[geos-commits] [SCM] GEOS branch master updated. 9dfef81cb651449287f95ea67510bfcdc03924a0
Mon Jan 25 15:56:48 PST 2021
the project "GEOS".
       via  9dfef81cb651449287f95ea67510bfcdc03924a0 (commit)
       via  230df6e52151dfb7adef7165fa0256c12d2ac6ae (commit)
      from  15954750ae442e132b36a0bbdd6d4157455184a8 (commit)
revisions in full, below.
commit 9dfef81cb651449287f95ea67510bfcdc03924a0
Merge: 230df6e 1595475
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jan 25 15:56:39 2021 -0800
    Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit 230df6e52151dfb7adef7165fa0256c12d2ac6ae
Date:   Mon Jan 25 15:56:16 2021 -0800
    Add example of using the CAPI Strtree.
diff --git a/examples/CMakeLists.txt b/examples/CMakeLists.txt
index c72e8c5..8e6f5e6 100644
--- a/examples/CMakeLists.txt
+++ b/examples/CMakeLists.txt
@@ -16,11 +16,14 @@ find_package(GEOS 3.9 REQUIRED)
 add_executable(cpp_read cpp_read.cpp)
 target_link_libraries(cpp_read PRIVATE GEOS::geos)
-add_executable(capi_read capi_read.cpp)
+add_executable(capi_read capi_read.c)
 target_link_libraries(capi_read PRIVATE GEOS::geos_c)
-add_executable(capi_prepared capi_prepared.cpp)
+add_executable(capi_prepared capi_prepared.c)
 target_link_libraries(capi_prepared PRIVATE GEOS::geos_c)
-add_executable(capi_read_ts capi_read_ts.cpp)
+add_executable(capi_strtree capi_strtree.c)
+target_link_libraries(capi_strtree PRIVATE GEOS::geos_c)
+add_executable(capi_read_ts capi_read_ts.c)
 target_link_libraries(capi_read_ts PRIVATE GEOS::geos_c)
diff --git a/examples/README.md b/examples/README.md
index e4622fc..de3e474 100644
--- a/examples/README.md
+++ b/examples/README.md
@@ -3,8 +3,10 @@
 * `capi_read` uses the standard C API to read two WKT geometries, calculate the intersection and print the result
 * `capi_read_ts` uses the "re-entrant" C API (threadsafe) to read two WKT geometries, calculate the intersection and print the result
 * `capi_prepared` uses the standard C API to read one WKT geometry, and fill it with a point grid, applying a high performance "prepared" geometry to speed up intersection testing
+* `capi_strtree` uses the standard C API to build a random collection of points, and then search that collection quickly to find the nearest to a query point
 * `cpp_read` uses the C++ API to read two WKT geometries, calculate the intersection and print the result
 ## Build
 To build the examples _in situ_:
@@ -39,4 +41,3 @@ cc -I/usr/local/include \
     -L/usr/local/lib \
     -lgeos
diff --git a/examples/capi_prepared.cpp b/examples/capi_prepared.cpp
new file mode 100644
index 0000000..a1ffd12
--- /dev/null
+++ b/examples/capi_prepared.cpp
@@ -0,0 +1,137 @@
+* # GEOS C API example 2
+* Reads one geometry and does a high-performance
+* prepared geometry operations to place random
+* points inside it.
+/* To print to stdout */
+#include <stdio.h>
+#include <stdarg.h>
+#include <stdlib.h>
+/* Only the CAPI header is required */
+#include <geos_c.h>
+* GEOS requires two message handlers to return
+* error and notice message to the calling program.
+*   typedef void(* GEOSMessageHandler) (const char *fmt,...)
+* Here we stub out an example that just prints the
+* messages to stdout.
+static void
+geos_message_handler(const char* fmt, ...)
+    va_list ap;
+    va_start(ap, fmt);
+    vprintf (fmt, ap);
+    va_end(ap);
+int main()
+    /* Send notice and error messages to our stdout handler */
+    initGEOS(geos_message_handler, geos_message_handler);
+    /* One concave polygon */
+    const char* wkt = "POLYGON ((189 115, 200 170, 130 170, 35 242, 156 215, 210 290, 274 256, 360 190, 267 215, 300 50, 200 60, 189 115))";
+    /* Read the WKT into geometry objects */
+    GEOSWKTReader* reader = GEOSWKTReader_create();
+    GEOSGeometry* geom = GEOSWKTReader_read(reader, wkt);
+    GEOSWKTReader_destroy(reader);
+    /* Check for parse success */
+    if (!geom) {
+        finishGEOS();
+        return 1;
+    /* Prepare the geometry */
+    const GEOSPreparedGeometry* prep_geom = GEOSPrepare(geom);
+    /* Read bounds of geometry */
+    double xmin, xmax, ymin, ymax;
+    GEOSGeom_getXMin(geom, &xmin);
+    GEOSGeom_getXMax(geom, &xmax);
+    GEOSGeom_getYMin(geom, &ymin);
+    GEOSGeom_getYMax(geom, &ymax);
+    * Set up the point generator
+    * Generate all the points in the bounding box
+    * of the input polygon.
