[geos-commits] [SCM] GEOS branch main updated. b541b57849a3148706ac2ce5f4a41453d50bde65
git at osgeo.org
git at osgeo.org
Fri Oct 29 10:57:06 PDT 2021
the project "GEOS".
The branch, main has been updated
via b541b57849a3148706ac2ce5f4a41453d50bde65 (commit)
via 15029298a3d64550439504083f48e2714fb17dec (commit)
from 31deb41d81529756b9e47b9c8f2576849463b488 (commit)
revisions in full, below.
commit b541b57849a3148706ac2ce5f4a41453d50bde65
Merge: 31deb41d8 15029298a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Oct 29 10:55:32 2021 -0700
Merge branch 'invert_unionSafe_conditions' of https://github.com/eyal0/geos into main
commit 15029298a3d64550439504083f48e2714fb17dec
Author: eyal0 <109809+eyal0 at users.noreply.github.com>
Date: Thu Oct 28 21:06:38 2021 -0600
Invert conditional in unionSafe()
This prevents the compiler from mistakenly thinking that the
dereferenced geometry is . The compiler *should* have been able to
figure this out and suppress the warning but it doesn't.
This change shouldn't affect the functionality of the code. It only
gives a better hint to the compiler about the validity of the pointer
to Geometry.
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index c30c6f7eb..1db99e630 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -120,18 +120,17 @@ CascadedPolygonUnion::binaryUnion(const std::vector<const geom::Geometry*> & geo
std::unique_ptr<geom::Geometry>
CascadedPolygonUnion::unionSafe(const geom::Geometry* g0, const geom::Geometry* g1) const
- if(g0 == nullptr && g1 == nullptr) {
- return nullptr;
+ if(g0 != nullptr && g1 != nullptr) {
+ return unionActual(g0, g1);
- if(g0 == nullptr) {
+ if(g1 != nullptr) {
return g1->clone();
- if(g1 == nullptr) {
+ if(g0 != nullptr) {
return g0->clone();
- return unionActual(g0, g1);
+ return nullptr;
Summary of changes:
src/operation/union/CascadedPolygonUnion.cpp | 11 +++++------
1 file changed, 5 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
