nearest item in the tree to 'item', or NULL in
-extern const void GEOS_DLL *GEOSSTRtree_nearest_generic(GEOSSTRtree *tree,
-                                                        const void* item,
-                                                        const GEOSGeometry* itemEnvelope,
-                                                        GEOSDistanceCallback distancefn,
-                                                        void* userdata);
- * Iterates over all items in the STRtree
- * @param tree the STRtree over which to iterate
- * @param callback a function to be executed for each item in the tree.
-extern void GEOS_DLL GEOSSTRtree_iterate(GEOSSTRtree *tree,
-                                       void *userdata);
+* Returns the nearest item in the \ref GEOSSTRtree to the supplied geometry.
+* All items in the tree MUST be of type \ref GEOSGeometry.
+* If this is not the case, use GEOSSTRtree_nearest_generic() instead.
+* \param geom the geometry with which the tree should be queried
+* \return a const pointer to the nearest \ref GEOSGeometry in the tree to 'geom', or NULL in
+*            case of exception
+extern const GEOSGeometry GEOS_DLL *GEOSSTRtree_nearest(
+    const GEOSGeometry* geom);
- * Removes an item from the STRtree
+* Returns the nearest item in the \ref GEOSSTRtree to the supplied item
+* \param tree the STRtree to search
+* \param item the item with which the tree should be queried
+* \param itemEnvelope a GEOSGeometry having the bounding box of 'item'
+* \param distancefn a function that can compute the distance between two items
+*            in the STRtree.  The function should return zero in case of error,
+*            and should store the computed distance to the location pointed to by
+*            the 'distance' argument.  The computed distance between two items
+*            must not exceed the Cartesian distance between their envelopes.
+* \param userdata optional pointer to arbitrary data; will be passed to distancefn
+*            each time it is called.
+* \return a const pointer to the nearest item in the tree to 'item', or NULL in
+extern const void GEOS_DLL *GEOSSTRtree_nearest_generic(
+    const void* item,
+    const GEOSGeometry* itemEnvelope,
+    GEOSDistanceCallback distancefn,
+    void* userdata);
+* Iterate over all items in the \ref GEOSSTRtree.
+* \param tree the STRtree over which to iterate
+* \param callback a function to be executed for each item in the tree.
+* \param userdata payload to pass the callback function.
+extern void GEOS_DLL GEOSSTRtree_iterate(
+    void *userdata);
+ * Removes an item from the \ref GEOSSTRtree
- * @param tree the STRtree from which to remove an item
- * @param g the envelope of the item to remove
- * @param the item to remove
- * @return 0 if the item was not removed;
+ * \param tree the STRtree from which to remove an item
+ * \param g the envelope of the item to remove
+ * \param item the item to remove
+ * \return 0 if the item was not removed;
  *         1 if the item was removed;
-extern char GEOS_DLL GEOSSTRtree_remove(GEOSSTRtree *tree,
-                                        const GEOSGeometry *g,
-                                        void *item);
+extern char GEOS_DLL GEOSSTRtree_remove(
+    void *item);
+* Frees all the memory associated with a \ref GEOSSTRtree.
+* Only the tree is freed. The geometries and items fed into
+* GEOSSTRtree_insert() are not owned by the tree, and are
+* still left to the caller to manage.
 extern void GEOS_DLL GEOSSTRtree_destroy(GEOSSTRtree *tree);
- *  Unary predicate - return 2 on exception, 1 on true, 0 on false
+/* ========= Unary predicates ========= */
+* Tests whether the input geometry is empty. If the geometry or any
+* component is non-empty, the geometry is non-empty. An empty geometry
+* has no boundary or interior.
+* \param g The geometry to test
+* \return 1 on true, 0 on false, 2 on exception
 extern char GEOS_DLL GEOSisEmpty(const GEOSGeometry* g);
+* Tests whether the input geometry is "simple". Mostly relevant for
+* linestrings. A "simple" linestring has no self-intersections.
 extern char GEOS_DLL GEOSisSimple(const GEOSGeometry* g);
+* Tests whether the input geometry is a ring. Rings are
+* linestrings, without self-intersections,
+* with start and end point being identical.
 extern char GEOS_DLL GEOSisRing(const GEOSGeometry* g);
+* Tests whether the input geometry has z coordinates.
 extern char GEOS_DLL GEOSHasZ(const GEOSGeometry* g);
+* Tests whether the input geometry is closed.
+* A closed geometry is a linestring or multilinestring
+* with the start and end points being the same.
 extern char GEOS_DLL GEOSisClosed(const GEOSGeometry *g);
- *  Dimensionally Extended 9 Intersection Model related
+/* ========= Dimensionally Extended 9 Intersection Model ========= */
-/* return 2 on exception, 1 on true, 0 on false */
-extern char GEOS_DLL GEOSRelatePattern(const GEOSGeometry* g1, const GEOSGeometry* g2, const char *pat);
+* Calculate the DE9IM pattern for this geometry pair
+* and compare against the provided pattern to check for
+* consistency. If the result and pattern are consistent
+* return true. The pattern may include glob "*" characters
+* for portions that are allowed to match any value.
