[geos-commits] [SCM] GEOS branch master updated. b2e7efc30a979954bf7dfa8fb252473afcd509b8
    git at osgeo.org
    git at osgeo.org
    Thu Jan 28 20:22:30 PST 2021
the project "GEOS".
       via  b2e7efc30a979954bf7dfa8fb252473afcd509b8 (commit)
      from  d60a6649ab6a7db05798afc8f2032fecd0aaa8eb (commit)
revisions in full, below.
commit b2e7efc30a979954bf7dfa8fb252473afcd509b8
Author: Daniel Baston <dbaston at gmail.com>
Date:   Thu Jan 28 23:20:44 2021 -0500
    Quiet more clang warnings
diff --git a/benchmarks/algorithm/InteriorPointAreaPerfTest.cpp b/benchmarks/algorithm/InteriorPointAreaPerfTest.cpp
index c5b25e2..df294fd 100644
--- a/benchmarks/algorithm/InteriorPointAreaPerfTest.cpp
+++ b/benchmarks/algorithm/InteriorPointAreaPerfTest.cpp
@@ -46,7 +46,7 @@ public:
     void
-    test(int nPts)
+    test(uint32_t nPts)
         Coordinate origin(ORG_X, ORG_Y);
         std::unique_ptr<geos::geom::Polygon> sinePoly =
@@ -108,7 +108,7 @@ private:
     createSineStar(const Coordinate& origin,
-                   double size, int nPts)
+                   double size, uint32_t nPts)
         using geos::geom::util::SineStarFactory;
diff --git a/benchmarks/operation/predicate/RectangleIntersectsPerfTest.cpp b/benchmarks/operation/predicate/RectangleIntersectsPerfTest.cpp
index fddcd17..a0ec8c1 100644
--- a/benchmarks/operation/predicate/RectangleIntersectsPerfTest.cpp
+++ b/benchmarks/operation/predicate/RectangleIntersectsPerfTest.cpp
@@ -43,7 +43,7 @@ public:
     void
-    test(int nPts)
         double size = 100;
         Coordinate origin(0, 0);
@@ -130,7 +130,7 @@ private:
     Polygon::Ptr
diff --git a/tests/unit/noding/NodedSegmentStringTest.cpp b/tests/unit/noding/NodedSegmentStringTest.cpp
index 12e4ada..630cb12 100644
--- a/tests/unit/noding/NodedSegmentStringTest.cpp
+++ b/tests/unit/noding/NodedSegmentStringTest.cpp
@@ -63,7 +63,7 @@ struct test_nodedsegmentstring_data {
     void
-    checkNoding(const std::string& wktLine, const std::string& wktNodes, std::vector<int> segmentIndex, const std::string& wktExpected)
+    checkNoding(const std::string& wktLine, const std::string& wktNodes, std::vector<size_t> segmentIndex, const std::string& wktExpected)
         using geos::noding::NodedSegmentString;
@@ -115,7 +115,7 @@ template<>
 void object::test<1>
-    auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0, 2);
+    auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0u, 2u);
     ensure(nullptr != cs.get());
@@ -151,7 +151,7 @@ template<>
 void object::test<2>
@@ -187,7 +187,7 @@ template<>
 void object::test<3>
@@ -260,7 +260,7 @@ void object::test<5>
     geos::geom::Coordinate p1(10, 0);
     cs->add(p0);
     cs->add(p1);
@@ -302,7 +302,7 @@ template<>
 void object::test<6>
-    std::vector<int> segmentIndex;
+    std::vector<size_t> segmentIndex;
     segmentIndex.push_back(0);
     segmentIndex.push_back(1);
diff --git a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
index de93d1b..b5bc8de 100644
--- a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
+++ b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
@@ -270,7 +270,7 @@ template<>
 void object::test<10>
-    int npoints = 1000; // vertices in sinstar test shape
+    std::size_t npoints = 1000; // vertices in sinstar test shape
     int ncells = 100; // number of columns/rows in test grid square
     double radius = 100.0;
@@ -309,7 +309,7 @@ void object::test<10>
                                          "TestBoth"};
     bool perfTest = false;
-    std::vector<int> m = {TestBoth};
+    std::vector<size_t> m = {TestBoth};
     if (perfTest) {
         m.push_back(TestIndexedFacetDistance);
         m.push_back(TestGeometryDistance);
Summary of changes:
 benchmarks/algorithm/InteriorPointAreaPerfTest.cpp           |  4 ++--
 .../operation/predicate/RectangleIntersectsPerfTest.cpp      |  4 ++--
 tests/unit/noding/NodedSegmentStringTest.cpp                 | 12 ++++++------
 tests/unit/operation/distance/IndexedFacetDistanceTest.cpp   |  4 ++--
 4 files changed, 12 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits
