[geos-commits] [SCM] GEOS branch main updated. 3c7205e09413f62e1c940052c2cf376bfb36f080
Wed Sep 8 14:23:40 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  3c7205e09413f62e1c940052c2cf376bfb36f080 (commit)
      from  6839f11f7cf27ed051a9900224e50a56a7d92f21 (commit)
revisions in full, below.
commit 3c7205e09413f62e1c940052c2cf376bfb36f080
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Sep 8 14:23:34 2021 -0700
    Guard against some null inputs, references #1111
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 350c685..092e0e2 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2622,7 +2622,7 @@ extern "C" {
             // Validate input before taking ownership
             for (std::size_t i = 0; i < nholes; i++) {
-                if (!dynamic_cast<LinearRing*>(holes[i])) {
+                if ((!holes) || (!dynamic_cast<LinearRing*>(holes[i]))) {
                     good_holes = false;
                     break;
@@ -2635,9 +2635,10 @@ extern "C" {
             // which implies freeing them on exception,
             // see https://trac.osgeo.org/geos/ticket/1111
             if (!(good_holes && good_shell)) {
-                delete shell;
+                if (shell) delete shell;
-                    delete holes[i];
+                    if (holes && holes[i])
+                        delete holes[i];
                 if (!good_shell)
                     throw IllegalArgumentException("Shell is not a LinearRing");
diff --git a/tests/unit/capi/GEOSGeom_createPolygonTest.cpp b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
index ee73562..79f426d 100644
--- a/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
@@ -75,6 +75,27 @@ void object::test<2>
         GEOSGeom_destroy(polygon);
+template<>
+template<>
+void object::test<3>
+    GEOSGeometry* shell = nullptr;
+    GEOSGeometry** holes = nullptr;
+    unsigned int nholes = 0;
+    // Returns null on exception, wrong input type for shell
+    GEOSGeometry* polygon = GEOSGeom_createPolygon(shell, holes, 0);
+    ensure(polygon == nullptr);
+    GEOSGeometry* polygon = GEOSGeom_createPolygon(shell, holes, 1);
+    // Shouldn't need this
+    if (polygon)
+        GEOSGeom_destroy(polygon);
 } // namespace tut
Summary of changes:
 capi/geos_ts_c.cpp                             |  7 ++++---
 tests/unit/capi/GEOSGeom_createPolygonTest.cpp | 21 +++++++++++++++++++++
 2 files changed, 25 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