+* \see geos::geom::Geometry::relate
+* \param g1 First geometry in pair
+* \param g2 Second geometry in pair
+* \param pat DE9IM pattern to check
+extern char GEOS_DLL GEOSRelatePattern(
+    const char *pat);
-/* return NULL on exception, a string to GEOSFree otherwise */
-extern char GEOS_DLL *GEOSRelate(const GEOSGeometry* g1, const GEOSGeometry* g2);
+* Calculate and return the DE9IM pattern for this geometry pair.
+* \return DE9IM string. Caller is responsible for freeing with GEOSFree().
+extern char GEOS_DLL *GEOSRelate(
-extern char GEOS_DLL GEOSRelatePatternMatch(const char *mat, const char *pat);
+* Compare two DE9IM patterns and return true if they
+* are consistent.
+* \param mat Complete DE9IM string (does not have "*")
+* \param pat Pattern to match to (may contain "*")
+extern char GEOS_DLL GEOSRelatePatternMatch(
+    const char *mat,
+    const char *pat);
+* Apply the supplied \ref GEOSRelateBoundaryNodeRules.
+* \see geos::algorithm::BoundaryNodeRule
+* \param bnr A member of the \ref GEOSRelateBoundaryNodeRules enum
+extern char GEOS_DLL *GEOSRelateBoundaryNodeRule(
+    int bnr);
-extern char GEOS_DLL *GEOSRelateBoundaryNodeRule(const GEOSGeometry* g1,
-                                                 int bnr);
- *  Validity checking
+/* ========== Validity checking ========== */
+* Check the validity of the provided geometry.
+* - All points are valid.
+* - All non-zero-length linestrings are valid.
+* - Polygon rings must be non-self-intersecting, and interior rings
+*   contained within exterior rings.
+* - Multi-polygon components may not touch or overlap.
+* \see geos::operation::valid::isValidOp
 extern char GEOS_DLL GEOSisValid(const GEOSGeometry* g);
+* Return the human readable reason a geometry is invalid,
+* empty string otherwise, or NULL on exception.
+* \return A string with the reason, NULL on exception.
+          Caller must GEOSFree() ther result.
 extern char GEOS_DLL *GEOSisValidReason(const GEOSGeometry *g);
- * Caller has the responsibility to destroy 'reason' (GEOSFree)
- * and 'location' (GEOSGeom_destroy) params
- * return 2 on exception, 1 when valid, 0 when invalid
- * Use enum GEOSValidFlags values for the flags param.
-extern char GEOS_DLL GEOSisValidDetail(const GEOSGeometry* g,
-                                       int flags,
-                                       char** reason, GEOSGeometry** location);
+* In one step, calculate and return the validity, the
+* human readable validity reason and a point at which validity
+* rules are broken.
+* Caller has the responsibility to destroy 'reason' with GEOSFree()
+* and 'location' with GEOSGeom_destroy()
+* \param flags A value from the \ref GEOSValidFlags enum
+* \param reason A pointer in which the reason string will be places
+* \param location A pointer in which the location GEOSGeometry will be placed
+* \return 1 when valid, 0 when invalid, 2 on exception
+extern char GEOS_DLL GEOSisValidDetail(
+    const GEOSGeometry* g,
+    int flags,
+    char** reason,
+    GEOSGeometry** location);
+* Repair an invalid geometry, returning a valid output.
+* \return The repaired geometry. Caller must free with GEOSGeom_destroy().
 extern GEOSGeometry GEOS_DLL *GEOSMakeValid(const GEOSGeometry* g);
- *  Geometry info
+/* ========== Geometry info ========== */
-/* Return NULL on exception, result must be freed by caller. */
+* Returns the geometry type string for this geometry.
+* eg: "GeometryCollection", "LineString"
+* \return A string with the geometry type.
+* Caller must free with GEOSFree().
 extern char GEOS_DLL *GEOSGeomType(const GEOSGeometry* g);
-/* Return -1 on exception */
+* Returns the \ref GEOSGeomTypeId number for this geometry.
+* \return The geometry type number, or -1 on exception.
 extern int GEOS_DLL GEOSGeomTypeId(const GEOSGeometry* g);
-/* Return 0 on exception */
+* Returns the "spatial reference id" (SRID) for this geometry.
+* \return SRID number or 0 if unknown / not set.
 extern int GEOS_DLL GEOSGetSRID(const GEOSGeometry* g);
+* Set the "spatial reference id" (SRID) for this geometry.
+* \param SRID SRID number or 0 for unknown SRID.
 extern void GEOS_DLL GEOSSetSRID(GEOSGeometry* g, int SRID);
+* Return the anonymous "user data" for this geometry.
+* User data must be managed by the caller, and freed before
+* the geometry is freed.
+* \return A void* to the user data, caller is responsible for
+*         casting to the appropriate type and freeing.
 extern void GEOS_DLL *GEOSGeom_getUserData(const GEOSGeometry* g);
+* Set the anonymous "user data" for this geometry.
+* Don't forget to free the user data before freeing the geometry.
+* \param userData Void pointer to user data
 extern void GEOS_DLL GEOSGeom_setUserData(GEOSGeometry* g, void* userData);
-/* May be called on all geometries in GEOS 3.x, returns -1 on error and 1
- * for non-multi geometries. Older GEOS versions only accept
- * GeometryCollections or Multi* geometries here, and are likely to crash
- * when fed simple geometries, so beware if you need compatibility with
- * old GEOS versions.
