[geos-commits] [SCM] GEOS branch main updated. 9915ef54ef2648a6d5e149c8e19f7e0f24be0bb9
git at osgeo.org
git at osgeo.org
Fri Oct 15 13:34:40 PDT 2021
the project "GEOS".
The branch, main has been updated
via 9915ef54ef2648a6d5e149c8e19f7e0f24be0bb9 (commit)
from f65bb355896a9bebc4a52a638c2c67df4959ffb7 (commit)
revisions in full, below.
commit 9915ef54ef2648a6d5e149c8e19f7e0f24be0bb9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Oct 15 13:34:37 2021 -0700
More detailed description of setPrecision options
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 1e2171b..12f743f 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1384,9 +1384,11 @@ extern int GEOS_DLL GEOSNormalize_r(
* when altering the precision of a geometry.
enum GEOSPrecisionRules {
- /** This option causes GEOSGeom_setPrecision() to not attempt at preserving the topology */
+ /** The output is always valid. Collapsed geometry elements (including both polygons and lines) are removed. */
+ GEOS_PREC_VALID_OUTPUT = 0,
+ /** Precision reduction is performed pointwise. Output geometry may be invalid due to collapse or self-intersection. (This might be better called "GEOS_PREC_POINTWISE" - the current name is historical.) */
GEOS_PREC_NO_TOPO = 1,
- /** This option causes GEOSGeom_setPrecision() to retain collapsed elements */
+ /** Like the default mode, except that collapsed linear geometry elements are preserved. Collapsed polygonal input elements are removed. */
GEOS_PREC_KEEP_COLLAPSED = 2
@@ -3759,6 +3761,15 @@ extern int GEOS_DLL GEOSNormalize(GEOSGeometry* g);
* of the geometry with higher precision (smaller "gridSize").
* That same precision will be attached to the operation outputs.
+* In the Default and GEOS_PREC_KEEP_COLLAPSED modes invalid input
+* may cause an error to occur, unless the invalidity is below
+* the scale of the requested precision
+* There are only 3 modes. The GEOS_PREC_NO_TOPO mode
+* takes precedence over GEOS_PREC_KEEP_COLLAPSED.
+* So the combination GEOS_PREC_NO_TOPO || GEOS_PREC_KEEP_COLLAPSED
+* has the same semantics as GEOS_PREC_NO_TOPO
* \param g Input geometry
* \param gridSize cell size of grid to round coordinates to,
* or 0 for FLOATING precision
Summary of changes:
capi/geos_c.h.in | 15 +++++++++++++--
1 file changed, 13 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
