[geos-commits] [SCM] GEOS branch main updated. f65bb355896a9bebc4a52a638c2c67df4959ffb7
Fri Oct 15 13:12:57 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  f65bb355896a9bebc4a52a638c2c67df4959ffb7 (commit)
      from  a08dcd4dfdd722e454d4dc89dbef77a70fad5974 (commit)
revisions in full, below.
commit f65bb355896a9bebc4a52a638c2c67df4959ffb7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Oct 15 13:12:43 2021 -0700
    Use OBJECT library to build ryu, so it can be fully included in
    static libgeos.a, and up the cmake requirement to 3.13 to support
    that change. References #1103
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 56ea589..0c3c2e1 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -39,7 +39,7 @@ jobs:
           cxxstd: 11,
           arch: 64,
           packages: 'clang',
-          cmake: 3.10.*,
+          cmake: 3.13.*,
           os: ubuntu-18.04
@@ -48,7 +48,7 @@ jobs:
           cxxstd: 11,
           arch: 64,
           packages: 'clang',
-          cmake: 3.10.*,
+          cmake: 3.13.*,
           os: ubuntu-18.04
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 896dfb8..56d9494 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -9,9 +9,9 @@
 # See the COPYING file for more information.
-# Require CMake 3.8+ with support for meta-features that request compiler
-# modes for specific C/C++ language standard levels.
-cmake_minimum_required(VERSION 3.8)
+# Require CMake 3.13+ with support for meta-features that request compiler
+# modes for specific C/C++ language standard levels, and object libraries.
+cmake_minimum_required(VERSION 3.13)
 # Default to release build so packagers don't release debug builds
 set(DEFAULT_BUILD_TYPE Release)
diff --git a/src/deps/CMakeLists.txt b/src/deps/CMakeLists.txt
index a8be0a5..5c8ed27 100644
--- a/src/deps/CMakeLists.txt
+++ b/src/deps/CMakeLists.txt
@@ -9,7 +9,7 @@
 file(GLOB_RECURSE _sources ${CMAKE_CURRENT_LIST_DIR}/*.c  CONFIGURE_DEPEND)
-add_library(ryu STATIC ${_sources})
+add_library(ryu OBJECT ${_sources})
 target_include_directories(ryu PUBLIC ${CMAKE_CURRENT_LIST_DIR})
 set_target_properties(ryu PROPERTIES
   POSITION_INDEPENDENT_CODE ON
Summary of changes:
 .github/workflows/ci.yml | 4 ++--
 CMakeLists.txt           | 6 +++---
 src/deps/CMakeLists.txt  | 2 +-
 3 files changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
