[geos-commits] [SCM] GEOS branch main updated. 9e3aa68491ca56a93181e6a11272bb1feef06161
git at osgeo.org
git at osgeo.org
Thu Sep 9 16:19:31 PDT 2021
the project "GEOS".
The branch, main has been updated
via 9e3aa68491ca56a93181e6a11272bb1feef06161 (commit)
from dd26e4a6d97cd6dd1857736465270ac27ccaf875 (commit)
revisions in full, below.
commit 9e3aa68491ca56a93181e6a11272bb1feef06161
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Sep 9 16:18:26 2021 -0700
Support ISO WKB in WKBWriter.
Added GEOSWKBWriter_setFlavor and GEOSWKBWriter_getFlavor
to the CAPI.
Closes #466
diff --git a/NEWS b/NEWS
index da9ee04..f016ecb 100644
--- a/NEWS
+++ b/NEWS
@@ -13,6 +13,8 @@ Changes in 3.10.0
- CAPI: GEOSMakeValidWithParams new validity enforcement approach from
https://github.com/locationtech/jts/pull/704, uses GeometryFixer
(Paul Ramsey, Martin Davis)
+ - CAPI: GEOSWKBWriter_getFlavor, GEOSWKBWriter_setFlavor support
+ outputting ISO or Extended WKB flavors (#466, Paul Ramsey)
- Fixes/Improvements:
- Preserve ordering of lines in overlay results (Martin Davis)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index f4f3ed0..6134356 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -1281,6 +1281,18 @@ extern "C" {
GEOSWKBWriter_setByteOrder_r(handle, writer, newByteOrder);
+ int
+ GEOSWKBWriter_getFlavor(const GEOSWKBWriter* writer)
+ return GEOSWKBWriter_getFlavor_r(handle, writer);
+ void
+ GEOSWKBWriter_setFlavor(GEOSWKBWriter* writer, int newFlavor)
+ GEOSWKBWriter_setFlavor_r(handle, writer, newFlavor);
char
GEOSWKBWriter_getIncludeSRID(const GEOSWKBWriter* writer)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 68d1df3..0a3cb9d 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -218,7 +218,7 @@ enum GEOSGeomTypes {
* \see GEOSWKBWriter_setByteOrder
-enum GEOSByteOrders {
+enum GEOSWKBByteOrders {
/** Big Endian */
GEOS_WKB_XDR = 0,
/** Little Endian */
@@ -226,6 +226,22 @@ enum GEOSByteOrders {
+* Well-known binary flavors to use
+* when writing to WKB. ISO flavour is
+* more standard. Extended flavour supports
+* 3D and SRID embedding. GEOS reads both
+* transparently.
+* \see GEOSWKBWriter_setFlavor
+enum GEOSWKBFlavors {
+ /** Extended */
+ GEOS_WKB_EXTENDED = 1,
+ /** ISO */
+ GEOS_WKB_ISO = 2
* Callback function for use in spatial index search calls. Pass into
* the query function and handle query results as the index
* returns them.
@@ -1734,6 +1750,17 @@ extern void GEOS_DLL GEOSWKBWriter_setByteOrder_r(
int byteOrder);
+/** \see GEOSWKBWriter_getFlavor */
+extern int GEOS_DLL GEOSWKBWriter_getFlavor_r(
+ GEOSContextHandle_t handle,
+ const GEOSWKBWriter* writer);
+/** \see GEOSWKBWriter_setFlavor */
+extern void GEOS_DLL GEOSWKBWriter_setFlavor_r(
+ GEOSWKBWriter* writer,
+ int flavor);
/** \see GEOSWKBWriter_getIncludeSRID */
extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID_r(
@@ -4251,7 +4278,7 @@ extern void GEOS_DLL GEOSWKBWriter_setOutputDimension(
* Find whether the writer will use WKB
* [byte order](https://en.wikipedia.org/wiki/Endianness)
* that is big or little endian.
-* The return value is a member of \ref GEOSByteOrders.
+* The return value is a member of \ref GEOSWKBByteOrders.
* \param writer The writer to read byte order from
* \return The current byte order
@@ -4260,7 +4287,7 @@ extern int GEOS_DLL GEOSWKBWriter_getByteOrder(
* Set the output byte order of the writer, using
-* a value from \ref GEOSByteOrders enum.
+* a value from \ref GEOSWKBByteOrders enum.
* \param writer The writer to set byte order on
* \param byteOrder Desired byte order
@@ -4269,6 +4296,31 @@ extern void GEOS_DLL GEOSWKBWriter_setByteOrder(
int byteOrder);
+* Find whether the writer will use
+* [WKB](https://en.wikipedia.org/wiki/Well-known_text_representation_of_geometry#Well-known_binary)
+* that is ISO flavor or "extended" flavor. The flavor
+* determines how extra dimensionality is encoded with the
+* type number, and whether SRID can be included in the WKB.
+* ISO flavor does not support SRID embedding. ISO flavor
+* is "more standard" for 3D output. GEOS can read both flavors.
+* The return value is a member of \ref GEOSWKBFlavors.
+* \param writer The writer to read flavor from
+* \return The current flavor
+extern int GEOS_DLL GEOSWKBWriter_getFlavor(
+* Set the output flavor of the writer, using
+* a value from \ref GEOSWKBFlavors enum.
+* \param writer The writer to set flavor on
+* \param flavor Desired flavor
+extern void GEOS_DLL GEOSWKBWriter_setFlavor(
+ int flavor);
* Read the current SRID embedding value from the writer.
* \param writer The writer to check SRID value on
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 092e0e2..ee4beea 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -3058,6 +3058,22 @@ extern "C" {
+ int
+ GEOSWKBWriter_getFlavor_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
+ return execute(extHandle, -1, [&]{
+ return writer->getFlavor();
+ void
+ GEOSWKBWriter_setFlavor_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, int flavor)
+ execute(extHandle, [&]{
+ writer->setFlavor(flavor);
/* GeoJSON Reader */
GeoJSONReader*
GEOSGeoJSONReader_create_r(GEOSContextHandle_t extHandle)
diff --git a/include/geos/io/WKBConstants.h b/include/geos/io/WKBConstants.h
index 59ab732..147a225 100644
--- a/include/geos/io/WKBConstants.h
+++ b/include/geos/io/WKBConstants.h
@@ -17,8 +17,7 @@
-#ifndef GEOS_IO_WKBCONSTANTS_H
-#define GEOS_IO_WKBCONSTANTS_H
+#pragma once
namespace geos {
namespace io {
@@ -26,22 +25,28 @@ namespace io {
/// Constant values used by the WKB format
namespace WKBConstants {
-/// Big Endian
-const int wkbXDR = 0;
+ enum byteOrder {
+ wkbXDR = 0,
+ wkbNDR = 1
+ enum wkbType {
+ wkbPoint = 1,
+ wkbLineString = 2,
+ wkbPolygon = 3,
+ wkbMultiPoint = 4,
+ wkbMultiLineString = 5,
+ wkbMultiPolygon = 6,
+ wkbGeometryCollection = 7
+ enum wkbFlavour {
+ wkbIso = 1,
+ wkbExtended = 2
-/// Little Endian
-const int wkbNDR = 1;
-const int wkbPoint = 1;
-const int wkbLineString = 2;
-const int wkbPolygon = 3;
-const int wkbMultiPoint = 4;
-const int wkbMultiLineString = 5;
-const int wkbMultiPolygon = 6;
-const int wkbGeometryCollection = 7;
} // namespace geos::io
} // namespace geos
-#endif // #ifndef GEOS_IO_WKBCONSTANTS_H
diff --git a/include/geos/io/WKBWriter.h b/include/geos/io/WKBWriter.h
index fd15f49..a648e1d 100644
--- a/include/geos/io/WKBWriter.h
+++ b/include/geos/io/WKBWriter.h
@@ -23,6 +23,7 @@
#include <geos/export.h>
#include <geos/util/Machine.h> // for getMachineByteOrder
+#include <geos/io/WKBConstants.h>
#include <iosfwd>
#include <cstdint>
#include <cstddef>
@@ -86,20 +87,24 @@ public:
* @param incudeSRID true if SRID should be included in WKB (an
* extension).
- WKBWriter(uint8_t dims = 2, int bo = getMachineByteOrder(), bool includeSRID = false);
+ WKBWriter(
+ uint8_t dims = 2,
+ int bo = getMachineByteOrder(),
+ bool includeSRID = false,
+ int flv = WKBConstants::wkbExtended);
* \brief
* Destructor.
- virtual ~WKBWriter() = default;
+ ~WKBWriter() = default;
* \brief
* Returns the output dimension used by the
* <code>WKBWriter</code>.
- virtual uint8_t
+ uint8_t
getOutputDimension() const
return defaultOutputDimension;
@@ -112,14 +117,14 @@ public:
* Note that 3 indicates up to 3 dimensions will be written but
* 2D WKB is still produced for 2D geometries.