+* Returns the number of sub-geometries immediately under a
+* multi-geometry or collection or 1 for a simple geometry.
+* For nested collections, remember to check if returned
+* sub-geometries are **themselves** also collections.
+* \return Number of direct children in this collection
+* \warning For GEOS < 3.2 this function may crash when fed simple geometries
 extern int GEOS_DLL GEOSGetNumGeometries(const GEOSGeometry* g);
- * Return NULL on exception.
- * Returned object is a pointer to internal storage:
- * it must NOT be destroyed directly.
- * Up to GEOS 3.2.0 the input geometry must be a Collection, in
- * later version it doesn't matter (getGeometryN(0) for a single will
- * return the input).
-extern const GEOSGeometry GEOS_DLL *GEOSGetGeometryN(const GEOSGeometry* g, int n);
+* Returns the specified sub-geometry of a collection. For
+* a simple geometry, returns a pointer to the input.
+* Returned object is a pointer to internal storage:
+* it must NOT be destroyed directly.
+* \param n Sub-geometry index, zero-base
+* \return A const \ref GEOSGeometry, do not free!
+          It will be freed when the parent is freed.
+          Returns NULL on exception.
+* \note Up to GEOS 3.2.0 the input geometry must be a Collection, in
+*       later versions it doesn't matter (getGeometryN(0) for a single will
+*       return the input).
+extern const GEOSGeometry GEOS_DLL *GEOSGetGeometryN(
+    int n);
+* Organize the sub-geometries, rings, and coordinate order
+* of geometries, so that geometries that represent the same
+* object can be easily compared. Starts rings from the same
+* location, orients them in the same way, sorts geometry
+* sub-comonents in the same way. Use before calling
+* GEOSEqualsExact() to avoid false "not equal" results.
+* \return A normalized geometry.
+* Caller must free with GEOSGeometry_destroy()
+* -1 on exception.
 extern int GEOS_DLL GEOSNormalize(GEOSGeometry* g);
-/* Return NULL on exception */
+* Change the rounding precision on a geometry. This will
+* affect the precision of the existing geometry as well as
+* any geometries derived from this geometry using overlay
+* functions. The output will be a valid \ref GEOSGeometry.
+* Note that operations will always be performed in the precision
+* of the geometry with higher precision (smaller "gridSize").
+* That same precision will be attached to the operation outputs.
+* \param gridSize cell size of grid to round coordinates to,
+*        or 0 for FLOATING precision
+* \param flags The bitwise OR of members of the \ref GEOSPrecisionRules enum
+* \return The precision reduced result.
 extern GEOSGeometry GEOS_DLL *GEOSGeom_setPrecision(
-	const GEOSGeometry *g, double gridSize, int flags);
+    double gridSize,
+    int flags);
+* Read the currently set precision value from the
+* geometry and returns the grid size if it is a fixed
+* precision or 0.0 if it is full floating point precision.
+* \return The grid size, or -1 on exception
 extern double GEOS_DLL GEOSGeom_getPrecision(const GEOSGeometry *g);
+* Returns the number of interior rings, for a Polygon input, or
+* an exception otherwise.
+* \param g Input Polygon geometry
+* \return Number of interior rings, -1 on exception
 extern int GEOS_DLL GEOSGetNumInteriorRings(const GEOSGeometry* g);
-/* Return -1 on exception, Geometry must be a LineString. */
+* Returns the number of points, for a LineString input, or
+* \param g Input LineString geometry
+* \return Number of points, -1 on exception
 extern int GEOS_DLL GEOSGeomGetNumPoints(const GEOSGeometry* g);
-/* Return 0 on exception, otherwise 1, Geometry must be a Point. */
+* Returns the X coordinate, for a Point input, or an
+* exception otherwise.
+* \param[in] g Input Point geometry
+* \param[out] x Pointer to hold return value
+* \returns 1 on success, 0 on exception
 extern int GEOS_DLL GEOSGeomGetX(const GEOSGeometry *g, double *x);
+* Returns the Y coordinate, for a Point input, or an
+* \param[out] y Pointer to hold return value
 extern int GEOS_DLL GEOSGeomGetY(const GEOSGeometry *g, double *y);
+* Returns the Z coordinate, for a Point input, or an
+* \param[out] z Pointer to hold return value
 extern int GEOS_DLL GEOSGeomGetZ(const GEOSGeometry *g, double *z);
- * Return NULL on exception, Geometry must be a Polygon.
-extern const GEOSGeometry GEOS_DLL *GEOSGetInteriorRingN(const GEOSGeometry* g, int n);
+* Returns the N'th ring for a Polygon input.
+* \note Returned object is a pointer to internal storage:
+* \param n Index of the desired ring
+* \return LinearRing geometry. Owned by parent geometry, do not free. NULL on exception.
+extern const GEOSGeometry GEOS_DLL *GEOSGetInteriorRingN(
+    int n);
-extern const GEOSGeometry GEOS_DLL *GEOSGetExteriorRing(const GEOSGeometry* g);
+* Get the external ring of a Polygon.
