[geos-commits] [SCM] GEOS branch main updated. 6839f11f7cf27ed051a9900224e50a56a7d92f21
git at osgeo.org
git at osgeo.org
Wed Sep 8 13:37:06 PDT 2021
the project "GEOS".
The branch, main has been updated
via 6839f11f7cf27ed051a9900224e50a56a7d92f21 (commit)
from 5bb0eba2b33b924440b356334540e64b60c86201 (commit)
revisions in full, below.
commit 6839f11f7cf27ed051a9900224e50a56a7d92f21
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Sep 8 13:37:01 2021 -0700
Handle failure of createPolygon and clean up memory before throwing exception, closes #1111
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 2211d0f..350c685 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2618,15 +2618,31 @@ extern "C" {
return execute(extHandle, [&]() {
GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
const GeometryFactory* gf = handle->geomFactory;
+ bool good_holes = true, good_shell = true;
// Validate input before taking ownership
- for (size_t i = 0; i < nholes; i++) {
+ for (std::size_t i = 0; i < nholes; i++) {
if (!dynamic_cast<LinearRing*>(holes[i])) {
- throw IllegalArgumentException("Hole is not a LinearRing");
+ good_holes = false;
+ break;
if (!dynamic_cast<LinearRing*>(shell)) {
- throw IllegalArgumentException("Shell is not a LinearRing");
+ good_shell = false;
+ // Contract for GEOSGeom_createPolygon is to take ownership of arguments
+ // which implies freeing them on exception,
+ // see https://trac.osgeo.org/geos/ticket/1111
+ if (!(good_holes && good_shell)) {
+ delete shell;
+ delete holes[i];
+ if (!good_shell)
+ throw IllegalArgumentException("Shell is not a LinearRing");
+ else
+ throw IllegalArgumentException("Hole is not a LinearRing");
std::unique_ptr<LinearRing> tmpshell(static_cast<LinearRing*>(shell));
diff --git a/tests/unit/capi/GEOSGeom_createPolygonTest.cpp b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
index 025d4f6..ee73562 100644
--- a/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
@@ -50,5 +50,31 @@ void object::test<1>
free(holes);
+template<>
+template<>
+void object::test<2>
+ GEOSCoordSequence* shell_seq = GEOSCoordSeq_create(5, 2);
+ double shell_coords[] = {0,0, 0,10, 10,10, 10,0, 0,0};
+ for (unsigned int i = 0; i < 5; i++) {
+ GEOSCoordSeq_setXY(shell_seq, i, shell_coords[2*i], shell_coords[2*i+1]);
+ GEOSGeometry* shell = GEOSGeom_createLineString(shell_seq);
+ GEOSGeometry** holes = nullptr;
+ unsigned int nholes = 0;
+ // Returns null on exception, wrong input type for shell
+ GEOSGeometry* polygon = GEOSGeom_createPolygon(shell, holes, nholes);
+ ensure(polygon == nullptr);
+ // Shouldn't need this
+ if (polygon)
+ GEOSGeom_destroy(polygon);
} // namespace tut
Summary of changes:
capi/geos_ts_c.cpp | 22 +++++++++++++++++++---
tests/unit/capi/GEOSGeom_createPolygonTest.cpp | 26 ++++++++++++++++++++++++++
2 files changed, 45 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