+    const int steps = 10;
+    double xstep = (xmax - xmin) / steps;
+    double ystep = (ymax - ymin) / steps;
+    /* Place to hold points to output */
+    GEOSGeometry** geoms = (GEOSGeometry**)malloc(steps*steps*sizeof(GEOSGeometry*));
+    size_t ngeoms = 0;
+    * Test all the points in the polygon bounding box
+    * and only keep those that intersect the actual polygon
+    int i, j;
+    for (i = 0; i < steps; i++) {
+        for (j = 0; j < steps; j++) {
+            /* Make a point in the point grid */
+            GEOSGeometry* pt = GEOSGeom_createPointFromXY(
+                                    xmin + xstep*i,
+                                    ymin + ystep*j);
+            /* Check if the point and polygon intersect */
+            if (GEOSPreparedIntersects(prep_geom, pt)) {
+                /* Save the ones that do */
+                geoms[ngeoms++] = pt;
+            else {
+                /* Clean up the ones that don't */
+                GEOSGeom_destroy(pt);
+    /* Put the successful geoms inside a geometry for WKT output */
+    GEOSGeometry* result = GEOSGeom_createCollection(GEOS_MULTIPOINT, geoms, ngeoms);
+    * The GEOSGeom_createCollection() only takes ownership of the
+    * geometries, not the array container, so we can free the container
+    * now
+    free(geoms);
+    /* Convert result to WKT */
+    GEOSWKTWriter* writer = GEOSWKTWriter_create();
+    /* Trim trailing zeros off output */
+    GEOSWKTWriter_setTrim(writer, 1);
+    GEOSWKTWriter_setRoundingPrecision(writer, 3);
+    char* wkt_result = GEOSWKTWriter_write(writer, result);
+    GEOSWKTWriter_destroy(writer);
+    /* Print answer */
+    printf("Input Polygon:\n");
+    printf("%s\n\n", wkt);
+    printf("Output Points:\n");
+    printf("%s\n\n", wkt_result);
+    /* Clean up everything we allocated */
+    GEOSPreparedGeom_destroy(prep_geom);
+    GEOSGeom_destroy(geom);
+    GEOSGeom_destroy(result);
+    GEOSFree(wkt_result);
+    /* Clean up the global context */
+    finishGEOS();
+    /* Done */
+    return 0;
diff --git a/examples/capi_read.cpp b/examples/capi_read.cpp
index 0000000..691dd9b
--- /dev/null
+++ b/examples/capi_read.cpp
@@ -0,0 +1,75 @@
+* # GEOS C API example 1
+* Reads two WKT representations and calculates the
+* intersection, prints it out, and cleans up.
+#include <stdio.h>
+static void
+    va_list ap;
+    va_end(ap);
+int main()
+    /* Two squares that overlap */
+    const char* wkt_a = "POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))";
+    const char* wkt_b = "POLYGON((5 5, 15 5, 15 15, 5 15, 5 5))";
+    GEOSGeometry* geom_a = GEOSWKTReader_read(reader, wkt_a);
+    GEOSGeometry* geom_b = GEOSWKTReader_read(reader, wkt_b);
+    /* Calculate the intersection */
+    GEOSGeometry* inter = GEOSIntersection(geom_a, geom_b);
+    char* wkt_inter = GEOSWKTWriter_write(writer, inter);
+    printf("Geometry A:         %s\n", wkt_a);
+    printf("Geometry B:         %s\n", wkt_b);
+    printf("Intersection(A, B): %s\n", wkt_inter);
+    GEOSGeom_destroy(geom_a);
+    GEOSGeom_destroy(geom_b);
+    GEOSGeom_destroy(inter);
+    GEOSFree(wkt_inter);
+    finishGEOS();
+    /* Done */
+    return 0;
diff --git a/examples/capi_read_ts.cpp b/examples/capi_read_ts.cpp
index 0000000..b351159
--- /dev/null
+++ b/examples/capi_read_ts.cpp
@@ -0,0 +1,86 @@
+* Thread-safe version of example 1. Uses the
+* re-entrant API.
+#include <stdio.h>
+static void
+    va_list ap;
+    va_end(ap);
+int main()
+    * Each thread using the re-entrant API must get its
+    * own context handle
+    GEOSContextHandle_t context = GEOS_init_r();
+    * The notice/error handlers route message back to the calling
+    * application. Here they just print to stdout.