+extern const GEOSGeometry GEOS_DLL *GEOSGetExteriorRing(
-extern int GEOS_DLL GEOSGetNumCoordinates(const GEOSGeometry* g);
+* Get the total number of points in a geometry,
+* of any type.
+* \return Number of points in the geometry. -1 on exception.
+extern int GEOS_DLL GEOSGetNumCoordinates(
- * Geometry must be a LineString, LinearRing or Point.
-extern const GEOSCoordSequence GEOS_DLL *GEOSGeom_getCoordSeq(const GEOSGeometry* g);
+* Return the coordinate sequence underlying the
+* given geometry (Must be a LineString, LinearRing or Point).
+* Do not directly free the coordinate sequence, it is owned by
+* the parent geometry.
+* \return Coordinate sequence or NULL on exception.
+extern const GEOSCoordSequence GEOS_DLL *GEOSGeom_getCoordSeq(
- * Return 0 on exception (or empty geometry)
-extern int GEOS_DLL GEOSGeom_getDimensions(const GEOSGeometry* g);
+* Return the planar dimensionality of the geometry.
+* - 0 for point, multipoint
+* - 1 for linestring, multilinestring
+* - 2 for polygon, multipolygon
+* \see geos::geom::Dimension::DimensionType
+* \return The dimensionality
+extern int GEOS_DLL GEOSGeom_getDimensions(
- * Return 2 or 3.
-extern int GEOS_DLL GEOSGeom_getCoordinateDimension(const GEOSGeometry* g);
+* Return the cartesian dimension of the geometry.
+* - 2 for XY data
+* - 3 for XYZ data
+extern int GEOS_DLL GEOSGeom_getCoordinateDimension(
+* Finds the minimum X value in the geometry.
+* \param[in] g Input geometry
+* \param[out] value Pointer to place result
+* \return 0 on exception
 extern int GEOS_DLL GEOSGeom_getXMin(const GEOSGeometry* g, double* value);
+* Finds the minimum Y value in the geometry.
 extern int GEOS_DLL GEOSGeom_getYMin(const GEOSGeometry* g, double* value);
+* Finds the maximum X value in the geometry.
 extern int GEOS_DLL GEOSGeom_getXMax(const GEOSGeometry* g, double* value);
+* Finds the maximum Y value in the geometry.
 extern int GEOS_DLL GEOSGeom_getYMax(const GEOSGeometry* g, double* value);
- * Must be LineString and must be freed by called.
+* Return the N'th point of a LineString
+* \param g Input geometry, must be a LineString
+* \param n Index of desired point (zero based)
+* \return A Point geometry.
+*         NULL on exception.
 extern GEOSGeometry GEOS_DLL *GEOSGeomGetPointN(const GEOSGeometry *g, int n);
+* Return the first point of a LineString
 extern GEOSGeometry GEOS_DLL *GEOSGeomGetStartPoint(const GEOSGeometry *g);
+* Return the last point of a LineString
 extern GEOSGeometry GEOS_DLL *GEOSGeomGetEndPoint(const GEOSGeometry *g);
- *  Misc functions
+/* ========= Misc functions ========= */
+* Calculate the area of a geometry.
+* \param[out] area Pointer to be filled in with area result
+* \return 1 on success, 0 on exception.
+extern int GEOS_DLL GEOSArea(
+    double *area);
+* Calculate the length of a geometry.
+* \param[out] length Pointer to be filled in with length result
+extern int GEOS_DLL GEOSLength(
+    double *length);
+* Calculate the distance between two geometries.
+* \param[in] g1 Input geometry
+* \param[in] g2 Input geometry
+* \param[out] dist Pointer to be filled in with distance result
+extern int GEOS_DLL GEOSDistance(
+    double *dist);
-/* Return 0 on exception, 1 otherwise */
-extern int GEOS_DLL GEOSArea(const GEOSGeometry* g, double *area);
-extern int GEOS_DLL GEOSLength(const GEOSGeometry* g, double *length);
-extern int GEOS_DLL GEOSDistance(const GEOSGeometry* g1, const GEOSGeometry* g2,
+* Calculate the distance between two geometries, using the
+* indexed facet distance, which first indexes the geometries
+* internally, then calculates the distance. Useful when one
+* or both geometries is very large.
+* \see geos::operation::distance:;IndexedFacetDistance
+extern int GEOS_DLL GEOSDistanceIndexed(
     double *dist);
-extern int GEOS_DLL GEOSDistanceIndexed(const GEOSGeometry* g1, const GEOSGeometry* g2,
+* Calculate the Hausdorff distance between two geometries.
+* [Hausdorff distance](https://en.wikipedia.org/wiki/Hausdorff_distance)
+* is the largest distance between two geometries.
