[geos-commits] [SCM] GEOS branch master updated. e6c6fa39e32caf8bc15022cd17f47334a510197b
Mon Jan 25 16:48:45 PST 2021
the project "GEOS".
       via  e6c6fa39e32caf8bc15022cd17f47334a510197b (commit)
      from  9dfef81cb651449287f95ea67510bfcdc03924a0 (commit)
revisions in full, below.
commit e6c6fa39e32caf8bc15022cd17f47334a510197b
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Jan 25 16:45:39 2021 -0800
    Check for invalid area before fixing polygonal result in Densifier and DPSimplifier
diff --git a/src/geom/util/Densifier.cpp b/src/geom/util/Densifier.cpp
index 5154888..e0c5387 100644
--- a/src/geom/util/Densifier.cpp
+++ b/src/geom/util/Densifier.cpp
@@ -91,6 +91,8 @@ Densifier::DensifyTransformer::transformMultiPolygon(const MultiPolygon* geom, c
 std::unique_ptr<Geometry>
 Densifier::DensifyTransformer::createValidArea(const Geometry* roughAreaGeom)
+    if (roughAreaGeom->isValid())
+        return Geometry::Ptr(roughAreaGeom->clone());
     return roughAreaGeom->buffer(0.0);
diff --git a/src/simplify/DouglasPeuckerSimplifier.cpp b/src/simplify/DouglasPeuckerSimplifier.cpp
index cad62a1..f32d302 100644
--- a/src/simplify/DouglasPeuckerSimplifier.cpp
+++ b/src/simplify/DouglasPeuckerSimplifier.cpp
@@ -95,7 +95,10 @@ DPTransformer::DPTransformer(double t)
 Geometry::Ptr
 DPTransformer::createValidArea(const Geometry* roughAreaGeom)
-    return Geometry::Ptr(roughAreaGeom->buffer(0.0));
+    bool isValidArea = roughAreaGeom->getDimension() == 2 && roughAreaGeom->isValid();
+    if (! isValidArea)
+        return Geometry::Ptr(roughAreaGeom->buffer(0.0));
 CoordinateSequence::Ptr
diff --git a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
index 3894b9c..6c34530 100644
--- a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
+++ b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
@@ -102,7 +102,7 @@ void object::test<3>
     std::string wkt_in("POLYGON ((120 120, 121 121, 122 122, 220 120, \
 					180 199, 160 200, 140 199, 120 120))");
-    std::string wkt_ex("POLYGON ((120 120, 140 199, 160 200, 180 199, 220 120, 120 120))");
+    std::string wkt_ex("POLYGON ((120 120, 220 120, 180 199, 160 200, 140 199, 120 120))");
     GeomPtr g(wktreader.read(wkt_in));
@@ -126,8 +126,8 @@ void object::test<4>
     std::string wkt_in("POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), \
-    std::string wkt_ex("POLYGON ((80 200, 160 200, 240 200, 240 60, 80 60, 80 200), \
-					(160 200, 140 199, 120 120, 220 120, 180 199, 160 200)))");
+    std::string wkt_ex("POLYGON ((80 200, 240 200, 240 60, 80 60, 80 200), \
+					(120 120, 220 120, 180 199, 160 200, 140 199, 120 120))");
@@ -396,4 +396,3 @@ void object::test<13>
 } // namespace tut
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index f4d1ac3..7aeb905 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -1291,14 +1291,13 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
             geom::Geometry* p_gT = gA;
             GeomPtr gRes(parseGeometry(opRes, "expected"));
-            // gRes->normalize();
+            gRes->normalize();
             geom::util::Densifier den(p_gT);
             double distanceTolerance = std::atof(opArg2.c_str());
             den.setDistanceTolerance(distanceTolerance);
             GeomPtr gRealRes = den.getResultGeometry();
-            // gRealRes->normalize();
+            gRealRes->normalize();
             if(gRes->compareTo(gRealRes.get()) == 0) {
                 success = 1;
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index dff83ad..5493792 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -25,6 +25,7 @@
 #include <geos/geom/prep/PreparedGeometryFactory.h>
 #include <geos/algorithm/construct/MaximumInscribedCircle.h>
 #include <geos/algorithm/MinimumBoundingCircle.h>
+#include <geos/geom/util/Densifier.h>
 #include <geos/operation/linemerge/LineMerger.h>
 #include <geos/operation/distance/DistanceOp.h>
 #include <geos/operation/relate/RelateOp.h>
@@ -79,7 +80,7 @@ GeomFunction::init()
         [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
             return new Result( geom->getBoundary() );
-    add("buffer", "cmputes the buffer of geometry A", 1, 1,
+    add("buffer", "computes the buffer of geometry A to a distance", 1, 1,
             return new Result( geom->buffer( d ) );
@@ -104,6 +105,13 @@ GeomFunction::init()
             return new Result( geom->covers( geomB.get() ) );
+    add("densify", "densifies geometry A to a distance ", 1, 1,
+        [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
+            geom::util::Densifier densifier( geom.get() );
+            densifier.setDistanceTolerance( d );
+            return new Result( densifier.getResultGeometry() );
     add("distance", "computes distance between geometry A and B", 2, 0,
             return new Result( geom->distance( geomB.get() ) );
Summary of changes:
 src/geom/util/Densifier.cpp                          |  2 ++
 src/simplify/DouglasPeuckerSimplifier.cpp            |  5 ++++-
 tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp |  7 +++----
 tests/xmltester/XMLTester.cpp                        |  5 ++---
 util/geosop/GeomFunction.cpp                         | 10 +++++++++-
 5 files changed, 20 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