- virtual void setOutputDimension(uint8_t newOutputDimension);
+ void setOutputDimension(uint8_t newOutputDimension);
* \brief
* Returns the byte order used by the
- virtual int
+ int
getByteOrder() const
return byteOrder;
@@ -129,14 +134,14 @@ public:
* Sets the byte order used by the
- virtual void setByteOrder(int newByteOrder);
+ void setByteOrder(int newByteOrder);
* \brief
* Returns whether SRID values are output by the
- virtual bool
+ bool
getIncludeSRID() const
return includeSRID;
@@ -146,12 +151,28 @@ public:
* Sets whether SRID values should be output by the
- virtual void
+ void
setIncludeSRID(bool newIncludeSRID)
includeSRID = newIncludeSRID;
+ * \brief
+ * Returns the WKB flavor the writer will emit.
+ int
+ getFlavor() const
+ return flavor;
+ * \brief
+ * Set the WKB flavor the writer will emit.
+ void setFlavor(int newFlavor);
* \brief Write a Geometry to an ostream.
@@ -174,10 +195,14 @@ public:
private:
+ // 2 or 3
uint8_t defaultOutputDimension;
uint8_t outputDimension;
+ // WKBConstants::wkbwkbXDR | WKBConstants::wkbNDR
int byteOrder;
+ // WKBConstants::wkbIso | WKBConstants::wkbExtended
+ int flavor;
bool includeSRID;
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index 8957717..23424d1 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -18,7 +18,6 @@
#include <geos/io/WKBWriter.h>
#include <geos/io/WKBReader.h>
-#include <geos/io/WKBConstants.h>
#include <geos/io/ByteOrderValues.h>
#include <geos/util/IllegalArgumentException.h>
#include <geos/geom/Coordinate.h>
@@ -45,8 +44,12 @@ using namespace geos::geom;
namespace geos {
namespace io { // geos.io
-WKBWriter::WKBWriter(uint8_t dims, int bo, bool srid):
- defaultOutputDimension(dims), byteOrder(bo), includeSRID(srid), outStream(nullptr)
+WKBWriter::WKBWriter(uint8_t dims, int bo, bool srid, int flv)
+ : defaultOutputDimension(dims)
+ , byteOrder(bo)
+ , flavor(flv)
+ , includeSRID(srid)
+ , outStream(nullptr)
if(dims < 2 || dims > 3) {
throw util::IllegalArgumentException("WKB output dimension must be 2 or 3");
@@ -62,10 +65,22 @@ WKBWriter::setOutputDimension(uint8_t dims)
defaultOutputDimension = dims;
+/* public */
+void
+WKBWriter::setFlavor(int newFlavor)
+ if (newFlavor != WKBConstants::wkbIso &&
+ newFlavor != WKBConstants::wkbExtended) {
+ throw util::IllegalArgumentException("Invalid WKB output flavour");
+ flavor = newFlavor;
void
WKBWriter::writeHEX(const Geometry& g, std::ostream& os)
@@ -83,37 +98,37 @@ void
WKBWriter::write(const Geometry& g, std::ostream& os)
outputDimension = defaultOutputDimension;
- if(outputDimension > g.getCoordinateDimension()) {
+ if (outputDimension > g.getCoordinateDimension()) {
outputDimension = g.getCoordinateDimension();
outStream = &os;
- if(const Point* x = dynamic_cast<const Point*>(&g)) {
+ if (const Point* x = dynamic_cast<const Point*>(&g)) {
return writePoint(*x);
- if(const LineString* x = dynamic_cast<const LineString*>(&g)) {
+ if (const LineString* x = dynamic_cast<const LineString*>(&g)) {
return writeLineString(*x);
- if(const Polygon* x = dynamic_cast<const Polygon*>(&g)) {
+ if (const Polygon* x = dynamic_cast<const Polygon*>(&g)) {
return writePolygon(*x);
- if(const MultiPoint* x = dynamic_cast<const MultiPoint*>(&g)) {
+ if (const MultiPoint* x = dynamic_cast<const MultiPoint*>(&g)) {
return writeGeometryCollection(*x, WKBConstants::wkbMultiPoint);
- if(const MultiLineString* x = dynamic_cast<const MultiLineString*>(&g)) {
+ if (const MultiLineString* x = dynamic_cast<const MultiLineString*>(&g)) {
return writeGeometryCollection(*x, WKBConstants::wkbMultiLineString);
- if(const MultiPolygon* x = dynamic_cast<const MultiPolygon*>(&g)) {
+ if (const MultiPolygon* x = dynamic_cast<const MultiPolygon*>(&g)) {