+* \see geos::algorithm::distance::DiscreteHausdorffDistance
+extern int GEOS_DLL GEOSHausdorffDistance(
+    const GEOSGeometry *g1,
+    const GEOSGeometry *g2,
     double *dist);
-extern int GEOS_DLL GEOSHausdorffDistance(const GEOSGeometry *g1,
-        const GEOSGeometry *g2, double *dist);
-extern int GEOS_DLL GEOSHausdorffDistanceDensify(const GEOSGeometry *g1,
-        const GEOSGeometry *g2, double densifyFrac, double *dist);
-extern int GEOS_DLL GEOSFrechetDistance(const GEOSGeometry *g1,
-extern int GEOS_DLL GEOSFrechetDistanceDensify(const GEOSGeometry *g1,
-extern int GEOS_DLL GEOSGeomGetLength(const GEOSGeometry *g, double *length);
-/* Return 0 on exception, the closest points of the two geometries otherwise.
- * The first point comes from g1 geometry and the second point comes from g2.
+* Calculate a more precise Hausdorff distance between two geometries,
+* by densifying the inputs before computation.
+* \param[in] densifyFrac The largest % of the overall line length that
+*            any given two-point segment should be
+extern int GEOS_DLL GEOSHausdorffDistanceDensify(
+    double densifyFrac,
+    double *dist);
+* Calculate the
+* [Frechet distance](https://en.wikipedia.org/wiki/Fr%C3%A9chet_distance)
+* between two geometries,
+* a similarity measure for linear features.
+* \see geos::algorithm::distance::DiscreteFrechetDistance
+extern int GEOS_DLL GEOSFrechetDistance(
+    double *dist);
+* Calculate the
+* a similarity measure for linear features. For more precision, first
+* densify the inputs.
+extern int GEOS_DLL GEOSFrechetDistanceDensify(
+    double *dist);
+* Calculate the length of a LineString.
+* Only works for LineString inputs, returns exception otherwise.
+extern int GEOS_DLL GEOSGeomGetLength(
+    double *length);
+* The closest points of the two geometries.
+* The first point comes from g1 geometry and the second point comes from g2.
+* \return A coordinate sequence with the two points, or NULL on exception.
+* Caller must free with GEOSCoordSeq_destroy().
 extern GEOSCoordSequence GEOS_DLL *GEOSNearestPoints(
-  const GEOSGeometry* g1, const GEOSGeometry* g2);
- * Algorithms
+/* ========== Algorithms ========== */
-/* Walking from A to B:
- *  return -1 if reaching P takes a counter-clockwise (left) turn
- *  return  1 if reaching P takes a clockwise (right) turn
- *  return  0 if P is collinear with A-B
- * On exceptions, return 2.
-extern int GEOS_DLL GEOSOrientationIndex(double Ax, double Ay, double Bx, double By,
+* For the points formed by the six input ordinates,
+* walking from A to B and then to P.
+* \param Ax X coordinate of A
+* \param Ay Y coordinate of A
+* \param Bx X coordinate of B
+* \param By Y coordinate of B
+* \param Px X coordinate of P
+* \param Py Y coordinate of P
+* \return  -1 if reaching P takes a counter-clockwise (left) turn,
+*           1 if reaching P takes a clockwise (right) turn,
+*           0 if P is collinear with A-B
+extern int GEOS_DLL GEOSOrientationIndex(
+    double Ax, double Ay,
+    double Bx, double By,
     double Px, double Py);
- * Reader and Writer APIs
+/* ========= Reader and Writer APIs ========= */
-/* WKT Reader */
+/* ========= WKT Reader ========= */
+* Allocate a new \ref GEOSWKTReader.
+* \returns a new reader. Caller must free with GEOSWKTReader_destroy()
 extern GEOSWKTReader GEOS_DLL *GEOSWKTReader_create();
+* Free the memory associated with a \ref GEOSWKTReader.
+* \param reader The reader to destroy.
 extern void GEOS_DLL GEOSWKTReader_destroy(GEOSWKTReader* reader);
-extern GEOSGeometry GEOS_DLL *GEOSWKTReader_read(GEOSWKTReader* reader, const char *wkt);
-/* WKT Writer */
+* Use a reader to parse the well-known text representation of
+* a geometry, and return an allocated geometry.
+* \param reader A WKT reader object, caller retains ownership
+* \param wkt The WKT string to parse, caller retains ownership
+* \return A \ref GEOSGeometry, caller to free with GEOSGeometry_destroy())
+extern GEOSGeometry GEOS_DLL *GEOSWKTReader_read(
+    GEOSWKTReader* reader,
+    const char *wkt);
+/* ========= WKT Writer ========= */
+* Allocate a new \ref GEOSWKTWriter.
+* \returns a new writer. Caller must free with GEOSWKTWriter_destroy()
 extern GEOSWKTWriter GEOS_DLL *GEOSWKTWriter_create();
-extern void GEOS_DLL GEOSWKTWriter_destroy(GEOSWKTWriter* writer);
-extern char GEOS_DLL *GEOSWKTWriter_write(GEOSWKTWriter* writer, const GEOSGeometry* g);
-extern void GEOS_DLL GEOSWKTWriter_setTrim(GEOSWKTWriter *writer, char trim);
-extern void GEOS_DLL GEOSWKTWriter_setRoundingPrecision(GEOSWKTWriter *writer, int precision);
-extern void GEOS_DLL GEOSWKTWriter_setOutputDimension(GEOSWKTWriter *writer, int dim);
+* Free the memory associated with a \ref GEOSWKTWriter.
+* \param writer The writer to destroy.
