[geos-commits] [SCM] GEOS branch master updated. d0c602b817e6ae8b97965956bc5ecf9763a3c563
git at osgeo.org
git at osgeo.org
Fri Jan 29 09:35:13 PST 2021
the project "GEOS".
via d0c602b817e6ae8b97965956bc5ecf9763a3c563 (commit)
from b2e7efc30a979954bf7dfa8fb252473afcd509b8 (commit)
revisions in full, below.
commit d0c602b817e6ae8b97965956bc5ecf9763a3c563
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Jan 29 12:34:30 2021 -0500
Clear more clang warnings
diff --git a/include/geos/geomgraph/index/SegmentIntersector.h b/include/geos/geomgraph/index/SegmentIntersector.h
index f2f55b6..bde18f5 100644
--- a/include/geos/geomgraph/index/SegmentIntersector.h
+++ b/include/geos/geomgraph/index/SegmentIntersector.h
@@ -112,7 +112,7 @@ public:
includeProper(newIncludeProper),
recordIsolated(newRecordIsolated),
numIntersections(0),
- bdyNodes{nullptr, nullptr},
+ bdyNodes{{nullptr, nullptr}},
numTests(0)
diff --git a/include/geos/operation/buffer/RightmostEdgeFinder.h b/include/geos/operation/buffer/RightmostEdgeFinder.h
index 2500b61..d32af1e 100644
--- a/include/geos/operation/buffer/RightmostEdgeFinder.h
+++ b/include/geos/operation/buffer/RightmostEdgeFinder.h
@@ -64,7 +64,7 @@ private:
int getRightmostSide(geomgraph::DirectedEdge* de, int index);
- int getRightmostSideOfSegment(geomgraph::DirectedEdge* de, int i);
+ static int getRightmostSideOfSegment(geomgraph::DirectedEdge* de, int i);
public:
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index c798f66..04773fe 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -190,7 +190,7 @@ LineSegment::closestPoints(const LineSegment& line)
// test for intersection
Coordinate intPt = intersection(line);
if(!intPt.isNull()) {
- return { intPt, intPt };
+ return {{ intPt, intPt }};
diff --git a/src/noding/snap/SnappingIntersectionAdder.cpp b/src/noding/snap/SnappingIntersectionAdder.cpp
index 2a7b504..cd0c1aa 100644
--- a/src/noding/snap/SnappingIntersectionAdder.cpp
+++ b/src/noding/snap/SnappingIntersectionAdder.cpp
@@ -112,8 +112,8 @@ bool
SnappingIntersectionAdder::isAdjacent(SegmentString* ss0, std::size_t segIndex0, SegmentString* ss1, std::size_t segIndex1)
if (ss0 != ss1) return false;
- long l0 = segIndex0;
- long l1 = segIndex1;
+ long l0 = static_cast<long>(segIndex0);
+ long l1 = static_cast<long>(segIndex1);
bool isAdjacent = (std::abs(l0 - l1) == 1);
if (isAdjacent) {
diff --git a/src/operation/buffer/RightmostEdgeFinder.cpp b/src/operation/buffer/RightmostEdgeFinder.cpp
index a45208b..9004eed 100644
--- a/src/operation/buffer/RightmostEdgeFinder.cpp
+++ b/src/operation/buffer/RightmostEdgeFinder.cpp
@@ -165,8 +165,8 @@ RightmostEdgeFinder::findRightmostEdgeAtVertex()
assert(minIndex > 0);
assert((std::size_t)minIndex < pts->getSize());
- const Coordinate& pPrev = pts->getAt(minIndex - 1);
- const Coordinate& pNext = pts->getAt(minIndex + 1);
+ const Coordinate& pPrev = pts->getAt(static_cast<std::size_t>(minIndex) - 1);
+ const Coordinate& pNext = pts->getAt(static_cast<std::size_t>(minIndex) + 1);