return writeGeometryCollection(*x, WKBConstants::wkbMultiPolygon);
- if(const GeometryCollection* x =
+ if (const GeometryCollection* x =
dynamic_cast<const GeometryCollection*>(&g)) {
return writeGeometryCollection(*x, WKBConstants::wkbGeometryCollection);
@@ -138,7 +153,7 @@ WKBWriter::writePointEmpty(const Point& g)
void
WKBWriter::writePoint(const Point& g)
- if(g.isEmpty()) {
+ if (g.isEmpty()) {
return writePointEmpty(g);
@@ -173,7 +188,7 @@ WKBWriter::writePolygon(const Polygon& g)
writeGeometryType(WKBConstants::wkbPolygon, g.getSRID());
writeSRID(g.getSRID());
- if(g.isEmpty()) {
writeInt(0);
return;
@@ -256,20 +271,35 @@ WKBWriter::setByteOrder(int bo)
void
WKBWriter::writeGeometryType(int typeId, int SRID)
- int flag3D = (outputDimension == 3) ? int(0x80000000) : 0;
- int typeInt = typeId | flag3D;
- if(includeSRID && SRID != 0) {
- typeInt = typeInt | 0x20000000;
+ if (flavor == WKBConstants::wkbExtended) {
+ int flag3D = (outputDimension == 3) ? int(0x80000000) : 0;
+ typeId |= flag3D;
+ if(includeSRID && SRID != 0) {
+ typeId |= 0x20000000;
- writeInt(typeInt);
+ else if (flavor == WKBConstants::wkbIso) {
+ if (outputDimension == 3) {
+ typeId += 1000;
+ else {
+ throw util::IllegalArgumentException("Unknown WKB flavor");
+ writeInt(typeId);
void
WKBWriter::writeSRID(int SRID)
+ // Only write the SRID in if
+ // it is requested and
+ // it is non zero and
+ // the format is extended (ISO doesn't support SRID embedding)
+ if (includeSRID &&
+ SRID != 0 &&
+ flavor == WKBConstants::wkbExtended)
writeInt(SRID);
diff --git a/tests/unit/capi/GEOSGeomToWKBTest.cpp b/tests/unit/capi/GEOSGeomToWKBTest.cpp
new file mode 100644
index 0000000..5a349e9
--- /dev/null
+++ b/tests/unit/capi/GEOSGeomToWKBTest.cpp
@@ -0,0 +1,204 @@
+// Test Suite for C-API GEOSGeomToWKB
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <string>
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <memory>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capigeosgeomtowkb_data : public capitest::utility {
+ void
+ test_wkb(const std::string& wkt, int flavor)
+ geom1_ = GEOSGeomFromWKT(wkt.c_str());
+ ensure(nullptr != geom1_);
+ GEOSWKBWriter* wkbwriter = GEOSWKBWriter_create();
+ GEOSWKBWriter_setOutputDimension(wkbwriter, 3);
+ GEOSWKBWriter_setFlavor(wkbwriter, flavor);
+ std::size_t wkb_size;
+ unsigned char* wkb = GEOSWKBWriter_write(wkbwriter, geom1_, &wkb_size);
+ GEOSWKBWriter_destroy(wkbwriter);
+ GEOSWKBReader* wkbreader = GEOSWKBReader_create();
+ geom2_ = GEOSWKBReader_read(wkbreader, wkb, wkb_size);
+ GEOSWKBReader_destroy(wkbreader);
+ free(wkb);
+ GEOSWKTWriter* wktwriter = GEOSWKTWriter_create();
+ GEOSWKTWriter_setRoundingPrecision(wktwriter, 3);
+ GEOSWKTWriter_setTrim(wktwriter, 1);
+ GEOSWKTWriter_setOutputDimension(wktwriter, 3);
+ char* wkt_c = GEOSWKTWriter_write(wktwriter, geom2_);
+ GEOSWKTWriter_destroy(wktwriter);
+ std::string out(wkt_c);
+ free(wkt_c);
+ ensure_equals(out, wkt);
+ void
+ test_wkb(const std::string& wkt)
+ test_wkb(wkt, GEOS_WKB_EXTENDED);
+typedef test_group<test_capigeosgeomtowkb_data> group;
+typedef group::object object;
+group test_capigeosgeomtowkb_group("capi::GEOSGeomToWKB");
+// Test Cases
+template<>
+template<>
+void object::test<1>
+ test_wkb("POINT EMPTY");
+template<>
+template<>
+void object::test<2>
+ test_wkb("LINESTRING EMPTY");
+template<>
+template<>
+void object::test<3>
+ test_wkb("POLYGON EMPTY");
+template<>
+template<>
+void object::test<4>
+ test_wkb("MULTIPOINT EMPTY");
+template<>
+template<>
+void object::test<5>
+ test_wkb("MULTILINESTRING EMPTY");
+template<>
+template<>
+void object::test<6>
+ test_wkb("MULTIPOLYGON EMPTY");
+// Comparing string based on float-point numbers does not make sense,
+// so make poor-man comparison of WKT type tag.