+extern void GEOS_DLL GEOSWKTWriter_destroy(
+    GEOSWKTWriter* writer);
+* Writes out the well-known text representation of a geometry,
+* using the trim, rounding and dimension settings of the writer.
+* \param writer A \ref GEOSWKTWriter.
+* \return A newly allocated string containing the WKT output or NULL on exception.
+extern char GEOS_DLL *GEOSWKTWriter_write(
+    GEOSWKTWriter* writer,
+* Sets the number trimming option on a \ref GEOSWKTWriter.
+* With trim set to 1, the writer will strip trailing 0's from
+* the output coordinates. With 0, all coordinates will be
+* padded with 0's out to the rounding precision.
+* \param trim The trimming behaviour to set, 1 for 'on', 0 for 'off', default 'off'
+extern void GEOS_DLL GEOSWKTWriter_setTrim(
+    GEOSWKTWriter *writer,
+    char trim);
+* Sets the number places after the decimal to output in
+* WKT.
+* \param precision The desired precision, default 16.
+extern void GEOS_DLL GEOSWKTWriter_setRoundingPrecision(
+    int precision);
+* Sets whether or not to write out XY or XYZ coordinates.
+* Legal values are 2 or 3.
+* \param dim The desired dimension, default 2.
+extern void GEOS_DLL GEOSWKTWriter_setOutputDimension(
+    int dim);
+* Reads the current output dimension from a \ref GEOSWKTWriter.
+* \return The current dimension.
 extern int  GEOS_DLL GEOSWKTWriter_getOutputDimension(GEOSWKTWriter *writer);
-extern void GEOS_DLL GEOSWKTWriter_setOld3D(GEOSWKTWriter *writer, int useOld3D);
-/* WKB Reader */
+* Sets the format for 3D outputs. The "old 3D" format does not
+* include a dimensionality tag, eg. "POINT(1 2 3)" while the new (ISO)
+* format does includes a tag, eg "POINT Z (1 2 3)".
+* \param useOld3D True to use the old format, false is the default.
+extern void GEOS_DLL GEOSWKTWriter_setOld3D(
+    int useOld3D);
+/* ========== WKB Reader ========== */
+* Allocate a new \ref GEOSWKBReader.
+* \returns a new reader. Caller must free with GEOSWKBReader_destroy()
 extern GEOSWKBReader GEOS_DLL *GEOSWKBReader_create();
-extern void GEOS_DLL GEOSWKBReader_destroy(GEOSWKBReader* reader);
-extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read(GEOSWKBReader* reader, const unsigned char *wkb, size_t size);
-extern GEOSGeometry GEOS_DLL *GEOSWKBReader_readHEX(GEOSWKBReader* reader, const unsigned char *hex, size_t size);
-/* WKB Writer */
+* Free the memory associated with a \ref GEOSWKBReader.
+extern void GEOS_DLL GEOSWKBReader_destroy(
+    GEOSWKBReader* reader);
+* Read a geometry from a well-known binary buffer.
+* \param reader A \ref GEOSWKBReader
+* \param wkb A pointer to the buffer to read from
+* \param size The number of bytes of data in the buffer
+* \return A \ref GEOSGeometry built from the WKB, or NULL on exception.
+extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read(
+    GEOSWKBReader* reader,
+    const unsigned char *wkb,
+    size_t size);
+* Read a geometry from a **hex encoded** well-known binary buffer.
+* \param hex A pointer to the buffer to read from
+* \return A \ref GEOSGeometry built from the HEX WKB, or NULL on exception.
+extern GEOSGeometry GEOS_DLL *GEOSWKBReader_readHEX(
+    const unsigned char *hex,
+    size_t size);
+/* ========== WKB Writer ========== */
+* Allocate a new \ref GEOSWKBWriter.
+* \returns a new writer. Caller must free with GEOSWKBWriter_destroy()
 extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create();
+* Free the memory associated with a \ref GEOSWKBWriter.
 extern void GEOS_DLL GEOSWKBWriter_destroy(GEOSWKBWriter* writer);
-/* The caller owns the results for these two methods! */
-extern unsigned char GEOS_DLL *GEOSWKBWriter_write(GEOSWKBWriter* writer, const GEOSGeometry* g, size_t *size);
-extern unsigned char GEOS_DLL *GEOSWKBWriter_writeHEX(GEOSWKBWriter* writer, const GEOSGeometry* g, size_t *size);
+* Write out the WKB representation of a geometry.
+* \param writer The \ref GEOSWKBWriter controlling the
+* writing.
+* \param g Geometry to convert to WKB
+* \param size Pointer to write the size of the final output WKB to
+* \return The WKB representation. Caller must free with GEOSFree()
+extern unsigned char GEOS_DLL *GEOSWKBWriter_write(
+    GEOSWKBWriter* writer,
+    size_t *size);
- * Specify whether output WKB should be 2d or 3d.
- * Return previously set number of dimensions.
-extern int GEOS_DLL GEOSWKBWriter_getOutputDimension(const GEOSWKBWriter* writer);
-extern void GEOS_DLL GEOSWKBWriter_setOutputDimension(GEOSWKBWriter* writer, int newDimension);
+* Write out the **hex** WKB representation of a geometry.
+* writing.
