[geos-commits] [SCM] GEOS branch master updated. d8a1b32762a799ad8364c48ba84924f61c93c132
git at osgeo.org
git at osgeo.org
Fri Jan 29 13:22:39 PST 2021
the project "GEOS".
via d8a1b32762a799ad8364c48ba84924f61c93c132 (commit)
from d0c602b817e6ae8b97965956bc5ecf9763a3c563 (commit)
revisions in full, below.
commit d8a1b32762a799ad8364c48ba84924f61c93c132
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Jan 29 16:22:09 2021 -0500
Quiet clang warnings
diff --git a/include/geos/io/StringTokenizer.h b/include/geos/io/StringTokenizer.h
index e502c73..5c00cb5 100644
--- a/include/geos/io/StringTokenizer.h
+++ b/include/geos/io/StringTokenizer.h
@@ -45,8 +45,8 @@ public:
~StringTokenizer() {}
int nextToken();
int peekNextToken();
- double getNVal();
- std::string getSVal();
+ double getNVal() const;
+ std::string getSVal() const;
private:
const std::string& str;
std::string stok;
diff --git a/src/index/quadtree/Node.cpp b/src/index/quadtree/Node.cpp
index 26a908e..894d42c 100644
--- a/src/index/quadtree/Node.cpp
+++ b/src/index/quadtree/Node.cpp
@@ -99,9 +99,9 @@ Node::find(const Envelope* searchEnv)
if(subnodeIndex == -1) {
return this;
- if(subnodes[subnodeIndex] != nullptr) {
+ if(subnodes[static_cast<std::size_t>(subnodeIndex)] != nullptr) {
// query lies in subquad, so search it
- Node* node = subnodes[subnodeIndex];
+ Node* node = subnodes[static_cast<std::size_t>(subnodeIndex)];
return node->find(searchEnv);
// no existing subquad, so return this one anyway
@@ -118,8 +118,8 @@ Node::insertNode(std::unique_ptr<Node> node)
if(node->level == level - 1) {
// We take ownership of node
- delete subnodes[index];
- subnodes[index] = node.release();
+ delete subnodes[static_cast<std::size_t>(index)];
+ subnodes[static_cast<std::size_t>(index)] = node.release();
//System.out.println("inserted");
@@ -132,8 +132,8 @@ Node::insertNode(std::unique_ptr<Node> node)
childNode->insertNode(std::move(node));
// We take ownership of childNode
- subnodes[index] = childNode.release();
+ subnodes[static_cast<std::size_t>(index)] = childNode.release();
@@ -141,10 +141,10 @@ Node*
Node::getSubnode(int index)
assert(index >= 0 && index < 4);
- if(subnodes[index] == nullptr) {
- subnodes[index] = createSubnode(index).release();
+ if(subnodes[static_cast<std::size_t>(index)] == nullptr) {
+ subnodes[static_cast<std::size_t>(index)] = createSubnode(index).release();
- return subnodes[index];
+ return subnodes[static_cast<std::size_t>(index)];
diff --git a/src/index/quadtree/Root.cpp b/src/index/quadtree/Root.cpp
index 516b816..697b2ca 100644
--- a/src/index/quadtree/Root.cpp
+++ b/src/index/quadtree/Root.cpp
@@ -65,7 +65,7 @@ Root::insert(const Envelope* itemEnv, void* item)
* the item must be contained in one quadrant, so insert it into the
* tree for that quadrant (which may not yet exist)
- Node* node = subnodes[index];
+ Node* node = subnodes[static_cast<std::size_t>(index)];
#if GEOS_DEBUG
std::cerr << "(" << this << ") subnode[" << index << "] @ " << node << std::endl;
@@ -78,7 +78,7 @@ Root::insert(const Envelope* itemEnv, void* item)
if(node == nullptr || !node->getEnvelope()->contains(itemEnv)) {
std::unique_ptr<Node> snode(node); // may be NULL
node = nullptr;
- subnodes[index] = nullptr;
+ subnodes[static_cast<std::size_t>(index)] = nullptr;
std::unique_ptr<Node> largerNode =
Node::createExpanded(std::move(snode), *itemEnv);
@@ -89,8 +89,8 @@ Root::insert(const Envelope* itemEnv, void* item)
#endif
// Previous subnode was passed as a child of the larger one
- assert(!subnodes[index]);
- subnodes[index] = largerNode.release();
+ assert(!subnodes[static_cast<std::size_t>(index)]);
+ subnodes[static_cast<std::size_t>(index)] = largerNode.release();
#if GEOS_DEBUG
@@ -100,7 +100,7 @@ Root::insert(const Envelope* itemEnv, void* item)
* At this point we have a subquad which exists and must contain
* contains the env for the item. Insert the item into the tree.