+template<>
+template<>
+void object::test<7>
+ test_wkb("POINT (1 2)");
+template<>
+template<>
+void object::test<8>
+ test_wkb("LINESTRING (0 0, 5 5, 10 5, 10 10)");
+template<>
+template<>
+void object::test<9>
+ test_wkb("POLYGON ((0 10, 5 5, 10 5, 15 10, 10 15, 5 15, 0 10))");
+template<>
+template<>
+void object::test<10>
+ test_wkb("MULTIPOINT (0 0, 5 5, 10 10, 15 15, 20 20)");
+template<>
+template<>
+void object::test<11>
+ test_wkb("MULTILINESTRING ((0 0, 10 0, 10 10, 0 10, 10 20), (2 2, 2 6, 6 4, 20 2))");
+template<>
+template<>
+void object::test<12>
+ test_wkb("MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0), (2 2, 2 6, 6 4, 2 2)), ((60 60, 60 50, 70 40, 60 60)))");
+template<>
+template<>
+void object::test<13>
+ test_wkb("POINT Z (1 2 3)");
+template<>
+template<>
+void object::test<14>
+ test_wkb("LINESTRING Z (1 2 3, 4 5 6, 7 8 9)");
+template<>
+template<>
+void object::test<15>
+ test_wkb("POINT Z (1 2 3)", GEOS_WKB_ISO);
+template<>
+template<>
+void object::test<16>
+ test_wkb("LINESTRING Z (1 2 3, 4 5 6, 7 8 9)", GEOS_WKB_ISO);
+} // namespace tut
diff --git a/tests/unit/io/WKBWriterTest.cpp b/tests/unit/io/WKBWriterTest.cpp
index fae8fbc..1c17118 100644
--- a/tests/unit/io/WKBWriterTest.cpp
+++ b/tests/unit/io/WKBWriterTest.cpp
@@ -8,6 +8,7 @@
#include <geos/io/WKTReader.h>
#include <geos/io/WKTWriter.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
@@ -263,7 +264,43 @@ void object::test<9>
assert(geom->equals(geom2.get()));
+// Test writing a 3D geometry with the WKBWriter in ISO flavor
+template<>
+template<>
+ auto geom = wktreader.read("POINT(-117 33 11)");
+ std::stringstream result_stream;
+ wkbwriter.setOutputDimension(3);
+ wkbwriter.setFlavor(geos::io::WKBConstants::wkbIso);
+ wkbwriter.write(*geom, result_stream);
+ wkbwriter.setByteOrder(0);
+ ensure(result_stream.str().length() == 29);
+ result_stream.seekg(0);
+ geom = wkbreader.read(result_stream);
+ ensure(geom->getCoordinateDimension() == 3);
+ ensure(geom->getCoordinate()->x == -117.0);
+ ensure(geom->getCoordinate()->y == 33.0);
+ ensure(geom->getCoordinate()->z == 11.0);
+ result_stream.str("");
+ wkbwriter.writeHEX(*geom, result_stream);
+ std::string actual = result_stream.str();
+ // std::cout << std::endl << actual << std::endl;
+ // 00 == big endian
+ // 000003E9 == 1001
+ // C05D400000000000 == -117
+ // 4040800000000000 == 33
+ // 4026000000000000 == 11
+ ensure_equals(actual,
+ "00000003E9C05D40000000000040408000000000004026000000000000");
} // namespace tut
Summary of changes:
NEWS | 2 +
capi/geos_c.cpp | 12 ++
capi/geos_c.h.in | 58 +++++++++-
capi/geos_ts_c.cpp | 16 +++
include/geos/io/WKBConstants.h | 35 +++---
include/geos/io/WKBWriter.h | 41 +++++--
src/io/WKBWriter.cpp | 74 ++++++++----
tests/unit/capi/GEOSGeomToWKBTest.cpp | 204 ++++++++++++++++++++++++++++++++++
tests/unit/io/WKBWriterTest.cpp | 37 ++++++
9 files changed, 431 insertions(+), 48 deletions(-)
create mode 100644 tests/unit/capi/GEOSGeomToWKBTest.cpp
hooks/post-receive
More information about the geos-commits