+* \return The HEX WKB representation. Caller must free with GEOSFree()
+extern unsigned char GEOS_DLL *GEOSWKBWriter_writeHEX(
+    size_t *size);
- * Specify whether the WKB byte order is big or little endian.
- * The return value is the previous byte order.
-extern int GEOS_DLL GEOSWKBWriter_getByteOrder(const GEOSWKBWriter* writer);
-extern void GEOS_DLL GEOSWKBWriter_setByteOrder(GEOSWKBWriter* writer, int byteOrder);
+* Read the current output dimension of the writer.
+* Either 2 or 3 dimensions.
+* Return current number of dimensions.
+* \param writer The writer to read from.
+* \return Number of dimensions (2 or 3)
+extern int GEOS_DLL GEOSWKBWriter_getOutputDimension(
+    const GEOSWKBWriter* writer);
- * Specify whether SRID values should be output.
-extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID(const GEOSWKBWriter* writer);
-extern void GEOS_DLL GEOSWKBWriter_setIncludeSRID(GEOSWKBWriter* writer, const char writeSRID);
+* Set the output dimensionality of the writer. Either
+* 2 or 3 dimensions.
+* \param newDimension The dimensionality desired
+extern void GEOS_DLL GEOSWKBWriter_setOutputDimension(
+    int newDimension);
- * Free buffers returned by stuff like GEOSWKBWriter_write(),
- * GEOSWKBWriter_writeHEX() and GEOSWKTWriter_write().
+* Find whether the writer will use WKB
+* [byte order](https://en.wikipedia.org/wiki/Endianness)
+* that is big or little endian.
+* The return value is a member of \ref GEOSByteOrders.
+* \param writer The writer to read byte order from
+* \return The current byte order
+extern int GEOS_DLL GEOSWKBWriter_getByteOrder(
+* Set the output byte order of the writer, using
+* a value from \ref GEOSByteOrders enum.
+* \param writer The writer to set byte order on
+* \param byteOrder Desired byte order
+extern void GEOS_DLL GEOSWKBWriter_setByteOrder(
+    int byteOrder);
+* Read the current SRID embedding value from the writer.
+* \param writer The writer to check SRID value on
+extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID(
+* Specify whether SRID values should be output in WKB.
+* Many WKB readers do not support SRID values, use with caution.
+* \param writer The writer to set SRID output on
+* \param writeSRID Set to 1 to include SRID, 0 otherwise
+extern void GEOS_DLL GEOSWKBWriter_setIncludeSRID(
+    const char writeSRID);
+* Free strings and byte buffers returned by functions such
+* as GEOSWKBWriter_write(),
+* GEOSWKBWriter_writeHEX() and GEOSWKTWriter_write(), etc.
+* \param buffer The memory to free
 extern void GEOS_DLL GEOSFree(void *buffer);
 #endif /* #ifndef GEOS_USE_ONLY_R_API */
+/* DEPRECATIONS */
+* \deprecated in 3.3.0, use GEOSOffsetCurve() instead
+extern GEOSGeometry GEOS_DLL *GEOSSingleSidedBuffer(
+    double width, int quadsegs,
+    int joinStyle, double mitreLimit,
+    int leftSide);
+extern GEOSGeometry GEOS_DLL *GEOSSingleSidedBuffer_r(
+    GEOSContextHandle_t handle,
+    int leftSide);
+* \deprecated in 3.5.0. Use GEOS_init_r() and set the message handlers using
+* GEOSContext_setNoticeHandler_r() and/or GEOSContext_setErrorHandler_r()
+extern GEOSContextHandle_t GEOS_DLL initGEOS_r(
+    GEOSMessageHandler notice_function,
+    GEOSMessageHandler error_function);
+* \deprecated in 3.5.0, replaced by GEOS_finish_r()
+extern void GEOS_DLL finishGEOS_r(GEOSContextHandle_t handle);
+* \deprecated use \ref GEOSWKTReader and GEOSWKTReader_read_r()
+extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKT_r(
+    const char *wkt);
+* \deprecated use \ref GEOSWKTWriter and GEOSWKTWriter_write_r()
+extern char GEOS_DLL *GEOSGeomToWKT_r(
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_getOutputDimension_r()
+extern int GEOS_DLL GEOS_getWKBOutputDims_r(
+    GEOSContextHandle_t handle);
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_setOutputDimension_r()
+extern int GEOS_DLL GEOS_setWKBOutputDims_r(
+    int newDims);
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_getByteOrder_r()
+extern int GEOS_DLL GEOS_getWKBByteOrder_r(
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_setByteOrder_r()
+extern int GEOS_DLL GEOS_setWKBByteOrder_r(
+    int byteOrder);
+* \deprecated use \ref GEOSWKBReader and GEOSWKBReader_read_r()
+extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKB_buf_r(
+    size_t size);
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_write_r()
+extern unsigned char GEOS_DLL *GEOSGeomToWKB_buf_r(
+    size_t *size);
+* \deprecated use \ref GEOSWKBReader and GEOSWKBReader_readHEX_r()
+extern GEOSGeometry GEOS_DLL *GEOSGeomFromHEX_buf_r(
+    size_t size);
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_writeHEX_r()
+extern unsigned char GEOS_DLL *GEOSGeomToHEX_buf_r(
+    size_t *size);
+extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKT(const char *wkt);