- insertContained(subnodes[index], itemEnv, item);
+ insertContained(subnodes[static_cast<std::size_t>(index)], itemEnv, item);
#if GEOS_DEBUG
std::cerr << "(" << this << ") done calling insertContained with subnode " << subnode[index] << std::endl;
diff --git a/src/index/strtree/STRtree.cpp b/src/index/strtree/STRtree.cpp
index 0043de5..c26c80f 100644
--- a/src/index/strtree/STRtree.cpp
+++ b/src/index/strtree/STRtree.cpp
@@ -58,7 +58,7 @@ STRtree::createParentBoundables(BoundableList* childBoundables, int newLevel)
std::unique_ptr<BoundableList> sortedChildBoundables(sortBoundablesX(childBoundables));
std::unique_ptr< std::vector<BoundableList*> > verticalSlicesV(
- verticalSlices(sortedChildBoundables.get(), (int)ceil(sqrt((double)minLeafCount)))
+ verticalSlices(sortedChildBoundables.get(), static_cast<std::size_t>(std::ceil(std::sqrt(static_cast<double>(minLeafCount)))))
std::unique_ptr<BoundableList> ret(
diff --git a/src/io/StringTokenizer.cpp b/src/io/StringTokenizer.cpp
index 173c1f4..b536120 100644
--- a/src/io/StringTokenizer.cpp
+++ b/src/io/StringTokenizer.cpp
@@ -92,17 +92,17 @@ StringTokenizer::nextToken()
case '\t':
case ' ':
string::size_type pos = str.find_first_not_of(" \n\r\t",
- iter - str.begin());
+ static_cast<string::size_type>(iter - str.begin()));
if(pos == string::npos) {
return StringTokenizer::TT_EOF;
else {
- iter = str.begin() + pos;
+ iter = str.begin() + static_cast<string::difference_type>(pos);
return nextToken();
string::size_type pos = str.find_first_of("\n\r\t() ,",
if(iter != str.end()) {
tok.assign(iter, str.end());
@@ -113,8 +113,8 @@ StringTokenizer::nextToken()
else {
- tok.assign(iter, str.begin() + pos);
+ tok.assign(iter, str.begin() + static_cast<string::difference_type>(pos));
char* stopstring;
double dbl = strtod_with_vc_fix(tok.c_str(), &stopstring);
@@ -141,7 +141,7 @@ StringTokenizer::peekNextToken()
- pos = str.find_first_not_of(" \r\n\t", iter - str.begin());
+ pos = str.find_first_not_of(" \r\n\t", static_cast<string::size_type>(iter - str.begin()));
@@ -156,7 +156,7 @@ StringTokenizer::peekNextToken()
// It's either a Number or a Word, let's
// see when it ends
- pos = str.find_first_of("\n\r\t() ,", iter - str.begin());
+ pos = str.find_first_of("\n\r\t() ,", static_cast<string::size_type>(iter - str.begin()));
@@ -167,7 +167,7 @@ StringTokenizer::peekNextToken()
else {
- tok.assign(iter, str.begin() + pos); //str.end());
+ tok.assign(iter, str.begin() + static_cast<string::difference_type>(pos)); //str.end());
char* stopstring;
@@ -186,14 +186,14 @@ StringTokenizer::peekNextToken()
/*public*/
double
-StringTokenizer::getNVal()
+StringTokenizer::getNVal() const
return ntok;
/*public*/
string
-StringTokenizer::getSVal()
+StringTokenizer::getSVal() const
return stok;
diff --git a/src/triangulate/VoronoiDiagramBuilder.cpp b/src/triangulate/VoronoiDiagramBuilder.cpp
index 46aa9f0..b3a0db5 100644
--- a/src/triangulate/VoronoiDiagramBuilder.cpp
+++ b/src/triangulate/VoronoiDiagramBuilder.cpp
@@ -73,7 +73,7 @@ VoronoiDiagramBuilder::setTolerance(double nTolerance)
void
VoronoiDiagramBuilder::create()
- if(subdiv.get()) {
+ if(subdiv) {
return;
Summary of changes:
include/geos/io/StringTokenizer.h | 4 ++--
src/index/quadtree/Node.cpp | 18 +++++++++---------
src/index/quadtree/Root.cpp | 10 +++++-----
src/index/strtree/STRtree.cpp | 2 +-
src/io/StringTokenizer.cpp | 20 ++++++++++----------
src/triangulate/VoronoiDiagramBuilder.cpp | 2 +-
6 files changed, 28 insertions(+), 28 deletions(-)
hooks/post-receive
More information about the geos-commits