int orientation = Orientation::index(
minCoord,
pNext,
@@ -256,12 +256,14 @@ RightmostEdgeFinder::getRightmostSideOfSegment(DirectedEdge* de, int i)
// indicates edge is parallel to x-axis
- if(coord->getAt(i).y == coord->getAt(i + 1).y) {
+ const Coordinate& p0 = coord->getAt(static_cast<std::size_t>(i));
+ const Coordinate& p1 = coord->getAt(static_cast<std::size_t>(i) + 1);
+ if(p0.y == p1.y) {
return -1;
int pos = Position::LEFT;
- if(coord->getAt(i).y < coord->getAt(i + 1).y) {
+ if(p0.y < p1.y) {
pos = Position::RIGHT;
return pos;
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index c79af7a..33f6e8c 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -80,20 +80,20 @@ DistanceOp::nearestPoints(const Geometry* g0, const Geometry* g1)
DistanceOp::DistanceOp(const Geometry* g0, const Geometry* g1):
- geom{g0, g1},
+ geom{{g0, g1}},
terminateDistance(0.0),
minDistance(DoubleMax)
DistanceOp::DistanceOp(const Geometry& g0, const Geometry& g1):
- geom{&g0, &g1},
+ geom{{&g0, &g1}},
DistanceOp::DistanceOp(const Geometry& g0, const Geometry& g1, double tdist)
- geom{&g0, &g1},
+ geom{{&g0, &g1}},
terminateDistance(tdist),
diff --git a/src/operation/overlay/EdgeSetNoder.cpp b/src/operation/overlay/EdgeSetNoder.cpp
index 8d2448c..3ba98d7 100644
--- a/src/operation/overlay/EdgeSetNoder.cpp
+++ b/src/operation/overlay/EdgeSetNoder.cpp
@@ -49,8 +49,7 @@ EdgeSetNoder::getNodedEdges()
esi->computeIntersections(inputEdges, si, true);
//Debug.println("has proper int = " + si.hasProperIntersection());
std::vector<Edge*>* splitEdges = new std::vector<Edge*>();
- for(int i = 0; i < (int)inputEdges->size(); i++) {
- Edge* e = (*inputEdges)[i];
+ for(Edge* e : *inputEdges) {
e->getEdgeIntersectionList().addSplitEdges(splitEdges);
return splitEdges;
diff --git a/src/operation/overlay/ElevationMatrix.cpp b/src/operation/overlay/ElevationMatrix.cpp
index 128c368..262cb36 100644
--- a/src/operation/overlay/ElevationMatrix.cpp
+++ b/src/operation/overlay/ElevationMatrix.cpp
@@ -100,10 +100,10 @@ ElevationMatrix::ElevationMatrix(const Envelope& newEnv,
cellwidth = env.getWidth() / cols;
cellheight = env.getHeight() / rows;
- if(! cellwidth) {
+ if(cellwidth == 0) {
cols = 1;
- if(! cellheight) {
+ if(cellheight == 0) {
rows = 1;
@@ -159,7 +159,7 @@ ElevationMatrix::getCell(const Coordinate& c)
int col, row;
- if(! cellwidth) {
col = 0;
else {
@@ -169,7 +169,7 @@ ElevationMatrix::getCell(const Coordinate& c)
col = cols - 1;
row = 0;
else {
Summary of changes:
include/geos/geomgraph/index/SegmentIntersector.h | 2 +-
include/geos/operation/buffer/RightmostEdgeFinder.h | 2 +-
src/geom/LineSegment.cpp | 2 +-
src/noding/snap/SnappingIntersectionAdder.cpp | 4 ++--
src/operation/buffer/RightmostEdgeFinder.cpp | 10 ++++++----
src/operation/distance/DistanceOp.cpp | 6 +++---
src/operation/overlay/EdgeSetNoder.cpp | 3 +--
src/operation/overlay/ElevationMatrix.cpp | 8 ++++----
8 files changed, 19 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits
