[geos-commits] [SCM] GEOS branch main updated. 88ec9b8944fb94ef03afd54938679b0670227000
Fri Oct 29 10:59:31 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  88ec9b8944fb94ef03afd54938679b0670227000 (commit)
       via  5a2effad55b0d9c550035bb216f0810523a5c0b6 (commit)
       via  c9a114a78d39f58db593915ab86c32c980a8cc08 (commit)
      from  b541b57849a3148706ac2ce5f4a41453d50bde65 (commit)
revisions in full, below.
commit 88ec9b8944fb94ef03afd54938679b0670227000
Merge: b541b5784 5a2effad5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Oct 29 10:59:24 2021 -0700
    Merge branch 'eyal0-build_msys2_release' into main
commit 5a2effad55b0d9c550035bb216f0810523a5c0b6
Merge: b541b5784 c9a114a78
Date:   Fri Oct 29 10:57:49 2021 -0700
    Merge branch 'build_msys2_release' of https://github.com/eyal0/geos into eyal0-build_msys2_release
commit c9a114a78d39f58db593915ab86c32c980a8cc08
Author: eyal0 <109809+eyal0 at users.noreply.github.com>
Date:   Thu Oct 28 21:11:43 2021 -0600
    Add a mingw Release build to CI with updated msys2.
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 223cb7845..6ec0ebdb5 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -157,6 +157,7 @@ jobs:
       uses: msys2/setup-msys2 at v2
       with:
         install: mingw-w64-x86_64-gcc mingw-w64-x86_64-cmake make
+        update: true
     - name: 'Build'
       run: |
@@ -167,6 +168,31 @@ jobs:
        cmake --build . -j 2
        ctest --output-on-failure .
+  windows-mingw-release:
+    name: 'Windows (mingw-w64, Release, 11, x86_64, windows-2019)'
+    runs-on: windows-2019
+    defaults:
+      run:
+        shell: msys2 {0}
+    steps:
+    - name: 'Check Out'
+      uses: actions/checkout at v2
+    - name: 'Setup'
+      uses: msys2/setup-msys2 at v2
+      with:
+        install: mingw-w64-x86_64-gcc mingw-w64-x86_64-cmake make
+        update: true
+    - name: 'Build'
+      run: |
+       mkdir build
+       cd build
+       cmake --version
+       cmake -DCMAKE_BUILD_TYPE=Release -G"MSYS Makefiles" ..
+       cmake --build . -j 2
+       ctest --output-on-failure .
   windows-msvc-19:
     name: 'Windows (Visual Studio 2019, Release, windows-2019)'
Summary of changes:
 .github/workflows/ci.yml | 26 ++++++++++++++++++++++++++
 1 file changed, 26 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