+* \deprecated use \ref GEOSWKTWriter and GEOSWKTWriter_write()
+extern char GEOS_DLL *GEOSGeomToWKT(const GEOSGeometry* g);
+* \deprecated use \ref GEOSWKBWriter and GEOS_getWKBOutputDims()
+extern int GEOS_DLL GEOS_getWKBOutputDims();
+* \deprecated use \ref GEOSWKBWriter and GEOS_setWKBOutputDims()
+extern int GEOS_DLL GEOS_setWKBOutputDims(int newDims);
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_getByteOrder()
+extern int GEOS_DLL GEOS_getWKBByteOrder();
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_setByteOrder()
+extern int GEOS_DLL GEOS_setWKBByteOrder(int byteOrder);
+* \deprecated use \ref GEOSWKBReader and GEOSWKBWriter_read()
+extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKB_buf(const unsigned char *wkb, size_t size);
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_write()
+extern unsigned char GEOS_DLL *GEOSGeomToWKB_buf(const GEOSGeometry* g, size_t *size);
+* \deprecated use \ref GEOSWKBReader and GEOSWKBWriter_readHEX()
+extern GEOSGeometry GEOS_DLL *GEOSGeomFromHEX_buf(const unsigned char *hex, size_t size);
+* \deprecated use \ref GEOSWKBWriter and GEOSWKBWriter_writeHEX()
+extern unsigned char GEOS_DLL *GEOSGeomToHEX_buf(const GEOSGeometry* g, size_t *size);
+* \deprecated in 3.3.0: use GEOSUnaryUnion() instead
+extern GEOSGeometry GEOS_DLL *GEOSUnionCascaded(const GEOSGeometry* g);
+* \deprecated in 3.3.0: use GEOSUnaryUnion_r() instead
+extern GEOSGeometry GEOS_DLL *GEOSUnionCascaded_r(
+/* END DEPRECATIONS */
 #ifdef __cplusplus
 } // extern "C"
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 6962521..27ed55a 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -989,6 +989,7 @@ extern "C" {
     GEOSisRing_r(GEOSContextHandle_t extHandle, const Geometry* g)
         return execute(extHandle, 2, [&]() {
+            // both LineString* and LinearRing* can cast to LineString*
             const LineString* ls = dynamic_cast<const LineString*>(g);
             if(ls) {
                 return ls->isRing();
diff --git a/doc/Doxyfile.in b/doc/Doxyfile.in
index 0f9d70b..0f032eb 100644
--- a/doc/Doxyfile.in
+++ b/doc/Doxyfile.in
@@ -793,7 +793,7 @@ WARN_LOGFILE           = @DOXYGEN_LOGFILE@
 INPUT                  = @srcdir@/../src \
                          @srcdir@/../include \
-                         @srcdir@/../capi
+                         ../capi
 # This tag can be used to specify the character encoding of the source files
 # that doxygen parses. Internally doxygen uses the UTF-8 encoding. Doxygen uses
diff --git a/include/geos/algorithm/construct/LargestEmptyCircle.h b/include/geos/algorithm/construct/LargestEmptyCircle.h
index 84eed26..98ead21 100644
--- a/include/geos/algorithm/construct/LargestEmptyCircle.h
+++ b/include/geos/algorithm/construct/LargestEmptyCircle.h
@@ -53,10 +53,25 @@ namespace algorithm { // geos::algorithm
 namespace construct { // geos::algorithm::construct
- * Computes the Euclidean distance (L2 metric) from a Point to a Geometry.
- * Also computes two points which are separated by the distance.
+* Constructs the Largest Empty Circle for a set of obstacle geometries,
+* up to a specified tolerance. The obstacles are point and line geometries.
+* The Largest Empty Circle is the largest circle which has its center
+* in the convex hull of the obstacles (the boundary), and whose
+* interior does not intersect with any obstacle. The circle center
+* is the point in the interior of the boundary which has the
+* farthest distance from the obstacles (up to tolerance).
+* The circle is determined by the center point and a point lying
+* on an obstacle indicating the circle radius.
+* The implementation uses a successive-approximation technique
+* over a grid of square cells covering the obstacles and boundary.
+* The grid is refined using a branch-and-bound algorithm. Point
+* containment and distance are computed in a performant way
+* by using spatial indexes.
+* \author Martin Davis
 class GEOS_DLL LargestEmptyCircle {
 public:
@@ -73,7 +88,7 @@ public:
     * Computes the center point of the Largest Empty Circle
-    * `within a set of obstacles, up to a given tolerance distance.
+    * within a set of obstacles, up to a given tolerance distance.
     * @param p_obstacles a geometry representing the obstacles (points and lines)
     * @param p_tolerance the distance tolerance for computing the center point
Summary of changes:
 capi/geos_c.h.in                                   | 5435 +++++++++++++-------
 capi/geos_ts_c.cpp                                 |    1 +
 doc/Doxyfile.in                                    |    2 +-
 .../geos/algorithm/construct/LargestEmptyCircle.h  |   25 +-
 4 files changed, 3692 insertions(+), 1771 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