+    GEOSContext_setNoticeHandler_r(context, geos_message_handler);
+    GEOSContext_setErrorHandler_r(context, geos_message_handler);
+    GEOSWKTReader* reader = GEOSWKTReader_create_r(context);
+    GEOSGeometry* geom_a = GEOSWKTReader_read_r(context, reader, wkt_a);
+    GEOSGeometry* geom_b = GEOSWKTReader_read_r(context, reader, wkt_b);
+    GEOSGeometry* inter = GEOSIntersection_r(context, geom_a, geom_b);
+    GEOSWKTWriter* writer = GEOSWKTWriter_create_r(context);
+    char* wkt_inter = GEOSWKTWriter_write_r(context, writer, inter);
+    GEOSWKTReader_destroy_r(context, reader);
+    GEOSWKTWriter_destroy_r(context, writer);
+    GEOSGeom_destroy_r(context, geom_a);
+    GEOSGeom_destroy_r(context, geom_b);
+    GEOSGeom_destroy_r(context, inter);
+    GEOSFree_r(context, wkt_inter);
+    GEOS_finish_r(context);
+    /* Done */
+    return 0;
diff --git a/examples/capi_strtree.c b/examples/capi_strtree.c
index 0000000..f654bfb
--- /dev/null
+++ b/examples/capi_strtree.c
@@ -0,0 +1,118 @@
+* # GEOS C API example 3
+* Build a spatial index and search it for a
+* nearest pair.
+#include <stdio.h>
+static void
+    va_list ap;
+    va_end(ap);
+* Generate a random point in the range of
+* POINT(0..range, 0..range). Caller must
+* free.
+static GEOSGeometry*
+geos_random_point(double range)
+    double x = range * rand() / RAND_MAX;
+    double y = range * rand() / RAND_MAX;
+    return GEOSGeom_createPointFromXY(x, y);
+int main()
+    /* How many points to add to our random field */
+    const size_t npoints = 10000;
+    /* The coordinate range of the field (0->100.0) */
+    const double range = 100.0;
+    * The tree doesn't take ownership of inputs just
+    * holds references, so we keep our point field
+    * handy in an array
+    GEOSGeometry* geoms[npoints];
+    * The create parameter for the tree is not the
+    * number of inputs, it is the number of entries
+    * per node. 10 is a good default number to use.
+    GEOSSTRtree* tree = GEOSSTRtree_create(10);
+    for (size_t i = 0; i < npoints; i++) {
+        /* Make a random point */
+        GEOSGeometry* geom = geos_random_point(range);
+        /* Store away a reference so we can free it after */
+        geoms[i] = geom;
+        /* Add an entry for it to the tree */
+        GEOSSTRtree_insert(tree, geom, geom);
+    /* Random point to compare to the field */
+    GEOSGeometry* geom_random = geos_random_point(range);
+    /* Nearest point in the field to our test point */
+    const GEOSGeometry* geom_nearest = GEOSSTRtree_nearest(tree, geom_random);
+    /* Convert results to WKT */
+    char* wkt_random = GEOSWKTWriter_write(writer, geom_random);
+    char* wkt_nearest = GEOSWKTWriter_write(writer, geom_nearest);
+    printf(" Random Point: %s\n", wkt_random);
+    printf("Nearest Point: %s\n", wkt_nearest);
+    /* Clean up all allocated objects */
+    /* Destroying tree does not destroy inputs */
+    GEOSSTRtree_destroy(tree);
+    GEOSGeom_destroy(geom_random);
+    /* Destroy all the points in our random field */
+        GEOSGeom_destroy(geoms[i]);
+    * Don't forget to free memory allocated by the
+    * printing functions!
+    GEOSFree(wkt_random);
+    GEOSFree(wkt_nearest);
+    finishGEOS();
+    /* Done */
+    return 0;
Summary of changes:
 examples/CMakeLists.txt                         |   9 +-
 examples/README.md                              |   3 +-
 examples/{capi_prepared.c => capi_prepared.cpp} |   0
 examples/{capi_read.c => capi_read.cpp}         |   0
 examples/{capi_read_ts.c => capi_read_ts.cpp}   |   0
 examples/capi_strtree.c                         | 118 ++++++++++++++++++++++++
 6 files changed, 126 insertions(+), 4 deletions(-)
 copy examples/{capi_prepared.c => capi_prepared.cpp} (100%)
 copy examples/{capi_read.c => capi_read.cpp} (100%)
 copy examples/{capi_read_ts.c => capi_read_ts.cpp} (100%)
 create mode 100644 examples/capi_strtree.c
hooks/post-receive
More information about the geos-commits mailing list
